oriented_box_test.cpp File Reference
#include "moab/OrientedBox.hpp"
#include "moab/CartVect.hpp"
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include <cassert>
#include <iostream>
+ Include dependency graph for oriented_box_test.cpp:
Defines
#define ASSERT_VECTOR_ELEMENT(A, B)   assert_vector_element( ( A ), ( B ), #A, #B, __LINE__ )
#define ASSERT_VECTORS_EQUAL(A, B)   assert_vectors_equal( ( A ), ( B ), #A, #B, __LINE__ )
#define ASSERT_DOUBLES_EQUAL(A, B)   assert_doubles_equal( ( A ), ( B ), #A, #B, __LINE__ )
#define ASSERT(B)   assert_bool( ( B ), #B, __LINE__ )
Functions
static void test_basic ()
static void test_contained ()
static void test_ray_intersect ()
static void test_closest_point ()
static void test_build_from_tri ()
static void test_build_from_pts ()
static void test_save ()
static void assert_vector_element (const CartVect &a, const Matrix3 &b, const char *sa, const char *sb, int lineno)
static void assert_vectors_equal (const CartVect &a, const CartVect &b, const char *sa, const char *sb, int lineno)
static void assert_doubles_equal (double a, double b, const char *sa, const char *sb, int lineno)
static void assert_bool (bool b, const char *sb, int lineno)
int main ()
const Matrix3 origaxes (5 *unitaxes.col(0), 10 *unitaxes.col(1), 0.1 *unitaxes.col(2), true)
static CartVect scaled_corner (const OrientedBox &box, int corner, double factor)
static CartVect scaled_face (const OrientedBox &box, int face, double factor)
static void axis_dims (const Matrix3 &axis, CartVect &dims)
Variables
const double TOL = 1e-6
int error_count = 0
const CartVect origin (0.0, 0.0, 0.0)
const Matrix3 unitaxes (0.5, 0.0, 0.0, 0.0, 0.5, 0.0, 0.0, 0.0, 0.5)
const OrientedBox unitbox (unitaxes, origin)
const CartVect unitcenter (10, 20, 30)
const OrientedBox offsetbox (unitaxes, unitcenter)
const OrientedBox oblongbox (origaxes, origin)
const CartVect rotax0 = CartVect( 1.0, 1.0, 0.0 )
const CartVect rotax1 = CartVect( 1.0, -1.0, 1.0 )
const CartVect rotax2 = CartVect( 1.0, 1.0, 0.0 ) * CartVect( 1.0, -1.0, 1.0 )
const CartVect rotax [3] = { rotax0, rotax1, rotax2 }
const OrientedBox rotbox_cv (rotax, origin)
const Matrix3 rotaxes (rotax0, rotax1, rotax2, false)
const OrientedBox rotbox (rotaxes, origin)
Define Documentation
#define ASSERT (   B)    assert_bool( ( B ), #B, __LINE__ )
#define ASSERT_DOUBLES_EQUAL (   A,
Definition at line 24 of file oriented_box_test.cpp.
Referenced by test_basic(), and test_build_from_tri().
#define ASSERT_VECTOR_ELEMENT (   A,
Definition at line 22 of file oriented_box_test.cpp.
Referenced by test_basic().
#define ASSERT_VECTORS_EQUAL (   A,
Definition at line 23 of file oriented_box_test.cpp.
Referenced by test_basic(), and test_closest_point().
Function Documentation
static void assert_bool ( bool  b,
const char *  sb,
int  lineno
) [static]
static void assert_doubles_equal ( double  a,
double  b,
const char *  sa,
const char *  sb,
int  lineno
) [static]
static void assert_vector_element ( const CartVect a,
const Matrix3 b,
const char *  sa,
const char *  sb,
int  lineno
) [static]
Definition at line 1632 of file oriented_box_test.cpp.
References b, error_count, and TOL.
    int i;
    bool ismatch = false;
    for( i = 0; i < 3; ++i )
        if( fabs( a[0] - b( 0, i ) ) <= TOL && fabs( a[1] - b( 1, i ) ) <= TOL && fabs( a[2] - b( 2, i ) ) <= TOL )
            ismatch = true;
            break;
    if( !ismatch )
        ++error_count;
        std::cerr << "Assertion failed at line " << lineno << std::endl
                  << "\t" << sa << " in " << sb << std::endl
                  << "\t" << sa << " = " << a << std::endl
                  << "\t" << sb << " = " << b << std::endl;
    return;
static void assert_vectors_equal ( const CartVect a,
const CartVect b,
const char *  sa,
const char *  sb,
int  lineno
) [static]
static void axis_dims ( const Matrix3 axis,
CartVect dims
) [static]
Definition at line 93 of file oriented_box_test.cpp.
References moab::Matrix3::col(), moab::CartVect::length(), and swap().
    dims = CartVect( axis.col( 0 ).length(), axis.col( 1 ).length(), axis.col( 2 ).length() );
    if( dims[0] > dims[1] ) std::swap( dims[0], dims[1] );
    if( dims[1] > dims[2] ) std::swap( dims[1], dims[2] );
const Matrix3 origaxes ( 5 *unitaxes.  col0,
10 *unitaxes.  col1,
0.1 *unitaxes.  col2,
true
static CartVect scaled_corner ( const OrientedBox box,
int  corner,
double  factor
) [static]
Definition at line 76 of file oriented_box_test.cpp.
References moab::OrientedBox::center, moab::OrientedBox::scaled_axis(), and MBMesquite::signs.
Referenced by test_closest_point(), test_contained(), and test_ray_intersect().
    static const int signs[][3] = { { 1, 1, -1 }, { -1, 1, -1 }, { -1, -1, -1 }, { 1, -1, -1 },
                                    { 1, 1, 1 },  { -1, 1, 1 },  { -1, -1, 1 },  { 1, -1, 1 } };
    return box.center + signs[corner][0] * factor * box.scaled_axis( 0 ) +
           signs[corner][1] * factor * box.scaled_axis( 1 ) + signs[corner][2] * factor * box.scaled_axis( 2 );
static CartVect scaled_face ( const OrientedBox box,
int  face,
double  factor
) [static]
Definition at line 85 of file oriented_box_test.cpp.
