mbcn_test.cpp File Reference
#include "TestUtil.hpp"
#include "moab/CN.hpp"
#include "moab/Core.hpp"
+ Include dependency graph for mbcn_test.cpp:
Functions
void test_dimension_pair ()
void test_type_names ()
void test_dimension ()
void test_vertices_per_entity ()
void test_num_sub_entities ()
void test_sub_entity_type_vtx ()
void test_sub_entity_type_edge ()
void test_sub_entity_type_tri ()
void test_sub_entity_type_quad ()
void test_sub_entity_type_tet ()
void test_sub_entity_type_pyr ()
void test_sub_entity_type_pri ()
void test_sub_entity_type_knife ()
void test_sub_entity_type_hex ()
void test_sub_entity_indices_vtx ()
void test_sub_entity_indices_edge ()
void test_sub_entity_indices_tri ()
void test_sub_entity_indices_quad ()
void test_sub_entity_indices_tet ()
void test_sub_entity_indices_pyr ()
void test_sub_entity_indices_pri ()
void test_sub_entity_indices_hex ()
void test_side_number_tri ()
void test_side_number_quad ()
void test_side_number_tet ()
void test_side_number_pyr ()
void test_side_number_pri ()
void test_side_number_hex ()
void test_opposite_side_tri ()
void test_opposite_side_quad ()
void test_opposite_side_tet ()
void test_opposite_side_hex ()
void test_has_mid_nodes (EntityType type)
void test_has_mid_nodes_edge ()
void test_has_mid_nodes_tri ()
void test_has_mid_nodes_quad ()
void test_has_mid_nodes_tet ()
void test_has_mid_nodes_pyr ()
void test_has_mid_nodes_pri ()
void test_has_mid_nodes_knife ()
void test_has_mid_nodes_hex ()
void test_ho_node_parent ()
void test_ho_node_index ()
void test_sub_entity_nodes (EntityType parent, int sub_dimension)
void test_sub_entity_nodes (EntityType parent, int num_nodes, int sub_dimension)
void test_sub_entity_nodes_tri_edges ()
void test_sub_entity_nodes_quad_edges ()
void test_sub_entity_nodes_tet_edges ()
void test_sub_entity_nodes_tet_faces ()
void test_sub_entity_nodes_pyr_edges ()
void test_sub_entity_nodes_pyr_faces ()
void test_sub_entity_nodes_pri_edges ()
void test_sub_entity_nodes_pri_faces ()
void test_sub_entity_nodes_kni_edges ()
void test_sub_entity_nodes_kni_faces ()
void test_sub_entity_nodes_hex_edges ()
void test_sub_entity_nodes_hex_faces ()
void prism_issue ()
void test_wedges ()
int main ()
void do_test_sub_entity_type_2d (EntityType type)
void do_test_sub_entity_type_3d (EntityType type, int num_faces, const EntityType *face_types)
void test_0d_sub_entity_indices (EntityType type, int num_vtx)
void test_1d_sub_entity_indices (EntityType type, int num_edges, const int(*edge_indices)[2])
void test_2d_sub_entity_indices (EntityType type, int num_faces, const int(*face_indices)[5])
void test_elem_as_sub_entity (EntityType type, int dim, int num_vertices)
static void do_test_side_number_1d (EntityType type, int idx)
static void do_test_side_number_2d (EntityType type, int idx)
Variables
const EntityType elem_types [] = { MBTRI, MBQUAD, MBTET, MBPYRAMID, MBPRISM, MBHEX, MBMAXTYPE }
Function Documentation
static void do_test_side_number_1d ( EntityType  type,
int  idx
) [static]
Definition at line 544 of file mbcn_test.cpp.
References CHECK, CHECK_EQUAL, moab::CN::SideNumber(), and moab::CN::SubEntityVertexIndices().
Referenced by test_side_number_hex(), test_side_number_pri(), test_side_number_pyr(), test_side_number_quad(), test_side_number_tet(), and test_side_number_tri().
    // define a random handle list
    const int elem_verts[] = { 7400, 6233, 3027, 0454, 6839, 5391, 7735, 3603 };
    // get side indices
    int side_idx[4] = { 0, 0 };
    CN::SubEntityVertexIndices( type, 1, idx, side_idx );
    // "reversed" and "offset" are the same thing for edges.
    int side_conn[2] = { elem_verts[side_idx[0]], elem_verts[side_idx[1]] };
    int rev_conn[2]  = { elem_verts[side_idx[1]], elem_verts[side_idx[0]] };
    int result_side = -100, result_sense = -100, result_offset = -100;
    int err = CN::SideNumber( type, elem_verts, side_conn, 2, 1, result_side, result_sense, result_offset );
    CHECK_EQUAL( 0, err );
    CHECK_EQUAL( idx, result_side );
    CHECK_EQUAL( 1, result_sense );
    CHECK_EQUAL( 0, result_offset );
    err = CN::SideNumber( type, elem_verts, rev_conn, 2, 1, result_side, result_sense, result_offset );
    CHECK( result_offset == 1 || result_sense == -1 );
static void do_test_side_number_2d ( EntityType  type,
int  idx
) [static]
Definition at line 567 of file mbcn_test.cpp.
References CHECK_EQUAL, moab::CN::SideNumber(), moab::CN::SubEntityType(), moab::CN::SubEntityVertexIndices(), and moab::CN::VerticesPerEntity().
Referenced by test_side_number_hex(), test_side_number_pri(), test_side_number_pyr(), and test_side_number_tet().
    // get side indices
    const int side_size = CN::VerticesPerEntity( CN::SubEntityType( type, 2, idx ) );
    int side_idx[4]     = { 0, 0, 0, 0 };
    CN::SubEntityVertexIndices( type, 2, idx, side_idx );
    // for each possible forward or reverse offset
    for( int rev = -1; rev < 2; rev += 2 )
        for( int off = 0; off < side_size; ++off )
            int side_conn[4];
            side_conn[3] = 0;
            for( int i = 0; i < side_size; ++i )
                side_conn[( side_size + rev * i ) % side_size] = elem_verts[side_idx[( i + off ) % side_size]];
            int err =
                CN::SideNumber( type, elem_verts, side_conn, side_size, 2, result_side, result_sense, result_offset );
            CHECK_EQUAL( rev, result_sense );
            CHECK_EQUAL( off, result_offset );
void do_test_sub_entity_type_2d ( EntityType  type)
Definition at line 299 of file mbcn_test.cpp.
References CHECK_EQUAL, MBEDGE, MBVERTEX, moab::CN::SubEntityType(), and moab::CN::VerticesPerEntity().
Referenced by test_sub_entity_type_quad(), and test_sub_entity_type_tri().
    for( int j = 0; j < CN::VerticesPerEntity( type ); ++j )
        CHECK_EQUAL( MBVERTEX, CN::SubEntityType( type, 0, j ) );
        CHECK_EQUAL( MBEDGE, CN::SubEntityType( type, 1, j ) );
    CHECK_EQUAL( type, CN::SubEntityType( type, 2, 0 ) );
void do_test_sub_entity_type_3d ( EntityType  type,
int  num_faces,
const EntityType *  face_types
Definition at line 309 of file mbcn_test.cpp.
