moab::WriteVtk Class Reference
#include <WriteVtk.hpp>
+ Inheritance diagram for moab::WriteVtk:
+ Collaboration diagram for moab::WriteVtk:
Public Member Functions
 WriteVtk (Interface *impl)
 Constructor.
virtual ~WriteVtk ()
 Destructor.
ErrorCode write_file (const char *file_name, const bool overwrite, const FileOptions &opts, const EntityHandle *output_list, const int num_sets, const std::vector< std::string > &qa_list, const Tag *tag_list=NULL, int num_tags=0, int export_dimension=3)
 writes out a file
Static Public Member Functions
static WriterIfacefactory (Interface *)
Private Member Functions
ErrorCode gather_mesh (const EntityHandle *set_list, int num_sets, Range &nodes, Range &elems)
 Get entities to write, given set list passed to write_file.
ErrorCode write_header (std::ostream &stream)
 Write 4-line VTK file header.
ErrorCode write_nodes (std::ostream &stream, const Range &nodes)
 Write node coordinates.
ErrorCode write_elems (std::ostream &stream, const Range &nodes, const Range &elems)
 Write element connectivity.
ErrorCode write_tags (std::ostream &stream, bool nodes, const Range &entities, const Tag *tag_list, int num_tags)
 Write all tags on either the list of nodes or the list of elements.
ErrorCode write_tag (std::ostream &stream, Tag tag, const Range &entities, const Range &tagged_entities)
 Write the tad description for the passed tag and call the template write_tag function to write the tag data.
template<typename T >
ErrorCode write_tag (std::ostream &stream, Tag tag, const Range &entities, const Range &tagged_entities, const int)
 Write tag data.
ErrorCode write_bit_tag (std::ostream &stream, Tag tag, const Range &entities, const Range &tagged_entities)
void write_data (std::ostream &stream, const std::vector< T > &data, unsigned vals_per_tag)
 Write a list of values.
Private Attributes
InterfacembImpl
WriteUtilIfacewriteTool
bool mStrict
int freeNodes
bool createOneNodeCells
Detailed Description
Definition at line 30 of file WriteVtk.hpp.
Constructor.
Definition at line 58 of file WriteVtk.cpp.
References moab::Interface::query_interface(), and writeTool.
Referenced by factory().
    : mbImpl( impl ), writeTool( 0 ), mStrict( DEFAULT_STRICT ), freeNodes( 0 ), createOneNodeCells( false )
    assert( impl != NULL );
    impl->query_interface( writeTool );
Destructor.
Definition at line 65 of file WriteVtk.cpp.
References mbImpl, moab::Interface::release_interface(), and writeTool.
Member Function Documentation
Definition at line 53 of file WriteVtk.cpp.
References WriteVtk().
Referenced by moab::ReaderWriterSet::ReaderWriterSet().
    return new WriteVtk( iface );
ErrorCode moab::WriteVtk::gather_mesh ( const EntityHandle set_list,
int  num_sets,
Range nodes,
Range elems
) [private]
Definition at line 129 of file WriteVtk.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::CREATE_HANDLE(), moab::Range::empty(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_connectivity(), moab::Interface::get_entities_by_handle(), moab::VtkUtil::get_vtk_type(), moab::Range::insert(), moab::Range::lower_bound(), MB_ENTITY_NOT_FOUND, MB_SET_ERR, MB_SUCCESS, MBEDGE, MBENTITYSET, mbImpl, MBVERTEX, moab::Range::merge(), and moab::CN::VerticesPerEntity().
Referenced by write_file().
