info.c
00001 #include "mhdf.h"
00002 #include <stdlib.h>
00003 #include <stdio.h>
00004 #include <string.h>
00005 #include <ctype.h>
00006 #include <H5Tpublic.h>
00007
00008 static int print_file_summary( struct mhdf_FileDesc* data );
00009
00010 int main( int argc, char* argv[] )
00011 {
00012     int result;
00013     mhdf_FileHandle file;
00014     mhdf_Status status;
00015     unsigned long max_id;
00016     struct mhdf_FileDesc* data;
00017
00018     if( argc != 2 )
00019     {
00020         fprintf( stderr, "Usage: %s <filename>\n", argv[0] );
00021         return 1;
00022     }
00023
00024     file = mhdf_openFile( argv[1], 0, &max_id, -1, &status );
00025     if( mhdf_isError( &status ) )
00026     {
00027         fprintf( stderr, "%s: %s\n", argv[1], mhdf_message( &status ) );
00028         return 1;
00029     }
00030
00031     data = mhdf_getFileSummary( file, H5T_NATIVE_ULONG, &status, 0 ); /* no extra set info here*/
00032     if( mhdf_isError( &status ) )
00033     {
00034         fprintf( stderr, "%s: %s\n", argv[1], mhdf_message( &status ) );
00035         return 1;
00036     }
00037
00038     mhdf_closeFile( file, &status );
00039
00040     printf( "%s:\n", argv[1] );
00041     result = print_file_summary( data );
00042     free( data );
00043     return result;
00044 }
00045
00046 static void print_ent_desc( const char* name,
00047                             const char* subname,
00048                             struct mhdf_EntDesc* data,
00049                             const char* vals_label,
00050                             const char* extra_label,
00051                             struct mhdf_FileDesc* all )
00052 {
00053     int i, len = 10;
00054
00055     if( vals_label && (int)strlen( vals_label ) > len ) len = strlen( vals_label );
00056     if( extra_label && (int)strlen( extra_label ) > len ) len = strlen( extra_label );
00057
00058     if( subname )
00059         printf( "    %s (%s):\n", name, subname );
00060     else
00061         printf( "    %s:\n", name );
00062
00063     if( vals_label ) printf( "      %-*s: %d\n", len, vals_label, data->vals_per_ent );
00064
00065     printf( "      %-*s: %ld [%ld - %ld]\n", len, "entities", data->count, data->start_id,
00066             data->start_id + data->count - 1 );
00067
00068     if( extra_label ) printf( "      %-*s\n", len, extra_label );
00069
00070     if( !data->num_dense_tags ) return;
00071
00072     printf( "      %-*s: \"%s\"", len, "dense tags", all->tags[data->dense_tag_indices[0]].name );
00073     for( i = 1; i < data->num_dense_tags; ++i )
00074         printf( ", \"%s\"", all->tags[data->dense_tag_indices[i]].name );
00075     printf( "\n" );
00076 }
00077
00078 static void print_elem_desc( struct mhdf_ElemDesc* data, struct mhdf_FileDesc* all )
00079 {
00080     const char* adj = data->have_adj ? "adjacencies" : "no adjencies";
00081     print_ent_desc( data->handle, data->type, &data->desc, "nodes per element", adj, all );
00082 }
00083
00084 static const char* tag_type_name( enum mhdf_TagDataType type )
00085 {
00086     static const char opaque[]  = "opaque";
00087     static const char integer[] = "integer";
00088     static const char real[]    = "real";
00089     static const char bits[]    = "bit field";
00090     static const char boolean[] = "boolean";
00091     static const char id[]      = "entity id";
00092     static const char unknown[] = "(UNKNOWN TYPE ID)";
00093     switch( type )
00094     {
00095         case mhdf_OPAQUE:
00096             return opaque;
00097         case mhdf_INTEGER:
00098             return integer;
00099         case mhdf_FLOAT:
00100             return real;
00101         case mhdf_BITFIELD:
00102             return bits;
00103         case mhdf_BOOLEAN:
00104             return boolean;
00105         case mhdf_ENTITY_ID:
00106             return id;
00107     }
00108     return unknown;
00109 }
00110
00111 static const char* string_tag_value( const void* value, enum mhdf_TagDataType type, int size )
00112 {
00113     static char buffer[1024];
00114     const char* data = value;
00115     char* offset     = buffer;
00116     int print, i;
00117     const int* intptr          = value;
00118     const double* dblptr       = value;
00119     const unsigned long* idptr = value;
00120
00121     if( size <= 0 )
00122     {
00123         *buffer = '\0';
00124         return buffer;
00125     }
00126
00127     switch( type )
00128     {
00129         case mhdf_OPAQUE:
00130             print = 1;
00131             for( i = 0; i < size; ++i )
00132                 if( !isprint( data[i] ) ) print = 0;
00133             if( print )
00134             {
00135                 offset[0] = '"';
00136                 memcpy( offset + 1, data, size );
00137                 offset[size + 1] = '"';
00138                 offset[size + 2] = '\0';
00139                 offset += size + 2;
00140             }
00141             else
00142             {
00143                 strcpy( offset, "0x" );
00144                 offset += 2;
00145                 for( i = 0; i < size; ++i )
00146                     offset += sprintf( offset, "%02x", (unsigned int)data[i] );
00147             }
00148             break;
00149         case mhdf_INTEGER:
00150             if( size == 1 )
