mergemesh_test.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/MergeMesh.hpp"
#include <iostream>
#include "TestUtil.hpp"
+ Include dependency graph for mergemesh_test.cpp:
Functions
void mergesimple_test ()
void merge_with_tag_test ()
void merge_all_test ()
int main ()
Variables
std::string meshfile = "unittest/16_unmerged_hex.h5m"
std::string meshfile2 = "unittest/merge_with_tag.h5m"
std::string meshfile3 = "unittest/triangles.h5m"
std::string outfile = "mm_out.h5m"
Function Documentation
int main ( )
Definition at line 29 of file mergemesh_test.cpp.
References merge_all_test(), merge_with_tag_test(), mergesimple_test(), and RUN_TEST.
#ifdef MOAB_HAVE_MPI
    MPI_Init( &argc, &argv );
#endif
    int result = 0;
    result += RUN_TEST( mergesimple_test );
    result += RUN_TEST( merge_with_tag_test );
    result += RUN_TEST( merge_all_test );
    MPI_Finalize();
#endif
    return result;
void merge_all_test ( )
Definition at line 96 of file mergemesh_test.cpp.
References CHECK_ERR, ErrorCode, iface, moab::Interface::load_mesh(), mb, moab::MergeMesh::merge_all(), meshfile3, outfile, and moab::Interface::write_file().
Referenced by main().
    ErrorCode rval;
    Core mb;
    Interface* iface = &mb;
    rval = iface->load_mesh( meshfile3.c_str() );CHECK_ERR( rval );
    MergeMesh mm( iface );
    double merge_tol = 1e-3;
    rval             = mm.merge_all( 0, merge_tol );  // root set
    CHECK_ERR( rval );
    rval = iface->write_file( outfile.c_str() );CHECK_ERR( rval );
    return;
Definition at line 71 of file mergemesh_test.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), dim, ErrorCode, moab::Interface::get_entities_by_dimension(), iface, moab::Interface::load_mesh(), mb, moab::MergeMesh::merge_using_integer_tag(), meshfile2, outfile, moab::Range::size(), moab::Interface::tag_get_handle(), and moab::Interface::write_file().
    ErrorCode rval;
    Core mb;
    // can be generalized to load user defined input/output file
    rval = iface->load_mesh( meshfile2.c_str() );CHECK_ERR( rval );
    int dim = 0;
    moab::Range verts;
    iface->get_entities_by_dimension( 0, dim, verts );
    Tag tag_for_merge;
    rval = iface->tag_get_handle( "IDFTAG", tag_for_merge );CHECK_ERR( rval );
    rval = mm.merge_using_integer_tag( verts, tag_for_merge );CHECK_ERR( rval );
    verts.clear();
    CHECK_EQUAL( 405, (int)verts.size() );
    return;
void mergesimple_test ( )
Definition at line 47 of file mergemesh_test.cpp.
References CHECK_ERR, dim, ErrorCode, moab::Interface::get_entities_by_dimension(), iface, moab::Interface::load_mesh(), mb, moab::MergeMesh::merge_entities(), meshfile, outfile, and moab::Interface::write_file().
    ErrorCode rval;
    Core mb;
    rval = iface->load_mesh( meshfile.c_str() );CHECK_ERR( rval );
    int dim = 3;
    moab::Range ents;
    iface->get_entities_by_dimension( 0, dim, ents );
    rval = mm.merge_entities( ents, merge_tol );CHECK_ERR( rval );
    // Fixed for now
    return;
Variable Documentation
Definition at line 17 of file mergemesh_test.cpp.
Referenced by main(), and mergesimple_test().
Definition at line 18 of file mergemesh_test.cpp.
Referenced by merge_with_tag_test().
Definition at line 19 of file mergemesh_test.cpp.
Referenced by merge_all_test().
