mbmem.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/CN.hpp"
#include <iostream>
#include <iomanip>
#include <sstream>
#include <string>
#include <cstdio>
#include <cstdlib>
#include <sys/times.h>
#include <sys/resource.h>
#include <unistd.h>
+ Include dependency graph for mbmem.cpp:
Classes
struct  MemStats
Enumerations
enum  Units {
  HUMAN, BYTES, KILOBYTES, MEGABYTES,
  GIGABYTES
Functions
static void usage (const char *argv0, bool help=false)
static void print_memory_stats (moab::Interface &mb, bool per_type=true, bool per_tag=true, bool totals=true, bool sysstats=true)
static void do_test_mode ()
int main (int argc, char *argv[])
static bool is_zero (const MemStats &stats)
static void get_mem_stats (moab::Interface &mb, MemStats &data, moab::EntityType type=moab::MBMAXTYPE)
static std::string memstr (unsigned long long val)
static std::string tag_type_string (moab::Interface &mb, moab::Tag tag)
static std::string tag_storage_string (moab::Interface &mb, moab::Tag tag)
static std::string center (const char *str, size_t width)
static unsigned long long rdiv (unsigned long long num, unsigned long long den)
Variables
Units UNITS = HUMAN
Enumeration Type Documentation
enum Units
Enumerator:
HUMAN
BYTES
KILOBYTES
MEGABYTES
GIGABYTES
Definition at line 39 of file mbmem.cpp.
Function Documentation
void do_test_mode ( ) [static]
Definition at line 512 of file mbmem.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), mb, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_INTEGER, MBQUAD, MBTRI, MBVERTEX, print_memory_stats(), moab::Range::size(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
Referenced by main().
    const char prefix[] = "****************";
    moab::Core mbcore;
    moab::Interface& mb = mbcore;
    moab::ErrorCode rval;
    moab::Range handles;
    moab::EntityHandle h;
    moab::Range::iterator jt, it;
    const unsigned N = 1000;
    // creating some vertices
    double coords[3] = { 1, 2, 3 };
    for( unsigned i = 0; i < N; ++i )
        mb.create_vertex( coords, h );
    std::cout << std::endl << prefix << "Created " << N << " vertices" << std::endl;
    print_memory_stats( mb, true, false, true, true );
    std::cout << std::endl << prefix << "Created another " << N << " vertices" << std::endl;
    for( int i = 0; i < 100; ++i )
        for( unsigned j = 0; j < N; ++j )
    std::cout << std::endl << prefix << "Created another " << 100 * N << " vertices" << std::endl;
    // create some elements
    handles.clear();
    mb.get_entities_by_type( 0, moab::MBVERTEX, handles );
    it = handles.begin();
    for( unsigned i = 0; i < N - 2; ++i, ++it )
        jt = it;
        moab::EntityHandle conn[3];
        conn[0] = *jt;
        ++jt;
        conn[1] = *jt;
        ++jt;
        conn[2] = *jt;
        ++jt;
        mb.create_element( moab::MBTRI, conn, 3, h );
    std::cout << std::endl << prefix << "Created " << N - 2 << " triangles" << std::endl;
    for( unsigned i = 0; i < N - 3; ++i, ++it )
        jt = it;
        moab::EntityHandle conn[4];
        conn[0] = *jt;
        ++jt;
        conn[1] = *jt;
        ++jt;
        conn[2] = *jt;
        ++jt;
        conn[3] = *jt;
        ++jt;
        mb.create_element( moab::MBQUAD, conn, 4, h );
    std::cout << std::endl << prefix << "Created " << N - 3 << " quads" << std::endl;
        for( unsigned j = 0; j < N - 3; ++j, ++it )
            jt = it;
            conn[0] = *jt;
            ++jt;
            conn[1] = *jt;
            ++jt;
            conn[2] = *jt;
            ++jt;
            conn[3] = *jt;
            ++jt;
    std::cout << std::endl << prefix << "Created another " << 100 * ( N - 3 ) << " quads" << std::endl;
    // set global ID
    moab::Tag tag;
    rval = mb.tag_get_handle( "GLOBAL_ID", 1, moab::MB_TYPE_INTEGER, tag );
    if( moab::MB_SUCCESS != rval )
        std::cerr << "Failed to get GLOBAL_ID tag handle" << std::endl;
        return;
    handles.clear();
    int id = 1;
