MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "MBTagConventions.hpp"
#include "moab/CN.hpp"
#include "moab/Range.hpp"
#include "ReadNCDF.hpp"
#include "moab/FileOptions.hpp"
#include "ExoIIUtil.hpp"
#include <cmath>
#include <algorithm>
Classes | |
struct | TestType |
Defines | |
#define | IS_BUILDING_MB |
Functions | |
void | read_file (Interface &moab, const char *input_file) |
void | check_ho_element (Interface &moab, EntityHandle entity, int mid_nodes[4]) |
void | test_read_side (int sideset_id, EntityType sideset_type, int sideset_nodes_per_elem, bool shell_side=false) |
void | test_ho_elements (EntityType type, int num_nodes) |
void | mb_vertex_coordinate_test () |
void | mb_bar_connectivity_test () |
void | mb_tri_connectivity_test () |
void | mb_quad_connectivity_test () |
void | mb_hex_connectivity_test () |
void | mb_tet_connectivity_test () |
void | mb_write_mesh_test () |
void | test_types () |
void | test_tri6 () |
void | test_tri7 () |
void | test_quad5 () |
void | test_quad8 () |
void | test_quad9 () |
void | test_tet8 () |
void | test_tet10 () |
void | test_tet14 () |
void | test_hex9 () |
void | test_hex20 () |
void | test_hex27 () |
void | test_read_tri6_side () |
void | test_read_shell_side () |
void | test_read_shell_edge () |
void | test_read_hex20_side () |
void | test_read_block_ids () |
void | test_read_sideset_ids () |
void | test_read_nodeset_ids () |
void | test_write_polygons () |
void | test_write_polyhedra () |
void | test_read_polygons () |
void | test_read_polyhedra () |
void | test_read_alternate_coord_format () |
int | main () |
void | load_file_one (Interface *iface) |
void | check_type (const TestType &type) |
void | write_and_read (Interface &write_mb, Interface &read_mb, EntityHandle block=0) |
void | check_ho_elements (Interface &moab, EntityHandle block, EntityType type, int mid_nodes[4]) |
EntityHandle | find_block (Interface &mb, EntityType type, const int has_mid_nodes[4]) |
EntityHandle | find_sideset (Interface &mb, int sideset_id, EntityType) |
void | test_read_ids_common (const char *file_name, const char *tag_name, const int *expected_vals, int num_expected) |
Variables | |
static const char | ho_file [] = "ho_test.g" |
static const char | file_one [] = "mbtest1.g" |
static const char | alt_file [] = "hex_2x2x2_ss.exo" |
static const char | polyg [] = "poly8-10.vtk" |
static const char | polyh [] = "polyhedra.vtk" |
static const char | rpolyg [] = "polyg.exo" |
static const char | rpolyh [] = "polyh.exo" |
#define IS_BUILDING_MB |
Definition at line 8 of file exodus_test.cpp.
void check_ho_element | ( | Interface & | moab, |
EntityHandle | entity, | ||
int | mid_nodes[4] | ||
void check_ho_elements | ( | Interface & | moab, |
EntityHandle | block, | ||
EntityType | type, | ||
Definition at line 767 of file exodus_test.cpp.
References moab::Range::all_of_type(), moab::Range::begin(), CHECK, CHECK_ERR, check_ho_element(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), and MBENTITYSET.
Referenced by test_read_side().
{ ErrorCode rval; Range elems; rval = moab.get_entities_by_handle( block, elems, ( type != MBENTITYSET ? true : false ) );CHECK_ERR( rval ); CHECK( !elems.empty() ); CHECK( elems.all_of_type( type ) ); for( Range::const_iterator i = elems.begin(); i != elems.end(); ++i ) check_ho_element( moab, *i, mid_nodes ); }
void check_type | ( | const TestType & | type | ) |
Definition at line 678 of file exodus_test.cpp.
References CHECK_EQUAL, dim, moab::CN::Dimension(), moab::ExoIIUtil::element_name_to_type(), moab::ExoIIUtil::element_type_name(), moab::ExoIIUtil::ElementTypeNames, TestType::exo_type, moab::ExoIIUtil::ExoIIElementMBEntity, moab::ExoIIUtil::HasMidNodes, moab::CN::HasMidNodes(), TestType::moab_type, TestType::name, TestType::num_nodes, and moab::ExoIIUtil::VerticesPerElement.
Referenced by test_types().
{ int has_mid_nodes[4]; CN::HasMidNodes( type.moab_type, type.num_nodes, has_mid_nodes ); CHECK_EQUAL( type.moab_type, ExoIIUtil::ExoIIElementMBEntity[type.exo_type] ); CHECK_EQUAL( type.name, std::string( ExoIIUtil::ElementTypeNames[type.exo_type] ) ); CHECK_EQUAL( type.num_nodes, ExoIIUtil::VerticesPerElement[type.exo_type] ); auto dim = CN::Dimension( type.moab_type ); if( 3 == dim ) CHECK_EQUAL( has_mid_nodes[3], ExoIIUtil::HasMidNodes[type.exo_type][3] ); if( 2 <= dim ) CHECK_EQUAL( has_mid_nodes[2], ExoIIUtil::HasMidNodes[type.exo_type][2] ); if( 1 <= dim ) CHECK_EQUAL( has_mid_nodes[1], ExoIIUtil::HasMidNodes[type.exo_type][1] ); Core moab; ExoIIUtil tool( &moab ); CHECK_EQUAL( type.exo_type, tool.element_name_to_type( type.name.c_str() ) ); CHECK_EQUAL( type.name, std::string( tool.element_type_name( type.exo_type ) ) ); }
EntityHandle find_block | ( | Interface & | mb, |
const int | has_mid_nodes[4] | ||
Definition at line 837 of file exodus_test.cpp.
