obb_tree_tool.cpp File Reference
#include "moab/Core.hpp"
#include "moab/CartVect.hpp"
#include "moab/OrientedBoxTreeTool.hpp"
#include "moab/OrientedBox.hpp"
#include "Internals.hpp"
#include "moab/Range.hpp"
#include <iostream>
#include <iomanip>
#include <cstdio>
#include <limits>
#include <cstdlib>
#include <ctime>
#include <unistd.h>
#include <sys/stat.h>
#include <fcntl.h>
+ Include dependency graph for obb_tree_tool.cpp:
Classes
struct  SimpleStat< T >
class  TriTagger
class  VtxTagger
class  LeafHexer
Defines
#define IS_BUILDING_MB
Functions
std::string clock_to_string (clock_t t)
std::string mem_to_string (unsigned long mem)
ErrorCode get_root (Interface *moab, EntityHandle &root)
EntityHandle build_tree (Interface *interface, OrientedBoxTreeTool::Settings settings)
void delete_existing_tree (Interface *interface)
void print_stats (Interface *interface)
void tag_triangles (Interface *interface)
void tag_vertices (Interface *interface)
void write_tree_blocks (Interface *interface, const char *file)
static void usage (bool err=true)
static void memory_use (unsigned long long &vsize, unsigned long long &rss)
static int parseint (int &i, int argc, char *argv[])
static double parsedouble (int &i, int argc, char *argv[])
int main (int argc, char *argv[])
static int hash_handle (EntityHandle handle)
Variables
const int MAX_TAG_VALUE = 20
const char *const TAG_NAME = "OBB_ID"
const char *const TREE_TAG = "OBB_ROOT"
const char * root_tag = TREE_TAG
Define Documentation
Definition at line 1 of file obb_tree_tool.cpp.
Function Documentation
Definition at line 299 of file obb_tree_tool.cpp.
References moab::OrientedBoxTreeTool::build(), moab::Range::empty(), ErrorCode, moab::Interface::get_entities_by_type(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_HANDLE, MBTRI, mesh, root_tag, moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
    ErrorCode rval;
    EntityHandle root = 0;
    Range triangles;
    rval = interface->get_entities_by_type( 0, MBTRI, triangles );
    if( MB_SUCCESS != rval || triangles.empty() )
        std::cerr << "No triangles from which to build tree." << std::endl;
        exit( 4 );
    OrientedBoxTreeTool tool( interface );
    rval = tool.build( triangles, root, &settings );
    if( MB_SUCCESS != rval || !root )
        std::cerr << "Tree construction failed." << std::endl;
        exit( 4 );
    // store tree root
    Tag roottag;
    rval = interface->tag_get_handle( root_tag, 1, MB_TYPE_HANDLE, roottag, MB_TAG_CREAT | MB_TAG_SPARSE );
    if( MB_SUCCESS != rval )
        std::cout << "Failed to create root tag: \"" << root_tag << '"' << std::endl;
        exit( 2 );
    const EntityHandle mesh = 0;
    rval                    = interface->tag_set_data( roottag, &mesh, 1, &root );
        std::cout << "Failed to set root tag: \"" << root_tag << '"' << std::endl;
        exit( 2 );
    return root;
std::string clock_to_string ( clock_t  t)
void delete_existing_tree ( Interface interface)
ErrorCode get_root ( Interface moab,
EntityHandle root
Definition at line 271 of file obb_tree_tool.cpp.
References ErrorCode, MB_SUCCESS, MB_TYPE_HANDLE, mesh, root_tag, moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by print_stats(), and tag_triangles().
    Tag tag;
    ErrorCode rval;
    rval = moab->tag_get_handle( root_tag, 1, MB_TYPE_HANDLE, tag );
    if( MB_SUCCESS != rval ) return rval;
    return moab->tag_get_data( tag, &mesh, 1, &root );
static int hash_handle ( EntityHandle  handle) [static]
Definition at line 458 of file obb_tree_tool.cpp.
References moab::ID_FROM_HANDLE(), and MAX_TAG_VALUE.
Referenced by TriTagger::leaf(), VtxTagger::leaf(), and LeafHexer::leaf().
