MOAB: Mesh Oriented datABase
(version 5.4.1)
Functions | |
int | test_get_set () |
int | test_coord_operators () |
int | test_xform_operators () |
int | test_xform_functions () |
int | test_coord_xform_operators () |
int | main (int, char **) |
int | test_xform_constructors () |
int main | ( | int | , |
char ** | |||
Definition at line 30 of file homxform_test.cpp.
References test_coord_operators(), test_coord_xform_operators(), test_get_set(), test_xform_functions(), and test_xform_operators().
{ // first test HomCoord // constructors // following shouldn't compile, since bare constructor is private int errors = 0; errors += test_get_set(); errors += test_coord_operators(); errors += test_xform_operators(); errors += test_xform_functions(); errors += test_coord_xform_operators(); if( errors > 0 ) std::cout << errors << " errors found." << std::endl; else std::cout << "All tests passed." << std::endl; return errors; }
int test_coord_operators | ( | ) |
Definition at line 101 of file homxform_test.cpp.
Referenced by main().
{ int errors = 0; HomCoord coords1( 1, 2, 3, 1 ); HomCoord coords2( 4, 3, 2, 1 ); HomCoord coords3( 4, 3, 2 ); HomCoord coords4( 1, 1, 1, 1 ); // operator>= bool optest = ( coords2 >= coords4 && coords2 >= coords3 && coords3 >= coords2 ); if( !optest ) { std::cout << "Test failed for operator >=." << std::endl; errors++; } optest = ( coords4 <= coords2 && coords2 <= coords3 && coords3 <= coords2 ); if( !optest ) { std::cout << "Test failed for operator <=." << std::endl; errors++; } // operator> optest = ( coords2 > coords4 && !( coords2 > coords3 ) && !( coords3 > coords2 ) ); if( !optest ) { std::cout << "Test failed for operator >." << std::endl; errors++; } optest = ( coords4 < coords2 && !( coords2 < coords3 ) && !( coords3 < coords2 ) ); if( !optest ) { std::cout << "Test failed for operator <." << std::endl; errors++; } // operator[] for( int i = 0; i < 3; i++ ) { if( coords1[i] != coords2[3 - i] ) { std::cout << "Test failed for operator[]." << std::endl; errors++; } } // operator+ HomCoord coords5( 2 * coords1[0], 2 * coords1[1], 2 * coords1[2] ); HomCoord coords6 = coords1 + coords1; if( coords5 != coords6 ) { std::cout << "Test failed for operator+." << std::endl; errors++; } // operator- if( coords5 - coords1 != coords1 ) { std::cout << "Test failed for operator-." << std::endl; errors++; } return errors; }
int test_coord_xform_operators | ( | ) |
Definition at line 317 of file homxform_test.cpp.
References moab::HomXform::IDENTITY, scale(), and moab::HomXform::three_pt_xform().
