MOAB: Mesh Oriented datABase
(version 5.4.1)
test mbfacet, a unit test for the FBEngine class, which is providing iGeom like methods to a MOAB db More...
#include "moab/Core.hpp"
#include <iostream>
#include <fstream>
#include <set>
#include <algorithm>
#include <vector>
#include <iterator>
#include <iomanip>
#include <cassert>
#include <cstring>
#include <cmath>
#include "moab/FBEngine.hpp"
#include "moab/GeomTopoTool.hpp"
#include "TestUtil.hpp"
Functions | |
ErrorCode | root_set_test (FBEngine *pFacet) |
ErrorCode | gentityset_test (FBEngine *pFacet) |
ErrorCode | geometry_evaluation_test (FBEngine *pFacet) |
ErrorCode | normals_test (FBEngine *pFacet) |
ErrorCode | ray_test (FBEngine *pFacet) |
ErrorCode | split_test (Interface *mb, FBEngine *pFacet) |
ErrorCode | check_split (Interface *mb) |
ErrorCode | split_quads_test () |
void | handle_error_code (ErrorCode rv, int &number_failed, int &number_successful) |
int | main (int argc, char *argv[]) |
Variables | |
std::string | filename |
std::string | filename_out |
std::string | polygon_file_name |
std::string | quads_file |
double | min_dot = 0.8 |
bool | keep_output |
int | number_tests_successful = 0 |
int | number_tests_failed = 0 |
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition in file mbfacet_test.cpp.
ErrorCode check_split | ( | Interface * | mb | ) |
Definition at line 527 of file mbfacet_test.cpp.
References moab::Interface::delete_mesh(), ErrorCode, filename_out, gentityset_test(), geometry_evaluation_test(), handle_error_code(), moab::FBEngine::Init(), moab::Interface::load_file(), MB_CHK_SET_ERR, MB_SUCCESS, normals_test(), number_tests_failed, number_tests_successful, ray_test(), and root_set_test().
Referenced by main().
{ // check loading the file in an empty db // delete pFacet;// should clean up the FBEngine ErrorCode rval = mb->delete_mesh();MB_CHK_SET_ERR( rval, "ERROR : delete mesh failed!" ); rval = mb->load_file( filename_out.c_str() );MB_CHK_SET_ERR( rval, "ERROR : can't load modified file!" ); FBEngine* pFacet = new FBEngine( mb, NULL, true ); // smooth facetting, no OBB tree passed // repeat tests on modified file // should the init be part of constructor or not? // this is where the obb tree is constructed, and smooth faceting initialized, too. rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" ); std::cout << "root set test: "; rval = root_set_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "gentity set test: "; rval = gentityset_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "geometry evals test: "; rval = geometry_evaluation_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "normal evals test: "; rval = normals_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "ray test: "; rval = ray_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; delete pFacet; pFacet = NULL; if( number_tests_failed > 0 ) return MB_FAILURE; return MB_SUCCESS; }
ErrorCode gentityset_test | ( | FBEngine * | pFacet | ) |
Definition at line 188 of file mbfacet_test.cpp.
References moab::FBEngine::addEntArrToSet(), moab::FBEngine::addEntSet(), moab::FBEngine::createEntSet(), ErrorCode, moab::FBEngine::getEntities(), moab::FBEngine::getNumEntSets(), moab::FBEngine::getNumOfType(), moab::FBEngine::getRootSet(), moab::FBEngine::gsubtract(), MB_CHK_SET_ERR, MB_SUCCESS, root_set, and moab::Range::size().
