MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/ParallelComm.hpp"
#include "MBParallelConventions.h"
#include "MBTagConventions.hpp"
#include "moab/Core.hpp"
#include "ScdVertexData.hpp"
#include "StructuredElementSeq.hpp"
#include "SequenceManager.hpp"
#include "moab/Error.hpp"
#include "moab_mpi.h"
#include <iostream>
#include <sstream>
#include <cassert>
Defines | |
#define | REALTFI 1 |
#define | ERROR(a, b) |
#define | PRINT_LAST_ERROR |
#define | RRA(a) |
#define | PRINTSETS(a, b, c, p) |
Functions | |
ErrorCode | create_linear_mesh (Interface *mbImpl, int N, int M, int &nshared) |
ErrorCode | create_scd_mesh (Interface *mbImpl, int IJK, int &nshared) |
ErrorCode | read_file (Interface *mbImpl, std::vector< std::string > &filenames, const char *tag_name, int tag_val, int distrib, int parallel_option, int resolve_shared, int with_ghosts, int use_mpio, bool print_parallel) |
ErrorCode | test_packing (Interface *mbImpl, const char *filename) |
ErrorCode | report_nsets (Interface *mbImpl) |
ErrorCode | report_iface_ents (Interface *mbImpl, std::vector< ParallelComm * > &pcs) |
void | print_usage (const char *) |
int | main (int argc, char **argv) |
Variables | |
const bool | debug = false |
{ \ std::cerr << ( a ) << std::endl; \ return b; \ }
Definition at line 28 of file mbparallelcomm_test.cpp.
#define PRINT_LAST_ERROR |
std::string last_error; \
result = mbImpl->get_last_error( last_error ); \
if( last_error.empty() ) \
std::cerr << "(none)" << std::endl; \
else \
std::cerr << last_error << std::endl; \
Definition at line 34 of file mbparallelcomm_test.cpp.
Referenced by main(), read_file(), and test_packing().
if( a ) \ { \ result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &( a ), p, 1, b ); \ if( !( b ).empty() ) \ { \ std::vector< int > ids( ( b ).size() ); \ result = mbImpl->tag_get_data( gidtag, b, &ids[0] ); \ if( MB_SUCCESS == result ) \ { \ std::cout << "Proc " << rank << ": " << ( c ) << " (total " << ( b ).size() << "): " << ids[0]; \ for( unsigned int i = 1; i < ( b ).size(); i++ ) \ std::cout << ", " << ids[i]; \ std::cout << std::endl; \ } \ } \ }
Referenced by report_nsets().
#define REALTFI 1 |
test of ParallelComm functionality
To run:
mpirun -np <#procs> mbparallelcomm_test
Definition at line 22 of file mbparallelcomm_test.cpp.
#define RRA | ( | a | ) |
if( MB_SUCCESS != result ) \ { \ std::cerr << ( a ); \ return result; \ }
Definition at line 43 of file mbparallelcomm_test.cpp.
Referenced by read_file(), and test_packing().
ErrorCode create_linear_mesh | ( | Interface * | mbImpl, |
int | N, | ||
int | M, | ||
int & | nshared | ||
ErrorCode create_scd_mesh | ( | Interface * | mbImpl, |
int | IJK, | ||
int main | ( | int | argc, |
char ** | argv | ||
Definition at line 73 of file mbparallelcomm_test.cpp.
References moab::Interface::delete_mesh(), ErrorCode, MB_SUCCESS, MPI_COMM_WORLD, PRINT_LAST_ERROR, print_usage(), rank, read_file(), and test_packing().