References moab::Range::begin(), CHECK, CHECK_ERR, moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_type(), HAS_MID_NODES_TAG_NAME, MATERIAL_SET_TAG_NAME, MB_TYPE_INTEGER, MBENTITYSET, n, and moab::Interface::tag_get_handle().
{ ErrorCode rval; Tag ho_tag, block_tag; const int negone = -1; rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, block_tag, 0, &negone );CHECK_ERR( rval ); const int mids[] = { -1, -1, -1, -1 }; rval = mb.tag_get_handle( HAS_MID_NODES_TAG_NAME, 4, MB_TYPE_INTEGER, ho_tag, 0, mids );CHECK_ERR( rval ); // get material sets with expected higher-order nodes Range blocks; Tag tags[2] = { ho_tag, block_tag }; const void* vals[2] = { has_mid_nodes, NULL }; rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, tags, vals, 2, blocks );CHECK_ERR( rval ); for( Range::iterator i = blocks.begin(); i != blocks.end(); ++i ) { int n; rval = mb.get_number_entities_by_type( *i, type, n );CHECK_ERR( rval ); if( n > 0 ) return *i; } CHECK( false ); // no block matching element type description return 0; }
EntityHandle find_sideset | ( | Interface & | mb, |
int | sideset_id, | ||
EntityType | |||
Definition at line 864 of file exodus_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type_and_tag(), MB_TYPE_INTEGER, MBENTITYSET, NEUMANN_SET_TAG_NAME, moab::Range::size(), and moab::Interface::tag_get_handle().
{ ErrorCode rval; Tag ss_tag; const int negone = -1; rval = mb.tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, ss_tag, 0, &negone );CHECK_ERR( rval ); const void* tag_vals[] = { &sideset_id }; Range side_sets; rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &ss_tag, tag_vals, 1, side_sets );CHECK_ERR( rval ); CHECK_EQUAL( 1, (int)side_sets.size() ); return side_sets.front(); }
void load_file_one | ( | Interface * | iface | ) |
Definition at line 186 of file exodus_test.cpp.
References CHECK_ERR, moab::error(), ErrorCode, file_one, moab::Interface::get_last_error(), moab::Interface::load_mesh(), and MB_SUCCESS.
Referenced by mb_bar_connectivity_test(), mb_hex_connectivity_test(), mb_quad_connectivity_test(), mb_tet_connectivity_test(), mb_tri_connectivity_test(), mb_vertex_coordinate_test(), and mb_write_mesh_test().
{ ErrorCode error = iface->load_mesh( file_one ); if( MB_SUCCESS != error ) { std::cout << "Failed to load input file: " << file_one << std::endl; std::string error_reason; iface->get_last_error( error_reason ); std::cout << error_reason << std::endl; } CHECK_ERR( error ); }
int main | ( | ) |
Definition at line 141 of file exodus_test.cpp.
References mb_bar_connectivity_test(), mb_hex_connectivity_test(), mb_quad_connectivity_test(), mb_tet_connectivity_test(), mb_tri_connectivity_test(), mb_vertex_coordinate_test(), mb_write_mesh_test(), RUN_TEST, test_hex20(), test_hex27(), test_hex9(), test_quad5(), test_quad8(), test_quad9(), test_read_alternate_coord_format(), test_read_block_ids(), test_read_hex20_side(), test_read_nodeset_ids(), test_read_polygons(), test_read_polyhedra(), test_read_shell_edge(), test_read_shell_side(), test_read_sideset_ids(), test_read_tri6_side(), test_tet10(), test_tet14(), test_tet8(), test_tri6(), test_tri7(), test_types(), test_write_polygons(), and test_write_polyhedra().
{ int result = 0; result += RUN_TEST( mb_vertex_coordinate_test ); result += RUN_TEST( mb_bar_connectivity_test ); result += RUN_TEST( mb_tri_connectivity_test ); result += RUN_TEST( mb_quad_connectivity_test ); result += RUN_TEST( mb_hex_connectivity_test ); result += RUN_TEST( mb_tet_connectivity_test ); result += RUN_TEST( mb_write_mesh_test ); result += RUN_TEST( test_types ); result += RUN_TEST( test_tri6 ); result += RUN_TEST( test_tri7 ); result += RUN_TEST( test_quad5 ); result += RUN_TEST( test_quad8 ); result += RUN_TEST( test_quad9 ); result += RUN_TEST( test_tet8 ); result += RUN_TEST( test_tet10 ); result += RUN_TEST( test_tet14 ); result += RUN_TEST( test_hex9 ); result += RUN_TEST( test_hex20 ); result += RUN_TEST( test_hex27 ); result += RUN_TEST( test_read_tri6_side ); result += RUN_TEST( test_read_shell_side ); result += RUN_TEST( test_read_shell_edge ); result += RUN_TEST( test_read_hex20_side ); result += RUN_TEST( test_read_block_ids ); result += RUN_TEST( test_read_sideset_ids ); result += RUN_TEST( test_read_nodeset_ids ); result += RUN_TEST( test_read_alternate_coord_format ); result += RUN_TEST( test_write_polygons ); result += RUN_TEST( test_write_polyhedra ); result += RUN_TEST( test_read_polygons ); result += RUN_TEST( test_read_polyhedra ); return result; }
void mb_bar_connectivity_test | ( | ) |
Definition at line 248 of file exodus_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, conn, moab::error(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), load_file_one(), and MBEDGE.
