imoab_ptest2.cpp
00001 /*
00002  * imoab_ptest_C.cpp
00003  *
00004  *  push parallel mesh into moab, using iMoab API, C version
00005  *      This program shows how to push a mesh into MOAB in parallel using iMoab, with sufficient
00006  *     information to resolve boundary sharing and exchange a layer of ghost information.
00007  *
00008  *      After resolving the sharing, mesh is saved to a file, then read back again, in parallel
00009  *       the mesh is a quad mesh, 2x2 on each task,
00010  *      by default, this test is run on 2 processors
00011
00012  *      Test is similar to itaps/iMeshP_unit_tests.cpp, and with imoab_ptest.F, fortran 77 version
00013  *
00014  *
00015  *      Create a mesh:
00016  *      Groups of four quads will be arranged into parts as follows:
00017  *      +------+------+------+------+------+-----
00018  *      |             |             |
00019  *      |             |             |
00020  *      +    Part 0   +    Part 2   +    Part 4
00021  *      |             |             |
00022  *      |             |             |
00023  *      +------+------+------+------+------+-----
00024  *      |             |             |
00025  *      |             |             |
00026  *      +    Part 1   +    Part 3   +    Part 5
00027  *      |             |             |
00028  *      |             |             |
00029  *      +------+------+------+------+------+-----
00030  *
00031  *      Vertices will be enumerated as follows:
00032  *      1------6-----11-----16-----21-----26----- > x  x from 0, 1, 2
00033  *      |             |             |
00034  *      |             |             |
00035  *      2      7     12     17     22     27
00036  *      |             |             |
00037  *      |             |             |
00038  *      3------8-----13-----18-----23-----28-----
00039  *      |             |             |
00040  *      |             |             |
00041  *      4      9     14     19     24     29
00042  *      |             |             |
00043  *      |             |             |
00044  *      5-----10-----15-----20-----25-----30-----
00045  *      |
00046  *      y varies from 0 to 4
00047  *
00048  *      Processor 0 will have vertices 1, 2, 3, 6, 7, 8, 11, 12, 13
00049  *        and 4 quads, with ids from 1 to 4, and connectivity
00050  *         1, 2, 7, 6;  2, 3, 8, 7; 6 ,7, 12, 11; 7, 8, 13, 12
00051  *      Processor 1 will have vertices 3, 4, 5, 8, 9, 10, 13, 14, 15
00052  *        and 4 quads, with ids from 5 to 8, and connectivity
00053  *         3, 4, 8, 9;  4, 5, 10, 9; 8, 9, 14, 13; 9, 10, 15, 14,
00054  *      and so on
00055  *
00056  *      Vertex Global IDs will be used to resolve sharing
00057  *
00058  *      Element IDs will be [4*rank+1,4*rank+5]
00059  *      */
00060
00061 /*
00062  * #define ERROR(rval) if (0 .ne. rval) call exit(1)
00063  */
00064
00065 #include "moab/MOABConfig.h"
00066 #include "moab_mpi.h"
00067 #include "moab/iMOAB.h"
00068 #include <cstdio>
00069 #include <cstring>
00070 #include <vector>
00071
00072 #define ERROR( rc, msg )           \
00073     if( 0 != ( rc ) )              \
00074     {                              \
00075         printf( "error %s", msg ); \
00076         return 1;                  \
00077     }
00078
00079 int main( int argc, char** argv )
00080 {
00081     int my_id, num_procs, ix, iy, numv, nume;
00082     int dime, lco, mbtype, blockid, npe;
00083     char appname[10] = "IMTEST";
00084     /* coordinates for 9 vertices */
00085     double coordinates[27], deltax, deltay;
00086     int ids[9]     = { 1, 2, 3, 6, 7, 8, 11, 12, 13 };
00087     int connec[16] = { 1, 2, 5, 4, 2, 3, 6, 5, 4, 5, 8, 7, 5, 6, 9, 8 };
00088     /*      used for ghosting */
00089     int dimgh, bridge, num_layers;
00090     double coords_core[27] = { 0., 0., 0., 0., 1., 0., 0., 2., 0., 1., 0., 0., 1., 1.,
00091                                0., 1., 2., 0., 2., 0., 0., 2., 1., 0., 2., 2., 0. };
00092     int appID, compid;
00093     iMOAB_AppID pid = &appID;
00094
00095     MPI_Init( &argc, &argv );
00096     MPI_Comm comm = MPI_COMM_WORLD;
00097
00098     MPI_Comm_size( comm, &num_procs );
00099     MPI_Comm_rank( comm, &my_id );
00100
00101     ErrCode rc = iMOAB_Initialize( argc, argv );
00102     ERROR( rc, "can't initialize" );
00103     if( !my_id ) printf( " I'm process %d out of %d\n", my_id, num_procs );
00104
