h5file_test.cpp File Reference
#include <cstdio>
#include <cmath>
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "MBTagConventions.hpp"
#include "moab/CN.hpp"
#include <iostream>
#include <sstream>
+ Include dependency graph for h5file_test.cpp:
Defines
#define filename   "h5test.h5m"
#define tagname   "foo/\\/\\"
#define bitname   "bar\n"
#define intname   "int tag"
#define dblname   " dbl "
#define handlename   "hanlde"
Functions
void create ()
bool compare ()
void moab_error (const char *function)
int main (int argc, char *argv[])
EntityHandle vtx (double x, double y, double z)
EntityHandle pent (EntityHandle *vtx_list, int i1, int i2, int i3, int i4, int i5)
EntityHandle make_set (unsigned int options, EntityHandle *entities, size_t num_entities, bool reverse, int id)
bool compare_conn (std::vector< EntityHandle > &conn1, std::vector< EntityHandle > &conn2)
bool compare_sets (int id, const char *tag_name=0)
bool compare_tags (EntityHandle dod[])
Variables
const int FACE_SET_ID = 1101
const int VERTEX_SET_ID = 1102
const int REGION_SET_ID = 1103
const int EMPTY_SET_ID = 1100
const int SET_SET_ID = 1105
Interfaceiface
Define Documentation
Definition at line 34 of file h5file_test.cpp.
Referenced by compare(), and create().
Definition at line 36 of file h5file_test.cpp.
Referenced by compare_tags(), and create().
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Examples:
DeformMeshRemap.cpp, LoadPartial.cpp, QuadTriConv.cpp, and ReduceExchangeTags.cpp.
Definition at line 24 of file h5file_test.cpp.
Referenced by base_name(), ExodusTest::check_mesh(), do_file(), do_ray_fire_test(), exp_1_init(), get_cut_cube_example(), get_hex_3d_part_example(), get_homogenious_example(), get_part_example_quad(), get_part_example_tri(), get_sphere_cube_example(), get_sphere_cylinder_example(), iMesh_load(), iMesh_save(), moab::ReadCGNS::load_file(), moab::ReadTemplate::load_file(), moab::ReadTetGen::load_file(), main(), mesh_size_test(), moab::ReadTetGen::open_file(), parse_options(), read_write(), read_write_file(), reference(), save_entset_test(), TargetReadWriteTest::setUp(), DomainClassifierTest::setUp(), signal_handler(), split_test_across(), test_correct_ghost(), BoundedCylinderDomainTest::test_create_curve_from_mesh(), test_eul_check_across_files(), test_eul_check_append(), test_eul_check_T(), test_eul_check_timestep(), test_fv_check_T(), test_gcrm_check_vars(), test_homme_check_T(), test_mpas_check_vars(), test_native_read(), ExodusTest::test_read(), test_read_and_ghost_after(), test_read_with_ghost(), test_read_with_ghost_no_augment(), test_read_with_thin_ghost_layer(), test_sets_fileids(), test_tags_retrieval(), test_var_length_parallel(), ExodusTest::test_write(), test_write_invalid_elem(), test_write_read_many_tags(), verdict_test1(), MBMesquite::MeshWriter::write_eps_triangle(), MBMesquite::TerminationCriterion::write_iterations(), and MBMesquite::TerminationCriterion::write_mesh_steps().
Definition at line 37 of file h5file_test.cpp.
Definition at line 35 of file h5file_test.cpp.
Function Documentation
bool compare ( )
Definition at line 714 of file h5file_test.cpp.
References moab::Range::begin(), bitname, moab::Range::clear(), compare_conn(), compare_sets(), compare_tags(), conn, EMPTY_SET_ID, FACE_SET_ID, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type_and_tag(), GLOBAL_ID_TAG_NAME, iface, MB_SUCCESS, MB_TYPE_BIT, MBHEX, MBPOLYHEDRON, moab_error(), REGION_SET_ID, SET_SET_ID, size, moab::Range::size(), moab::Interface::tag_get_handle(), tagname, and VERTEX_SET_ID.
Referenced by moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::choose_best_split(), moab::find_map_values(), moab::find_tag_values(), main(), and moab::ReadRTT::split_string().