References moab::OrientedBox::center, moab::OrientedBox::scaled_axis(), and MBMesquite::sign.
    assert( face >= 0 && face <= 6 );
    int sign = face % 2 ? -1 : 1;
    return box.center + factor * sign * box.scaled_axis( face / 2 );
static void test_basic ( ) [static]
Definition at line 103 of file oriented_box_test.cpp.
References ASSERT_DOUBLES_EQUAL, ASSERT_VECTOR_ELEMENT, ASSERT_VECTORS_EQUAL, axis_dims(), moab::OrientedBox::center, moab::OrientedBox::dimensions(), moab::OrientedBox::inner_radius(), moab::CartVect::length(), oblongbox, offsetbox, origaxes(), origin, moab::OrientedBox::outer_radius(), rotax0, rotax1, rotax2, rotaxes, rotbox, rotbox_cv, moab::OrientedBox::scaled_axis(), unitaxes, unitbox, unitcenter, and moab::OrientedBox::volume().
Referenced by main().
    CartVect dims;
    axis_dims( unitaxes, dims );
    ASSERT_VECTORS_EQUAL( unitbox.center, origin );
    ASSERT_VECTOR_ELEMENT( unitbox.scaled_axis( 0 ), unitaxes );
    ASSERT_VECTOR_ELEMENT( unitbox.scaled_axis( 1 ), unitaxes );
    ASSERT_VECTOR_ELEMENT( unitbox.scaled_axis( 2 ), unitaxes );
    ASSERT_DOUBLES_EQUAL( unitbox.inner_radius(), dims[0] );
    ASSERT_DOUBLES_EQUAL( unitbox.outer_radius(), dims.length() );
    ASSERT_DOUBLES_EQUAL( unitbox.volume(), 8.0 * dims[0] * dims[1] * dims[2] );
    ASSERT_VECTORS_EQUAL( unitbox.dimensions(), 2 * dims );
    ASSERT_VECTORS_EQUAL( offsetbox.center, unitcenter );
    ASSERT_VECTOR_ELEMENT( offsetbox.scaled_axis( 0 ), unitaxes );
    ASSERT_VECTOR_ELEMENT( offsetbox.scaled_axis( 1 ), unitaxes );
    ASSERT_VECTOR_ELEMENT( offsetbox.scaled_axis( 2 ), unitaxes );
    ASSERT_DOUBLES_EQUAL( offsetbox.inner_radius(), dims[0] );
    ASSERT_DOUBLES_EQUAL( offsetbox.outer_radius(), dims.length() );
    ASSERT_DOUBLES_EQUAL( offsetbox.volume(), 8.0 * dims[0] * dims[1] * dims[2] );
    ASSERT_VECTORS_EQUAL( offsetbox.dimensions(), 2 * dims );
    axis_dims( origaxes, dims );
    ASSERT_VECTORS_EQUAL( oblongbox.center, origin );
    ASSERT_VECTOR_ELEMENT( oblongbox.scaled_axis( 0 ), origaxes );
    ASSERT_VECTOR_ELEMENT( oblongbox.scaled_axis( 1 ), origaxes );
    ASSERT_VECTOR_ELEMENT( oblongbox.scaled_axis( 2 ), origaxes );
    ASSERT_DOUBLES_EQUAL( oblongbox.inner_radius(), dims[0] );
    ASSERT_DOUBLES_EQUAL( oblongbox.outer_radius(), dims.length() );
    ASSERT_DOUBLES_EQUAL( oblongbox.volume(), 8.0 * dims[0] * dims[1] * dims[2] );
    ASSERT_VECTORS_EQUAL( oblongbox.dimensions(), 2 * dims );
    // test matrix constructor
    axis_dims( rotaxes, dims );
    ASSERT_VECTORS_EQUAL( rotbox.center, origin );
    ASSERT_VECTOR_ELEMENT( rotbox.scaled_axis( 0 ), rotaxes );
    ASSERT_VECTOR_ELEMENT( rotbox.scaled_axis( 1 ), rotaxes );
    ASSERT_VECTOR_ELEMENT( rotbox.scaled_axis( 2 ), rotaxes );
    ASSERT_DOUBLES_EQUAL( rotbox.inner_radius(), dims[0] );
    ASSERT_DOUBLES_EQUAL( rotbox.outer_radius(), dims.length() );
    ASSERT_DOUBLES_EQUAL( rotbox.volume(), 8.0 * dims[0] * dims[1] * dims[2] );
    ASSERT_VECTORS_EQUAL( rotbox.dimensions(), 2 * dims );
    // test cartvect constructor; ordering of the axes by length happens in the constructor
    ASSERT_VECTORS_EQUAL( rotbox_cv.center, origin );
    ASSERT_VECTORS_EQUAL( rotbox_cv.scaled_axis( 0 ), rotax0 );
    ASSERT_VECTORS_EQUAL( rotbox_cv.scaled_axis( 1 ), rotax1 );
    ASSERT_VECTORS_EQUAL( rotbox_cv.scaled_axis( 2 ), rotax2 );
    ASSERT_DOUBLES_EQUAL( rotbox_cv.inner_radius(), dims[0] );
    ASSERT_DOUBLES_EQUAL( rotbox_cv.outer_radius(), dims.length() );
    ASSERT_DOUBLES_EQUAL( rotbox_cv.volume(), 8.0 * dims[0] * dims[1] * dims[2] );
    ASSERT_VECTORS_EQUAL( rotbox_cv.dimensions(), 2 * dims );
void test_build_from_pts ( ) [static]
Definition at line 1559 of file oriented_box_test.cpp.
