ideas_test.cpp File Reference
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "MBTagConventions.hpp"
#include "ReadIDEAS.hpp"
#include "moab/Range.hpp"
#include <cmath>
#include <algorithm>
+ Include dependency graph for ideas_test.cpp:
Defines
#define IS_BUILDING_MB
Functions
void read_file (Interface &moab, const char *input_file)
void test_read_nodes ()
void test_read_tets ()
void test_read_hexes ()
void test_read_material_set ()
void test_read_physical_set ()
int main ()
Variables
static const char example [] = "test.unv"
Define Documentation
Definition at line 4 of file ideas_test.cpp.
Function Documentation
int main ( )
Definition at line 25 of file ideas_test.cpp.
References RUN_TEST, test_read_hexes(), test_read_material_set(), test_read_nodes(), test_read_physical_set(), and test_read_tets().
    int result = 0;
    result += RUN_TEST( test_read_nodes );
    result += RUN_TEST( test_read_tets );
    result += RUN_TEST( test_read_hexes );
    result += RUN_TEST( test_read_material_set );
    result += RUN_TEST( test_read_physical_set );
    return result;
void read_file ( Interface moab,
const char *  input_file
void test_read_hexes ( )
Definition at line 236 of file ideas_test.cpp.
References CHECK_ARRAYS_EQUAL, CHECK_EQUAL, CHECK_ERR, conn, ErrorCode, example, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), moab::Interface::globalId_tag(), MBHEX, read_file(), and moab::Interface::tag_get_data().
Referenced by main().
    ErrorCode rval;
    Core moab;
    Interface& mb = moab;
    read_file( moab, example );
    std::vector< EntityHandle > hexes;
    rval = mb.get_entities_by_type( 0, MBHEX, hexes );CHECK_ERR( rval );
    CHECK_EQUAL( (size_t)2, hexes.size() );
    Tag id_tag = mb.globalId_tag();
    std::vector< int > ids( hexes.size() );
    rval = mb.tag_get_data( id_tag, &hexes[0], hexes.size(), &ids[0] );CHECK_ERR( rval );
    int vtx_ids[8];
    const EntityHandle* conn;
    int len;
    const int conn1[] = { 1, 2, 3, 4, 5, 6, 7, 8 };
    int pos = 0, offset = 1;
    // Element id 1 is a hex
    CHECK_EQUAL( pos + offset, ids[pos] );
    rval = mb.get_connectivity( hexes[pos], conn, len );CHECK_ERR( rval );
    CHECK_EQUAL( 8, len );
    rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval );
    CHECK_ARRAYS_EQUAL( conn1, 8, vtx_ids, len );
    const int conn2[] = { 2, 9, 10, 3, 6, 11, 12, 7 };
    ++pos;
    // Element id 2 is a hex
    CHECK_ARRAYS_EQUAL( conn2, 8, vtx_ids, len );
void test_read_nodes ( )
Definition at line 302 of file ideas_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, example, moab::Range::front(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), MB_TYPE_INTEGER, MBENTITYSET, MBTET, PHYS_PROP_TABLE_TAG, read_file(), moab::Range::size(), and moab::Interface::tag_get_handle().
    ErrorCode rval;
    Core moab;
    Tag phys_tag;
    rval = mb.tag_get_handle( PHYS_PROP_TABLE_TAG, 1, MB_TYPE_INTEGER, phys_tag );CHECK_ERR( rval );
    Range phys_set;
    const int phys_set_id               = 4;
    const void* const phys_set_id_val[] = { &phys_set_id };
    rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &phys_tag, phys_set_id_val, 1, phys_set );CHECK_ERR( rval );
    CHECK_EQUAL( 1, (int)phys_set.size() );
    std::vector< EntityHandle > tets, contents;
    rval = mb.get_entities_by_type( 0, MBTET, tets );CHECK_ERR( rval );
    rval = mb.get_entities_by_handle( phys_set.front(), contents );CHECK_ERR( rval );
    std::sort( tets.begin(), tets.end() );
    std::sort( contents.begin(), contents.end() );
    CHECK_EQUAL( tets, contents );
void test_read_tets ( )
Definition at line 191 of file ideas_test.cpp.
References CHECK_ARRAYS_EQUAL, CHECK_EQUAL, CHECK_ERR, conn, ErrorCode, example, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), moab::Interface::globalId_tag(), MBTET, read_file(), swap(), and moab::Interface::tag_get_data().
    ErrorCode rval;
    Core moab;
    std::vector< EntityHandle > tets;
    CHECK_EQUAL( (size_t)2, tets.size() );
    std::vector< int > ids( tets.size() );
    rval = mb.tag_get_data( id_tag, &tets[0], tets.size(), &ids[0] );CHECK_ERR( rval );
    if( ids[0] != 3 )
        std::swap( ids[0], ids[1] );
        std::swap( tets[0], tets[1] );
    int vtx_ids[4];
    int len;
    // The first tet has id=3
    const int conn1[] = { 13, 14, 15, 16 };
    int pos = 0, offset = 3;
    rval = mb.get_connectivity( tets[pos], conn, len );CHECK_ERR( rval );
    CHECK_EQUAL( 4, len );
    CHECK_ARRAYS_EQUAL( conn1, 4, vtx_ids, len );
    // The second tet has id=4
    const int conn2[] = { 13, 17, 14, 16 };
    ++pos;
    CHECK_ARRAYS_EQUAL( conn2, 4, vtx_ids, len );
Variable Documentation
const char example[] = "test.unv" [static]
Definition at line 15 of file ideas_test.cpp.