References CHECK_EQUAL, MBEDGE, MBVERTEX, moab::CN::NumSubEntities(), moab::CN::SubEntityType(), and moab::CN::VerticesPerEntity().
Referenced by test_sub_entity_type_hex(), test_sub_entity_type_knife(), test_sub_entity_type_pri(), test_sub_entity_type_pyr(), and test_sub_entity_type_tet().
    for( int j = 0; j < CN::NumSubEntities( type, 1 ); ++j )
    for( int j = 0; j < num_faces; ++j )
        EntityType sub_type = CN::SubEntityType( type, 2, j );
        CHECK_EQUAL( face_types[j], sub_type );
    CHECK_EQUAL( type, CN::SubEntityType( type, 3, 0 ) );
int main ( )
Definition at line 133 of file mbcn_test.cpp.
References prism_issue(), RUN_TEST, test_dimension(), test_dimension_pair(), test_has_mid_nodes_edge(), test_has_mid_nodes_hex(), test_has_mid_nodes_knife(), test_has_mid_nodes_pri(), test_has_mid_nodes_pyr(), test_has_mid_nodes_quad(), test_has_mid_nodes_tet(), test_has_mid_nodes_tri(), test_ho_node_index(), test_ho_node_parent(), test_num_sub_entities(), test_opposite_side_hex(), test_opposite_side_quad(), test_opposite_side_tet(), test_opposite_side_tri(), test_side_number_hex(), test_side_number_pri(), test_side_number_pyr(), test_side_number_quad(), test_side_number_tet(), test_side_number_tri(), test_sub_entity_indices_edge(), test_sub_entity_indices_hex(), test_sub_entity_indices_pri(), test_sub_entity_indices_pyr(), test_sub_entity_indices_quad(), test_sub_entity_indices_tet(), test_sub_entity_indices_tri(), test_sub_entity_indices_vtx(), test_sub_entity_nodes_hex_edges(), test_sub_entity_nodes_hex_faces(), test_sub_entity_nodes_kni_edges(), test_sub_entity_nodes_kni_faces(), test_sub_entity_nodes_pri_edges(), test_sub_entity_nodes_pri_faces(), test_sub_entity_nodes_pyr_edges(), test_sub_entity_nodes_pyr_faces(), test_sub_entity_nodes_quad_edges(), test_sub_entity_nodes_tet_edges(), test_sub_entity_nodes_tet_faces(), test_sub_entity_nodes_tri_edges(), test_sub_entity_type_edge(), test_sub_entity_type_hex(), test_sub_entity_type_knife(), test_sub_entity_type_pri(), test_sub_entity_type_pyr(), test_sub_entity_type_quad(), test_sub_entity_type_tet(), test_sub_entity_type_tri(), test_sub_entity_type_vtx(), test_type_names(), test_vertices_per_entity(), and test_wedges().
    int result = 0;
    result += RUN_TEST( test_dimension_pair );
    result += RUN_TEST( test_type_names );
    result += RUN_TEST( test_dimension );
    result += RUN_TEST( test_vertices_per_entity );
    result += RUN_TEST( test_num_sub_entities );
    result += RUN_TEST( test_sub_entity_type_vtx );
    result += RUN_TEST( test_sub_entity_type_edge );
    result += RUN_TEST( test_sub_entity_type_tri );
    result += RUN_TEST( test_sub_entity_type_quad );
    result += RUN_TEST( test_sub_entity_type_tet );
    result += RUN_TEST( test_sub_entity_type_pyr );
    result += RUN_TEST( test_sub_entity_type_pri );
    result += RUN_TEST( test_sub_entity_type_knife );
    result += RUN_TEST( test_sub_entity_type_hex );
    result += RUN_TEST( test_sub_entity_indices_vtx );
    result += RUN_TEST( test_sub_entity_indices_edge );
    result += RUN_TEST( test_sub_entity_indices_tri );
    result += RUN_TEST( test_sub_entity_indices_quad );
    result += RUN_TEST( test_sub_entity_indices_tet );
    result += RUN_TEST( test_sub_entity_indices_pyr );
    result += RUN_TEST( test_sub_entity_indices_pri );
    result += RUN_TEST( test_sub_entity_indices_hex );
    result += RUN_TEST( test_side_number_tri );
    result += RUN_TEST( test_side_number_quad );
    result += RUN_TEST( test_side_number_tet );
    result += RUN_TEST( test_side_number_pyr );
    result += RUN_TEST( test_side_number_pri );
    result += RUN_TEST( test_side_number_hex );
    result += RUN_TEST( test_opposite_side_tri );
    result += RUN_TEST( test_opposite_side_quad );
    result += RUN_TEST( test_opposite_side_tet );
    result += RUN_TEST( test_opposite_side_hex );
    result += RUN_TEST( test_has_mid_nodes_edge );
    result += RUN_TEST( test_has_mid_nodes_tri );
    result += RUN_TEST( test_has_mid_nodes_quad );
    result += RUN_TEST( test_has_mid_nodes_tet );
    result += RUN_TEST( test_has_mid_nodes_pyr );
    result += RUN_TEST( test_has_mid_nodes_pri );
    result += RUN_TEST( test_has_mid_nodes_knife );
    result += RUN_TEST( test_has_mid_nodes_hex );
    result += RUN_TEST( test_sub_entity_nodes_tri_edges );
    result += RUN_TEST( test_sub_entity_nodes_quad_edges );
    result += RUN_TEST( test_sub_entity_nodes_tet_edges );
    result += RUN_TEST( test_sub_entity_nodes_tet_faces );
    result += RUN_TEST( test_sub_entity_nodes_pyr_edges );
    result += RUN_TEST( test_sub_entity_nodes_pyr_faces );
    result += RUN_TEST( test_sub_entity_nodes_pri_edges );
    result += RUN_TEST( test_sub_entity_nodes_pri_faces );
    result += RUN_TEST( test_sub_entity_nodes_kni_edges );
    result += RUN_TEST( test_sub_entity_nodes_kni_faces );
    result += RUN_TEST( test_sub_entity_nodes_hex_edges );
    result += RUN_TEST( test_sub_entity_nodes_hex_faces );
    result += RUN_TEST( test_ho_node_parent );
    result += RUN_TEST( test_ho_node_index );
    result += RUN_TEST( prism_issue );
    result += RUN_TEST( test_wedges );
    return result;
void prism_issue ( )
Definition at line 1166 of file mbcn_test.cpp.
References MBMesquite::adj(), CHECK, conn, moab::Core::create_element(), moab::Core::create_vertex(), edges, MBMesquite::faces, moab::Core::get_adjacencies(), moab::Core::get_connectivity(), moab::Core::get_entities_by_dimension(), mb, MBPRISM, and n.
