Mesh Oriented datABase
(version 5.4.1)
#include "iGeom.h"
#include "iMesh.h"
#include "iRel.h"
#include <cstdio>
#include <cstdlib>
#include <cstring>
#include "MBiMesh.hpp"
#include "moab/Core.hpp"
Defines | |
#define | STRINGIFY_(X) #X |
#define | STRINGIFY(X) STRINGIFY_( X ) |
#define | CHECK_SIZE_C(type, array, allocated_size, size) |
Typedefs | |
typedef void * | iRel_EntityHandle |
Functions | |
int | print_geom_info (iGeom_Instance geom, iBase_EntityHandle gent) |
int | print_mesh_info (iMesh_Instance mesh, iBase_EntityHandle ment) |
int | load_geom_mesh (const char *geom_filename, const char *mesh_filename, iGeom_Instance geom, iMesh_Instance mesh) |
int | create_relation (iRel_Instance assoc, iGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle *pair) |
int | relate_geom_mesh (iRel_Instance assoc, iGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair) |
int | compute_normals (iRel_Instance assoc, iGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair) |
int | main (int argc, char *argv[]) |
#define CHECK_SIZE_C | ( | type, | |
array, | |||
allocated_size, | |||
size | |||
if( NULL == *( array ) || *( allocated_size ) == 0 ) \ { \ *( array ) = (type*)malloc( sizeof( type ) * ( size ) ); \ *( allocated_size ) = size; \ } \ else if( *( allocated_size ) < ( size ) ) \ { \ printf( " Array passed in is non-zero but too short.\n" ); \ }
Definition at line 31 of file normals.cpp.
#define STRINGIFY | ( | X | ) | STRINGIFY_( X ) |
Definition at line 20 of file normals.cpp.
#define STRINGIFY_ | ( | X | ) | #X |
Definition at line 19 of file normals.cpp.
typedef void* iRel_EntityHandle |
Definition at line 42 of file normals.cpp.
int compute_normals | ( | iRel_Instance | assoc, |
iGeom_Instance | geom, | ||
iMesh_Instance | mesh, | ||
iRel_PairHandle | pair | ||
Definition at line 427 of file normals.cpp.
References ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), iBase_FACE, iBase_SUCCESS, iMesh_isList, iRel_getEntArrSetArrRelation, mb, MB_SUCCESS, mesh, print_geom_info(), moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by main().
{ int result; int i; iBase_EntityHandle* gentities = NULL; int gentities_size = 0, gentities_alloc = 0; iBase_EntitySetHandle* out_mentities = NULL; int out_mentities_size, out_mentities_alloc = 0; /* get all the face geo entities, and find relation to some mesh entity */ iGeom_getEntities( geom, NULL, iBase_FACE, &gentities, &gentities_alloc, &gentities_size, &result ); if( iBase_SUCCESS != result ) { printf( "Problem getting all geom entities.\n" ); return 0; } for( i = 0; i < gentities_size; i++ ) { print_geom_info( geom, gentities[i] ); } iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities, &out_mentities_alloc, &out_mentities_size, &result ); /* might not all be */ if( iBase_SUCCESS != result ) { printf( "Failed to get mesh entities related to geom entities in compute_normals.\n" ); return 0; } /* check that they're all non-null */ if( out_mentities_size != gentities_size ) { printf( "Number of mesh & related geom entities don't match.\n" ); return 0; } /* check to make sure they're mesh sets; how to do that? */ for( i = 0; i < out_mentities_size; i++ ) { int is_list; iMesh_isList( mesh, (iBase_EntitySetHandle)out_mentities[i], &is_list, &result ); if( iBase_SUCCESS != result ) { printf( "Entity set returned from classification wasn't valid.