moab::WriteSTL Class Reference
ASCII and Binary Stereo Lithography File writers. More...
#include <WriteSTL.hpp>
+ Inheritance diagram for moab::WriteSTL:
+ Collaboration diagram for moab::WriteSTL:
Public Member Functions
 WriteSTL (Interface *impl)
 Constructor.
virtual ~WriteSTL ()
 Destructor.
ErrorCode write_file (const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3)
 writes out a file
Static Public Member Functions
static WriterIfacefactory (Interface *)
 factory method forSTL writer
Protected Types
enum  ByteOrder { STL_BIG_ENDIAN, STL_LITTLE_ENDIAN, STL_UNKNOWN_BYTE_ORDER }
Protected Member Functions
ErrorCode ascii_write_triangles (FILE *file, const char header[81], const Range &triangles, int precision)
 Write list of triangles to an STL file.
ErrorCode binary_write_triangles (FILE *file, const char header[81], ByteOrder byte_order, const Range &triangles)
ErrorCode get_triangle_data (const double vtx_coords[9], float v1[3], float v2[3], float v3[3], float n[3])
 Given an array of vertex coordinates for a triangle, pass back individual point coordinates as floats and calculate triangle normal.
ErrorCode get_triangle_data (const double vtx_coords[9], CartVect &v1, CartVect &v2, CartVect &v3, CartVect &n)
Protected Attributes
InterfacembImpl
 interface instance
WriteUtilIfacemWriteIface
Private Member Functions
ErrorCode make_header (char header[81], const std::vector< std::string > &qa_list)
 Construct 80-byte, null-terminated description string from qa_list. Unused space in header will be null-char padded.
ErrorCode get_triangles (const EntityHandle *set_array, int set_array_length, Range &triangles)
 Get triangles to write from input array of entity sets. If no sets, gets all triangles.
FILE * open_file (const char *name, bool overwrite, bool binary)
 Open a file, respecting passed overwrite value and subclass-specified value for need_binary_io().
Detailed Description
Author:
Jason Kraftcheck
This writer will write only the MBTRI elements in the mesh. It will not decompose other 2-D elements into triangles, nor will it skin the mesh or do any other high-level operation to generate triangles from 3-D elements.
Binary files will be written with a little-endian byte order by default. The byte order can be controlled with writer options.
Definition at line 42 of file WriteSTL.hpp.
Member Enumeration Documentation
enum moab::WriteSTL::ByteOrder [protected]
Enumerator:
STL_BIG_ENDIAN
STL_LITTLE_ENDIAN
Definition at line 67 of file WriteSTL.hpp.
Constructor.
Definition at line 59 of file WriteSTL.cpp.
References mWriteIface, and moab::Interface::query_interface().
Referenced by factory().
                                    : mbImpl( impl )
    impl->query_interface( mWriteIface );
WriteSTL::~WriteSTL ( ) [virtual]
Destructor.
Definition at line 64 of file WriteSTL.cpp.
References mbImpl, mWriteIface, and moab::Interface::release_interface().
Member Function Documentation
ErrorCode WriteSTL::ascii_write_triangles ( FILE *  file,
const Range triangles,
int  precision
) [protected]
Definition at line 234 of file WriteSTL.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), get_triangle_data(), MB_FILE_WRITE_ERROR, MB_SUCCESS, and mbImpl.
Referenced by write_file().
    const char solid_name[] = "MOAB";
    char myheader[81] = "solid ";
    strcat( myheader, solid_name );
    strncat( myheader, header, 80 );
    if( EOF == fputs( myheader, file ) || EOF == fputs( "\n", file ) ) return MB_FILE_WRITE_ERROR;
    ErrorCode rval;
    double coords[9];
    CartVect v1, v2, v3, n;
    for( Range::const_iterator iter = triangles.begin(); iter != triangles.end(); ++iter )
        const EntityHandle* conn;
        int num_vtx;
        rval = mbImpl->get_connectivity( *iter, conn, num_vtx );
        if( MB_SUCCESS != rval ) return rval;
        if( num_vtx != 3 ) return MB_FAILURE;
        rval = mbImpl->get_coords( conn, 3, coords );
        rval = get_triangle_data( coords, v1, v2, v3, n );
        fprintf( file, "facet normal %e %e %e\n", n[0], n[1], n[2] );
        fprintf( file, "outer loop\n" );
        fprintf( file, "vertex %.*e %.*e %.*e\n", prec, (float)v1[0], prec, (float)v1[1], prec, (float)v1[2] );
        fprintf( file, "vertex %.*e %.*e %.*e\n", prec, (float)v2[0], prec, (float)v2[1], prec, (float)v2[2] );
        fprintf( file, "vertex %.*e %.*e %.*e\n", prec, (float)v3[0], prec, (float)v3[1], prec, (float)v3[2] );
        fprintf( file, "endloop\n" );
        fprintf( file, "endfacet\n" );
    fprintf( file, "endsolid %s\n", solid_name );
    return MB_SUCCESS;
ErrorCode WriteSTL::binary_write_triangles ( FILE *  file,
) [protected]
Definition at line 284 of file WriteSTL.cpp.