References ASSERT, box(), center(), moab::OrientedBox::compute_from_vertices(), moab::OrientedBox::contained(), moab::Interface::create_vertex(), ErrorCode, gMB, moab::Range::insert(), MB_SUCCESS, and vertex_coords().
    ErrorCode rval;
    Core moab;
    Interface* const gMB = &moab;
    const double vertex_coords[] = { 0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, 0, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1 };
    const int num_double         = sizeof( vertex_coords ) / ( sizeof( double ) );
    const int num_vertex         = num_double / 3;
    assert( 0 == num_double % 3 );
    // create some vertices
    Range vertices;
    double min[3] = { HUGE_VAL, HUGE_VAL, HUGE_VAL };
    double max[3] = { -HUGE_VAL, -HUGE_VAL, -HUGE_VAL };
    for( int i = 0; i < num_vertex; ++i )
        EntityHandle h;
        rval = gMB->create_vertex( vertex_coords + 3 * i, h );
        ASSERT( MB_SUCCESS == rval );
        vertices.insert( h );
        for( int j = 0; j < 3; ++j )
            const double c = vertex_coords[3 * i + j];
            if( c < min[j] ) min[j] = c;
            if( c > max[j] ) max[j] = c;
    // create box containing vertices
    OrientedBox box;
    rval = OrientedBox::compute_from_vertices( box, gMB, vertices );
        ASSERT( box.contained( CartVect( vertex_coords[3 * i] ), 1e-6 ) );
    // define a set of points otside of the box to test
    double center[3]   = { 0.5 * ( max[0] + min[0] ), 0.5 * ( max[1] + min[1] ), 0.5 * ( max[2] + min[2] ) };
    double diag[3]     = { max[0] - min[0], max[1] - min[1], max[2] - min[2] };
    double outside1[3] = { center[0] + diag[0], center[1] + diag[1], center[2] + diag[2] };
    double outside2[3] = { center[0] + diag[0], center[1] + diag[1], center[2] };
    double outside3[3] = { center[0] + diag[0], center[1], center[2] };
    double* outside[3] = { outside1, outside2, outside3 };
    // test 'contained' method for all points
    for( int i = 0; i < 3; ++i )
        ASSERT( !box.contained( CartVect( outside[i] ), 1e-6 ) );
void test_build_from_tri ( ) [static]
Test:
Construct OBB Box from triangles
  • Check building OBB box from triangles
Definition at line 1483 of file oriented_box_test.cpp.
References ASSERT, ASSERT_DOUBLES_EQUAL, moab::OrientedBox::axis(), box(), moab::OrientedBox::center, moab::OrientedBox::compute_from_2d_cells(), conn, moab::Core::create_element(), moab::Core::create_vertex(), moab::OrientedBox::dimensions(), ErrorCode, moab::Range::insert(), MB_SUCCESS, MBTRI, moab::OrientedBox::scaled_axis(), and TOL.
    ErrorCode rval;
    Core moab;
    int i;
    // define a planar patch of triangles
    const double coords[] = { 0,  0,  0, 5,   0,  0, 5,  5,  0, 0,  5,  0, -5, 5,   0, -5, 0,  0, -5, -5, 0,
                              0,  -5, 0, 5,   -5, 0, 10, 0,  0, 8,  5,  0, 5,  8,   0, 0,  10, 0, -5, 8,  0,
                              -8, 5,  0, -10, 0,  0, -8, -5, 0, -5, -8, 0, 0,  -10, 0, 5,  -8, 0, 8,  -5, 0 };
    const int conn[]      = { 3, 12, 13, 3, 11, 12, 4, 13, 14, 4, 3,  13, 3, 2, 11, 2, 10, 11,
                         5, 14, 15, 5, 4,  14, 3, 4,  5,  0, 3,  5,  0, 1, 3,  1, 2,  3,  2, 1, 10, 1, 9, 10,
                         5, 15, 16, 6, 5,  16, 5, 6,  7,  0, 5,  7,  1, 0, 7,  1, 7,  8,  1, 8, 20, 9, 1, 20,
                         6, 16, 17, 7, 6,  17, 7, 17, 18, 7, 18, 19, 8, 7, 19, 8, 19, 20 };
    // build triangle mesh
    std::vector< EntityHandle > vertices( 21 );
    for( i = 0; i < 21; ++i )
        rval = moab.create_vertex( coords + 3 * i, vertices[i] );
    Range tris;
    for( i = 0; i < 28; ++i )
        EntityHandle tri;
        EntityHandle c[3] = { vertices[conn[3 * i]], vertices[conn[3 * i + 1]], vertices[conn[3 * i + 2]] };
        rval              = moab.create_element( MBTRI, c, 3, tri );
        tris.insert( tri );
    // create box from triangles
    OrientedBox box;
    rval = OrientedBox::compute_from_2d_cells( box, &moab, tris );
    // compute range along each box axis for input vertices
    const Matrix3 axis( box.scaled_axis( 0 ), box.scaled_axis( 1 ), box.scaled_axis( 2 ), false );
    double min[3], max[3];
    CartVect v = CartVect( coords ) - box.center;
    min[0] = max[0] = box.scaled_axis( 0 ) % v;
    min[1] = max[1] = box.scaled_axis( 1 ) % v;
    min[2] = max[2] = box.scaled_axis( 2 ) % v;
    for( i = 1; i < 21; ++i )
        CartVect vi( coords + 3 * i );
        CartVect vLocal = vi - box.center;
            double d = ( axis.col( j ) % vLocal ) / ( axis.col( j ) % axis.col( j ) );
            if( d < min[j] ) min[j] = d;
            if( d > max[j] ) max[j] = d;
    // Vrify that all points are contained in box
    // and that box fits points tightly.
    // Triangles line in xy plane, so assuming axes are
    // sorted by length, first axis should be zero.
