mbparallelcomm_test.cpp
00001 /** test of ParallelComm functionality
00002  *
00003  * To run:
00004  *
00005  * mpirun -np <#procs> mbparallelcomm_test
00006  *
00007  */
00008
00009 #include "moab/ParallelComm.hpp"
00010 #include "MBParallelConventions.h"
00011 #include "MBTagConventions.hpp"
00012 #include "moab/Core.hpp"
00013 #include "ScdVertexData.hpp"
00014 #include "StructuredElementSeq.hpp"
00015 #include "SequenceManager.hpp"
00016 #include "moab/Error.hpp"
00017 #include "moab_mpi.h"
00018 #include <iostream>
00019 #include <sstream>
00020 #include <cassert>
00021
00022 #define REALTFI 1
00023
00024 const bool debug = false;
00025
00026 using namespace moab;
00027
00028 #define ERROR( a, b )                    \
00029     {                                    \
00030         std::cerr << ( a ) << std::endl; \
00031         return b;                        \
00032     }
00033
00034 #define PRINT_LAST_ERROR                               \
00035     {                                                  \
00036         std::string last_error;                        \
00037         result = mbImpl->get_last_error( last_error ); \
00038         if( last_error.empty() )                       \
00039             std::cerr << "(none)" << std::endl;        \
00040         else                                           \
00041             std::cerr << last_error << std::endl;      \
00042     }
00043 #define RRA( a )               \
00044     if( MB_SUCCESS != result ) \
00045     {                          \
00046         std::cerr << ( a );    \
00047         return result;         \
00048     }
00049
00050 ErrorCode create_linear_mesh( Interface* mbImpl, int N, int M, int& nshared );
00051
00052 ErrorCode create_scd_mesh( Interface* mbImpl, int IJK, int& nshared );
00053
00054 ErrorCode read_file( Interface* mbImpl,
00055                      std::vector< std::string >& filenames,
00056                      const char* tag_name,
00057                      int tag_val,
00058                      int distrib,
00059                      int parallel_option,
00060                      int resolve_shared,
00061                      int with_ghosts,
00062                      int use_mpio,
00063                      bool print_parallel );
00064
00065 ErrorCode test_packing( Interface* mbImpl, const char* filename );
00066
00067 ErrorCode report_nsets( Interface* mbImpl );
00068
00069 ErrorCode report_iface_ents( Interface* mbImpl, std::vector< ParallelComm* >& pcs );
00070
00071 void print_usage( const char* );
00072
00073 int main( int argc, char** argv )
00074 {
00075     // need to init MPI first, to tell how many procs and rank
00076     MPI_Init( &argc, &argv );
00077
00078     int nprocs, rank;
00079     MPI_Comm_size( MPI_COMM_WORLD, &nprocs );
00080     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00081
00082     // start time
00083     double stime = 0, rtime = 0, dtime = 0, ltime = 0;
00084     if( 0 == rank ) stime = MPI_Wtime();
00085
00086     // create MOAB instance based on that
00087     Interface* mbImpl = new Core;
00088     if( NULL == mbImpl ) return 1;
00089
00090     ErrorCode result = MB_SUCCESS;
00091
00092     // each interior proc has a vector of N+M vertices, sharing
00093     // M vertices each with lower- and upper-rank processors, except
00094     // procs on the end
00095
00096     // get N, M from command line
00097     if( argc < 3 )
00098     {
00099         if( 0 == rank ) print_usage( argv[0] );
00100         MPI_Finalize();
00101         return 1;
00102     }
00103
00104     int npos = 1, tag_val, distrib, with_ghosts = 1, resolve_shared = 1, use_mpio = 0;
00105     bool print_parallel = false;
00106     const char* tag_name;
00107     std::vector< std::string > filenames;
00108     int parallel_option = 0;
00109     int num_files;
00110
00111     if( !strcmp( argv[npos], "-p" ) ) print_parallel = true;
00112
00113     while( npos != argc )
00114     {
00115         ErrorCode tmp_result;
00116         int this_opt = strtol( argv[npos++], NULL, 0 );
00117         switch( this_opt )
00118         {
00119             case 0:
00120             case -1:
00121             case -2:
00122             case -3:
00123                 parallel_option = this_opt;
00124                 continue;
00125
00126             case 3:
00127                 // read a file in parallel from the filename on the command line
00128                 tag_name  = "MATERIAL_SET";
00129                 tag_val   = -1;
00130                 num_files = strtol( argv[npos++], NULL, 0 );
00131                 if( 0 == num_files )
00132                 {
00133                     if( 0 == rank ) print_usage( argv[0] );
00134                     MPI_Finalize();
00135                     return 1;
00136                 }
00137                 while( num_files-- && npos < argc )