References moab::Range::begin(), moab::SysUtil::byteswap(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), get_triangle_data(), moab::SysUtil::little_endian(), MB_FILE_WRITE_ERROR, MB_SUCCESS, mbImpl, moab::BinTri::normal, moab::BinTri::pad, moab::Range::size(), STL_BIG_ENDIAN, moab::SysUtil::swap_bytes(), moab::BinTri::vertex1, moab::BinTri::vertex2, and moab::BinTri::vertex3.
    ErrorCode rval;
    if( 1 != fwrite( header, 80, 1, file ) ) return MB_FILE_WRITE_ERROR;
    // Default to little endian if byte_order == UNKNOWN_BYTE_ORDER
    const bool want_big_endian = ( byte_order == STL_BIG_ENDIAN );
    const bool am_big_endian   = !SysUtil::little_endian();
    const bool swap_bytes      = ( want_big_endian == am_big_endian );
    if( triangles.size() > INT_MAX )  // Can't write that many triangles
        return MB_FAILURE;
    uint32_t count = (uint32_t)triangles.size();
    if( swap_bytes ) SysUtil::byteswap( &count, 1 );
    if( 1 != fwrite( &count, 4, 1, file ) ) return MB_FILE_WRITE_ERROR;
    double coords[9];
    BinTri tri;
    tri.pad[0] = tri.pad[1] = '\0';
        int num_vtx;
        rval = get_triangle_data( coords, tri.vertex1, tri.vertex2, tri.vertex3, tri.normal );
        if( swap_bytes )
            SysUtil::byteswap( tri.normal, 3 );
            SysUtil::byteswap( tri.vertex1, 3 );
            SysUtil::byteswap( tri.vertex2, 3 );
            SysUtil::byteswap( tri.vertex3, 3 );
        if( 1 != fwrite( &tri, 50, 1, file ) ) return MB_FILE_WRITE_ERROR;
    return MB_SUCCESS;
WriterIface * WriteSTL::factory ( Interface iface) [static]
Definition at line 54 of file WriteSTL.cpp.
References WriteSTL().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new WriteSTL( iface );
ErrorCode WriteSTL::get_triangle_data ( const double  vtx_coords[9],
float  v1[3],
float  v2[3],
float  v3[3],
float  n[3]
) [protected]
Definition at line 207 of file WriteSTL.cpp.
References ErrorCode, moab::CartVect::get(), and MB_SUCCESS.
Referenced by ascii_write_triangles(), and binary_write_triangles().
    CartVect cv1, cv2, cv3, cn;
    ErrorCode rval = get_triangle_data( coords, cv1, cv2, cv3, cn );
    cv1.get( v1 );
    cv2.get( v2 );
    cv3.get( v3 );
    cn.get( n );
    return MB_SUCCESS;
CartVect v1,
CartVect v2,
CartVect v3,
CartVect n
) [protected]
Definition at line 221 of file WriteSTL.cpp.
References MB_SUCCESS, and moab::CartVect::normalize().
    v1 = coords;
    v2 = coords + 3;
    v3 = coords + 6;
    n = ( v2 - v1 ) * ( v3 - v1 );
    n.normalize();
    return MB_SUCCESS;
ErrorCode WriteSTL::get_triangles ( const EntityHandle set_array,
Range triangles
) [private]
Definition at line 190 of file WriteSTL.cpp.
References ErrorCode, moab::Interface::get_entities_by_type(), MB_SUCCESS, mbImpl, MBTRI, and moab::Range::merge().
    if( !set_array || 0 == set_array_length ) return mbImpl->get_entities_by_type( 0, MBTRI, triangles );
    const EntityHandle* iter = set_array;
    const EntityHandle* end  = iter + set_array_length;
    for( ; iter != end; ++iter )
        Range r;
        ErrorCode rval = mbImpl->get_entities_by_type( *iter, MBTRI, r, true );
        triangles.merge( r );
    return MB_SUCCESS;
ErrorCode WriteSTL::make_header ( char  header[81],
const std::vector< std::string > &  qa_list
) [private]
Definition at line 172 of file WriteSTL.cpp.
References MB_SUCCESS.
    memset( header, 0, 81 );
    std::string result;
    for( std::vector< std::string >::const_iterator i = qa_list.begin(); i != qa_list.end(); ++i )
        result += " ";
        result += *i;
    size_t len = result.size();
    if( len > 80 ) len = 80;
    memcpy( header, result.c_str(), len );
    return MB_SUCCESS;
FILE * WriteSTL::open_file ( const char *  name,
bool  overwrite,
bool  binary
) [private]
Definition at line 134 of file WriteSTL.cpp.
