Common element type names.
Defines
#define mhdf_EDGE_TYPE_NAME   "Edge"
 Name to use for edge element.
#define mhdf_TRI_TYPE_NAME   "Tri"
 Name to use for triangle element.
#define mhdf_QUAD_TYPE_NAME   "Quad"
 Name to use for quadrilateral element.
#define mhdf_POLYGON_TYPE_NAME   "Polygon"
 Name to use for general polygon element.
#define mhdf_TET_TYPE_NAME   "Tet"
 Name to use for tetrahedral element.
#define mhdf_PYRAMID_TYPE_NAME   "Pyramid"
 Name to use for quad-based pyramid element.
#define mhdf_PRISM_TYPE_NAME   "Prism"
 Name to use for triangular prism element.
#define mdhf_KNIFE_TYPE_NAME   "Knife"
 Name to use for knife element.
#define mdhf_HEX_TYPE_NAME   "Hex"
 Name to use for quad-sided hexahedral element.
#define mhdf_POLYHEDRON_TYPE_NAME   "Polyhedron"
 Name to use for general polyhedron specified as a arbitrary-length list of faces.
#define mhdf_SEPTAHEDRON_TYPE_NAME   "Septahedron"
 Name to use for hexagonal-based pyramid.
Define Documentation
Definition at line 50 of file mhdf_public.h.
Referenced by get_dim_ranges(), iMOAB_ReadHeaderInfo(), and main().
Definition at line 48 of file mhdf_public.h.
Referenced by get_dim_ranges(), and iMOAB_ReadHeaderInfo().
Definition at line 34 of file mhdf_public.h.
Definition at line 40 of file mhdf_public.h.
Definition at line 52 of file mhdf_public.h.
Referenced by check_valid_connectivity(), check_valid_poly_conn(), get_dim_ranges(), and iMOAB_ReadHeaderInfo().
Definition at line 46 of file mhdf_public.h.
Definition at line 44 of file mhdf_public.h.
Definition at line 38 of file mhdf_public.h.
Definition at line 54 of file mhdf_public.h.
Definition at line 42 of file mhdf_public.h.
Definition at line 36 of file mhdf_public.h.