00138                     filenames.push_back( std::string( argv[npos++] ) );
00139                 if( npos < argc ) tag_name = argv[npos++];
00140                 if( npos < argc ) tag_val = strtol( argv[npos++], NULL, 0 );
00141                 if( npos < argc )
00142                     distrib = strtol( argv[npos++], NULL, 0 );
00143                 else
00144                     distrib = 1;
00145                 if( npos < argc ) resolve_shared = strtol( argv[npos++], NULL, 0 );
00146                 if( npos < argc ) with_ghosts = strtol( argv[npos++], NULL, 0 );
00147                 if( npos < argc ) use_mpio = strtol( argv[npos++], NULL, 0 );
00148
00149                 tmp_result = read_file( mbImpl, filenames, tag_name, tag_val, distrib, parallel_option, resolve_shared,
00150                                         with_ghosts, use_mpio, print_parallel );
00151                 if( MB_SUCCESS != tmp_result )
00152                 {
00153                     result = tmp_result;
00154                     std::cerr << "Couldn't read mesh; error message:" << std::endl;
00155                     PRINT_LAST_ERROR;
00156                     MPI_Abort( MPI_COMM_WORLD, result );
00157                 }
00158                 break;
00159
00160             case 4:
00161                 filenames.push_back( argv[npos++] );
00162                 tmp_result = test_packing( mbImpl, filenames[0].c_str() );
00163                 if( MB_SUCCESS != tmp_result )
00164                 {
00165                     result = tmp_result;
00166                     std::cerr << "Packing test failed; error message:" << std::endl;
00167                     PRINT_LAST_ERROR
00168                 }
00169                 break;
00170
00171             case 5:
00172                 // read a file in parallel from the filename on the command line
00173                 tag_name       = "MATERIAL_SET";
00174                 distrib        = 1;
00175                 tag_val        = -1;
00176                 with_ghosts    = 0;
00177                 resolve_shared = 1;
00178                 while( npos < argc )
00179                     filenames.push_back( std::string( argv[npos++] ) );
00180                 tmp_result = read_file( mbImpl, filenames, tag_name, tag_val, distrib, parallel_option, resolve_shared,
00181                                         with_ghosts, use_mpio, print_parallel );
00182                 if( MB_SUCCESS != tmp_result )
00183                 {
00184                     result = tmp_result;
00185                     std::cerr << "Couldn't read mesh; error message:" << std::endl;
00186                     PRINT_LAST_ERROR;
00187                     MPI_Abort( MPI_COMM_WORLD, result );
00188                 }
00189                 break;
00190
00191             default:
00192                 std::cerr << "Unrecognized option \"" << this_opt << "\"; skipping." << std::endl;
00193                 tmp_result = MB_FAILURE;
00194         }
00195
00196         if( 0 == rank ) rtime = MPI_Wtime();
00197     }
00198
00199     if( 0 == rank ) dtime = MPI_Wtime();
00200
00201     result = mbImpl->delete_mesh();
00202     if( MB_SUCCESS != result )
00203     {
00204         std::cerr << "Couldn't delete mesh on rank " << rank << "; error message: " << std::endl;
00205         PRINT_LAST_ERROR;
00206     }
00207     if( 0 == rank ) ltime = MPI_Wtime();
00208
00209     if( MB_SUCCESS == result ) std::cerr << "Proc " << rank << ": Success." << std::endl;
00210
00211     if( 0 == rank )
00212         std::cout << "Times: " << dtime - stime << " " << rtime - stime << " " << ltime - dtime
00213                   << " (total/read/delete)" << std::endl;
00214
00215     MPI_Finalize();
00216
00217     delete mbImpl;
00218
00219     return ( MB_SUCCESS == result ? 0 : 1 );
00220 }
00221
00222 void print_usage( const char* command )
00223 {
00224     std::cerr << "Usage: " << command << " [readpar_option] <opt> <input> [...] where:" << std::endl
00225               << " readpar_option = 0 (BCAST_DELETE) (default), -1 (READ_DELETE), " << std::endl
00226               << "                 -2 (READ_PARALLEL), -3 (BCAST)" << std::endl
00227               << "opt   input" << std::endl
00228               << "===   =====" << std::endl
00229               << " 1     <linear_ints> <shared_verts> " << std::endl
00230               << " 2     <n_ints> " << std::endl
00231               << " 3*    <# files> <file_names...> [<tag_name>=\"MATERIAL_SET\" [tag_val] "
00232                  "[distribute=1] [resolve_shared=1] [with_ghosts=1] [use_mpio=0]"
00233               << std::endl
00234               << " 4    <file_name> " << std::endl
00235               << "*Note: if opt 3 is used, it must be the last one." << std::endl;
00236 }
00237
00238 ErrorCode report_nsets( Interface* mbImpl )
00239 {
00240     // get and report various numbers...