    ASSERT_DOUBLES_EQUAL( min[1], -1 );
    ASSERT_DOUBLES_EQUAL( min[2], -1 );
    ASSERT_DOUBLES_EQUAL( max[1], 1 );
    ASSERT_DOUBLES_EQUAL( max[2], 1 );
    // verify that the box is flat along first axis
    ASSERT( box.dimensions()[0] <= TOL );
    // verify that other two axes are in XY plane
    const CartVect z_axis( 0.0, 0.0, 1.0 );
    ASSERT( fabs( box.axis( 1 ) % z_axis ) <= TOL );
    ASSERT( fabs( box.axis( 2 ) % z_axis ) <= TOL );
static void test_closest_point ( ) [static]
Definition at line 409 of file oriented_box_test.cpp.
References ASSERT_VECTORS_EQUAL, moab::OrientedBox::center, moab::OrientedBox::closest_location_in_box(), oblongbox, offsetbox, rotbox, scaled_corner(), scaled_face(), and unitbox.
    CartVect result;
    // start with unit box
    // test locations inside box
    unitbox.closest_location_in_box( unitbox.center, result );
    ASSERT_VECTORS_EQUAL( result, unitbox.center );
    double f = 0.5;
    unitbox.closest_location_in_box( scaled_corner( unitbox, 0, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 0, f ) );
    unitbox.closest_location_in_box( scaled_corner( unitbox, 1, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 1, f ) );
    unitbox.closest_location_in_box( scaled_corner( unitbox, 2, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 2, f ) );
    unitbox.closest_location_in_box( scaled_corner( unitbox, 3, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 3, f ) );
    unitbox.closest_location_in_box( scaled_corner( unitbox, 4, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 4, f ) );
    unitbox.closest_location_in_box( scaled_corner( unitbox, 5, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 5, f ) );
    unitbox.closest_location_in_box( scaled_corner( unitbox, 6, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 6, f ) );
    unitbox.closest_location_in_box( scaled_corner( unitbox, 7, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 7, f ) );
    // test each corner
    f = 1.0;
    // test outside each corner
    f = 1.5;
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 0, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 1, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 2, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 3, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 4, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 5, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 6, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( unitbox, 7, 1 ) );
    // test on each face
    f = 1.0;
    unitbox.closest_location_in_box( scaled_face( unitbox, 0, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 0, f ) );
    unitbox.closest_location_in_box( scaled_face( unitbox, 1, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 1, f ) );
    unitbox.closest_location_in_box( scaled_face( unitbox, 2, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 2, f ) );
    unitbox.closest_location_in_box( scaled_face( unitbox, 3, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 3, f ) );
    unitbox.closest_location_in_box( scaled_face( unitbox, 4, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 4, f ) );
    unitbox.closest_location_in_box( scaled_face( unitbox, 5, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 5, f ) );
    // test outside each face
    f = 1.5;
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 0, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 1, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 2, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 3, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 4, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( unitbox, 5, 1 ) );
    // next offset box
    offsetbox.closest_location_in_box( offsetbox.center, result );
    ASSERT_VECTORS_EQUAL( result, offsetbox.center );
    f = 0.5;
    offsetbox.closest_location_in_box( scaled_corner( offsetbox, 0, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 0, f ) );
    offsetbox.closest_location_in_box( scaled_corner( offsetbox, 1, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 1, f ) );
    offsetbox.closest_location_in_box( scaled_corner( offsetbox, 2, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 2, f ) );
    offsetbox.closest_location_in_box( scaled_corner( offsetbox, 3, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 3, f ) );
    offsetbox.closest_location_in_box( scaled_corner( offsetbox, 4, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 4, f ) );
    offsetbox.closest_location_in_box( scaled_corner( offsetbox, 5, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 5, f ) );
    offsetbox.closest_location_in_box( scaled_corner( offsetbox, 6, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 6, f ) );
    offsetbox.closest_location_in_box( scaled_corner( offsetbox, 7, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 7, f ) );
    // test each corner
    f = 1.0;
    f = 1.5;
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 0, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 1, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 2, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 3, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 4, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 5, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 6, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( offsetbox, 7, 1 ) );
    f = 1.0;
    offsetbox.closest_location_in_box( scaled_face( offsetbox, 0, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 0, f ) );
    offsetbox.closest_location_in_box( scaled_face( offsetbox, 1, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 1, f ) );
    offsetbox.closest_location_in_box( scaled_face( offsetbox, 2, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 2, f ) );
    offsetbox.closest_location_in_box( scaled_face( offsetbox, 3, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 3, f ) );
    offsetbox.closest_location_in_box( scaled_face( offsetbox, 4, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 4, f ) );
    offsetbox.closest_location_in_box( scaled_face( offsetbox, 5, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 5, f ) );
    f = 1.5;
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 0, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 1, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 2, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 3, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 4, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( offsetbox, 5, 1 ) );
    // next oblong box
    oblongbox.closest_location_in_box( oblongbox.center, result );
    ASSERT_VECTORS_EQUAL( result, oblongbox.center );
    f = 0.5;
    oblongbox.closest_location_in_box( scaled_corner( oblongbox, 0, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 0, f ) );
    oblongbox.closest_location_in_box( scaled_corner( oblongbox, 1, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 1, f ) );
    oblongbox.closest_location_in_box( scaled_corner( oblongbox, 2, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 2, f ) );
    oblongbox.closest_location_in_box( scaled_corner( oblongbox, 3, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 3, f ) );
    oblongbox.closest_location_in_box( scaled_corner( oblongbox, 4, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 4, f ) );
