MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <cstdlib>
#include <cstdio>
#include <cstring>
#include <cctype>
#include "moab/mhdf_public.h"
Functions | |
static int | print_file_summary (MHDF_FileDesc *data) |
int | main (int argc, char *argv[]) |
static void | print_ent_desc (const char *name, const char *subname, MHDF_EntDesc *data, const char *vals_label, const char *extra_label, MHDF_FileDesc *all) |
static void | print_elem_desc (MHDF_ElemDesc *data, MHDF_FileDesc *all) |
static const char * | tag_type_name (MHDF_TagDataType type) |
static const char * | string_tag_value (const void *value, MHDF_TagDataType type, int size) |
static const char * | ent_desc_name (MHDF_FileDesc *all, int idx) |
static void | print_tag_desc (MHDF_TagDesc *data, MHDF_FileDesc *all) |
static const char* ent_desc_name | ( | MHDF_FileDesc * | all, |
int | idx | ||
) | [static] |
Definition at line 218 of file mhdf_public_test.cpp.
References mhdf_FileDesc::elems, mhdf_ElemDesc::handle, and mhdf_FileDesc::num_elem_desc.
Referenced by print_tag_desc().
{ static const char nodes[] = "Nodes"; static const char sets[] = "Sets"; static const char invalid[] = "<INVALID INDEX!>"; if( idx == -2 ) return sets; if( idx == -1 ) return nodes; if( idx >= all->num_elem_desc || idx < -2 ) return invalid; return all->elems[idx].handle; }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 9 of file mhdf_public_test.cpp.
References mhdf_closeFile(), mhdf_getFileSummary(), mhdf_isError(), mhdf_message(), mhdf_openFile(), and print_file_summary().
{ int result; MHDF_FileHandle file; MHDF_Status status; unsigned long max_id; MHDF_FileDesc* data; if( argc != 2 ) { fprintf( stderr, "Usage: %s <filename>\n", argv[0] ); return 0; } file = mhdf_openFile( argv[1], 0, &max_id, -1, &status ); if( mhdf_isError( &status ) ) { fprintf( stderr, "%s: %s\n", argv[1], mhdf_message( &status ) ); return 1; } data = mhdf_getFileSummary( file, H5T_NATIVE_ULONG, &status, 1 ); if( mhdf_isError( &status ) ) { fprintf( stderr, "%s: %s\n", argv[1], mhdf_message( &status ) ); return 1; } mhdf_closeFile( file, &status ); printf( "%s:\n", argv[1] ); result = print_file_summary( data ); free( data ); return result; }
static void print_elem_desc | ( | MHDF_ElemDesc * | data, |
MHDF_FileDesc * | all | ||
) | [static] |
Definition at line 77 of file mhdf_public_test.cpp.
References MBMesquite::adj(), mhdf_ElemDesc::desc, mhdf_ElemDesc::handle, mhdf_ElemDesc::have_adj, print_ent_desc(), and mhdf_ElemDesc::type.
Referenced by print_file_summary().
static void print_ent_desc | ( | const char * | name, |
const char * | subname, | ||
MHDF_EntDesc * | data, | ||
const char * | vals_label, | ||
const char * | extra_label, | ||
) | [static] |
Definition at line 45 of file mhdf_public_test.cpp.
References mhdf_EntDesc::count, mhdf_EntDesc::dense_tag_indices, mhdf_TagDesc::name, mhdf_EntDesc::num_dense_tags, mhdf_EntDesc::start_id, mhdf_FileDesc::tags, and mhdf_EntDesc::vals_per_ent.
Referenced by print_elem_desc(), and print_file_summary().
{ int i, len = 10; if( vals_label && (int)strlen( vals_label ) > len ) len = strlen( vals_label ); if( extra_label && (int)strlen( extra_label ) > len ) len = strlen( extra_label ); if( subname ) printf( " %s (%s):\n", name, subname ); else printf( " %s:\n", name ); if( vals_label ) printf( " %-*s: %d\n", len, vals_label, data->vals_per_ent ); printf( " %-*s: %ld [%ld - %ld]\n", len, "entities", data->count, data->start_id, data->start_id + data->count - 1 ); if( extra_label ) printf( " %-*s\n", len, extra_label ); if( !data->num_dense_tags ) return; printf( " %-*s: \"%s\"", len, "dense tags", all->tags[data->dense_tag_indices[0]].name ); for( i = 1; i < data->num_dense_tags; ++i ) printf( ", \"%s\"", all->tags[data->dense_tag_indices[i]].name ); printf( "\n" ); }
static int print_file_summary | ( | MHDF_FileDesc * | data | ) | [static] |
Definition at line 265 of file mhdf_public_test.cpp.