{ // need to init MPI first, to tell how many procs and rank MPI_Init( &argc, &argv ); int nprocs, rank; MPI_Comm_size( MPI_COMM_WORLD, &nprocs ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); // start time double stime = 0, rtime = 0, dtime = 0, ltime = 0; if( 0 == rank ) stime = MPI_Wtime(); // create MOAB instance based on that Interface* mbImpl = new Core; if( NULL == mbImpl ) return 1; ErrorCode result = MB_SUCCESS; // each interior proc has a vector of N+M vertices, sharing // M vertices each with lower- and upper-rank processors, except // procs on the end // get N, M from command line if( argc < 3 ) { if( 0 == rank ) print_usage( argv[0] ); MPI_Finalize(); return 1; } int npos = 1, tag_val, distrib, with_ghosts = 1, resolve_shared = 1, use_mpio = 0; bool print_parallel = false; const char* tag_name; std::vector< std::string > filenames; int parallel_option = 0; int num_files; if( !strcmp( argv[npos], "-p" ) ) print_parallel = true; while( npos != argc ) { ErrorCode tmp_result; int this_opt = strtol( argv[npos++], NULL, 0 ); switch( this_opt ) { case 0: case -1: case -2: case -3: parallel_option = this_opt; continue; case 3: // read a file in parallel from the filename on the command line tag_name = "MATERIAL_SET"; tag_val = -1; num_files = strtol( argv[npos++], NULL, 0 ); if( 0 == num_files ) { if( 0 == rank ) print_usage( argv[0] ); MPI_Finalize(); return 1; } while( num_files-- && npos < argc ) filenames.push_back( std::string( argv[npos++] ) ); if( npos < argc ) tag_name = argv[npos++]; if( npos < argc ) tag_val = strtol( argv[npos++], NULL, 0 ); if( npos < argc ) distrib = strtol( argv[npos++], NULL, 0 ); else distrib = 1; if( npos < argc ) resolve_shared = strtol( argv[npos++], NULL, 0 ); if( npos < argc ) with_ghosts = strtol( argv[npos++], NULL, 0 ); if( npos < argc ) use_mpio = strtol( argv[npos++], NULL, 0 ); tmp_result = read_file( mbImpl, filenames, tag_name, tag_val, distrib, parallel_option, resolve_shared, with_ghosts, use_mpio, print_parallel ); if( MB_SUCCESS != tmp_result ) { result = tmp_result; std::cerr << "Couldn't read mesh; error message:" << std::endl; PRINT_LAST_ERROR; MPI_Abort( MPI_COMM_WORLD, result ); } break; case 4: filenames.push_back( argv[npos++] ); tmp_result = test_packing( mbImpl, filenames[0].c_str() ); if( MB_SUCCESS != tmp_result ) { result = tmp_result; std::cerr << "Packing test failed; error message:" << std::endl; PRINT_LAST_ERROR } break; case 5: // read a file in parallel from the filename on the command line tag_name = "MATERIAL_SET"; distrib = 1; tag_val = -1; with_ghosts = 0; resolve_shared = 1; while( npos < argc ) filenames.push_back( std::string( argv[npos++] ) ); tmp_result = read_file( mbImpl, filenames, tag_name, tag_val, distrib, parallel_option, resolve_shared, with_ghosts, use_mpio, print_parallel ); if( MB_SUCCESS != tmp_result ) { result = tmp_result; std::cerr << "Couldn't read mesh; error message:" << std::endl; PRINT_LAST_ERROR; MPI_Abort( MPI_COMM_WORLD, result ); } break; default: std::cerr << "Unrecognized option \"" << this_opt << "\"; skipping." << std::endl; tmp_result = MB_FAILURE; } if( 0 == rank ) rtime = MPI_Wtime(); } if( 0 == rank ) dtime = MPI_Wtime(); result = mbImpl->delete_mesh(); if( MB_SUCCESS != result ) { std::cerr << "Couldn't delete mesh on rank " << rank << "; error message: " << std::endl; PRINT_LAST_ERROR; } if( 0 == rank ) ltime = MPI_Wtime(); if( MB_SUCCESS == result ) std::cerr << "Proc " << rank << ": Success." << std::endl; if( 0 == rank ) std::cout << "Times: " << dtime - stime << " " << rtime - stime << " " << ltime - dtime << " (total/read/delete)" << std::endl; MPI_Finalize(); delete mbImpl; return ( MB_SUCCESS == result ? 0 : 1 ); }
void print_usage | ( | const char * | command | ) |
Definition at line 222 of file mbparallelcomm_test.cpp.