    oblongbox.closest_location_in_box( scaled_corner( oblongbox, 5, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 5, f ) );
    oblongbox.closest_location_in_box( scaled_corner( oblongbox, 6, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 6, f ) );
    oblongbox.closest_location_in_box( scaled_corner( oblongbox, 7, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 7, f ) );
    // test each corner
    f = 1.0;
    f = 1.5;
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 0, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 1, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 2, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 3, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 4, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 5, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 6, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( oblongbox, 7, 1 ) );
    f = 1.0;
    oblongbox.closest_location_in_box( scaled_face( oblongbox, 0, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 0, f ) );
    oblongbox.closest_location_in_box( scaled_face( oblongbox, 1, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 1, f ) );
    oblongbox.closest_location_in_box( scaled_face( oblongbox, 2, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 2, f ) );
    oblongbox.closest_location_in_box( scaled_face( oblongbox, 3, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 3, f ) );
    oblongbox.closest_location_in_box( scaled_face( oblongbox, 4, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 4, f ) );
    oblongbox.closest_location_in_box( scaled_face( oblongbox, 5, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 5, f ) );
    f = 1.5;
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 0, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 1, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 2, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 3, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 4, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( oblongbox, 5, 1 ) );
    // next rotated box
    rotbox.closest_location_in_box( rotbox.center, result );
    ASSERT_VECTORS_EQUAL( result, rotbox.center );
    f = 0.5;
    rotbox.closest_location_in_box( scaled_corner( rotbox, 0, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 0, f ) );
    rotbox.closest_location_in_box( scaled_corner( rotbox, 1, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 1, f ) );
    rotbox.closest_location_in_box( scaled_corner( rotbox, 2, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 2, f ) );
    rotbox.closest_location_in_box( scaled_corner( rotbox, 3, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 3, f ) );
    rotbox.closest_location_in_box( scaled_corner( rotbox, 4, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 4, f ) );
    rotbox.closest_location_in_box( scaled_corner( rotbox, 5, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 5, f ) );
    rotbox.closest_location_in_box( scaled_corner( rotbox, 6, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 6, f ) );
    rotbox.closest_location_in_box( scaled_corner( rotbox, 7, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 7, f ) );
    // test each corner
    f = 1.0;
    f = 1.5;
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 0, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 1, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 2, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 3, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 4, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 5, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 6, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_corner( rotbox, 7, 1 ) );
    f = 1.0;
    rotbox.closest_location_in_box( scaled_face( rotbox, 0, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 0, f ) );
    rotbox.closest_location_in_box( scaled_face( rotbox, 1, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 1, f ) );
    rotbox.closest_location_in_box( scaled_face( rotbox, 2, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 2, f ) );
    rotbox.closest_location_in_box( scaled_face( rotbox, 3, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 3, f ) );
    rotbox.closest_location_in_box( scaled_face( rotbox, 4, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 4, f ) );
    rotbox.closest_location_in_box( scaled_face( rotbox, 5, f ), result );
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 5, f ) );
    f = 1.5;
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 0, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 1, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 2, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 3, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 4, 1 ) );
    ASSERT_VECTORS_EQUAL( result, scaled_face( rotbox, 5, 1 ) );
static void test_contained ( ) [static]
Definition at line 160 of file oriented_box_test.cpp.
References ASSERT, moab::OrientedBox::center, moab::OrientedBox::contained(), oblongbox, offsetbox, rotbox, scaled_corner(), scaled_face(), TOL, and unitbox.
    // first do tests of unit box
    // test points inside box
    ASSERT( unitbox.contained( unitbox.center, TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 0, 0.6 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 1, 0.6 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 2, 0.6 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 3, 0.6 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 4, 0.6 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 5, 0.6 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 6, 0.6 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 7, 0.6 ), TOL ) );
    // test points at box corners
    ASSERT( unitbox.contained( scaled_corner( unitbox, 0, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 1, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 2, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 3, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 4, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 5, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 6, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_corner( unitbox, 7, 1.0 ), TOL ) );
    // test points at center of each face
    ASSERT( unitbox.contained( scaled_face( unitbox, 0, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_face( unitbox, 1, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_face( unitbox, 2, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_face( unitbox, 3, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_face( unitbox, 4, 1.0 ), TOL ) );
    ASSERT( unitbox.contained( scaled_face( unitbox, 5, 1.0 ), TOL ) );
    // test points beyond each corner
    ASSERT( !unitbox.contained( scaled_corner( unitbox, 0, 1.2 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_corner( unitbox, 1, 1.2 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_corner( unitbox, 2, 1.2 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_corner( unitbox, 3, 1.2 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_corner( unitbox, 4, 1.2 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_corner( unitbox, 5, 1.2 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_corner( unitbox, 6, 1.2 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_corner( unitbox, 7, 1.2 ), TOL ) );