{ int num_type = 4; EntityHandle ges_array[4]; int number_array[4]; // int num_all_gentities_super = 0; int ent_type = 0; // iBase_VERTEX; EntityHandle root_set; ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); // get the number of sets in the whole model int all_sets = 0; rval = pFacet->getNumEntSets( root_set, 0, &all_sets );MB_CHK_SET_ERR( rval, "Problem getting the number of all gentity sets in whole model." ); // why do we // count all sets // add gentities to entitysets by type for( ; ent_type < num_type; ent_type++ ) { // initialize the entityset rval = pFacet->createEntSet( 1, &ges_array[ent_type] ); // 1 means isList, ordered MB_CHK_SET_ERR( rval, "Problem creating entityset." ); // get entities by type in total "mesh" Range gentities; rval = pFacet->getEntities( root_set, ent_type, gentities );MB_CHK_SET_ERR( rval, "Failed to get gentities by type in gentityset_test." ); // add gentities into gentity set rval = pFacet->addEntArrToSet( gentities, ges_array[ent_type] );MB_CHK_SET_ERR( rval, "Failed to add gentities in entityset_test." ); // Check to make sure entity set really has correct number of entities in it rval = pFacet->getNumOfType( ges_array[ent_type], ent_type, &number_array[ent_type] );MB_CHK_SET_ERR( rval, "Failed to get number of gentities by type in entityset_test." ); // compare the number of entities by type int num_type_gentity = gentities.size(); if( number_array[ent_type] != num_type_gentity ) { std::cerr << "Number of gentities by type is not correct" << std::endl; return MB_FAILURE; } // add to number of all entities in super set // num_all_gentities_super += num_type_gentity; } // make a super set having all entitysets EntityHandle super_set; rval = pFacet->createEntSet( 1, &super_set ); // 1 is list MB_CHK_SET_ERR( rval, "Failed to create a super set in gentityset_test." ); for( int i = 0; i < num_type; i++ ) { rval = pFacet->addEntSet( ges_array[i], super_set );MB_CHK_SET_ERR( rval, "Failed to create a super set in gentityset_test." ); } //----------TEST BOOLEAN OPERATIONS----------------// EntityHandle temp_ges1; rval = pFacet->createEntSet( 1, &temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to create a super set in gentityset_test." ); // Subtract // add all EDGEs and FACEs to temp_es1 // get all EDGE entities Range gedges, gfaces, temp_gentities1; rval = pFacet->getEntities( ges_array[1], /* iBase_EDGE*/ 1, gedges );MB_CHK_SET_ERR( rval, "Failed to get gedge gentities in gentityset_test." ); // add EDGEs to ges1 rval = pFacet->addEntArrToSet( gedges, temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to add gedge gentities in gentityset_test." ); // get all FACE gentities rval = pFacet->getEntities( ges_array[2], /*iBase_FACE*/ 2, gfaces );MB_CHK_SET_ERR( rval, "Failed to get gface gentities in gentityset_test." ); // add FACEs to es1 rval = pFacet->addEntArrToSet( gfaces, temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to add gface gentities in gentityset_test." ); // subtract EDGEs rval = pFacet->gsubtract( temp_ges1, ges_array[1], temp_ges1 );MB_CHK_SET_ERR( rval, "Failed to subtract gentitysets in gentityset_test." ); rval = pFacet->getEntities( temp_ges1, 2, temp_gentities1 );MB_CHK_SET_ERR( rval, "Failed to get gface gentities in gentityset_test." ); if( gfaces.size() != temp_gentities1.size() ) { std::cerr << "Number of entitysets after subtraction not correct \ in gentityset_test." << std::endl; return MB_FAILURE; } // check there's nothing but gfaces in temp_ges1 int num_gents; rval = pFacet->getNumOfType( temp_ges1, 1, &num_gents );MB_CHK_SET_ERR( rval, "Failed to get dimensions of gentities in gentityset_test." ); if( 0 != num_gents ) { std::cerr << "Subtraction failed to remove all edges" << std::endl; return MB_FAILURE; } return MB_SUCCESS; }
ErrorCode geometry_evaluation_test | ( | FBEngine * | pFacet | ) |
Definition at line 289 of file mbfacet_test.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::FBEngine::getEntBoundBox(), moab::FBEngine::getEntClosestPt(), moab::FBEngine::getEntities(), moab::FBEngine::getEntUtoXYZ(), moab::FBEngine::getRootSet(), MB_CHK_SET_ERR, MB_SUCCESS, root_set, and moab::Range::size().
