create_dp.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Interface.hpp"
#include <iostream>
#include <cmath>
#include <cassert>
#include "moab/IntxMesh/IntxUtils.hpp"
#include "IntxUtilsCSLAM.hpp"
#include <TestUtil.hpp>
+ Include dependency graph for create_dp.cpp:
Functions
ErrorCode add_field_value (Interface &mb)
int main (int argc, char **argv)
Variables
double radius = 1.
int field_type = 1
Function Documentation
Definition at line 24 of file create_dp.cpp.
References moab::IntxAreaUtils::area_spherical_polygon(), moab::Range::begin(), moab::IntxUtils::cart_to_spherical(), moab::Range::end(), ErrorCode, field_type, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::IntxUtils::SphereCoords::lat, moab::IntxUtils::SphereCoords::lon, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, IntxUtilsCSLAM::quasi_smooth_field(), moab::IntxUtils::SphereCoords::R, radius, moab::Range::size(), IntxUtilsCSLAM::slotted_cylinder_field(), IntxUtilsCSLAM::smooth_field(), moab::IntxUtils::spherical_to_cart(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and moab::Interface::tag_iterate().
Referenced by main().
    Tag tagTracer = 0;
    std::string tag_name( "Tracer" );
    ErrorCode rval = mb.tag_get_handle( tag_name.c_str(), 1, MB_TYPE_DOUBLE, tagTracer, MB_TAG_DENSE | MB_TAG_CREAT );CHECK_ERR( rval );
    // tagElem is the average computed at each element, from nodal values
    Tag tagElem = 0;
    std::string tag_name2( "TracerAverage" );
    rval = mb.tag_get_handle( tag_name2.c_str(), 1, MB_TYPE_DOUBLE, tagElem, MB_TAG_DENSE | MB_TAG_CREAT );CHECK_ERR( rval );
    Tag tagArea = 0;
    std::string tag_name4( "Area" );
    rval = mb.tag_get_handle( tag_name4.c_str(), 1, MB_TYPE_DOUBLE, tagArea, MB_TAG_DENSE | MB_TAG_CREAT );CHECK_ERR( rval );
     * get all plys first, then vertices, then move them on the surface of the sphere
     *  radius is 1., most of the time
    Range polygons;
    rval = mb.get_entities_by_dimension( 0, 2, polygons );
    if( MB_SUCCESS != rval ) return rval;
    Range connecVerts;
    rval = mb.get_connectivity( polygons, connecVerts );
    void* data;  // pointer to the LOC in memory, for each vertex
    int count;
    rval = mb.tag_iterate( tagTracer, connecVerts.begin(), connecVerts.end(), count, data );CHECK_ERR( rval );
    // here we are checking contiguity
    assert( count == (int)connecVerts.size() );
    double* ptr_DP = (double*)data;
    // lambda is for longitude, theta for latitude
    // param will be: (la1, te1), (la2, te2), b, c; hmax=1, r=1/2
    // nondivergent flow, page 5, case 1, (la1, te1) = (M_PI, M_PI/3)
    //                                    (la2, te2) = (M_PI, -M_PI/3)
    //                 la1,    te1    la2    te2     b     c  hmax  r
    if( field_type == 1 )  // quasi smooth
        double params[] = { M_PI, M_PI / 3, M_PI, -M_PI / 3, 0.1, 0.9, 1., 0.5 };
        for( Range::iterator vit = connecVerts.begin(); vit != connecVerts.end(); ++vit )
            EntityHandle oldV = *vit;
            CartVect posi;
            rval = mb.get_coords( &oldV, 1, &( posi[0] ) );CHECK_ERR( rval );
            moab::IntxUtils::SphereCoords sphCoord = moab::IntxUtils::cart_to_spherical( posi );
            ptr_DP[0] = IntxUtilsCSLAM::quasi_smooth_field( sphCoord.lon, sphCoord.lat, params );
            ptr_DP++;  // increment to the next node
    else if( 2 == field_type )  // smooth
        CartVect p1, p2;
        moab::IntxUtils::SphereCoords spr;
        spr.R   = 1;
        spr.lat = M_PI / 3;
        spr.lon = M_PI;
        p1      = moab::IntxUtils::spherical_to_cart( spr );
        spr.lat = -M_PI / 3;
        p2      = moab::IntxUtils::spherical_to_cart( spr );
        //                  x1,    y1,     z1,    x2,   y2,    z2,   h_max, b0
        double params[] = { p1[0], p1[1], p1[2], p2[0], p2[1], p2[2], 1, 5. };
            CartVect posi;
            ptr_DP[0] = IntxUtilsCSLAM::smooth_field( sphCoord.lon, sphCoord.lat, params );
    else if( 3 == field_type )  // slotted
        //                   la1, te1,   la2, te2,       b,   c,   r
        double params[] = { M_PI, M_PI / 3, M_PI, -M_PI / 3, 0.1, 0.9, 0.5 };  // no h_max
            CartVect posi;
            ptr_DP[0] = IntxUtilsCSLAM::slotted_cylinder_field( sphCoord.lon, sphCoord.lat, params );
    // add average value for quad/polygon (average corners)
    // do some averages
    Range::iterator iter = polygons.begin();
    // double local_mass = 0.; // this is total mass on one proc
    while( iter != polygons.end() )
        rval = mb.tag_iterate( tagElem, iter, polygons.end(), count, data );CHECK_ERR( rval );
        double* ptr = (double*)data;