Referenced by main().
{ Core moab; Interface* MB = &moab; load_file_one( MB ); std::vector< EntityHandle > conn; Range bars; ErrorCode error = MB->get_entities_by_type( 0, MBEDGE, bars );CHECK_ERR( error ); // get the connectivity of the second bar EntityHandle handle = *( ++bars.begin() ); error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error ); CHECK_EQUAL( (size_t)2, conn.size() ); // from ncdump the connectivity of bar 2 (0 based) is // 14, 13 CHECK_EQUAL( (EntityHandle)14, conn[0] ); CHECK_EQUAL( (EntityHandle)13, conn[1] ); // Now try getting the connectivity of one of the vertices for fun. // just return the vertex in the connectivity handle = conn[0]; error = MB->get_connectivity( &handle, 1, conn ); CHECK_EQUAL( MB_FAILURE, error ); }
void mb_hex_connectivity_test | ( | ) |
Definition at line 330 of file exodus_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, conn, moab::error(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), load_file_one(), and MBHEX.
{ Core moab; Interface* MB = &moab; load_file_one( MB ); std::vector< EntityHandle > conn; Range hexes; ErrorCode error = MB->get_entities_by_type( 0, MBHEX, hexes );CHECK_ERR( error ); // get the connectivity of the second hex EntityHandle handle = *( ++hexes.begin() ); error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error ); CHECK_EQUAL( (size_t)8, conn.size() ); // from ncdump the connectivity of hex 1 (0 based) is // 19, 13, 16, 23, 21, 14, 18, 27 CHECK_EQUAL( (EntityHandle)19, conn[0] ); CHECK_EQUAL( (EntityHandle)13, conn[1] ); CHECK_EQUAL( (EntityHandle)16, conn[2] ); CHECK_EQUAL( (EntityHandle)23, conn[3] ); CHECK_EQUAL( (EntityHandle)21, conn[4] ); CHECK_EQUAL( (EntityHandle)14, conn[5] ); CHECK_EQUAL( (EntityHandle)18, conn[6] ); CHECK_EQUAL( (EntityHandle)27, conn[7] ); }
void mb_quad_connectivity_test | ( | ) |
Definition at line 303 of file exodus_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, conn, moab::error(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), load_file_one(), and MBQUAD.
{ Core moab; Interface* MB = &moab; load_file_one( MB ); std::vector< EntityHandle > conn; Range quads; ErrorCode error = MB->get_entities_by_type( 0, MBQUAD, quads );CHECK_ERR( error ); // get the connectivity of the second quad EntityHandle handle = *( ++quads.begin() ); error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error ); CHECK_EQUAL( (size_t)4, conn.size() ); // from ncdump the connectivity of quad 2 (0 based) is // 20, 11, 12, 26, CHECK_EQUAL( (EntityHandle)20, conn[0] ); CHECK_EQUAL( (EntityHandle)11, conn[1] ); CHECK_EQUAL( (EntityHandle)12, conn[2] ); CHECK_EQUAL( (EntityHandle)26, conn[3] ); }
void mb_tet_connectivity_test | ( | ) |
Definition at line 361 of file exodus_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, conn, moab::error(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), load_file_one(), and MBTET.
{ Core moab; Interface* MB = &moab; load_file_one( MB ); std::vector< EntityHandle > conn; Range tets; ErrorCode error = MB->get_entities_by_type( 0, MBTET, tets );CHECK_ERR( error ); // get the connectivity of the second tet EntityHandle handle = *( ++tets.begin() ); error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error ); CHECK_EQUAL( (size_t)4, conn.size() ); // from ncdump the connectivity of tet 2 (0 based) is: // 35, 34, 32, 43 CHECK_EQUAL( (EntityHandle)35, conn[0] ); CHECK_EQUAL( (EntityHandle)34, conn[1] ); CHECK_EQUAL( (EntityHandle)32, conn[2] ); CHECK_EQUAL( (EntityHandle)43, conn[3] ); }
void mb_tri_connectivity_test | ( | ) |
Definition at line 278 of file exodus_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, conn, moab::error(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), load_file_one(), and MBTRI.
{ Core moab; Interface* MB = &moab; load_file_one( MB ); std::vector< EntityHandle > conn; Range tris; ErrorCode error = MB->get_entities_by_type( 0, MBTRI, tris );CHECK_ERR( error ); // get the connectivity of the second tri EntityHandle handle = *( ++tris.begin() ); error = MB->get_connectivity( &handle, 1, conn );CHECK_ERR( error ); CHECK_EQUAL( (size_t)3, conn.size() ); // from ncdump the connectivity of tri 2 (0 based) is // 45, 37, 38 CHECK_EQUAL( (EntityHandle)45, conn[0] ); CHECK_EQUAL( (EntityHandle)37, conn[1] ); CHECK_EQUAL( (EntityHandle)38, conn[2] ); }
void mb_vertex_coordinate_test | ( | ) |
Definition at line 206 of file exodus_test.cpp.
References CHECK_ARRAYS_EQUAL, CHECK_EQUAL, CHECK_ERR, moab::CREATE_HANDLE(), moab::error(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_number_entities_by_type(), load_file_one(), and MBVERTEX.
