migrate_test.cpp File Reference
#include "moab/ParallelComm.hpp"
#include "moab/Core.hpp"
#include "moab_mpi.h"
#include "moab/iMOAB.h"
#include "TestUtil.hpp"
+ Include dependency graph for migrate_test.cpp:
Defines
#define RUN_TEST_ARG2(A, B)   run_test( &( A ), #A, B )
#define CHECKRC(rc, message)
Functions
int is_any_proc_error (int is_my_error)
int run_test (ErrorCode(*func)(const char *), const char *func_name, const char *file_name)
ErrorCode migrate_1_1 (const char *filename)
ErrorCode migrate_1_2 (const char *filename)
ErrorCode migrate_2_1 (const char *filename)
ErrorCode migrate_2_2 (const char *filename)
ErrorCode migrate_4_2 (const char *filename)
ErrorCode migrate_2_4 (const char *filename)
ErrorCode migrate_4_3 (const char *filename)
ErrorCode migrate_overlap (const char *filename)
int main (int argc, char *argv[])
ErrorCode migrate (const char *filename, const char *outfile)
Variables
int rank
int size
int ierr
int compid1
int compid2
int nghlay
int groupTasks [4]
int startG1
int startG2
int endG1
int endG2
MPI_Comm jcomm
MPI_Group jgroup
Define Documentation
#define CHECKRC (   rc,
  message
Value:
if( 0 != ( rc ) )                     \
        printf( "Error: %s\n", message ); \
        return MB_FAILURE;                \
Definition at line 20 of file migrate_test.cpp.
Referenced by migrate().
#define RUN_TEST_ARG2 (   A,
Definition at line 16 of file migrate_test.cpp.
Referenced by main().
Function Documentation
int is_any_proc_error ( int  is_my_error)
Definition at line 27 of file migrate_test.cpp.
References MPI_COMM_WORLD.
    int result = 0;
    int err    = MPI_Allreduce( &is_my_error, &result, 1, MPI_INT, MPI_MAX, MPI_COMM_WORLD );
    return err || result;
int main ( int  argc,
char *  argv[]
Definition at line 71 of file migrate_test.cpp.
References filename, jcomm, jgroup, migrate_1_1(), migrate_1_2(), migrate_2_1(), migrate_2_2(), migrate_2_4(), migrate_4_2(), migrate_4_3(), migrate_overlap(), MPI_COMM_WORLD, rank, RUN_TEST_ARG2, and size.
    MPI_Init( &argc, &argv );
    MPI_Comm_rank( MPI_COMM_WORLD, &rank );
    MPI_Comm_size( MPI_COMM_WORLD, &size );
    MPI_Comm_dup( MPI_COMM_WORLD, &jcomm );
    MPI_Comm_group( jcomm, &jgroup );
    std::string filename;
    filename = TestDir + "unittest/field1.h5m";
    if( argc > 1 )
        filename = argv[1];
    int num_errors = 0;
    num_errors += RUN_TEST_ARG2( migrate_1_1, filename.c_str() );
    num_errors += RUN_TEST_ARG2( migrate_1_2, filename.c_str() );
    num_errors += RUN_TEST_ARG2( migrate_2_1, filename.c_str() );
    num_errors += RUN_TEST_ARG2( migrate_2_2, filename.c_str() );
    if( size >= 4 )
        num_errors += RUN_TEST_ARG2( migrate_4_2, filename.c_str() );
        num_errors += RUN_TEST_ARG2( migrate_2_4, filename.c_str() );
        num_errors += RUN_TEST_ARG2( migrate_4_3, filename.c_str() );
        num_errors += RUN_TEST_ARG2( migrate_overlap, filename.c_str() );
    if( rank == 0 )
        if( !num_errors )
            std::cout << "All tests passed" << std::endl;
        else
            std::cout << num_errors << " TESTS FAILED!" << std::endl;
    MPI_Group_free( &jgroup );
    MPI_Comm_free( &jcomm );
    MPI_Finalize();
    return num_errors;
ErrorCode migrate ( const char *  filename,
const char *  outfile
Definition at line 112 of file migrate_test.cpp.
References CHECKRC, compid1, compid2, DENSE_DOUBLE, endG1, endG2, groupTasks, ierr, iMOAB_AppID, iMOAB_DefineTagStorage(), iMOAB_DeregisterApplication(), iMOAB_Finalize(), iMOAB_Initialize(), iMOAB_LoadMesh(), iMOAB_RegisterApplication(), iMOAB_WriteMesh(), jcomm, jgroup, MB_SUCCESS, nghlay, readopts(), startG1, and startG2.