Referenced by main().
    moab::Core mb;
    std::vector< moab::EntityHandle > conn;
    double coords[3];
    for( int i = 0; i < 15; ++i )
        moab::EntityHandle h;
        mb.create_vertex( coords, h );
        conn.push_back( h );
    moab::EntityHandle w;
    mb.create_element( moab::MBPRISM, conn.data(), 15, w );
    // this leads to the failure
        std::vector< moab::EntityHandle > adj;
        mb.get_adjacencies( &w, 1, 2, true, adj );
    std::vector< moab::EntityHandle > edges;
    std::vector< moab::EntityHandle > faces;
    mb.get_entities_by_dimension( 0, 1, edges );
    for( const auto& e : edges )
        std::cout << "edge " << e << " connectivity: ";
        mb.get_connectivity( &e, 1, conn );
        for( const auto& n : conn )
            std::cout << n << " ";
        std::cout << "\n";
    mb.get_entities_by_dimension( 0, 2, faces );
    for( const auto& f : faces )
        std::cout << "face " << f << " connectivity: ";
        mb.get_connectivity( &f, 1, conn );
        std::cout << "\n";
    std::vector< moab::EntityHandle > nodes;
    mb.get_entities_by_dimension( 0, 0, nodes );
    for( const auto& n : nodes )
        std::cout << "node " << n << " connection: ";
        adj.clear();
        mb.get_adjacencies( &n, 1, 1, true, adj );
        std::cout << adj.size() << " edges,";
        // there are either 1 or 3 adjacent edges to each vertex (1 for mid edge vertex)
        CHECK( 1 == adj.size() || 3 == adj.size() );
        adj.clear();
        mb.get_adjacencies( &n, 1, 2, true, adj );
        std::cout << adj.size() << " faces,";
        // there are either 2 or 3 adjacent faces to each vertex ( 2 for mid edge evertex)
        CHECK( 2 == adj.size() || 3 == adj.size() );
        adj.clear();
        mb.get_adjacencies( &n, 1, 3, true, adj );
        std::cout << adj.size() << " volumes\n";
void test_0d_sub_entity_indices ( EntityType  type,
int  num_vtx
Definition at line 382 of file mbcn_test.cpp.
References CHECK_EQUAL, and moab::CN::SubEntityVertexIndices().
Referenced by test_sub_entity_indices_edge(), test_sub_entity_indices_hex(), test_sub_entity_indices_pri(), test_sub_entity_indices_pyr(), test_sub_entity_indices_quad(), test_sub_entity_indices_tet(), and test_sub_entity_indices_tri().
    for( int i = 0; i < num_vtx; ++i )
        // zero input array
        int indices[2] = { 0, -100 };
        // check correct results
        CN::SubEntityVertexIndices( type, 0, i, indices );
        CHECK_EQUAL( i, indices[0] );
        // check didn't write past end of array
        CHECK_EQUAL( -100, indices[1] );
void test_1d_sub_entity_indices ( EntityType  type,
int  num_edges,
const int(*)  edge_indices[2]
Definition at line 396 of file mbcn_test.cpp.
Referenced by test_sub_entity_indices_hex(), test_sub_entity_indices_pri(), test_sub_entity_indices_pyr(), test_sub_entity_indices_quad(), test_sub_entity_indices_tet(), and test_sub_entity_indices_tri().
    for( int i = 0; i < num_edges; ++i )
        // zero input array
        int indices[3] = { 0, 0, -99 };
        CN::SubEntityVertexIndices( type, 1, i, indices );
        if( edge_indices[i][0] == indices[0] )
            CHECK_EQUAL( edge_indices[i][1], indices[1] );
        else
            CHECK_EQUAL( edge_indices[i][0], indices[1] );
            CHECK_EQUAL( edge_indices[i][1], indices[0] );
        CHECK_EQUAL( -99, indices[2] );
void test_2d_sub_entity_indices ( EntityType  type,
int  num_faces,
const int(*)  face_indices[5]
Definition at line 418 of file mbcn_test.cpp.
References CHECK, CHECK_EQUAL, and moab::CN::SubEntityVertexIndices().
Referenced by test_sub_entity_indices_hex(), test_sub_entity_indices_pri(), test_sub_entity_indices_pyr(), and test_sub_entity_indices_tet().
    for( int i = 0; i < num_faces; ++i )
        // zero input array
        int indices[5] = { 0, 0, 0, -99, -99 };
        CN::SubEntityVertexIndices( type, 2, i, indices );
        const int num_vtx = face_indices[i][0];
        if( num_vtx != 3 ) CHECK_EQUAL( 4, num_vtx );
        const int* exp_index = face_indices[i] + 1;
        int off              = std::find( indices, indices + num_vtx, exp_index[0] ) - indices;
        CHECK( off < num_vtx );
        /* Expect faces to be ordered such that CCW normal is outwards
      bool reverse = indices[(off+num_vtx-1)%num_vtx] == exp_index[1];
      if (reverse) {
        CHECK_EQUAL( exp_index[1], indices[(off+num_vtx-1)%num_vtx] );
        CHECK_EQUAL( exp_index[2], indices[(off+num_vtx-2)%num_vtx] );
        if (num_vtx == 4)
          CHECK_EQUAL( exp_index[3], indices[(off+num_vtx-3)%num_vtx] );
      else {
        CHECK_EQUAL( exp_index[1], indices[( off + 1 ) % num_vtx] );
        CHECK_EQUAL( exp_index[2], indices[( off + 2 ) % num_vtx] );
        if( num_vtx == 4 ) CHECK_EQUAL( exp_index[3], indices[( off + 3 ) % num_vtx] );
        if( num_vtx == 3 ) CHECK_EQUAL( -99, indices[3] );
        CHECK_EQUAL( -99, indices[4] );
void test_dimension ( )
Definition at line 235 of file mbcn_test.cpp.
References CHECK_EQUAL, moab::CN::Dimension(), MBEDGE, MBHEX, MBKNIFE, MBPOLYGON, MBPOLYHEDRON, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, and MBVERTEX.
    CHECK_EQUAL( 0, CN::Dimension( MBVERTEX ) );
    CHECK_EQUAL( 1, CN::Dimension( MBEDGE ) );
    CHECK_EQUAL( 2, CN::Dimension( MBTRI ) );
    CHECK_EQUAL( 2, CN::Dimension( MBQUAD ) );
    CHECK_EQUAL( 2, CN::Dimension( MBPOLYGON ) );
    CHECK_EQUAL( 3, CN::Dimension( MBTET ) );
    CHECK_EQUAL( 3, CN::Dimension( MBPYRAMID ) );
    CHECK_EQUAL( 3, CN::Dimension( MBPRISM ) );
    CHECK_EQUAL( 3, CN::Dimension( MBKNIFE ) );
    CHECK_EQUAL( 3, CN::Dimension( MBHEX ) );
    CHECK_EQUAL( 3, CN::Dimension( MBPOLYHEDRON ) );
Definition at line 205 of file mbcn_test.cpp.
References CHECK_EQUAL, MBEDGE, MBPOLYGON, MBPOLYHEDRON, MBTET, MBTRI, MBVERTEX, and moab::CN::TypeDimensionMap.