    ErrorCode rval;
    int e;
    if( !set_list || !num_sets )
        Range a;
        rval = mbImpl->get_entities_by_handle( 0, a );
        if( MB_SUCCESS != rval ) return rval;
        Range::const_iterator node_i, elem_i, set_i;
        node_i = a.lower_bound( a.begin(), a.end(), CREATE_HANDLE( MBVERTEX, 0, e ) );
        elem_i = a.lower_bound( node_i, a.end(), CREATE_HANDLE( MBEDGE, 0, e ) );
        set_i  = a.lower_bound( elem_i, a.end(), CREATE_HANDLE( MBENTITYSET, 0, e ) );
        nodes.merge( node_i, elem_i );
        elems.merge( elem_i, set_i );
        // Filter out unsupported element types
        EntityType et = MBEDGE;
        for( et++; et < MBENTITYSET; et++ )
            if( VtkUtil::get_vtk_type( et, CN::VerticesPerEntity( et ) ) ) continue;
            Range::iterator eit   = elems.lower_bound( elems.begin(), elems.end(), CREATE_HANDLE( et, 0, e ) ),
                            ep1it = elems.lower_bound( elems.begin(), elems.end(), CREATE_HANDLE( et + 1, 0, e ) );
            elems.erase( eit, ep1it );
    else
        std::set< EntityHandle > visited;
        std::vector< EntityHandle > sets;
        sets.reserve( num_sets );
        std::copy( set_list, set_list + num_sets, std::back_inserter( sets ) );
        while( !sets.empty() )
            // Get next set
            EntityHandle set = sets.back();
            sets.pop_back();
            // Skip sets we've already done
            if( !visited.insert( set ).second ) continue;
            Range a;
            rval = mbImpl->get_entities_by_handle( set, a );
            std::copy( set_i, a.end(), std::back_inserter( sets ) );
            a.clear();
            rval = mbImpl->get_child_meshsets( set, a );
            std::copy( a.begin(), a.end(), std::back_inserter( sets ) );
        for( Range::const_iterator ei = elems.begin(); ei != elems.end(); ++ei )
            std::vector< EntityHandle > connect;
            rval = mbImpl->get_connectivity( &( *ei ), 1, connect );
            for( unsigned int i = 0; i < connect.size(); ++i )
                nodes.insert( connect[i] );
    if( nodes.empty() )
        MB_SET_ERR( MB_ENTITY_NOT_FOUND, "Nothing to write" );
    return MB_SUCCESS;
ErrorCode moab::WriteVtk::write_bit_tag ( std::ostream &  stream,
Tag  tag,
const Range entities,
const Range tagged_entities
) [private]
Definition at line 552 of file WriteVtk.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, MB_SET_ERR, MB_SUCCESS, mbImpl, moab::Range::size(), t, moab::Interface::tag_get_data(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), and write_data().
Referenced by write_tag().
    ErrorCode rval;
    const unsigned long n = entities.size();
    // Get tag properties
    std::string name;
    int vals_per_tag;
    if( MB_SUCCESS != mbImpl->tag_get_name( tag, name ) || MB_SUCCESS != mbImpl->tag_get_length( tag, vals_per_tag ) )
        return MB_FAILURE;
    if( vals_per_tag > 8 )
        MB_SET_ERR( MB_FAILURE, "Invalid tag size for bit tag \"" << name << "\"" );
    // Get a tag value for each entity.
    // Get bits for each entity and unpack into
    // one integer in the 'data' array for each bit.
    // Initialize 'data' to zero because we will skip
    // those entities for which the tag is not set.
    std::vector< unsigned short > data;
    data.resize( n * vals_per_tag, 0 );
    Range::const_iterator t                   = tagged.begin();
    std::vector< unsigned short >::iterator d = data.begin();
    for( Range::const_iterator i = entities.begin(); i != entities.end() && t != tagged.end(); ++i )
        if( *i == *t )
            ++t;
            unsigned char value;
            rval = mbImpl->tag_get_data( tag, &( *i ), 1, &value );
            for( int j = 0; j < vals_per_tag; ++j, ++d )
                *d = (unsigned short)( value & ( 1 << j ) ? 1 : 0 );
        else
            // If tag is not set for entity, skip values in array
            d += vals_per_tag;
    // Write the tag values, one entity per line.
    write_data( stream, data, vals_per_tag );
    return MB_SUCCESS;
void moab::WriteVtk::write_data ( std::ostream &  stream,
const std::vector< T > &  data,
) [private]
Definition at line 473 of file WriteVtk.cpp.
References T.
Referenced by write_bit_tag(), and write_tag().
    typename std::vector< T >::const_iterator d = data.begin();
    const unsigned long n                       = data.size() / vals_per_tag;
    for( unsigned long i = 0; i < n; ++i )
        for( unsigned j = 0; j < vals_per_tag; ++j, ++d )
            if( sizeof( T ) == 1 )
                stream << (unsigned int)*d << ' ';
            else
                stream << *d << ' ';
        stream << std::endl;
ErrorCode moab::WriteVtk::write_elems ( std::ostream &  stream,
const Range nodes,
const Range elems
) [private]
Definition at line 234 of file WriteVtk.cpp.