    Range range;
    EntityHandle hex[2];
    EntityHandle dod[2];
    Tag elemtag;
    Range::iterator iter;
    // get tag
    if( MB_SUCCESS != iface->tag_get_handle( bitname, 2, MB_TYPE_BIT, elemtag ) ) moab_error( "tag_get_handle" );
    // get two hexes
    char two             = '\002';
    const void* tarray[] = { &two };
    if( MB_SUCCESS != iface->get_entities_by_type_and_tag( 0, MBHEX, &elemtag, tarray, 1, range ) )
        moab_error( "get_entities_by_type_and_tag" );
    if( range.size() != 2 )
        fprintf( stderr, "Expected 2 Hexes.  Got %lu\n", (unsigned long)range.size() );
        exit( 1 );
    iter   = range.begin();
    hex[0] = *iter;
    hex[1] = *++iter;
    // get two polyhedra
    range.clear();
    char one             = '\001';
    const void* oarray[] = { &one };
    if( MB_SUCCESS != iface->get_entities_by_type_and_tag( 0, MBPOLYHEDRON, &elemtag, oarray, 1, range ) )
        fprintf( stderr, "Expected 2 Polyhedra.  Got %lu\n", (unsigned long)range.size() );
        exit( 1 );
    dod[0] = *iter;
    dod[1] = *++iter;
    // compare hexes
    std::vector< EntityHandle > conn[2];
    if( MB_SUCCESS != iface->get_connectivity( hex, 1, conn[0] ) ||
        MB_SUCCESS != iface->get_connectivity( hex + 1, 1, conn[1] ) )
        moab_error( "get_connectivity" );
    if( !compare_conn( conn[0], conn[1] ) ) return false;
    // compare polyhedra
    std::vector< EntityHandle > face[2];
    conn[0].clear();
    conn[1].clear();
    if( MB_SUCCESS != iface->get_connectivity( dod, 1, conn[0], false ) ||
        MB_SUCCESS != iface->get_connectivity( dod + 1, 1, conn[1], false ) )
    if( conn[0].size() != 12 || conn[1].size() != 12 )
        fprintf( stderr,
                 "Expected two dodecahedrons.  Got polyhedrons with "
                 "%lu and %lu faces respectively.\n",
                 (unsigned long)conn[0].size(), (unsigned long)conn[1].size() );
        return false;
    for( int i = 0; i < 12; ++i )
        face[0].clear();
        face[1].clear();
        if( MB_SUCCESS != iface->get_connectivity( &conn[0][i], 1, face[0], false ) ||
            MB_SUCCESS != iface->get_connectivity( &conn[1][i], 1, face[1], false ) )
        if( !compare_conn( face[0], face[1] ) ) return false;
    // compare sets
    if( !compare_sets( VERTEX_SET_ID, tagname ) || !compare_sets( FACE_SET_ID ) || !compare_sets( REGION_SET_ID ) ||
        !compare_sets( EMPTY_SET_ID ) || !compare_sets( SET_SET_ID, GLOBAL_ID_TAG_NAME ) )
        return false;
    // check tags
    if( !compare_tags( dod ) ) return false;
    return true;
bool compare_conn ( std::vector< EntityHandle > &  conn1,
std::vector< EntityHandle > &  conn2
Definition at line 367 of file h5file_test.cpp.
References moab::Interface::get_coords(), iface, MB_SUCCESS, MB_TYPE_INTEGER, moab_error(), size, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and tagname.
Referenced by compare().
    unsigned i;
    if( conn1.size() != conn2.size() || conn1.size() == 0 )
        fprintf( stderr, "Error comparing connectivity: sizes %lu and %lu\n", (unsigned long)conn1.size(),
                 (unsigned long)conn2.size() );
        return false;
    std::vector< double > coords[2];
    coords[0].resize( 3 * conn1.size() );
    coords[1].resize( 3 * conn2.size() );
    if( MB_SUCCESS != iface->get_coords( &conn1[0], conn1.size(), &coords[0][0] ) ||
        MB_SUCCESS != iface->get_coords( &conn2[0], conn2.size(), &coords[1][0] ) ||
        coords[0].size() != coords[1].size() )
        moab_error( "get_coords" );
    std::vector< double >::iterator citer1 = coords[0].begin(), citer2 = coords[1].begin();
    for( i = 0; i < conn1.size(); i++ )
        double x1 = *( citer1++ ), y1 = *( citer1++ ), z1 = *( citer1++ );
        double x2 = *( citer2++ ), y2 = *( citer2++ ), z2 = *( citer2++ );
        if( x1 != x2 || y1 != y2 || z1 != z2 )
            fprintf( stderr, "Vertex coords don't match: ( %f, %f, %f ) and ( %f, %f, %f )\n", x1, y1, z1, x2, y2, z2 );
            return false;
    std::vector< int > tags[2];
    tags[0].resize( conn1.size() );
    tags[1].resize( conn2.size() );
    Tag tag;
    if( MB_SUCCESS != iface->tag_get_handle( tagname, 1, MB_TYPE_INTEGER, tag ) ) moab_error( "tag_get_handle" );
    if( MB_SUCCESS != iface->tag_get_data( tag, &conn1[0], conn1.size(), &tags[0][0] ) ||
        MB_SUCCESS != iface->tag_get_data( tag, &conn2[0], conn2.size(), &tags[1][0] ) )
        moab_error( "tag_get_data" );
    std::vector< int >::iterator titer1 = tags[0].begin(), titer2 = tags[1].begin();
        int t1 = *( titer1++ );
        int t2 = *( titer2++ );
        if( t1 != t2 )
            fprintf( stderr, "Vertex tags don't match: %d != %d\n", t1, t2 );
            return false;
    return true;
bool compare_sets ( int  id,
const char *  tag_name = 0
Definition at line 427 of file h5file_test.cpp.