{ double coords[3]; EntityHandle handle; ErrorCode error; int err; Core moab; Interface* MB = &moab; load_file_one( MB ); // coordinate 2 should be {1.5, -1.5, 3.5} handle = CREATE_HANDLE( MBVERTEX, 2, err ); error = MB->get_coords( &handle, 1, coords );CHECK_ERR( error ); const double exp2[] = { 1.5, -1.5, 3.5 }; CHECK_ARRAYS_EQUAL( exp2, 3, coords, 3 ); // coordinate 9 should be {1, -2, 3.5} handle = CREATE_HANDLE( MBVERTEX, 9, err ); error = MB->get_coords( &handle, 1, coords );CHECK_ERR( error ); const double exp9[] = { 1, -2, 3.5 }; CHECK_ARRAYS_EQUAL( exp9, 3, coords, 3 ); // coordinate 7 should be {0.5, -2, 3.5} handle = CREATE_HANDLE( MBVERTEX, 7, err ); error = MB->get_coords( &handle, 1, coords );CHECK_ERR( error ); const double exp7[] = { 0.5, -2, 3.5 }; CHECK_ARRAYS_EQUAL( exp7, 3, coords, 3 ); int node_count = 0; error = MB->get_number_entities_by_type( 0, MBVERTEX, node_count );CHECK_ERR( error ); // Number of vertices (node_count) should be 83 assuming no gaps in the handle space CHECK_EQUAL( 47, node_count ); }
void mb_write_mesh_test | ( | ) |
Definition at line 387 of file exodus_test.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), CHECK_ERR, moab::Range::clear(), moab::Interface::create_meshset(), DIRICHLET_SET_TAG_NAME, moab::Range::end(), ErrorCode, GEOM_DIMENSION_TAG_NAME, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::ID_FROM_HANDLE(), moab::Range::insert(), load_file_one(), MATERIAL_SET_TAG_NAME, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBHEX, MBQUAD, MESHSET_TRACK_OWNER, NEUMANN_SET_TAG_NAME, moab::Range::size(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::Interface::write_mesh().
{ Core moab; Interface* MB = &moab; load_file_one( MB ); ErrorCode result; std::string file_name = "mb_write.g"; // no need to get lists, write out the whole mesh result = MB->write_mesh( file_name.c_str() );CHECK_ERR( result ); //---------The following tests outputting meshsets that are in meshsets of blocks ---/ // lets create a block meshset and put some entities and meshsets into it EntityHandle block_ms; result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, block_ms );CHECK_ERR( result ); // make another meshset to put quads in, so SHELLs can be written out EntityHandle block_of_shells; result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, block_of_shells );CHECK_ERR( result ); // tag the meshset so it's a block, with id 100 int id = 100; Tag tag_handle; const int negone = -1; result = MB->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result ); result = MB->tag_set_data( tag_handle, &block_ms, 1, &id );CHECK_ERR( result ); id = 101; result = MB->tag_set_data( tag_handle, &block_of_shells, 1, &id );CHECK_ERR( result ); // set dimension tag on this to ensure shells get output; reuse id variable result = MB->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result ); id = 3; result = MB->tag_set_data( tag_handle, &block_of_shells, 1, &id );CHECK_ERR( result ); // get some entities (tets) Range temp_range; result = MB->get_entities_by_type( 0, MBHEX, temp_range );CHECK_ERR( result ); Range::iterator iter, end_iter; iter = temp_range.begin(); end_iter = temp_range.end(); // add evens to 'block_ms' std::vector< EntityHandle > temp_vec; for( ; iter != end_iter; ++iter ) { if( ID_FROM_HANDLE( *iter ) % 2 == 0 ) temp_vec.push_back( *iter ); } result = MB->add_entities( block_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); // make another meshset EntityHandle ms_of_block_ms; result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_block_ms );CHECK_ERR( result ); // add some entities to it temp_vec.clear(); iter = temp_range.begin(); for( ; iter != end_iter; ++iter ) { if( ID_FROM_HANDLE( *iter ) % 2 ) // add all odds temp_vec.push_back( *iter ); } result = MB->add_entities( ms_of_block_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); // add the other meshset to the block's meshset result = MB->add_entities( block_ms, &ms_of_block_ms, 1 );CHECK_ERR( result ); //---------------testing sidesets----------------/ // lets create a sideset meshset and put some entities and meshsets into it EntityHandle sideset_ms; result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, sideset_ms );CHECK_ERR( result ); // tag the meshset so it's a sideset, with id 104 id = 104; result = MB->tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result ); result = MB->tag_set_data( tag_handle, &sideset_ms, 1, &id );CHECK_ERR( result ); // get some entities (tris) temp_range.clear(); result = MB->get_entities_by_type( 0, MBQUAD, temp_range );CHECK_ERR( result ); iter = temp_range.begin(); end_iter = temp_range.end(); // add evens to 'sideset_ms' temp_vec.clear(); for( ; iter != end_iter; ++iter ) { if( ID_FROM_HANDLE( *iter ) % 2 == 0 ) temp_vec.push_back( *iter ); } result = MB->add_entities( sideset_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); // make another meshset EntityHandle ms_of_sideset_ms; result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_sideset_ms );CHECK_ERR( result ); // add some entities to it temp_vec.clear(); iter = temp_range.begin(); for( ; iter != end_iter; ++iter ) { if( ID_FROM_HANDLE( *iter ) % 2 ) // add all odds temp_vec.push_back( *iter ); } result = MB->add_entities( ms_of_sideset_ms, &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); // add the other meshset to the sideset's meshset result = MB->add_entities( sideset_ms, &ms_of_sideset_ms, 1 );CHECK_ERR( result ); //---------test sense on meshsets (reverse/foward)-------// // get all quads whose x-coord = 2.5 and put