h5portable.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "TestRunner.hpp"
#include "ReadHDF5.hpp"
#include "MBTagConventions.hpp"
#include "moab/FileOptions.hpp"
#include <vector>
#include <cstdlib>
#include <iostream>
#include <algorithm>
#include <limits>
+ Include dependency graph for h5portable.cpp:
Defines
#define FILE_NAME_BASE   "portable"
#define BASE_NAME   STRINGIFY( MESHDIR ) "/h5file/" FILE_NAME_BASE
#define NATIVE_NAME   FILE_NAME_BASE ".h5m"
#define READ_OPTS   "BUFFER_SIZE=256"
#define DEFINE_TEST_SET(NAME)
#define REGISTER_TEST_SET(NAME)
Functions
void create_mesh (const char *filename)
void test_load_file (const char *filename)
void test_read_vertices (const char *filename)
void test_elements (Interface &mb, bool odd_only)
void test_read_elements (const char *filename)
void read_sets (Interface &mb, EntityHandle rows[INTERVALS])
void test_read_set_contents (const char *filename)
void test_read_set_parent_child (const char *filename)
void test_read_int_tag (const char *filename)
void test_read_real_tag (const char *filename)
void test_read_handle_tag (const char *filename)
void test_read_bit_tag (const char *filename)
void test_read_partial (const char *filename)
void test_native_read ()
int main (int argc, char *argv[])
Variables
const int default_int_tag [] = { -100, -99 }
const int mesh_int_tag [] = { 1134, -1134 }
const double default_real_tag [] = { -1, -2, -3, -4, -5, -6, -7, -8 }
const double mesh_real_tag [] = { 8, 7, 6, 5, 4, 3, 2, 1 }
const size_t INTERVALS = 8
const size_t NUM_VERT = ( INTERVALS + 1 ) * ( INTERVALS + 1 )
const size_t NUM_QUAD = INTERVALS * INTERVALS
const double Z = 0.0
const double EPS = std::numeric_limits< double >::epsilon()
Detailed Description
Author:
Jason Kraftcheck
Date:
2010-09-23
Tests for HDF5 portability because we call H5Tconvert ourselves to work around parallel performance issues in the HDF5 library.
Definition in file h5portable.cpp.
Define Documentation
Definition at line 24 of file h5portable.cpp.
#define DEFINE_TEST_SET (   NAME)
Definition at line 530 of file h5portable.cpp.
Definition at line 23 of file h5portable.cpp.
Definition at line 25 of file h5portable.cpp.
Referenced by test_native_read().
#define REGISTER_TEST_SET (   NAME)
Value:
REGISTER_DEP_TEST( test_load_file_##NAME, test_native_read );                          \
    REGISTER_DEP_TEST( test_read_vertices_##NAME, test_load_file_##NAME );                 \
    REGISTER_DEP_TEST( test_read_elements_##NAME, test_read_vertices_##NAME );             \
    REGISTER_DEP_TEST( test_read_set_contents_##NAME, test_read_elements_##NAME );         \
    REGISTER_DEP_TEST( test_read_set_parent_child_##NAME, test_read_set_contents_##NAME ); \
    REGISTER_DEP_TEST( test_read_int_tag_##NAME, test_read_elements_##NAME );              \
    REGISTER_DEP_TEST( test_read_real_tag_##NAME, test_read_elements_##NAME );             \
    REGISTER_DEP_TEST( test_read_handle_tag_##NAME, test_read_elements_##NAME );           \
    REGISTER_DEP_TEST( test_read_bit_tag_##NAME, test_read_set_contents_##NAME );          \
    REGISTER_DEP_TEST( test_read_partial_##NAME, test_read_elements_##NAME );
Definition at line 572 of file h5portable.cpp.
Referenced by main().
Function Documentation
void create_mesh ( const char *  filename)
Definition at line 73 of file h5portable.cpp.
References moab::Interface::add_entities(), moab::Interface::add_parent_child(), CHECK_ERR, conn, moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), default_int_tag, default_real_tag, ErrorCode, moab::Interface::get_coords(), INTERVALS, mb, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MBQUAD, mesh_int_tag, mesh_real_tag, MESHSET_SET, NUM_QUAD, NUM_VERT, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::Interface::write_file(), and MBMesquite::MeshWriter::Z.
