laplacian_test.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2004 Sandia Corporation and Argonne National
00005     Laboratory.  Under the terms of Contract DE-AC04-94AL85000
00006     with Sandia Corporation, the U.S. Government retains certain
00007     rights in this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     [email protected], [email protected], [email protected],
00024     [email protected], [email protected], [email protected]
00025
00026   ***************************************************************** */
00027 // -*- Mode : c++; tab-width: 2; c-tab-always-indent: t; indent-tabs-mode: nil; c-basic-offset: 2
00028 // -*-
00029 //
00030 //   SUMMARY:
00031 //     USAGE:
00032 //
00033 // ORIG-DATE: 19-Feb-02 at 10:57:52
00034 //  LAST-MOD: 23-Jul-03 at 18:04:37 by Thomas Leurent
00035 //
00036 //
00037 // DESCRIPTION:
00038 // ============
00039 /*! \file main.cpp
00040
00041 describe main.cpp here
00042
00043  */
00044 // DESCRIP-END.
00045 //
00046
00047 #include <iostream>
00048 using std::cout;
00049 using std::endl;
00050 #include <cstdlib>
00051
00052 #include "Mesquite.hpp"
00053 #include "MsqError.hpp"
00054 #include "MeshImpl.hpp"
00055 #include "Vector3D.hpp"
00056 #include "InstructionQueue.hpp"
00057 #include "PatchData.hpp"
00058 #include "TerminationCriterion.hpp"
00059 #include "QualityAssessor.hpp"
00060 #include "PlanarDomain.hpp"
00061 #include "MsqTimer.hpp"
00062 #include "TestUtil.hpp"
00063
00064 // algorythms
00065 #include "ConditionNumberQualityMetric.hpp"
00066 #include "LInfTemplate.hpp"
00067 #include "SteepestDescent.hpp"
00068 #include "LaplacianSmoother.hpp"
00069 #include "EdgeLengthQualityMetric.hpp"
00070 using namespace MBMesquite;
00071
00072 std::string DEFAULT_INPUT = TestDir + "unittest/mesquite/2D/vtk/quads/untangled/square_quad_2.vtk";
00073
00074 void help( const char* argv0 )
00075 {
00076     std::cerr << "Usage: " << argv0 << " [<input_file>] [<output_file>]" << std::endl
00077               << "  default input file is: " << DEFAULT_INPUT << std::endl
00078               << "  defualt is no output file" << std::endl
00079               << "  Warning: input mesh is assumed to lie in Z=5 plane" << std::endl;
00080     exit( 1 );
00081 }
00082
00083 int main( int argc, char* argv[] )
00084 {
00085     const char* input_file  = DEFAULT_INPUT.c_str();
00086     const char* output_file = NULL;
00087     switch( argc )
00088     {
00089         default:
00090             help( argv[0] );
00091         case 3:
00092             if( !strcmp( argv[2], "-h" ) ) help( argv[0] );
00093             output_file = argv[2];
00094         case 2:
00095             if( !strcmp( argv[1], "-h" ) ) help( argv[0] );
00096             input_file = argv[1];
00097         case 1:;
00098     }
00099
00100     /* Read a VTK Mesh file */
00101     MsqPrintError err( cout );
00102     MBMesquite::MeshImpl mesh;
00103     mesh.read_vtk( input_file, err );
00104     if( err ) return 1;
00105
00106     // creates an intruction queue
00107     InstructionQueue queue1;
00108
00109     // creates a mean ratio quality metric ...
00110     ConditionNumberQualityMetric shape_metric;
00111     EdgeLengthQualityMetric lapl_met;
00112     lapl_met.set_averaging_method( QualityMetric::RMS );
00113
00114     // creates the laplacian smoother  procedures
00115     LaplacianSmoother lapl1;
00116     QualityAssessor stop_qa = QualityAssessor( &shape_metric );
00117     stop_qa.add_quality_assessment( &lapl_met );
00118
00119     //**************Set stopping criterion****************
00120     TerminationCriterion sc2;
00121     sc2.add_iteration_limit( 10 );
00122     if( err ) return 1;
00123     lapl1.set_outer_termination_criterion( &sc2 );
00124
00125     // adds 1 pass of pass1 to mesh_set1
00126     queue1.add_quality_assessor( &stop_qa, err );
00127     if( err ) return 1;
00128     queue1.set_master_quality_improver( &lapl1, err );
00129     if( err ) return 1;
00130     queue1.add_quality_assessor( &stop_qa, err );
00131     if( err ) return 1;
00132     // adds 1 passes of pass2 to mesh_set1
00133     //  mesh_set1.add_quality_pass(pass2);
00134
00135     // writeVtkMesh("original_mesh", mesh, err); MSQ_CHKERR(err);
00136
00137     PlanarDomain plane( Vector3D( 0, 0, 1 ), Vector3D( 0, 0, 5 ) );
00138
00139     // launches optimization on mesh_set1
00140     MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &plane );
00141     Timer t;
00142     queue1.run_instructions( &mesh_and_domain, err );
00143     if( err ) return 1;
00144     double secs = t.since_birth();
00145     std::cout << "Optimization completed in " << secs << " seconds" << std::endl;
00146
00147     if( output_file )
00148     {
00149         mesh.write_vtk( output_file, err );
00150         if( err ) return 1;
00151         std::cout << "Wrote file: " << output_file << std::endl;
00152     }
00153
00154     // check that smoother is working:
00155     // the one free vertex must be at the origin
00156     if( !DEFAULT_INPUT.compare( input_file ) )
00157     {
00158         std::vector< Mesh::VertexHandle > vertices;
00159         mesh.get_all_vertices( vertices, err );
00160         if( err ) return 1;
00161
00162         std::vector< bool > fixed_flags;
00163         mesh.vertices_get_fixed_flag( arrptr( vertices ), fixed_flags, vertices.size(), err );
00164         if( err ) return 1;
00165
00166         // find one free vertex
00167         int idx = -1;
00168         for( unsigned i = 0; i < vertices.size(); ++i )
00169         {
00170             if( fixed_flags[i] == true ) continue;
00171             if( idx != -1 )
00172             {
00173                 std::cerr << "Multiple free vertices in mesh." << std::endl;
00174                 return 1;
00175             }
00176             idx = i;
00177         }
00178
00179         if( idx == -1 )
00180         {
00181             std::cerr << "No free vertex in mesh!!!!!" << std::endl;
00182             return 1;
00183         }
00184
00185         Mesh::VertexHandle vertex = vertices[idx];
00186         MsqVertex coords;
00187         mesh.vertices_get_coordinates( &vertex, &coords, 1, err );
00188         if( err ) return 1;
00189
00190         // calculate distance from origin
00191         double dist = sqrt( coords[0] * coords[0] + coords[1] * coords[1] );
00192         if( dist > 1e-8 )
00193         {
00194             std::cerr << "Free vertex not at origin after Laplace smooth." << std::endl
00195                       << "Expected location: (0,0)" << std::endl
00196                       << "Actual location: (" << coords[0] << "," << coords[1] << ")" << std::endl;
00197             return 2;
00198         }
00199     }
00200
00201     return 0;
00202 }
