MOAB: Mesh Oriented datABase
(version 5.3.0)
#include "moab/MOABConfig.h"
#include "moab/iMOAB.h"
#include "TestUtil.hpp"
#include <cstdlib>
#include <cstdio>
#include <cstring>
Defines | |
#define | CHECKRC(rc, message) |
Functions | |
int | main (int argc, char *argv[]) |
#define CHECKRC | ( | rc, | |
message | |||
if( 0 != ( rc ) ) \ { \ printf( "%s", message ); \ return 1; \ }
Definition at line 15 of file imoab_test.cpp.
Referenced by main().
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 22 of file imoab_test.cpp.
References CHECKRC, conn, DENSE_DOUBLE, DENSE_INTEGER, ErrCode, iMOAB_AppID, iMOAB_DefineTagStorage, iMOAB_DeregisterApplication, iMOAB_Finalize, iMOAB_GetBlockElementConnectivities, iMOAB_GetBlockID, iMOAB_GetBlockInfo, iMOAB_GetDoubleTagStorage, iMOAB_GetElementConnectivity, iMOAB_GetElementID, iMOAB_GetElementOwnership, iMOAB_GetIntTagStorage, iMOAB_GetMeshInfo, iMOAB_GetNeighborElements, iMOAB_GetPointerToSurfaceBC, iMOAB_GetPointerToVertexBC, iMOAB_GetVertexID, iMOAB_GetVertexOwnership, iMOAB_GetVisibleElementsInfo, iMOAB_GetVisibleVerticesCoordinates, iMOAB_GlobalID, iMOAB_Initialize(), iMOAB_LoadMesh, iMOAB_LocalID, iMOAB_ReadHeaderInfo, iMOAB_RegisterApplication(), iMOAB_SetGlobalInfo, iMOAB_SynchronizeTags, iMOAB_WriteMesh, MPI_COMM_WORLD, outputFile, and rank.
{ int nprocs = 1, rank = 0; std::string filen; #ifdef MOAB_HAVE_MPI MPI_Init( &argc, &argv ); MPI_Comm comm = MPI_COMM_WORLD; MPI_Comm_size( comm, &nprocs ); MPI_Comm_rank( comm, &rank ); #endif #ifdef MOAB_HAVE_HDF5 filen = TestDir + "/io/p8ex1.h5m"; #endif if( argc > 1 ) filen = std::string( argv[1] ); if( !filen.size() ) return 1; /* * MOAB needs to be initialized; A MOAB instance will be created, and will be used by each * application in this framework. There is no parallel context yet. */ ErrCode rc = iMOAB_Initialize( argc, argv ); CHECKRC( rc, "failed to initialize MOAB" ); int num_global_vertices = 0, num_global_elements = 0, num_dimension = 0, num_parts = 0; /* * Header information is cheap to retrieve from an hdf5 file; it can be called by each process * or can be called by one master task and broadcasted. The hdf5 file has to be in MOAB native * format, and has to be partitioned in advance. There should be at least as many partitions in * the file as number of tasks in the communicator. */ rc = iMOAB_ReadHeaderInfo( filen.c_str(), &num_global_vertices, &num_global_elements, &num_dimension, &num_parts, (int)( filen.size() ) ); CHECKRC( rc, "failed to read header info" ); if( 0 == rank ) { printf( "file %s has %d vertices, %d elements, %d parts in partition\n", filen.c_str(), num_global_vertices, num_global_elements, num_parts ); } int appID, appDupID; iMOAB_AppID pid = &appID; iMOAB_AppID pidDup = &appDupID; /* * Each application has to be registered once. A mesh set and a parallel communicator will be * associated with each application. A unique application id will be returned, and will be used * for all future mesh operations/queries. */ int compid = 11, compdupid = 12; rc = iMOAB_RegisterApplication( "MBAPP", #ifdef MOAB_HAVE_MPI &comm, #endif &compid, pid ); CHECKRC( rc, "failed to register application" ); rc = iMOAB_RegisterApplication( "MBDUPAPP", #ifdef MOAB_HAVE_MPI &comm, #endif &compdupid, pidDup ); CHECKRC( rc, "failed to register duplicate application" ); #ifdef MOAB_HAVE_MPI const char* read_opts = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS"; int num_ghost_layers[1] = { 1 }; #else const char* read_opts = ""; int* num_ghost_layers = nullptr; #endif /* * Loading the mesh is a parallel IO operation. Ghost layers can be exchanged too, and default * MOAB sets are augmented with ghost elements. By convention, blocks correspond to MATERIAL_SET * sets, side sets with NEUMANN_SET sets, node sets with DIRICHLET_SET sets. Each element and * vertex entity should have a GLOBAL ID tag in the file, which will be available for visible * entities */ rc = iMOAB_LoadMesh( pid, filen.c_str(), read_opts, num_ghost_layers, (int)( filen.size() ), strlen( read_opts ) ); CHECKRC( rc, "failed to load mesh" ); rc = iMOAB_LoadMesh( pidDup, filen.c_str(), read_opts, num_ghost_layers, (int)( filen.size() ), strlen( read_opts ) ); CHECKRC( rc, "failed to load mesh" ); rc = iMOAB_SetGlobalInfo( pid, &num_global_vertices, &num_global_elements ); CHECKRC( rc, "failed to set global info" ); int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3]; /* * Each process in the communicator will have access to a local mesh instance, which will * contain the original cells in the local partition and ghost entities. Number of vertices, * primary cells, visible blocks, number of sidesets and nodesets boundary conditions will be * returned in size 3 arrays, for local, ghost and total numbers. */ rc = iMOAB_GetMeshInfo( pid, nverts, nelem, nblocks, nsbc, ndbc ); CHECKRC( rc, "failed to get mesh info" ); iMOAB_GlobalID* vGlobalID = (iMOAB_GlobalID*)malloc( nverts[2] * sizeof( iMOAB_GlobalID ) ); /* * All visible vertices have a unique global ID. All arrays are allocated by client. * Currently, global ID is a 32 bit integer, total number of visible vertices was returned by * iMOAB_GetMeshInfo */ rc = iMOAB_GetVertexID( pid, &nverts[2], vGlobalID ); CHECKRC( rc, "failed to get vertex id info" ); int* vranks = (int*)malloc( nverts[2] * sizeof( int ) ); /* * In MOAB terminology, a vertex can be owned, shared or ghost. An owned vertex will be * owned by the current process. A shared vertex appears at the interface between partitions, it * can be owned by another process, while a ghost vertex is owned by another process always. All * vertex arrays have a natural local order, in which the ghost vertices are at the end of the * arrays. The local index of the vertex will vary from 0 to number of visible vertices (in this * example nverts[2]-1) */ rc = iMOAB_GetVertexOwnership( pid, &nverts[2], vranks ); CHECKRC( rc, "failed to get vertex ranks" ); double* coords = (double*)malloc( 3 * nverts[2] * sizeof( double ) ); int size_coords = 3 * nverts[2]; /* * Coordinates are returned interleaved, for all visible vertices. Size is dimension times * number of visible vertices */ rc = iMOAB_GetVisibleVerticesCoordinates( pid, &size_coords, coords ); CHECKRC( rc, "failed to get coordinates" ); /* * Block IDs correspond to MATERIAL_SET tag values in hdf5 file * They also correspond to block IDs in a Cubit model. * Local visible blocks might contain ghost cells, owned by other * processes. * Inside MOAB, a block will correspond to a meshset with a MATERIAL_SET tag, * with value the block ID. * A MATERIAL_SET tag in moab if SPARSE and type INTEGER. */ iMOAB_GlobalID* gbIDs = (iMOAB_GlobalID*)malloc( nblocks[2] * sizeof( iMOAB_GlobalID ) ); rc = iMOAB_GetBlockID( pid, &nblocks[2], gbIDs ); CHECKRC( rc, "failed to get block info" ); /* * The 2 tags used in this example exist in the file, already. * If a user needs a new tag, it can be defined with the same call as this one * this method, iMOAB_DefineTagStorage, will return a local index for the tag. * The name of the tag is case sensitive. * This method is collective. */ int tagIndex[2]; int entTypes[2] = { 0, 1 }; /* first is on vertex, second is on elements; */ int tagTypes[2] = { DENSE_INTEGER, DENSE_DOUBLE }; int num_components = 1; rc = iMOAB_DefineTagStorage( pid, "INTFIELD", &tagTypes[0], &num_components, &tagIndex[0], strlen( "INTFIELD" ) ); CHECKRC( rc, "failed to get tag INTFIELD " ); rc = iMOAB_DefineTagStorage( pid, "DFIELD", &tagTypes[1], &num_components, &tagIndex[1], strlen( "DFIELD" ) ); CHECKRC( rc, "failed to get tag DFIELD " ); // synchronize one of the tags only, just to see what happens int num_tags_to_sync = 1; /* * tags are not exchanged for ghost entities by default. The user has to explicitly * synchronize them with a call like this one. The tags to synchronize are referenced by the * index returned at their "definition" with iMOAB_DefineTagStorage method. */ rc = iMOAB_SynchronizeTags( pid, &num_tags_to_sync, &tagIndex[0], &tagTypes[0] ); CHECKRC( rc, "failed to sync tag INTFIELD " ); for( int irank = 0; irank < nprocs; irank++ ) { if( irank == rank ) { /* printf some of the block info */ printf( "on rank %d, there are \n" " %3d visible vertices of which %3d local %3d ghost \n" " %3d visible elements of which %3d owned %3d ghost \n" " %3d visible blocks\n" " %3d visible neumann BCs\n" " %3d visible dirichlet BCs\n", rank, nverts[2], nverts[0], nverts[1], nelem[2], nelem[0], nelem[1], nblocks[2], nsbc[2], ndbc[2] ); /* printf some of the vertex id infos */ int numToPrint = nverts[2]; printf( "on rank %d vertex info:\n", rank ); for( int i = 0; i < numToPrint; i++ ) printf( " vertex local id: %3d, rank ID:%d global ID: %3d coords: %g, %g, %g\n", i, vranks[i], vGlobalID[i], coords[3 * i], coords[3 * i + 1], coords[3 * i + 2] ); iMOAB_GlobalID* element_global_IDs = (iMOAB_GlobalID*)malloc( nelem[2] * sizeof( iMOAB_GlobalID ) ); iMOAB_GlobalID* block_IDs = (iMOAB_GlobalID*)malloc( nelem[2] * sizeof( iMOAB_GlobalID ) ); int* ranks = (int*)malloc( nelem[2] * sizeof( int ) ); /* * visible elements info is available for all visible elements, with this call. Similar * information can be retrieved by looping over visible blocks */ rc = iMOAB_GetVisibleElementsInfo( pid, &nelem[2], element_global_IDs, ranks, block_IDs ); CHECKRC( rc, "failed to get all elem info" ); for( int i = 0; i < nelem[2]; i++ ) printf( " element local id: %3d, global ID: %3d rank:%d block ID: %2d \n", i, element_global_IDs[i], ranks[i], block_IDs[i] ); free( element_global_IDs ); free( ranks ); free( block_IDs ); // get first element connectivity int conn[27]; int nv = 27; int eindex = 0; /* * element connectivity can be retrieved for a single element. Local vertex indices are * returned. */ rc = iMOAB_GetElementConnectivity( pid, &eindex, &nv, conn ); CHECKRC( rc, "failed to get first element connectivity" ); printf( " conn for first element: \n" ); for( int i = 0; i < nv; i++ ) printf( " %3d", conn[i] ); printf( "\n" ); // test neighbors int local_index = 0; // test element with local index 0 int num_adjacent_elements = 10; // we can have maximum 6 actually iMOAB_LocalID adjacent_element_IDs[10]; /* * Neighbor elements that share a face with current element can be determined with this * call Elements are identified by their local index */ rc = iMOAB_GetNeighborElements( pid, &local_index, &num_adjacent_elements, adjacent_element_IDs ); CHECKRC( rc, "failed to get first element neighbors" ); printf( " neighbors for first element:\n" ); for( int i = 0; i < num_adjacent_elements; i++ ) { printf( " %4d", adjacent_element_IDs[i] ); } printf( "\n" ); for( int i = 0; i < nblocks[2]; i++ ) { printf( " block index: %3d, block ID: %3d \n", i, gbIDs[i] ); int vertices_per_element, num_elements_in_block; /* * blocks should have the same type of primary elements. Number of elements in block * and number of vertices per element are found with this call. The method refers * only to the visible elements on the process. The block is identified with its * block ID. Should it be identified with its local index in the list of visible * blocks? */ rc = iMOAB_GetBlockInfo( pid, &gbIDs[i], &vertices_per_element, &num_elements_in_block ); CHECKRC( rc, "failed to elem block info" ); printf( " has %4d elements with %d vertices per element\n", num_elements_in_block, vertices_per_element ); int size_conn = num_elements_in_block * vertices_per_element; iMOAB_LocalID* element_connectivity = (iMOAB_LocalID*)malloc( sizeof( iMOAB_LocalID ) * size_conn ); /* * Connectivity for all elements in the block can be determined with this method. * Vertices are identified by their local index (from 0 to number of visible * vertices -1) */ rc = iMOAB_GetBlockElementConnectivities( pid, &gbIDs[i], &size_conn, element_connectivity ); CHECKRC( rc, "failed to get block elem connectivity" ); int* element_ownership = (int*)malloc( sizeof( int ) * num_elements_in_block ); /* * Each element is owned by a particular process. Ownership can be returned for all * elements in a block with this call. */ rc = iMOAB_GetElementOwnership( pid, &gbIDs[i], &num_elements_in_block, element_ownership ); CHECKRC( rc, "failed to get block elem ownership" ); iMOAB_GlobalID* global_element_ID = (iMOAB_GlobalID*)malloc( sizeof( iMOAB_GlobalID ) * num_elements_in_block ); iMOAB_LocalID* local_element_ID = (iMOAB_LocalID*)malloc( sizeof( iMOAB_LocalID ) * num_elements_in_block ); /* * Global element IDs are determined with this call. Local indices within the * process are returned too. */ rc = iMOAB_GetElementID( pid, &gbIDs[i], &num_elements_in_block, global_element_ID, local_element_ID ); CHECKRC( rc, "failed to get block elem IDs" ); for( int j = 0; j < num_elements_in_block; j++ ) { printf( " elem %3d owned by %d gid: %4d lid: %4d -- ", j, element_ownership[j], global_element_ID[j], local_element_ID[j] ); for( int k = 0; k < vertices_per_element; k++ ) printf( " %5d", element_connectivity[j * vertices_per_element + k] ); printf( "\n" ); } free( global_element_ID ); free( local_element_ID ); free( element_connectivity ); free( element_ownership ); } /* * query integer tag values on vertices * this tag was synchronized (see iMOAB_SynchronizeTags above) * Being a dense tag, all visible vertices have a value. * As usual, the client allocates the returned array, which is filled with data with * this call (deep copy) */ int* int_tag_vals = (int*)malloc( sizeof( int ) * nverts[2] ); // for