    EntityHandle verts[NUM_VERT];
    EntityHandle quads[NUM_QUAD];
    ErrorCode rval;
    Core core;
    Interface& mb           = core;
    const EntityHandle root = 0;
    Tag int_tag, real_tag, handle_tag, bit_tag, row_tag;
    rval = mb.tag_get_handle( "int_tag", 2, MB_TYPE_INTEGER, int_tag, MB_TAG_DENSE | MB_TAG_EXCL, default_int_tag );CHECK_ERR( rval );
    rval = mb.tag_set_data( int_tag, &root, 1, mesh_int_tag );CHECK_ERR( rval );
    rval = mb.tag_get_handle( "real_tag", 8, MB_TYPE_DOUBLE, real_tag, MB_TAG_DENSE | MB_TAG_EXCL, default_real_tag );CHECK_ERR( rval );
    rval = mb.tag_set_data( real_tag, &root, 1, mesh_real_tag );CHECK_ERR( rval );
    rval = mb.tag_get_handle( "handle_tag", 1, MB_TYPE_HANDLE, handle_tag, MB_TAG_SPARSE | MB_TAG_EXCL );CHECK_ERR( rval );
    rval = mb.tag_get_handle( "bit_tag", 1, MB_TYPE_BIT, bit_tag, MB_TAG_EXCL );CHECK_ERR( rval );
    rval = mb.tag_get_handle( "rowset", 1, MB_TYPE_INTEGER, row_tag, MB_TAG_SPARSE | MB_TAG_EXCL );CHECK_ERR( rval );
    for( size_t i = 0; i < NUM_VERT; ++i )
        double coords[] = { static_cast< double >( i % 9 ), static_cast< double >( i / 9 ),
                            static_cast< double >( Z ) };
        rval            = mb.create_vertex( coords, verts[i] );CHECK_ERR( rval );
    for( size_t i = 0; i < NUM_QUAD; ++i )
        size_t j            = ( i / 8 ) * 9 + i % 8;
        EntityHandle conn[] = { verts[j], verts[j + 1], verts[j + 10], verts[j + 9] };
        rval                = mb.create_element( MBQUAD, conn, 4, quads[i] );CHECK_ERR( rval );
        double coords[4 * 3];
        rval = mb.get_coords( conn, 4, coords );CHECK_ERR( rval );
        int int_val[] = { (int)coords[0], (int)coords[1] };
        rval          = mb.tag_set_data( int_tag, quads + i, 1, int_val );CHECK_ERR( rval );
        double real_val[] = { coords[0], coords[1], coords[3], coords[4], coords[6], coords[7], coords[9], coords[10] };
        rval              = mb.tag_set_data( real_tag, quads + i, 1, real_val );CHECK_ERR( rval );
        rval = mb.tag_set_data( handle_tag, conn, 1, quads + i );CHECK_ERR( rval );
    EntityHandle prev = 0;
    for( size_t i = 0; i < INTERVALS; ++i )
        EntityHandle set;
        int flag = i < 4 ? MESHSET_SET : MESHSET_ORDERED;
        rval     = mb.create_meshset( flag, set );CHECK_ERR( rval );
        rval = mb.add_entities( set, quads + i * INTERVALS, INTERVALS );CHECK_ERR( rval );
        char bit = i % 2;
        rval     = mb.tag_set_data( bit_tag, &set, 1, &bit );CHECK_ERR( rval );
        int ival = bit;
        rval     = mb.tag_set_data( row_tag, &set, 1, &ival );CHECK_ERR( rval );
        if( prev != 0 )
            rval = mb.add_parent_child( prev, set );CHECK_ERR( rval );
        prev = set;
    rval = mb.write_file( filename, "MOAB" );CHECK_ERR( rval );
int main ( int  argc,
char *  argv[]
Definition at line 588 of file h5portable.cpp.
References moab::fail(), REGISTER_TEST, REGISTER_TEST_SET, RUN_TESTS, and test_native_read().
#ifdef MOAB_HAVE_MPI
    int fail = MPI_Init( &argc, &argv );
    if( fail ) return fail;
#endif
    REGISTER_TEST( test_native_read );
    REGISTER_TEST_SET( x86_64 );
    REGISTER_TEST_SET( x86_32 );
    REGISTER_TEST_SET( power_32 );
    int result = RUN_TESTS( argc, argv );
    fail = MPI_Finalize();
#endif
    return result;
void read_sets ( Interface mb,
Definition at line 242 of file h5portable.cpp.
References moab::Range::all_of_type(), moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, conn, moab::Range::end(), ErrorCode, moab::Range::front(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), MBENTITYSET, MBQUAD, and moab::Range::size().