{ int i; EntityHandle root_set; ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); int top = 0; // iBase_VERTEX; int num_test_top = 4; // iBase_ALL_TYPES; std::vector< std::vector< EntityHandle > > gentity_vectors( num_test_top ); // fill the vectors of each topology entities // for( i = top; i < num_test_top; i++ ) { Range gentities; rval = pFacet->getEntities( root_set, i, gentities );MB_CHK_SET_ERR( rval, "Failed to get gentities in eval tests." ); gentity_vectors[i].resize( gentities.size() ); std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() ); } // check geometries in both directions double min[3], max[3], on[3]; double near[3] = { .0, .0, .0 }; std::vector< EntityHandle >::iterator vit; /*for (i = iBase_REGION; i >= iBase_VERTEX; i--) { if (i != iBase_EDGE) {*/ for( i = 3; i >= 0; i-- ) { if( i != 1 ) { for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit ) { EntityHandle this_gent = *vit; rval = pFacet->getEntBoundBox( this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2] );MB_CHK_SET_ERR( rval, "Failed to get bounding box of entity." ); for( int j = 0; j < 3; j++ ) near[j] = ( min[j] + max[j] ) / 2.; rval = pFacet->getEntClosestPt( this_gent, near[0], near[1], near[2], &on[0], &on[1], &on[2] );MB_CHK_SET_ERR( rval, "Failed to get closest point on entity." ); } } else { // for edges, provide a little better help for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit ) { EntityHandle this_gent = *vit; // we know that the edge is parametric, with par between 0 and 1 // some random parameter rval = pFacet->getEntUtoXYZ( this_gent, 0.33, near[0], near[1], near[2] );MB_CHK_SET_ERR( rval, "Failed to get a new point" ); std::cout << " entity of type " << i << " position:\n " << near[0] << " " << near[1] << " " << near[2] << "\n"; rval = pFacet->getEntClosestPt( this_gent, near[0], near[1], near[2], &on[0], &on[1], &on[2] );MB_CHK_SET_ERR( rval, "Failed to get closest point on entity." ); std::cout << " close by: " << on[0] << " " << on[1] << " " << on[2] << "\n"; } } } return MB_SUCCESS; }
void handle_error_code | ( | ErrorCode | rv, |
int & | number_failed, | ||
int & | number_successful | ||
Definition at line 55 of file mbfacet_test.cpp.
References MB_SUCCESS.
{ if( rv == MB_SUCCESS ) { std::cout << "Success"; number_successful++; } else { std::cout << "Failure"; number_failed++; } }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 69 of file mbfacet_test.cpp.
References check_split(), ErrorCode, filename, filename_out, gentityset_test(), geometry_evaluation_test(), handle_error_code(), moab::FBEngine::Init(), keep_output, moab::Interface::load_file(), mb, MB_CHK_SET_ERR, mbcore, min_dot, normals_test(), number_tests_failed, number_tests_successful, polygon_file_name, quads_file, ray_test(), root_set_test(), split_quads_test(), and split_test().