References moab::Range::begin(), moab::CN::EntityTypeName(), ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_meshset_options(), moab::Interface::get_parent_meshsets(), moab::Interface::globalId_tag(), id_tag, iface, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_ANY, MB_TAG_NOT_FOUND, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MBENTITYSET, MBMAXTYPE, MESHSET_SET, MESHSET_TRACK_OWNER, moab_error(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), and moab::Interface::type_from_handle().
    bool ok;
    ErrorCode rval;
    // get sets
    Tag id_tag = iface->globalId_tag();
    Range range;
    const void* tag_data[] = { &id };
    rval                   = iface->get_entities_by_type_and_tag( 0, MBENTITYSET, &id_tag, tag_data, 1, range );
    if( MB_ENTITY_NOT_FOUND == rval || range.size() != 2 )
        fprintf( stderr, "Could not find set with id %d pair in file\n", id );
        return false;
    else if( MB_SUCCESS != rval )
    EntityHandle set1 = *range.begin();
    EntityHandle set2 = *++range.begin();
    // Compare set descriptions
    unsigned opt1 = 0, opt2 = 0;
    rval = iface->get_meshset_options( set1, opt1 );
    if( MB_SUCCESS != rval ) moab_error( "get_meshset_options for set1 failed" );
    rval = iface->get_meshset_options( set2, opt2 );
    if( MB_SUCCESS != rval ) moab_error( "get_meshset_options for set2 failed" );
    if( opt1 != opt2 )
        fprintf( stderr,
                 "Sets with id %d do not have matching options.\n"
                 "Set 1: track_owner=%s set=%s ordered=%s\n"
                 "Set 2: track_owner=%s set=%s ordered=%s\n",
                 id, opt1 & MESHSET_TRACK_OWNER ? "yes" : "no", opt1 & MESHSET_SET ? "yes" : "no",
                 opt1 & MESHSET_ORDERED ? "yes" : "no", opt2 & MESHSET_TRACK_OWNER ? "yes" : "no",
                 opt2 & MESHSET_SET ? "yes" : "no", opt2 & MESHSET_ORDERED ? "yes" : "no" );
        return false;
    // Compare set contents
    // First check if same number of entities.
    // Then select from three possible methods to compare set contents
    //  o If caller gave us a tag to use, compare entities by tag value
    //  o If set is ordered, compare entity types in order
    //  o Otherwise compare counts of entity types in sets
    std::vector< EntityHandle > list1, list2;
    rval = iface->get_entities_by_handle( set1, list1 );
    if( MB_SUCCESS != rval ) moab_error( "get_entities_by_handle for set1 failed" );
    rval = iface->get_entities_by_handle( set2, list2 );
    if( MB_SUCCESS != rval ) moab_error( "get_entities_by_handle for set2 failed" );
    if( list1.size() != list2.size() )
        fprintf( stderr,
                 "Sets with id %d do not have the same number of entities.\n"
                 "Set 1 : %u  Set 2 : %u\n",
                 id, (unsigned)list1.size(), (unsigned)list2.size() );
        return false;
    if( tag_name )  // compare contents using tag value
        Tag tag;
        if( MB_SUCCESS != iface->tag_get_handle( tag_name, 0, MB_TYPE_OPAQUE, tag, MB_TAG_ANY ) )
            fprintf( stderr, "Could not find tag \"%s\" in file.\n", tag_name );
            return false;
        // Make sure tag is integer type
        DataType type;
        if( MB_SUCCESS != iface->tag_get_data_type( tag, type ) ) moab_error( "tag_get_data_type" );
        if( MB_TYPE_INTEGER != type && MB_TYPE_OPAQUE != type ) moab_error( "compare_sets" );
        std::vector< int > data1( list1.size() ), data2( list2.size() );
        if( MB_SUCCESS != iface->tag_get_data( tag, &list1[0], list1.size(), &data1[0] ) ||
            MB_SUCCESS != iface->tag_get_data( tag, &list2[0], list2.size(), &data2[0] ) )
        if( !( opt1 & MESHSET_ORDERED ) )
            std::sort( data1.begin(), data1.end() );
            std::sort( data2.begin(), data2.end() );
