MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>
#include <sstream>
#include <ctime>
#include <cstdlib>
#include <cstdio>
#include <cstring>
#include "moab/Core.hpp"
#include "moab/IntxMesh/Intx2MeshOnSphere.hpp"
#include "moab/IntxMesh/IntxUtils.hpp"
#include "TestUtil.hpp"
#include "moab/ProgOptions.hpp"
#include <cmath>
Functions | |
int | main (int argc, char *argv[]) |
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 25 of file intx_on_sphere_test.cpp.
References ProgOptions::addOpt(), moab::IntxAreaUtils::area_on_sphere(), moab::Interface::create_meshset(), ErrorCode, moab::Intx2Mesh::FindMaxEdges(), moab::Interface::get_number_entities_by_dimension(), moab::ParallelComm::get_pcomm(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), moab::Interface::load_file(), mb, MB_CHK_ERR, MB_CHK_SET_ERR, MESHSET_SET, MPI_COMM_WORLD, outputFile, ProgOptions::parseCommandLine(), moab::R, rank, moab::IntxUtils::ScaleToRadius(), moab::Intx2Mesh::set_box_error(), moab::Intx2Mesh::set_error_tolerance(), moab::Intx2MeshOnSphere::set_radius_destination_mesh(), moab::Intx2MeshOnSphere::set_radius_source_mesh(), size, moab::Interface::subtract_meshset(), moab::Interface::unite_meshset(), and moab::Interface::write_file().
{ std::string firstModel, secondModel, outputFile; firstModel = TestDir + "unittest/mbcslam/lagrangeHomme.vtk"; secondModel = TestDir + "unittest/mbcslam/eulerHomme.vtk"; ProgOptions opts; opts.addOpt< std::string >( "first,t", "first mesh filename (source)", &firstModel ); opts.addOpt< std::string >( "second,m", "second mesh filename (target)", &secondModel ); opts.addOpt< std::string >( "outputFile,o", "output intersection file", &outputFile ); double R = 1.; // input double epsrel = 1.e-12; double boxeps = 1.e-4; outputFile = "intx.h5m"; opts.addOpt< double >( "radius,R", "radius for model intx", &R ); opts.addOpt< double >( "epsilon,e", "relative error in intx", &epsrel ); opts.addOpt< double >( "boxerror,b", "relative error for box boundaries", &boxeps ); int output_fraction = 0; int write_files_rank = 0; int brute_force = 0; opts.addOpt< int >( "outputFraction,f", "output fraction of areas", &output_fraction ); opts.addOpt< int >( "writeFiles,w", "write files of interest", &write_files_rank ); opts.addOpt< int >( "kdtreeOption,k", "use kd tree for intersection", &brute_force ); opts.parseCommandLine( argc, argv ); int rank = 0, size = 1; #ifdef MOAB_HAVE_MPI MPI_Init( &argc, &argv ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); MPI_Comm_size( MPI_COMM_WORLD, &size ); #endif // check command line arg second grid is red, arrival, first mesh is blue, departure // will will keep the std::string optsRead = ( size == 1 ? "" : std::string( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ) + std::string( ";PARALLEL_RESOLVE_SHARED_ENTS" ) ); // read meshes in 2 file sets ErrorCode rval; Core moab; Interface* mb = &moab; // global EntityHandle sf1, sf2, outputSet; // create meshsets and load files rval = mb->create_meshset( MESHSET_SET, sf1 );MB_CHK_ERR( rval ); rval = mb->create_meshset( MESHSET_SET, sf2 );MB_CHK_ERR( rval ); if( 0 == rank ) std::cout << "Loading mesh file " << firstModel << "\n"; rval = mb->load_file( firstModel.c_str(), &sf1, optsRead.c_str() );MB_CHK_ERR( rval ); if( 0 == rank ) std::cout << "Loading mesh file " << secondModel << "\n"; rval = mb->load_file( secondModel.c_str(), &sf2, optsRead.c_str() );MB_CHK_ERR( rval ); if( 0 == rank ) { std::cout << "Radius: " << R << "\n"; std::cout << "relative eps: " << epsrel << "\n"; std::cout << "box eps: " << boxeps << "\n"; std::cout << " use kd tree for intersection: " << brute_force << "\n"; } rval = mb->create_meshset( MESHSET_SET, outputSet );MB_CHK_ERR( rval ); // fix radius of both meshes, to be consistent with input R rval = moab::IntxUtils::ScaleToRadius( mb, sf1, R );MB_CHK_ERR( rval ); rval = moab::IntxUtils::ScaleToRadius( mb, sf2, R );MB_CHK_ERR( rval ); #if 0 // std::cout << "Fix orientation etc ..