{ int errors = 0; // sample pt HomCoord test_pt( 1, 2, 3 ); HomCoord test_pt2 = test_pt * HomXform::IDENTITY; if( test_pt2 != test_pt ) { std::cout << "Coord-xform operator* failed." << std::endl; errors++; } // get an inverse transform quickly int rotate[] = { 0, 1, 0, -1, 0, 0, 0, 0, 1 }; int translate[] = { 4, 5, 6 }; int scale[] = { 1, 1, 1 }; HomXform xform2( rotate, scale, translate ); // operator* HomCoord ident( 1, 1, 1, 1 ); HomCoord test_pt3 = ident * HomXform::IDENTITY; if( test_pt3 != ident ) { std::cout << "Coord-xform operator* failed." << std::endl; errors++; } // operator/ test_pt2 = ( test_pt * xform2 ) / xform2; if( test_pt2 != test_pt ) { std::cout << "Coord-xform operator/ failed." << std::endl; errors++; } // test three_pt_xform; use known transforms in most cases HomXform xform; // first test: i = j, j = -i, k = k, t = (7,5,0) xform.three_pt_xform( HomCoord( 0, 0, 0, 1 ), HomCoord( 7, 5, 0, 1 ), HomCoord( 0, 3, 0, 1 ), HomCoord( 4, 5, 0, 1 ), HomCoord( 0, 0, 3, 1 ), HomCoord( 7, 5, 3, 1 ) ); HomXform solution( 0, 1, 0, 0, -1, 0, 0, 0, 0, 0, 1, 0, 7, 5, 0, 1 ); if( xform != solution ) { std::cout << "Three-pt transform (general) test failed." << std::endl; errors++; } // now test 1d xform.three_pt_xform( HomCoord( 0, 0, 0, 1 ), HomCoord( 7, 5, 0, 1 ), HomCoord( 6, 0, 0, 1 ), HomCoord( 7, 11, 0, 1 ), HomCoord( 0, 0, 0, 1 ), HomCoord( 7, 5, 0, 1 ) ); solution = HomXform( 0, 1, 0, 0, 1, 0, 0, 0, 0, 0, -1, 0, 7, 5, 0, 1 ); if( xform != solution ) { std::cout << "Three-pt transform (1d) test failed." << std::endl; errors++; } return errors; }
int test_get_set | ( | ) |
Definition at line 53 of file homxform_test.cpp.
References moab::HomCoord::h(), moab::HomCoord::hom_coord(), moab::HomCoord::i(), moab::HomCoord::j(), moab::HomCoord::k(), and moab::HomCoord::set().
Referenced by main(), test_clear_dense(), test_clear_sparse(), test_get_pointers_dense(), test_get_pointers_sparse(), test_get_set_dense_double(), test_get_set_dense_int(), test_get_set_sparse_int(), test_set_pointers_dense(), and test_set_pointers_sparse().
{ int errors = 0; // other constructors int coordsa[4] = { 1, 2, 3, 1 }; int coordsb[4] = { 4, 3, 2, 1 }; HomCoord coords1( coordsa ); HomCoord coords2( 4, 3, 2, 1 ); HomCoord coords3( 4, 3, 2 ); HomCoord coords4( 1, 1, 1, 1 ); // set coords2.set( coordsb ); // hom_coord() for( int i = 0; i < 4; i++ ) { if( coords2.hom_coord()[i] != coordsb[i] ) { std::cout << "Get test failed." << std::endl; errors++; } } // ijkh if( coords2.i() != coordsb[0] || coords2.j() != coordsb[1] || coords2.k() != coordsb[2] || coords2.h() != coordsb[3] ) { std::cout << "ijkh test failed." << std::endl; errors++; } // set coords2.set( 3, 3, 3 ); // hom_coord() if( coords2.hom_coord()[0] != 3 || coords2.hom_coord()[1] != 3 || coords2.hom_coord()[2] != 3 || coords2.hom_coord()[3] != 1 ) { std::cout << "Set (int) test failed." << std::endl; errors++; } return errors; }
int test_xform_constructors | ( | ) |
Definition at line 169 of file homxform_test.cpp.
References scale(), and XFORM_INDEX.
