MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/ProgOptions.hpp"
#include "moab/CartVect.hpp"
#include "moab/ElemEvaluator.hpp"
#include "moab/CN.hpp"
#include "ElemUtil.hpp"
#include <iostream>
#include <ctime>
#include <cstdlib>
#include <cassert>
#include <sstream>
#include <string>
#include <sys/resource.h>
Defines | |
#define | CHK(r, s) |
Functions | |
static void | fail (ErrorCode error_code, const char *str, const char *file_name, int line_number) |
double | mytime () |
ErrorCode | get_ents (Interface &mbi, std::string &filename, int &dim, Range &elems, EntityType &tp, int &nv) |
void | parse_options (ProgOptions &opts, int &dim, std::string &filename) |
ErrorCode | get_elem_map (EntityType tp, std::vector< CartVect > &vcoords, int nconn, Element::Map *&elemmap) |
ErrorCode | time_forward_eval (Interface *mbi, int method, Range &elems, std::vector< CartVect > ¶ms, std::vector< CartVect > &coords, double &evtime) |
ErrorCode | time_reverse_eval (Interface *mbi, int method, Range &elems, std::vector< CartVect > &coords, std::vector< CartVect > ¶ms, double &retime) |
ErrorCode | time_jacobian (Interface *mbi, int method, Range &elems, std::vector< CartVect > ¶ms, double &jactime) |
ErrorCode | time_integrate (Interface *mbi, int method, Tag tag, Range &elems, double &inttime) |
ErrorCode | put_random_field (Interface &mbi, Tag &tag, Range &elems) |
ErrorCode | elem_evals (Interface *mbi, int method, Range &elems, Tag tag, std::vector< CartVect > ¶ms, std::vector< CartVect > &coords, double &evtime, double &retime, double &jactime, double &inttime) |
int | main (int argc, char *argv[]) |
double | mytime2 (double &tot_time, double &utime, double &stime, long &imem, long &rmem) |
Variables | |
const int | ELEMEVAL = 0 |
const int | ELEMUTIL = 1 |
#define CHK | ( | r, | |
s | |||
do \ { \ if( MB_SUCCESS != ( r ) ) \ { \ fail( ( r ), ( s ), __FILE__, __LINE__ ); \ return ( r ); \ } \ } while( false )
Definition at line 27 of file elem_eval_time.cpp.
Referenced by elem_evals(), get_ents(), main(), put_random_field(), time_forward_eval(), time_integrate(), time_jacobian(), and time_reverse_eval().
ErrorCode elem_evals | ( | Interface * | mbi, |
int | method, | ||
Range & | elems, | ||
Tag | tag, | ||
std::vector< CartVect > & | params, | ||
std::vector< CartVect > & | coords, | ||
double & | evtime, | ||
double & | retime, | ||
double & | jactime, | ||
double & | inttime | ||
Definition at line 333 of file elem_eval_time.cpp.
References CHK, ErrorCode, time_forward_eval(), time_integrate(), time_jacobian(), and time_reverse_eval().
Referenced by main().
{ evtime = 0, retime = 0, jactime = 0, inttime = 0; // initializations to avoid compiler warning // time/test forward evaluation, putting results into vector ErrorCode rval = time_forward_eval( mbi, method, elems, params, coords, evtime ); CHK( rval, "time_forward_eval" ); // time/test reverse evaluation, putting results into vector rval = time_reverse_eval( mbi, method, elems, coords, params, retime ); CHK( rval, "time_reverse_eval" ); // time/test Jacobian evaluation rval = time_jacobian( mbi, method, elems, params, jactime ); CHK( rval, "time_jacobian" ); // time/test integration rval = time_integrate( mbi, method, tag, elems, inttime ); CHK( rval, "time_integrate" ); return rval; }
static void fail | ( | ErrorCode | error_code, |
const char * | str, | ||
const char * | file_name, | ||
int | line_number | ||
) | [static] |
Definition at line 39 of file elem_eval_time.cpp.
{ std::cerr << str << ", line " << line_number << " of file " << file_name << ", error code " << error_code << std::endl; }
ErrorCode get_elem_map | ( | EntityType | tp, |
std::vector< CartVect > & | vcoords, | ||
int | nconn, | ||
Element::Map *& | elemmap | ||
Definition at line 88 of file elem_eval_time.cpp.