00241     int rank;
00242     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00243
00244     Range matsets, geomsets, parsets;
00245     int nsets;
00246     Tag mtag = 0, gtag = 0, ptag = 0, gidtag;
00247     ErrorCode result = mbImpl->tag_get_handle( "MATERIAL_SET", 1, MB_TYPE_INTEGER, mtag );
00248     if( MB_SUCCESS != result )
00249     {
00250         std::cerr << "Couldn't get MATERIAL_SET tag." << std::endl;
00251         return result;
00252     }
00253     result = mbImpl->tag_get_handle( "GEOM_DIMENSION", 1, MB_TYPE_INTEGER, gtag );
00254     if( MB_SUCCESS != result )
00255     {
00256         std::cerr << "Couldn't get MATERIAL_SET tag." << std::endl;
00257         return result;
00258     }
00259     result = mbImpl->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, ptag );
00260     if( MB_SUCCESS != result )
00261     {
00262         std::cerr << "Couldn't PARALLEL_PARTITION tag." << std::endl;
00263         return result;
00264     }
00265     result = mbImpl->tag_get_handle( "GLOBAL_ID", 1, MB_TYPE_INTEGER, gidtag );
00266     if( MB_SUCCESS != result )
00267     {
00268         std::cerr << "Couldn't get GLOBAL_ID tag." << std::endl;
00269         return result;
00270     }
00271     result = mbImpl->get_number_entities_by_type( 0, MBENTITYSET, nsets );
00272     if( MB_SUCCESS != result )
00273     {
00274         std::cerr << "Couldn't get number entities by type." << std::endl;
00275         return result;
00276     }
00277     std::cout << "Proc " << rank << ": Total of " << nsets << " entity sets." << std::endl;
00278
00279 #define PRINTSETS( a, b, c, p )        \
00280     if( a )        \
00281     {        \
00282         result = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, &( a ), p, 1, b );                       \
00283         if( !( b ).empty() )        \
00284         {        \
00285             std::vector< int > ids( ( b ).size() );                                                             \
00286             result = mbImpl->tag_get_data( gidtag, b, &ids[0] );                                                \
00287             if( MB_SUCCESS == result )        \
00288             {        \
00289                 std::cout << "Proc " << rank << ": " << ( c ) << " (total " << ( b ).size() << "): " << ids[0]; \
00290                 for( unsigned int i = 1; i < ( b ).size(); i++ )                                                \
00291                     std::cout << ", " << ids[i];        \
00292                 std::cout << std::endl;        \
00293             }        \
00294         }        \
00295     }
00296
00297     PRINTSETS( mtag, matsets, "material sets", NULL );
00298
00299     int tval   = 3;
00300     void* pval = &tval;
00301
00302     PRINTSETS( gtag, geomsets, "geom sets (vols)", &pval );
00303     tval = 2;
00304     geomsets.clear();
00305     PRINTSETS( gtag, geomsets, "geom sets (surfs)", &pval );
00306     tval = 1;
00307     geomsets.clear();
00308     PRINTSETS( gtag, geomsets, "geom sets (curves)", &pval );
00309     tval = 0;
00310     geomsets.clear();
00311     PRINTSETS( gtag, geomsets, "geom sets (verts)", &pval );
00312
00313     PRINTSETS( ptag, parsets, "partition sets", NULL );
00314
00315     if( debug )
00316     {
00317         // list info on all ent sets, reuse parsets
00318         parsets.clear();
00319         result = mbImpl->get_entities_by_type( 0, MBENTITYSET, parsets );
00320         if( MB_SUCCESS == result )
00321         {
00322             std::cout << "Total sets (by range): " << parsets.size() << "; sets: " << std::endl;
00323             parsets.print( "  " );
00324             mbImpl->list_entities( parsets );
00325         }
00326     }
00327
00328     return MB_SUCCESS;
00329 }
00330
00331 ErrorCode read_file( Interface* mbImpl,
00332                      std::vector< std::string >& filenames,
00333                      const char* tag_name,
00334                      int tag_val,
00335                      int distrib,
00336                      int parallel_option,
00337                      int resolve_shared,