{ filename = TestDir + "unittest/PB.h5m"; polygon_file_name = TestDir + "unittest/polyPB.txt"; filename_out = "PB_facet.h5m"; quads_file = TestDir + "unittest/quads.h5m"; min_dot = 0.8; keep_output = false; bool only_cropping = false; if( argc == 1 ) { std::cout << "Using default input files: " << filename << " " << polygon_file_name << " " << filename_out << " " << min_dot << " " << quads_file << std::endl; std::cout << " default output file: " << filename_out << " will be deleted \n"; } else if( argc == 5 ) { only_cropping = true; filename = argv[1]; polygon_file_name = argv[2]; filename_out = argv[3]; min_dot = atof( argv[4] ); } else if( argc >= 6 ) { filename = argv[1]; polygon_file_name = argv[2]; filename_out = argv[3]; min_dot = atof( argv[4] ); quads_file = argv[5]; keep_output = true; std::cout << "Using input files: " << filename << " " << polygon_file_name << " " << std::endl; std::cout << " default output file: " << filename_out << " will be saved \n"; std::cout << " min_dot: " << min_dot << " quads file:" << quads_file << "\n"; } else { std::cerr << "Usage: " << argv[0] << " [geom_filename] [polygon_file] [output_file] [min_dot] [quads_file]" << std::endl; return 1; } Core mbcore; Interface* mb = &mbcore; ErrorCode rval = mb->load_file( filename.c_str() );MB_CHK_SET_ERR( rval, "failed to load input file" ); FBEngine* pFacet = new FBEngine( mb, NULL, true ); // smooth facetting, no OBB tree passed if( !pFacet ) return 1; // error // should the init be part of constructor or not? // this is where the obb tree is constructed, and smooth faceting initialized, too. rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" ); std::cout << "root set test: "; rval = root_set_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "gentity set test: "; rval = gentityset_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "geometry evals test: "; rval = geometry_evaluation_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "normal evals test: "; rval = normals_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "ray test: "; rval = ray_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "split with loop test "; rval = split_test( mb, pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; // pFacet has been deleted in split_test(), so we should mark it as NULL // Setting pFacet (value parameter) to NULL in split_test() does not work pFacet = NULL; std::cout << " check split: "; rval = check_split( mb ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; if( only_cropping ) return number_tests_failed; // we do not remove the output file, either std::cout << " split quads test: "; rval = split_quads_test(); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; // when we are done, remove modified file if we want to if( !keep_output ) { remove( filename_out.c_str() ); } return number_tests_failed; }
ErrorCode normals_test | ( | FBEngine * | pFacet | ) |
Definition at line 355 of file mbfacet_test.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::FBEngine::getEntBoundBox(), moab::FBEngine::getEntities(), moab::FBEngine::getEntNrmlXYZ(), moab::FBEngine::getRootSet(), MB_CHK_SET_ERR, MB_SUCCESS, root_set, and moab::Range::size().
{ int i; EntityHandle root_set; ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); int top = 0; // iBase_VERTEX; int num_test_top = 4; // iBase_ALL_TYPES; std::vector< std::vector< EntityHandle > > gentity_vectors( num_test_top ); // fill the vectors of each topology entities // for( i = top; i < num_test_top; i++ ) { Range gentities; rval = pFacet->getEntities( root_set, i, gentities );MB_CHK_SET_ERR( rval, "Failed to get gentities in eval tests." ); gentity_vectors[i].resize( gentities.size() ); std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() ); } // check adjacencies in both directions double min[3], max[3]; double normal[3] = { .0, .0, .0 }; std::vector< EntityHandle >::iterator vit; for( i = 3 /*iBase_REGION*/; i > 1 /*iBase_EDGE*/; i-- ) { for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit ) { EntityHandle this_gent = *vit; rval = pFacet->getEntBoundBox( this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2] );MB_CHK_SET_ERR( rval, "Failed to get bounding box of entity." ); rval = pFacet->getEntNrmlXYZ( this_gent, ( max[0] + min[0] ) / 2, ( max[1] + min[1] ) / 2, ( max[2] + min[2] ) / 2, &normal[0], &normal[1], &normal[2] );MB_CHK_SET_ERR( rval, "Failed to get normal to the closest point." ); std::cout << " entity of type " << i << " closest normal to center:\n " << normal[0] << " " << normal[1] << " " << normal[2] << "\n"; } } return MB_SUCCESS; }
Definition at line 399 of file mbfacet_test.cpp.
References ErrorCode, MBMesquite::faces, moab::FBEngine::getEntBoundBox(), moab::FBEngine::getEntities(), moab::FBEngine::getPntRayIntsct(), moab::FBEngine::getRootSet(), moab::Interface::id_from_handle(), MB_CHK_SET_ERR, MB_SUCCESS, moab::FBEngine::moab_instance(), root_set, moab::Interface::type_from_handle(), and z.