all visible vertices on the rank rc = iMOAB_GetIntTagStorage( pid, "INTFIELD", &nverts[2], &entTypes[0], int_tag_vals, strlen( "INTFIELD" ) ); CHECKRC( rc, "failed to get INTFIELD tag" ); printf( "INTFIELD tag values:\n" ); for( int i = 0; i < nverts[2]; i++ ) { printf( " %4d", int_tag_vals[i] ); if( i % 20 == 19 ) printf( "\n" ); } printf( "\n" ); free( int_tag_vals ); /* * query double tag values on elements * This tag was not synchronized, so ghost elements have a default value of 0. */ double* double_tag_vals = (double*)malloc( sizeof( double ) * nelem[2] ); // for all visible elements on the rank rc = iMOAB_GetDoubleTagStorage( pid, "DFIELD", &nelem[2], &entTypes[1], double_tag_vals, strlen( "DFIELD" ) ); CHECKRC( rc, "failed to get DFIELD tag" ); printf( "DFIELD tag values: (not exchanged) \n" ); for( int i = 0; i < nelem[2]; i++ ) { printf( " %f", double_tag_vals[i] ); if( i % 8 == 7 ) printf( "\n" ); } printf( "\n" ); free( double_tag_vals ); /* query surface BCs */ iMOAB_LocalID* surfBC_ID = (iMOAB_LocalID*)malloc( sizeof( iMOAB_LocalID ) * nsbc[2] ); int* ref_surf = (int*)malloc( sizeof( int ) * nsbc[2] ); int* bc_value = (int*)malloc( sizeof( int ) * nsbc[2] ); /* * Surface boundary condition information is returned for all visible Neumann conditions * the reference surfaces are indexed from 1 to 6 for hexahedrons, 1 to 4 to * tetrahedrons, in the MOAB canonical ordering convention */ rc = iMOAB_GetPointerToSurfaceBC( pid, &nsbc[2], surfBC_ID, ref_surf, bc_value ); CHECKRC( rc, "failed to get surf boundary conditions" ); printf( " Surface boundary conditions:\n" ); for( int i = 0; i < nsbc[2]; i++ ) { printf( " elem_localID %4d side:%d BC:%2d\n", surfBC_ID[i], ref_surf[i], bc_value[i] ); } free( surfBC_ID ); free( ref_surf ); free( bc_value ); /* query vertex BCs */ iMOAB_LocalID* vertBC_ID = (iMOAB_LocalID*)malloc( sizeof( iMOAB_LocalID ) * ndbc[2] ); int* vertBC_value = (int*)malloc( sizeof( int ) * ndbc[2] ); rc = iMOAB_GetPointerToVertexBC( pid, &ndbc[2], vertBC_ID, vertBC_value ); CHECKRC( rc, "failed to get vertex boundary conditions" ); printf( " Vertex boundary conditions:\n" ); for( int i = 0; i < ndbc[2]; i++ ) { printf( " vertex %4d BC:%2d\n", vertBC_ID[i], vertBC_value[i] ); } free( vertBC_ID ); free( vertBC_value ); } #ifdef MOAB_HAVE_MPI MPI_Barrier( comm ); // to avoid printing problems, as we write all procs data #endif } // free allocated data free( coords ); free( vGlobalID ); free( vranks ); char outputFile[] = "fnew.h5m"; #ifdef MOAB_HAVE_MPI char writeOptions[] = "PARALLEL=WRITE_PART"; #else char writeOptions[] = ""; #endif /* * the file can be written in parallel, and it will contain additional tags defined by the user * we may extend the method to write only desired tags to the file */ rc = iMOAB_WriteMesh( pid, outputFile, writeOptions, strlen( outputFile ), strlen( writeOptions ) ); /* * deregistering application will delete all mesh entities associated with the application and * will free allocated tag storage. */ rc = iMOAB_DeregisterApplication( pid ); CHECKRC( rc, "failed to de-register application" ); rc = iMOAB_DeregisterApplication( pidDup ); CHECKRC( rc, "failed to de-register application" ); /* * this method will delete MOAB instance */ rc = iMOAB_Finalize(); CHECKRC( rc, "failed to finalize MOAB" ); #ifdef MOAB_HAVE_MPI MPI_Finalize(); #endif return 0; }
