Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"
#include "moab/ProgOptions.hpp"
#include "moab/ReorderTool.hpp"
#include <iostream>
#include <sstream>
#include <cmath>
#include <cstdlib>
#include <list>
#include <ctime>
#include "moab/IntxMesh/IntxUtils.hpp"
Typedefs | |
typedef int | PartType |
Functions | |
int | main (int argc, char *argv[]) |
Variables | |
std::string | DEFAULT_TAGGEDSETS_TAG = "PARALLEL_PARTITION" |
const char | DEFAULT_ZOLTAN_METHOD [] = "RCB" |
const char | METIS_DEFAULT_METHOD [] = "ML_KWAY" |
const char | BRIEF_DESC [] = "Use Zoltan or Metis to partition MOAB meshes for use on parallel computers" |
std::ostringstream | LONG_DESC |
typedef int PartType |
Definition at line 23 of file mbpart.cpp.
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 51 of file mbpart.cpp.
References ProgOptions::addOpt(), BRIEF_DESC, moab::Interface::create_meshset(), DEFAULT_TAGGEDSETS_TAG, DEFAULT_ZOLTAN_METHOD, dim, ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_dimension(), moab::ReorderTool::handle_order_from_int_tag(), moab::ReorderTool::handle_order_from_sets_and_adj(), ZoltanPartitioner::include_closure(), input_file, ProgOptions::int_flag, moab::Interface::load_file(), moab::Interface::load_mesh(), LONG_DESC, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MB_SET_ERR, MB_SUCCESS, MB_TYPE_INTEGER, MBENTITYSET, MESHSET_SET, METIS_DEFAULT_METHOD, ZoltanPartitioner::partition_inferred_mesh(), MetisPartitioner::partition_mesh(), ZoltanPartitioner::partition_mesh_and_geometry(), print_time(), moab::ReorderTool::reorder_entities(), moab::IntxUtils::ScaleToRadius(), PartitionerBase< T >::set_global_id_option(), moab::Range::size(), t, moab::Interface::tag_delete(), moab::Interface::tag_get_handle(), and moab::Interface::write_file().
{ #ifdef MOAB_HAVE_MPI int err = MPI_Init( &argc, &argv ); if( err ) { std::cerr << "MPI_Init failed. Aborting." << std::endl; return 3; } #endif Core moab; Interface& mb = moab; std::vector< int > set_l; #ifdef MOAB_HAVE_ZOLTAN bool moab_use_zoltan = false; #endif #ifdef MOAB_HAVE_METIS bool moab_use_metis = false; #endif LONG_DESC << "This utility invokes the ZoltanPartitioner or MetisPartitioner component of MOAB/CGM " "to partition a mesh/geometry." << std::endl << "If no partitioning method is specified, the defaults are: " << "for Zoltan=\"" << DEFAULT_ZOLTAN_METHOD << "\" and Metis=\"" << METIS_DEFAULT_METHOD << " method" << std::endl; ProgOptions opts( LONG_DESC.str(), BRIEF_DESC ); int part_dim = 3; opts.addOpt< int >( "dimension", "Specify dimension of entities to partition." " Default is largest in file.", &part_dim, ProgOptions::int_flag ); std::string zoltan_method, parm_method, oct_method, metis_method; #ifdef MOAB_HAVE_ZOLTAN opts.addOpt< std::string >( "zoltan,z", "(Zoltan) Specify Zoltan partition method. " "One of RR, RCB, RIB, HFSC, PHG, or Hypergraph (PHG and Hypergraph " "are synonymous).", &zoltan_method ); #ifdef MOAB_HAVE_PARMETIS opts.addOpt< std::string >( "parmetis,p", "(Zoltan+PARMetis) Specify PARMetis partition method.", &parm_method ); #endif // MOAB_HAVE_PARMETIS opts.addOpt< std::string >( "octpart,o", "(Zoltan) Specify OctPart partition method.", &oct_method ); bool incl_closure = false; opts.addOpt< void >( "include_closure,c", "Include element closure for part sets.", &incl_closure ); bool recompute_box_rcb = false; opts.addOpt< void >( "recompute_rcb_box,b", "recompute box in rcb cuts", &recompute_box_rcb ); #endif // MOAB_HAVE_ZOLTAN double imbal_tol = 1.03; opts.addOpt< double >( "imbalance,i", "Imbalance tolerance (used in PHG/Hypergraph method)", &imbal_tol ); #ifdef MOAB_HAVE_METIS opts.addOpt< std::string >( "metis,m", "(Metis) Specify Metis partition method. One of ML_RB or ML_KWAY.", &metis_method ); #endif // MOAB_HAVE_METIS bool write_sets = true, write_tags = false; opts.addOpt< void >( "sets,s", "Write partition as tagged sets (Default)", &write_sets ); opts.addOpt< void >( "tags,t", "Write partition by tagging entities", &write_tags ); int power = -1; opts.addOpt< int >( "power,M", "Generate multiple partitions, in powers of 2, up to 2^(pow)", &power ); bool reorder = false; opts.addOpt< void >( "reorder,R", "Reorder mesh to group entities by partition", &reorder ); double part_geom_mesh_size = -1.0; #ifdef MOAB_HAVE_ZOLTAN bool part_surf = false; #ifdef MOAB_HAVE_CGM opts.addOpt< double >( "geom,g", "(CGM) If partition geometry, specify mesh size.", &part_geom_mesh_size ); opts.addOpt< void >( "surf,f", "(CGM) Specify if partition geometry surface.", &part_surf ); #endif // MOAB_HAVE_CGM bool ghost = false; opts.addOpt< void >( "ghost,H", "(Zoltan) Specify if partition ghost geometry body." ); int obj_weight = 0; opts.addOpt< int >( "vertex_w,v", "(Zoltan) Number of weights associated with a graph vertex." ); int edge_weight = 0; opts.addOpt< int >( "edge_w,e", "(Zoltan) Number of weights associated with an edge." ); bool moab_partition_slave = false; std::string slave_file_name = ""; opts.addOpt< std::string >( "inferred", "(Zoltan) Specify inferred slave mesh file name to impose " "partition based on cuts computed for original master mesh.", &slave_file_name ); bool rescale_spherical_radius = false; opts.addOpt< void >( "scale_sphere", "(Zoltan) If the meshes are defined on a sphere, rescale radius as needed " "(in combination with --inferred)", &rescale_spherical_radius ); #endif // MOAB_HAVE_ZOLTAN long num_parts; opts.addOpt< std::vector< int > >( "set_l,l", "Load material set(s) with specified ids (comma separated) for partition" ); opts.addRequiredArg< int >( "#parts", "Number of parts in partition" ); std::string input_file, output_file; opts.addRequiredArg< std::string >( "input_file", "Mesh/geometry to partition", &input_file ); opts.addRequiredArg< std::string >( "output_file", "File to which to write partitioned mesh/geometry", &output_file ); bool print_time = false; opts.addOpt< void >( ",T", "Print CPU time for each phase.", &print_time ); int projection_type = 0; opts.addOpt< int >( "project_on_sphere,p", "use spherical coordinates (1) or gnomonic projection (2) for partitioning ", &projection_type ); #ifdef MOAB_HAVE_METIS bool partition_tagged_sets = false; opts.addOpt< void >( "taggedsets,x", "(Metis) Partition tagged sets.", &partition_tagged_sets ); bool partition_tagged_ents = false; opts.addOpt< void >( "taggedents,y", "(Metis) Partition tagged ents.", &partition_tagged_ents ); std::string aggregating_tag; opts.addOpt< std::string >( "aggregatingtag,a", "(Metis) Specify aggregating tag to partion tagged sets or tagged entities.", &aggregating_tag ); std::string aggregating_bc_tag; opts.addOpt< std::string >( "aggregatingBCtag,B", "(Metis) Specify boundary id tag name used to group cells with same boundary ids.", &aggregating_bc_tag ); std::string boundaryIds; std::vector< int > BCids; opts.addOpt< std::string >( "aggregatingBCids,I", " (Metis) Specify id or ids of boundaries to be aggregated before " "partitioning (all elements with same boundary id will be in the " "same partition). Comma separated e.g. -I 1,2,5 ", &boundaryIds ); #endif // MOAB_HAVE_METIS bool assign_global_ids = false; opts.addOpt< void >( "globalIds,j", "Assign GLOBAL_ID tag to entities", &assign_global_ids ); opts.parseCommandLine( argc, argv ); #ifdef MOAB_HAVE_ZOLTAN if( !zoltan_method.empty() ) moab_use_zoltan = true; else #endif #ifdef MOAB_HAVE_METIS if( !metis_method.empty() ) moab_use_metis = true; else #endif MB_SET_ERR( MB_FAILURE, "Specify either Zoltan or Metis partitioner type" ); #ifdef MOAB_HAVE_ZOLTAN ZoltanPartitioner* zoltan_tool = NULL; // check if partition geometry, if it is, should get mesh size for the geometry if( part_geom_mesh_size != -1.0 && part_geom_mesh_size <= 0.0 ) { std::cerr << part_geom_mesh_size << ": invalid geometry partition mesh size." << std::endl << std::endl; opts.printHelp(); return EXIT_FAILURE; } if( slave_file_name.size() ) moab_partition_slave = true; if( moab_use_zoltan ) { if( part_geom_mesh_size < 0. ) { // partition mesh we have no ParallelComm here, so we will create one later zoltan_tool = new ZoltanPartitioner( &mb, NULL, false, argc, argv ); } else { // partition geometry #ifdef MOAB_HAVE_CGM CubitStatus status = InitCGMA::initialize_cgma(); if( CUBIT_SUCCESS != status ) { std::cerr << "CGM couldn't be initialized." << std::endl << std::endl; opts.printHelp(); return EXIT_FAILURE; } GeometryQueryTool* gti = GeometryQueryTool::instance(); // no ParallelComm so far zoltan_tool = new ZoltanPartitioner( &mb, NULL, false, argc, argv, gti ); #else std::cerr << "CGM should be configured to partition geometry." << std::endl << std::endl; opts.printHelp(); return EXIT_FAILURE; #endif // MOAB_HAVE_CGM } zoltan_tool->set_global_id_option( assign_global_ids ); } if( zoltan_method.empty() && parm_method.empty() && oct_method.empty() ) zoltan_method = DEFAULT_ZOLTAN_METHOD; if( !parm_method.empty() ) zoltan_method = ZOLTAN_PARMETIS_METHOD; if( !oct_method.empty() ) zoltan_method = ZOLTAN_OCTPART_METHOD; #endif // MOAB_HAVE_ZOLTAN #ifdef MOAB_HAVE_METIS MetisPartitioner* metis_tool = NULL; if( moab_use_metis && !metis_tool ) { metis_tool = new MetisPartitioner( &mb, false ); metis_tool->set_global_id_option( assign_global_ids ); } if( ( aggregating_tag.empty() && partition_tagged_sets ) || ( aggregating_tag.empty() && partition_tagged_ents ) ) aggregating_tag = DEFAULT_TAGGEDSETS_TAG; if( !write_sets && !write_tags ) write_sets = true; if( !boundaryIds.empty() ) { std::vector< std::string > ids; std::stringstream ss( boundaryIds ); std::string item; while( std::getline( ss, item, ',' ) ) { ids.push_back( item ); } for( unsigned int i = 0; i < ids.size(); i++ ) BCids.push_back( std::atoi( ids[i].c_str() ) ); } if( metis_method.empty() ) { metis_method = METIS_DEFAULT_METHOD; } #endif // MOAB_HAVE_METIS if( !write_sets && !write_tags ) write_sets = true; if( -1 == power ) { num_parts = opts.getReqArg< int >( "#parts" ); power = 1; } else if( power < 1 || power > 18 ) { std::cerr << power << ": invalid power for multiple partitions. Expected value in [1,18]" << std::endl << std::endl; opts.printHelp(); return EXIT_FAILURE; } else { num_parts = 2; } if( part_dim < 0 || part_dim > 3 ) { std::cerr << part_dim << " : invalid dimension" << std::endl << std::endl; opts.printHelp(); return EXIT_FAILURE; } if( imbal_tol < 0.0 ) { std::cerr << imbal_tol << ": invalid imbalance tolerance" << std::endl << std::endl; opts.printHelp(); return EXIT_FAILURE; } bool load_msets = false; if( opts.getOpt( "set_l,l", &set_l ) ) { load_msets = true; if( set_l.size() <= 0 ) { std::cerr << " No material set id's to load" << std::endl << std::endl; opts.printHelp(); return EXIT_FAILURE; } } if( num_parts <= 1 ) { std::cerr << "** Please specify #parts = " << num_parts << " to be greater than 1." << std::endl << std::endl; opts.printHelp(); return EXIT_FAILURE; } clock_t t = clock(); const char* options = NULL; ErrorCode rval; #ifdef MOAB_HAVE_ZOLTAN if( part_geom_mesh_size > 0. ) options = "FACET_DISTANCE_TOLERANCE=0.1"; #endif // MOAB_HAVE_ZOLTAN std::cout << "Loading file " << input_file << "..." << std::endl; if( load_msets == false ) { rval = mb.load_file( input_file.c_str(), 0, options );MB_CHK_SET_ERR( rval, "Failed to load input file: " + input_file ); } else // load the material set(s) { rval = mb.load_mesh( input_file.c_str(), &set_l[0], (int)set_l.size() );MB_CHK_SET_ERR( rval, "Failed to load input mesh: " + input_file ); } if( print_time ) std::cout << "Read input file in " << ( clock() - t ) / (double)CLOCKS_PER_SEC << " seconds" << std::endl; for( int dim = part_dim; dim >= 0; --dim ) { int n; rval = mb.get_number_entities_by_dimension( 0, dim, n ); if( MB_SUCCESS == rval && 0 != n ) { part_dim = dim; break; } } if( part_dim < 0 ) { std::cerr << input_file << " : file does not contain any mesh entities" << std::endl; return 2; } ReorderTool reorder_tool( &moab ); for( int p = 0; p < power; p++ ) { t = clock(); #ifdef MOAB_HAVE_ZOLTAN if( moab_use_zoltan ) { rval = zoltan_tool->partition_mesh_and_geometry( part_geom_mesh_size, num_parts, zoltan_method.c_str(), ( !parm_method.empty() ? parm_method.c_str() : oct_method.c_str() ), imbal_tol, part_dim, write_sets, write_tags, obj_weight, edge_weight, part_surf, ghost, projection_type, recompute_box_rcb, print_time );MB_CHK_SET_ERR( rval, "Zoltan partitioner failed." ); } #endif #ifdef MOAB_HAVE_METIS if( moab_use_metis ) { rval = metis_tool->partition_mesh( num_parts, metis_method.c_str(), part_dim, write_sets, write_tags, partition_tagged_sets, partition_tagged_ents, aggregating_tag.c_str(), print_time );MB_CHK_SET_ERR( rval, "Metis partitioner failed." ); } #endif if( print_time ) std::cout << "Generated " << num_parts << " part partitioning in " << ( clock() - t ) / (double)CLOCKS_PER_SEC << " seconds" << std::endl; if( reorder && part_geom_mesh_size < 0. ) { std::cout << "Reordering mesh for partition..." << std::endl; Tag tag, order; rval = mb.tag_get_handle( DEFAULT_TAGGEDSETS_TAG.c_str(), 1, MB_TYPE_INTEGER, tag );MB_CHK_SET_ERR( rval, "Partitioner did not create " + DEFAULT_TAGGEDSETS_TAG + " tag" ); t = clock(); if( write_sets ) { Range sets; mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, sets ); rval = reorder_tool.handle_order_from_sets_and_adj( sets, order );MB_CHK_SET_ERR( rval, "Failed to calculate reordering." ); } else { rval = reorder_tool.handle_order_from_int_tag( tag, -1, order );MB_CHK_SET_ERR( rval, "Failed to calculate reordering." ); } rval = reorder_tool.reorder_entities( order );MB_CHK_SET_ERR( rval, "Failed to perform reordering." ); rval = mb.tag_delete( order );MB_CHK_SET_ERR( rval, "Failed to delete tag." ); if( print_time ) std::cout << "Reordered mesh in " << ( clock() - t ) / (double)CLOCKS_PER_SEC << " seconds" << std::endl; } #ifdef MOAB_HAVE_ZOLTAN if( incl_closure ) { rval = zoltan_tool->include_closure();MB_CHK_SET_ERR( rval, "Closure inclusion failed." ); } #endif std::ostringstream tmp_output_file; if( power > 1 ) { // append num_parts to output filename std::string::size_type idx = output_file.find_last_of( "." ); if( idx == std::string::npos ) { tmp_output_file << output_file << "_" << num_parts; if( part_geom_mesh_size < 0. ) tmp_output_file << ".h5m"; else { std::cerr << "output file type is not specified." << std::endl; return 1; } } else { tmp_output_file << output_file.substr( 0, idx ) << "_" << num_parts << output_file.substr( idx ); } } else tmp_output_file << output_file; t = clock(); std::cout << "Saving file to " << output_file << "..." << std::endl; if( part_geom_mesh_size < 0. ) { rval = mb.write_file( tmp_output_file.str().c_str() );MB_CHK_SET_ERR( rval, tmp_output_file.str() << " : failed to write file." << std::endl ); } #ifdef MOAB_HAVE_ZOLTAN #ifdef MOAB_HAVE_CGM else { std::string::size_type idx = output_file.find_last_of( "." ); int c_size = output_file.length() - idx; const char* file_type = NULL; if( output_file.compare( idx, c_size, ".occ" ) == 0 || output_file.compare( idx, c_size, ".OCC" ) == 0 ) file_type = "OCC"; else if( output_file.compare( idx, c_size, ".sab" ) == 0 ) file_type = "ACIS_SAB"; else if( output_file.compare( idx, c_size, ".sat" ) == 0 ) file_type = "ACIS_SAT"; else { std::cerr << "File type for " << output_file.c_str() << " not supported." << std::endl; return 1; } int num_ents_exported = 0; DLIList< RefEntity* > ref_entity_list; CubitStatus status = CubitCompat_export_solid_model( ref_entity_list, tmp_output_file.str().c_str(), file_type, num_ents_exported, CubitString( __FILE__ ) ); if( CUBIT_SUCCESS != status ) { std::cerr << "CGM couldn't export models." << std::endl; return 1; } } #endif #endif if( print_time ) std::cout << "Wrote \"" << tmp_output_file.str() << "\" in " << ( clock() - t ) / (double)CLOCKS_PER_SEC << " seconds" << std::endl; #ifdef MOAB_HAVE_ZOLTAN if( moab_use_zoltan && moab_partition_slave && p == 0 ) { t = clock(); double master_radius, slave_radius; if( rescale_spherical_radius ) { EntityHandle rootset = 0; Range masterverts; rval = mb.get_entities_by_dimension( rootset, 0, masterverts );MB_CHK_SET_ERR( rval, "Can't create vertices on master set" ); double points[6]; EntityHandle mfrontback[2] = { masterverts[0], masterverts[masterverts.size() - 1] }; rval = mb.get_coords( &mfrontback[0], 2, points );MB_CHK_ERR( rval ); const double mr1 = std::sqrt( points[0] * points[0] + points[1] * points[1] + points[2] * points[2] ); const double mr2 = std::sqrt( points[3] * points[3] + points[4] * points[4] + points[5] * points[5] ); master_radius = 0.5 * ( mr1 + mr2 ); } EntityHandle slaveset; rval = mb.create_meshset( moab::MESHSET_SET, slaveset );MB_CHK_SET_ERR( rval, "Can't create new set" ); rval = mb.load_file( slave_file_name.c_str(), &slaveset, options );MB_CHK_SET_ERR( rval, "Can't load slave mesh" ); if( rescale_spherical_radius ) { double points[6]; Range slaveverts; rval = mb.get_entities_by_dimension( slaveset, 0, slaveverts );MB_CHK_SET_ERR( rval, "Can't create vertices on master set" ); EntityHandle sfrontback[2] = { slaveverts[0], slaveverts[slaveverts.size() - 1] }; rval = mb.get_coords( &sfrontback[0], 2, points );MB_CHK_ERR( rval ); const double sr1 = std::sqrt( points[0] * points[0] + points[1] * points[1] + points[2] * points[2] ); const double sr2 = std::sqrt( points[3] * points[3] + points[4] * points[4] + points[5] * points[5] ); slave_radius = 0.5 * ( sr1 + sr2 ); // Let us rescale both master and slave meshes to a unit sphere rval = moab::IntxUtils::ScaleToRadius( &mb, slaveset, master_radius );MB_CHK_ERR( rval ); } rval = zoltan_tool->partition_inferred_mesh( slaveset, num_parts, part_dim, write_sets, projection_type );MB_CHK_ERR( rval ); if( rescale_spherical_radius ) { // rescale the slave mesh back to its original radius rval = moab::IntxUtils::ScaleToRadius( &mb, slaveset, slave_radius );MB_CHK_ERR( rval ); } if( print_time ) { std::cout << "Time taken to infer slave mesh partitions = " << ( clock() - t ) / (double)CLOCKS_PER_SEC << " seconds" << std::endl; } size_t lastindex = slave_file_name.find_last_of( "." ); std::string inferred_output_file = slave_file_name.substr( 0, lastindex ) + "_inferred" + slave_file_name.substr( lastindex, slave_file_name.size() ); // Save the resulting mesh std::cout << "Saving inferred file to " << inferred_output_file << "..." << std::endl; rval = mb.write_file( inferred_output_file.c_str(), 0, 0, &slaveset, 1 );MB_CHK_SET_ERR( rval, inferred_output_file << " : failed to write file." << std::endl ); } #endif num_parts *= 2; } #ifdef MOAB_HAVE_ZOLTAN delete zoltan_tool; #endif #ifdef MOAB_HAVE_METIS delete metis_tool; #endif #ifdef MOAB_HAVE_MPI err = MPI_Finalize(); assert( MPI_SUCCESS == err ); #endif return 0; }
const char BRIEF_DESC[] = "Use Zoltan or Metis to partition MOAB meshes for use on parallel computers" |
Definition at line 48 of file mbpart.cpp.
std::string DEFAULT_TAGGEDSETS_TAG = "PARALLEL_PARTITION" |
Definition at line 37 of file mbpart.cpp.
Referenced by main().
const char DEFAULT_ZOLTAN_METHOD[] = "RCB" |
Definition at line 39 of file mbpart.cpp.
std::ostringstream LONG_DESC |
Definition at line 49 of file mbpart.cpp.
const char METIS_DEFAULT_METHOD[] = "ML_KWAY" |
Definition at line 45 of file mbpart.cpp.