{ EntityHandle root_set; ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); int top = 2; // iBase_FACE; Range faces; rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in ray_test." ); // check only the first face // check adjacencies in both directions double min[3], max[3]; EntityHandle first_face = faces[0]; rval = pFacet->getEntBoundBox( first_face, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2] );MB_CHK_SET_ERR( rval, "Failed to get bounding box of entity." ); // assume that the ray shot from the bottom of the box (middle) is a pretty good candidate // in z direction double x = ( min[0] + max[0] ) / 2, y = ( min[1] + max[1] ) / 2, z = min[2]; std::vector< EntityHandle > intersect_entity_handles; std::vector< double > intersect_coords; std::vector< double > param_coords; rval = pFacet->getPntRayIntsct( x, y, z, // shot from 0., 0., 1., // direction intersect_entity_handles, /*iBase_INTERLEAVED,*/ intersect_coords, param_coords );MB_CHK_SET_ERR( rval, "Failed to find ray intersections points " ); for( unsigned int i = 0; i < intersect_entity_handles.size(); i++ ) { std::cout << " entity of type " << pFacet->moab_instance()->type_from_handle( intersect_entity_handles[i] ) << " id from handle: " << pFacet->moab_instance()->id_from_handle( intersect_entity_handles[i] ) << "\n" << intersect_coords[3 * i] << " " << intersect_coords[3 * i + 1] << " " << intersect_coords[3 * i + 2] << "\n" << " distance: " << param_coords[i] << "\n"; } return MB_SUCCESS; }
ErrorCode root_set_test | ( | FBEngine * | pFacet | ) |
Definition at line 180 of file mbfacet_test.cpp.
References ErrorCode, moab::FBEngine::getRootSet(), MB_CHK_SET_ERR, MB_SUCCESS, and root_set.
Referenced by check_split(), and main().
{ EntityHandle root_set; ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); return MB_SUCCESS; }
Definition at line 575 of file mbfacet_test.cpp.
References moab::FBEngine::delete_smooth_tags(), ErrorCode, MBMesquite::faces, gentityset_test(), geometry_evaluation_test(), moab::FBEngine::getEntities(), moab::FBEngine::getRootSet(), handle_error_code(), moab::FBEngine::Init(), keep_output, moab::Interface::load_file(), mb, MB_CHK_SET_ERR, MB_SUCCESS, mbcore, normals_test(), number_tests_failed, number_tests_successful, quads_file, ray_test(), root_set, moab::Range::size(), and moab::Interface::write_file().
{ Core mbcore; Interface* mb = &mbcore; ErrorCode rval = mb->load_file( quads_file.c_str() );MB_CHK_SET_ERR( rval, "failed to load quads file" ); FBEngine* pFacet = new FBEngine( mb, NULL, true ); rval = pFacet->Init();MB_CHK_SET_ERR( rval, "failed to initialize smoothing" ); EntityHandle root_set; rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); int top = 2; // iBase_FACE; Range faces; rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in split_test." ); if( faces.size() != 2 ) { std::cout << "num faces after loading quads model:" << faces.size() << "\n"; return MB_FAILURE; // } // multiple tests std::cout << "gentity set test: "; rval = gentityset_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "geometry evals test: "; rval = geometry_evaluation_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "normal evals test: "; rval = normals_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; std::cout << "ray test: "; rval = ray_test( pFacet ); handle_error_code( rval, number_tests_failed, number_tests_successful ); std::cout << "\n"; // export split triangles model, after deleting the smooth tags pFacet->delete_smooth_tags(); delete pFacet; pFacet = NULL; std::string spl_file = "q.split.h5m"; rval = mb->write_file( spl_file.c_str(), 0, 0, &root_set, 1 );MB_CHK_SET_ERR( rval, "can't write result file" ); if( !keep_output ) { remove( spl_file.c_str() ); } if( number_tests_failed > 0 ) return MB_FAILURE; return MB_SUCCESS; }
ErrorCode split_test | ( | Interface * | mb, |
FBEngine * | pFacet | ||
Definition at line 449 of file mbfacet_test.cpp.
