Set flag bits
+ Collaboration diagram for Set flag bits:
Defines
#define mhdf_SET_OWNER_BIT   0x1
 Make entities in set aware of owning set (MOAB-specific?)
#define mhdf_SET_UNIQUE_BIT   0x2
 Set cannot contain duplicates.
#define mhdf_SET_ORDER_BIT   0x4
 Set order is preserved.
#define mhdf_SET_RANGE_BIT   0x8
 The bit specifying set storage format.
Define Documentation
Definition at line 1188 of file mhdf.h.
Referenced by check_valid_set_contents().
Definition at line 1184 of file mhdf.h.
If this bit is set, then the contents of a set (not the children) is written as set of ranges, where each range is of the form {global start id, count}. For such a range, the set contains the count entities with sequential global IDs beginning with the specified start ID. If this bit is not set in the set flags, the contents of the set are stored as a simple list of global IDs.
Definition at line 1199 of file mhdf.h.
Referenced by check_valid_set_contents(), moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::ReadHDF5::find_sets_containing(), moab::WriteHDF5Parallel::pack_set(), moab::ReadHDF5::read_set_data(), moab::ReadHDF5::read_sets(), moab::WriteHDF5Parallel::unpack_set(), and moab::WriteHDF5::write_sets().
Definition at line 1186 of file mhdf.h.