\n" ); return 0; } } moab::Interface* mb = reinterpret_cast< MBiMesh* >( mesh )->mbImpl; if( !mb ) return 0; moab::ErrorCode rval = MB_SUCCESS; moab::Tag idtag; rval = mb->tag_get_handle( "GLOBAL_ID", idtag ); if( MB_SUCCESS != rval ) return 0; for( i = 0; i < gentities_size; i++ ) { EntityHandle meshSet = (EntityHandle)out_mentities[i]; Range faces; rval = mb->get_entities_by_dimension( meshSet, 2, faces ); // MB_CHK_ERR(rval); Range vertices; rval = mb->get_connectivity( faces, vertices ); std::vector< double > coords; coords.resize( vertices.size() * 3 ); rval = mb->get_coords( vertices, &coords[0] ); int id; rval = mb->tag_get_data( idtag, &meshSet, 1, &id ); printf( "surface %d has %d faces and %d vertices \n", id, (int)faces.size(), (int)vertices.size() ); std::vector< double > normals; normals.resize( 3 * vertices.size() ); std::vector< double > on_coordinates; on_coordinates.resize( 3 * vertices.size() ); for( int j = 0; j < (int)vertices.size(); j++ ) { iGeom_getEntNrmlXYZ( geom, gentities[i], coords[3 * j], coords[3 * j + 1], coords[3 * j + 2], &normals[3 * j], &normals[3 * j + 1], &normals[3 * j + 2], &result ); if( iBase_SUCCESS != result ) { printf( "Problem getting normals.\n" ); return 0; } EntityHandle vertex = vertices[j]; rval = mb->tag_get_data( idtag, &vertex, 1, &id ); printf( "v: %4d coor: %12.6f %12.6f %12.6f norm: %12.6f %12.6f %12.6f \n", id, coords[3 * j], coords[3 * j + 1], coords[3 * j + 2], normals[3 * j], normals[3 * j + 1], normals[3 * j + 2] ); ; } } free( gentities ); gentities = NULL; free( out_mentities ); out_mentities = NULL; /* ok, we're done */ return 1; }
int create_relation | ( | iRel_Instance | assoc, |
iRel_PairHandle * | pair | ||
Definition at line 195 of file normals.cpp.
References iBase_SUCCESS, iRel_ACTIVE, iRel_createPair, iRel_ENTITY, iRel_findPairs, iRel_getPairInfo, iRel_IGEOM_IFACE, iRel_IMESH_IFACE, and iRel_SET.
{ int result; iBase_Instance iface1, iface2; int type1, type2; int ent_or_set1, ent_or_set2; int status1, status2; iRel_PairHandle tmp_pair; iRel_PairHandle* pair_ptr = &tmp_pair; int pairs_alloc = 1, pairs_size; /* create an relation, entity to set */ iRel_createPair( assoc, geom, iRel_ENTITY, iRel_IGEOM_IFACE, iRel_ACTIVE, mesh, iRel_SET, iRel_IMESH_IFACE, iRel_ACTIVE, pair, &result ); if( iBase_SUCCESS != result ) { printf( "Couldn't create a new relation.\n" ); return 0; } iRel_getPairInfo( assoc, *pair, &iface1, &ent_or_set1, &type1, &status1, &iface2, &ent_or_set2, &type2, &status2, &result ); if( iBase_SUCCESS != result ) { printf( "Couldn't retrieve relation info.\n" ); return 0; } if( iface1 != geom || ent_or_set1 != iRel_ENTITY || type1 != iRel_IGEOM_IFACE || iface2 != mesh || ent_or_set2 != iRel_SET || type2 != iRel_IMESH_IFACE ) { printf( "Unexpected relation info returned.\n" ); return 0; } iRel_findPairs( assoc, geom, &pair_ptr, &pairs_alloc, &pairs_size, &result ); if( iBase_SUCCESS != result ) { printf( "Couldn't find relation pair when querying geom.\n" ); return 0; } if( pairs_size != 1 || tmp_pair != *pair ) { printf( "Unexpected relation pairs returned when querying geom.\n" ); return 0; } iRel_findPairs( assoc, mesh, &pair_ptr, &pairs_alloc, &pairs_size, &result ); if( iBase_SUCCESS != result ) { printf( "Couldn't find relation pair when querying mesh.\n" ); return 0; } if( pairs_size != 1 || tmp_pair != *pair ) { printf( "Unexpected relation pairs returned when querying mesh.\n" ); return 0; } return 1; }
int load_geom_mesh | ( | const char * | geom_filename, |
const char * | mesh_filename, | ||
iMesh_Instance | mesh | ||
Definition at line 169 of file normals.cpp.
References iBase_SUCCESS, and iMesh_load.