00338                      int with_ghosts,
00339                      int use_mpio,
00340                      bool print_parallel )
00341 {
00342     std::ostringstream options;
00343     switch( parallel_option )
00344     {
00345         case 0:
00346             options << "PARALLEL=BCAST_DELETE;PARTITION=" << tag_name;
00347             break;
00348         case -1:
00349             options << "PARALLEL=READ_DELETE;PARTITION=" << tag_name;
00350             break;
00351         case -2:
00352             options << "PARALLEL=READ_PART;PARTITION=" << tag_name;
00353             break;
00354         case -3:
00355             options << "PARALLEL=BCAST;PARTITION=" << tag_name;
00356             break;
00357         default:
00358             return MB_FAILURE;
00359     }
00360
00361     if( -1 != tag_val ) options << ";PARTITION_VAL=" << tag_val;
00362
00363     if( 1 == distrib ) options << ";PARTITION_DISTRIBUTE";
00364
00365     if( 1 == resolve_shared ) options << ";PARALLEL_RESOLVE_SHARED_ENTS";
00366
00367     if( 1 == with_ghosts ) options << ";PARALLEL_GHOSTS=3.0.1";
00368
00369     if( 1 == use_mpio ) options << ";USE_MPIO";
00370
00371     options << ";CPUTIME";
00372
00373     if( print_parallel ) options << ";PRINT_PARALLEL";
00374
00375     std::vector< ParallelComm* > pcs( filenames.size() );
00376     ErrorCode result = MB_FAILURE;
00377
00378     if( 1 < filenames.size() )
00379     {
00380         for( unsigned int i = 0; i < filenames.size(); i++ )
00381         {
00382             pcs[i]    = new ParallelComm( mbImpl, MPI_COMM_WORLD );
00383             int index = pcs[i]->get_id();
00384             std::ostringstream newopts;
00385             newopts << options.str();
00386             newopts << ";PARALLEL_COMM=" << index;
00387             result = mbImpl->load_file( filenames[i].c_str(), 0, newopts.str().c_str() );
00388
00389             if( MB_SUCCESS != result ) PRINT_LAST_ERROR;
00390
00391             if( MB_SUCCESS != result )
00392             {
00393                 MPI_Abort( MPI_COMM_WORLD, result );
00394                 break;
00395             }
00396
00397             // exchange tag
00398             Range tmp_range;
00399             result = pcs[i]->exchange_tags( "GLOBAL_ID", tmp_range );
00400             if( MB_SUCCESS != result )
00401             {
00402                 std::cerr << "Tag exchange didn't work." << std::endl;
00403                 break;
00404             }
00405         }
00406     }
00407     else
00408     {
00409         result = mbImpl->load_file( filenames[0].c_str(), 0, options.str().c_str() );
00410         RRA( "Failed to load file." );
00411         pcs[0] = ParallelComm::get_pcomm( mbImpl, 0 );
00412         assert( pcs[0] );
00413     }
00414
00415     if( MB_SUCCESS == result ) report_iface_ents( mbImpl, pcs );
00416
00417     return result;
00418 }
00419
00420 ErrorCode test_packing( Interface* mbImpl, const char* filename )
00421 {
00422     // read the mesh
00423     EntityHandle file_set;
00424     ErrorCode result = mbImpl->create_meshset( MESHSET_SET, file_set );
00425     RRA( "create_meshset failed." );
00426
00427     result = mbImpl->load_file( filename, &file_set, NULL );
00428     if( MB_SUCCESS != result )
00429     {
00430         std::cerr << "Reading file failed; message:" << std::endl;
00431         PRINT_LAST_ERROR;
00432         return result;
00433     }
00434
00435     // get 3d entities and pack a buffer with them
00436     Range ents, whole_range;
00437     std::vector< EntityHandle > new_ents;
00438     result = mbImpl->get_entities_by_handle( file_set, ents );
00439     RRA( "Getting 3d ents failed." );
00440
00441     ents.insert( file_set );
00442
00443     ParallelComm* pcomm = new ParallelComm( mbImpl, MPI_COMM_WORLD );
00444
00445     ParallelComm::Buffer buff;
00446     result = pcomm->pack_buffer( ents, false, true, false, -1, &buff );
00447     RRA( "Packing buffer count (non-stored handles) failed." );
00448
00449     std::vector< std::vector< EntityHandle > > L1hloc, L1hrem;
00450     std::vector< std::vector< int > > L1p;
00451     std::vector< EntityHandle > L2hloc, L2hrem;