References moab::Range::begin(), createOneNodeCells, moab::Range::end(), moab::CN::EntityTypeName(), ErrorCode, freeNodes, moab::Interface::get_connectivity(), moab::VtkUtil::get_vtk_type(), moab::Range::index(), MB_CHK_ERR, MB_SET_ERR, MB_SUCCESS, mbImpl, MBPOLYHEDRON, MBVERTEX, moab::Range::merge(), moab::VtkElemType::node_order, moab::Range::size(), moab::Range::subset_by_type(), moab::subtract(), t, moab::TYPE_FROM_HANDLE(), moab::Interface::type_from_handle(), moab::CN::VerticesPerEntity(), and moab::VtkElemType::vtk_type.
    ErrorCode rval;
    Range connectivity;  // because we now support polyhedra, it could contain faces
    rval = mbImpl->get_connectivity( elems, connectivity );MB_CHK_ERR( rval );
    Range nodes_from_connectivity = connectivity.subset_by_type( MBVERTEX );
    Range faces_from_connectivity =
        subtract( connectivity, nodes_from_connectivity );  // these could be faces of polyhedra
    Range connected_nodes;
    rval = mbImpl->get_connectivity( faces_from_connectivity, connected_nodes );MB_CHK_ERR( rval );
    connected_nodes.merge( nodes_from_connectivity );
    Range free_nodes = subtract( nodes, connected_nodes );
    // Get and write counts
    unsigned long num_elems, num_uses;
    num_elems = num_uses = elems.size();
    std::map< EntityHandle, int > sizeFieldsPolyhedra;
    for( Range::const_iterator i = elems.begin(); i != elems.end(); ++i )
        EntityType type = mbImpl->type_from_handle( *i );
        if( !VtkUtil::get_vtk_type( type, CN::VerticesPerEntity( type ) ) ) continue;
        EntityHandle elem           = *i;
        const EntityHandle* connect = NULL;
        int conn_len                = 0;
        // Dummy storage vector for structured mesh "get_connectivity" function
        std::vector< EntityHandle > storage;
        rval = mbImpl->get_connectivity( elem, connect, conn_len, false, &storage );MB_CHK_ERR( rval );
        num_uses += conn_len;
        // if polyhedra, we will count the number of nodes in each face too
        if( TYPE_FROM_HANDLE( elem ) == MBPOLYHEDRON )
            int numFields = 1;  // there will be one for number of faces; forgot about this one
            for( int j = 0; j < conn_len; j++ )
                const EntityHandle* conn = NULL;
                int num_nd               = 0;
                rval                     = mbImpl->get_connectivity( connect[j], conn, num_nd );MB_CHK_ERR( rval );
                numFields += num_nd + 1;
            sizeFieldsPolyhedra[elem] = numFields;  // will be used later, at writing
            num_uses += ( numFields - conn_len );
    freeNodes = (int)free_nodes.size();
    if( !createOneNodeCells ) freeNodes = 0;  // do not create one node cells
    stream << "CELLS " << num_elems + freeNodes << ' ' << num_uses + 2 * freeNodes << std::endl;
    // Write element connectivity
    std::vector< int > conn_data;
    std::vector< unsigned > vtk_types( elems.size() + freeNodes );
    std::vector< unsigned >::iterator t = vtk_types.begin();
        // Get type information for element
        EntityType type   = TYPE_FROM_HANDLE( elem );
        // Get element connectivity
        int conn_len                = 0;
        // Get VTK type
        const VtkElemType* vtk_type = VtkUtil::get_vtk_type( type, conn_len );
        if( !vtk_type )
            // Try connectivity with 1 fewer node
            vtk_type = VtkUtil::get_vtk_type( type, conn_len - 1 );
            if( vtk_type )
                conn_len--;
            else
                MB_SET_ERR( MB_FAILURE, "Vtk file format does not support elements of type "
                                            << CN::EntityTypeName( type ) << " (" << (int)type << ") with " << conn_len
                                            << " nodes" );
        // Save VTK type index for later
        *t = vtk_type->vtk_type;
        ++t;
        if( type != MBPOLYHEDRON )
            // Get IDs from vertex handles
            assert( conn_len > 0 );