References MB_SUCCESS, MBHEX, MBQUAD, and MBTET.
Referenced by time_forward_eval(), time_integrate(), time_jacobian(), and time_reverse_eval().
{ switch( tp ) { case MBHEX: if( nconn == 8 ) { elemmap = new Element::LinearHex( vcoords ); break; } else if( nconn == 27 ) { elemmap = new Element::QuadraticHex( vcoords ); break; } else return MB_FAILURE; case MBTET: if( nconn == 4 ) { elemmap = new Element::LinearTet( vcoords ); break; } else return MB_FAILURE; case MBQUAD: if( nconn == 4 ) { elemmap = new Element::LinearQuad( vcoords ); break; } else return MB_FAILURE; default: return MB_FAILURE; } return MB_SUCCESS; }
ErrorCode get_ents | ( | Interface & | mbi, |
std::string & | filename, | ||
int & | dim, | ||
EntityType & | tp, | ||
int & | nv | ||
Definition at line 47 of file elem_eval_time.cpp.
References moab::Range::begin(), CHK, moab::Range::empty(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), moab::Interface::load_file(), MB_SUCCESS, moab::Range::rbegin(), and moab::Interface::type_from_handle().
{ ErrorCode rval = mbi.load_file( filename.c_str(), 0 ); while( elems.empty() && dim >= 1 ) { rval = mbi.get_entities_by_dimension( 0, dim, elems ); CHK( rval, "get_entities_by_dimension" ); if( elems.empty() ) dim--; } if( elems.empty() ) { CHK( MB_FAILURE, "No elements in file" ); } // check to see they're all the same type & #vertices tp = mbi.type_from_handle( *elems.begin() ); EntityType tp2 = mbi.type_from_handle( *elems.rbegin() ); if( tp != tp2 ) CHK( MB_FAILURE, "Elements must have same type" ); int nv2; const EntityHandle* c1; rval = mbi.get_connectivity( *elems.begin(), c1, nv ); CHK( rval, "get_connectivity" ); rval = mbi.get_connectivity( *elems.rbegin(), c1, nv2 ); CHK( rval, "get_connectivity" ); if( nv != nv2 ) { CHK( MB_FAILURE, "Elements must have same #vertices" ); } return MB_SUCCESS; }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 365 of file elem_eval_time.cpp.
References CHK, dim, elem_evals(), ELEMEVAL, ELEMUTIL, moab::CN::EntityTypeName(), ErrorCode, filename, get_ents(), MB_SUCCESS, parse_options(), ProgOptions::parseCommandLine(), put_random_field(), and moab::Range::size().
{ // parse options ProgOptions opts; std::string filename; int dim = 3; parse_options( opts, dim, filename ); opts.parseCommandLine( argc, argv ); if( filename.empty() ) CHK( MB_FAILURE, "No file specified" ); else if( dim < 1 || dim > 3 ) CHK( MB_FAILURE, "Dimension must be > 0 and <= 3" ); // read mesh file & gather element handles Core mbi; Range elems; int nv; EntityType tp; ErrorCode rval = get_ents( mbi, filename, dim, elems, tp, nv ); if( MB_SUCCESS != rval ) return 1; // construct (random) parameter values for queries unsigned int ne = elems.size(); std::vector< CartVect > params( ne ), coords( ne ); srand( time( NULL ) ); for( unsigned int i = 0; i < ne; i++ ) { params[i][0] = -1 + 2 * ( (double)rand() ) / RAND_MAX; if( dim > 1 ) params[i][1] = -1 + 2 * ( (double)rand() ) / RAND_MAX; if( dim > 2 ) params[i][2] = -1 + 2 * ( (double)rand() ) / RAND_MAX; } // put random field on vertices Tag tag; rval = put_random_field( mbi, tag, elems ); CHK( rval, "put_random_field" ); double evtime[2], retime[2], jactime[2], inttime[2]; // initializations to avoid compiler warning rval = elem_evals( &mbi, ELEMEVAL, elems, tag, params, coords, evtime[0], retime[0], jactime[0], inttime[0] ); CHK( rval, "new elem_evals" ); rval = elem_evals( &mbi, ELEMUTIL, elems, tag, params, coords, evtime[1], retime[1], jactime[1], inttime[1] ); CHK( rval, "old