        rval = mb.tag_iterate( tagArea, iter, polygons.end(), count, data );CHECK_ERR( rval );
        double* ptrArea = (double*)data;
        for( int i = 0; i < count; i++, ++iter, ptr++, ptrArea++ )
            const moab::EntityHandle* conn = NULL;
            int num_nodes                  = 0;
            rval                           = mb.get_connectivity( *iter, conn, num_nodes );CHECK_ERR( rval );
            if( num_nodes == 0 ) return MB_FAILURE;
            std::vector< double > nodeVals( num_nodes );
            double average = 0.;
            rval           = mb.tag_get_data( tagTracer, conn, num_nodes, &nodeVals[0] );CHECK_ERR( rval );
            for( int j = 0; j < num_nodes; j++ )
                average += nodeVals[j];
            average /= num_nodes;
            *ptr = average;
            // now get area
            std::vector< double > coords;
            coords.resize( 3 * num_nodes );
            rval = mb.get_coords( conn, num_nodes, &coords[0] );CHECK_ERR( rval );
            IntxAreaUtils sphAreaUtils;
            *ptrArea = sphAreaUtils.area_spherical_polygon( &coords[0], num_nodes, radius );
            // we should have used some
            // total mass:
            // local_mass += *ptrArea * average;
    // now we can delete the tags? not yet
    return MB_SUCCESS;
int main ( int  argc,
char **  argv
Definition at line 169 of file create_dp.cpp.
References add_field_value(), moab::Range::begin(), moab::Interface::coords_iterate(), IntxUtilsCSLAM::departure_point_case1(), moab::Range::end(), ErrorCode, field_type, moab::Interface::get_entities_by_dimension(), moab::Interface::load_mesh(), mb, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, output, moab::Range::size(), t, moab::Interface::tag_get_handle(), moab::Interface::tag_iterate(), and moab::Interface::write_file().
    if( argc < 3 )
        std::cout << " usage: create_dp <input> <output> -t <time>  -dt <delta_t> [-skipdp] -f "
                     "<field> -h \n";
        return 1;
    bool skip = false;
    double dt = 0.1;
    double t  = 0.1;  // corresponding to diffusion first step
    int index         = 2;
    char* input_mesh1 = argv[1];
    char* output      = argv[2];
    while( index < argc )
        if( !strcmp( argv[index], "-t" ) )  // this is for radius to project
            t = atof( argv[++index] );
        if( !strcmp( argv[index], "-dt" ) )  // delete partition sets
            dt = atof( argv[++index] );
        if( !strcmp( argv[index], "-h" ) )
            std::cout << " usage: create_dp <input> <output> -t <time>  -dt <delta_t>  [-skipdp] "
                         "-f <field>  -h \n";
            return 1;
        if( !strcmp( argv[index], "-f" ) )  // delete partition sets
            field_type = atoi( argv[++index] );
        if( !strcmp( argv[index], "-skipdp" ) )
            skip = true;
        index++;
    Core moab;
    Interface& mb = moab;
    ErrorCode rval;
    rval = mb.load_mesh( input_mesh1 );
    std::cout << " -t " << t << " -dt " << dt << " input: " << input_mesh1 << "  output: " << output << "\n";
    // skip if we need for DP (already existing)
    if( skip )
        std::cout << " do not add DP tag \n";
    else
        Range verts;
        rval = mb.get_entities_by_dimension( 0, 0, verts );
        if( MB_SUCCESS != rval ) return 1;
        double *x_ptr, *y_ptr, *z_ptr;
        int count;
        rval = mb.coords_iterate( verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count );
        assert( count == (int)verts.size() );  // should end up with just one contiguous chunk of vertices
        Tag tagh = 0;
        std::string tag_name( "DP" );
        rval = mb.tag_get_handle( tag_name.c_str(), 3, MB_TYPE_DOUBLE, tagh, MB_TAG_DENSE | MB_TAG_CREAT );CHECK_ERR( rval );
        int count_tag;
        rval = mb.tag_iterate( tagh, verts.begin(), verts.end(), count_tag, data );CHECK_ERR( rval );
        assert( count_tag == (int)verts.size() );
        for( int v = 0; v < count; v++ )
            // EntityHandle v = verts[v];
            CartVect pos( x_ptr[v], y_ptr[v], z_ptr[v] );
            CartVect newPos;
            IntxUtilsCSLAM::departure_point_case1( pos, t, dt, newPos );
            ptr_DP[0] = newPos[0];
            ptr_DP[1] = newPos[1];
            ptr_DP[2] = newPos[2];
            ptr_DP += 3;  // increment to the next vertex
    rval = add_field_value( mb );
    mb.write_file( output );
    return 0;
Variable Documentation
int field_type = 1
Definition at line 22 of file create_dp.cpp.
Referenced by add_field_value(), and main().
double radius = 1.
Definition at line 21 of file create_dp.cpp.
