mpastrvpart.cpp File Reference
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/ParallelComm.hpp"
#include "moab/ProgOptions.hpp"
#include "MBParallelConventions.h"
#include "moab/ReadUtilIface.hpp"
#include "MBTagConventions.hpp"
#include <sstream>
+ Include dependency graph for mpastrvpart.cpp:
Functions
void test_read_onevar_trivial ()
void test_read_onevar_trivial_no_mixed_elements ()
void test_read_mesh_parallel_trivial ()
void test_read_mesh_parallel_trivial_no_mixed_elements ()
void test_gather_onevar_on_rank0 ()
void test_gather_onevar_on_rank1 ()
void test_multiple_loads_of_same_file ()
void test_multiple_loads_of_same_file_no_mixed_elements ()
void read_one_cell_var (bool rcbzoltan, bool no_mixed_elements)
void read_mesh_parallel (bool rcbzoltan, bool no_mixed_elements)
void gather_one_cell_var (int gather_set_rank)
void multiple_loads_of_same_file (bool no_mixed_elements)
int main (int argc, char *argv[])
void test_read_onevar_rcbzoltan ()
void test_read_onevar_rcbzoltan_no_mixed_elements ()
void test_read_mesh_parallel_rcbzoltan ()
void test_read_mesh_parallel_rcbzoltan_no_mixed_elements ()
Variables
std::string example = "unittest/io/mpasx1.642.t.2.nc"
std::string read_options
const double eps = 1e-20
Function Documentation
void gather_one_cell_var ( int  gather_set_rank)
int main ( int  argc,
char *  argv[]
void multiple_loads_of_same_file ( bool  no_mixed_elements)
Definition at line 492 of file mpastrvpart.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, moab::Interface::create_meshset(), eps, ErrorCode, example, moab::Interface::get_entities_by_type(), moab::ParallelComm::get_pcomm(), moab::Interface::load_file(), MB_TYPE_DOUBLE, MBEDGE, MBPOLYGON, MBVERTEX, MESHSET_SET, moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), moab::Range::psize(), read_options, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    Core moab;
    Interface& mb = moab;
    // Need a file set for nomesh to work right
    EntityHandle file_set;
    ErrorCode rval;
    rval = mb.create_meshset( MESHSET_SET, file_set );CHECK_ERR( rval );
    // Read first only header information, no mesh, no variable
    read_options = "PARALLEL=READ_PART;PARTITION;NOMESH;VARIABLE=;PARTITION_METHOD=TRIVIAL";
    if( no_mixed_elements ) read_options += ";NO_MIXED_ELEMENTS";
    rval = mb.load_file( example.c_str(), &file_set, read_options.c_str() );CHECK_ERR( rval );
    // Create mesh, no variable
    read_options = "PARALLEL=READ_PART;PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARTITION_METHOD="
                   "TRIVIAL;VARIABLE=";
    // Read variable ke at timestep 0, no mesh
    read_options = "PARALLEL=READ_PART;PARTITION;PARTITION_METHOD=TRIVIAL;NOMESH;VARIABLE=ke;TIMESTEP=0";
    Range local_verts;
    rval = mb.get_entities_by_type( file_set, MBVERTEX, local_verts );CHECK_ERR( rval );
    Range local_edges;
    rval = mb.get_entities_by_type( file_set, MBEDGE, local_edges );CHECK_ERR( rval );
    Range local_cells;
    rval = mb.get_entities_by_type( file_set, MBPOLYGON, local_cells );CHECK_ERR( rval );
    ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
    int procs           = pcomm->proc_config().proc_size();
    int rank            = pcomm->proc_config().proc_rank();
    // Make check runs this test on two processors
    if( 2 == procs )
        CHECK_EQUAL( (size_t)321, local_cells.size() );
        // Check tag for cell variable ke at timestep 0
        Tag ke_tag0;
        rval = mb.tag_get_handle( "ke0", 1, MB_TYPE_DOUBLE, ke_tag0 );CHECK_ERR( rval );
        // Get ke0 tag values on 3 local cells
        EntityHandle cell_ents[] = { local_cells[0], local_cells[160], local_cells[320] };
        double ke0_val[3];
        rval = mb.tag_get_data( ke_tag0, cell_ents, 3, ke0_val );CHECK_ERR( rval );
        if( 0 == rank )
            CHECK_EQUAL( (size_t)1120, local_verts.size() );
            CHECK_EQUAL( (size_t)1438, local_edges.size() );
            CHECK_EQUAL( (size_t)1, local_cells.psize() );
            CHECK_REAL_EQUAL( 15.001, ke0_val[0], eps );
            CHECK_REAL_EQUAL( 16.161, ke0_val[1], eps );
            CHECK_REAL_EQUAL( 16.321, ke0_val[2], eps );
        else if( 1 == rank )
            CHECK_EQUAL( (size_t)1122, local_verts.size() );
            CHECK_EQUAL( (size_t)1444, local_edges.size() );
            CHECK_REAL_EQUAL( 16.322, ke0_val[0], eps );
            CHECK_REAL_EQUAL( 16.482, ke0_val[1], eps );
            CHECK_REAL_EQUAL( 16.642, ke0_val[2], eps );
void read_mesh_parallel ( bool  rcbzoltan,
Definition at line 256 of file mpastrvpart.cpp.