        for( unsigned i = 0; i < data1.size(); ++i )
            if( data1[i] != data2[i] )
                fprintf( stderr, "Entities in sets with id %d do not have matching tag values.\n", id );
                return false;
    else if( opt1 & MESHSET_ORDERED )  // compare types of each entity in set
        ok = true;
        for( unsigned i = 0; i < list1.size(); ++i )
            if( iface->type_from_handle( list1[i] ) != iface->type_from_handle( list2[i] ) )
                fprintf( stderr,
                         "Entities at position %u in ordered sets with id %d\n"
                         "have different types.\n",
                         i, id );
                ok = false;
        if( !ok ) return false;
    else  // compare count of entity types in each set
        unsigned counts1[MBMAXTYPE], counts2[MBMAXTYPE];
        memset( counts1, 0, MBMAXTYPE * sizeof( unsigned ) );
        memset( counts2, 0, MBMAXTYPE * sizeof( unsigned ) );
            counts1[iface->type_from_handle( list1[i] )]++;
            counts2[iface->type_from_handle( list2[i] )]++;
        ok = true;
        for( int j = 0; j < MBMAXTYPE; ++j )
            if( counts1[j] != counts2[j] )
                fprintf( stderr, "Sets with id %d have differing numbers of %s: %u and %u\n", id,
                         CN::EntityTypeName( (EntityType)j ), counts1[j], counts2[j] );
                ok = false;
    // Compare set parent/child links using global id
    ok                  = true;
    const char* words[] = { "children", "parents" };
    std::vector< EntityHandle > adj1, adj2;
    for( unsigned two = 0; two < 2; ++two )
        adj1.clear();
        adj2.clear();
        if( two )
            if( MB_SUCCESS != iface->get_parent_meshsets( set1, adj1 ) ||
                MB_SUCCESS != iface->get_parent_meshsets( set2, adj2 ) )
                moab_error( "get_parent_meshsets" );
        else
            if( MB_SUCCESS != iface->get_child_meshsets( set1, adj1 ) ||
                MB_SUCCESS != iface->get_child_meshsets( set2, adj2 ) )
                moab_error( "get_child_meshsets" );
        if( adj1.size() != adj2.size() )
            fprintf( stderr, "Sets with id %d have different number of %s: %u and %u\n", id, words[two],
                     (unsigned)adj1.size(), (unsigned)adj2.size() );
            ok = false;
            continue;
        std::vector< int > ids1( adj1.size() ), ids2( adj2.size() );
        unsigned i;
        for( i = 0; i < adj1.size(); ++i )
            rval = iface->tag_get_data( id_tag, &adj1[i], 1, &ids1[i] );
            if( MB_TAG_NOT_FOUND == rval )
                ids1[i] = 0;
            rval = iface->tag_get_data( id_tag, &adj2[i], 1, &ids2[i] );
                ids2[i] = 0;
        std::sort( ids1.begin(), ids1.end() );
        std::sort( ids2.begin(), ids2.end() );
        for( i = 0; i < ids1.size(); ++i )
            if( ids1[i] != ids2[i] )
                fprintf( stderr, "Sets with id %d have non-matching %s\n", id, words[two] );
                ok = false;
                break;
    return ok;
bool compare_tags ( EntityHandle  dod[])
Definition at line 620 of file h5file_test.cpp.
References conn, dblname, moab::Interface::get_connectivity(), handlename, iface, intname, MB_ENTITY_NOT_FOUND, MB_SUCCESS, MB_TAG_DENSE, MB_TAG_SPARSE, MB_TAG_STORE, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MBHEX, MBPOLYHEDRON, moab_error(), moab::Interface::tag_get_data(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), and moab::Interface::type_from_handle().
Referenced by compare(), test_global_opaque_common(), test_global_value_common(), test_huge_var_length(), test_var_length_big_data(), test_var_length_data_common(), test_var_length_handle_tag(), and test_var_length_no_data().