{ std::cerr << "Usage: " << command << " [readpar_option] <opt> <input> [...] where:" << std::endl << " readpar_option = 0 (BCAST_DELETE) (default), -1 (READ_DELETE), " << std::endl << " -2 (READ_PARALLEL), -3 (BCAST)" << std::endl << "opt input" << std::endl << "=== =====" << std::endl << " 1 <linear_ints> <shared_verts> " << std::endl << " 2 <n_ints> " << std::endl << " 3* <# files> <file_names...> [<tag_name>=\"MATERIAL_SET\" [tag_val] " "[distribute=1] [resolve_shared=1] [with_ghosts=1] [use_mpio=0]" << std::endl << " 4 <file_name> " << std::endl << "*Note: if opt 3 is used, it must be the last one." << std::endl; }
ErrorCode read_file | ( | Interface * | mbImpl, |
std::vector< std::string > & | filenames, | ||
const char * | tag_name, | ||
int | tag_val, | ||
int | distrib, | ||
int | parallel_option, | ||
int | resolve_shared, | ||
int | with_ghosts, | ||
int | use_mpio, | ||
bool | print_parallel | ||
Definition at line 331 of file mbparallelcomm_test.cpp.
References ErrorCode, moab::ParallelComm::get_pcomm(), moab::Interface::load_file(), MB_SUCCESS, MPI_COMM_WORLD, PRINT_LAST_ERROR, report_iface_ents(), and RRA.
{ std::ostringstream options; switch( parallel_option ) { case 0: options << "PARALLEL=BCAST_DELETE;PARTITION=" << tag_name; break; case -1: options << "PARALLEL=READ_DELETE;PARTITION=" << tag_name; break; case -2: options << "PARALLEL=READ_PART;PARTITION=" << tag_name; break; case -3: options << "PARALLEL=BCAST;PARTITION=" << tag_name; break; default: return MB_FAILURE; } if( -1 != tag_val ) options << ";PARTITION_VAL=" << tag_val; if( 1 == distrib ) options << ";PARTITION_DISTRIBUTE"; if( 1 == resolve_shared ) options << ";PARALLEL_RESOLVE_SHARED_ENTS"; if( 1 == with_ghosts ) options << ";PARALLEL_GHOSTS=3.0.1"; if( 1 == use_mpio ) options << ";USE_MPIO"; options << ";CPUTIME"; if( print_parallel ) options << ";PRINT_PARALLEL"; std::vector< ParallelComm* > pcs( filenames.size() ); ErrorCode result = MB_FAILURE; if( 1 < filenames.size() ) { for( unsigned int i = 0; i < filenames.size(); i++ ) { pcs[i] = new ParallelComm( mbImpl, MPI_COMM_WORLD ); int index = pcs[i]->get_id(); std::ostringstream newopts; newopts << options.str(); newopts << ";PARALLEL_COMM=" << index; result = mbImpl->load_file( filenames[i].c_str(), 0, newopts.str().c_str() ); if( MB_SUCCESS != result ) PRINT_LAST_ERROR; if( MB_SUCCESS != result ) { MPI_Abort( MPI_COMM_WORLD, result ); break; } // exchange tag Range tmp_range; result = pcs[i]->exchange_tags( "GLOBAL_ID", tmp_range ); if( MB_SUCCESS != result ) { std::cerr << "Tag exchange didn't work." << std::endl; break; } } } else { result = mbImpl->load_file( filenames[0].c_str(), 0, options.str().c_str() ); RRA( "Failed to load file." ); pcs[0] = ParallelComm::get_pcomm( mbImpl, 0 ); assert( pcs[0] ); } if( MB_SUCCESS == result ) report_iface_ents( mbImpl, pcs ); return result; }
ErrorCode report_iface_ents | ( | Interface * | mbImpl, |
std::vector< ParallelComm * > & | pcs | ||
Definition at line 461 of file mbparallelcomm_test.cpp.
References ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_last_error(), moab::Interface::get_number_entities_by_dimension(), MB_SUCCESS, moab::Range::merge(), MPI_COMM_WORLD, PSTATUS_NOT_OWNED, rank, size, moab::Range::size(), and moab::Interface::UNION.
Referenced by read_file().