References moab::ParallelComm::check_all_shared_handles(), CHECK_EQUAL, CHECK_ERR, ErrorCode, example, moab::ParallelComm::filter_pstatus(), moab::Interface::get_entities_by_type(), moab::ParallelComm::get_pcomm(), moab::Interface::load_file(), mb, MBEDGE, MBPOLYGON, MBVERTEX, moab::ProcConfig::proc_comm(), moab::ParallelComm::proc_config(), moab::ProcConfig::proc_rank(), moab::ProcConfig::proc_size(), moab::Range::psize(), PSTATUS_NOT, PSTATUS_NOT_OWNED, rank, read_options, moab::Range::size(), and moab::Interface::write_file().
    Core moab;
    read_options = "PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=";
    if( rcbzoltan )
        read_options = "PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=";
    ErrorCode rval = mb.load_file( example.c_str(), NULL, read_options.c_str() );CHECK_ERR( rval );
    rval = pcomm->check_all_shared_handles();CHECK_ERR( rval );
    // Get local vertices
    Range local_verts;
    rval = mb.get_entities_by_type( 0, MBVERTEX, local_verts );CHECK_ERR( rval );
    int verts_num = local_verts.size();
    if( 2 == procs )
        if( rcbzoltan )
            if( 0 == rank )
                CHECK_EQUAL( 685, verts_num );
                CHECK_EQUAL( 685, verts_num );  // Not owned vertices included
        else
            if( 0 == rank )
                CHECK_EQUAL( 1120, verts_num );
                CHECK_EQUAL( 1122, verts_num );  // Not owned vertices included
    rval = pcomm->filter_pstatus( local_verts, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval );
    if( 2 == procs )
        if( rcbzoltan )
            if( 0 == rank )
                CHECK_EQUAL( 595, verts_num );  // Not owned vertices excluded
        else
            if( 0 == rank )
                CHECK_EQUAL( 160, verts_num );  // Not owned vertices excluded
    // Get local edges
    Range local_edges;
    rval = mb.get_entities_by_type( 0, MBEDGE, local_edges );CHECK_ERR( rval );
    int edges_num = local_edges.size();
    if( 2 == procs )
        if( rcbzoltan )
            if( 0 == rank )
                CHECK_EQUAL( 1005, edges_num );
                CHECK_EQUAL( 1005, edges_num );  // Not owned edges included
        else
            if( 0 == rank )
                CHECK_EQUAL( 1438, edges_num );
                CHECK_EQUAL( 1444, edges_num );  // Not owned edges included
    rval = pcomm->filter_pstatus( local_edges, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval );
    if( 2 == procs )
        if( rcbzoltan )
            if( 0 == rank )
                CHECK_EQUAL( 915, edges_num );  // Not owned edges excluded
        else
            if( 0 == rank )
                CHECK_EQUAL( 482, edges_num );  // Not owned edges excluded
    // Get local cells
    Range local_cells;
    rval = mb.get_entities_by_type( 0, MBPOLYGON, local_cells );CHECK_ERR( rval );
    int cells_num = local_cells.size();
    if( 2 == procs )
        CHECK_EQUAL( 321, cells_num );
    rval = pcomm->filter_pstatus( local_cells, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval );
    if( 2 == procs )
    std::cout << "proc: " << rank << " verts:" << verts_num << "\n";
    int total_verts_num;
    MPI_Reduce( &verts_num, &total_verts_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() );
    if( 0 == rank )
        std::cout << "total vertices: " << total_verts_num << "\n";
        CHECK_EQUAL( 1280, total_verts_num );
    std::cout << "proc: " << rank << " edges:" << edges_num << "\n";
    int total_edges_num;
    MPI_Reduce( &edges_num, &total_edges_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() );
    if( 0 == rank )
        std::cout << "total edges: " << total_edges_num << "\n";
        CHECK_EQUAL( 1920, total_edges_num );
    std::cout << "proc: " << rank << " cells:" << cells_num << "\n";
    int total_cells_num;
    MPI_Reduce( &cells_num, &total_cells_num, 1, MPI_INT, MPI_SUM, 0, pcomm->proc_config().proc_comm() );
    if( 0 == rank )
        std::cout << "total cells: " << total_cells_num << "\n";
        CHECK_EQUAL( 642, total_cells_num );
#ifdef MOAB_HAVE_HDF5_PARALLEL
    std::string write_options( "PARALLEL=WRITE_PART;" );
    std::string output_file = "test_mpas";
