moab::WriteCCMIO Member List
This is the complete list of members for moab::WriteCCMIO, including all inherited members.
close_and_compress(const char *filename, CCMIOID rootID)moab::WriteCCMIO [private]
create_ccmio_structure(CCMIOID rootID, CCMIOID &stateID, CCMIOID &processorID)moab::WriteCCMIO [private]
factory(Interface *)moab::WriteCCMIO [static]
fileNamemoab::WriteCCMIO [private]
gather_matset_info(std::vector< EntityHandle > &matsets, std::vector< MaterialSetData > &matset_data, Range &all_verts)moab::WriteCCMIO [private]
gather_neuset_info(std::vector< EntityHandle > &neusets, std::vector< NeumannSetData > &neuset_data)moab::WriteCCMIO [private]
get_gids(const Range &ents, int *&gids, int &minid, int &maxid)moab::WriteCCMIO [private]
get_neuset_elems(EntityHandle neuset, int current_sense, Range &forward_elems, Range &reverse_elems)moab::WriteCCMIO [private]
get_sets(const EntityHandle *ent_handles, int num_sets, std::vector< EntityHandle > &matsets, std::vector< EntityHandle > &dirsets, std::vector< EntityHandle > &neusets, std::vector< EntityHandle > &partsets)moab::WriteCCMIO [private]
get_valid_sides(Range &elems, const int sense, WriteCCMIO::NeumannSetData &neuset_data)moab::WriteCCMIO [private]
initialize_file(MeshInfo &mesh_info)moab::WriteCCMIO [private]
mbImplmoab::WriteCCMIO [private]
mBoundaryTypeTagmoab::WriteCCMIO [private]
mColorIdxTagmoab::WriteCCMIO [private]
mCreatingProgramTagmoab::WriteCCMIO [private]
mCurrentMeshHandlemoab::WriteCCMIO [private]
mDimensionmoab::WriteCCMIO [private]
mDirichletSetTagmoab::WriteCCMIO [private]
mEntityMarkmoab::WriteCCMIO [private]
mFreeSurfaceMaterialTagmoab::WriteCCMIO [private]
mGlobalIdTagmoab::WriteCCMIO [private]
mGroupIdTagmoab::WriteCCMIO [private]
mHasMidNodesTagmoab::WriteCCMIO [private]
mLightMaterialTagmoab::WriteCCMIO [private]
mMaterialIdTagmoab::WriteCCMIO [private]
mMaterialSetTagmoab::WriteCCMIO [private]
mMaterialTypeTagmoab::WriteCCMIO [private]
mNameTagmoab::WriteCCMIO [private]
mNeumannSetTagmoab::WriteCCMIO [private]
moab_to_ccmio_type(EntityType etype, int has_mid_nodes[])moab::WriteCCMIO [private]
mPartitionSetTagmoab::WriteCCMIO [private]
mPorosityIdTagmoab::WriteCCMIO [private]
mProcessorIdTagmoab::WriteCCMIO [private]
mProstarRegionNumberTagmoab::WriteCCMIO [private]
mRadiationTagmoab::WriteCCMIO [private]
mSpinIdTagmoab::WriteCCMIO [private]
mThicknessTagmoab::WriteCCMIO [private]
mWholeMeshmoab::WriteCCMIO [private]
mWriteIfacemoab::WriteCCMIO [private]
open_file(const char *filename, bool overwrite, CCMIOID &rootID)moab::WriteCCMIO [protected]
reset_matset(std::vector< MaterialSetData > &matset_info)moab::WriteCCMIO [private]
transform_coords(const int dimension, const int num_nodes, double *coords)moab::WriteCCMIO [private]
write_cells_and_faces(CCMIOID rootID, std::vector< WriteCCMIO::MaterialSetData > &matset_data, std::vector< WriteCCMIO::NeumannSetData > &neuset_data, Range &verts, CCMIOID &topologyID)moab::WriteCCMIO [private]
write_dbl_option(const char *opt_name, EntityHandle seth, Tag &tag, CCMIOID &node)moab::WriteCCMIO [private]
write_external_faces(CCMIOID rootID, CCMIOID topologyID, int set_num, Range &facets)moab::WriteCCMIO [private]
write_file(const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3)moab::WriteCCMIO [virtual]
write_int_option(const char *opt_name, EntityHandle seth, Tag &tag, CCMIOID &node)moab::WriteCCMIO [private]
write_meshes(MeshInfo &mesh_info, std::vector< MaterialSetData > &matset_data, std::vector< NeumannSetData > &neuset_data, Range &verts, const int *vgids)moab::WriteCCMIO [private]
write_nodes(CCMIOID rootID, const Range &nodes, const int dimension, CCMIOID &verticesID)moab::WriteCCMIO [private]
write_problem_description(CCMIOID rootID, CCMIOID stateID, CCMIOID &problemID, CCMIOID processorID, std::vector< MaterialSetData > &matset_data, std::vector< NeumannSetData > &neuset_data)moab::WriteCCMIO [private]
write_processor(CCMIOID processorID, CCMIOID verticesID, CCMIOID topologyID)moab::WriteCCMIO [private]
write_solution_data()moab::WriteCCMIO [private]
write_str_option(const char *opt_name, EntityHandle seth, Tag &tag, CCMIOID &node, const char *other_name=NULL)moab::WriteCCMIO [private]
WriteCCMIO(Interface *impl)moab::WriteCCMIO
~WriteCCMIO()moab::WriteCCMIO [virtual]
~WriterIface()moab::WriterIface [inline, virtual]