    Tag tag;
    // Get integer tag handle and characterstics
    if( MB_SUCCESS != iface->tag_get_handle( intname, 2, MB_TYPE_INTEGER, tag, MB_TAG_SPARSE | MB_TAG_STORE ) )
        moab_error( "tag_get_handle(intname)" );
    // integer tag should not have a default value
    int idata[4];
    if( MB_ENTITY_NOT_FOUND != iface->tag_get_default_value( tag, idata ) )
        fprintf( stderr, "tag_get_default_value() for nonexistant default integer tag value did "
                         "not fail correctly.\n" );
        return false;
    // check data for integer tag on both dodecahedrons
    if( MB_SUCCESS != iface->tag_get_data( tag, dod, 2, idata ) ) moab_error( "tag_get_data(itag)" );
    if( idata[0] != (int)0xDEADBEEF || idata[1] != (int)0xDEFACED || idata[2] != idata[0] || idata[3] != idata[1] )
        fprintf( stderr, "Incorrect values for integer tag data.\n" );
        return false;
    // Get double tag handle and characterstics
    if( MB_SUCCESS != iface->tag_get_handle( dblname, 1, MB_TYPE_DOUBLE, tag, MB_TAG_DENSE | MB_TAG_STORE ) )
        moab_error( "tag_get_handle(dblname)" );
    // check default value of double tag
    double ddata[2];
    if( MB_SUCCESS != iface->tag_get_default_value( tag, ddata ) ) moab_error( "tag_get_default_value" );
    if( ddata[0] != 3.14159 )
        fprintf( stderr, "incorrect default value for double tag.\n" );
        return false;
    // check data for double tag on both dodecahedrons
    if( MB_SUCCESS != iface->tag_get_data( tag, dod, 2, ddata ) ) moab_error( "tag_get_data()" );
    if( ddata[0] != .333 || ddata[0] != ddata[1] )
        fprintf( stderr, "Incorrect values for double tag data.\n" );
        return false;
    // Get handle tag handle and characterstics
    if( MB_SUCCESS != iface->tag_get_handle( handlename, 3, MB_TYPE_HANDLE, tag, MB_TAG_SPARSE | MB_TAG_STORE ) )
        moab_error( "tag_get_handle(handlename)" );
    // check default value of handle tag
    // default value will not change after tag is created.  As we
    // do multiple iterations of save/restore, we shouldn't expect
    // the dodecahedron handles to point to the most recent two.
    EntityHandle hdata[6];
    if( MB_SUCCESS != iface->tag_get_default_value( tag, hdata ) ) moab_error( "tag_get_default_value" );
    if( iface->type_from_handle( hdata[0] ) != MBHEX || hdata[2] != 0 ||
        iface->type_from_handle( hdata[1] ) != MBPOLYHEDRON )
        fprintf( stderr, "incorrect default value for handle tag '%s'\n", handlename );
        return false;
    // check global value for handle tag
    // global value should be changed each time a new global is read,
    // so expect one of the two dodecahedrons in the last slot.
    const EntityHandle root = 0;
    if( MB_SUCCESS != iface->tag_get_data( tag, &root, 1, hdata ) ) moab_error( "tag_get_data(mesh)" );
    if( iface->type_from_handle( hdata[1] ) != MBHEX || hdata[0] != 0 || ( hdata[2] != dod[0] && hdata[2] != dod[1] ) )
        fprintf( stderr, "incorrect global/mesh value for handle tag.\n" );
        return false;
    // check data on each dodecahedron
    const EntityHandle* conn;
    int len;
    if( MB_SUCCESS != iface->tag_get_data( tag, dod, 2, hdata ) ) moab_error( "tag_get_data()" );
    if( MB_SUCCESS != iface->get_connectivity( dod[0], conn, len ) ) moab_error( "get_connectivity" );
    if( memcmp( conn, hdata, 3 * sizeof( EntityHandle ) ) )
        fprintf( stderr, "Incorrect values for handle tag data.\n" );
        return false;
    if( MB_SUCCESS != iface->get_connectivity( dod[1], conn, len ) ) moab_error( "get_connectivity" );
    if( memcmp( conn, hdata + 3, 3 * sizeof( EntityHandle ) ) )
        return false;
    return true;
void create ( )
Definition at line 217 of file h5file_test.cpp.
References moab::Interface::add_child_meshset(), moab::Interface::add_parent_child(), moab::Interface::add_parent_meshset(), b, bitname, moab::Interface::create_element(), dblname, EMPTY_SET_ID, FACE_SET_ID, MBMesquite::faces, handlename, iface, intname, make_set(), MB_SUCCESS, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MBHEX, MBPOLYHEDRON, MESHSET_SET, MESHSET_TRACK_OWNER, moab_error(), pent(), REGION_SET_ID, SET_SET_ID, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), tagname, VERTEX_SET_ID, vtx(), and z.
Referenced by main(), and moab::WriteNC::write_file().
