MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"
#include <iostream>
#include <fstream>
#include <cstring>
#include "moab/FBEngine.hpp"
#include "moab/GeomTopoTool.hpp"
#include "TestUtil.hpp"
Functions | |
ErrorCode | volume_test (FBEngine *pFacet) |
void | handle_error_code (ErrorCode rv, int &number_failed, int &number_successful) |
int | main (int argc, char *argv[]) |
Variables | |
std::string | filename_top |
std::string | filename_bot |
std::string | polygon_file_name |
double | min_dot = 0.8 |
std::string | vol_file |
int | number_tests_successful = 0 |
int | number_tests_failed = 0 |
void handle_error_code | ( | ErrorCode | rv, |
int & | number_failed, | ||
int & | number_successful | ||
Definition at line 36 of file crop_vol_test.cpp.
References MB_SUCCESS.
{ if( rv == MB_SUCCESS ) { std::cout << "Success"; number_successful++; } else { std::cout << "Failure"; number_failed++; } }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 50 of file crop_vol_test.cpp.
References ErrorCode, filename_bot, filename_top, handle_error_code(), moab::FBEngine::Init(), moab::Interface::load_file(), mb, MB_CHK_SET_ERR, mbcore, min_dot, number_tests_failed, number_tests_successful, polygon_file_name, vol_file, and volume_test().
{ filename_bot = TestDir + "unittest/BedCrop2.h5m"; filename_top = TestDir + "unittest/SECrop2.h5m"; //"/polyPB.txt"; polygon_file_name = TestDir + "unittest/poly14.txt"; vol_file = "volIce.h5m"; // output number_tests_successful = 0; bool remove_output = true; if( argc == 1 ) { std::cout << "Using default input files: " << filename_bot << " " << filename_top << " " << polygon_file_name << " " << min_dot << " " << vol_file << std::endl; std::cout << " default output file: " << vol_file << " will be deleted \n"; } else if( argc == 6 ) { remove_output = false; filename_bot = argv[1]; filename_top = argv[2]; polygon_file_name = argv[3]; min_dot = atof( argv[4] ); vol_file = argv[5]; } else { std::cout << " wrong number of arguments\n"; return 1; // fail } Core mbcore; Interface* mb = &mbcore; ErrorCode rval = mb->load_file( filename_bot.c_str() );MB_CHK_SET_ERR( rval, "failed to load bed file" ); rval = mb->load_file( filename_top.c_str() ); // load the second face (we know we have one face in each file) MB_CHK_SET_ERR( rval, "failed to load top file" ); FBEngine* pFacet = new FBEngine( mb, NULL, true ); // smooth facetting, no OBB tree passed if( !pFacet ) return 1; // error // should the init be part of constructor or not? // this is where the obb tree is constructed, and smooth faceting initialized, too. rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" ); std::cout << "volume creation test: "; rval = volume_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; if( remove_output ) { remove( vol_file.c_str() ); } return number_tests_failed; }
ErrorCode volume_test | ( | FBEngine * | pFacet | ) |
Definition at line 108 of file crop_vol_test.cpp.
References moab::FBEngine::create_volume_with_direction(), moab::FBEngine::delete_smooth_tags(), moab::GeomTopoTool::duplicate_model(), ErrorCode, MBMesquite::faces, moab::FBEngine::get_gtt(), moab::GeomTopoTool::get_root_model_set(), moab::FBEngine::getEntities(), moab::FBEngine::getRootSet(), mb, MB_CHK_SET_ERR, min_dot, moab::FBEngine::moab_instance(), nr, polygon_file_name, root_set, moab::Range::size(), moab::FBEngine::split_surface_with_direction(), vol_file, moab::Interface::write_file(), and z.
Referenced by main().
{ // there should be 2 faces in the model std::ifstream datafile( polygon_file_name.c_str(), std::ifstream::in ); if( !datafile ) { std::cout << "can't read file\n"; return MB_FAILURE; } // char temp[100]; double direction[3]; // normalized double gridSize; datafile.getline( temp, 100 ); // first line // get direction and mesh size along polygon segments, from file sscanf( temp, " %lf %lf %lf %lf ", direction, direction + 1, direction + 2, &gridSize ); // NORMALIZE(direction);// just to be sure std::vector< double > xyz; while( !datafile.eof() ) { datafile.getline( temp, 100 ); // int id = 0; double x, y, z; int nr = sscanf( temp, "%lf %lf %lf", &x, &y, &z ); if( nr == 3 ) { xyz.push_back( x ); xyz.push_back( y ); xyz.push_back( z ); } } int sizePolygon = (int)xyz.size() / 3; if( sizePolygon < 3 ) { std::cerr << " Not enough points in the polygon" << std::endl; return MB_FAILURE; } EntityHandle root_set; ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); int top = 2; // iBase_FACE; Range faces; rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in volume_test." ); if( 2 != faces.size() ) { std::cerr << "expected 2 faces, top and bottom\n"; return MB_FAILURE; } EntityHandle newFace1; // first test is with closed surface rval = pFacet->split_surface_with_direction( faces[0], xyz, direction, /*closed*/ 1, min_dot, newFace1 );MB_CHK_SET_ERR( rval, "Failed to crop first face." ); EntityHandle newFace2; // first test is with closed surface rval = pFacet->split_surface_with_direction( faces[1], xyz, direction, /*closed*/ 1, min_dot, newFace2 );MB_CHK_SET_ERR( rval, "Failed to crop second face." ); // here we make the assumption that the edges, vertices are matching fine... EntityHandle volume; rval = pFacet->create_volume_with_direction( newFace1, newFace2, direction, volume );MB_CHK_SET_ERR( rval, "Failed to create volume." ); Interface* mb = pFacet->moab_instance(); pFacet->delete_smooth_tags(); // duplicate -- extract a new geom topo tool GeomTopoTool* gtt = pFacet->get_gtt(); GeomTopoTool* duplicate = NULL; std::vector< EntityHandle > gents; gents.push_back( volume ); rval = gtt->duplicate_model( duplicate, &gents );MB_CHK_SET_ERR( rval, "Failed to extract volume." ); EntityHandle newRootSet = duplicate->get_root_model_set(); delete pFacet; pFacet = NULL; // try not to write the obb tree delete duplicate; rval = mb->write_file( vol_file.c_str(), NULL, NULL, &newRootSet, 1 ); return rval; }
std::string filename_bot |
Definition at line 24 of file crop_vol_test.cpp.
std::string filename_top |
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition at line 23 of file crop_vol_test.cpp.
double min_dot = 0.8 |
Definition at line 26 of file crop_vol_test.cpp.
Referenced by moab::FBEngine::initializeSmoothing(), main(), split_test(), and volume_test().
int number_tests_failed = 0 |
Definition at line 30 of file crop_vol_test.cpp.
int number_tests_successful = 0 |
Definition at line 29 of file crop_vol_test.cpp.
std::string polygon_file_name |
Definition at line 25 of file crop_vol_test.cpp.
Referenced by main(), split_test(), and volume_test().
std::string vol_file |
Definition at line 27 of file crop_vol_test.cpp.
Referenced by main(), and volume_test().