them into a meshset_a EntityHandle meshset_a; result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_a );CHECK_ERR( result ); temp_range.clear(); result = MB->get_entities_by_type( 0, MBQUAD, temp_range );CHECK_ERR( result ); std::vector< EntityHandle > nodes1, entity_vec; std::copy( temp_range.begin(), temp_range.end(), std::back_inserter( entity_vec ) ); result = MB->get_connectivity( &entity_vec[0], entity_vec.size(), nodes1 );CHECK_ERR( result ); assert( nodes1.size() == 4 * temp_range.size() ); temp_vec.clear(); std::vector< double > coords( 3 * nodes1.size() ); result = MB->get_coords( &nodes1[0], nodes1.size(), &coords[0] );CHECK_ERR( result ); unsigned int k = 0; for( Range::iterator it = temp_range.begin(); it != temp_range.end(); ++it ) { if( coords[12 * k] == 2.5 && coords[12 * k + 3] == 2.5 && coords[12 * k + 6] == 2.5 && coords[12 * k + 9] == 2.5 ) temp_vec.push_back( *it ); k++; } result = MB->add_entities( meshset_a, ( temp_vec.empty() ) ? NULL : &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); result = MB->add_entities( block_of_shells, ( temp_vec.empty() ) ? NULL : &temp_vec[0], temp_vec.size() );CHECK_ERR( result ); // put these quads into a different meshset_b and tag them with a reverse sense tag EntityHandle meshset_b; result = MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_b );CHECK_ERR( result ); result = MB->add_entities( meshset_b, &meshset_a, 1 );CHECK_ERR( result ); result = MB->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, tag_handle, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( result ); int reverse_value = -1; result = MB->tag_set_data( tag_handle, &meshset_b, 1, &reverse_value );CHECK_ERR( result ); // get some random quad, whose x-coord != 2.5, and put it into a different meshset_c // and tag it with a reverse sense tag iter = temp_range.begin(); end_iter = temp_range.end(); temp_vec.clear(); for( ; iter != end_iter; ++iter ) { std::vector< EntityHandle > nodes; result = MB->get_connectivity( &( *iter ), 1, nodes );CHECK_ERR( result ); bool not_equal_2_5 = true; for( unsigned int ku = 0; ku < nodes.size(); ku++ ) { double coords2[3] = { 0 }; result = MB->get_coords( &( nodes[ku] ), 1, coords2 );CHECK_ERR( result ); if( coords2[0] == 2.5 ) { not_equal_2_5 = false; break; } } if( not_equal_2_5 && nodes.size() > 0 ) { temp_vec.push_back( *iter ); break; } } EntityHandle meshset_c; MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_c ); result = MB->tag_get_handle( "SENSE", 1, MB_TYPE_INTEGER, tag_handle );CHECK_ERR( result ); reverse_value = -1; result = MB->tag_set_data( tag_handle, &meshset_c, 1, &reverse_value );CHECK_ERR( result ); MB->add_entities( meshset_c, &temp_vec[0], temp_vec.size() ); MB->add_entities( block_of_shells, &temp_vec[0], temp_vec.size() ); // create another meshset_abc, adding meshset_a, meshset_b, meshset_c EntityHandle meshset_abc; MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, meshset_abc ); temp_vec.clear(); temp_vec.push_back( meshset_a ); temp_vec.push_back( meshset_b ); temp_vec.push_back( meshset_c ); MB->add_entities( meshset_abc, &temp_vec[0], temp_vec.size() ); // tag it so it's a sideset id = 444; result = MB->tag_get_handle( "NEUMANN_SET", 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result ); result = MB->tag_set_data( tag_handle, &meshset_abc, 1, &id );CHECK_ERR( result ); //---------------do nodesets now -----------------// // lets create a nodeset meshset and put some entities and meshsets into it EntityHandle nodeset_ms; MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, nodeset_ms ); // tag the meshset so it's a nodeset, with id 119 id = 119; result = MB->tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handle, 0, &negone );CHECK_ERR( result ); result = MB->tag_set_data( tag_handle, &nodeset_ms, 1, &id );CHECK_ERR( result ); // get all Quads temp_range.clear(); result = MB->get_entities_by_type( 0, MBQUAD, temp_range );CHECK_ERR( result ); // get all the nodes of the tris Range nodes_of_quads; iter = temp_range.begin(); end_iter = temp_range.end(); for( ; iter != end_iter; ++iter ) { std::vector< EntityHandle > nodes; result = MB->get_connectivity( &( *iter ), 1, nodes );CHECK_ERR( result ); for( unsigned int ku = 0; ku < nodes.size(); ku++ ) nodes_of_quads.insert( nodes[ku] ); } iter = nodes_of_quads.begin(); end_iter = nodes_of_quads.end(); // add evens to 'nodeset_ms' temp_vec.clear(); for( ; iter != end_iter; ++iter ) { if( ID_FROM_HANDLE( *iter ) % 2 == 0 ) temp_vec.push_back( *iter ); } MB->add_entities( nodeset_ms, &temp_vec[0], temp_vec.size() ); // make another meshset EntityHandle ms_of_nodeset_ms; MB->create_meshset( MESHSET_ORDERED | MESHSET_TRACK_OWNER, ms_of_nodeset_ms ); // add some entities to it temp_vec.clear(); iter = nodes_of_quads.begin(); end_iter = nodes_of_quads.end(); for( ; iter != end_iter; ++iter ) { if( ID_FROM_HANDLE( *iter ) % 2 ) // add all odds temp_vec.push_back( *iter ); } MB->add_entities( ms_of_nodeset_ms, &temp_vec[0], temp_vec.size() ); // add the other meshset to the nodeset's meshset MB->add_entities( nodeset_ms, &ms_of_nodeset_ms, 1 ); // no need to get lists, write out the whole mesh file_name = "mb_write2.g"; std::vector< EntityHandle > output_list; output_list.push_back( block_ms ); output_list.push_back( sideset_ms ); output_list.push_back( meshset_abc ); output_list.push_back( nodeset_ms ); output_list.push_back( block_of_shells ); result = MB->write_mesh( file_name.c_str(), &output_list[0], output_list.size() );CHECK_ERR( result ); }
Definition at line 748 of file exodus_test.cpp.