00452     std::vector< unsigned int > L2p;
00453
00454     buff.reset_ptr();
00455     result = pcomm->unpack_buffer( buff.buff_ptr, false, -1, -1, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents );
00456     RRA( "Unpacking buffer (non-stored handles) failed." );
00457
00458     return MB_SUCCESS;
00459 }
00460
00461 ErrorCode report_iface_ents( Interface* mbImpl, std::vector< ParallelComm* >& pcs )
00462 {
00463     Range iface_ents[6];
00464     ErrorCode result = MB_SUCCESS, tmp_result;
00465
00466     // now figure out which vertices are shared
00467     Range part_ents, part_verts;
00468     for( unsigned int p = 0; p < pcs.size(); p++ )
00469     {
00470         // get entities owned by this partition
00471         for( Range::iterator rit = pcs[p]->partition_sets().begin(); rit != pcs[p]->partition_sets().end(); ++rit )
00472         {
00473             tmp_result = mbImpl->get_entities_by_dimension( *rit, 3, part_ents, true );
00474             if( MB_SUCCESS != tmp_result ) result = tmp_result;
00475         }
00476
00477         for( int i = 0; i < 4; i++ )
00478         {
00479             tmp_result = pcs[p]->get_iface_entities( -1, i, iface_ents[i] );
00480
00481             if( MB_SUCCESS != tmp_result )
00482             {
00483                 std::cerr << "get_iface_entities returned error on proc " << pcs[p]->proc_config().proc_rank()
00484                           << "; message: " << std::endl;
00485                 std::string last_error;
00486                 result = mbImpl->get_last_error( last_error );
00487                 if( last_error.empty() )
00488                     std::cerr << "(none)" << std::endl;
00489                 else
00490                     std::cerr << last_error << std::endl;
00491                 result = tmp_result;
00492             }
00493             if( 0 != i ) iface_ents[4].merge( iface_ents[i] );
00494         }
00495     }
00496
00497     // get non-owned vertices
00498     result = pcs[0]->get_pstatus_entities( 0, PSTATUS_NOT_OWNED, part_verts );
00499     if( MB_SUCCESS != result )
00500     {
00501         std::cerr << "Couldn't get non-owned entities." << std::endl;
00502         return result;
00503     }
00504     int tot_verts;
00505     result = mbImpl->get_number_entities_by_dimension( 0, 0, tot_verts );
00506     if( MB_SUCCESS != result )
00507     {
00508         std::cerr << "Couldn't get number of vertices." << std::endl;
00509         return result;
00510     }
00511     tot_verts -= part_verts.size();
00512
00513     // report # iface entities
00514     result = mbImpl->get_adjacencies( iface_ents[4], 0, false, iface_ents[5], Interface::UNION );
00515
00516     int rank;
00517     MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00518
00519     std::cerr << "Proc " << rank << " iface entities: " << std::endl;
00520     for( int i = 0; i < 4; i++ )
00521         std::cerr << "    " << iface_ents[i].size() << " " << i << "d iface entities." << std::endl;
00522     std::cerr << "    (" << iface_ents[5].size() << " verts adj to other iface ents)" << std::endl;
00523     if( iface_ents[0].size() != iface_ents[5].size() )
00524         std::cerr << "WARNING: number of interface vertices don't agree with "
00525                   << "vertex adjacencies on interface entities." << std::endl;
00526
00527     // report # regions owned by this proc
00528     std::cout << "Proc " << rank << " owns " << part_ents.size() << " 3d entities." << std::endl;
00529
00530     // get total # regions over all procs
00531     int num_local[2], num_total[2];
00532     num_local[0] = tot_verts;
00533     num_local[1] = part_ents.size();
00534
00535     int failure = MPI_Reduce( num_local, num_total, 2, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD );
00536     if( failure ) result = MB_FAILURE;
00537
00538     if( 0 == rank )
00539     {
00540         std::cout << "Total # owned vertices = " << num_total[0] << std::endl;
00541         std::cout << "Total # owned regions = " << num_total[1] << std::endl;
00542     }
00543
00544     return result;
00545 }