Referenced by migrate_1_1(), migrate_1_2(), migrate_2_1(), migrate_2_2(), migrate_2_4(), migrate_4_2(), migrate_4_3(), and migrate_overlap().
    // first create MPI groups
    std::string filen( filename );
    MPI_Group group1, group2;
    for( int i = startG1; i <= endG1; i++ )
        groupTasks[i - startG1] = i;
    ierr = MPI_Group_incl( jgroup, endG1 - startG1 + 1, groupTasks, &group1 );
    CHECKRC( ierr, "can't create group1" )
    for( int i = startG2; i <= endG2; i++ )
        groupTasks[i - startG2] = i;
    ierr = MPI_Group_incl( jgroup, endG2 - startG2 + 1, groupTasks, &group2 );
    CHECKRC( ierr, "can't create group2" )
    // create 2 communicators, one for each group
    int tagcomm1 = 1, tagcomm2 = 2;
    MPI_Comm comm1, comm2;
    ierr = MPI_Comm_create_group( jcomm, group1, tagcomm1, &comm1 );
    CHECKRC( ierr, "can't create comm1" )
    ierr = MPI_Comm_create_group( jcomm, group2, tagcomm2, &comm2 );
    CHECKRC( ierr, "can't create comm2" )
    ierr = iMOAB_Initialize( 0, 0 );  // not really needed anything from argc, argv, yet; maybe we should
    CHECKRC( ierr, "can't initialize iMOAB" )
    // give some dummy values to component ids, just to differentiate between them
    // the par comm graph is unique between components
    compid1        = 4;
    compid2        = 7;
    int context_id = -1;  // default context; will be now set to compid1 or compid2
    int appID1;
    iMOAB_AppID pid1 = &appID1;
    int appID2;
    iMOAB_AppID pid2 = &appID2;
    if( comm1 != MPI_COMM_NULL )
        ierr = iMOAB_RegisterApplication( "APP1", &comm1, &compid1, pid1 );
        CHECKRC( ierr, "can't register app1 " )
    if( comm2 != MPI_COMM_NULL )
        ierr = iMOAB_RegisterApplication( "APP2", &comm2, &compid2, pid2 );
        CHECKRC( ierr, "can't register app2 " )
    int method = 0;  // trivial partition for sending
        std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" );
        nghlay = 0;
        ierr = iMOAB_LoadMesh( pid1, filen.c_str(), readopts.c_str(), &nghlay );
        CHECKRC( ierr, "can't load mesh " )
        ierr = iMOAB_SendMesh( pid1, &jcomm, &group2, &compid2, &method );  // send to component 2
        CHECKRC( ierr, "cannot send elements" )
        ierr = iMOAB_ReceiveMesh( pid2, &jcomm, &group1, &compid1 );  // receive from component 1
        CHECKRC( ierr, "cannot receive elements" )
        std::string wopts;
        wopts = "PARALLEL=WRITE_PART;";
        ierr  = iMOAB_WriteMesh( pid2, outfile, wopts.c_str() );
        CHECKRC( ierr, "cannot write received mesh" )
    MPI_Barrier( jcomm );
    // we can now free the sender buffers
    if( comm1 != MPI_COMM_NULL ) ierr = iMOAB_FreeSenderBuffers( pid1, &context_id );
    // exchange tag, from component to component
    // one is receiving, one is sending the tag; the one that is sending needs to have communicator
    // not null
    int size_tag  = 1;  // a double dense tag, on elements
    int tagType   = DENSE_DOUBLE;
    int tagIndex2 = 0, tagIndex1 = 0;  // these will be tag indices on each app pid
    std::string fileAfterTagMigr( outfile );  // has h5m
    int sizen = fileAfterTagMigr.length();
    fileAfterTagMigr.erase( sizen - 4, 4 );  // erase extension .h5m
    fileAfterTagMigr = fileAfterTagMigr + "_tag.h5m";
    // now send a tag from component 2, towards component 1
        ierr = iMOAB_DefineTagStorage( pid2, "element_field", &tagType, &size_tag, &tagIndex2 );
        CHECKRC( ierr, "failed to get tag element_field " );
        // this tag is already existing in the file
        // first, send from compid2 to compid1, from comm2, using common joint comm
        // as always, use nonblocking sends
        // contex_id should be now compid1
        context_id = compid1;
        ierr       = iMOAB_SendElementTag( pid2, "element_field", &jcomm, &context_id );