            conn_data.resize( conn_len );
            for( int j = 0; j < conn_len; ++j )
                conn_data[j] = nodes.index( connect[j] );
            // Write connectivity list
            stream << conn_len;
            if( vtk_type->node_order )
                for( int k = 0; k < conn_len; ++k )
                    stream << ' ' << conn_data[vtk_type->node_order[k]];
            else
                    stream << ' ' << conn_data[k];
        else
            // POLYHEDRON needs a special case, loop over faces to get nodes
            stream << sizeFieldsPolyhedra[elem] << " " << conn_len;
            for( int k = 0; k < conn_len; k++ )
                EntityHandle face        = connect[k];
                int num_nodes            = 0;
                rval                     = mbImpl->get_connectivity( face, conn, num_nodes );MB_CHK_ERR( rval );
                //        num_uses += num_nd + 1; // 1 for number of vertices in face
                conn_data.resize( num_nodes );
                for( int j = 0; j < num_nodes; ++j )
                    conn_data[j] = nodes.index( conn[j] );
                stream << ' ' << num_nodes;
                    stream << ' ' << conn_data[j];
    if( createOneNodeCells )
        for( Range::const_iterator v = free_nodes.begin(); v != free_nodes.end(); ++v, ++t )
            EntityHandle node = *v;
            stream << "1 " << nodes.index( node ) << std::endl;
            *t = 1;
    // Write element types
    stream << "CELL_TYPES " << vtk_types.size() << std::endl;
    for( std::vector< unsigned >::const_iterator i = vtk_types.begin(); i != vtk_types.end(); ++i )
        stream << *i << std::endl;
    return MB_SUCCESS;
ErrorCode moab::WriteVtk::write_file ( const char *  file_name,
const FileOptions opts,
const EntityHandle output_list,
const int  num_sets,
const std::vector< std::string > &  qa_list,
const Tag tag_list = NULL,
int  num_tags = 0,
int  export_dimension = 3
) [virtual]
writes out a file
Implements moab::WriterIface.
Definition at line 70 of file WriteVtk.cpp.
References moab::WriteUtilIface::check_doesnt_exist(), createOneNodeCells, moab::DEFAULT_PRECISION, moab::DEFAULT_STRICT, ErrorCode, gather_mesh(), moab::FileOptions::get_int_option(), moab::FileOptions::get_null_option(), MB_FILE_WRITE_ERROR, MB_SET_ERR, MB_SUCCESS, mStrict, write_elems(), write_header(), write_nodes(), write_tags(), and writeTool.
Referenced by moab::Core::write_file().
    ErrorCode rval;
    // Get precision for node coordinates
    int precision;
    if( MB_SUCCESS != opts.get_int_option( "PRECISION", precision ) ) precision = DEFAULT_PRECISION;
    if( MB_SUCCESS == opts.get_null_option( "STRICT" ) )
        mStrict = true;
    else if( MB_SUCCESS == opts.get_null_option( "RELAXED" ) )
        mStrict = false;
    else
        mStrict = DEFAULT_STRICT;
    if( MB_SUCCESS == opts.get_null_option( "CREATE_ONE_NODE_CELLS" ) ) createOneNodeCells = true;
    // Get entities to write
    Range nodes, elems;
    rval = gather_mesh( output_list, num_sets, nodes, elems );
    // Honor overwrite flag
    if( !overwrite )
        rval = writeTool->check_doesnt_exist( file_name );
    // Create file
    std::ofstream file( file_name );
    if( !file )
        MB_SET_ERR( MB_FILE_WRITE_ERROR, "Could not open file: " << file_name );
    file.precision( precision );
    // Write file
    if( ( rval = write_header( file ) ) != MB_SUCCESS || ( rval = write_nodes( file, nodes ) ) != MB_SUCCESS ||
        ( rval = write_elems( file, nodes, elems ) ) != MB_SUCCESS ||
        ( rval = write_tags( file, true, nodes, tag_list, num_tags ) ) != MB_SUCCESS ||
        ( rval = write_tags( file, false, elems, tag_list, num_tags ) ) != MB_SUCCESS )
        file.close();
        remove( file_name );
        return rval;
    return MB_SUCCESS;
ErrorCode moab::WriteVtk::write_header ( std::ostream &  stream) [private]
Definition at line 207 of file WriteVtk.cpp.