{ int errors = 0; // integer constructor int test_int[] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15 }; HomXform xform( test_int ); for( int i = 0; i < 16; i++ ) { if( xform[i] != i ) { std::cout << "HomXform integer array constructor failed." << std::endl; errors++; } } HomXform xform3( test_int[0], test_int[1], test_int[2], test_int[3], test_int[4], test_int[5], test_int[6], test_int[7], test_int[8], test_int[9], test_int[10], test_int[11], test_int[12], test_int[13], test_int[14], test_int[15] ); for( int i = 0; i < 16; i++ ) { if( xform3[i] != i ) { std::cout << "HomXform integer constructor failed." << std::endl; errors++; } } // sample rotation, translation, and scaling matrices/vectors int rotate[] = { 0, 1, 0, -1, 0, 0, 0, 0, 1 }; int translate[] = { 4, 5, 6 }; int scale[] = { 1, 1, 1 }; // construct an xform matrix based on those HomXform xform2( rotate, scale, translate ); // test where those went in the xform if( !( xform2[XFORM_INDEX( 0, 0 )] == rotate[0] && xform2[XFORM_INDEX( 0, 1 )] == rotate[1] && xform2[XFORM_INDEX( 0, 2 )] == rotate[2] && xform2[XFORM_INDEX( 1, 0 )] == rotate[3] && xform2[XFORM_INDEX( 1, 1 )] == rotate[4] && xform2[XFORM_INDEX( 1, 2 )] == rotate[5] && xform2[XFORM_INDEX( 2, 0 )] == rotate[6] && xform2[XFORM_INDEX( 2, 1 )] == rotate[7] && xform2[XFORM_INDEX( 2, 2 )] == rotate[8] && xform2[XFORM_INDEX( 3, 0 )] == translate[0] && xform2[XFORM_INDEX( 3, 1 )] == translate[1] && xform2[XFORM_INDEX( 3, 2 )] == translate[2] && xform2[XFORM_INDEX( 0, 3 )] == 0 && xform2[XFORM_INDEX( 1, 3 )] == 0 && xform2[XFORM_INDEX( 2, 3 )] == 0 && xform2[XFORM_INDEX( 3, 3 )] == 1 ) ) { std::cout << "HomXform rotate, scale, translate constructor failed." << std::endl; errors++; } return errors; }
int test_xform_functions | ( | ) |
Definition at line 276 of file homxform_test.cpp.
References moab::HomXform::IDENTITY, moab::HomXform::inverse(), moab::HomCoord::length(), moab::HomCoord::length_squared(), and moab::HomCoord::normalize().
{ int errors = 0; // HomCoord functions // length() and length_squared() HomCoord coord1( 3, 4, 5 ); if( coord1.length_squared() != 50 || coord1.length() != 7 ) { std::cout << "HomCoord length() or length_squared() failed." << std::endl; errors++; } // normalize() coord1.normalize(); HomCoord coord2( 3, 0, 0 ); coord2.normalize(); if( coord1.length_squared() != 0 || coord2.length_squared() != 1 ) { std::cout << "HomCoord normalize failed." << std::endl; errors++; } // sample rotation, translation, and scaling matrices/vectors int inv_int[] = { 0, 1, 0, 0, -1, 0, 0, 0, 0, 0, 1, 0, 7, 5, 0, 1 }; // construct an xform matrix based on those HomXform xform1( inv_int ); HomXform xform1_inv = xform1.inverse(); HomXform xform2 = xform1 * xform1_inv; if( xform2 != HomXform::IDENTITY ) { std::cout << "HomXform inverse failed." << std::endl; errors++; } return errors; }
int test_xform_operators | ( | ) |
Definition at line 222 of file homxform_test.cpp.
References moab::HomXform::IDENTITY, and scale().
{ int errors = 0; // sample rotation, translation, and scaling matrices/vectors int rotate[] = { 0, 1, 0, -1, 0, 0, 0, 0, 1 }; int translate[] = { 4, 5, 6 }; int scale[] = { 1, 1, 1 }; // construct an xform matrix based on those HomXform xform1( rotate, scale, translate ); HomXform xform1a( rotate, scale, translate ); // test operator== if( !( xform1 == xform1a ) ) { std::cout << "HomXform operator== failed." << std::endl; errors++; } // test operator!= xform1a[1] = 0; if( !( xform1 != xform1a ) ) { std::cout << "HomXform operator!= failed." << std::endl; errors++; } // test operator= HomXform xform1c = xform1; if( !( xform1c == xform1 ) ) { std::cout << "HomXform operator= failed." << std::endl; errors++; } HomXform xform3 = xform1 * HomXform::IDENTITY; if( xform3 != xform1 ) { std::cout << "HomXform operator * failed." << std::endl; errors++; } // test operator*= xform3 *= HomXform::IDENTITY; if( xform3 != xform1 ) { std::cout << "HomXform operator *= failed." << std::endl; errors++; } return errors; }
