gs.cpp File Reference
#include <cstdio>
#include <cstdlib>
#include <cstdarg>
#include <cstring>
#include <cmath>
#include "moab/gs.hpp"
+ Include dependency graph for gs.cpp:
Namespaces
namespace  moab
Class representing axis-aligned bounding box.
Defines
#define DO_SET(a, b)   b = a
#define DO_ADD(a, b)   a += b
#define DO_MUL(a, b)   a *= b
#define DO_MIN(a, b)   if( ( b ) < ( a ) ) ( a ) = b
#define DO_MAX(a, b)   if( ( b ) > ( a ) ) ( a ) = b
#define DO_BPR(a, b)
#define LOOP(op)
#define LOOP(op)
Functions
static void moab::local_condense (realType *u, int op, const sint *cm)
static void moab::local_uncondense (realType *u, const sint *cm)
static void moab::local_condense_vec (realType *u, uint n, int op, const sint *cm)
static void moab::local_uncondense_vec (realType *u, uint n, const sint *cm)
Define Documentation
#define DO_ADD (   a,
)    a += b
Definition at line 96 of file gs.cpp.
Referenced by moab::local_condense(), and moab::local_condense_vec().
#define DO_BPR (   a,
Value:
do                         \
        uint a_ = a;           \
        uint b_ = b;           \
        for( ;; )              \
            if( a_ < b_ )      \
                b_ >>= 1;      \
            else if( b_ < a_ ) \
                a_ >>= 1;      \
            else               \
                break;         \
        ( a ) = a_;            \
    } while( 0 )
Definition at line 102 of file gs.cpp.
#define DO_MAX (   a,
Definition at line 100 of file gs.cpp.
#define DO_MIN (   a,
Definition at line 98 of file gs.cpp.
#define DO_MUL (   a,
)    a *= b
Definition at line 97 of file gs.cpp.
#define DO_SET (   a,
)    b = a
Definition at line 95 of file gs.cpp.
Referenced by moab::local_uncondense(), and moab::local_uncondense_vec().
#define LOOP (   op)
Value:
do                                   \
        sint i, j;                       \
        while( ( i = *cm++ ) != -1 )     \
            while( ( j = *cm++ ) != -1 ) \
                op( u[i], u[j] );        \
    } while( 0 )
Definition at line 157 of file gs.cpp.
Referenced by moab::local_condense(), moab::local_condense_vec(), moab::local_uncondense(), and moab::local_uncondense_vec().
#define LOOP (   op)
Value:
do                                    \
        sint i, j, k;                     \
            realType* pi = u + n * i;     \
                realType* pj = u + n * j; \
                for( k = n; k; --k )      \
                    op( *pi, *pj );       \
                    ++pi;                 \
                    ++pj;                 \
    } while( 0 )