    for( it = handles.begin(); it != handles.end(); ++it )
        mb.tag_set_data( tag, &*it, 1, &id );
        ++id;
    std::cout << std::endl << prefix << "Set global ID tag on " << handles.size() << " vertices" << std::endl;
    print_memory_stats( mb, true, true, true, true );
    handles.clear();
    mb.get_entities_by_type( 0, moab::MBQUAD, handles );
    id = 1;
        ++id;
    std::cout << std::endl << prefix << "Set global ID tag on " << handles.size() << " quads" << std::endl;
    // create and set a sparse tag
    mb.tag_get_handle( "mem_test_tag", 3, moab::MB_TYPE_DOUBLE, tag, moab::MB_TAG_SPARSE | moab::MB_TAG_CREAT );
    handles.clear();
        mb.get_coords( &*it, 1, coords );
        mb.tag_set_data( tag, &*it, 1, coords );
              << prefix << "Copied vertex coords to sparse tag for " << handles.size() << " vertices" << std::endl;
    // create and set bit tag
    mb.tag_get_handle( "mem_test_bit", 1, moab::MB_TYPE_BIT, tag, moab::MB_TAG_CREAT );
    handles.clear();
    mb.get_entities_by_type( 0, moab::MBTRI, handles );
        char byte = '\001';
        mb.tag_set_data( tag, &*it, 1, &byte );
    std::cout << std::endl << prefix << "Set 1-bit tag for " << handles.size() << " triangles" << std::endl;
    // create vertex to element adjacency data
    handles.clear();
    std::vector< moab::EntityHandle > adj_vec;
    mb.get_adjacencies( &*handles.begin(), 1, 2, false, adj_vec );
    std::cout << std::endl << prefix << "Created vertex-to-element adjacencies" << std::endl;
    std::cout << std::endl;
bool is_zero ( const MemStats stats) [static]
Definition at line 347 of file mbmem.cpp.
References MemStats::total_amortized.
Referenced by print_memory_stats().
    return stats.total_amortized == 0;
int main ( int  argc,
char *  argv[]
Definition at line 60 of file mbmem.cpp.
References BYTES, do_test_mode(), ErrorCode, moab::Interface::get_error_string(), moab::Interface::get_last_error(), GIGABYTES, HUMAN, KILOBYTES, moab::Interface::load_file(), mb, MB_SUCCESS, MEGABYTES, print_memory_stats(), UNITS, and usage.
    bool no_more_flags = false;
    bool test_mode     = false;
    std::vector< int > input_file_list;
    // load each file specified on command line
    for( int i = 1; i < argc; ++i )
        if( !no_more_flags && argv[i][0] == '-' )
            if( !strcmp( argv[i], "-H" ) )
                UNITS = HUMAN;
            else if( !strcmp( argv[i], "-b" ) )
                UNITS = BYTES;
            else if( !strcmp( argv[i], "-k" ) )
                UNITS = KILOBYTES;
            else if( !strcmp( argv[i], "-m" ) )
                UNITS = MEGABYTES;
            else if( !strcmp( argv[i], "-g" ) )
                UNITS = GIGABYTES;
            else if( !strcmp( argv[i], "-T" ) )
                test_mode = true;
            else if( !strcmp( argv[i], "-h" ) )
                usage( argv[0], true );
            else if( !strcmp( argv[i], "--" ) )
                no_more_flags = true;
            else
                std::cerr << argv[0] << ": Invalid flag: \"" << argv[i] << "\"." << std::endl << std::endl;
                usage( argv[0] );
        else
            input_file_list.push_back( i );
    if( test_mode )
        do_test_mode();
        if( input_file_list.empty() ) return 0;
    moab::Core mbcore;
    for( std::vector< int >::iterator it = input_file_list.begin(); it != input_file_list.end(); ++it )
        rval = mb.load_file( argv[*it] );
        // if file load failed, print some info and exit
            std::string message;
            mb.get_last_error( message );
            std::cerr << mb.get_error_string( rval ) << ": " << message << std::endl
                      << argv[*it] << ": Failed to read file." << std::endl;
            return 1;
        std::cout << "Loaded file: " << argv[*it] << std::endl;
    // print summary of MOAB's memory use
    print_memory_stats( mb );
    return 0;
std::string memstr ( unsigned long long  val) [static]
Definition at line 376 of file mbmem.cpp.