    EntityID h = ID_FROM_HANDLE( handle );
    return (int)( ( h * 13 + 7 ) % MAX_TAG_VALUE ) + 1;
int main ( int  argc,
char *  argv[]
Definition at line 135 of file obb_tree_tool.cpp.
References moab::OrientedBoxTreeTool::Settings::best_split_ratio, build_time, build_tree(), clock_to_string(), delete_existing_tree(), ErrorCode, input_file, load_time, moab::OrientedBoxTreeTool::Settings::max_depth, moab::OrientedBoxTreeTool::Settings::max_leaf_entities, MB_SUCCESS, MESHSET_SET, parsedouble(), parseint(), print_stats(), root_tag, moab::OrientedBoxTreeTool::Settings::set_options, settings, tag_time(), tag_triangles(), tag_vertices(), usage, moab::OrientedBoxTreeTool::Settings::worst_split_ratio, and write_tree_blocks().
    const char* input_file  = 0;
    const char* output_file = 0;
    const char* tree_file   = 0;
    OrientedBoxTreeTool::Settings settings;
    bool tag_tris = false;
    clock_t load_time, build_time, stat_time, tag_time, write_time, block_time;
    for( int i = 1; i < argc; ++i )
        if( argv[i][0] != '-' )
            if( !input_file )
                input_file = argv[i];
            else if( !output_file )
                output_file = argv[i];
            else
                usage();
            continue;
        if( !argv[i][1] || argv[i][2] ) usage();
        switch( argv[i][1] )
            case 's':
                settings.set_options = MESHSET_SET;
                break;
            case 'S':
                settings.set_options = MESHSET_ORDERED;
                break;
            case 'd':
                settings.max_depth = parseint( i, argc, argv );
                break;
            case 'n':
                settings.max_leaf_entities = parseint( i, argc, argv );
                break;
            case 'm':
                settings.worst_split_ratio = parsedouble( i, argc, argv );
                break;
            case 'M':
                settings.best_split_ratio = parsedouble( i, argc, argv );
                break;
            case 't':
                tag_tris = true;
                break;
            case 'T':
                if( ++i == argc ) usage();
                tree_file = argv[i];
                break;
            case 'N':
                root_tag = argv[i];
                break;
            case 'h':
                usage( false );
                break;
            default:
                usage();
    if( !output_file ) usage();
    ErrorCode rval;
    Core moab_core;
    Interface* interface = &moab_core;
    load_time = clock();
    rval      = interface->load_mesh( input_file );
        std::cerr << "Error reading file: " << input_file << std::endl;
        exit( 2 );
    load_time = clock() - load_time;
    delete_existing_tree( interface );
    std::cout << "Building tree..." << std::endl;
    build_time = clock();
    build_tree( interface, settings );
    build_time = clock() - build_time;
    std::cout << "Calculating stats..." << std::endl;
    print_stats( interface );
    stat_time = clock() - build_time;
    if( tag_tris )
        std::cout << "Tagging tree..." << std::endl;
        tag_triangles( interface );
        tag_vertices( interface );
    tag_time = clock() - stat_time;
    std::cout << "Writing file... ";
    std::cout.flush();
    rval = interface->write_mesh( output_file );
        std::cerr << "Error writing file: " << output_file << std::endl;
        exit( 3 );
    write_time = clock() - tag_time;
    std::cout << "Wrote " << output_file << std::endl;
    if( tree_file )
        std::cout << "Writing tree block rep...";
        std::cout.flush();
        write_tree_blocks( interface, tree_file );
        std::cout << "Wrote " << tree_file << std::endl;
    block_time = clock() - write_time;
    std::cout << "Times:  "
              << "    Load"
              << "   Build"
              << "   Stats"
              << "   Write";
    if( tag_tris ) std::cout << "Tag Sets";
    if( tree_file ) std::cout << "Block   ";
    std::cout << std::endl;
    std::cout << "        " << std::setw( 8 ) << clock_to_string( load_time ) << std::setw( 8 )
              << clock_to_string( build_time ) << std::setw( 8 ) << clock_to_string( stat_time ) << std::setw( 8 )
              << clock_to_string( write_time );
    if( tag_tris ) std::cout << std::setw( 8 ) << clock_to_string( tag_time );
    if( tree_file ) std::cout << std::setw( 8 ) << clock_to_string( block_time );
    return 0;
std::string mem_to_string ( unsigned long  mem)
Definition at line 360 of file obb_tree_tool.cpp.