References mhdf_FileDesc::defTagsEntSets, mhdf_FileDesc::defTagsVals, mhdf_FileDesc::elems, mhdf_FileDesc::nodes, mhdf_FileDesc::num_elem_desc, mhdf_FileDesc::num_tag_desc, mhdf_FileDesc::numEntSets, print_elem_desc(), print_ent_desc(), print_tag_desc(), mhdf_FileDesc::sets, and mhdf_FileDesc::tags.
Referenced by main().
{ int i; printf( " Entities:\n" ); print_ent_desc( "Nodes", NULL, &data->nodes, "dimension", NULL, data ); for( i = 0; i < data->num_elem_desc; ++i ) print_elem_desc( data->elems + i, data ); print_ent_desc( "Sets", NULL, &data->sets, NULL, NULL, data ); printf( " Tags:\n" ); for( i = 0; i < data->num_tag_desc; ++i ) print_tag_desc( data->tags + i, data ); printf( " Number partitions: %d\n", data->numEntSets[0] ); for( i = 0; i < data->numEntSets[0]; i++ ) printf( " set id %d value %d \n", data->defTagsEntSets[0][i], data->defTagsVals[0][i] ); printf( "\n Number material sets: %d\n", data->numEntSets[1] ); for( i = 0; i < data->numEntSets[1]; i++ ) printf( " set id %d value %d \n", data->defTagsEntSets[1][i], data->defTagsVals[1][i] ); printf( "\n Number neumann sets: %d\n", data->numEntSets[2] ); for( i = 0; i < data->numEntSets[2]; i++ ) printf( " set id %d value %d \n", data->defTagsEntSets[2][i], data->defTagsVals[2][i] ); printf( "\n Number dirichlet sets: %d\n", data->numEntSets[3] ); for( i = 0; i < data->numEntSets[3]; i++ ) printf( " set id %d value %d \n", data->defTagsEntSets[3][i], data->defTagsVals[3][i] ); printf( "\n Number geometry sets: %d\n", data->numEntSets[4] ); for( i = 0; i < data->numEntSets[4]; i++ ) printf( " set id %d value %d \n", data->defTagsEntSets[4][i], data->defTagsVals[4][i] ); return 0; }
static void print_tag_desc | ( | MHDF_TagDesc * | data, |
) | [static] |
Definition at line 229 of file mhdf_public_test.cpp.
References mhdf_TagDesc::bytes, mhdf_TagDesc::default_value, mhdf_TagDesc::default_value_size, mhdf_TagDesc::dense_elem_indices, ent_desc_name(), mhdf_TagDesc::global_value, mhdf_TagDesc::global_value_size, mhdf_TagDesc::have_sparse, mhdf_TagDesc::name, mhdf_TagDesc::num_dense_indices, mhdf_TagDesc::size, mhdf_TagDesc::storage, string_tag_value(), tag_type_name(), mhdf_TagDesc::type, and MBMesquite::width().
{ int i, width = 8; printf( " \"%s\":\n", data->name ); printf( " %-*s: %s\n", width, "type", tag_type_name( data->type ) ); if( data->size < 0 ) printf( " %-*s: (variable)\n", width, "size" ); else printf( " %-*s: %d (%d bytes)\n", width, "size", data->size, data->bytes ); printf( " %-*s: %x\n", width, "flags", data->storage ); if( data->default_value ) printf( " %-*s: %s\n", width, "default", string_tag_value( data->default_value, data->type, data->default_value_size ) ); if( data->global_value ) printf( " %-*s: %s\n", width, "mesh val", string_tag_value( data->global_value, data->type, data->global_value_size ) ); if( data->have_sparse ) { printf( " %-*s: (sparse)", width, "tables" ); for( i = 0; i < data->num_dense_indices; ++i ) printf( ", %s", ent_desc_name( all, data->dense_elem_indices[i] ) ); } else if( data->num_dense_indices ) { printf( " %-*s: %s", width, "tables", ent_desc_name( all, data->dense_elem_indices[0] ) ); for( i = 1; i < data->num_dense_indices; ++i ) printf( ", %s", ent_desc_name( all, data->dense_elem_indices[i] ) ); } else { printf( " %-*s: (none)", width, "tables" ); } printf( "\n" ); }
static const char* string_tag_value | ( | const void * | value, |
MHDF_TagDataType | type, | ||
int | size | ||
) | [static] |
Definition at line 110 of file mhdf_public_test.cpp.