References BYTES, GIGABYTES, HUMAN, KILOBYTES, mb, MEGABYTES, rdiv(), and UNITS.
    const unsigned long long kb = 1024;
    const unsigned long long mb = kb * kb;
    const unsigned long long gb = kb * mb;
    const unsigned long long tb = kb * gb;
    std::ostringstream s;
    if( UNITS == HUMAN )
        if( val >= 10 * tb )
            s << rdiv( val, tb ) << "TB";
        else if( val >= 10 * gb )
            s << rdiv( val, gb ) << "GB";
        else if( val >= 10 * mb )
            s << rdiv( val, mb ) << "MB";
        else if( val >= 10 * kb )
            s << rdiv( val, kb ) << "kB";
        else if( val > 0 )
            s << val << " B";
        else
            s << "0  ";
    else
        unsigned long long den = 1;
        switch( UNITS )
            case BYTES:
                den = 1;
                break;
            case KILOBYTES:
                den = kb;
                break;
            case MEGABYTES:
                den = mb;
                break;
            case GIGABYTES:
                den = gb;
                break;
            case HUMAN:
                break;  // handled above, list here to suppress warning
        s << rdiv( val, den );
    return s.str();
void print_memory_stats ( moab::Interface mb,
bool  per_type = true,
bool  per_tag = true,
bool  totals = true,
bool  sysstats = true
) [static]
Definition at line 162 of file mbmem.cpp.
References MemStats::adjacency_amortized, MemStats::adjacency_storage, center(), MemStats::entity_amortized, MemStats::entity_storage, moab::CN::EntityTypeName(), ErrorCode, moab::Interface::estimated_memory_use(), get_mem_stats(), is_zero(), MB_SUCCESS, MBMAXTYPE, MBVERTEX, memstr(), t, MemStats::tag_amortized, moab::Interface::tag_get_name(), moab::Interface::tag_get_tags(), MemStats::tag_storage, tag_storage_string(), tag_type_string(), MemStats::total_amortized, and MemStats::total_storage.
Referenced by do_test_mode(), and main().
    const char ANON_TAG_NAME[]   = "(anonymous)";
    const int TYPE_WIDTH         = 10;
    const int MEM_WIDTH          = 7;
    const int MEM2_WIDTH         = 2 * MEM_WIDTH + 1;
    const int MIN_TAG_NAME_WIDTH = strlen( ANON_TAG_NAME );
    const int DTYPE_WIDTH        = 12;
    const int STORAGE_WIDTH      = 8;
    // per-entity-type table header
    MemStats stats;
    if( per_type )
        std::cout.fill( ' ' );
        std::cout << std::left << std::setw( TYPE_WIDTH ) << "Type" << ' ' << center( "Total", MEM2_WIDTH ) << ' '
                  << center( "Entity", MEM2_WIDTH ) << ' ' << center( "Adjacency", MEM2_WIDTH ) << ' '
                  << center( "Tag", MEM2_WIDTH ) << ' ' << std::endl
                  << std::setw( TYPE_WIDTH ) << " ";
        for( int i = 0; i < 4; ++i )
            std::cout << ' ' << std::left << std::setw( MEM_WIDTH ) << "Used" << ' ' << std::left
                      << std::setw( MEM_WIDTH ) << "Alloc";
        std::cout.fill( '-' );
        std::cout << std::setw( TYPE_WIDTH ) << '-';
        for( int i = 0; i < 8; ++i )
            std::cout << ' ' << std::setw( MEM_WIDTH ) << '-';
        // per-entity-type memory use
        for( moab::EntityType t = moab::MBVERTEX; t != moab::MBMAXTYPE; ++t )
            get_mem_stats( mb, stats, t );
            if( is_zero( stats ) ) continue;  // skip types with no allocated memory
            std::cout << std::left << std::setw( TYPE_WIDTH ) << moab::CN::EntityTypeName( t ) << ' ' << std::right
                      << std::setw( MEM_WIDTH ) << memstr( stats.total_storage ) << ' ' << std::right
                      << std::setw( MEM_WIDTH ) << memstr( stats.total_amortized ) << ' ' << std::right
                      << std::setw( MEM_WIDTH ) << memstr( stats.entity_storage ) << ' ' << std::right
                      << std::setw( MEM_WIDTH ) << memstr( stats.entity_amortized ) << ' ' << std::right
                      << std::setw( MEM_WIDTH ) << memstr( stats.adjacency_storage ) << ' ' << std::right
                      << std::setw( MEM_WIDTH ) << memstr( stats.adjacency_amortized ) << ' ' << std::right
                      << std::setw( MEM_WIDTH ) << memstr( stats.tag_storage ) << ' ' << std::right
                      << std::setw( MEM_WIDTH ) << memstr( stats.tag_amortized ) << std::endl;
    }  // end per_type
    if( per_tag )
        // get list of tags
        std::vector< moab::Tag > tags;
        std::vector< moab::Tag >::const_iterator ti;
        mb.tag_get_tags( tags );
        // figure out required field with to fit longest tag name
        unsigned maxlen = MIN_TAG_NAME_WIDTH;
        for( ti = tags.begin(); ti != tags.end(); ++ti )
            std::string name;
            rval = mb.tag_get_name( *ti, name );
            if( moab::MB_SUCCESS != rval ) continue;
            if( name.size() > maxlen ) maxlen = name.size();