References buffer, and moab::unit().
    char unit[3] = "B";
    if( mem > 9 * 1024 )
        mem = ( mem + 512 ) / 1024;
        strcpy( unit, "kB" );
        strcpy( unit, "MB" );
        strcpy( unit, "GB" );
    char buffer[256];
    sprintf( buffer, "%lu %s", mem, unit );
    return buffer;
static void memory_use ( unsigned long long &  vsize,
unsigned long long &  rss
) [static]
Definition at line 68 of file obb_tree_tool.cpp.
References buffer.
Referenced by print_stats().
    char buffer[512];
    unsigned long lvsize;
    long lrss;
    int filp  = open( "/proc/self/stat", O_RDONLY );
    ssize_t r = read( filp, buffer, sizeof( buffer ) - 1 );
    close( filp );
    if( r < 0 ) r = 0;
    lvsize = lrss = 0;
    buffer[r]     = '\0';
    sscanf( buffer,
            "%*d %*s %*c "      // pid command state
            "%*d %*d "          // ppid pgrp
            "%*d %*d %*d "      // session tty_nr tpgid
            "%*u "              // flags
            "%*u %*u %*u %*u "  // minflt cminflt majflt cmajflt
            "%*u %*u %*d %*d "  // utime stime cutime cstime
            "%*d %*d %*d "      // priority nice (unused)
            "%*d %*u "          // itrealval starttime
            "%lu %ld",
            &lvsize, &lrss );
    rss   = lrss * getpagesize();
    vsize = lvsize;
static double parsedouble ( int &  i,
int  argc,
char *  argv[]
) [static]
Definition at line 115 of file obb_tree_tool.cpp.
References usage.
Referenced by main().
    char* end;
    ++i;
    if( i == argc )
        std::cerr << "Expected value following '" << argv[i - 1] << "'" << std::endl;
        usage();
    double result = strtod( argv[i], &end );
    if( result < 0 || *end )
        std::cerr << "Expected positive real number following '" << argv[i - 1] << "'" << std::endl;
        usage();
    return result;
static int parseint ( int &  i,
int  argc,
char *  argv[]
) [static]
Definition at line 95 of file obb_tree_tool.cpp.
References usage.
    char* end;
    ++i;
    if( i == argc )
        usage();
    int result = strtol( argv[i], &end, 0 );
        std::cerr << "Expected positive integer following '" << argv[i - 1] << "'" << std::endl;
        usage();
    return result;
void print_stats ( Interface interface)
Definition at line 410 of file obb_tree_tool.cpp.
References moab::Range::begin(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Interface::estimated_memory_use(), moab::Interface::get_entities_by_type(), moab::Interface::get_number_entities_by_type(), get_root(), moab::Range::insert(), MB_SUCCESS, MBENTITYSET, MBTRI, MBVERTEX, moab::mem_to_string(), memory_use(), moab::Range::merge(), and moab::OrientedBoxTreeTool::stats().