    DimensionPair dp;
    dp = CN::TypeDimensionMap[0];
    CHECK_EQUAL( MBVERTEX, dp.first );
    CHECK_EQUAL( MBVERTEX, dp.second );
    dp = CN::TypeDimensionMap[1];
    CHECK_EQUAL( MBEDGE, dp.first );
    CHECK_EQUAL( MBEDGE, dp.second );
    dp = CN::TypeDimensionMap[2];
    CHECK_EQUAL( MBTRI, dp.first );
    CHECK_EQUAL( MBPOLYGON, dp.second );
    dp = CN::TypeDimensionMap[3];
    CHECK_EQUAL( MBTET, dp.first );
    CHECK_EQUAL( MBPOLYHEDRON, dp.second );
void test_elem_as_sub_entity ( EntityType  type,
int  dim,
int  num_vertices
Definition at line 455 of file mbcn_test.cpp.
Referenced by test_sub_entity_indices_edge(), test_sub_entity_indices_hex(), test_sub_entity_indices_pri(), test_sub_entity_indices_pyr(), test_sub_entity_indices_quad(), test_sub_entity_indices_tet(), test_sub_entity_indices_tri(), and test_sub_entity_indices_vtx().
    int indices[9] = { -2, -2, -2, -2, -2, -2, -2, -2, -2 };
    CN::SubEntityVertexIndices( type, dim, 0, indices );
    for( int i = 0; i < num_vertices; ++i )
        CHECK_EQUAL( i, indices[i] );
    // make sure didn't write past end
    CHECK_EQUAL( -2, indices[num_vertices] );
void test_has_mid_nodes ( EntityType  type)
Definition at line 884 of file mbcn_test.cpp.
References CHECK_EQUAL, dim, moab::CN::Dimension(), moab::CN::HasMidEdgeNodes(), moab::CN::HasMidFaceNodes(), moab::CN::HasMidNodes(), moab::CN::HasMidRegionNodes(), moab::CN::NumSubEntities(), and moab::CN::VerticesPerEntity().
Referenced by test_has_mid_nodes_edge(), test_has_mid_nodes_hex(), test_has_mid_nodes_knife(), test_has_mid_nodes_pri(), test_has_mid_nodes_pyr(), test_has_mid_nodes_quad(), test_has_mid_nodes_tet(), and test_has_mid_nodes_tri().
    const int combinations[][4] = { { 0, 0, 0, 0 }, { 0, 1, 0, 0 }, { 0, 0, 1, 0 }, { 0, 1, 1, 0 },
                                    { 0, 0, 0, 1 }, { 0, 1, 0, 1 }, { 0, 0, 1, 1 }, { 0, 1, 1, 1 } };
    const int dim = CN::Dimension( type );
    // calculate number of valid combinations of ho node flags
    int num_comb = 1;
    for( int i = 0; i < dim; ++i )
        num_comb *= 2;
    // for each valid combination
    for( int c = 0; c < num_comb; ++c )
        // calculate corresponding number of vertices in element
        const int* ho_nodes = combinations[c];
        int num_vtx         = CN::VerticesPerEntity( type );
        switch( dim )
            case 3:
            case 2:
                // extra clauses to avoid fall-through error
                if( 3 == dim && ho_nodes[2] ) num_vtx += CN::NumSubEntities( type, 2 );
                if( 2 <= dim && ho_nodes[1] ) num_vtx += CN::NumSubEntities( type, 1 );
        if( ho_nodes[dim] ) ++num_vtx;
        CHECK_EQUAL( ho_nodes[1], (int)CN::HasMidEdgeNodes( type, num_vtx ) );
        CHECK_EQUAL( ho_nodes[2], (int)CN::HasMidFaceNodes( type, num_vtx ) );
        CHECK_EQUAL( ho_nodes[3], (int)CN::HasMidRegionNodes( type, num_vtx ) );
        int results[4] = { 0, -1, -1, -1 };
        CN::HasMidNodes( type, num_vtx, results );
        CHECK_EQUAL( 0, !!results[0] );
        CHECK_EQUAL( ho_nodes[1], !!results[1] );
        CHECK_EQUAL( ho_nodes[2], !!results[2] );
        CHECK_EQUAL( ho_nodes[3], !!results[3] );
Definition at line 44 of file mbcn_test.cpp.
References MBEDGE, and test_has_mid_nodes().
Definition at line 72 of file mbcn_test.cpp.
References MBHEX, and test_has_mid_nodes().
Definition at line 68 of file mbcn_test.cpp.
References MBKNIFE, and test_has_mid_nodes().
Definition at line 64 of file mbcn_test.cpp.
References MBPRISM, and test_has_mid_nodes().
Definition at line 60 of file mbcn_test.cpp.
References MBPYRAMID, and test_has_mid_nodes().
Definition at line 52 of file mbcn_test.cpp.
References MBQUAD, and test_has_mid_nodes().
Definition at line 56 of file mbcn_test.cpp.
References MBTET, and test_has_mid_nodes().
Definition at line 48 of file mbcn_test.cpp.
References MBTRI, and test_has_mid_nodes().
Definition at line 991 of file mbcn_test.cpp.
References CHECK_EQUAL, dim, moab::CN::Dimension(), elem_types, moab::CN::HONodeIndex(), MBMAXTYPE, moab::CN::NumSubEntities(), t, and moab::CN::VerticesPerEntity().
    for( const EntityType* t = elem_types; *t != MBMAXTYPE; ++t )
        const EntityType type = *t;
        int num_comb = 1;
            num_comb *= 2;
            switch( dim )
                case 3:
                case 2:
            // start at first higher-order node
            int pos = CN::VerticesPerEntity( type );
            // check mid-edge
            if( dim > 1 && ho_nodes[1] )
                for( int i = 0; i < CN::NumSubEntities( type, 1 ); ++i )
                    int idx = CN::HONodeIndex( type, num_vtx, 1, i );
                    CHECK_EQUAL( pos++, idx );
            // check mid-face
            if( dim > 2 && ho_nodes[2] )
                for( int i = 0; i < CN::NumSubEntities( type, 2 ); ++i )
                    int idx = CN::HONodeIndex( type, num_vtx, 2, i );
            // check mid-volume
            if( ho_nodes[dim] )
                int idx = CN::HONodeIndex( type, num_vtx, dim, 0 );
        }  // for ho_node combinatinos
    }      // for each type
Definition at line 923 of file mbcn_test.cpp.
References CHECK_EQUAL, dim, moab::CN::Dimension(), elem_types, moab::CN::HONodeParent(), MBMAXTYPE, moab::CN::NumSubEntities(), t, and moab::CN::VerticesPerEntity().
        int num_comb = 1;
            num_comb *= 2;
            switch( dim )
                case 3:
                case 2:
            // check mid-edge
                    int pdim = -1, pidx = -1;
                    CN::HONodeParent( type, num_vtx, pos++, pdim, pidx );
                    CHECK_EQUAL( 1, pdim );
                    CHECK_EQUAL( i, pidx );
            // check mid-face
                    CHECK_EQUAL( 2, pdim );
            // check mid-volume
            if( ho_nodes[dim] )
                CHECK_EQUAL( dim, pdim );
                CHECK_EQUAL( 0, pidx );
    }      // for each type
Definition at line 263 of file mbcn_test.cpp.