{ /* load a geom */ int result; iGeom_load( geom, geom_filename, 0, &result, strlen( geom_filename ), 0 ); if( iBase_SUCCESS != result ) { printf( "ERROR : can not load a geometry\n" ); return 0; } /* load a mesh */ iMesh_load( mesh, 0, mesh_filename, 0, &result, strlen( mesh_filename ), 0 ); if( iBase_SUCCESS != result ) { printf( "ERROR : can not load a mesh\n" ); return 0; } return 1; }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 535 of file normals.cpp.
References compute_normals(), create_relation(), geom, iMesh_dtor, iMesh_newMesh, iRel_create, iRel_destroy, load_geom_mesh(), mesh, and relate_geom_mesh().
{ /* Check command line arg */ const char* geom_filename = DEFAULT_GEOM; const char* mesh_filename = DEFAULT_MESH; int result; iGeom_Instance geom; iMesh_Instance mesh; iRel_Instance assoc; iRel_PairHandle pair; printf( "Usage: %s %s\n", geom_filename, mesh_filename ); if( argc == 2 && !strcmp( argv[1], "-h" ) ) { printf( "Usage: %s <geom_filename> <mesh_filename>\n", argv[0] ); return 1; } else if( argc == 2 ) { geom_filename = argv[1]; mesh_filename = argv[1]; } else if( argc == 3 ) { geom_filename = argv[1]; mesh_filename = argv[2]; } /* initialize the Geometry */ iGeom_newGeom( 0, &geom, &result, 0 ); /* initialize the Mesh */ iMesh_newMesh( 0, &mesh, &result, 0 ); /* initialize the Associate */ iRel_create( 0, &assoc, &result, 0 ); printf( " load_geom_mesh: \n" ); result = load_geom_mesh( geom_filename, mesh_filename, geom, mesh ); printf( " create_relation: \n" ); result = create_relation( assoc, geom, mesh, &pair ); printf( " relate_geom_mesh: \n" ); result = relate_geom_mesh( assoc, geom, mesh, pair ); /* compute normals */ printf( " compute normals: \n" ); result = compute_normals( assoc, geom, mesh, pair ); /* summary */ iRel_destroy( assoc, &result ); iMesh_dtor( mesh, &result ); iGeom_dtor( geom, &result ); return 0; }
int print_geom_info | ( | iGeom_Instance | geom, |
iBase_EntityHandle | gent | ||
Definition at line 44 of file normals.cpp.
References iBase_SUCCESS.
Referenced by compute_normals(), and query_relations_test().
{ /* print information about this entity */ int ent_type; int result; const char* type_names[] = { "Vertex", "Edge", "Face", "Region" }; iGeom_getEntType( geom, gent, &ent_type, &result ); if( iBase_SUCCESS != result ) { printf( "Trouble getting entity adjacencies or types." ); return 0; } printf( "%s 0x%lx\n", type_names[ent_type], (unsigned long)gent ); return 1; }
int print_mesh_info | ( | iMesh_Instance | mesh, |
iBase_EntityHandle | ment | ||
Definition at line 64 of file normals.cpp.
References iBase_ALL_TYPES, iBase_BYTES, iBase_DOUBLE, iBase_ENTITY_HANDLE, iBase_INTEGER, iBase_SUCCESS, iMesh_getAllTags, iMesh_getData, iMesh_getDblData, iMesh_getEHData, iMesh_getEntAdj, iMesh_getEntArrType, iMesh_getIntData, iMesh_getTagName, and iMesh_getTagType.