Referenced by test_gather_sets_ranged(), test_read_bit_tag(), test_read_set_contents(), and test_read_set_parent_child().
    // get the sets
    Range sets;
    ErrorCode rval = mb.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval );
    CHECK_EQUAL( INTERVALS, sets.size() );
    // check set contents
    for( Range::iterator i = sets.begin(); i != sets.end(); ++i )
        Range contents;
        rval = mb.get_entities_by_handle( *i, contents );CHECK_ERR( rval );
        CHECK_EQUAL( INTERVALS, contents.size() );
        CHECK( contents.all_of_type( MBQUAD ) );
        const EntityHandle* conn = 0;
        int len                  = 0;
        rval                     = mb.get_connectivity( contents.front(), conn, len );CHECK_ERR( rval );
        double coords[3];
        rval = mb.get_coords( conn, 1, coords );CHECK_ERR( rval );
        size_t y = (size_t)coords[1];
        CHECK( y < INTERVALS );
        rows[y] = *i;
void test_elements ( Interface mb,
bool  odd_only
Definition at line 185 of file h5portable.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, conn, moab::Range::end(), EPS, ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), INTERVALS, MBQUAD, NUM_QUAD, moab::Range::size(), and MBMesquite::MeshWriter::Z.
Referenced by test_read_elements(), and test_read_partial().
    // get the elements
    Range quads;
    ErrorCode rval = mb.get_entities_by_type( 0, MBQUAD, quads );CHECK_ERR( rval );
    CHECK_EQUAL( NUM_QUAD / ( 1 + odd_only ), quads.size() );
    // check quad connectivity
    bool seen[INTERVALS][INTERVALS];
        for( size_t j = 0; j < INTERVALS; ++j )
            seen[i][j] = false;
    for( Range::iterator i = quads.begin(); i != quads.end(); ++i )
        int len                  = 0;
        rval                     = mb.get_connectivity( *i, conn, len );CHECK_ERR( rval );
        CHECK_EQUAL( 4, len );
        rval = mb.get_coords( conn, len, coords );CHECK_ERR( rval );
        size_t x = (size_t)coords[0];
        CHECK_REAL_EQUAL( (double)x, coords[0], EPS );
        CHECK_REAL_EQUAL( (double)y, coords[1], EPS );
        CHECK( x < INTERVALS );
        CHECK_REAL_EQUAL( Z, coords[2], EPS );
        CHECK_REAL_EQUAL( 1.0 + x, coords[3], EPS );
        CHECK_REAL_EQUAL( 0.0 + y, coords[4], EPS );
        CHECK_REAL_EQUAL( Z, coords[5], EPS );
        CHECK_REAL_EQUAL( 1.0 + x, coords[6], EPS );
        CHECK_REAL_EQUAL( 1.0 + y, coords[7], EPS );
        CHECK_REAL_EQUAL( Z, coords[8], EPS );
        CHECK_REAL_EQUAL( 0.0 + x, coords[9], EPS );
        CHECK_REAL_EQUAL( 1.0 + y, coords[10], EPS );
        CHECK_REAL_EQUAL( Z, coords[11], EPS );
    if( odd_only )
        for( size_t i = 0; i < INTERVALS; i += 2 )
                CHECK( !seen[i][j] );
void test_load_file ( const char *  filename)
Definition at line 147 of file h5portable.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::load_file(), and READ_OPTS.
    Core core;
    ErrorCode rval = mb.load_file( filename, 0, READ_OPTS );CHECK_ERR( rval );
void test_read_bit_tag ( const char *  filename)
Definition at line 469 of file h5portable.cpp.
References CHECK_ARRAYS_EQUAL, CHECK_EQUAL, CHECK_ERR, ErrorCode, INTERVALS, moab::Interface::load_file(), MB_TAG_BIT, MB_TYPE_BIT, READ_OPTS, read_sets(), size, moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), and TagType.