    // test points beyond the center of each face
    ASSERT( !unitbox.contained( scaled_face( unitbox, 0, 1.3 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_face( unitbox, 1, 1.3 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_face( unitbox, 2, 1.3 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_face( unitbox, 3, 1.3 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_face( unitbox, 4, 1.3 ), TOL ) );
    ASSERT( !unitbox.contained( scaled_face( unitbox, 5, 1.3 ), TOL ) );
    // now do offset box
    ASSERT( offsetbox.contained( offsetbox.center, TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 0, 0.6 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 1, 0.6 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 2, 0.6 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 3, 0.6 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 4, 0.6 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 5, 0.6 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 6, 0.6 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 7, 0.6 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 0, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 1, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 2, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 3, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 4, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 5, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 6, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_corner( offsetbox, 7, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_face( offsetbox, 0, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_face( offsetbox, 1, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_face( offsetbox, 2, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_face( offsetbox, 3, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_face( offsetbox, 4, 1.0 ), TOL ) );
    ASSERT( offsetbox.contained( scaled_face( offsetbox, 5, 1.0 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 0, 1.2 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 1, 1.2 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 2, 1.2 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 3, 1.2 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 4, 1.2 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 5, 1.2 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 6, 1.2 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_corner( offsetbox, 7, 1.2 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_face( offsetbox, 0, 1.3 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_face( offsetbox, 1, 1.3 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_face( offsetbox, 2, 1.3 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_face( offsetbox, 3, 1.3 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_face( offsetbox, 4, 1.3 ), TOL ) );
    ASSERT( !offsetbox.contained( scaled_face( offsetbox, 5, 1.3 ), TOL ) );
    // now do oblong box
    ASSERT( oblongbox.contained( oblongbox.center, TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 0, 0.6 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 1, 0.6 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 2, 0.6 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 3, 0.6 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 4, 0.6 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 5, 0.6 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 6, 0.6 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 7, 0.6 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 0, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 1, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 2, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 3, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 4, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 5, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 6, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_corner( oblongbox, 7, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_face( oblongbox, 0, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_face( oblongbox, 1, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_face( oblongbox, 2, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_face( oblongbox, 3, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_face( oblongbox, 4, 1.0 ), TOL ) );
    ASSERT( oblongbox.contained( scaled_face( oblongbox, 5, 1.0 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 0, 1.2 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 1, 1.2 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 2, 1.2 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 3, 1.2 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 4, 1.2 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 5, 1.2 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 6, 1.2 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_corner( oblongbox, 7, 1.2 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_face( oblongbox, 0, 1.3 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_face( oblongbox, 1, 1.3 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_face( oblongbox, 2, 1.3 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_face( oblongbox, 3, 1.3 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_face( oblongbox, 4, 1.3 ), TOL ) );
    ASSERT( !oblongbox.contained( scaled_face( oblongbox, 5, 1.3 ), TOL ) );
    // now do rotated box
    ASSERT( rotbox.contained( rotbox.center, TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 0, 0.6 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 1, 0.6 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 2, 0.6 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 3, 0.6 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 4, 0.6 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 5, 0.6 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 6, 0.6 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 7, 0.6 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 0, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 1, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 2, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 3, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 4, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 5, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 6, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_corner( rotbox, 7, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_face( rotbox, 0, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_face( rotbox, 1, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_face( rotbox, 2, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_face( rotbox, 3, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_face( rotbox, 4, 1.0 ), TOL ) );
    ASSERT( rotbox.contained( scaled_face( rotbox, 5, 1.0 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_corner( rotbox, 0, 1.2 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_corner( rotbox, 1, 1.2 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_corner( rotbox, 2, 1.2 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_corner( rotbox, 3, 1.2 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_corner( rotbox, 4, 1.2 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_corner( rotbox, 5, 1.2 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_corner( rotbox, 6, 1.2 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_corner( rotbox, 7, 1.2 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_face( rotbox, 0, 1.3 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_face( rotbox, 1, 1.3 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_face( rotbox, 2, 1.3 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_face( rotbox, 3, 1.3 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_face( rotbox, 4, 1.3 ), TOL ) );