    // Create dodecahedron
    // radius
    const double r = 50.;
    // center
    const double x = 0., y = 0., z = 0.;
    // length of edge of inscribed cube
    const double cube = r * ( 2.0 / sqrt( 3.0 ) );
    // length of dodecahedron edge
    const double edge = cube * ( 2.0 / ( 1.0 + sqrt( 5.0 ) ) );
    // distance of projection of a dodecahedron vertex to
    // closest edge of inscribed cube
    const double p = ( cube - edge ) / 2.0;
    // closest face of inscribed cube
    const double d = sqrt( edge * edge - cube * cube / 4 - p );
    // coordinate values
    const double c = cube / 2.0;
    const double a = c + d;
    const double b = edge / 2.0;
    // list of vertex handles
    EntityHandle vertices[20];
    // list of pentagon handles
    EntityHandle faces[12];
    // Dodecahedron handle
    EntityHandle dodec;
    // Inscribed Hex handle
    EntityHandle hex;
    // Create vertices if inscribed cube
    vertices[0] = vtx( x - c, y + c, z + c );
    vertices[1] = vtx( x + c, y + c, z + c );
    vertices[2] = vtx( x + c, y - c, z + c );
    vertices[3] = vtx( x - c, y - c, z + c );
    vertices[4] = vtx( x - c, y + c, z - c );
    vertices[5] = vtx( x + c, y + c, z - c );
    vertices[6] = vtx( x + c, y - c, z - c );
    vertices[7] = vtx( x - c, y - c, z - c );
    // Create inscribed hex
    if( MB_SUCCESS != iface->create_element( MBHEX, vertices, 8, hex ) ) moab_error( "create_element" );
    // Create vertices, 2 "above" each face of inscribed cube
    // +z face
    vertices[8] = vtx( x - b, y, z + a );
    vertices[9] = vtx( x + b, y, z + a );
    // +x face
    vertices[10] = vtx( x + a, y + b, z );
    vertices[11] = vtx( x + a, y - b, z );
    // -z face
    vertices[12] = vtx( x - b, y, z - a );
    vertices[13] = vtx( x + b, y, z - a );
    // -x face
    vertices[14] = vtx( x - a, y + b, z );
    vertices[15] = vtx( x - a, y - b, z );
    // +y face
    vertices[16] = vtx( x, y + a, z + b );
    vertices[17] = vtx( x, y + a, z - b );
    // -y face
    vertices[18] = vtx( x, y - a, z + b );
    vertices[19] = vtx( x, y - a, z - b );
    // Create petagons
    faces[0]  = pent( vertices, 0, 8, 9, 1, 16 );
    faces[1]  = pent( vertices, 3, 18, 2, 9, 8 );
    faces[2]  = pent( vertices, 2, 11, 10, 1, 9 );
    faces[3]  = pent( vertices, 2, 18, 19, 6, 11 );
    faces[4]  = pent( vertices, 1, 10, 5, 17, 16 );
    faces[5]  = pent( vertices, 5, 10, 11, 6, 13 );
    faces[6]  = pent( vertices, 4, 17, 5, 13, 12 );
    faces[7]  = pent( vertices, 7, 12, 13, 6, 19 );
    faces[8]  = pent( vertices, 4, 12, 7, 15, 14 );
    faces[9]  = pent( vertices, 0, 16, 17, 4, 14 );
    faces[10] = pent( vertices, 3, 15, 7, 19, 18 );
    faces[11] = pent( vertices, 0, 14, 15, 3, 8 );
    if( MB_SUCCESS != iface->create_element( MBPOLYHEDRON, faces, 12, dodec ) ) moab_error( "create_element" );
    // Create a dense tag
    int zero = 0;
    Tag tag;
    if( MB_SUCCESS != iface->tag_get_handle( tagname, 1, MB_TYPE_INTEGER, tag, MB_TAG_DENSE | MB_TAG_EXCL, &zero ) )
    // Put dense tag on all vertices.
    for( int i = 0; i < 20; ++i )
        if( MB_SUCCESS != iface->tag_set_data( tag, vertices + i, 1, &i ) ) moab_error( "tag_set_data" );
    // Create bit tag
    Tag tag2;
    if( MB_SUCCESS != iface->tag_get_handle( bitname, 2, MB_TYPE_BIT, tag2, MB_TAG_EXCL ) )
    // Set tag to 0 on Hex
    char two = '\002';
    if( MB_SUCCESS != iface->tag_set_data( tag2, &hex, 1, &two ) ) moab_error( "tag_set_data" );
    // set tag to 1 on dodecahedron
    char one = '\001';
    if( MB_SUCCESS != iface->tag_set_data( tag2, &dodec, 1, &one ) ) moab_error( "tag_set_data" );
    // Create an integer array tag and set some values on the dodecahedron
    Tag itag;
    if( MB_SUCCESS != iface->tag_get_handle( intname, 2, MB_TYPE_INTEGER, itag, MB_TAG_SPARSE | MB_TAG_EXCL ) )
        moab_error( "tag_get_handle(MB_TYPE_INT)" );
    int idata[] = { static_cast< int >( 0xDEADBEEF ), static_cast< int >( 0xDEFACED ) };
    if( MB_SUCCESS != iface->tag_set_data( itag, &dodec, 1, idata ) ) moab_error( "tag_set_data(itag)" );
    // Create a double tag with a non-zero default value, and set on dodecahedron
    Tag dtag;
    double ddef = 3.14159;
    if( MB_SUCCESS != iface->tag_get_handle( dblname, 1, MB_TYPE_DOUBLE, dtag, MB_TAG_DENSE | MB_TAG_EXCL, &ddef ) )
        moab_error( "tag_get_handle(dtag)" );
    double dval = 0.333;
    if( MB_SUCCESS != iface->tag_set_data( dtag, &dodec, 1, &dval ) ) moab_error( "tag_set_data(dtag)" );