References CHECK_EQUAL, MBEDGE, MBHEX, MBKNIFE, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, MBVERTEX, and moab::CN::NumSubEntities().
    CHECK_EQUAL( 1, CN::NumSubEntities( MBVERTEX, 0 ) );
    CHECK_EQUAL( 2, CN::NumSubEntities( MBEDGE, 0 ) );
    CHECK_EQUAL( 1, CN::NumSubEntities( MBEDGE, 1 ) );
    CHECK_EQUAL( 3, CN::NumSubEntities( MBTRI, 0 ) );
    CHECK_EQUAL( 3, CN::NumSubEntities( MBTRI, 1 ) );
    CHECK_EQUAL( 1, CN::NumSubEntities( MBTRI, 2 ) );
    CHECK_EQUAL( 4, CN::NumSubEntities( MBQUAD, 0 ) );
    CHECK_EQUAL( 4, CN::NumSubEntities( MBQUAD, 1 ) );
    CHECK_EQUAL( 1, CN::NumSubEntities( MBQUAD, 2 ) );
    CHECK_EQUAL( 4, CN::NumSubEntities( MBTET, 0 ) );
    CHECK_EQUAL( 6, CN::NumSubEntities( MBTET, 1 ) );
    CHECK_EQUAL( 4, CN::NumSubEntities( MBTET, 2 ) );
    CHECK_EQUAL( 5, CN::NumSubEntities( MBPYRAMID, 0 ) );
    CHECK_EQUAL( 8, CN::NumSubEntities( MBPYRAMID, 1 ) );
    CHECK_EQUAL( 5, CN::NumSubEntities( MBPYRAMID, 2 ) );
    CHECK_EQUAL( 6, CN::NumSubEntities( MBPRISM, 0 ) );
    CHECK_EQUAL( 9, CN::NumSubEntities( MBPRISM, 1 ) );
    CHECK_EQUAL( 5, CN::NumSubEntities( MBPRISM, 2 ) );
    CHECK_EQUAL( 7, CN::NumSubEntities( MBKNIFE, 0 ) );
    CHECK_EQUAL( 10, CN::NumSubEntities( MBKNIFE, 1 ) );
    CHECK_EQUAL( 5, CN::NumSubEntities( MBKNIFE, 2 ) );
    CHECK_EQUAL( 8, CN::NumSubEntities( MBHEX, 0 ) );
    CHECK_EQUAL( 12, CN::NumSubEntities( MBHEX, 1 ) );
    CHECK_EQUAL( 6, CN::NumSubEntities( MBHEX, 2 ) );
Definition at line 772 of file mbcn_test.cpp.
References CHECK_EQUAL, dim, MBHEX, and moab::CN::OppositeSide().
    int idx, dim, err;
    err = CN::OppositeSide( MBHEX, 0, 0, idx, dim );
    CHECK_EQUAL( 0, dim );
    CHECK_EQUAL( 6, idx );
    err = CN::OppositeSide( MBHEX, 1, 0, idx, dim );
    CHECK_EQUAL( 7, idx );
    err = CN::OppositeSide( MBHEX, 2, 0, idx, dim );
    CHECK_EQUAL( 4, idx );
    err = CN::OppositeSide( MBHEX, 3, 0, idx, dim );
    CHECK_EQUAL( 5, idx );
    err = CN::OppositeSide( MBHEX, 4, 0, idx, dim );
    CHECK_EQUAL( 2, idx );
    err = CN::OppositeSide( MBHEX, 5, 0, idx, dim );
    CHECK_EQUAL( 3, idx );
    err = CN::OppositeSide( MBHEX, 6, 0, idx, dim );
    CHECK_EQUAL( 0, idx );
    err = CN::OppositeSide( MBHEX, 7, 0, idx, dim );
    CHECK_EQUAL( 1, idx );
    err = CN::OppositeSide( MBHEX, 0, 1, idx, dim );
    CHECK_EQUAL( 1, dim );
    CHECK_EQUAL( 10, idx );
    err = CN::OppositeSide( MBHEX, 1, 1, idx, dim );
    CHECK_EQUAL( 11, idx );
    err = CN::OppositeSide( MBHEX, 2, 1, idx, dim );
    CHECK_EQUAL( 8, idx );
    err = CN::OppositeSide( MBHEX, 3, 1, idx, dim );
    CHECK_EQUAL( 9, idx );
    err = CN::OppositeSide( MBHEX, 4, 1, idx, dim );
    err = CN::OppositeSide( MBHEX, 5, 1, idx, dim );
    err = CN::OppositeSide( MBHEX, 6, 1, idx, dim );
    err = CN::OppositeSide( MBHEX, 7, 1, idx, dim );
    err = CN::OppositeSide( MBHEX, 8, 1, idx, dim );
    err = CN::OppositeSide( MBHEX, 9, 1, idx, dim );
    err = CN::OppositeSide( MBHEX, 10, 1, idx, dim );
    err = CN::OppositeSide( MBHEX, 11, 1, idx, dim );
    err = CN::OppositeSide( MBHEX, 0, 2, idx, dim );
    CHECK_EQUAL( 2, dim );
    err = CN::OppositeSide( MBHEX, 1, 2, idx, dim );
    err = CN::OppositeSide( MBHEX, 2, 2, idx, dim );
    err = CN::OppositeSide( MBHEX, 3, 2, idx, dim );
    err = CN::OppositeSide( MBHEX, 4, 2, idx, dim );
    err = CN::OppositeSide( MBHEX, 5, 2, idx, dim );
Definition at line 670 of file mbcn_test.cpp.
References CHECK_EQUAL, dim, MBQUAD, and moab::CN::OppositeSide().
    int idx, dim, err;
    err = CN::OppositeSide( MBQUAD, 0, 0, idx, dim );
    err = CN::OppositeSide( MBQUAD, 1, 0, idx, dim );
    err = CN::OppositeSide( MBQUAD, 2, 0, idx, dim );
    err = CN::OppositeSide( MBQUAD, 3, 0, idx, dim );
    err = CN::OppositeSide( MBQUAD, 0, 1, idx, dim );
    err = CN::OppositeSide( MBQUAD, 1, 1, idx, dim );
    err = CN::OppositeSide( MBQUAD, 2, 1, idx, dim );
    err = CN::OppositeSide( MBQUAD, 3, 1, idx, dim );
Definition at line 708 of file mbcn_test.cpp.