00151             {
00152                 offset += sprintf( offset, "%d", intptr[0] );
00153             }
00154             else
00155             {
00156                 offset += sprintf( offset, "{%d", intptr[0] );
00157                 for( i = 1; i < size; ++i )
00158                     offset += sprintf( offset, ",%d", intptr[i] );
00159                 offset += sprintf( offset, "}" );
00160             }
00161             break;
00162         case mhdf_FLOAT:
00163             if( size == 1 )
00164             {
00165                 offset += sprintf( offset, "%g", dblptr[0] );
00166             }
00167             else
00168             {
00169                 offset += sprintf( offset, "{%g", dblptr[0] );
00170                 for( i = 1; i < size; ++i )
00171                     offset += sprintf( offset, ",%g", dblptr[i] );
00172                 offset += sprintf( offset, "}" );
00173             }
00174             break;
00175         case mhdf_BITFIELD:
00176             if( size > 8 )
00177                 offset += sprintf( offset, "(more than 8 bits)" );
00178             else
00179             {
00180                 for( i = size - 1; i >= 0; --i )
00181                     *( offset++ ) = (char)( *data & ( 1 << i ) ? '1' : '0' );
00182                 *offset = '\0';
00183             }
00184             break;
00185         case mhdf_BOOLEAN:
00186             if( size == 1 )
00187             {
00188                 offset += sprintf( offset, "%s", data[0] ? "true" : "false" );
00189             }
00190             else
00191             {
00192                 offset += sprintf( offset, "{%s", data[0] ? "true" : "false" );
00193                 for( i = 1; i < size; ++i )
00194                     offset += sprintf( offset, ",%s", data[i] ? "true" : "false" );
00195                 offset += sprintf( offset, "}" );
00196             }
00197             break;
00198         case mhdf_ENTITY_ID:
00199             if( size == 1 )
00200             {
00201                 offset += sprintf( offset, "%lu", idptr[0] );
00202             }
00203             else
00204             {
00205                 offset += sprintf( offset, "{%lu", idptr[0] );
00206                 for( i = 1; i < size; ++i )
00207                     offset += sprintf( offset, ",%lu", idptr[i] );
00208                 offset += sprintf( offset, "}" );
00209             }
00210             break;
00211         default:
00212             strcpy( buffer, "(unknown data type)" );
00213             break;
00214     }
00215
00216     return buffer;
00217 }
00218
00219 static const char* ent_desc_name( struct mhdf_FileDesc* all, int idx )
00220 {
00221     static const char nodes[]   = "Nodes";
00222     static const char sets[]    = "Sets";
00223     static const char invalid[] = "<INVALID INDEX!>";
00224     if( idx == -2 ) return sets;
00225     if( idx == -1 ) return nodes;
00226     if( idx >= all->num_elem_desc || idx < -2 ) return invalid;
00227     return all->elems[idx].handle;
00228 }
00229
00230 static void print_tag_desc( struct mhdf_TagDesc* data, struct mhdf_FileDesc* all )
00231 {
00232     int i, width = 8;
00233
00234     printf( "    \"%s\":\n", data->name );
00235     printf( "      %-*s: %s\n", width, "type", tag_type_name( data->type ) );
00236     if( data->size < 0 )
00237         printf( "      %-*s: (variable)\n", width, "size" );
00238     else
00239         printf( "      %-*s: %d (%d bytes)\n", width, "size", data->size, data->bytes );
00240     printf( "      %-*s: %x\n", width, "flags", data->storage );
00241     if( data->default_value )
00242         printf( "      %-*s: %s\n", width, "default",
00243                 string_tag_value( data->default_value, data->type, data->default_value_size ) );
00244     if( data->global_value )
00245         printf( "      %-*s: %s\n", width, "mesh val",
00246                 string_tag_value( data->global_value, data->type, data->global_value_size ) );
00247     if( data->have_sparse )
00248     {
00249         printf( "      %-*s: (sparse)", width, "tables" );
00250         for( i = 0; i < data->num_dense_indices; ++i )
00251             printf( ", %s", ent_desc_name( all, data->dense_elem_indices[i] ) );
00252     }
00253     else if( data->num_dense_indices )
00254     {
00255         printf( "      %-*s: %s", width, "tables", ent_desc_name( all, data->dense_elem_indices[0] ) );
00256         for( i = 1; i < data->num_dense_indices; ++i )
00257             printf( ", %s", ent_desc_name( all, data->dense_elem_indices[i] ) );
00258     }
00259     else
00260     {
00261         printf( "      %-*s: (none)", width, "tables" );
00262     }
00263     printf( "\n" );
00264 }
00265
00266 static int print_file_summary( struct mhdf_FileDesc* data )
00267 {
00268     int i;
00269
00270     printf( "  Entities:\n" );
00271     print_ent_desc( "Nodes", NULL, &data->nodes, "dimension", NULL, data );
00272     for( i = 0; i < data->num_elem_desc; ++i )
00273         print_elem_desc( data->elems + i, data );
00274     print_ent_desc( "Sets", NULL, &data->sets, NULL, NULL, data );
00275
00276     printf( "  Tags:\n" );
00277     for( i = 0; i < data->num_tag_desc; ++i )
00278         print_tag_desc( data->tags + i, data );
00279
00280     return 0;
00281 }