elem_evals" ); std::cout << filename << ": " << elems.size() << " " << CN::EntityTypeName( tp ) << " elements, " << nv << " vertices per element." << std::endl << std::endl; std::cout << "New, old element evaluation code:" << std::endl; std::cout << "Evaluation type, time, time per element:" << std::endl; std::cout << " New Old (New/Old)*100" << std::endl; std::cout << "Forward evaluation " << evtime[0] << ", " << evtime[0] / elems.size() << " " << evtime[1] << ", " << evtime[1] / elems.size() << " " << ( evtime[0] / ( evtime[1] ? evtime[1] : 1 ) ) * 100.0 << std::endl; std::cout << "Reverse evaluation " << retime[0] << ", " << retime[0] / elems.size() << " " << retime[1] << ", " << retime[1] / elems.size() << " " << ( retime[0] / ( retime[1] ? retime[1] : 1 ) ) * 100.0 << std::endl; std::cout << "Jacobian " << jactime[0] << ", " << jactime[0] / elems.size() << " " << jactime[1] << ", " << jactime[1] / elems.size() << " " << ( jactime[0] / ( jactime[1] ? jactime[1] : 1 ) ) * 100.0 << std::endl; std::cout << "Integration " << inttime[0] << ", " << inttime[0] / elems.size() << " " << inttime[1] << ", " << inttime[1] / elems.size() << " " << ( inttime[0] / ( inttime[1] ? inttime[1] : 1 ) ) * 100.0 << std::endl; }
double mytime | ( | ) |
Definition at line 457 of file elem_eval_time.cpp.
References mytime2().
{ double ttime, utime, stime; long imem, rmem; return mytime2( ttime, utime, stime, imem, rmem ); }
double mytime2 | ( | double & | tot_time, |
double & | utime, | ||
double & | stime, | ||
long & | imem, | ||
long & | rmem | ||
Definition at line 439 of file elem_eval_time.cpp.
Referenced by mytime().
{ struct rusage r_usage; getrusage( RUSAGE_SELF, &r_usage ); utime = (double)r_usage.ru_utime.tv_sec + ( (double)r_usage.ru_utime.tv_usec / 1.e6 ); stime = (double)r_usage.ru_stime.tv_sec + ( (double)r_usage.ru_stime.tv_usec / 1.e6 ); tot_time = utime + stime; #ifndef LINUX imem = r_usage.ru_idrss; rmem = r_usage.ru_maxrss; #else system( "ps o args,drs,rss | grep perf | grep -v grep" ); // RedHat 9.0 doesnt fill in actual // memory data imem = rmem = 0; #endif return tot_time; }
void parse_options | ( | ProgOptions & | opts, |
int & | dim, | ||
std::string & | filename | ||
Definition at line 80 of file elem_eval_time.cpp.
References ProgOptions::addOpt(), dim, filename, and ProgOptions::int_flag.
{ opts.addOpt< int >( std::string( "dim" ), std::string( "Evaluate 1d/2d/3d elements (default: maximal dimension in mesh)" ), &dim, ProgOptions::int_flag ); opts.addOpt< std::string >( std::string( "filename,f" ), std::string( "Filename containing mesh" ), &filename ); }
ErrorCode put_random_field | ( | Interface & | mbi, |
Tag & | tag, | ||
Range & | elems | ||
Definition at line 319 of file elem_eval_time.cpp.
References CHK, ErrorCode, moab::Interface::get_adjacencies(), MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::Interface::UNION.
{ Range verts; ErrorCode rval = mbi.get_adjacencies( elems, 0, false, verts, Interface::UNION ); CHK( rval, "get_adjacencies" ); rval = mbi.tag_get_handle( "mytag", 1, MB_TYPE_DOUBLE, tag, MB_TAG_CREAT | MB_TAG_DENSE ); CHK( rval, "tag_get_handle" ); std::vector< double > tag_vals( verts.size() ); for( unsigned int i = 0; i < verts.size(); i++ ) tag_vals[i] = ( (double)rand() ) / RAND_MAX; rval = mbi.tag_set_data( tag, verts, &tag_vals[0] ); return rval; }
ErrorCode time_forward_eval | ( | Interface * | mbi, |
int | method, | ||
double & | evtime | ||
Definition at line 128 of file elem_eval_time.cpp.
