MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/FileOptions.hpp"
#include <cctype>
#include <cstdlib>
#include <cstring>
#include <algorithm>
#include <iostream>
Defines | |
#define | CHECK(A) |
#define | EQUAL(A, B) |
Functions | |
int | main () |
#define CHECK | ( | A | ) |
if( MB_SUCCESS != ( A ) ) \ { \ std::cerr << "Failure at line " << __LINE__ << ": error code " << ( A ) << std::endl; \ return 1; \ }
Definition at line 31 of file fileopts_test.cpp.
Referenced by main().
#define EQUAL | ( | A, | |
B | |||
if( ( A ) != ( B ) ) \ { \ std::cerr << "Failure at line " << __LINE__ << ": expected " << ( B ) << " but got " << ( A ) << std::endl; \ return 2; \ }
Definition at line 38 of file fileopts_test.cpp.
int main | ( | ) |
Definition at line 45 of file fileopts_test.cpp.
References moab::FileOptions::all_seen(), CHECK, moab::FileOptions::empty(), EQUAL, ErrorCode, moab::FileOptions::get_int_option(), moab::FileOptions::get_ints_option(), moab::FileOptions::get_null_option(), moab::FileOptions::get_option(), moab::FileOptions::get_real_option(), moab::FileOptions::get_reals_option(), moab::FileOptions::get_str_option(), moab::FileOptions::get_strs_option(), moab::FileOptions::get_unseen_option(), l, MB_ENTITY_NOT_FOUND, MB_TYPE_OUT_OF_RANGE, moab::FileOptions::size(), and u.
{ FileOptions tool( "INT1=1;NUL1;STR1=ABC;DBL1=1.0;dbl2=2.0;DBL3=3.0;INT2=2;nul2;NUL3;INT3=3;str2=once upon a " "time;str3==fubar=;;INTS=1-3,5,6;DBLS=1.0,2.0, 3.0;STRS=var1, var2_var2;STRS2=" ); std::string s; int i; double d; ErrorCode rval; // test basic get_option method without deleting entry rval = tool.get_option( "STR1", s ); CHECK( rval ); EQUAL( s, "ABC" ); // test basic get_option method again, this time deleting the entry rval = tool.get_option( "STR1", s ); CHECK( rval ); EQUAL( s, "ABC" ); // test basig get_option method with a null option rval = tool.get_option( "NUL2", s ); CHECK( rval ); EQUAL( s.empty(), true ); // test null option rval = tool.get_null_option( "nul1" ); CHECK( rval ); // try null option method on non-null value rval = tool.get_null_option( "INT1" ); EQUAL( rval, MB_TYPE_OUT_OF_RANGE ); // test integer option rval = tool.get_int_option( "int1", i ); CHECK( rval ); EQUAL( i, 1 ); rval = tool.get_int_option( "int2", i ); CHECK( rval ); EQUAL( i, 2 ); // test integer option on non-integer value rval = tool.get_int_option( "dbl2", i ); EQUAL( rval, MB_TYPE_OUT_OF_RANGE ); // test integer option on null value rval = tool.get_int_option( "NUL3", i ); EQUAL( rval, MB_TYPE_OUT_OF_RANGE ); // test double option rval = tool.get_real_option( "dbl1", d ); CHECK( rval ); EQUAL( d, 1.0 ); rval = tool.get_real_option( "dbl2", d ); CHECK( rval ); EQUAL( d, 2.0 ); rval = tool.get_real_option( "int3", d ); CHECK( rval ); EQUAL( d, 3.0 ); // test real option on non-real value rval = tool.get_real_option( "str2", d ); EQUAL( rval, MB_TYPE_OUT_OF_RANGE ); // test real option on null value rval = tool.get_real_option( "NUL3", d ); EQUAL( rval, MB_TYPE_OUT_OF_RANGE ); // test get a simple string option rval = tool.get_str_option( "DBL3", s ); CHECK( rval ); EQUAL( s, "3.0" ); // test get a string with spaces rval = tool.get_str_option( "STR2", s ); CHECK( rval ); EQUAL( s, "once upon a time" ); // try to get a string value for a null option rval = tool.get_str_option( "nul3", s ); EQUAL( rval, MB_TYPE_OUT_OF_RANGE ); // We haven't looked at all of the options yet EQUAL( false, tool.all_seen() ); rval = tool.get_unseen_option( s ); CHECK( rval ); EQUAL( s, "str3" ); // test options using generic get_option method rval = tool.get_option( "NUL3", s ); CHECK( rval ); EQUAL( s.empty(), true ); rval = tool.get_option( "STR3", s ); CHECK( rval ); EQUAL( s, "=fubar=" ); // test size of options string unsigned l = tool.size(); EQUAL( l, 16u ); // test ints option std::vector< int > ivals; rval = tool.get_ints_option( "INTS", ivals ); CHECK( rval ); EQUAL( 5, ivals.size() ); EQUAL( 1, ivals[0] ); EQUAL( 2, ivals[1] ); EQUAL( 3, ivals[2] ); EQUAL( 5, ivals[3] ); EQUAL( 6, ivals[4] ); // test dbls option std::vector< double > vals; rval = tool.get_reals_option( "DBLS", vals ); CHECK( rval ); EQUAL( 3, vals.size() ); EQUAL( 1.0, vals[0] ); EQUAL( 2.0, vals[1] ); EQUAL( 3.0, vals[2] ); // test strs option std::vector< std::string > svals; rval = tool.get_strs_option( "STRS", svals ); CHECK( rval ); EQUAL( 2, svals.size() ); EQUAL( "var1", svals[0] ); EQUAL( "var2_var2", svals[1] ); svals.clear(); rval = tool.get_strs_option( "STRS2", svals ); EQUAL( MB_TYPE_OUT_OF_RANGE, rval ); // We requested every option EQUAL( true, tool.all_seen() ); rval = tool.get_unseen_option( s ); EQUAL( MB_ENTITY_NOT_FOUND, rval ); // test alternate separator FileOptions tool2( ";+OPT1=ABC+OPT2=" ); l = tool2.size(); EQUAL( l, 2 ); // We haven't looked at all of the options yet EQUAL( false, tool2.all_seen() ); rval = tool2.get_unseen_option( s ); CHECK( rval ); EQUAL( s, "OPT1" ); rval = tool2.get_option( "opt1", s ); CHECK( rval ); EQUAL( s, "ABC" ); rval = tool2.get_option( "opt2", s ); CHECK( rval ); bool e = s.empty(); EQUAL( e, true ); l = tool2.size(); EQUAL( l, 2 ); // We requested every option EQUAL( true, tool2.all_seen() ); rval = tool2.get_unseen_option( s ); EQUAL( MB_ENTITY_NOT_FOUND, rval ); // test empty options string FileOptions tool3( ";;;;" ); e = tool3.empty(); EQUAL( e, true ); l = tool3.size(); EQUAL( l, 0 ); EQUAL( true, tool3.all_seen() ); FileOptions tool4( NULL ); e = tool4.empty(); EQUAL( e, true ); l = tool4.size(); EQUAL( l, 0 ); EQUAL( true, tool4.all_seen() ); FileOptions tool5( ";+" ); e = tool5.empty(); EQUAL( e, true ); l = tool5.size(); EQUAL( l, 0 ); EQUAL( true, tool5.all_seen() ); // test copy constructor const FileOptions& tool6( tool2 ); rval = tool6.get_option( "opt1", s ); CHECK( rval ); EQUAL( s, "ABC" ); rval = tool6.get_option( "opt2", s ); CHECK( rval ); e = s.empty(); EQUAL( e, true ); l = tool6.size(); EQUAL( l, 2 ); const FileOptions& tool7( tool5 ); e = tool7.empty(); EQUAL( e, true ); l = tool7.size(); EQUAL( l, 0 ); // test assignment operator FileOptions tool8( tool2 ); tool8 = tool; EQUAL( tool8.size(), tool.size() ); return 0; }