References moab::FBEngine::delete_smooth_tags(), moab::GeomTopoTool::duplicate_model(), ErrorCode, MBMesquite::faces, filename_out, moab::FBEngine::get_gtt(), moab::GeomTopoTool::get_root_model_set(), moab::FBEngine::getEntities(), moab::FBEngine::getRootSet(), MB_CHK_SET_ERR, min_dot, nr, polygon_file_name, root_set, moab::FBEngine::split_surface_with_direction(), moab::Interface::write_file(), and z.
{ EntityHandle root_set; ErrorCode rval = pFacet->getRootSet( &root_set );MB_CHK_SET_ERR( rval, "ERROR : getRootSet failed!" ); int top = 2; // iBase_FACE; Range faces; rval = pFacet->getEntities( root_set, top, faces );MB_CHK_SET_ERR( rval, "Failed to get faces in split_test." ); // check only the first face EntityHandle first_face = faces[0]; // use the polyPB.txt file to get the trimming polygon ; // read the file with the polygon user data std::ifstream datafile( polygon_file_name.c_str(), std::ifstream::in ); if( !datafile ) { std::cout << "can't read file\n"; return MB_FAILURE; } // char temp[100]; double direction[3]; // normalized double gridSize; datafile.getline( temp, 100 ); // first line // get direction and mesh size along polygon segments, from file sscanf( temp, " %lf %lf %lf %lf ", direction, direction + 1, direction + 2, &gridSize ); // NORMALIZE(direction);// just to be sure std::vector< double > xyz; while( !datafile.eof() ) { datafile.getline( temp, 100 ); // int id = 0; double x, y, z; int nr = sscanf( temp, "%lf %lf %lf", &x, &y, &z ); if( nr == 3 ) { xyz.push_back( x ); xyz.push_back( y ); xyz.push_back( z ); } } int sizePolygon = (int)xyz.size() / 3; if( sizePolygon < 3 ) { std::cerr << " Not enough points in the polygon" << std::endl; return MB_FAILURE; } EntityHandle newFace; // first test is with closed surface rval = pFacet->split_surface_with_direction( first_face, xyz, direction, /*closed*/ 1, min_dot, newFace );MB_CHK_SET_ERR( rval, "ERROR : splitting surface failed!" ); // save a new database pFacet->delete_smooth_tags(); // get a new gtt tool // duplicate -- extract a new geom topo tool GeomTopoTool* gtt = pFacet->get_gtt(); GeomTopoTool* duplicate = NULL; std::vector< EntityHandle > gents; gents.push_back( newFace ); rval = gtt->duplicate_model( duplicate, &gents );MB_CHK_SET_ERR( rval, "Failed to extract surface." ); EntityHandle newRootSet = duplicate->get_root_model_set(); delete pFacet; pFacet = NULL; // try not to write the obb tree rval = mb->write_file( filename_out.c_str(), NULL, NULL, &newRootSet, 1 );MB_CHK_SET_ERR( rval, "ERROR : writing mesh failed!" ); delete duplicate; return rval; }
std::string filename |
Definition at line 31 of file mbfacet_test.cpp.
std::string filename_out |
Definition at line 32 of file mbfacet_test.cpp.
Referenced by check_split(), main(), split_test(), split_test_across(), and verify_split().
bool keep_output |
Definition at line 39 of file mbfacet_test.cpp.
Referenced by main(), and split_quads_test().
double min_dot = 0.8 |
Definition at line 37 of file mbfacet_test.cpp.
int number_tests_failed = 0 |
Definition at line 41 of file mbfacet_test.cpp.
int number_tests_successful = 0 |
Definition at line 40 of file mbfacet_test.cpp.
std::string polygon_file_name |
Definition at line 33 of file mbfacet_test.cpp.
std::string quads_file |
Definition at line 35 of file mbfacet_test.cpp.
