MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <stdio.h>
#include <stdlib.h>
#include <hdf5.h>
#include <vector>
#include <map>
#include <string>
Functions | |
hid_t | open_file (const char *name) |
long | read_scalar_attrib (hid_t file, const char *table, const char *attrib) |
void | read_data (hid_t file, const char *name, int expected_cols, std::vector< long > &data) |
void | create_map (const std::vector< long > &ents, const std::vector< long > &vals, std::map< long, long > &map, const char *name) |
std::string | ent_from_handle (const std::map< long, long > &dimmap, const std::map< long, long > &idmap, long handle) |
std::string | ent_list_from_handles (const std::map< long, long > &dimmap, const std::map< long, long > &idmap, const std::vector< long > &vect, long start, long stop) |
int | main (int argc, char *argv[]) |
void create_map | ( | const std::vector< long > & | ents, |
const std::vector< long > & | vals, | ||
std::map< long, long > & | map, | ||
const char * | name | ||
Definition at line 98 of file dump_geom_sets.cxx.
Referenced by main().
{ if (ents.size() != vals.size()) { fprintf(stderr, "Invalid data for tag \"%s\": mismatched table lengths.\n", name ); exit (1); } std::vector<long>::const_iterator e_iter = ents.begin(), v_iter = vals.begin(); for (; e_iter != ents.end(); ++e_iter, ++v_iter) map[*e_iter] = *v_iter; }
std::string ent_from_handle | ( | const std::map< long, long > & | dimmap, |
const std::map< long, long > & | idmap, | ||
long | handle | ||
Definition at line 116 of file dump_geom_sets.cxx.
References buffer.
Referenced by ent_list_from_handles(), and main().
{ std::string result; std::map<long,long>::const_iterator d_iter, i_iter; d_iter = dimmap.find( handle ); i_iter = idmap.find( handle ); if (d_iter == dimmap.end() || i_iter == idmap.end()) return result; switch (d_iter->second) { case 0: result += "v"; break; case 1: result += "c"; break; case 2: result += "s"; break; case 3: result += "V"; break; default: fprintf(stderr,"Invalid value in GEOM_DIMENSION tag data.\n"); exit (1); } char buffer[128]; sprintf(buffer, "%ld", i_iter->second ); result += buffer; return result; }
std::string ent_list_from_handles | ( | const std::map< long, long > & | dimmap, |
const std::vector< long > & | vect, | ||
long | start, | ||
long | stop | ||
Definition at line 146 of file dump_geom_sets.cxx.
References ent_from_handle().
{ std::string result; if (start >= (long)vect.size() || stop >= (long)vect.size() || stop < start) { fprintf(stderr, "Invalid set data. Corrupt file?\n"); exit(2); } std::vector<long>::const_iterator iter = vect.begin() + start+1, end = vect.begin() + stop+1; for (; iter != end; ++iter) { std::string tmp = ent_from_handle( dimmap, idmap, *iter ); if (!tmp.empty()) { result += tmp; result += " "; } else result += "? "; } return result; }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 173 of file dump_geom_sets.cxx.
References children, create_map(), ent_from_handle(), ent_list_from_handles(), l, open_file(), read_data(), and read_scalar_attrib().
