honodes.cpp
00001 #include <iostream>
00002 #include <moab/Core.hpp>
00003 #include "moab/ProgOptions.hpp"
00004
00005 using namespace moab;
00006 using namespace std;
00007 const char BRIEF_DESC[] = "Add higher order nodes to existing mesh, eg. hex8 to hex27 (default). "
00008                           "Use available options as desired.";
00009 std::ostringstream LONG_DESC;
00010
00011 int main( int argc, char* argv[] )
00012 {
00013     moab::Core* mb = new moab::Core();
00014     moab::ErrorCode rval;
00015     bool edge   = false;
00016     bool face   = false;
00017     bool volume = false;
00018
00019     LONG_DESC << "mbhonodes tool reads a mesh file and adds higher order nodes." << std::endl
00020               << "Options to add higher order nodes on all volume or face or edge elements of the mesh "
00021                  "are supported"
00022               << std::endl
00023               << "Example1: Use the following command to create hex mid volume nodes, in.h5m is a hex8 "
00024                  "mesh"
00025               << std::endl
00026               << " -> mbhonodes -i in.h5m -o o.h5m -f -e" << std::endl
00027               << "Example2: Use the following command to create hex27 mesh o2.h5m, in.h5m is a hex8 mesh" << std::endl
00028               << " -> mbhonodes -i in.h5m -o o2.h5m" << std::endl;
00029
00030     ProgOptions opts( LONG_DESC.str(), BRIEF_DESC );
00031     string inFileName = "";
00032     opts.addRequiredArg< string >( "inFile,i", "Specify the output file name string", &inFileName );
00033 #ifdef MOAB_HAVE_HDF5
00034     string outFileName = "outfile.h5m";
00035 #else
00036     string outFileName = "outfile.vtk";
00037 #endif
00038     opts.addOpt< string >( "outFile,o", "Specify the output file name string (default outfile.h5m)", &outFileName );
00039     opts.addOpt< void >( "edge,e", "DO NOT create mid nodes along edge (default=true)", &edge );
00040     opts.addOpt< void >( "face,f", "DO NOT create face mid nodes (default=true)", &face );
00041     opts.addOpt< void >( "volume,v", "DO NOT create volume mid nodes (default=true)", &volume );
00042
00043     opts.parseCommandLine( argc, argv );
00044
00045     // load the input file
00046     rval = mb->load_mesh( inFileName.c_str() );MB_CHK_SET_ERR( rval, "Failed to write the mesh file" );
00047     std::cout << "Read input mesh file: " << inFileName << std::endl;
00048     moab::Range entities;
00049     moab::EntityHandle meshset;
00050
00051     rval = mb->get_entities_by_type( 0, MBHEX, entities );MB_CHK_SET_ERR( rval, "Failed to get hex entities" );
00052     rval = mb->create_meshset( MESHSET_SET, meshset );MB_CHK_SET_ERR( rval, "Failed to create meshset" );
00053     rval = mb->add_entities( meshset, entities );MB_CHK_SET_ERR( rval, "Failed to add entitites to meshset" );
00054
00055     rval = mb->convert_entities( meshset, !edge, !face, !volume );MB_CHK_SET_ERR( rval, "Failed to convert to higher dimension entities" );
00056
00057     rval = mb->write_mesh( outFileName.c_str() );MB_CHK_SET_ERR( rval, "Failed to write the mesh file" );
00058     std::cout << "Wrote mesh file: " << outFileName << std::endl;
00059     delete mb;
00060 }
