gqt_simple_test.cpp File Reference
#include <iostream>
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
#include "moab/GeomTopoTool.hpp"
#include "moab/GeomQueryTool.hpp"
+ Include dependency graph for gqt_simple_test.cpp:
Defines
#define IS_BUILDING_MB
#define CHKERR(A)
Functions
void gqt_load_file ()
void gqt_load_file_dagmc_build_obb ()
void gqt_load_file_dagmc_via_moab_build_obb ()
void gqt_load_file_dagmc_internal_build_obb ()
void gqt_test_obb_retreval ()
void gqt_create_impl_compl ()
void gqt_build_obb ()
void gqt_num_vols ()
void gqt_point_in ()
void gqt_test_obb_retreval_rayfire ()
void gqt_rayfire ()
void gqt_closest_to ()
void gqt_test_boundary ()
void gqt_point_in_box_1 ()
void gqt_point_in_box_2 ()
void gqt_point_in_box_3 ()
void gqt_point_in_box_4 ()
void gqt_point_in_box_5 ()
void cleanup ()
int main (int, char **)
Variables
GeomTopoToolGTT
GeomQueryToolGQT
InterfaceMBI
const std::string input_file = "unittest/test_geom.h5m"
Define Documentation
#define CHKERR (   A)
Value:
do        \
        if( MB_SUCCESS != ( A ) )        \
            std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
            return A;        \
    } while( false )
Definition at line 19 of file gqt_simple_test.cpp.
Definition at line 4 of file gqt_simple_test.cpp.
Function Documentation
void cleanup ( )
Definition at line 338 of file gqt_simple_test.cpp.
References GQT, GTT, and MBI.
Referenced by main().
    // cleanup instances
    delete GQT;
    delete GTT;
    delete MBI;
void gqt_closest_to ( )
Definition at line 242 of file gqt_simple_test.cpp.
References CHECK_ERR, CHECK_REAL_EQUAL, moab::GeomQueryTool::closest_to_location(), moab::GeomTopoTool::entity_by_id(), eps, ErrorCode, GQT, and moab::GeomQueryTool::gttool().
    const double eps = 1e-6;  // epsilon for test, faceting tol?
    int vol_idx = 1;
    // note model is cube of side 10, centred at 0,0,0, so ray fire along
    // any unit direction should be exactly 5.0
    double xyz[3] = { -6.0, 0.0, 0.0 };
    double distance;  // distance from point to nearest surface
    double expect_distance = 1.0;
    EntityHandle vol_h;
    ErrorCode rval;
    // get the volume handle
    vol_h = GQT->gttool()->entity_by_id( 3, vol_idx );
    // test closest to location
    rval = GQT->closest_to_location( vol_h, xyz, distance );CHECK_ERR( rval );
    // distance should be 1.0 cm
    CHECK_REAL_EQUAL( expect_distance, distance, eps );
void gqt_load_file ( )
Definition at line 31 of file gqt_simple_test.cpp.
References CHECK_ERR, ErrorCode, GQT, GTT, input_file, and MBI.
    MBI            = new moab::Core();
    ErrorCode rval = MBI->load_file( input_file.c_str() );  // open the
    CHECK_ERR( rval );
    GTT = new GeomTopoTool( MBI, true );
    GQT = new GeomQueryTool( GTT );
Definition at line 40 of file gqt_simple_test.cpp.
References CHECK_ERR, ErrorCode, GQT, GTT, moab::GeomQueryTool::initialize(), input_file, and MBI.
    /* 1 - Test with external moab, load file in GTT/GQT*/
    // make new moab core
    ErrorCode rval;
    // load a file
    CHECK_ERR( rval );
    GTT  = new GeomTopoTool( MBI );
    rval = GQT->initialize();CHECK_ERR( rval );
Definition at line 72 of file gqt_simple_test.cpp.
References CHECK_ERR, moab::GeomTopoTool::construct_obb_trees(), ErrorCode, GQT, GTT, moab::GeomQueryTool::gttool(), input_file, MBI, and moab::GeomTopoTool::setup_implicit_complement().