{ Range iface_ents[6]; ErrorCode result = MB_SUCCESS, tmp_result; // now figure out which vertices are shared Range part_ents, part_verts; for( unsigned int p = 0; p < pcs.size(); p++ ) { // get entities owned by this partition for( Range::iterator rit = pcs[p]->partition_sets().begin(); rit != pcs[p]->partition_sets().end(); ++rit ) { tmp_result = mbImpl->get_entities_by_dimension( *rit, 3, part_ents, true ); if( MB_SUCCESS != tmp_result ) result = tmp_result; } for( int i = 0; i < 4; i++ ) { tmp_result = pcs[p]->get_iface_entities( -1, i, iface_ents[i] ); if( MB_SUCCESS != tmp_result ) { std::cerr << "get_iface_entities returned error on proc " << pcs[p]->proc_config().proc_rank() << "; message: " << std::endl; std::string last_error; result = mbImpl->get_last_error( last_error ); if( last_error.empty() ) std::cerr << "(none)" << std::endl; else std::cerr << last_error << std::endl; result = tmp_result; } if( 0 != i ) iface_ents[4].merge( iface_ents[i] ); } } // get non-owned vertices result = pcs[0]->get_pstatus_entities( 0, PSTATUS_NOT_OWNED, part_verts ); if( MB_SUCCESS != result ) { std::cerr << "Couldn't get non-owned entities." << std::endl; return result; } int tot_verts; result = mbImpl->get_number_entities_by_dimension( 0, 0, tot_verts ); if( MB_SUCCESS != result ) { std::cerr << "Couldn't get number of vertices." << std::endl; return result; } tot_verts -= part_verts.size(); // report # iface entities result = mbImpl->get_adjacencies( iface_ents[4], 0, false, iface_ents[5], Interface::UNION ); int rank; MPI_Comm_rank( MPI_COMM_WORLD, &rank ); std::cerr << "Proc " << rank << " iface entities: " << std::endl; for( int i = 0; i < 4; i++ ) std::cerr << " " << iface_ents[i].size() << " " << i << "d iface entities." << std::endl; std::cerr << " (" << iface_ents[5].size() << " verts adj to other iface ents)" << std::endl; if( iface_ents[0].size() != iface_ents[5].size() ) std::cerr << "WARNING: number of interface vertices don't agree with " << "vertex adjacencies on interface entities." << std::endl; // report # regions owned by this proc std::cout << "Proc " << rank << " owns " << part_ents.size() << " 3d entities." << std::endl; // get total # regions over all procs int num_local[2], num_total[2]; num_local[0] = tot_verts; num_local[1] = part_ents.size(); int failure = MPI_Reduce( num_local, num_total, 2, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD ); if( failure ) result = MB_FAILURE; if( 0 == rank ) { std::cout << "Total # owned vertices = " << num_total[0] << std::endl; std::cout << "Total # owned regions = " << num_total[1] << std::endl; } return result; }
ErrorCode report_nsets | ( | Interface * | mbImpl | ) |
Definition at line 238 of file mbparallelcomm_test.cpp.
References moab::Range::clear(), moab::debug, ErrorCode, moab::Interface::get_entities_by_type(), moab::Interface::get_number_entities_by_type(), moab::Interface::list_entities(), MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, MPI_COMM_WORLD, moab::Range::print(), PRINTSETS, rank, moab::Range::size(), and moab::Interface::tag_get_handle().