    ASSERT( !rotbox.contained( scaled_face( rotbox, 5, 1.3 ), TOL ) );
void test_ray_intersect ( ) [static]
Definition at line 779 of file oriented_box_test.cpp.
References ASSERT, moab::OrientedBox::center, moab::OrientedBox::intersect_ray(), moab::CartVect::normalize(), oblongbox, offsetbox, rotbox, moab::OrientedBox::scaled_axis(), scaled_corner(), scaled_face(), TOL, and unitbox.
    CartVect dir, pt;
    // test ray from box center towards each face
    dir = scaled_face( unitbox, 0, 1.0 ) - unitbox.center;
    dir.normalize();
    ASSERT( unitbox.intersect_ray( unitbox.center, dir, TOL ) );
    dir = scaled_face( unitbox, 1, 1.0 ) - unitbox.center;
    dir.normalize();
    dir = scaled_face( unitbox, 2, 1.0 ) - unitbox.center;
    dir.normalize();
    dir = scaled_face( unitbox, 3, 1.0 ) - unitbox.center;
    dir.normalize();
    dir = scaled_face( unitbox, 4, 1.0 ) - unitbox.center;
    dir.normalize();
    dir = scaled_face( unitbox, 5, 1.0 ) - unitbox.center;
    dir.normalize();
    // test ray starting outside each face and pointing towards box center
    pt  = scaled_face( unitbox, 0, 3.0 );
    dir = unitbox.center - pt;
    dir.normalize();
    ASSERT( unitbox.intersect_ray( pt, dir, TOL ) );
    pt  = scaled_face( unitbox, 1, 3.0 );
    dir.normalize();
    pt  = scaled_face( unitbox, 2, 3.0 );
    dir.normalize();
    pt  = scaled_face( unitbox, 3, 3.0 );
    dir.normalize();
    pt  = scaled_face( unitbox, 4, 3.0 );
    dir.normalize();
    pt  = scaled_face( unitbox, 5, 3.0 );
    dir.normalize();
    // test ray from outside first face toward box center, with nonnegative ray length
    dir.normalize();
    const double short_pos = 0.99;
    const double short_neg = -0.99;
    const double long_pos  = 1.01;
    const double long_neg  = -1.01;
    ASSERT( unitbox.intersect_ray( pt, dir, TOL, &long_pos ) );
    ASSERT( !unitbox.intersect_ray( pt, dir, TOL, &short_pos ) );
    // test ray from outside first face away from box center, with negative ray length
    ASSERT( unitbox.intersect_ray( pt, -dir, TOL, NULL, &long_neg ) );
    ASSERT( !unitbox.intersect_ray( pt, -dir, TOL, NULL, &short_neg ) );
    // test ray from outside first face toward box center, with both ray lengths
    // Note that box.intersect_ray requires neg_ray_len<0 and -neg_ray_len<=nonneg_ray_len
    ASSERT( unitbox.intersect_ray( pt, dir, TOL, &long_pos, &long_neg ) );
    ASSERT( !unitbox.intersect_ray( pt, dir, TOL, &short_pos, &long_neg ) );
    ASSERT( unitbox.intersect_ray( pt, dir, TOL, &long_pos, &short_neg ) );
    ASSERT( !unitbox.intersect_ray( pt, dir, TOL, &short_pos, &short_neg ) );
    // test ray starting inside box and passing through a corner
    pt  = scaled_corner( unitbox, 0, 0.3 );
    dir = pt - unitbox.center;
    dir.normalize();
    pt  = scaled_corner( unitbox, 1, 0.3 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 2, 0.3 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 3, 0.3 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 4, 0.3 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 5, 0.3 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 6, 0.3 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 7, 0.3 );
    dir.normalize();
    // test ray starting outside box and passing through opposite corners
    pt  = scaled_corner( unitbox, 0, 3.0 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 1, 3.0 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 2, 3.0 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 3, 3.0 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 4, 3.0 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 5, 3.0 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 6, 3.0 );
    dir.normalize();
    pt  = scaled_corner( unitbox, 7, 3.0 );
    dir.normalize();
    // test ray starting outside face and pointing away from box
    dir.normalize();
    ASSERT( !unitbox.intersect_ray( pt, dir, TOL ) );
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
    // test ray starting outside face and parallel to face
    dir = unitbox.scaled_axis( 1 );
    dir.normalize();
    dir = unitbox.scaled_axis( 2 );
    dir.normalize();
    dir = unitbox.scaled_axis( 0 );
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
    // next do offset box
    dir = scaled_face( offsetbox, 0, 1.0 ) - offsetbox.center;
    dir.normalize();
    ASSERT( offsetbox.intersect_ray( offsetbox.center, dir, TOL ) );
    dir = scaled_face( offsetbox, 1, 1.0 ) - offsetbox.center;
    dir.normalize();
    dir = scaled_face( offsetbox, 2, 1.0 ) - offsetbox.center;
    dir.normalize();
    dir = scaled_face( offsetbox, 3, 1.0 ) - offsetbox.center;
    dir.normalize();
    dir = scaled_face( offsetbox, 4, 1.0 ) - offsetbox.center;
    dir.normalize();
    dir = scaled_face( offsetbox, 5, 1.0 ) - offsetbox.center;
    dir.normalize();
    pt  = scaled_face( offsetbox, 0, 3.0 );
    dir = offsetbox.center - pt;
    dir.normalize();
    ASSERT( offsetbox.intersect_ray( pt, dir, TOL ) );
    pt  = scaled_face( offsetbox, 1, 3.0 );
    dir.normalize();
    pt  = scaled_face( offsetbox, 2, 3.0 );
    dir.normalize();
    pt  = scaled_face( offsetbox, 3, 3.0 );
    dir.normalize();
    pt  = scaled_face( offsetbox, 4, 3.0 );
    dir.normalize();
    pt  = scaled_face( offsetbox, 5, 3.0 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 0, 0.3 );
    dir = pt - offsetbox.center;
    dir.normalize();
    pt  = scaled_corner( offsetbox, 1, 0.3 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 2, 0.3 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 3, 0.3 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 4, 0.3 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 5, 0.3 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 6, 0.3 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 7, 0.3 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 0, 3.0 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 1, 3.0 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 2, 3.0 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 3, 3.0 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 4, 3.0 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 5, 3.0 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 6, 3.0 );
    dir.normalize();
    pt  = scaled_corner( offsetbox, 7, 3.0 );
    dir.normalize();
    dir.normalize();
    ASSERT( !offsetbox.intersect_ray( pt, dir, TOL ) );
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir = offsetbox.scaled_axis( 1 );
    dir.normalize();
    dir = offsetbox.scaled_axis( 2 );
    dir.normalize();
    dir = offsetbox.scaled_axis( 0 );
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
    // next do oblong box
    dir = scaled_face( oblongbox, 0, 1.0 ) - oblongbox.center;
    dir.normalize();
    ASSERT( oblongbox.intersect_ray( oblongbox.center, dir, TOL ) );