References moab::Range::begin(), CHK, ELEMEVAL, ELEMUTIL, moab::Range::end(), ErrorCode, moab::ElemEvaluator::eval(), moab::Element::Map::evaluate(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), get_elem_map(), moab::CN::MAX_NODES_PER_ELEMENT, MB_SUCCESS, mytime(), moab::ElemEvaluator::set_ent_handle(), moab::ElemEvaluator::set_eval_set(), moab::ElemEvaluator::set_tag_handle(), and moab::Interface::type_from_handle().
Referenced by elem_evals().
{ evtime = mytime(); ErrorCode rval; Range::iterator rit; unsigned int i; if( ELEMEVAL == method ) { // construct ElemEvaluator EvalSet eset; ElemEvaluator eeval( mbi ); eeval.set_eval_set( *elems.begin() ); eeval.set_tag_handle( 0, 0 ); // indicates coordinates as the field to evaluate for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) { eeval.set_ent_handle( *rit ); rval = eeval.eval( params[i].array(), coords[i].array(), 3 ); #ifndef NDEBUG if( MB_SUCCESS != rval ) return rval; #endif } } else if( ELEMUTIL == method ) { std::vector< CartVect > vcoords( CN::MAX_NODES_PER_ELEMENT ); const EntityHandle* connect; int nconn; Element::Map* elemmap = NULL; for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) { rval = mbi->get_connectivity( *rit, connect, nconn ); CHK( rval, "get_connectivity" ); rval = mbi->get_coords( connect, nconn, vcoords[0].array() ); CHK( rval, "get_coords" ); rval = get_elem_map( mbi->type_from_handle( *rit ), vcoords, nconn, elemmap ); CHK( rval, "get_elem_map" ); coords[i] = elemmap->evaluate( params[i] ); } } evtime = mytime() - evtime; return MB_SUCCESS; }
ErrorCode time_integrate | ( | Interface * | mbi, |
int | method, | ||
Tag | tag, | ||
Definition at line 270 of file elem_eval_time.cpp.
References moab::Range::begin(), CHK, ELEMEVAL, ELEMUTIL, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), get_elem_map(), moab::ElemEvaluator::integrate(), moab::Element::Map::integrate_scalar_field(), moab::CN::MAX_NODES_PER_ELEMENT, MB_SUCCESS, mytime(), moab::ElemEvaluator::set_ent_handle(), moab::ElemEvaluator::set_eval_set(), moab::ElemEvaluator::set_tag_handle(), moab::Interface::tag_get_data(), and moab::Interface::type_from_handle().
{ inttime = mytime(); ErrorCode rval; double integral = 0.0; if( ELEMEVAL == method ) { EvalSet eset; ElemEvaluator eeval( mbi ); eeval.set_eval_set( *elems.begin() ); eeval.set_tag_handle( 0, 0 ); // indicates coordinates as the field to evaluate rval = eeval.set_tag_handle( tag, 0 ); CHK( rval, "set_tag_handle" ); for( Range::iterator rit = elems.begin(); rit != elems.end(); ++rit ) { eeval.set_ent_handle( *rit ); rval = eeval.integrate( &integral ); #ifndef NDEBUG if( MB_SUCCESS != rval ) return rval; #endif } } else if( ELEMUTIL == method ) { std::vector< CartVect > vcoords( CN::MAX_NODES_PER_ELEMENT ); std::vector< double > tagval( CN::MAX_NODES_PER_ELEMENT ); const EntityHandle* connect; int nconn; Element::Map* elemmap = NULL; Range::iterator rit; unsigned int i; for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) { rval = mbi->get_connectivity( *rit, connect, nconn ); CHK( rval, "get_connectivity" ); rval = mbi->get_coords( connect, nconn, vcoords[0].array() ); CHK( rval, "get_coords" ); rval = get_elem_map( mbi->type_from_handle( *rit ), vcoords, nconn, elemmap ); CHK( rval, "get_elem_map" ); rval = mbi->tag_get_data( tag, connect, nconn, &tagval[0] ); CHK( rval, "tag_get_data" ); integral = elemmap->integrate_scalar_field( &tagval[0] ); } } inttime = mytime() - inttime; std::cout << "integral = " << integral << std::endl; return MB_SUCCESS; }
ErrorCode time_jacobian | ( | Interface * | mbi, |
int | method, | ||
double & | jactime | ||
Definition at line 227 of file elem_eval_time.cpp.