References CHECK_EQUAL, dim, MBTET, and moab::CN::OppositeSide().
    int idx, dim, err;
    err = CN::OppositeSide( MBTET, 0, 0, idx, dim );
    err = CN::OppositeSide( MBTET, 1, 0, idx, dim );
    err = CN::OppositeSide( MBTET, 2, 0, idx, dim );
    err = CN::OppositeSide( MBTET, 3, 0, idx, dim );
    err = CN::OppositeSide( MBTET, 0, 2, idx, dim );
    err = CN::OppositeSide( MBTET, 1, 2, idx, dim );
    err = CN::OppositeSide( MBTET, 2, 2, idx, dim );
    err = CN::OppositeSide( MBTET, 3, 2, idx, dim );
    err = CN::OppositeSide( MBTET, 0, 1, idx, dim );
    err = CN::OppositeSide( MBTET, 1, 1, idx, dim );
    err = CN::OppositeSide( MBTET, 2, 1, idx, dim );
    err = CN::OppositeSide( MBTET, 3, 1, idx, dim );
    err = CN::OppositeSide( MBTET, 4, 1, idx, dim );
    err = CN::OppositeSide( MBTET, 5, 1, idx, dim );
Definition at line 641 of file mbcn_test.cpp.
References CHECK_EQUAL, dim, MBTRI, and moab::CN::OppositeSide().
    int idx, dim, err;
    err = CN::OppositeSide( MBTRI, 0, 0, idx, dim );
    err = CN::OppositeSide( MBTRI, 1, 0, idx, dim );
    err = CN::OppositeSide( MBTRI, 2, 0, idx, dim );
    err = CN::OppositeSide( MBTRI, 0, 1, idx, dim );
    err = CN::OppositeSide( MBTRI, 1, 1, idx, dim );
    err = CN::OppositeSide( MBTRI, 2, 1, idx, dim );
Definition at line 633 of file mbcn_test.cpp.
References do_test_side_number_1d(), do_test_side_number_2d(), and MBHEX.
    for( int edge = 0; edge < 12; ++edge )
        do_test_side_number_1d( MBHEX, edge );
    for( int face = 0; face < 6; ++face )
        do_test_side_number_2d( MBHEX, face );
Definition at line 625 of file mbcn_test.cpp.
References do_test_side_number_1d(), do_test_side_number_2d(), and MBPRISM.
    for( int edge = 0; edge < 9; ++edge )
        do_test_side_number_1d( MBPRISM, edge );
    for( int face = 0; face < 5; ++face )
        do_test_side_number_2d( MBPRISM, face );
Definition at line 617 of file mbcn_test.cpp.
References do_test_side_number_1d(), do_test_side_number_2d(), and MBPYRAMID.
    for( int edge = 0; edge < 8; ++edge )
        do_test_side_number_1d( MBPYRAMID, edge );
        do_test_side_number_2d( MBPYRAMID, face );
Definition at line 603 of file mbcn_test.cpp.
References do_test_side_number_1d(), and MBQUAD.
    for( int side = 0; side < 4; ++side )
        do_test_side_number_1d( MBQUAD, side );
Definition at line 609 of file mbcn_test.cpp.
References do_test_side_number_1d(), do_test_side_number_2d(), and MBTET.
    for( int edge = 0; edge < 6; ++edge )
        do_test_side_number_1d( MBTET, edge );
    for( int face = 0; face < 4; ++face )
        do_test_side_number_2d( MBTET, face );
Definition at line 597 of file mbcn_test.cpp.
References do_test_side_number_1d(), and MBTRI.
    for( int side = 0; side < 3; ++side )
        do_test_side_number_1d( MBTRI, side );
Definition at line 530 of file mbcn_test.cpp.
References edges, MBMesquite::faces, MBHEX, test_0d_sub_entity_indices(), test_1d_sub_entity_indices(), test_2d_sub_entity_indices(), and test_elem_as_sub_entity().
    const EntityType type = MBHEX;
    const int num_vtx     = 8;
    const int edges[][2]  = { { 0, 1 }, { 1, 2 }, { 2, 3 }, { 3, 0 }, { 0, 4 }, { 1, 5 },
                             { 2, 6 }, { 3, 7 }, { 4, 5 }, { 5, 6 }, { 6, 7 }, { 7, 4 } };
    const int faces[][5]  = { { 4, 0, 1, 5, 4 }, { 4, 1, 2, 6, 5 }, { 4, 2, 3, 7, 6 },
                             { 4, 3, 0, 4, 7 }, { 4, 3, 2, 1, 0 }, { 4, 4, 5, 6, 7 } };
    test_0d_sub_entity_indices( type, num_vtx );
    test_1d_sub_entity_indices( type, sizeof( edges ) / sizeof( edges[0] ), edges );
    test_2d_sub_entity_indices( type, sizeof( faces ) / sizeof( faces[0] ), faces );
    test_elem_as_sub_entity( type, 3, num_vtx );
Definition at line 517 of file mbcn_test.cpp.
References edges, MBMesquite::faces, MBPRISM, test_0d_sub_entity_indices(), test_1d_sub_entity_indices(), test_2d_sub_entity_indices(), and test_elem_as_sub_entity().
    const EntityType type = MBPRISM;
    const int num_vtx     = 6;
    const int edges[][2] = { { 0, 1 }, { 1, 2 }, { 2, 0 }, { 0, 3 }, { 1, 4 }, { 2, 5 }, { 3, 4 }, { 4, 5 }, { 5, 3 } };
        { 4, 0, 1, 4, 3 }, { 4, 1, 2, 5, 4 }, { 4, 2, 0, 3, 5 }, { 3, 2, 1, 0, 0 }, { 3, 3, 4, 5, 0 } };
Definition at line 504 of file mbcn_test.cpp.
References edges, MBMesquite::faces, MBPYRAMID, test_0d_sub_entity_indices(), test_1d_sub_entity_indices(), test_2d_sub_entity_indices(), and test_elem_as_sub_entity().
    const EntityType type = MBPYRAMID;
    const int num_vtx     = 5;
    const int edges[][2]  = { { 0, 1 }, { 1, 2 }, { 2, 3 }, { 3, 0 }, { 0, 4 }, { 1, 4 }, { 2, 4 }, { 3, 4 } };
        { 3, 0, 1, 4, 0 }, { 3, 1, 2, 4, 0 }, { 3, 2, 3, 4, 0 }, { 3, 3, 0, 4, 0 }, { 4, 3, 2, 1, 0 } };
Definition at line 484 of file mbcn_test.cpp.
References edges, MBQUAD, test_0d_sub_entity_indices(), test_1d_sub_entity_indices(), and test_elem_as_sub_entity().
    const int edges[4][2] = { { 0, 1 }, { 1, 2 }, { 2, 3 }, { 3, 0 } };
    test_0d_sub_entity_indices( MBQUAD, 4 );
    test_1d_sub_entity_indices( MBQUAD, 4, edges );
    test_elem_as_sub_entity( MBQUAD, 2, 4 );
Definition at line 492 of file mbcn_test.cpp.