References MB_SUCCESS.
    stream << "# vtk DataFile Version 3.0" << std::endl;
    stream << MOAB_VERSION_STRING << std::endl;
    stream << "ASCII" << std::endl;
    stream << "DATASET UNSTRUCTURED_GRID" << std::endl;
    return MB_SUCCESS;
ErrorCode moab::WriteVtk::write_nodes ( std::ostream &  stream,
const Range nodes
) [private]
Definition at line 216 of file WriteVtk.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_coords(), MB_SUCCESS, mbImpl, and moab::Range::size().
    ErrorCode rval;
    stream << "POINTS " << nodes.size() << " double" << std::endl;
    double coords[3];
    for( Range::const_iterator i = nodes.begin(); i != nodes.end(); ++i )
        coords[1] = coords[2] = 0.0;
        rval                  = mbImpl->get_coords( &( *i ), 1, coords );
        stream << coords[0] << ' ' << coords[1] << ' ' << coords[2] << std::endl;
    return MB_SUCCESS;
ErrorCode moab::WriteVtk::write_tag ( std::ostream &  stream,
Tag  tag,
) [private]
Definition at line 602 of file WriteVtk.cpp.
References entities, MB_SUCCESS, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, mbImpl, moab::Interface::tag_get_data_type(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::VtkUtil::vtkTypeNames, and write_bit_tag().
Referenced by write_tags().
    std::string name;
    DataType type;
    int vals_per_tag;
    if( MB_SUCCESS != mbImpl->tag_get_name( tag, name ) || MB_SUCCESS != mbImpl->tag_get_length( tag, vals_per_tag ) ||
        MB_SUCCESS != mbImpl->tag_get_data_type( tag, type ) )
        return MB_FAILURE;
    // Skip tags of type ENTITY_HANDLE
    if( MB_TYPE_HANDLE == type ) return MB_FAILURE;
    // Now that we're past the point where the name would be used in
    // an error message, remove any spaces to conform to VTK file.
    for( std::string::iterator i = name.begin(); i != name.end(); ++i )
        if( isspace( *i ) || iscntrl( *i ) ) *i = '_';
    // Write the tag description
    if( 3 == vals_per_tag && MB_TYPE_DOUBLE == type )
        s << "VECTORS " << name << ' ' << VtkUtil::vtkTypeNames[type] << std::endl;
    else if( 9 == vals_per_tag )
        s << "TENSORS " << name << ' ' << VtkUtil::vtkTypeNames[type] << std::endl;
    else
        s << "SCALARS " << name << ' ' << VtkUtil::vtkTypeNames[type] << ' ' << vals_per_tag << std::endl
          << "LOOKUP_TABLE default" << std::endl;
    // Write the tag data
    switch( type )
        case MB_TYPE_OPAQUE:
            return write_tag< unsigned char >( s, tag, entities, tagged, 0 );
        case MB_TYPE_INTEGER:
            return write_tag< int >( s, tag, entities, tagged, 0 );
        case MB_TYPE_DOUBLE:
            return write_tag< double >( s, tag, entities, tagged, 0 );
        case MB_TYPE_BIT:
            return write_bit_tag( s, tag, entities, tagged );
        default:
            return MB_FAILURE;
Tag  tag,
const Range tagged_entities,
const int
) [private]
Write tag data.
Definition at line 507 of file WriteVtk.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, freeNodes, MB_SUCCESS, mbImpl, MBVERTEX, moab::SysUtil::setmem(), moab::Range::size(), t, T, moab::Interface::tag_get_data(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_length(), moab::Interface::tag_get_name(), moab::TYPE_FROM_HANDLE(), and write_data().