{ // get and report various numbers... int rank; MPI_Comm_rank( MPI_COMM_WORLD, &rank ); Range matsets, geomsets, parsets; int nsets; Tag mtag = 0, gtag = 0, ptag = 0, gidtag; ErrorCode result = mbImpl->tag_get_handle( "MATERIAL_SET", 1, MB_TYPE_INTEGER, mtag ); if( MB_SUCCESS != result ) { std::cerr << "Couldn't get MATERIAL_SET tag." << std::endl; return result; } result = mbImpl->tag_get_handle( "GEOM_DIMENSION", 1, MB_TYPE_INTEGER, gtag ); if( MB_SUCCESS != result ) { std::cerr << "Couldn't get MATERIAL_SET tag." << std::endl; return result; } result = mbImpl->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, ptag ); if( MB_SUCCESS != result ) { std::cerr << "Couldn't PARALLEL_PARTITION tag." << std::endl; return result; } result = mbImpl->tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, gidtag ); if( MB_SUCCESS != result ) { std::cerr << "Couldn't get GLOBAL_ID tag." << std::endl; return result; } result = mbImpl->get_number_entities_by_type( 0, MBENTITYSET, nsets ); if( MB_SUCCESS != result ) { std::cerr << "Couldn't get number entities by type." << std::endl; return result; } std::cout << "Proc " << rank << ": Total of " << nsets << " entity sets." << std::endl; #define PRINTSETS( a, b, c, p ) \ if( a ) \ { \ result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &( a ), p, 1, b ); \ if( !( b ).empty() ) \ { \ std::vector< int > ids( ( b ).size() ); \ result = mbImpl->tag_get_data( gidtag, b, &ids[0] ); \ if( MB_SUCCESS == result ) \ { \ std::cout << "Proc " << rank << ": " << ( c ) << " (total " << ( b ).size() << "): " << ids[0]; \ for( unsigned int i = 1; i < ( b ).size(); i++ ) \ std::cout << ", " << ids[i]; \ std::cout << std::endl; \ } \ } \ } PRINTSETS( mtag, matsets, "material sets", NULL ); int tval = 3; void* pval = &tval; PRINTSETS( gtag, geomsets, "geom sets (vols)", &pval ); tval = 2; geomsets.clear(); PRINTSETS( gtag, geomsets, "geom sets (surfs)", &pval ); tval = 1; geomsets.clear(); PRINTSETS( gtag, geomsets, "geom sets (curves)", &pval ); tval = 0; geomsets.clear(); PRINTSETS( gtag, geomsets, "geom sets (verts)", &pval ); PRINTSETS( ptag, parsets, "partition sets", NULL ); if( debug ) { // list info on all ent sets, reuse parsets parsets.clear(); result = mbImpl->get_entities_by_type( 0, MBENTITYSET, parsets ); if( MB_SUCCESS == result ) { std::cout << "Total sets (by range): " << parsets.size() << "; sets: " << std::endl; parsets.print( " " ); mbImpl->list_entities( parsets ); } } return MB_SUCCESS; }
ErrorCode test_packing | ( | Interface * | mbImpl, |
const char * | filename | ||
Definition at line 420 of file mbparallelcomm_test.cpp.
References moab::ParallelComm::Buffer::buff_ptr, moab::Interface::create_meshset(), ErrorCode, moab::Interface::get_entities_by_handle(), moab::Range::insert(), moab::Interface::load_file(), MB_SUCCESS, MESHSET_SET, MPI_COMM_WORLD, moab::ParallelComm::pack_buffer(), PRINT_LAST_ERROR, moab::ParallelComm::Buffer::reset_ptr(), RRA, and moab::ParallelComm::unpack_buffer().
Referenced by main().
{ // read the mesh EntityHandle file_set; ErrorCode result = mbImpl->create_meshset( MESHSET_SET, file_set ); RRA( "create_meshset failed." ); result = mbImpl->load_file( filename, &file_set, NULL ); if( MB_SUCCESS != result ) { std::cerr << "Reading file failed; message:" << std::endl; PRINT_LAST_ERROR; return result; } // get 3d entities and pack a buffer with them Range ents, whole_range; std::vector< EntityHandle > new_ents; result = mbImpl->get_entities_by_handle( file_set, ents ); RRA( "Getting 3d ents failed." ); ents.insert( file_set ); ParallelComm* pcomm = new ParallelComm( mbImpl, MPI_COMM_WORLD ); ParallelComm::Buffer buff; result = pcomm->pack_buffer( ents, false, true, false, -1, &buff ); RRA( "Packing buffer count (non-stored handles) failed." ); std::vector< std::vector< EntityHandle > > L1hloc, L1hrem; std::vector< std::vector< int > > L1p; std::vector< EntityHandle > L2hloc, L2hrem; std::vector< unsigned int > L2p; buff.reset_ptr(); result = pcomm->unpack_buffer( buff.buff_ptr, false, -1, -1, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents ); RRA( "Unpacking buffer (non-stored handles) failed." ); return MB_SUCCESS; }
const bool debug = false |
Definition at line 24 of file mbparallelcomm_test.cpp.