    if( rcbzoltan ) output_file += "_rcbzoltan";
    if( no_mixed_elements ) output_file += "_no_mixed_elements";
    output_file += ".h5m";
    mb.write_file( output_file.c_str(), NULL, write_options.c_str() );
#endif
void read_one_cell_var ( bool  rcbzoltan,
Definition at line 134 of file mpastrvpart.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, eps, ErrorCode, example, moab::Interface::get_entities_by_type(), moab::ParallelComm::get_pcomm(), moab::Interface::globalId_tag(), moab::Interface::load_file(), mb, MB_TYPE_DOUBLE, MBEDGE, MBPOLYGON, moab::Range::psize(), rank, read_options, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
    Core moab;
    read_options = "PARALLEL=READ_PART;PARTITION_METHOD=TRIVIAL;NO_EDGES;VARIABLE=ke";
    if( rcbzoltan ) read_options = "PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN;NO_EDGES;VARIABLE=ke";
    // Get local edges
    Range local_edges;
    CHECK_EQUAL( (size_t)0, local_edges.size() );
    // Get local cells
    Range local_cells;
    Tag gid_tag = mb.globalId_tag();
    std::vector< int > gids( local_cells.size() );
    rval = mb.tag_get_data( gid_tag, local_cells, &gids[0] );
    Range local_cell_gids;
    std::copy( gids.rbegin(), gids.rend(), range_inserter( local_cell_gids ) );
    if( 2 == procs )
        CHECK_EQUAL( (size_t)321, local_cell_gids.size() );
        Tag ke_tag0;
        // Check tag for cell variable ke at timestep 1
        Tag ke_tag1;
        rval = mb.tag_get_handle( "ke1", 1, MB_TYPE_DOUBLE, ke_tag1 );CHECK_ERR( rval );
        // Get ke0 and ke1 tag values on 3 local cells
        double ke0_val[3];
        double ke1_val[3];
        rval = mb.tag_get_data( ke_tag1, cell_ents, 3, ke1_val );CHECK_ERR( rval );
        if( rcbzoltan )
            CHECK_EQUAL( (size_t)37, local_cell_gids.psize() );
            if( 0 == rank )
                CHECK_EQUAL( 1, (int)local_cell_gids[0] );
                CHECK_EQUAL( 284, (int)local_cell_gids[160] );
                CHECK_EQUAL( 630, (int)local_cell_gids[320] );
                CHECK_REAL_EQUAL( 16.284, ke0_val[1], eps );
                CHECK_REAL_EQUAL( 16.630, ke0_val[2], eps );
                CHECK_REAL_EQUAL( 25.001, ke1_val[0], eps );
                CHECK_REAL_EQUAL( 26.284, ke1_val[1], eps );
                CHECK_REAL_EQUAL( 26.630, ke1_val[2], eps );
                CHECK_EQUAL( 4, (int)local_cell_gids[0] );
                CHECK_EQUAL( 341, (int)local_cell_gids[160] );
                CHECK_EQUAL( 642, (int)local_cell_gids[320] );
                CHECK_REAL_EQUAL( 15.004, ke0_val[0], eps );
                CHECK_REAL_EQUAL( 16.341, ke0_val[1], eps );
                CHECK_REAL_EQUAL( 25.004, ke1_val[0], eps );
                CHECK_REAL_EQUAL( 26.341, ke1_val[1], eps );
                CHECK_REAL_EQUAL( 26.642, ke1_val[2], eps );
        else
            CHECK_EQUAL( (size_t)1, local_cell_gids.psize() );
            if( 0 == rank )
                CHECK_EQUAL( 161, (int)local_cell_gids[160] );
                CHECK_EQUAL( 321, (int)local_cell_gids[320] );
                CHECK_REAL_EQUAL( 26.161, ke1_val[1], eps );
                CHECK_REAL_EQUAL( 26.321, ke1_val[2], eps );
                CHECK_EQUAL( 322, (int)local_cell_gids[0] );
                CHECK_EQUAL( 482, (int)local_cell_gids[160] );
                CHECK_REAL_EQUAL( 26.322, ke1_val[0], eps );
                CHECK_REAL_EQUAL( 26.482, ke1_val[1], eps );
Definition at line 103 of file mpastrvpart.cpp.
References read_mesh_parallel().
    read_mesh_parallel( true, false );
Definition at line 108 of file mpastrvpart.cpp.
Referenced by main().
    read_mesh_parallel( true, true );
Definition at line 98 of file mpastrvpart.cpp.
    read_mesh_parallel( false, true );
Definition at line 83 of file mpastrvpart.cpp.
References read_one_cell_var().
    read_one_cell_var( true, false );
Definition at line 88 of file mpastrvpart.cpp.
    read_one_cell_var( true, true );
Definition at line 78 of file mpastrvpart.cpp.
    read_one_cell_var( false, true );
Variable Documentation
Definition at line 42 of file mpastrvpart.cpp.
Definition at line 13 of file mpastrvpart.cpp.
Definition at line 41 of file mpastrvpart.cpp.