\n"; //IntxUtils; those calls do nothing for a good mesh rval = fix_degenerate_quads(mb, sf1);MB_CHK_ERR(rval); rval = fix_degenerate_quads(mb, sf2);MB_CHK_ERR(rval); rval = positive_orientation(mb, sf1, R);MB_CHK_ERR(rval); rval = positive_orientation(mb, sf2, R);MB_CHK_ERR(rval); #endif #ifdef MOAB_HAVE_MPI ParallelComm* pcomm = ParallelComm::get_pcomm( mb, 0 ); #endif Intx2MeshOnSphere worker( mb ); IntxAreaUtils areaAdaptor; worker.set_error_tolerance( R * epsrel ); worker.set_box_error( boxeps ); #ifdef MOAB_HAVE_MPI worker.set_parallel_comm( pcomm ); #endif // worker.SetEntityType(moab::MBQUAD); worker.set_radius_source_mesh( R ); worker.set_radius_destination_mesh( R ); // worker.enable_debug(); rval = worker.FindMaxEdges( sf1, sf2 );MB_CHK_ERR( rval ); EntityHandle covering_set; #ifdef MOAB_HAVE_MPI if( size > 1 ) { Range local_verts; rval = worker.build_processor_euler_boxes( sf2, local_verts );MB_CHK_ERR( rval ); // output also the local_verts if( write_files_rank ) { std::stringstream outf; outf << "second_mesh" << rank << ".h5m"; rval = mb->write_file( outf.str().c_str(), 0, 0, &sf2, 1 );MB_CHK_ERR( rval ); } } if( size > 1 ) { double elapsed = MPI_Wtime(); rval = mb->create_meshset( moab::MESHSET_SET, covering_set );MB_CHK_SET_ERR( rval, "Can't create new set" ); rval = worker.construct_covering_set( sf1, covering_set );MB_CHK_ERR( rval ); // lots of communication if mesh is distributed very differently elapsed = MPI_Wtime() - elapsed; if( 0 == rank ) std::cout << "\nTime to communicate the mesh = " << elapsed << std::endl; // area fraction of the covering set that needed to be communicated from other processors // number of elements in the covering set communicated, compared to total number of elements // in the covering set if( output_fraction ) { EntityHandle comm_set; // set with elements communicated from other tasks rval = mb->create_meshset( MESHSET_SET, comm_set );MB_CHK_ERR( rval ); // see how much more different is compared to sf1 rval = mb->unite_meshset( comm_set, covering_set );MB_CHK_ERR( rval ); // will have to subtract from covering set, initial set // subtract rval = mb->subtract_meshset( comm_set, sf1 );MB_CHK_ERR( rval ); // compute fractions double area_cov_set = areaAdaptor.area_on_sphere( mb, covering_set, R ); assert( area_cov_set > 0 ); double comm_area = areaAdaptor.area_on_sphere( mb, comm_set, R ); // more important is actually the number of elements communicated int num_cov_cells, num_comm_cells; rval = mb->get_number_entities_by_dimension( covering_set, 2, num_cov_cells );MB_CHK_ERR( rval ); rval = mb->get_number_entities_by_dimension( comm_set, 2, num_comm_cells );MB_CHK_ERR( rval ); double fraction_area = comm_area / area_cov_set; double fraction_num_cells = (double)num_comm_cells / num_cov_cells; // determine min, max, average of these fractions double max_fraction_area, max_fraction_num_cells, min_fraction_area, min_fraction_num_cells; double average_fraction_area, average_fraction_num_cells; MPI_Reduce( &fraction_area, &max_fraction_area, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD ); MPI_Reduce( &fraction_num_cells, &max_fraction_num_cells, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD ); MPI_Reduce( &fraction_area, &min_fraction_area, 1, MPI_DOUBLE, MPI_MIN, 0, MPI_COMM_WORLD ); MPI_Reduce( &fraction_num_cells, &min_fraction_num_cells, 1, MPI_DOUBLE, MPI_MIN, 0, MPI_COMM_WORLD ); MPI_Reduce( &fraction_area, &average_fraction_area, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD ); MPI_Reduce( &fraction_num_cells, &average_fraction_num_cells, 1, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD ); average_fraction_area /= size; average_fraction_num_cells /= size; if( rank == 0 ) { std::cout << " fraction area: min: " << min_fraction_area << " max: " << max_fraction_area << " average :" << average_fraction_area << " \n"; std::cout << " fraction num cells: min: " << min_fraction_num_cells << " max: " << max_fraction_num_cells << " average: " << average_fraction_num_cells << " \n"; } } if( write_files_rank ) { std::stringstream cof; cof << "covering_mesh" << rank << ".h5m"; rval = mb->write_file( cof.str().c_str(), 0, 0, &covering_set, 1 );MB_CHK_ERR( rval ); } } else #endif covering_set = sf1; if( 0 == rank ) std::cout << "Computing intersections ..\n"; #ifdef MOAB_HAVE_MPI double elapsed = MPI_Wtime(); #endif if( brute_force ) { rval = worker.intersect_meshes_kdtree( covering_set, sf2, outputSet );MB_CHK_SET_ERR( rval, "failed to intersect meshes with slow method" ); } else { rval = worker.intersect_meshes( covering_set, sf2, outputSet );MB_CHK_SET_ERR( rval, "failed to intersect meshes" ); } #ifdef MOAB_HAVE_MPI elapsed = MPI_Wtime() - elapsed; if( 0 == rank ) std::cout << "\nTime to compute the intersection between meshes = " << elapsed << std::endl; #endif // the output set does not have the intx vertices on the boundary shared, so they will be // duplicated right now we write this file just for checking it looks OK // compute total area with 2 methods // double initial_area = areaAdaptor.area_on_sphere_lHuiller(mb, sf1, R); // double area_method1 = areaAdaptor.area_on_sphere_lHuiller(mb, outputSet, R); // double area_method2 = areaAdaptor.area_on_sphere(mb, outputSet, R); // std::cout << "initial area: " << initial_area << "\n"; // std::cout<< " area with l'Huiller: " << area_method1 << " with Girard: " << area_method2<< // "\n"; std::cout << " relative difference areas " << // fabs(area_method1-area_method2)/area_method1 << "\n"; std::cout << " relative error " << // fabs(area_method1-initial_area)/area_method1 << "\n"; if( write_files_rank ) { std::stringstream outf; outf << "intersect" << rank << ".h5m"; rval = mb->write_file( outf.str().c_str(), 0, 0, &outputSet, 1 ); } double intx_area = areaAdaptor.area_on_sphere( mb, outputSet, R ); double arrival_area = areaAdaptor.area_on_sphere( mb, sf2, R ); std::cout << "On rank : " << rank << " arrival area: " << arrival_area << " intersection area:" << intx_area << " rel error: " << fabs( ( intx_area - arrival_area ) / arrival_area ) << "\n"; #ifdef MOAB_HAVE_MPI #ifdef MOAB_HAVE_HDF5_PARALLEL rval = mb->write_file( outputFile.c_str(), 0, "PARALLEL=WRITE_PART", &outputSet, 1 );MB_CHK_SET_ERR( rval, "failed to write intx file" ); #else // write intx set on rank 0, in serial; we cannot write in parallel if( 0 == rank ) { rval = mb->write_file( outputFile.c_str(), 0, 0, &outputSet, 1 );MB_CHK_SET_ERR( rval, "failed to write intx file" ); } #endif MPI_Finalize(); #else rval = mb->write_file( outputFile.c_str(), 0, 0, &outputSet, 1 );MB_CHK_SET_ERR( rval, "failed to write intx file" ); #endif return 0; }