00105     appname[7] = 0;  // make sure it is NULL
00106     compid     = 8;  // given number, external application number
00107     rc         = iMOAB_RegisterApplication( appname, &comm, &compid, pid );
00108     ERROR( rc, " can't register app" );
00109     /* create first 9 vertices,  in a square 3x3; */
00110     deltax = ( my_id / 2 ) * 2.;
00111     deltay = ( my_id % 2 ) * 2.;
00112     ix     = ( my_id / 2 ) * 10;
00113     iy     = my_id % 2 * 2;
00114     for( int i = 0; i < 9; i++ )
00115     {
00116         coordinates[3 * i]     = coords_core[3 * i] + deltax;
00117         coordinates[3 * i + 1] = coords_core[3 * i + 1] + deltay;
00118         coordinates[3 * i + 2] = coords_core[3 * i + 2];
00119
00120         /*       translate the ids too, by multiples of 10 or add 2, depending on my_id*/
00121         ids[i] = ids[i] + ix + iy;
00122     }
00123     numv = 9;
00124     nume = 4;
00125     lco  = numv * 3;
00126     dime = 3;
00127     rc   = iMOAB_CreateVertices( pid, &lco, &dime, coordinates );
00128     ERROR( rc, "can't create vertices" );
00129     /* create now 4 quads with those 9 vertices*/
00130     mbtype  = 3;
00131     blockid = 100;
00132     npe     = 4;
00133     rc      = iMOAB_CreateElements( pid, &nume, &mbtype, &npe, connec, &blockid );
00134     ERROR( rc, "can't create elements" );
00135
00136     rc = iMOAB_ResolveSharedEntities( pid, &numv, ids );
00137     ERROR( rc, "can't resolve shared ents" );
00138
00139     // test iMOAB_ReduceTagsMax on a tag
00140     int tagType        = DENSE_DOUBLE;
00141     int num_components = 1;
00142     int tagIndex       = 0;  // output
00143
00144     rc = iMOAB_DefineTagStorage( pid, "afrac:ifrac", &tagType, &num_components, &tagIndex );
00145     ERROR( rc, "failed to create tags afrac:ifrac " );
00146     double af[4] = {1.,1.,1.,1.};
00147     int entType = 1; // cells
00148     rc = iMOAB_SetDoubleTagStorage( pid, "afrac", &nume, &entType, af);
00149     ERROR( rc, "failed to set tag afrac " );
00150     /*     write out the mesh file to disk, in parallel, if h5m*/
00151 #ifdef MOAB_HAVE_HDF5_PARALLEL
00152     char wopts[100]  = "PARALLEL=WRITE_PART";
00153     char outfile[32] = "whole.h5m";
00154     rc               = iMOAB_WriteMesh( pid, outfile, wopts );
00155     ERROR( rc, "can't write mesh" );
00156 #endif
00157
00158     // define repeat tags
00159     rc = iMOAB_DefineTagStorage( pid, "ofrac:afrac:ofrad", &tagType, &num_components, &tagIndex );
00160     ERROR( rc, "failed to create tags ofrac:afrac:ofrad " );
00161
00162     // write again
00163 #ifdef MOAB_HAVE_HDF5_PARALLEL
00164     rc               = iMOAB_WriteMesh( pid, outfile, wopts );
00165     ERROR( rc, "can't write mesh 3\n" );
00166 #endif
00167
00168     tagType = DENSE_INTEGER;
00169     rc = iMOAB_DefineTagStorage( pid, "INTFIELD", &tagType, &num_components, &tagIndex );
00170     ERROR( rc, "failed to get tag INTFIELD " );
00171     // set some values
00172     std::vector< int > valstest( numv );
00173     for( int k = 0; k < numv; k++ )
00174     {
00175         valstest[k] = my_id + k;
00176     }
00177     int num_tag_storage_length = numv * num_components;
00178     entType                = 0;  // vertex
00179     // create an integer tag
00180
00181     rc = iMOAB_SetIntTagStorage( pid, "INTFIELD", &num_tag_storage_length, &entType, &valstest[0] );
00182     ERROR( rc, "failed to set tag INTFIELD " );
00183
00184     rc = iMOAB_ReduceTagsMax( pid, &tagIndex, &entType );
00185     ERROR( rc, "failed reduce tags max " );
00186
00187     /* see ghost elements */
00188    dimgh      = 2; /* will ghost quads, topological dim 2 */
00189    bridge     = 0; /* use vertex as bridge */
00190    num_layers = 1; /* so far, one layer only */
00191    rc         = iMOAB_DetermineGhostEntities( pid, &dimgh, &num_layers, &bridge );
00192    ERROR( rc, "can't determine ghosts" );
00193
00194
00195    /*     write out the mesh file to disk, in parallel, if h5m*/
00196 #ifdef MOAB_HAVE_HDF5_PARALLEL
00197    rc               = iMOAB_WriteMesh( pid, outfile, wopts );
00198    ERROR( rc, "can't write mesh" );
00199 #endif
00200        /*     all done. de-register and finalize */
00201     rc = iMOAB_DeregisterApplication( pid );
00202     ERROR( rc, "can't de-register app" );
00203
00204     rc = iMOAB_Finalize();
00205     ERROR( rc, "can't finalize" );
00206
00207     MPI_Finalize();
00208     return 0;
00209 }