References edges, MBMesquite::faces, MBTET, test_0d_sub_entity_indices(), test_1d_sub_entity_indices(), test_2d_sub_entity_indices(), and test_elem_as_sub_entity().
    const EntityType type = MBTET;
    const int num_vtx     = 4;
    const int edges[][2]  = { { 0, 1 }, { 1, 2 }, { 2, 0 }, { 0, 3 }, { 1, 3 }, { 2, 3 } };
    const int faces[][5]  = { { 3, 0, 1, 3, 0 }, { 3, 1, 2, 3, 0 }, { 3, 2, 0, 3, 0 }, { 3, 2, 1, 0, 0 } };
Definition at line 476 of file mbcn_test.cpp.
References edges, MBTRI, test_0d_sub_entity_indices(), test_1d_sub_entity_indices(), and test_elem_as_sub_entity().
    const int edges[3][2] = { { 0, 1 }, { 1, 2 }, { 2, 0 } };
    test_0d_sub_entity_indices( MBTRI, 3 );
    test_1d_sub_entity_indices( MBTRI, 3, edges );
    test_elem_as_sub_entity( MBTRI, 2, 3 );
Definition at line 465 of file mbcn_test.cpp.
References MBVERTEX, and test_elem_as_sub_entity().
void test_sub_entity_nodes ( EntityType  parent,
int  sub_dimension
Definition at line 1053 of file mbcn_test.cpp.
References CHECK, dim, moab::CN::Dimension(), moab::CN::NumSubEntities(), and moab::CN::VerticesPerEntity().
Referenced by test_sub_entity_nodes_hex_edges(), test_sub_entity_nodes_hex_faces(), test_sub_entity_nodes_kni_edges(), test_sub_entity_nodes_kni_faces(), test_sub_entity_nodes_pri_edges(), test_sub_entity_nodes_pri_faces(), test_sub_entity_nodes_pyr_edges(), test_sub_entity_nodes_pyr_faces(), test_sub_entity_nodes_quad_edges(), test_sub_entity_nodes_tet_edges(), test_sub_entity_nodes_tet_faces(), and test_sub_entity_nodes_tri_edges().
    const int num_corner = CN::VerticesPerEntity( parent );
    const int num_edge   = CN::NumSubEntities( parent, 1 );
    const int num_face   = CN::NumSubEntities( parent, 2 );
    auto dim = CN::Dimension( parent );
    switch( dim )
        case 3:
        case 2:
        case 1:
            test_sub_entity_nodes( parent, num_corner + num_face, sub_dimension );
            test_sub_entity_nodes( parent, num_corner + num_edge + num_face, sub_dimension );
            test_sub_entity_nodes( parent, num_corner + num_face + 1, sub_dimension );
            test_sub_entity_nodes( parent, num_corner + num_edge + num_face + 1, sub_dimension );
            if( 2 <= dim )
                test_sub_entity_nodes( parent, num_corner + num_edge, sub_dimension );
                test_sub_entity_nodes( parent, num_corner + num_edge + 1, sub_dimension );
            if( 1 <= dim )
                test_sub_entity_nodes( parent, num_corner, sub_dimension );
                test_sub_entity_nodes( parent, num_corner + 1, sub_dimension );
            break;
        default:
            CHECK( false );
int  num_nodes,
int  sub_dimension
Definition at line 1085 of file mbcn_test.cpp.
References CHECK, CHECK_EQUAL, conn, corners, moab::CN::Dimension(), moab::CN::HasMidNodes(), moab::CN::HONodeIndex(), moab::MAX_SUB_ENTITY_VERTICES, moab::CN::MID_EDGE_BIT, moab::CN::MID_FACE_BIT, moab::CN::NumSubEntities(), moab::CN::SideNumber(), moab::CN::SubEntityNodeIndices(), moab::CN::SubEntityType(), moab::CN::SubEntityVertexIndices(), and moab::CN::VerticesPerEntity().
    const int num_sub   = CN::NumSubEntities( parent, sub_dimension );
    const int parent_ho = CN::HasMidNodes( parent, num_nodes );
    int child_ho        = 0;
    for( int d = 1; d <= sub_dimension; ++d )
        child_ho |= ( parent_ho & ( 1 << d ) );
    // first test the types
    for( int i = 0; i < num_sub; ++i )
        int num, conn[moab::MAX_SUB_ENTITY_VERTICES];
        EntityType type;
        CN::SubEntityNodeIndices( parent, num_nodes, sub_dimension, i, type, num, conn );
        CHECK_EQUAL( CN::SubEntityType( parent, sub_dimension, i ), type );
    // now test that they have the correct number of higher-order node
        EntityType type;
        const int ho = CN::HasMidNodes( type, num );
        CHECK_EQUAL( child_ho, ho );
    // now test the actual indices
        int num, conn[moab::MAX_SUB_ENTITY_VERTICES], corners[moab::MAX_SUB_ENTITY_VERTICES];
        EntityType type;
        // check corner indices against SubEntityVertexIndices
        const int num_corner = CN::VerticesPerEntity( type );
        CHECK( num >= num_corner );
        CN::SubEntityVertexIndices( parent, sub_dimension, i, corners );
        for( int j = 0; j < num_corner; ++j )
            CHECK_EQUAL( corners[j], conn[j] );
        // check mid-edge indices, if present
        int idx = num_corner;
        if( child_ho & CN::MID_EDGE_BIT )
            // for each edge in the sub-entity type
            const int num_edge = CN::NumSubEntities( type, 1 );
            for( int j = 0; j < num_edge; ++j )
                // get edge indices for sub-entity connectivity
                int edge_ends[2];
                CN::SubEntityVertexIndices( type, 1, j, edge_ends );
                // convert to indices into parent type's connectivity
                CHECK( edge_ends[0] < num_corner );
                edge_ends[0] = corners[edge_ends[0]];
                CHECK( edge_ends[1] < num_corner );
                edge_ends[1] = corners[edge_ends[1]];
                // find edge index in parent element
                int side, sense, off;
                int result = CN::SideNumber( parent, edge_ends, 2, 1, side, sense, off );
                CHECK_EQUAL( 0, result );
                // get location in parent entity connectivity for mid-edge node
                int loc = CN::HONodeIndex( parent, num_nodes, 1, side );
                CHECK_EQUAL( loc, conn[idx++] );
        // check mid-face indices, if present
        if( child_ho & CN::MID_FACE_BIT )
            CHECK_EQUAL( 2, CN::Dimension( type ) );
            int loc = CN::HONodeIndex( parent, num_nodes, 2, i );
        // make sure there were no extra node indices returned
        CHECK_EQUAL( idx, num );
Definition at line 122 of file mbcn_test.cpp.
References MBHEX, and test_sub_entity_nodes().
Definition at line 126 of file mbcn_test.cpp.
Definition at line 114 of file mbcn_test.cpp.
References MBKNIFE, and test_sub_entity_nodes().
Definition at line 118 of file mbcn_test.cpp.
Definition at line 106 of file mbcn_test.cpp.
References MBPRISM, and test_sub_entity_nodes().
Definition at line 110 of file mbcn_test.cpp.
Definition at line 98 of file mbcn_test.cpp.
References MBPYRAMID, and test_sub_entity_nodes().
