merge.cpp
00001 #include <iostream>
00002 #include <moab/Core.hpp>
00003 #include "moab/MergeMesh.hpp"
00004 #include "moab/ProgOptions.hpp"
00005
00006 #ifdef MOAB_HAVE_MPI
00007 #include "moab_mpi.h"
00008 #include "moab/ParallelComm.hpp"
00009 #include "moab/ParallelMergeMesh.hpp"
00010 #endif
00011
00012 using namespace moab;
00013
00014 const char BRIEF_DESC[] = "Merges mesh files or entities in a mesh file. Use available options as desired.";
00015 std::ostringstream LONG_DESC;
00016
00017 int main( int argc, char* argv[] )
00018 {
00019 #ifdef MOAB_HAVE_MPI
00020     int myID = 0, numprocs = 1;
00021     MPI_Init( &argc, &argv );
00022     MPI_Comm_rank( MPI_COMM_WORLD, &myID );
00023     MPI_Comm_size( MPI_COMM_WORLD, &numprocs );
00024 #endif
00025     bool fsimple     = true;   // default
00026     bool ffile       = false;  // parmerge
00027     bool fall        = false;  // merge all
00028     std::string mtag = "";     // tag based merge
00029     std::string input_file, output_file;
00030     double merge_tol = 1.0e-4;
00031
00032     LONG_DESC << "mbmerge tool has the ability to merge nodes in a mesh. For skin-based merge with "
00033                  "multiple"
00034                  "files parallel options is also supported."
00035               << std::endl
00036               << "If no method is specified, the default is simple merge. Simple merge case gets "
00037                  "all the skins available"
00038               << " in the mesh file and merges the nodes to obtain a conformal mesh. Options to "
00039                  "merge all duplicate nodes"
00040               << " and merging based on a specific tag on the nodes are also supported." << std::endl;
00041
00042     ProgOptions opts( LONG_DESC.str(), BRIEF_DESC );
00043
00044     opts.addOpt< void >( "all,a", "merge all including interior.", &fall );
00045     opts.addOpt< std::string >( "mergetag name,t", "merge based on nodes that have a specific tag name assigned",
00046                                 &mtag );
00047     opts.addOpt< double >( "mergetolerance,e", "merge tolerance, default is 1e-4", &merge_tol );
00048     opts.addOpt< void >( "simple,s", "simple merge, merge based on skins provided as in the input mesh (Default)",
00049                          &fsimple );
00050     opts.addRequiredArg< std::string >( "input_file", "Input file to be merged", &input_file );
00051     opts.addRequiredArg< std::string >( "output_file", "Output mesh file name with extension", &output_file );
00052 #ifdef MOAB_HAVE_MPI
00053     opts.addOpt< void >( "file,f",
00054                          "files based merge using skin for individual meshes. Input file is a file containing names"
00055                          "of mesh files to be merged (each on a different line). Only works with parallel build",
00056                          &ffile );
00057 #endif
00058     opts.parseCommandLine( argc, argv );
00059
00060     moab::Core* mb = new moab::Core();
00061     moab::ErrorCode rval;
00062
00063     if( mtag != "" )
00064     {
00065         rval = mb->load_mesh( input_file.c_str() );
00066         if( rval != moab::MB_SUCCESS )
00067         {
00068             std::cerr << "Error Opening Mesh File " << input_file << std::endl;
00069             return 1;
00070         }
00071         else
00072         {
00073             std::cout << "Read input mesh file: " << input_file << std::endl;
00074         }
00075         int dim = 0;
00076         moab::Range verts;
00077         mb->get_entities_by_dimension( 0, dim, verts );
00078         if( rval != moab::MB_SUCCESS )
00079         {
00080             std::cerr << "failed to get entities by dimension" << std::endl;
00081             return 1;
00082         }
00083         Tag tag_for_merge;
00084         rval = mb->tag_get_handle( mtag.c_str(), tag_for_merge );
00085         if( rval != moab::MB_SUCCESS )
00086         {
00087             std::cerr << "unable to get tag: " << mtag << " specified" << std::endl;
00088             return 1;
00089         }
00090         MergeMesh mm( mb );
00091         rval = mm.merge_using_integer_tag( verts, tag_for_merge );
00092         if( rval != moab::MB_SUCCESS )
00093         {
00094             std::cerr << "error in routine merge using integer tag" << std::endl;
00095             return 1;
00096         }
00097         rval = mb->write_file( output_file.c_str() );
00098         if( rval != moab::MB_SUCCESS )
00099         {
00100             std::cerr << "Error Writing Mesh File " << output_file << std::endl;
00101             return 1;
00102         }
00103         else
00104         {
00105             std::cout << "Wrote output mesh file: " << output_file << std::endl;
00106         }
00107     }
00108
00109     else if( fall == true )
00110     {
00111
00112         rval = mb->load_mesh( input_file.c_str() );
00113         if( rval != moab::MB_SUCCESS )
00114         {
00115             std::cerr << "Error Opening Mesh File " << input_file << std::endl;
00116             return 1;
00117         }
00118         else
00119         {
00120             std::cout << "Read input mesh file: " << input_file << std::endl;
00121         }
00122         MergeMesh mm( mb );
00123         rval = mm.merge_all( 0, merge_tol );  // root set
00124         if( rval != moab::MB_SUCCESS )
00125         {
00126             std::cerr << "error in merge_all routine" << std::endl;
00127             return 1;
00128         }
00129         rval = mb->write_file( output_file.c_str() );
00130         if( rval != moab::MB_SUCCESS )
00131         {
00132             std::cerr << "Error Writing Mesh File " << output_file << std::endl;
00133             return 1;
00134         }
00135         else
00136         {
00137             std::cout << "Wrote output mesh file: " << output_file << std::endl;
00138         }
00139     }
00140     else if( ffile == true )
00141     {
00142         /*
00143             Parmerge
00144             Takes multiple mesh files and merges them into a single output file.
00145             This is a driver for ParallelMergeMesh
00146             Does not currently work if #procs > #meshfiles
00147
00148             <input_file> is text file containing each mesh file on a line
00149             i.e.
