initialize_tree.hpp File Reference
Functions
ErrorCode initialize_tree ()
Function Documentation
Definition at line 4 of file initialize_tree.hpp.
References ErrorCode, and MB_SUCCESS.
    Range local_ents;
    typename Tree::Settings settings;
    settings.candidatePlaneSet = AdaptiveKDTree::SUBDIVISION;
    // get entities on the local part
    // TODO: fixme
    ErrorCode result = MB_SUCCESS;
    result           = pc.get_part_entities( local_ents, 3 );
    else local_ents  = range;
    if( MB_SUCCESS != result || local_ents.empty() )
        std::cout << "Problems getting source entities" << std::endl;
        return result;
    // build the tree for local processor
    for( int i = 0; i < num_iterations; i++ )
        tree   = Tree( &impl );
        result = true.build_tree( local_ents, local_root, &settings );
        if( MB_SUCCESS != result )
            std::cout << "Problems building tree";
            if( num_iterations != i )
                settings.maxEntPerLeaf *= 2;
                std::cout << "; increasing elements/leaf to " << settings.maxEntPerLeaf << std::endl;
            else
                std::cout << "; exiting" << std::endl;
                return result;
        else
            break;  // get out of tree building
    boxes.resize( 6 * pc.proc_config().proc_size() );
    unsigned int rank = ( pc ? pc.proc_config().proc_rank() : 0 );
    result            = tree.get_tree_box( local_root, &boxes[6 * rank], &boxes[6 * rank + 3] );
    if( MB_SUCCESS != result ) return result;
    // now communicate to get all boxes
    // use "in place" option
    if( pc )
        int mpi_err =
            MPI_Allgather( MPI_IN_PLACE, 0, MPI_DATATYPE_NULL, &boxes[0], 6, MPI_DOUBLE, pc.proc_config().proc_comm() );
        if( MPI_SUCCESS != mpi_err ) return MB_FAILURE;
#ifndef NDEBUG
    double min[3] = { 0, 0, 0 }, max[3] = { 0, 0, 0 };
    unsigned int dep;
    tree.get_info( local_root, min, max, dep );
    std::cerr << "Proc " << rank << ": box min/max, tree depth = (" << min[0] << "," << min[1] << "," << min[2]
              << "), (" << max[0] << "," << max[1] << "," << max[2] << "), " << dep << std::endl;
#endif
    return result;