    // load the file
    Core core;
    // get the tag
    Tag tag;
    rval = mb.tag_get_handle( "bit_tag", 1, MB_TYPE_BIT, tag );CHECK_ERR( rval );
    // check tag properties
    int size;
    rval = mb.tag_get_length( tag, size );CHECK_ERR( rval );
    CHECK_EQUAL( 1, size );
    TagType storage;
    rval = mb.tag_get_type( tag, storage );CHECK_ERR( rval );
    CHECK_EQUAL( MB_TAG_BIT, storage );
    DataType type;
    rval = mb.tag_get_data_type( tag, type );CHECK_ERR( rval );
    CHECK_EQUAL( MB_TYPE_BIT, type );
    // check entity values
    EntityHandle sets[INTERVALS];
    read_sets( mb, sets );
    char values[INTERVALS], expected[INTERVALS];
    rval = mb.tag_get_data( tag, sets, INTERVALS, values );CHECK_ERR( rval );
        expected[i] = (char)( i % 2 );
    CHECK_ARRAYS_EQUAL( expected, INTERVALS, values, INTERVALS );
void test_read_elements ( const char *  filename)
Definition at line 232 of file h5portable.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::load_file(), READ_OPTS, and test_elements().
Referenced by main(), and test_native_read().
    // load the file
    Core core;
    // check the elements
    test_elements( mb, false );
void test_read_handle_tag ( const char *  filename)
Definition at line 432 of file h5portable.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, conn, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), moab::Interface::load_file(), MB_TAG_SPARSE, MB_TYPE_HANDLE, MBQUAD, READ_OPTS, size, moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), TagType, and value().
    // load the file
    Core core;
    // get the tag
    Tag tag;
    rval = mb.tag_get_handle( "handle_tag", 1, MB_TYPE_HANDLE, tag );CHECK_ERR( rval );
    int size;
    TagType storage;
    CHECK_EQUAL( MB_TAG_SPARSE, storage );
    DataType type;
    CHECK_EQUAL( MB_TYPE_HANDLE, type );
    Range quads;
        int len                  = 0;
        EntityHandle value;
        rval = mb.tag_get_data( tag, conn, 1, &value );CHECK_ERR( rval );
        CHECK_EQUAL( *i, value );
void test_read_int_tag ( const char *  filename)
Definition at line 333 of file h5portable.cpp.
References moab::Range::begin(), CHECK_ARRAYS_EQUAL, CHECK_EQUAL, CHECK_ERR, conn, default_int_tag, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Interface::load_file(), MB_TAG_DENSE, MB_TYPE_INTEGER, MBQUAD, mesh_int_tag, READ_OPTS, size, moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), TagType, and value().
    // load the file
    Core core;
    // get the tag
    Tag tag;
    rval = mb.tag_get_handle( "int_tag", 2, MB_TYPE_INTEGER, tag );CHECK_ERR( rval );
    int size;
    CHECK_EQUAL( 2, size );
    TagType storage;
    CHECK_EQUAL( MB_TAG_DENSE, storage );
    DataType type;
    CHECK_EQUAL( MB_TYPE_INTEGER, type );
    // check default value
    int value[2];
    rval = mb.tag_get_default_value( tag, value );CHECK_ERR( rval );
    CHECK_ARRAYS_EQUAL( default_int_tag, 2, value, 2 );
    // check mesh value
    rval                    = mb.tag_get_data( tag, &root, 1, value );CHECK_ERR( rval );
    CHECK_ARRAYS_EQUAL( mesh_int_tag, 2, value, 2 );
    Range quads;
        int len                  = 0;
        double coords[3];
        int exp[] = { (int)coords[0], (int)coords[1] };
        rval = mb.tag_get_data( tag, &*i, 1, value );CHECK_ERR( rval );
        CHECK_ARRAYS_EQUAL( exp, 2, value, 2 );
void test_read_partial ( const char *  filename)
Definition at line 501 of file h5portable.cpp.
    // load the file
    Core core;
    const int odd  = 1;
    ErrorCode rval = mb.load_file( filename, 0, "CHILDREN=NONE;SETS=NONE;" READ_OPTS, "rowset", &odd, 1 );CHECK_ERR( rval );
    test_elements( mb, true );
void test_read_real_tag ( const char *  filename)
Definition at line 382 of file h5portable.cpp.
References moab::Range::begin(), CHECK_ARRAYS_EQUAL, CHECK_EQUAL, CHECK_ERR, conn, default_real_tag, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Interface::load_file(), MB_TAG_DENSE, MB_TYPE_DOUBLE, MBQUAD, mesh_real_tag, READ_OPTS, size, moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), TagType, and value().