        // print header for per-tag data
        if( !tags.empty() )
                      << std::left << std::setw( maxlen ) << "Tag Name" << ' ' << std::left << std::setw( DTYPE_WIDTH )
                      << "Type" << ' ' << std::left << std::setw( STORAGE_WIDTH ) << "Storage" << ' ' << std::left
                      << std::setw( MEM_WIDTH ) << "Used" << ' ' << std::left << std::setw( MEM_WIDTH ) << "Alloc"
                      << std::endl;
            std::cout << std::setw( maxlen ) << '-' << ' ' << std::setw( DTYPE_WIDTH ) << '-' << ' '
                      << std::setw( STORAGE_WIDTH ) << '-' << ' ' << std::setw( MEM_WIDTH ) << '-' << ' '
                      << std::setw( MEM_WIDTH ) << '-' << std::endl;
        // print per-tag memory use
            std::string name;
            if( moab::MB_SUCCESS != rval || name.empty() ) name = ANON_TAG_NAME;
            unsigned long long occupied, allocated;
            mb.estimated_memory_use( 0, 0, 0, 0, 0, 0, 0, 0, &*ti, 1, &occupied, &allocated );
            std::cout << std::left << std::setw( maxlen ) << name << ' ' << std::right << std::setw( DTYPE_WIDTH )
                      << tag_type_string( mb, *ti ) << ' ' << std::right << std::setw( STORAGE_WIDTH )
                      << tag_storage_string( mb, *ti ) << ' ' << std::right << std::setw( MEM_WIDTH )
                      << memstr( occupied ) << ' ' << std::right << std::setw( MEM_WIDTH ) << memstr( allocated )
                      << std::endl;
    }  // end per_tag
    if( totals )
        // print summary of overall memory use
        get_mem_stats( mb, stats );
                  << "TOTAL: (Used/Allocated)" << std::endl
                  << "memory:    " << memstr( stats.total_storage ) << "/" << memstr( stats.total_amortized )
                  << std::endl
                  << "entity:    " << memstr( stats.entity_storage ) << "/" << memstr( stats.entity_amortized )
                  << std::endl
                  << "adjacency: " << memstr( stats.adjacency_storage ) << "/" << memstr( stats.adjacency_amortized )
                  << std::endl
                  << "tag:       " << memstr( stats.tag_storage ) << "/" << memstr( stats.tag_amortized ) << std::endl
                  << std::endl;
    }  // end totals
    if( sysstats )
        std::FILE* filp = std::fopen( "/proc/self/stat", "r" );
        unsigned long long vsize;
        long rss;
        if( filp && 2 == std::fscanf( filp,
                                      "%*d "   // pid
                                      "%*s "   // comm
                                      "%*c "   // state
                                      "%*d "   // ppid
                                      "%*d "   // pgrp
                                      "%*d "   // session
                                      "%*d "   // tty_nr
                                      "%*d "   // tpgid
                                      "%*u "   // flags
                                      "%*u "   // minflt
                                      "%*u "   // cminflt
                                      "%*u "   // majflt
                                      "%*u "   // cmajflt
                                      "%*u "   // utime
                                      "%*u "   // stime
                                      "%*d "   // cutime
                                      "%*d "   // cstime
                                      "%*d "   // priority
                                      "%*d "   // nice
                                      "%*d "   // num_threads
                                      "%*d "   // itrealvalue
                                      "%*u "   // starttime
                                      "%llu "  // vsize
                                      "%ld",   // rss
                                      &vsize, &rss ) )
#ifndef _WIN32
            long long tmprss = rss * getpagesize();
#endif
                      << "SYSTEM:" << std::endl
                      << "Virtual memory:    " << memstr( vsize )
#ifndef _WIN32
                      << std::endl
                      << "Resident set size: " << memstr( tmprss )
#endif
                      << std::endl;
        else
#ifndef _WIN32
            struct rusage sysdata;
            if( getrusage( RUSAGE_SELF, &sysdata ) )
                std::cerr << "getrusage failed" << std::endl;
            else
                rss              = sysdata.ru_maxrss;
                std::cerr << std::endl
                          << "Resident set size: " << memstr( tmprss ) << std::endl;
#endif
        if( filp ) fclose( filp );
    }  // end sysstats
static unsigned long long rdiv ( unsigned long long  num,
) [static]
Definition at line 371 of file mbmem.cpp.