References CHECK_ERR, ErrorCode, and moab::Interface::load_file().
{ ErrorCode rval = moab.load_file( input_file );CHECK_ERR( rval ); }
void test_hex20 | ( | ) |
Definition at line 105 of file exodus_test.cpp.
References MBHEX, and test_ho_elements().
{ test_ho_elements( MBHEX, 20 ); }
void test_hex27 | ( | ) |
Definition at line 109 of file exodus_test.cpp.
{ test_ho_elements( MBHEX, 27 ); }
void test_hex9 | ( | ) |
Definition at line 101 of file exodus_test.cpp.
{ test_ho_elements( MBHEX, 9 ); }
void test_ho_elements | ( | EntityType | type, |
int | num_nodes | ||
void test_quad5 | ( | ) |
Definition at line 75 of file exodus_test.cpp.
References MBQUAD, and test_ho_elements().
{ test_ho_elements( MBQUAD, 5 ); }
void test_quad8 | ( | ) |
Definition at line 79 of file exodus_test.cpp.
{ test_ho_elements( MBQUAD, 8 ); }
void test_quad9 | ( | ) |
Definition at line 83 of file exodus_test.cpp.
{ test_ho_elements( MBQUAD, 9 ); }
void test_read_alternate_coord_format | ( | ) |
Definition at line 967 of file exodus_test.cpp.
References alt_file, CHECK_ARRAYS_EQUAL, CHECK_EQUAL, CHECK_ERR, conn, ErrorCode, moab::Range::front(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Interface::load_file(), mb, MBHEX, and moab::Range::size().
{ Core moab; Interface& mb = moab; ErrorCode rval = mb.load_file( alt_file );CHECK_ERR( rval ); const double exp[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1 }; Range hexes; rval = mb.get_entities_by_type( 0, MBHEX, hexes );CHECK_ERR( rval ); CHECK_EQUAL( (size_t)1, hexes.size() ); EntityHandle hex = hexes.front(); const EntityHandle* conn; int len; rval = mb.get_connectivity( hex, conn, len );CHECK_ERR( rval ); CHECK_EQUAL( 8, len ); double act[3 * 8]; rval = mb.get_coords( conn, len, act );CHECK_ERR( rval ); CHECK_ARRAYS_EQUAL( exp, 3 * 8, act, 3 * 8 ); }
void test_read_block_ids | ( | ) |
Definition at line 950 of file exodus_test.cpp.
References ho_file, MATERIAL_SET_TAG_NAME, and test_read_ids_common().
{ const int expected[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 }; test_read_ids_common( ho_file, MATERIAL_SET_TAG_NAME, expected, sizeof( expected ) / sizeof( expected[0] ) ); }
void test_read_hex20_side | ( | ) |
Definition at line 126 of file exodus_test.cpp.
References MBQUAD, and test_read_side().
{ test_read_side( 2, MBQUAD, 8 ); } // sideset 2
void test_read_ids_common | ( | const char * | file_name, |
const char * | tag_name, | ||
const int * | expected_vals, | ||
int | num_expected | ||
Definition at line 935 of file exodus_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, mb, and moab::ReadNCDF::read_tag_values().
Referenced by test_read_block_ids(), test_read_nodeset_ids(), and test_read_sideset_ids().
{ Core mb; ReadNCDF reader( &mb ); FileOptions opts( "" ); std::vector< int > values; ErrorCode rval = reader.read_tag_values( file_name, tag_name, opts, values );CHECK_ERR( rval ); std::vector< int > expected( expected_vals, expected_vals + num_expected ); std::sort( values.begin(), values.end() ); std::sort( expected.begin(), expected.end() ); CHECK_EQUAL( expected, values ); }
void test_read_nodeset_ids | ( | ) |
Definition at line 962 of file exodus_test.cpp.
References DIRICHLET_SET_TAG_NAME, ho_file, and test_read_ids_common().
{ test_read_ids_common( ho_file, DIRICHLET_SET_TAG_NAME, 0, 0 ); }
void test_read_polygons | ( | ) |
void test_read_polyhedra | ( | ) |
void test_read_shell_edge | ( | ) |
Definition at line 122 of file exodus_test.cpp.
References MBEDGE, and test_read_side().