    /* 3 - Test with internal moab, load file in MOAB*/
    // find geomsets, build implicit complement, and construct obb trees
    ErrorCode rval;
    CHECK_ERR( rval );
    GTT  = new GeomTopoTool( MBI, true, 0 );
    rval = GQT->gttool()->setup_implicit_complement();CHECK_ERR( rval );
    rval = GQT->gttool()->construct_obb_trees();CHECK_ERR( rval );
Definition at line 55 of file gqt_simple_test.cpp.
    /* 2 - Test with external moab, load file in MOAB*/
    // build implicit complement and obb trees
    ErrorCode rval;
    // load file
    rval = MBI->load_file( input_file.c_str() );  // open the file
    CHECK_ERR( rval );
    // create obb trees
void gqt_num_vols ( )
Definition at line 131 of file gqt_simple_test.cpp.
References CHECK_EQUAL, GQT, moab::GeomQueryTool::gttool(), and moab::GeomTopoTool::num_ents_of_dim().
    int expect_num_vols = 2;
    int num_vols        = GQT->gttool()->num_ents_of_dim( 3 );
    CHECK_EQUAL( expect_num_vols, num_vols );
void gqt_point_in ( )
Definition at line 138 of file gqt_simple_test.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::GeomTopoTool::entity_by_id(), ErrorCode, GQT, GTT, moab::GeomQueryTool::gttool(), moab::GeomQueryTool::initialize(), input_file, MBI, and moab::GeomQueryTool::point_in_volume().
    int result        = 0;
    int expect_result = 1;
    int vol_idx       = 1;
    double xyz[3]     = { 0.0, 0.0, 0.0 };
    EntityHandle vol_h;
    // load file and create instances
    CHECK_ERR( rval );
    // initialize for geom queries
    GQT->initialize();
    // get volume
    // test point in volume
    GQT->point_in_volume( vol_h, xyz, result );CHECK_ERR( rval );
    CHECK_EQUAL( expect_result, result );
Definition at line 283 of file gqt_simple_test.cpp.
References CHECK_EQUAL, moab::GeomTopoTool::entity_by_id(), ErrorCode, GQT, moab::GeomQueryTool::gttool(), MB_SUCCESS, origin, and moab::GeomQueryTool::point_in_box().
    int vol_id         = 1;
    double origin[3]   = { 0.0, 0.0, 0.0 };
    EntityHandle vol_h = GQT->gttool()->entity_by_id( 3, vol_id );
    int result;
    ErrorCode rval = GQT->point_in_box( vol_h, origin, result );
    CHECK_EQUAL( rval, moab::MB_SUCCESS );
    CHECK_EQUAL( result, 1 );  // inside
Definition at line 294 of file gqt_simple_test.cpp.
    int vol_id         = 1;
    double origin[3]   = { 5.0, 0.0, 0.0 };
    int result;
Definition at line 305 of file gqt_simple_test.cpp.
    int vol_id         = 1;
    double origin[3]   = { 5.1, 0.0, 0.0 };
    int result;
    CHECK_EQUAL( result, 0 );  // outside
Definition at line 316 of file gqt_simple_test.cpp.
    int vol_id         = 1;
    double origin[3]   = { 5.1, 5.1, 5.1 };
    int result;
Definition at line 327 of file gqt_simple_test.cpp.
    int vol_id         = 1;
    double origin[3]   = { 5.0 - 1.e-308, 5.0 - 1.e-308, 5.0 - 1.e-308 };
    int result;
    CHECK_EQUAL( result, 1 );  // outside
void gqt_rayfire ( )
Definition at line 215 of file gqt_simple_test.cpp.
References CHECK_ERR, CHECK_REAL_EQUAL, FindVolTestResult::dir, moab::GeomTopoTool::entity_by_id(), eps, ErrorCode, GQT, GTT, moab::GeomQueryTool::gttool(), moab::GeomQueryTool::initialize(), input_file, MBI, and moab::GeomQueryTool::ray_fire().
    int vol_idx = 1;
    double dir[3] = { 0.0, 0.0, 1.0 };
    EntityHandle next_surf;
    double next_surf_dist;
    double expect_next_surf_dist = 5.0;
    EntityHandle vol_h;
    ErrorCode rval;
    CHECK_ERR( rval );
    rval  = GQT->ray_fire( vol_h, xyz, dir, next_surf, next_surf_dist );CHECK_ERR( rval );
    CHECK_REAL_EQUAL( expect_next_surf_dist, next_surf_dist, eps );
Definition at line 265 of file gqt_simple_test.cpp.