00150
00151             /my/path/file1
00152             /my/path/file2
00153             ...
00154             /my/path/fileN
00155
00156             <output_file> file is a single file where the entire mesh is written to
00157             It must be of type ".h5m"
00158
00159             <tolerance> is the merging tolerance
00160
00161             Typical usage of:
00162             mpirun -n <#procs> parmerge <input_file> <output_file> <tolerance>
00163         */
00164         // Read in files from input files
00165         // Round robin distribution of reading meshes
00166 #ifdef MOAB_HAVE_MPI
00167         std::ifstream file( input_file.c_str() );
00168         if( file.is_open() )
00169         {
00170             std::string line;
00171             int count = 0;
00172             // Read each line
00173             while( file.good() )
00174             {
00175                 getline( file, line );
00176                 if( myID == count && line != "" )
00177                 {
00178                     // Read in the file
00179                     rval = mb->load_mesh( line.c_str() );
00180                     if( rval != moab::MB_SUCCESS )
00181                     {
00182                         std::cerr << "Error Opening Mesh File " << line << std::endl;
00183                         MPI_Abort( MPI_COMM_WORLD, 1 );
00184                         file.close();
00185                         return 1;
00186                     }
00187                     else
00188                     {
00189                         std::cout << "Read input mesh file: " << line << std::endl;
00190                     }
00191                 }
00192                 count = ( count + 1 ) % numprocs;
00193             }
00194             file.close();
00195         }
00196         else
00197         {
00198             std::cerr << "Error Opening Input File " << input_file << std::endl;
00199             MPI_Abort( MPI_COMM_WORLD, 1 );
00200             return 1;
00201         }
00202
00203         // Get a pcomm object
00204         moab::ParallelComm* pc = new moab::ParallelComm( mb, MPI_COMM_WORLD );
00205
00206         // Call the resolve parallel function
00207         moab::ParallelMergeMesh pm( pc, merge_tol );
00208         rval = pm.merge();
00209         if( rval != moab::MB_SUCCESS )
00210         {
00211             std::cerr << "Merge Failed" << std::endl;
00212             MPI_Abort( MPI_COMM_WORLD, 1 );
00213             return 1;
00214         }
00215
00216         // Write out the file
00217         rval = mb->write_file( output_file.c_str(), 0, "PARALLEL=WRITE_PART" );
00218         if( rval != moab::MB_SUCCESS )
00219         {
00220             std::cerr << "Writing output file failed. Code:";
00221             // Temporary File error info.
00222             std::cerr << mb->get_error_string( rval ) << std::endl;
00223             std::string foo = "";
00224             mb->get_last_error( foo );
00225             std::cerr << "File Error: " << foo << std::endl;
00226             return 1;
00227         }
00228         else if( myID == 0 )
00229         {
00230             std::cout << "Wrote output mesh file: " << output_file << std::endl;
00231         }
00232
00233         // The barrier may be necessary to stop items from being deleted when needed
00234         // But probably not necessary
00235         MPI_Barrier( MPI_COMM_WORLD );
00236
00237         delete pc;
00238 #endif
00239     }
00240     else if( fsimple == true )
00241     {
00242         rval = mb->load_mesh( input_file.c_str() );
00243         if( rval != moab::MB_SUCCESS )
00244         {
00245             std::cerr << "Error Opening Mesh File " << input_file << std::endl;
00246             return 1;
00247         }
00248         else
00249         {
00250             std::cout << "Read input mesh file: " << input_file << std::endl;
00251         }
00252         int dim = 3;
00253         moab::Range ents;
00254         mb->get_entities_by_dimension( 0, dim, ents );
00255         if( rval != moab::MB_SUCCESS )
00256         {
00257             std::cerr << "error getting entities by dimension" << std::endl;
00258             return 1;
00259         }
00260         MergeMesh mm( mb );
00261         rval = mm.merge_entities( ents, merge_tol );
00262         if( rval != moab::MB_SUCCESS )
00263         {
00264             std::cerr << "error in merge entities routine" << std::endl;
00265             return 1;
00266         }
00267         rval = mb->write_file( output_file.c_str() );
00268         if( rval != moab::MB_SUCCESS )
00269         {
00270             std::cerr << "   Writing Mesh File " << output_file << std::endl;
00271             return 1;
00272         }
00273         else
00274         {
00275             std::cout << "Wrote output mesh file: " << output_file << std::endl;
00276         }
00277     }
00278     else
00279     {
00280         std::cerr << " Unhandled option " << std::endl;
00281         return 1;
00282     }
00283
00284     delete mb;
00285 #ifdef MOAB_HAVE_MPI
00286     MPI_Finalize();
00287 #endif
00288
00289     return 0;
00290 }