Definition at line 102 of file mbcn_test.cpp.
Definition at line 86 of file mbcn_test.cpp.
References MBQUAD, and test_sub_entity_nodes().
Definition at line 90 of file mbcn_test.cpp.
References MBTET, and test_sub_entity_nodes().
Definition at line 94 of file mbcn_test.cpp.
Definition at line 82 of file mbcn_test.cpp.
References MBTRI, and test_sub_entity_nodes().
Definition at line 335 of file mbcn_test.cpp.
References CHECK_EQUAL, MBEDGE, MBVERTEX, and moab::CN::SubEntityType().
    CHECK_EQUAL( MBVERTEX, CN::SubEntityType( MBEDGE, 0, 0 ) );
    CHECK_EQUAL( MBVERTEX, CN::SubEntityType( MBEDGE, 0, 1 ) );
    CHECK_EQUAL( MBEDGE, CN::SubEntityType( MBEDGE, 1, 0 ) );
Definition at line 376 of file mbcn_test.cpp.
References do_test_sub_entity_type_3d(), MBHEX, and MBQUAD.
    const EntityType types[] = { MBQUAD, MBQUAD, MBQUAD, MBQUAD, MBQUAD, MBQUAD };
    do_test_sub_entity_type_3d( MBHEX, sizeof( types ) / sizeof( types[0] ), types );
Definition at line 370 of file mbcn_test.cpp.
References do_test_sub_entity_type_3d(), MBKNIFE, and MBQUAD.
    const EntityType types[] = { MBQUAD, MBQUAD, MBQUAD, MBQUAD, MBQUAD };
    do_test_sub_entity_type_3d( MBKNIFE, sizeof( types ) / sizeof( types[0] ), types );
Definition at line 364 of file mbcn_test.cpp.
References do_test_sub_entity_type_3d(), MBPRISM, MBQUAD, and MBTRI.
    const EntityType types[] = { MBQUAD, MBQUAD, MBQUAD, MBTRI, MBTRI };
    do_test_sub_entity_type_3d( MBPRISM, sizeof( types ) / sizeof( types[0] ), types );
Definition at line 358 of file mbcn_test.cpp.
References do_test_sub_entity_type_3d(), MBPYRAMID, MBQUAD, and MBTRI.
    const EntityType types[] = { MBTRI, MBTRI, MBTRI, MBTRI, MBQUAD };
    do_test_sub_entity_type_3d( MBPYRAMID, sizeof( types ) / sizeof( types[0] ), types );
Definition at line 347 of file mbcn_test.cpp.
References do_test_sub_entity_type_2d(), and MBQUAD.
Definition at line 352 of file mbcn_test.cpp.
References do_test_sub_entity_type_3d(), MBTET, and MBTRI.
    const EntityType types[] = { MBTRI, MBTRI, MBTRI, MBTRI };
    do_test_sub_entity_type_3d( MBTET, sizeof( types ) / sizeof( types[0] ), types );
Definition at line 342 of file mbcn_test.cpp.
References do_test_sub_entity_type_2d(), and MBTRI.
Definition at line 330 of file mbcn_test.cpp.
References CHECK_EQUAL, MBVERTEX, and moab::CN::SubEntityType().
    CHECK_EQUAL( MBVERTEX, CN::SubEntityType( MBVERTEX, 0, 0 ) );
void test_type_names ( )
Definition at line 226 of file mbcn_test.cpp.
References CHECK_EQUAL, moab::CN::EntityTypeFromName(), moab::CN::EntityTypeName(), MBMAXTYPE, MBVERTEX, and t.
    for( EntityType t = MBVERTEX; t != MBMAXTYPE; ++t )
        const char* name = CN::EntityTypeName( t );
        CHECK_EQUAL( t, CN::EntityTypeFromName( name ) );
Definition at line 250 of file mbcn_test.cpp.
References CHECK_EQUAL, MBEDGE, MBHEX, MBKNIFE, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, MBVERTEX, and moab::CN::VerticesPerEntity().
    CHECK_EQUAL( 1, CN::VerticesPerEntity( MBVERTEX ) );
    CHECK_EQUAL( 2, CN::VerticesPerEntity( MBEDGE ) );
    CHECK_EQUAL( 3, CN::VerticesPerEntity( MBTRI ) );
    CHECK_EQUAL( 4, CN::VerticesPerEntity( MBQUAD ) );
    CHECK_EQUAL( 4, CN::VerticesPerEntity( MBTET ) );
    CHECK_EQUAL( 5, CN::VerticesPerEntity( MBPYRAMID ) );
    CHECK_EQUAL( 6, CN::VerticesPerEntity( MBPRISM ) );
    CHECK_EQUAL( 7, CN::VerticesPerEntity( MBKNIFE ) );
    CHECK_EQUAL( 8, CN::VerticesPerEntity( MBHEX ) );
void test_wedges ( )
Definition at line 1233 of file mbcn_test.cpp.
References MBMesquite::adj(), CHECK, conn, moab::Core::create_element(), moab::Core::create_vertex(), edges, MBMesquite::faces, moab::Core::get_adjacencies(), moab::Core::get_connectivity(), moab::Core::get_entities_by_dimension(), moab::Core::id_from_handle(), mb, MBPRISM, and n.
    moab::Core mb;
    //mb.load_file("./wed15_2.h5m");
    double coords[3];
    for( int i = 0; i < 22; ++i )
    moab::EntityHandle conn1[15] = { 10, 20, 14, 1, 8, 5, 21, 19, 15, 16, 22, 18, 9, 7, 6 };
    moab::EntityHandle conn2[15] = { 10, 14, 12, 1, 5, 3, 15, 13, 11, 16, 18, 17, 6, 4, 2 };
    mb.create_element( moab::MBPRISM, conn1, 15, w );
    mb.create_element( moab::MBPRISM, conn2, 15, w );
    std::vector< moab::EntityHandle > wedges;
    mb.get_entities_by_dimension( 0, 3, wedges );
    // > If I comment this block there is no problem
    for( const auto& w : wedges )
        CHECK( 5 == adj.size() );
        mb.get_connectivity( &w, 1, conn );
        CHECK( 15 == conn.size() );
            mb.get_adjacencies( &n, 1, 1, true, edges );
            if( edges.size() == 0 )
                std::cout << " node " << n << " not connected to edges \n";
                mb.get_adjacencies( &n, 1, 2, false, faces );
                    std::vector< moab::EntityHandle > connf;
                    mb.get_connectivity( &f, 1, connf );
                    std::cout << "face:" << mb.id_from_handle( f );
                    for( const auto& n1 : connf )
                        std::cout << " " << n1;
                    std::cout << "\n";
                std::vector< moab::EntityHandle > prisms;
                mb.get_adjacencies( &n, 1, 3, false, prisms );
                for( const auto& p : prisms )
                    mb.get_connectivity( &p, 1, connf );
                    std::cout << "prism:" << mb.id_from_handle( p );
                    std::cout << "\n";
                CHECK( edges.size() != 0 );
Variable Documentation