References CHECK_EQUAL, CHECK_ERR, FindVolTestResult::dir, moab::GeomTopoTool::entity_by_id(), ErrorCode, GQT, moab::GeomQueryTool::gttool(), and moab::GeomQueryTool::test_volume_boundary().
    int vol_idx         = 1;
    EntityHandle vol_h  = GQT->gttool()->entity_by_id( 3, vol_idx );
    int surf_idx        = 1;
    EntityHandle surf_h = GQT->gttool()->entity_by_id( 2, surf_idx );
    double xyz[3] = { 0.0, 0.0, 5.0 };
    int result;
    int expect_result = 0;
    // test vol boundary
    ErrorCode rval = GQT->test_volume_boundary( vol_h, surf_h, xyz, dir, result );CHECK_ERR( rval );
    // check ray leaving volume
Definition at line 87 of file gqt_simple_test.cpp.
    // make new dagmc
    std::cout << "test_obb_retreval" << std::endl;
    ErrorCode rval;
    // load a file
    CHECK_ERR( rval );
    // write to file
    rval = MBI->write_file( "fcad" );CHECK_ERR( rval );
    delete GQT;
    delete GTT;
    delete MBI;
    // re-load written file
    rval = MBI->load_file( "fcad" );  // open the
    CHECK_ERR( rval );
    // remove file
    remove( "fcad" );
Definition at line 162 of file gqt_simple_test.cpp.
    // make new dagmc
    std::cout << "test_obb_retreval and ray_fire" << std::endl;
    ErrorCode rval;
    // load file and initialize
    CHECK_ERR( rval );
    // write to file
    // delete instances
    delete GTT;
    delete GQT;
    delete MBI;
    // load the file that was written and initialize
    CHECK_ERR( rval );
    // remove generated test file
    remove( "fcad" );
    // now perform full ray fire
    double eps  = 1.e-6;
    int vol_idx = 1;
    EntityHandle vol_h;
    // get volume handle to fire on
    // test ray fire
int main ( int  ,
char **
Definition at line 346 of file gqt_simple_test.cpp.
References cleanup(), gqt_build_obb(), gqt_closest_to(), gqt_create_impl_compl(), gqt_load_file(), gqt_load_file_dagmc_build_obb(), gqt_load_file_dagmc_internal_build_obb(), gqt_load_file_dagmc_via_moab_build_obb(), gqt_num_vols(), gqt_point_in(), gqt_rayfire(), gqt_test_boundary(), gqt_test_obb_retreval(), gqt_test_obb_retreval_rayfire(), and RUN_TEST.
    int result = 0;
    result += RUN_TEST( gqt_load_file );          // test ray fire
    result += RUN_TEST( gqt_build_obb );          // build the obb
    result += RUN_TEST( gqt_create_impl_compl );  // build the obb
    result += RUN_TEST( gqt_num_vols );           // make sure the num of vols correct
    cleanup();
    result += RUN_TEST( gqt_load_file_dagmc_build_obb );  //
    cleanup();
    result += RUN_TEST( gqt_load_file_dagmc_via_moab_build_obb );  //
    cleanup();
    result += RUN_TEST( gqt_load_file_dagmc_internal_build_obb );  //
    cleanup();
    result += RUN_TEST( gqt_test_obb_retreval );  // check that we are retreving loaded obbs
    cleanup();
    result += RUN_TEST( gqt_test_obb_retreval_rayfire );  // check that we can ray fire on loaded obbs
    cleanup();
    result += RUN_TEST( gqt_point_in );  // check entity by point
    cleanup();
    result += RUN_TEST( gqt_rayfire );        // ensure ray fire distance is correct
    result += RUN_TEST( gqt_closest_to );     // check the distance to surface nearest point
    result += RUN_TEST( gqt_test_boundary );  // check particle entering leaving
    cleanup();
    return result;
Variable Documentation
Definition at line 16 of file gqt_simple_test.cpp.
Definition at line 15 of file gqt_simple_test.cpp.
Definition at line 29 of file gqt_simple_test.cpp.
Definition at line 17 of file gqt_simple_test.cpp.
