iMeshP_extensions.h
00001 #ifndef IMESHP_REC_CBIND_H__
00002 #define IMESHP_REC_CBIND_H__
00003
00004 #include "iMeshP.h"
00005 #include "iMeshP_protos.h"
00006 #include "moab_mpi.h"
00007
00008 #ifdef __cplusplus
00009 extern "C" {
00010 #endif
00011
00012 /** \brief Convert a fortran to C communicator
00013  * Given a Fortran communicator, convert to a C communicator that can be passed back to iMeshP.
00014  * Though this is an iMeshP function, it doesn't take an iMeshP Partition handle, since the (C)
00015  * communicator is needed by the function that creates the partition.
00016  *  COMMUNICATION:  None.
00017  *
00018  *  \param  instance         (In)  Mesh instance to contain the partition.
00019  *  \param  fcomm            (In)  Pointer to fortran communicator
00020  *  \param  ccomm            (Out) Pointer to the C communicator
00021  *  \param  err              (Out) Error code.
00022  */
00023 void iMeshP_getCommunicator( iMesh_Instance instance, int* fcomm, MPI_Comm* ccomm, int* err );
00024
00025 /** \brief Assign a global id space to entities
00026  * Assign a global id space to entities and vertices, and optionally intermediate-dimension entities
00027  *
00028  *  COMMUNICATION:  Collective.
00029  */
00030 void iMeshP_assignGlobalIds( iMesh_Instance instance,
00031                              const iMeshP_PartitionHandle partition,
00032                              const iBase_EntitySetHandle this_set,
00033                              const int dimension,
00034                              const int start_id,
00035                              const int largest_dim_only,
00036                              const int parallel,
00037                              const int owned_only,
00038                              int* err );
00039
00040 #ifdef __cplusplus
00041 }
00042 #endif
00043
00044 #endif