        CHECKRC( ierr, "cannot send tag values" )
    // receive on component 1
        ierr = iMOAB_DefineTagStorage( pid1, "element_field", &tagType, &size_tag, &tagIndex1 );
        CHECKRC( ierr, "failed to get tag DFIELD " );
        context_id = compid2;
        ierr       = iMOAB_ReceiveElementTag( pid1, "element_field", &jcomm, &context_id );
        std::string wopts;
        ierr  = iMOAB_WriteMesh( pid1, fileAfterTagMigr.c_str(), wopts.c_str() );
    if( comm2 != MPI_COMM_NULL ) ierr = iMOAB_FreeSenderBuffers( pid2, &context_id );
        ierr = iMOAB_DeregisterApplication( pid2 );
        CHECKRC( ierr, "cannot deregister app 2 receiver" )
        ierr = iMOAB_DeregisterApplication( pid1 );
        CHECKRC( ierr, "cannot deregister app 1 sender" )
    ierr = iMOAB_Finalize();
    CHECKRC( ierr, "did not finalize iMOAB" )
    if( MPI_COMM_NULL != comm1 ) MPI_Comm_free( &comm1 );
    if( MPI_COMM_NULL != comm2 ) MPI_Comm_free( &comm2 );
    MPI_Group_free( &group1 );
    MPI_Group_free( &group2 );
    return MB_SUCCESS;
ErrorCode migrate_1_1 ( const char *  filename)
Definition at line 261 of file migrate_test.cpp.
References endG1, endG2, migrate(), startG1, and startG2.
    startG1 = endG1 = 0;
    startG2 = endG2 = 1;
    return migrate( filename, "migrate11.h5m" );
ErrorCode migrate_1_2 ( const char *  filename)
Definition at line 268 of file migrate_test.cpp.
    startG1 = endG1 = startG2 = 0;
    endG2                     = 1;
    return migrate( filename, "migrate12.h5m" );
ErrorCode migrate_2_1 ( const char *  filename)
Definition at line 276 of file migrate_test.cpp.
    startG1 = endG2 = startG2 = 0;
    endG1                     = 1;
    return migrate( filename, "migrate21.h5m" );
ErrorCode migrate_2_2 ( const char *  filename)
Definition at line 284 of file migrate_test.cpp.
    startG1 = startG2 = 0;
    endG1 = endG2 = 1;
    return migrate( filename, "migrate22.h5m" );
ErrorCode migrate_2_4 ( const char *  filename)
Definition at line 299 of file migrate_test.cpp.
    endG2             = 3;
    endG1             = 1;
    return migrate( filename, "migrate24.h5m" );
ErrorCode migrate_4_2 ( const char *  filename)
Definition at line 291 of file migrate_test.cpp.
    endG2             = 1;
    endG1             = 3;
    return migrate( filename, "migrate42.h5m" );
ErrorCode migrate_4_3 ( const char *  filename)
Definition at line 307 of file migrate_test.cpp.
    endG2             = 2;
    endG1             = 3;
    return migrate( filename, "migrate43.h5m" );
ErrorCode migrate_overlap ( const char *  filename)
Definition at line 315 of file migrate_test.cpp.
    startG1 = 0;
    startG2 = 1;
    endG1   = 1;
    endG2   = 2;
    return migrate( filename, "migrate_over.h5m" );
int run_test ( ErrorCode(*)(const char *)  func,
const char *  func_name,
const char *  file_name
Definition at line 34 of file migrate_test.cpp.
References ErrorCode, is_any_proc_error(), MB_SUCCESS, MPI_COMM_WORLD, and rank.
    ErrorCode result = ( *func )( file_name );
    int is_err       = is_any_proc_error( ( MB_SUCCESS != result ) );
    int rank;
    if( rank == 0 )
        if( is_err )
            std::cout << func_name << " : FAILED!!" << std::endl;
        else
            std::cout << func_name << " : success" << std::endl;
    return is_err;
Variable Documentation
int compid1
Definition at line 63 of file migrate_test.cpp.
int compid2
int endG1
Definition at line 66 of file migrate_test.cpp.
int endG2
int groupTasks[4]
Definition at line 65 of file migrate_test.cpp.
int ierr
Definition at line 61 of file migrate_test.cpp.
Definition at line 68 of file migrate_test.cpp.
MPI_Group jgroup
Definition at line 69 of file migrate_test.cpp.
int nghlay
Definition at line 64 of file migrate_test.cpp.
int rank
int size
int startG1
int startG2