References _S_IREAD, _S_IWRITE, and MB_SET_ERR_RET_VAL.
    // Open file with write access, and create it if it doesn't exist.
    int flags = O_WRONLY | O_CREAT;
    // Select behavior if the named file already exists. If
    // overwrite is true, truncate the file. If it is false,
    // make the call to open() fail.
    if( overwrite )
        flags |= O_TRUNC;
    else
        flags |= O_EXCL;
        // If platform defines a "binary" bit in the file access
        // flags (i.e. we're building on windows), then set it
        // if we're writing a binary file.
#ifdef O_BINARY
    if( binary ) flags |= O_BINARY;
#endif
    // Give everyone read and write, but not execute, permission.
    // These are not the final permissions for the file. Permissions
    // are removed according to the user's umask. All we want to
    // say here is that the executable bits should not be set because
    // this isn't an executable file. Everything else is a user
    // preference and should be left up to the umask.
    int creat_mode = _S_IREAD | _S_IWRITE;
    // Open the file.
    int fd = open( name, flags, creat_mode );
    if( fd < 0 )
        MB_SET_ERR_RET_VAL( name << ": " << strerror( errno ), NULL );
    FILE* result = fdopen( fd, binary ? "wb" : "w" );
    if( !result ) close( fd );
    return result;
ErrorCode WriteSTL::write_file ( const char *  file_name,
const FileOptions opts,
const EntityHandle output_list,
const int  num_sets,
const std::vector< std::string > &  qa_list,
const Tag tag_list = NULL,
int  num_tags = 0,
int  export_dimension = 3
) [virtual]
writes out a file
Implements moab::WriterIface.
Definition at line 69 of file WriteSTL.cpp.
References ascii_write_triangles(), moab::SysUtil::big_endian(), binary_write_triangles(), moab::DEFAULT_PRECISION, moab::Range::empty(), ErrorCode, moab::FileOptions::get_int_option(), moab::FileOptions::get_null_option(), get_triangles(), moab::SysUtil::little_endian(), make_header(), MB_ENTITY_NOT_FOUND, MB_FILE_DOES_NOT_EXIST, MB_SET_ERR, MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, open_file(), STL_BIG_ENDIAN, STL_LITTLE_ENDIAN, and STL_UNKNOWN_BYTE_ORDER.
    char header[81];
    Range triangles;
    ErrorCode rval;
    if( tag_list && num_tags )
        MB_SET_ERR( MB_TYPE_OUT_OF_RANGE, "STL file does not support tag data" );
    rval = make_header( header, qa_list );
    rval = get_triangles( ent_handles, num_sets, triangles );
    if( triangles.empty() )
        MB_SET_ERR( MB_ENTITY_NOT_FOUND, "No triangles to write" );
    bool is_ascii = false, is_binary = false;
    if( MB_SUCCESS == opts.get_null_option( "ASCII" ) ) is_ascii = true;
    if( MB_SUCCESS == opts.get_null_option( "BINARY" ) ) is_binary = true;
    if( is_ascii && is_binary )
        MB_SET_ERR( MB_FAILURE, "Conflicting options: BINARY ASCII" );
    bool big_endian = false, little_endian = false;
    if( MB_SUCCESS == opts.get_null_option( "BIG_ENDIAN" ) ) big_endian = true;
    if( MB_SUCCESS == opts.get_null_option( "LITTLE_ENDIAN" ) ) little_endian = true;
    if( big_endian && little_endian )
        MB_SET_ERR( MB_FAILURE, "Conflicting options: BIG_ENDIAN LITTLE_ENDIAN" );
    ByteOrder byte_order = big_endian ? STL_BIG_ENDIAN : little_endian ? STL_LITTLE_ENDIAN : STL_UNKNOWN_BYTE_ORDER;
    FILE* file = open_file( file_name, overwrite, is_binary );
    if( !file ) return MB_FILE_DOES_NOT_EXIST;
    if( is_binary )
        rval = binary_write_triangles( file, header, byte_order, triangles );
    else
        // Get precision for node coordinates
        int precision;
        if( MB_SUCCESS != opts.get_int_option( "PRECISION", precision ) ) precision = DEFAULT_PRECISION;
        rval = ascii_write_triangles( file, header, triangles, precision );
    fclose( file );
    return rval;
Member Data Documentation
interface instance
Definition at line 87 of file WriteSTL.hpp.
Referenced by ascii_write_triangles(), binary_write_triangles(), get_triangles(), and ~WriteSTL().
Definition at line 88 of file WriteSTL.hpp.
Referenced by WriteSTL(), and ~WriteSTL().
List of all members.
