hypre_parcsr.hpp
00001 // Copyright (c) 2010, Lawrence Livermore National Security, LLC. Produced at
00002 // the Lawrence Livermore National Laboratory. LLNL-CODE-443211. All Rights
00003 // reserved. See file COPYRIGHT for details.
00004 //
00005 // This file is part of the MFEM library. For more information and source code
00006 // availability see http://mfem.org.
00007 //
00008 // MFEM is free software; you can redistribute it and/or modify it under the
00009 // terms of the GNU Lesser General Public License (as published by the Free
00010 // Software Foundation) version 2.1 dated February 1999.
00011
00012 #ifndef MOAB_HYPRE_PARCSR
00013 #define MOAB_HYPRE_PARCSR
00014
00015 #include "moab/MOABConfig.h"
00016
00017 #ifdef MOAB_HAVE_MPI
00018
00019 #include "_hypre_parcsr_mv.h"
00020
00021 namespace moab
00022 {
00023
00024 namespace internal
00025 {
00026
00027     // This module contains functions that are logically part of HYPRE, and might
00028     // become part of HYPRE at some point. In the meantime the module can be
00029     // thought of as an extension of HYPRE.
00030
00031     /** Parallel essential BC elimination from the system A*X = B.
00032         (Adapted from hypre_ParCSRMatrixEliminateRowsCols.) */
00033     void hypre_ParCSRMatrixEliminateAXB( hypre_ParCSRMatrix* A,
00034                                          HYPRE_Int num_rowscols_to_elim,
00035                                          HYPRE_Int* rowscols_to_elim,
00036                                          hypre_ParVector* X,
00037                                          hypre_ParVector* B );
00038
00039     /** Parallel essential BC elimination from matrix A only. The eliminated
00040         elements are stored in a new matrix Ae, so that (A + Ae) equals the original
00041         matrix A. */
00042     void hypre_ParCSRMatrixEliminateAAe( hypre_ParCSRMatrix* A,
00043                                          hypre_ParCSRMatrix** Ae,
00044                                          HYPRE_Int num_rowscols_to_elim,
00045                                          HYPRE_Int* rowscols_to_elim );
00046
00047     /** Split matrix 'A' into nr x nc blocks, return nr x nc pointers to
00048         new parallel matrices. The array 'blocks' needs to be preallocated to hold
00049         nr x nc pointers. If 'interleaved' == 0 the matrix is split into contiguous
00050         blocks (AAABBBCCC) otherwise the blocks are interleaved (ABCABCABC).
00051         The local number of rows of A must be divisible by nr. The local number of
00052         columns of A must be divisible by nc. */
00053     void hypre_ParCSRMatrixSplit( hypre_ParCSRMatrix* A,
00054                                   HYPRE_Int nr,
00055                                   HYPRE_Int nc,
00056                                   hypre_ParCSRMatrix** blocks,
00057                                   int interleaved_rows,
00058                                   int interleaved_cols );
00059
00060     typedef int HYPRE_Bool;
00061 #define HYPRE_MPI_BOOL MPI_INT
00062
00063     /** The "Boolean" analog of y = alpha * A * x + beta * y, where elements in the
00064         sparsity pattern of the CSR matrix A are treated as "true". */
00065     void hypre_CSRMatrixBooleanMatvec( hypre_CSRMatrix* A,
00066                                        HYPRE_Bool alpha,
00067                                        HYPRE_Bool* x,
00068                                        HYPRE_Bool beta,
00069                                        HYPRE_Bool* y );
00070
00071     hypre_ParCSRCommHandle* hypre_ParCSRCommHandleCreate_bool( HYPRE_Int job,
00072        hypre_ParCSRCommPkg* comm_pkg,
00073        HYPRE_Bool* send_data,
00074        HYPRE_Bool* recv_data );
00075
00076     /** The "Boolean" analog of y = alpha * A * x + beta * y, where elements in the
00077         sparsity pattern of the ParCSR matrix A are treated as "true". */
00078     void hypre_ParCSRMatrixBooleanMatvec( hypre_ParCSRMatrix* A,
00079                                           HYPRE_Bool alpha,
00080                                           HYPRE_Bool* x,
00081                                           HYPRE_Bool beta,
00082                                           HYPRE_Bool* y );
00083
00084 }  // namespace internal
00085
00086 }  // namespace moab
00087
00088 #endif  // MOAB_HAVE_MPI
00089
00090 #endif
