gqt_rayfire_test.cpp File Reference
#include <iostream>
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
#include "moab/GeomQueryTool.hpp"
#include "moab/GeomTopoTool.hpp"
+ Include dependency graph for gqt_rayfire_test.cpp:
Defines
#define IS_BUILDING_MB
#define CHKERR(A)
Functions
void gqt_setup_test ()
void gqt_origin_face_rayfire ()
void gqt_outside_face_rayfire ()
void gqt_outside_face_rayfire_orient_exit ()
void gqt_outside_face_rayfire_orient_entrance ()
void gqt_outside_face_rayfire_history_fail ()
void gqt_outside_face_rayfire_history ()
int main (int, char **)
Variables
InterfaceMBI
GeomTopoToolGTT
GeomQueryToolGQT
const std::string input_file = "unittest/test_geom.h5m"
double eps = 1.0e-6
Define Documentation
#define CHKERR (   A)
Value:
do        \
        if( MB_SUCCESS != ( A ) )        \
            std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
            return A;        \
    } while( false )
Definition at line 20 of file gqt_rayfire_test.cpp.
Definition at line 4 of file gqt_rayfire_test.cpp.
Function Documentation
Definition at line 43 of file gqt_rayfire_test.cpp.
References CHECK_REAL_EQUAL, FindVolTestResult::dir, moab::GeomTopoTool::entity_by_id(), eps, GQT, moab::GeomQueryTool::gttool(), origin, and moab::GeomQueryTool::ray_fire().
Referenced by main().
    int vol_idx        = 1;
    EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_idx );
    double dir[3]      = { -1.0, 0.0, 0.0 };
    double origin[3]   = { 0.0, 0.0, 0.0 };
    double next_surf_dist;
    EntityHandle next_surf;
    GQT->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist );
    double expected_next_surf_dist = 5.0;
    CHECK_REAL_EQUAL( expected_next_surf_dist, next_surf_dist, eps );
Definition at line 56 of file gqt_rayfire_test.cpp.
    int vol_idx        = 1;
    double dir[3]      = { 1.0, 0.0, 0.0 };    // ray along x direction
    double origin[3]   = { -10.0, 0.0, 0.0 };  // origin at -10 0 0
    std::cout << next_surf_dist << std::endl;
    double expected_next_surf_dist = 15.0;
Definition at line 128 of file gqt_rayfire_test.cpp.
References CHECK_EQUAL, FindVolTestResult::dir, moab::GeomTopoTool::entity_by_id(), GQT, moab::GeomQueryTool::gttool(), origin, moab::GeomQueryTool::ray_fire(), moab::GeomQueryTool::RayHistory::reset(), and moab::GeomQueryTool::RayHistory::size().
    GeomQueryTool::RayHistory history;
    int vol_idx        = 1;
    double xyz[3];
    history.reset();
    // first ray fire with history
    GQT->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist, &history, 0, 1 );
    std::cout << next_surf << " " << history.size() << std::endl;
    // second ray fire with history
    xyz[0] = origin[0] + ( next_surf_dist * dir[0] );
    xyz[1] = origin[1] + ( next_surf_dist * dir[1] );
    xyz[2] = origin[2] + ( next_surf_dist * dir[2] );
    // ray fired execacyl
    GQT->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist, &history, 0, 1 );
    // using history with this geom, there should be no next surface, i.e. 0
    EntityHandle ZERO = 0;
    CHECK_EQUAL( ZERO, next_surf );
Definition at line 100 of file gqt_rayfire_test.cpp.
References CHECK_EQUAL, FindVolTestResult::dir, moab::GeomTopoTool::entity_by_id(), GQT, moab::GeomQueryTool::gttool(), origin, moab::GeomQueryTool::ray_fire(), and moab::GeomQueryTool::RayHistory::reset().
    int vol_idx        = 1;
    double xyz[3];
    history.reset();
    // ray fired exactly along boundary shared by 2 facets on a single surface,
    // needs two ray_fires to cross, this is expected and ok
    // this fire should hit graveyard, i.e. next_surf = 0
Definition at line 85 of file gqt_rayfire_test.cpp.
    int vol_idx        = 1;
    GQT->ray_fire( vol_h, origin, dir, next_surf, next_surf_dist, &history, 0.0, -1 );
Definition at line 70 of file gqt_rayfire_test.cpp.
    int vol_idx        = 1;
void gqt_setup_test ( )
Definition at line 34 of file gqt_rayfire_test.cpp.
References CHECK_ERR, ErrorCode, GQT, GTT, moab::GeomQueryTool::initialize(), input_file, and MBI.
    MBI            = new Core();
    ErrorCode rval = MBI->load_file( input_file.c_str() );CHECK_ERR( rval );
    GTT  = new GeomTopoTool( MBI );
    GQT  = new GeomQueryTool( GTT );
    rval = GQT->initialize();CHECK_ERR( rval );
int main ( int  ,
char **
Definition at line 160 of file gqt_rayfire_test.cpp.
References GQT, gqt_origin_face_rayfire(), gqt_outside_face_rayfire(), gqt_outside_face_rayfire_history(), gqt_outside_face_rayfire_history_fail(), gqt_outside_face_rayfire_orient_entrance(), gqt_outside_face_rayfire_orient_exit(), gqt_setup_test(), GTT, MBI, and RUN_TEST.
    int result = 0;
    result += RUN_TEST( gqt_setup_test );  // setup problem
    // rays fired along cardinal directions
    result += RUN_TEST( gqt_origin_face_rayfire );  // point in centre
    result += RUN_TEST( gqt_outside_face_rayfire );
    result += RUN_TEST( gqt_outside_face_rayfire_orient_exit );      // fire ray from point outside volume
        // looking for exit intersections
    result += RUN_TEST( gqt_outside_face_rayfire_orient_entrance );  // fire ray from point outside volume
        // looking for entrance intersection
    result += RUN_TEST( gqt_outside_face_rayfire_history_fail );     // fire ray from point outside
        // geometry using ray history
    result += RUN_TEST( gqt_outside_face_rayfire_history );          // fire ray from point outside geometry
        // using ray history
    delete GQT;
    delete GTT;
    delete MBI;
    return result;
Variable Documentation
double eps = 1.0e-6
Definition at line 32 of file gqt_rayfire_test.cpp.
Definition at line 18 of file gqt_rayfire_test.cpp.
Definition at line 17 of file gqt_rayfire_test.cpp.
Definition at line 30 of file gqt_rayfire_test.cpp.
Definition at line 16 of file gqt_rayfire_test.cpp.