    ErrorCode rval;
    int addFreeNodes = 0;
    if( TYPE_FROM_HANDLE( entities[0] ) > MBVERTEX ) addFreeNodes = freeNodes;
    // we created freeNodes 1-node cells, so we have to augment cell data too
    // we know that the 1 node cells are added at the end, after all other cells;
    // so the default values will be set to those extra , artificial cells
    const unsigned long n = entities.size() + addFreeNodes;
    std::string name;
    int vals_per_tag;
        return MB_FAILURE;
    // Get a tag value for each entity. Do this by initializing the
    // "data" vector with zero, and then filling in the values for
    // the entities that actually have the tag set.
    std::vector< T > data;
    // If there is a default value for the tag, set the actual default value
    std::vector< T > def_value( vals_per_tag );
    rval = mbImpl->tag_get_default_value( tag, &( def_value[0] ) );
    if( MB_SUCCESS == rval ) SysUtil::setmem( &( data[0] ), &( def_value[0] ), vals_per_tag * sizeof( T ), n );
    typename std::vector< T >::iterator d = data.begin();
    for( Range::const_iterator i = entities.begin(); i != entities.end() && t != tagged.end(); ++i, d += vals_per_tag )
        if( *i == *t )
            ++t;
            rval = mbImpl->tag_get_data( tag, &( *i ), 1, &( *d ) );
    return MB_SUCCESS;
ErrorCode moab::WriteVtk::write_tags ( std::ostream &  stream,
bool  nodes,
const Tag tag_list,
int  num_tags
) [private]
Definition at line 384 of file WriteVtk.cpp.
References moab::Range::empty(), ErrorCode, freeNodes, moab::Interface::get_entities_by_type_and_tag(), moab::WriteUtilIface::get_tag_list(), moab::intersect(), MB_SUCCESS, MB_TYPE_HANDLE, MBEDGE, MBENTITYSET, mbImpl, MBVERTEX, moab::Range::merge(), mStrict, moab::Range::size(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_length(), write_tag(), and writeTool.
    ErrorCode rval;
    // The #$%@#$% MOAB interface does not have a function to retrieve
    // all entities with a tag, only all entities with a specified type
    // and tag. Define types to loop over depending on the if vertex
    // or element tag data is being written. It seems horribly inefficient
    // to have the implementation subdivide the results by type and have
    // to call that function once for each type just to recombine the results.
    // Unfortunately, there doesn't seem to be any other way.
    EntityType low_type, high_type;
    if( nodes )
        low_type  = MBVERTEX;
        high_type = MBEDGE;
    else
        low_type  = MBEDGE;
        high_type = MBENTITYSET;
    // Get all defined tags
    std::vector< Tag > tags;
    std::vector< Tag >::iterator i;
    rval = writeTool->get_tag_list( tags, tag_list, num_tags, false );
    // For each tag...
    bool entities_have_tags = false;
    for( i = tags.begin(); i != tags.end(); ++i )
        // Skip tags holding entity handles -- no way to save them
        DataType dtype;
        rval = mbImpl->tag_get_data_type( *i, dtype );
        if( dtype == MB_TYPE_HANDLE ) continue;
        // If in strict mode, don't write tags that do not fit in any
        // attribute type (SCALAR : 1 to 4 values, VECTOR : 3 values, TENSOR : 9 values)
        if( mStrict )
            int count;
            rval = mbImpl->tag_get_length( *i, count );
            if( count < 1 || ( count > 4 && count != 9 ) ) continue;
        // Get subset of input entities that have the tag set
        Range tagged;
        for( EntityType type = low_type; type < high_type; ++type )
            Range tmp_tagged;
            rval = mbImpl->get_entities_by_type_and_tag( 0, type, &( *i ), 0, 1, tmp_tagged );
            tmp_tagged = intersect( tmp_tagged, entities );
            tagged.merge( tmp_tagged );
        // If any entities were tagged
        if( !tagged.empty() )
            // If this is the first tag being written for the
            // entity type, write the label marking the beginning
            // of the tag data.
            if( !entities_have_tags )
                entities_have_tags = true;
                if( nodes )
                    stream << "POINT_DATA " << entities.size() << std::endl;
                else
                    stream << "CELL_DATA " << entities.size() + freeNodes << std::endl;
            // Write the tag
            rval = write_tag( stream, *i, entities, tagged );
    return MB_SUCCESS;
Member Data Documentation
Definition at line 91 of file WriteVtk.hpp.
Referenced by write_elems(), and write_file().
Definition at line 90 of file WriteVtk.hpp.
Referenced by write_elems(), write_tag(), and write_tags().
bool moab::WriteVtk::mStrict [private]
Definition at line 89 of file WriteVtk.hpp.
Referenced by write_file(), and write_tags().
Definition at line 87 of file WriteVtk.hpp.
Referenced by write_file(), write_tags(), WriteVtk(), and ~WriteVtk().
List of all members.