    // load the file
    Core core;
    // get the tag
    Tag tag;
    rval = mb.tag_get_handle( "real_tag", 8, MB_TYPE_DOUBLE, tag );CHECK_ERR( rval );
    int size;
    CHECK_EQUAL( 8, size );
    TagType storage;
    DataType type;
    CHECK_EQUAL( MB_TYPE_DOUBLE, type );
    double value[8];
    CHECK_ARRAYS_EQUAL( default_real_tag, 8, value, 8 );
    // check mesh value
    CHECK_ARRAYS_EQUAL( mesh_real_tag, 8, value, 8 );
    Range quads;
        int len                  = 0;
        double coords[3 * 4];
        double exp[] = { coords[0], coords[1], coords[3], coords[4], coords[6], coords[7], coords[9], coords[10] };
        CHECK_ARRAYS_EQUAL( exp, 8, value, 8 );
void test_read_set_contents ( const char *  filename)
Definition at line 268 of file h5portable.cpp.
References moab::Range::all_of_type(), moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, conn, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), INTERVALS, moab::Interface::load_file(), MBQUAD, READ_OPTS, read_sets(), and moab::Range::size().
    // load the file
    Core core;
    // get the sets
    EntityHandle rows[INTERVALS];
    read_sets( mb, rows );
        Range contents;
        rval = mb.get_entities_by_handle( rows[i], contents );CHECK_ERR( rval );
        for( Range::iterator j = contents.begin(); j != contents.end(); ++j )
            int len                  = 0;
            rval                     = mb.get_connectivity( *j, conn, len );CHECK_ERR( rval );
            double coords[3];
            CHECK_EQUAL( i, y );
void test_read_set_parent_child ( const char *  filename)
Definition at line 299 of file h5portable.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_parent_meshsets(), INTERVALS, moab::Interface::load_file(), READ_OPTS, and read_sets().
    // load the file
    Core core;
    // get the sets
    // check set children
    std::vector< EntityHandle > list;
    for( size_t i = 0; i < INTERVALS - 1; ++i )
        list.clear();
        rval = mb.get_child_meshsets( rows[i], list );CHECK_ERR( rval );
        CHECK_EQUAL( (size_t)1, list.size() );
        CHECK_EQUAL( rows[i + 1], list.front() );
    list.clear();
    rval = mb.get_child_meshsets( rows[INTERVALS - 1], list );CHECK_ERR( rval );
    CHECK( list.empty() );
    // check set parents
    list.clear();
    rval = mb.get_parent_meshsets( rows[0], list );CHECK_ERR( rval );
    for( size_t i = 1; i < INTERVALS; ++i )
        list.clear();
        rval = mb.get_parent_meshsets( rows[i], list );CHECK_ERR( rval );
        CHECK_EQUAL( rows[i - 1], list.front() );
void test_read_vertices ( const char *  filename)
Definition at line 154 of file h5portable.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, moab::Range::end(), EPS, ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), INTERVALS, moab::Interface::load_file(), MBVERTEX, READ_OPTS, moab::Range::size(), and MBMesquite::MeshWriter::Z.
    // load the file
    Core core;
    // get the vertices
    Range verts;
    rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval );
    CHECK_EQUAL( NUM_VERT, verts.size() );
    // check vertex coordinates
    bool seen[INTERVALS + 1][INTERVALS + 1];
    for( size_t i = 0; i <= INTERVALS; ++i )
        for( size_t j = 0; j <= INTERVALS; ++j )
            seen[i][j] = false;
    for( Range::iterator i = verts.begin(); i != verts.end(); ++i )
        double coords[3];
        rval = mb.get_coords( &*i, 1, coords );CHECK_ERR( rval );
        CHECK( x <= INTERVALS );
        CHECK( y <= INTERVALS );
        CHECK( !seen[x][y] );
        seen[x][y] = true;
Variable Documentation
const int default_int_tag[] = { -100, -99 }
Definition at line 28 of file h5portable.cpp.
Referenced by create_mesh(), and test_read_int_tag().
const double default_real_tag[] = { -1, -2, -3, -4, -5, -6, -7, -8 }
Definition at line 30 of file h5portable.cpp.
Referenced by create_mesh(), and test_read_real_tag().
Definition at line 37 of file h5portable.cpp.
Definition at line 33 of file h5portable.cpp.
const int mesh_int_tag[] = { 1134, -1134 }
Definition at line 29 of file h5portable.cpp.
const double mesh_real_tag[] = { 8, 7, 6, 5, 4, 3, 2, 1 }
Definition at line 31 of file h5portable.cpp.
Definition at line 35 of file h5portable.cpp.
Referenced by create_mesh(), and test_elements().
Definition at line 34 of file h5portable.cpp.
Referenced by create_mesh().
Definition at line 36 of file h5portable.cpp.