    EntityHandle root;
    Range range;
    ErrorCode rval;
    rval = get_root( interface, root );
        std::cerr << "Internal error: Failed to retrieve root." << std::endl;
        exit( 5 );
    Range tree_sets, triangles, verts;
    // interface->get_child_meshsets( root, tree_sets, 0 );
    interface->get_entities_by_type( 0, MBENTITYSET, tree_sets );
    tree_sets.erase( tree_sets.begin(), Range::lower_bound( tree_sets.begin(), tree_sets.end(), root ) );
    interface->get_entities_by_type( 0, MBVERTEX, verts );
    triangles.merge( verts );
    tree_sets.insert( root );
    unsigned long long set_used, set_amortized, set_store_used, set_store_amortized, set_tag_used, set_tag_amortized,
        tri_used, tri_amortized;
    interface->estimated_memory_use( tree_sets, &set_used, &set_amortized, &set_store_used, &set_store_amortized, 0, 0,
                                     0, 0, &set_tag_used, &set_tag_amortized );
    interface->estimated_memory_use( triangles, &tri_used, &tri_amortized );
    int num_tri = 0;
    interface->get_number_entities_by_type( 0, MBTRI, num_tri );
    tool.stats( root, std::cout );
    unsigned long long real_rss, real_vsize;
    memory_use( real_vsize, real_rss );
    printf( "------------------------------------------------------------------\n" );
    printf( "\nmemory:           used  amortized\n" );
    printf( "            ---------- ----------\n" );
    printf( "triangles   %10s %10s\n", mem_to_string( tri_used ).c_str(), mem_to_string( tri_amortized ).c_str() );
    printf( "sets (total)%10s %10s\n", mem_to_string( set_used ).c_str(), mem_to_string( set_amortized ).c_str() );
    printf( "sets        %10s %10s\n", mem_to_string( set_store_used ).c_str(),
            mem_to_string( set_store_amortized ).c_str() );
    printf( "set tags    %10s %10s\n", mem_to_string( set_tag_used ).c_str(),
            mem_to_string( set_tag_amortized ).c_str() );
    printf( "total real  %10s %10s\n", mem_to_string( real_rss ).c_str(), mem_to_string( real_vsize ).c_str() );
void tag_triangles ( Interface interface)
Definition at line 492 of file obb_tree_tool.cpp.
References ErrorCode, get_root(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, moab::OrientedBoxTreeTool::preorder_traverse(), moab::Interface::tag_get_handle(), and TAG_NAME.
    EntityHandle root;
    ErrorCode rval = get_root( moab, root );
        std::cerr << "Internal error: Failed to retrieve tree." << std::endl;
        exit( 5 );
    Tag tag;
    int zero = 0;
    moab->tag_get_handle( TAG_NAME, 1, MB_TYPE_INTEGER, tag, MB_TAG_DENSE | MB_TAG_CREAT, &zero );
    TriTagger op( tag, moab );
    OrientedBoxTreeTool tool( moab );
    rval = tool.preorder_traverse( root, op );
        std::cerr << "Internal error tagging triangles" << std::endl;
        exit( 5 );
void tag_vertices ( Interface interface)
static void usage ( bool  err = true) [static]
Definition at line 39 of file obb_tree_tool.cpp.
References moab::OrientedBoxTreeTool::Settings::best_split_ratio, moab::OrientedBoxTreeTool::Settings::max_depth, moab::OrientedBoxTreeTool::Settings::max_leaf_entities, TREE_TAG, and moab::OrientedBoxTreeTool::Settings::worst_split_ratio.
    std::ostream& s = err ? std::cerr : std::cout;
    s << "obb_tree_tool [-s|-S] [-d <int>] [-n <int>] <input file> <output file>" << std::endl
      << "obb_tree_tool [-h]" << std::endl;
    if( !err )
        OrientedBoxTreeTool::Settings st;
        s << "Tool to build adaptive kd-Tree from triangles" << std::endl;
        s << "  -s        Use range-based sets for tree nodes" << std::endl
          << "  -S        Use vector-based sets for tree nodes" << std::endl
          << "  -d <int>  Specify maximum depth for tree. Default: " << st.max_depth << std::endl
          << "  -n <int>  Specify maximum entities per leaf. Default: " << st.max_leaf_entities << std::endl
          << "  -m <real> Specify worst split ratio. Default: " << st.worst_split_ratio << std::endl
          << "  -M <real> Specify best split ratio. Default: " << st.best_split_ratio << std::endl
          << "  -t        Tag triangles will tree cell number." << std::endl
          << "  -T        Write tree boxes to file." << std::endl
          << "  -N        Specify mesh tag containing tree root. Default: \"" << TREE_TAG << '"' << std::endl
          << std::endl;
    exit( err );
void write_tree_blocks ( Interface interface,
const char *  file
Variable Documentation
Definition at line 26 of file obb_tree_tool.cpp.
const char* root_tag = TREE_TAG
Definition at line 29 of file obb_tree_tool.cpp.
Referenced by build_tree(), get_root(), and main().
const char* const TAG_NAME = "OBB_ID"
Definition at line 27 of file obb_tree_tool.cpp.
const char* const TREE_TAG = "OBB_ROOT"
Definition at line 28 of file obb_tree_tool.cpp.
Referenced by usage().