Referenced by memstr().
    return ( num + den / 2 ) / den;
std::string tag_storage_string ( moab::Interface mb,
moab::Tag  tag
) [static]
Definition at line 475 of file mbmem.cpp.
References ErrorCode, MB_SUCCESS, MB_TAG_BIT, MB_TAG_DENSE, MB_TAG_SPARSE, moab::Interface::tag_get_type(), and TagType.
    moab::TagType type;
    rval = mb.tag_get_type( tag, type );
    if( moab::MB_SUCCESS != rval ) return std::string();
    switch( type )
        case moab::MB_TAG_DENSE:
            return "dense";
        case moab::MB_TAG_SPARSE:
            return "sparse";
        case moab::MB_TAG_BIT:
            return "bit";
        default:
            return "(none)";
std::string tag_type_string ( moab::Interface mb,
moab::Tag  tag
) [static]
Definition at line 425 of file mbmem.cpp.
References ErrorCode, MB_SUCCESS, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MB_VARIABLE_DATA_LENGTH, size, moab::Interface::tag_get_data_type(), and moab::Interface::tag_get_length().
    moab::DataType type;
    rval = mb.tag_get_data_type( tag, type );
    int typesize;
    std::string typestr;
    switch( type )
        case moab::MB_TYPE_INTEGER:
            typestr  = "int";
            typesize = sizeof( int );
            break;
        case moab::MB_TYPE_DOUBLE:
            typestr  = "double";
            typesize = sizeof( double );
            break;
        case moab::MB_TYPE_HANDLE:
            typestr  = "handle";
            typesize = sizeof( moab::EntityHandle );
            break;
        case moab::MB_TYPE_BIT:
            typesize = 1;
            typestr  = "bits";
            break;
        case moab::MB_TYPE_OPAQUE:
            typesize = 1;
            typestr  = "bytes";
            break;
        default:
            typesize = 1;
            typestr  = "???";
            break;
    int size;
    rval = mb.tag_get_length( tag, size );
    if( moab::MB_VARIABLE_DATA_LENGTH == rval )
        s << "VAR " << typestr;
    else if( moab::MB_SUCCESS == rval )
        s << size / typesize << " " << typestr;
    // else do nothing
    return s.str();
static void usage ( const char *  argv0,
bool  help = false
) [static]
Definition at line 18 of file mbmem.cpp.
References help().
    std::ostream& str = help ? std::cout : std::cerr;
    str << "Usage: " << argv0 << " [-H|-b|-k|-m] <filename> [<filename> ...]" << std::endl
        << "       " << argv0 << " [-H|-b|-k|-m] -T" << std::endl;
    if( !help )
        str << "       " << argv0 << " -h" << std::endl;
        std::exit( 1 );
    std::cerr << "  -H : human readable units" << std::endl
              << "  -b : bytes" << std::endl
              << "  -k : kilobytes (1 kB == 1024 bytes)" << std::endl
              << "  -m : megabytes (1 MB == 1024 kB)" << std::endl
              << "  -g : gigabytes (1 GB == 1024 MB)" << std::endl
              << "  -T : test mode" << std::endl
              << std::endl;
    std::exit( 0 );
Variable Documentation
Definition at line 47 of file mbmem.cpp.
Referenced by main(), and memstr().