{ /* print information about this entity */ /* get adjacencies first; assume not more than 50 */ iBase_EntityHandle adj_ents[500], *adj_ents_ptr = adj_ents; int ent_types[500], *ent_types_ptr = ent_types; int adj_ents_alloc = 500, adj_ents_size, ent_types_size, ent_types_allocated = 500; int result; iBase_TagHandle* ment_tags = NULL; int ment_tags_size, ment_tags_alloc; char** tag_names; int i; const char* type_names[] = { "Vertex", "Edge", "Face", "Region" }; iMesh_getEntAdj( mesh, ment, iBase_ALL_TYPES, &adj_ents_ptr, &adj_ents_alloc, &adj_ents_size, &result ); if( iBase_SUCCESS != result ) return 0; /* put this ent on the end, then get types */ adj_ents[adj_ents_size] = ment; iMesh_getEntArrType( mesh, adj_ents, adj_ents_size + 1, &ent_types_ptr, &ent_types_allocated, &ent_types_size, &result ); if( iBase_SUCCESS != result ) { printf( "Trouble getting entity adjacencies or types." ); return 0; } /* get tags on ment */ iMesh_getAllTags( mesh, ment, &ment_tags, &ment_tags_alloc, &ment_tags_size, &result ); printf( "Trouble getting tags on an entity or their names." ); /* while we're at it, get all the tag names */ tag_names = (char**)malloc( ment_tags_size * sizeof( char* ) ); for( i = 0; i < ment_tags_size; i++ ) { tag_names[i] = (char*)malloc( 120 * sizeof( char ) ); iMesh_getTagName( mesh, ment_tags[i], tag_names[i], &result, 120 ); } /* now print the information */ printf( "%s %ld:\n", type_names[ent_types[ent_types_size - 1]], (long)ment ); printf( "Adjacencies:" ); for( i = 0; i < adj_ents_size; i++ ) { if( i > 0 ) printf( ", " ); printf( "%s %ld", type_names[ent_types[i]], (long)adj_ents[i] ); } printf( "\nTags: \n" ); for( i = 0; i < ment_tags_size; i++ ) { int tag_type; printf( "%s ", tag_names[i] ); iMesh_getTagType( mesh, ment_tags[i], &tag_type, &result ); if( iBase_SUCCESS != result ) printf( "(trouble getting type...)\n" ); else { char* dum_handle = NULL; int dum_handle_alloc = 0, dum_handle_size = 0; int int_data; double dbl_data; iBase_EntityHandle eh_data; switch( tag_type ) { case iBase_INTEGER: iMesh_getIntData( mesh, ment, ment_tags[i], &int_data, &result ); printf( "(Int value=%d)", int_data ); break; case iBase_DOUBLE: iMesh_getDblData( mesh, ment, ment_tags[i], &dbl_data, &result ); printf( "(Dbl value=%f)", dbl_data ); break; case iBase_ENTITY_HANDLE: iMesh_getEHData( mesh, ment, ment_tags[i], &eh_data, &result ); printf( "(EH value=%ld)", (long)eh_data ); break; case iBase_BYTES: iMesh_getData( mesh, ment, ment_tags[i], (void**)&dum_handle, &dum_handle_alloc, &dum_handle_size, &result ); if( NULL != dum_handle && dum_handle_size > 0 ) printf( "(Opaque value=%c)", dum_handle[0] ); break; } } printf( "\n" ); } printf( "(end tags)\n\n" ); free( ment_tags ); return 1; }
int relate_geom_mesh | ( | iRel_Instance | assoc, |
Definition at line 260 of file normals.cpp.
References dim, iBase_ALL_TYPES, iBase_INTEGER, iBase_SUCCESS, iBase_TAG_ALREADY_EXISTS, iBase_VERTEX, iMesh_createTag, iMesh_getEntSetIntData, iMesh_getEntSets, iRel_getEntArrSetArrRelation, iRel_getSetArrEntArrRelation, iRel_inferAllRelations, iRel_inferEntArrRelations, iRel_inferSetArrRelations, iRel_rmvEntArrRelation, and iRel_setEntArrSetArrRelation.