References moab::Matrix3::array(), moab::Range::begin(), CHK, ELEMEVAL, ELEMUTIL, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), get_elem_map(), moab::Element::Map::jacobian(), moab::ElemEvaluator::jacobian(), moab::CN::MAX_NODES_PER_ELEMENT, MB_SUCCESS, mytime(), moab::ElemEvaluator::set_ent_handle(), moab::ElemEvaluator::set_eval_set(), moab::ElemEvaluator::set_tag_handle(), and moab::Interface::type_from_handle().
{ jactime = mytime(); ErrorCode rval; Range::iterator rit; unsigned int i; Matrix3 jac; if( ELEMEVAL == method ) { EvalSet eset; ElemEvaluator eeval( mbi ); eeval.set_eval_set( *elems.begin() ); eeval.set_tag_handle( 0, 0 ); // indicates coordinates as the field to evaluate for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) { eeval.set_ent_handle( *rit ); rval = eeval.jacobian( params[i].array(), jac.array() ); #ifndef NDEBUG if( MB_SUCCESS != rval ) return rval; #endif } } else if( ELEMUTIL == method ) { std::vector< CartVect > vcoords( CN::MAX_NODES_PER_ELEMENT ); const EntityHandle* connect; int nconn; Element::Map* elemmap = NULL; for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) { rval = mbi->get_connectivity( *rit, connect, nconn ); CHK( rval, "get_connectivity" ); rval = mbi->get_coords( connect, nconn, vcoords[0].array() ); CHK( rval, "get_coords" ); rval = get_elem_map( mbi->type_from_handle( *rit ), vcoords, nconn, elemmap ); CHK( rval, "get_elem_map" ); jac = elemmap->jacobian( params[i] ); } } jactime = mytime() - jactime; return MB_SUCCESS; }
ErrorCode time_reverse_eval | ( | Interface * | mbi, |
int | method, | ||
double & | retime | ||
Definition at line 178 of file elem_eval_time.cpp.
References moab::Range::begin(), CHK, ELEMEVAL, ELEMUTIL, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), get_elem_map(), moab::Element::Map::ievaluate(), moab::CN::MAX_NODES_PER_ELEMENT, MB_SUCCESS, mytime(), moab::ElemEvaluator::reverse_eval(), moab::ElemEvaluator::set_ent_handle(), moab::ElemEvaluator::set_eval_set(), moab::ElemEvaluator::set_tag_handle(), and moab::Interface::type_from_handle().
{ retime = mytime(); ErrorCode rval; Range::iterator rit; unsigned int i; if( ELEMEVAL == method ) { EvalSet eset; ElemEvaluator eeval( mbi ); eeval.set_eval_set( *elems.begin() ); eeval.set_tag_handle( 0, 0 ); // indicates coordinates as the field to evaluate int ins; for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) { eeval.set_ent_handle( *rit ); rval = eeval.reverse_eval( coords[i].array(), 1.0e-10, 1.0e-6, params[i].array(), &ins ); assert( ins ); #ifndef NDEBUG if( MB_SUCCESS != rval ) return rval; #endif } } else if( ELEMUTIL == method ) { std::vector< CartVect > vcoords( CN::MAX_NODES_PER_ELEMENT ); const EntityHandle* connect; int nconn; Element::Map* elemmap = NULL; for( rit = elems.begin(), i = 0; rit != elems.end(); ++rit, i++ ) { rval = mbi->get_connectivity( *rit, connect, nconn ); CHK( rval, "get_connectivity" ); rval = mbi->get_coords( connect, nconn, vcoords[0].array() ); CHK( rval, "get_coords" ); rval = get_elem_map( mbi->type_from_handle( *rit ), vcoords, nconn, elemmap ); CHK( rval, "get_elem_map" ); coords[i] = elemmap->ievaluate( coords[i], 1.0e-6 ); } } retime = mytime() - retime; return MB_SUCCESS; }
const int ELEMEVAL = 0 |
Definition at line 37 of file elem_eval_time.cpp.
Referenced by main(), time_forward_eval(), time_integrate(), time_jacobian(), and time_reverse_eval().
const int ELEMUTIL = 1 |