{ // Need a file name to read if (argc != 2) { printf("Usage: %s <file>\n", argv[0] ); exit(1); } // Read everything we need from the file std::vector<long> set_meta, set_child, set_parent, dim_ents, dim_vals, id_ents, id_vals; hid_t file = open_file( argv[1] ); read_data( file, "/tstt/sets/list", 4, set_meta ); read_data( file, "/tstt/sets/parents", 1, set_parent ); read_data( file, "/tstt/sets/children", 1, set_child ); read_data( file, "/tstt/tags/GEOM_DIMENSION/id_list", 1, dim_ents ); read_data( file, "/tstt/tags/GEOM_DIMENSION/values", 1, dim_vals ); read_data( file, "/tstt/tags/GLOBAL_ID/id_list", 1, id_ents ); read_data( file, "/tstt/tags/GLOBAL_ID/values", 1, id_vals ); const long startid = read_scalar_attrib( file, "/tstt/sets/list", "start_id" ); H5Fclose( file ); // Construct handle->dimension and handle->global_id maps. std::map<long,long> dimmap, idmap; create_map( dim_ents, dim_vals, dimmap, "GEOM_DIMENSION" ); create_map( id_ents, id_vals, idmap, "GLOBAL_ID" ); // For each entity set long parent_start = -1l, child_start = -1l; printf("handle ID Children Parents\n"); for (unsigned i = 0; i < set_meta.size(); i += 4) { // Get name long handle = startid + i/4; std::string name = ent_from_handle( dimmap, idmap, handle ); if (name.empty()) // not a geometry set continue; // Get parents and children long child_end = set_meta[i+1]; long parent_end = set_meta[i+2]; std::string children = ent_list_from_handles( dimmap, idmap, set_child, child_start, child_end ); std::string parents = ent_list_from_handles( dimmap, idmap, set_parent, parent_start, parent_end ); child_start = child_end; parent_start = parent_end; // Print printf( "%6ld %-6s %-20s %-20s\n", handle, name.c_str(), children.c_str(), parents.c_str() ); } return 0; }
hid_t open_file | ( | const char * | name | ) |
Definition at line 13 of file dump_geom_sets.cxx.
{ hid_t handle = H5Fopen( name, H5F_ACC_RDONLY, H5P_DEFAULT ); if (handle < 0) { fprintf(stderr, "Cannot open file: \"%s\"\n", name ); exit (1); } return handle; }
void read_data | ( | hid_t | file, |
const char * | name, | ||
int | expected_cols, | ||
std::vector< long > & | data | ||
Definition at line 52 of file dump_geom_sets.cxx.
{ hid_t handle = H5Dopen( file, name ); if (handle < 0) { fprintf(stderr, "Invalid file. Data not found: \"%s\"\n", name ); exit (1); } hid_t space = H5Dget_space( handle ); if (space < 0) { fprintf(stderr, "Internal error accessing: \"%s\"\n", name ); exit (2); } int ndims = H5Sget_simple_extent_ndims( space ); if (ndims < 0) { fprintf(stderr, "Internal error accessing: \"%s\"\n", name ); exit (2); } else if (ndims < 1 || ndims > 2) { fprintf(stderr, "\"%s\" is an %d-dimension table. Corrupt file?", name, ndims ); exit (2); } hsize_t dims[2] = { 0, 1 }; H5Sget_simple_extent_dims( space, dims, 0 ); H5Sclose( space ); if (dims[1] != expected_cols) { fprintf(stderr, "Error reading \"%s\": expected %d cols, has %d\n", name, expected_cols, (int)dims[1] ); exit (2); } data.resize( dims[0] * dims[1] ); herr_t rval = H5Dread( handle, H5T_NATIVE_LONG, H5S_ALL, H5S_ALL, H5P_DEFAULT, &data[0] ); if (rval < 0) { fprintf(stderr, "Error reading data from: \"%s\"\n", name ); exit (1); } H5Dclose( handle ); }
long read_scalar_attrib | ( | hid_t | file, |
const char * | table, | ||
const char * | attrib | ||
Definition at line 24 of file dump_geom_sets.cxx.
References value().
{ hid_t table_id = H5Dopen( file, table ); if (table_id < 0) { fprintf(stderr, "Invalid file. Data not found: \"%s\"\n", table ); exit (1); } hid_t attr_id = H5Aopen_name( table_id, attrib ); H5Dclose( table_id ); if (attr_id < 0) { fprintf(stderr, "Invalid file. No \"%s\" attrib on \"%s\"\n", attrib, table ); exit (1); } long value; herr_t rval = H5Aread( attr_id, H5T_NATIVE_LONG, &value ); H5Aclose( attr_id ); if (rval < 0) { fprintf(stderr, "Failed to read \"%s\" attrib on \"%s\"\n", attrib, table ); exit (2); } return value; }