{ test_read_side( 4, MBEDGE, 3 ); } // sideset 4
void test_read_shell_side | ( | ) |
Definition at line 118 of file exodus_test.cpp.
{ test_read_side( 3, MBQUAD, 9, true ); } // sideset 3
void test_read_side | ( | int | sideset_id, |
EntityType | sideset_type, | ||
int | sideset_nodes_per_elem, | ||
bool | shell_side = false |
Definition at line 904 of file exodus_test.cpp.
References MBMesquite::adj(), moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, check_ho_elements(), dim, moab::CN::Dimension(), moab::Range::end(), ErrorCode, find_sideset(), moab::Core::get_adjacencies(), moab::Core::get_entities_by_handle(), moab::CN::HasMidNodes(), ho_file, read_file(), moab::Range::size(), and moab::Interface::UNION.
Referenced by test_read_hex20_side(), test_read_shell_edge(), test_read_shell_side(), and test_read_tri6_side().
{ // read test file Core mb_impl; Interface& moab = mb_impl; read_file( moab, ho_file ); // get side set EntityHandle set = find_sideset( moab, id, sideset_type ); CHECK( set != 0 ); // check expected element connectivity int ho_flags[4]; CN::HasMidNodes( sideset_type, sideset_nodes_per_elem, ho_flags ); check_ho_elements( moab, set, sideset_type, ho_flags ); if( shell_side ) return; // check that each element is on the boundary of the mesh Range elems; ErrorCode rval = mb_impl.get_entities_by_handle( set, elems );CHECK_ERR( rval ); int dim = CN::Dimension( sideset_type ); for( Range::iterator i = elems.begin(); i != elems.end(); ++i ) { Range adj; rval = mb_impl.get_adjacencies( &*i, 1, dim + 1, false, adj, Interface::UNION );CHECK_ERR( rval ); CHECK_EQUAL( 1, (int)adj.size() ); } }
void test_read_sideset_ids | ( | ) |
Definition at line 956 of file exodus_test.cpp.
References ho_file, NEUMANN_SET_TAG_NAME, and test_read_ids_common().
{ const int expected[] = { 1, 2, 3, 4 }; test_read_ids_common( ho_file, NEUMANN_SET_TAG_NAME, expected, sizeof( expected ) / sizeof( expected[0] ) ); }
void test_read_tri6_side | ( | ) |
Definition at line 114 of file exodus_test.cpp.
{ test_read_side( 1, MBEDGE, 3 ); } // sideset 1
void test_tet10 | ( | ) |
Definition at line 92 of file exodus_test.cpp.
References MBTET, and test_ho_elements().
{ test_ho_elements( MBTET, 10 ); }
void test_tet14 | ( | ) |
Definition at line 96 of file exodus_test.cpp.
{ test_ho_elements( MBTET, 14 ); }
void test_tet8 | ( | ) |
Definition at line 88 of file exodus_test.cpp.
{ test_ho_elements( MBTET, 8 ); }
void test_tri6 | ( | ) |
Definition at line 66 of file exodus_test.cpp.
References MBTRI, and test_ho_elements().
{ test_ho_elements( MBTRI, 6 ); }
void test_tri7 | ( | ) |
Definition at line 70 of file exodus_test.cpp.
{ test_ho_elements( MBTRI, 7 ); }
void test_types | ( | ) |
Definition at line 697 of file exodus_test.cpp.
References check_type(), moab::EXOII_BAR, moab::EXOII_BAR2, moab::EXOII_BAR3, moab::EXOII_BEAM, moab::EXOII_BEAM2, moab::EXOII_BEAM3, moab::EXOII_HEX, moab::EXOII_HEX20, moab::EXOII_HEX27, moab::EXOII_HEX8, moab::EXOII_HEX9, moab::EXOII_HEXSHELL, moab::EXOII_KNIFE, moab::EXOII_PYRAMID, moab::EXOII_PYRAMID10, moab::EXOII_PYRAMID13, moab::EXOII_PYRAMID18, moab::EXOII_PYRAMID5, moab::EXOII_QUAD, moab::EXOII_QUAD4, moab::EXOII_QUAD5, moab::EXOII_QUAD8, moab::EXOII_QUAD9, moab::EXOII_SHELL, moab::EXOII_SHELL4, moab::EXOII_SHELL5, moab::EXOII_SHELL8, moab::EXOII_SHELL9, moab::EXOII_SPHERE, moab::EXOII_SPRING, moab::EXOII_TET4, moab::EXOII_TETRA, moab::EXOII_TETRA10, moab::EXOII_TETRA14, moab::EXOII_TETRA4, moab::EXOII_TETRA8, moab::EXOII_TRI, moab::EXOII_TRI3, moab::EXOII_TRI6, moab::EXOII_TRI7, moab::EXOII_TRUSS, moab::EXOII_TRUSS2, moab::EXOII_TRUSS3, moab::EXOII_WEDGE, MBEDGE, MBHEX, MBKNIFE, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, and MBVERTEX.