    // Create a tag containing entity handles, with default values
    Tag htag;
    EntityHandle hdef[] = { hex, dodec, 0 };
    if( MB_SUCCESS != iface->tag_get_handle( handlename, 3, MB_TYPE_HANDLE, htag, MB_TAG_SPARSE | MB_TAG_EXCL, hdef ) )
        moab_error( "tag_get_handle(htag)" );
    // Set global (mesh) value for tag
    EntityHandle hgbl[]     = { 0, hex, dodec };
    if( MB_SUCCESS != iface->tag_set_data( htag, &root, 1, hgbl ) ) moab_error( "tag_set_data(hgbl)" );
    // Store first three entiries of dodec connectivity on dodec
    EntityHandle hval[] = { faces[0], faces[1], faces[2] };
    if( MB_SUCCESS != iface->tag_set_data( htag, &dodec, 1, hval ) ) moab_error( "tag_set_data(hgbl)" );
    // create some sets
    EntityHandle face_set, vertex_set, region_set, empty_set;
    EntityHandle regions[]     = { dodec, hex };
    const unsigned empty_flags = MESHSET_ORDERED | MESHSET_TRACK_OWNER;
    face_set                   = make_set( MESHSET_SET, faces, 12, false, FACE_SET_ID );
    vertex_set                 = make_set( MESHSET_ORDERED, vertices, 20, true, VERTEX_SET_ID );
    region_set                 = make_set( MESHSET_SET, regions, 2, false, REGION_SET_ID );
    empty_set                  = make_set( empty_flags, 0, 0, true, EMPTY_SET_ID );
    EntityHandle sets[]        = { face_set, vertex_set, region_set, empty_set };
    make_set( MESHSET_ORDERED, sets, 4, false, SET_SET_ID );
    // create some set parent-child links
    if( MB_SUCCESS != iface->add_parent_child( face_set, vertex_set ) ) moab_error( "add_parent_child" );
    if( MB_SUCCESS != iface->add_child_meshset( region_set, face_set ) ) moab_error( "add_child_meshset" );
    if( MB_SUCCESS != iface->add_parent_meshset( vertex_set, region_set ) ) moab_error( "add_parent_meshet" );
int main ( int  argc,
char *  argv[]
Definition at line 53 of file h5file_test.cpp.
References compare(), create(), moab::Interface::delete_mesh(), ErrorCode, filename, moab::Interface::get_last_error(), iface, moab::Interface::load_file(), MB_SUCCESS, moab_error(), and moab::Interface::write_file().
    ErrorCode rval;
    std::string msg;
    std::string read_opt;
    std::string write_opt( "DEBUG_BINIO" );
    for( int i = 1; i < argc; ++i )
        long val;
        char* endptr;
        if( argv[i][0] == '-' && ( argv[i][1] == 'r' || argv[i][1] == 'w' ) && i + 1 < argc &&
            ( val = strtol( argv[i + 1], &endptr, 0 ) ) >= 0 && !*endptr )
            std::string& s = argv[i][1] == 'r' ? read_opt : write_opt;
            std::ostringstream str;
            str << "DEBUG_IO=" << val;
            if( s.empty() )
                s = str.str();
            else
                s += ';';
                s += str.str();
            ++i;
        else
            std::cerr << "Usage: " << argv[0] << " [-r <n>] [-w <n>]" << std::endl;
            return 1;
    iface = new Core();
    // create a dodecahedron and inscribed hex
    fprintf( stderr, "creating... " );
    create();
    // write out the dodecahedron
    fprintf( stderr, "writing... " );
    rval = iface->write_file( filename, 0, write_opt.c_str() );
        fprintf( stderr, "Failed to write \"%s\"\n", filename );
        if( MB_SUCCESS == iface->get_last_error( msg ) ) fprintf( stderr, "%s\n", msg.c_str() );
        delete iface;
        return 1;
    // Read back in as a copy of the original
    fprintf( stderr, "reading... " );
    rval = iface->load_file( filename, 0, read_opt.c_str() );
        fprintf( stderr, "Failed to read \"%s\"\n", filename );
        delete iface;
        return 1;
    // Compare the two.
    fprintf( stderr, "comparing... " );
    if( !compare() )
        fprintf( stderr, "Comparison failed.\n" );
        delete iface;
        return 1;
    fprintf( stderr, "success!\n" );
    // Write both the original and copy to a file
        delete iface;
        return 1;
    // Delete the mesh
    fprintf( stderr, "clearing db... " );
    rval = iface->delete_mesh();
    if( MB_SUCCESS != rval ) moab_error( "delete_mesh" );
    // Read the two dodecahedrons from the file
        delete iface;
        return 1;
    // Compare them
    if( !compare() )
        delete iface;
        return 1;
    // Delete the mesh
    fprintf( stderr, "cleaning up... " );
    // Clean up the file.
    remove( filename );
    fprintf( stderr, "done.\n" );
    delete iface;
    return 0;
EntityHandle make_set ( unsigned int  options,
EntityHandle entities,
bool  reverse,
int  id
Definition at line 196 of file h5file_test.cpp.