{ int result; iBase_EntityHandle* gentities = NULL; int gentities_size = 0, gentities_alloc = 0; iBase_EntitySetHandle* mentity_handles = NULL; int mentity_handles_size = 0, mentity_handles_alloc = 0; const char* dim_tag_name = "GEOM_DIMENSION"; iBase_TagHandle dim_tag_mesh; iBase_EntitySetHandle* mentities_vec; int mentities_vec_size = 0; int i; iBase_EntitySetHandle* out_mentities = NULL; int out_mentities_size = 0, out_mentities_alloc = 0; iBase_EntitySetHandle* out_mentities2 = NULL; int out_mentities2_size = 0, out_mentities2_alloc = 0; iBase_EntityHandle* out_gentities = NULL; int out_gentities_size = 0, out_gentities_alloc = 0; /* relate geometry entities with coresponding mesh entity sets */ iGeom_getEntities( geom, NULL, iBase_VERTEX, &gentities, &gentities_alloc, &gentities_size, &result ); if( iBase_SUCCESS != result ) { printf( "Failed to get gentities by type in relate_geom_mesh.\n" ); return 0; } iRel_inferEntArrRelations( assoc, pair, gentities, gentities_size, 0, &result ); if( iBase_SUCCESS != result ) { printf( "Failed to relate geom entities in relate_geom_mesh.\n" ); return 0; } /* relate coresponding mesh entity sets for geometry entities */ /* get 1-dimensional mesh entitysets */ iMesh_getEntSets( mesh, NULL, 1, &mentity_handles, &mentity_handles_alloc, &mentity_handles_size, &result ); if( iBase_SUCCESS != result ) { printf( "Problem to get all entity sets.\n" ); return 0; } /* get geom dimension tags for mesh entitysets */ iMesh_createTag( mesh, dim_tag_name, 1, iBase_INTEGER, &dim_tag_mesh, &result, 15 ); if( iBase_SUCCESS != result && result != iBase_TAG_ALREADY_EXISTS ) { printf( "Couldn't create geom dim tag for mesh entities.\n" ); return 0; } /* get 1-dimensional mesh entitysets */ mentities_vec = (iBase_EntitySetHandle*)malloc( mentity_handles_size * sizeof( iBase_EntitySetHandle ) ); for( i = 0; i < mentity_handles_size; i++ ) { /* test */ int dim; iMesh_getEntSetIntData( mesh, mentity_handles[i], dim_tag_mesh, &dim, &result ); if( iBase_SUCCESS != result ) continue; if( dim == 1 ) mentities_vec[mentities_vec_size++] = mentity_handles[i]; } iRel_inferSetArrRelations( assoc, pair, mentities_vec, mentities_vec_size, 1, &result ); if( iBase_SUCCESS != result ) { printf( "Failed to relate mesh entities in relate_geom_mesh.\n" ); return 0; } /* relate all geometry and mesh entities */ iRel_inferAllRelations( assoc, pair, &result ); if( iBase_SUCCESS != result ) { printf( "Failed to relate all geom and mesh entities in relate_geom_mesh.\n" ); return 0; } /* reset geom entities list and get all geom entities (prev only vertices) */ free( gentities ); gentities = NULL; gentities_alloc = 0; iGeom_getEntities( geom, NULL, iBase_ALL_TYPES, &gentities, &gentities_alloc, &gentities_size, &result ); if( iBase_SUCCESS != result ) { printf( "Failed to get gentities by type in relate_geom_mesh.\n" ); return 0; } /* get related mesh entity sets for geometry entities */ iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities, &out_mentities_alloc, &out_mentities_size, &result ); if( iBase_SUCCESS != result ) { printf( "Failed to get geom entities in relate_geom_mesh.\n" ); return 0; } if( out_mentities_size != gentities_size ) { printf( "Number of input geom entities and output mesh entity sets should be same\n" ); return 0; } /* now try deleting this relation */ iRel_rmvEntArrRelation( assoc, pair, gentities, gentities_size, 0, &result ); if( iBase_SUCCESS != result ) { printf( "Failed to remove relation in relate_geom_mesh.\n" ); return 0; } iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities2, &out_mentities2_alloc, &out_mentities2_size, &result ); if( iBase_SUCCESS == result ) { printf( "Shouldn't have gotten mesh sets in relate_geom_mesh.\n" ); return 0; } /* restore the relation, since we need it later */ iRel_setEntArrSetArrRelation( assoc, pair, gentities, gentities_size, out_mentities, out_mentities_size, &result ); if( iBase_SUCCESS != result ) { printf( "Failed to restore relation in relate_geom_mesh.\n" ); return 0; } /* get related geometry entities for mesh entity sets */ iRel_getSetArrEntArrRelation( assoc, pair, out_mentities, out_mentities_size, 1, &out_gentities, &out_gentities_alloc, &out_gentities_size, &result ); if( iBase_SUCCESS != result ) { printf( "Failed to get mesh entities in relate_geom_mesh.\n" ); return 0; } if( out_mentities_size != out_gentities_size ) { printf( "Number of input mesh entity sets and output geom entities should be same\n" ); return 0; } free( mentity_handles ); mentity_handles = NULL; free( gentities ); gentities = NULL; free( mentity_handles ); mentity_handles = NULL; free( out_mentities ); out_mentities = NULL; free( mentities_vec ); mentities_vec = NULL; free( out_gentities ); out_gentities = NULL; return 1; }