{ const TestType types[] = { { MBVERTEX, EXOII_SPHERE, 1, "SPHERE" }, { MBEDGE, EXOII_SPRING, 1, "SPRING" }, { MBEDGE, EXOII_BAR, 2, "BAR" }, { MBEDGE, EXOII_BAR2, 2, "BAR2" }, { MBEDGE, EXOII_BAR3, 3, "BAR3" }, { MBEDGE, EXOII_BEAM, 2, "BEAM" }, { MBEDGE, EXOII_BEAM2, 2, "BEAM2" }, { MBEDGE, EXOII_BEAM3, 3, "BEAM3" }, { MBEDGE, EXOII_TRUSS, 2, "TRUSS" }, { MBEDGE, EXOII_TRUSS2, 2, "TRUSS2" }, { MBEDGE, EXOII_TRUSS3, 3, "TRUSS3" }, { MBTRI, EXOII_TRI, 3, "TRI" }, { MBTRI, EXOII_TRI3, 3, "TRI3" }, { MBTRI, EXOII_TRI6, 6, "TRI6" }, { MBTRI, EXOII_TRI7, 7, "TRI7" }, { MBQUAD, EXOII_QUAD, 4, "QUAD" }, { MBQUAD, EXOII_QUAD4, 4, "QUAD4" }, { MBQUAD, EXOII_QUAD5, 5, "QUAD5" }, { MBQUAD, EXOII_QUAD8, 8, "QUAD8" }, { MBQUAD, EXOII_QUAD9, 9, "QUAD9" }, { MBQUAD, EXOII_SHELL, 4, "SHELL" }, { MBQUAD, EXOII_SHELL4, 4, "SHELL4" }, { MBQUAD, EXOII_SHELL5, 5, "SHELL5" }, { MBQUAD, EXOII_SHELL8, 8, "SHELL8" }, { MBQUAD, EXOII_SHELL9, 9, "SHELL9" }, { MBTET, EXOII_TETRA, 4, "TETRA" }, { MBTET, EXOII_TETRA4, 4, "TETRA4" }, { MBTET, EXOII_TET4, 4, "TET4" }, { MBTET, EXOII_TETRA8, 8, "TETRA8" }, { MBTET, EXOII_TETRA10, 10, "TETRA10" }, { MBTET, EXOII_TETRA14, 14, "TETRA14" }, { MBPYRAMID, EXOII_PYRAMID, 5, "PYRAMID" }, { MBPYRAMID, EXOII_PYRAMID5, 5, "PYRAMID5" }, { MBPYRAMID, EXOII_PYRAMID10, 10, "PYRAMID10" }, { MBPYRAMID, EXOII_PYRAMID13, 13, "PYRAMID13" }, { MBPYRAMID, EXOII_PYRAMID18, 18, "PYRAMID18" }, { MBPRISM, EXOII_WEDGE, 6, "WEDGE" }, { MBKNIFE, EXOII_KNIFE, 7, "KNIFE" }, { MBHEX, EXOII_HEX, 8, "HEX" }, { MBHEX, EXOII_HEX8, 8, "HEX8" }, { MBHEX, EXOII_HEX9, 9, "HEX9" }, { MBHEX, EXOII_HEX20, 20, "HEX20" }, { MBHEX, EXOII_HEX27, 27, "HEX27" }, { MBHEX, EXOII_HEXSHELL, 12, "HEXSHELL" } }; const int num_types = sizeof( types ) / sizeof( types[0] ); for( int i = 0; i < num_types; ++i ) check_type( types[i] ); }
void test_write_polygons | ( | ) |
Definition at line 987 of file exodus_test.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::load_file(), mb, polyg, and moab::Interface::write_file().
void test_write_polyhedra | ( | ) |
Definition at line 995 of file exodus_test.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::load_file(), mb, polyh, and moab::Interface::write_file().
void write_and_read | ( | Interface & | write_mb, |
Interface & | read_mb, | ||
EntityHandle | block = 0 |
Definition at line 753 of file exodus_test.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::load_file(), MB_SUCCESS, tmp_file, and moab::Interface::write_file().
Referenced by check_tag_data(), and test_read_write_element().
{ const char* tmp_file = "exodus_test_tmp.g"; ErrorCode rval; EntityHandle* write_set_list = █ int write_set_list_len = 0; //(block != 0); rval = write_mb.write_file( tmp_file, "EXODUS", 0, write_set_list, write_set_list_len ); if( MB_SUCCESS != rval ) remove( tmp_file );CHECK_ERR( rval ); rval = read_mb.load_file( tmp_file ); remove( tmp_file );CHECK_ERR( rval ); }
const char alt_file[] = "hex_2x2x2_ss.exo" [static] |
Definition at line 33 of file exodus_test.cpp.
Referenced by test_read_alternate_coord_format().
const char file_one[] = "mbtest1.g" [static] |
Definition at line 32 of file exodus_test.cpp.
Referenced by load_file_one().
const char ho_file[] = "ho_test.g" [static] |
Definition at line 31 of file exodus_test.cpp.
Referenced by test_read_block_ids(), test_read_nodeset_ids(), test_read_side(), and test_read_sideset_ids().
const char polyg[] = "poly8-10.vtk" [static] |
Definition at line 34 of file exodus_test.cpp.
Referenced by moab::WriteNCDF::initialize_exodus_file(), main(), test_write_polygons(), and moab::WriteNCDF::write_poly_faces().
const char polyh[] = "polyhedra.vtk" [static] |
Definition at line 35 of file exodus_test.cpp.
Referenced by moab::WriteNCDF::initialize_exodus_file(), test_write_polyhedra(), and moab::WriteNCDF::write_elementblocks().
const char rpolyg[] = "polyg.exo" [static] |
Definition at line 36 of file exodus_test.cpp.
Referenced by test_read_polygons().
const char rpolyh[] = "polyh.exo" [static] |
Definition at line 37 of file exodus_test.cpp.
Referenced by test_read_polyhedra().