References buffer, mhdf_BITFIELD, mhdf_BOOLEAN, mhdf_ENTITY_ID, mhdf_FLOAT, mhdf_INTEGER, mhdf_OPAQUE, MBMesquite::print(), and size.
{ static char buffer[1024]; const char* data = (const char*)value; char* offset = buffer; int print, i; const int* intptr = (const int*)value; const double* dblptr = (const double*)value; const unsigned long* idptr = (const unsigned long*)value; if( size <= 0 ) { *buffer = '\0'; return buffer; } switch( type ) { case mhdf_OPAQUE: print = 1; for( i = 0; i < size; ++i ) if( !isprint( data[i] ) ) print = 0; if( print ) { offset[0] = '"'; memcpy( offset + 1, data, size ); offset[size + 1] = '"'; offset[size + 2] = '\0'; offset += size + 2; } else { strcpy( offset, "0x" ); offset += 2; for( i = 0; i < size; ++i ) offset += sprintf( offset, "%02x", (unsigned int)data[i] ); } break; case mhdf_INTEGER: if( size == 1 ) { offset += sprintf( offset, "%d", intptr[0] ); } else { offset += sprintf( offset, "{%d", intptr[0] ); for( i = 1; i < size; ++i ) offset += sprintf( offset, ",%d", intptr[i] ); offset += sprintf( offset, "}" ); } break; case mhdf_FLOAT: if( size == 1 ) { offset += sprintf( offset, "%g", dblptr[0] ); } else { offset += sprintf( offset, "{%g", dblptr[0] ); for( i = 1; i < size; ++i ) offset += sprintf( offset, ",%g", dblptr[i] ); offset += sprintf( offset, "}" ); } break; case mhdf_BITFIELD: if( size > 8 ) offset += sprintf( offset, "(more than 8 bits)" ); else { for( i = size - 1; i >= 0; --i ) *( offset++ ) = (char)( *data & ( 1 << i ) ? '1' : '0' ); *offset = '\0'; } break; case mhdf_BOOLEAN: if( size == 1 ) { offset += sprintf( offset, "%s", data[0] ? "true" : "false" ); } else { offset += sprintf( offset, "{%s", data[0] ? "true" : "false" ); for( i = 1; i < size; ++i ) offset += sprintf( offset, ",%s", data[i] ? "true" : "false" ); offset += sprintf( offset, "}" ); } break; case mhdf_ENTITY_ID: if( size == 1 ) { offset += sprintf( offset, "%lu", idptr[0] ); } else { offset += sprintf( offset, "{%lu", idptr[0] ); for( i = 1; i < size; ++i ) offset += sprintf( offset, ",%lu", idptr[i] ); offset += sprintf( offset, "}" ); } break; default: strcpy( buffer, "(unknown data type)" ); break; } return buffer; }
static const char* tag_type_name | ( | MHDF_TagDataType | type | ) | [static] |
Definition at line 83 of file mhdf_public_test.cpp.
References mhdf_BITFIELD, mhdf_BOOLEAN, mhdf_ENTITY_ID, mhdf_FLOAT, mhdf_INTEGER, and mhdf_OPAQUE.
{ static const char opaque[] = "opaque"; static const char integer[] = "integer"; static const char real[] = "real"; static const char bits[] = "bit field"; static const char boolean[] = "boolean"; static const char id[] = "entity id"; static const char unknown[] = "(UNKNOWN TYPE ID)"; switch( type ) { case mhdf_OPAQUE: return opaque; case mhdf_INTEGER: return integer; case mhdf_FLOAT: return real; case mhdf_BITFIELD: return bits; case mhdf_BOOLEAN: return boolean; case mhdf_ENTITY_ID: return id; } return unknown; }