    dir = scaled_face( oblongbox, 1, 1.0 ) - oblongbox.center;
    dir.normalize();
    dir = scaled_face( oblongbox, 2, 1.0 ) - oblongbox.center;
    dir.normalize();
    dir = scaled_face( oblongbox, 3, 1.0 ) - oblongbox.center;
    dir.normalize();
    dir = scaled_face( oblongbox, 4, 1.0 ) - oblongbox.center;
    dir.normalize();
    dir = scaled_face( oblongbox, 5, 1.0 ) - oblongbox.center;
    dir.normalize();
    pt  = scaled_face( oblongbox, 0, 3.0 );
    dir = oblongbox.center - pt;
    dir.normalize();
    ASSERT( oblongbox.intersect_ray( pt, dir, TOL ) );
    pt  = scaled_face( oblongbox, 1, 3.0 );
    dir.normalize();
    pt  = scaled_face( oblongbox, 2, 3.0 );
    dir.normalize();
    pt  = scaled_face( oblongbox, 3, 3.0 );
    dir.normalize();
    pt  = scaled_face( oblongbox, 4, 3.0 );
    dir.normalize();
    pt  = scaled_face( oblongbox, 5, 3.0 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 0, 0.3 );
    dir = pt - oblongbox.center;
    dir.normalize();
    pt  = scaled_corner( oblongbox, 1, 0.3 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 2, 0.3 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 3, 0.3 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 4, 0.3 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 5, 0.3 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 6, 0.3 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 7, 0.3 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 0, 3.0 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 1, 3.0 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 2, 3.0 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 3, 3.0 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 4, 3.0 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 5, 3.0 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 6, 3.0 );
    dir.normalize();
    pt  = scaled_corner( oblongbox, 7, 3.0 );
    dir.normalize();
    dir.normalize();
    ASSERT( !oblongbox.intersect_ray( pt, dir, TOL ) );
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir = oblongbox.scaled_axis( 1 );
    dir.normalize();
    dir = oblongbox.scaled_axis( 2 );
    dir.normalize();
    dir = oblongbox.scaled_axis( 0 );
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
    // next do rotated box
    dir = scaled_face( rotbox, 0, 1.0 ) - rotbox.center;
    dir.normalize();
    ASSERT( rotbox.intersect_ray( rotbox.center, dir, TOL ) );
    dir = scaled_face( rotbox, 1, 1.0 ) - rotbox.center;
    dir.normalize();
    dir = scaled_face( rotbox, 2, 1.0 ) - rotbox.center;
    dir.normalize();
    dir = scaled_face( rotbox, 3, 1.0 ) - rotbox.center;
    dir.normalize();
    dir = scaled_face( rotbox, 4, 1.0 ) - rotbox.center;
    dir.normalize();
    dir = scaled_face( rotbox, 5, 1.0 ) - rotbox.center;
    dir.normalize();
    pt  = scaled_face( rotbox, 0, 3.0 );
    dir = rotbox.center - pt;
    dir.normalize();
    ASSERT( rotbox.intersect_ray( pt, dir, TOL ) );
    pt  = scaled_face( rotbox, 1, 3.0 );
    dir.normalize();
    pt  = scaled_face( rotbox, 2, 3.0 );
    dir.normalize();
    pt  = scaled_face( rotbox, 3, 3.0 );
    dir.normalize();
    pt  = scaled_face( rotbox, 4, 3.0 );
    dir.normalize();
    pt  = scaled_face( rotbox, 5, 3.0 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 0, 0.3 );
    dir = pt - rotbox.center;
    dir.normalize();
    pt  = scaled_corner( rotbox, 1, 0.3 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 2, 0.3 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 3, 0.3 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 4, 0.3 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 5, 0.3 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 6, 0.3 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 7, 0.3 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 0, 3.0 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 1, 3.0 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 2, 3.0 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 3, 3.0 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 4, 3.0 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 5, 3.0 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 6, 3.0 );
    dir.normalize();
    pt  = scaled_corner( rotbox, 7, 3.0 );
    dir.normalize();
    dir.normalize();
    ASSERT( !rotbox.intersect_ray( pt, dir, TOL ) );
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir = rotbox.scaled_axis( 1 );
    dir.normalize();
    dir = rotbox.scaled_axis( 2 );
    dir.normalize();
    dir = rotbox.scaled_axis( 0 );
    dir.normalize();
    dir.normalize();
    dir.normalize();
    dir.normalize();
static void test_save ( ) [static]
Definition at line 1612 of file oriented_box_test.cpp.
References ASSERT, box(), ErrorCode, MB_SUCCESS, size, moab::Core::tag_get_bytes(), and moab::OrientedBox::tag_handle().
    ErrorCode rval;
    Core moab;
    OrientedBox box;
    // create a tag to store the data in
    Tag tag;
    rval = OrientedBox::tag_handle( tag, &moab, "FOO" );
    // check tag size
    int size;
    rval = moab.tag_get_bytes( tag, size );
    ASSERT( size == sizeof( OrientedBox ) );
Variable Documentation
int error_count = 0
Definition at line 11 of file oriented_box_test.cpp.
const CartVect origin(0.0, 0.0, 0.0)
Referenced by dagmc_origin_face_rayfire(), dagmc_outside_face_rayfire(), dagmc_outside_face_rayfire_history(), dagmc_outside_face_rayfire_history_fail(), dagmc_outside_face_rayfire_orient_entrance(), dagmc_outside_face_rayfire_orient_exit(), dagmc_point_in_vol_1(), dagmc_point_in_vol_2(), dagmc_point_in_vol_3(), dagmc_point_in_vol_4(), dagmc_point_in_vol_5(), dagmc_point_in_vol_6(), dagmc_point_on_corner_1(), dagmc_point_on_corner_2(), dagmc_point_on_corner_3(), dagmc_point_on_corner_4(), dagmc_point_on_corner_5(), dagmc_point_on_corner_6(), dagmc_point_on_corner_7(), dagmc_point_on_corner_8(), do_ray_fire_test(), gqt_origin_face_rayfire(), gqt_outside_face_rayfire(), gqt_outside_face_rayfire_history(), gqt_outside_face_rayfire_history_fail(), gqt_outside_face_rayfire_orient_entrance(), gqt_outside_face_rayfire_orient_exit(), gqt_point_in_box_1(), gqt_point_in_box_2(), gqt_point_in_box_3(), gqt_point_in_box_4(), gqt_point_in_box_5(), gqt_point_in_vol_1(), gqt_point_in_vol_2(), gqt_point_in_vol_3(), gqt_point_in_vol_4(), gqt_point_in_vol_5(), gqt_point_in_vol_6(), gqt_point_on_corner_1(), gqt_point_on_corner_2(), gqt_point_on_corner_3(), gqt_point_on_corner_4(), gqt_point_on_corner_5(), gqt_point_on_corner_6(), gqt_point_on_corner_7(), gqt_point_on_corner_8(), moab::GeomUtil::plucker_ray_tri_intersect(), moab::ReadMCNP5::read_mesh_planes(), smooth_mesh(), MBMesquite::CircleDomainTest::test_arc_length(), test_basic(), MBMesquite::CircleDomainTest::test_position_from_length(), test_ray_fire(), MBMesquite::CircleDomainTest::test_snap_to(), moab::ReadVtk::vtk_read_structured_points(), and MBMesquite::MeshImpl::vtk_read_structured_points().
const CartVect rotax[3] = { rotax0, rotax1, rotax2 }
Definition at line 64 of file oriented_box_test.cpp.
Definition at line 61 of file oriented_box_test.cpp.
Definition at line 62 of file oriented_box_test.cpp.
Definition at line 63 of file oriented_box_test.cpp.
const Matrix3 rotaxes(rotax0, rotax1, rotax2, false)
Definition at line 10 of file oriented_box_test.cpp.
const Matrix3 unitaxes(0.5, 0.0, 0.0, 0.0, 0.5, 0.0, 0.0, 0.0, 0.5)
const CartVect unitcenter(10, 20, 30)