References moab::Interface::add_entities(), moab::Interface::create_meshset(), moab::Interface::globalId_tag(), id_tag, iface, MB_SUCCESS, moab_error(), and moab::Interface::tag_set_data().
Referenced by create().
    EntityHandle handle;
    if( MB_SUCCESS != iface->create_meshset( options, handle ) ) moab_error( "create_meshset" );
    if( reverse )
        for( int i = (int)num_entities - 1; i >= 0; --i )
            if( MB_SUCCESS != iface->add_entities( handle, entities + i, 1 ) ) moab_error( "add_entities" );
    else
        if( MB_SUCCESS != iface->add_entities( handle, entities, num_entities ) ) moab_error( "add_entities" );
    if( MB_SUCCESS != iface->tag_set_data( id_tag, &handle, 1, &id ) ) moab_error( "tag_set_data" );
    return handle;
void moab_error ( const char *  function)
Definition at line 800 of file h5file_test.cpp.
References moab::Interface::get_last_error(), iface, and MB_SUCCESS.
Referenced by compare(), compare_conn(), compare_sets(), compare_tags(), create(), main(), make_set(), pent(), and vtx().
    std::string msg;
    fprintf( stderr, "%s() failed.\n", str );
    delete iface;
    exit( 1 );
EntityHandle pent ( EntityHandle vtx_list,
int  i1,
int  i2,
int  i3,
int  i4,
int  i5
Definition at line 182 of file h5file_test.cpp.
References conn, moab::Interface::create_element(), iface, MB_SUCCESS, MBPOLYGON, and moab_error().
    const EntityHandle conn[5] = { vtx_list[i1], vtx_list[i2], vtx_list[i3], vtx_list[i4], vtx_list[i5] };
    EntityHandle result;
    if( MB_SUCCESS != iface->create_element( MBPOLYGON, conn, 5, result ) ) moab_error( "create_element" );
    return result;
EntityHandle vtx ( double  x,
double  y,
double  z
Examples:
ComputeTriDual.cpp.
Definition at line 174 of file h5file_test.cpp.
References moab::Interface::create_vertex(), iface, MB_SUCCESS, and moab_error().
Referenced by check_one_layer(), PatchDataTest::check_sub_patch(), compute_dual_mesh(), create(), moab::ReadCGM::create_surface_facets(), MBMesquite::derivatives_at_mid_edge(), DistTestMetric::evaluate(), MBMesquite::ElementQM::evaluate_with_indices(), DistTestMetric::evaluate_with_indices(), exp_1_init(), MBMesquite::ElementQM::get_element_evaluations(), get_slaved_coords(), horseshoe(), moab::BSPTreePoly::is_valid(), mb_skin_adjacent_surf_patches(), MBMesquite::next_vertex(), parabolic_squash(), PartMap::part_from_coords(), quarter_annulus(), moab::ReadVtk::read_vertices(), scale(), moab::BSPTreePoly::VertexUse::set_vertex(), smooth_mesh(), test_entity_copy_parts(), MsqVertexTest::test_flags(), test_ghost_elements(), MsqVertexTest::test_hex_vertices(), MsqMeshEntityTest::test_hex_vertices(), PatchDataTest::test_patch_contents(), PatchDataTest::test_quad8_patch(), MBMesquite::DomainClassifier::test_valid_classification(), MBMesquite::MeshImpl::vtk_read_polydata(), MBMesquite::MeshImpl::vtk_read_rectilinear_grid(), MBMesquite::MeshImpl::vtk_read_structured_grid(), MBMesquite::MeshImpl::vtk_read_structured_points(), MBMesquite::MeshImpl::vtk_read_unstructured_grid(), LinearMappingFunctionTest::xi_at_edges(), and LinearMappingFunctionTest::xi_at_faces().
    const double p[3] = { x, y, z };
    if( MB_SUCCESS != iface->create_vertex( p, result ) ) moab_error( "create_vertex" );
    return result;
Variable Documentation
Definition at line 42 of file h5file_test.cpp.
Definition at line 39 of file h5file_test.cpp.
Definition at line 45 of file h5file_test.cpp.
Definition at line 41 of file h5file_test.cpp.
Definition at line 43 of file h5file_test.cpp.
Definition at line 40 of file h5file_test.cpp.
