MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Range.hpp"
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/ParallelComm.hpp"
#include "moab/Skinner.hpp"
#include "MBTagConventions.hpp"
#include "moab/CN.hpp"
#include "MBParallelConventions.h"
#include <iostream>
#include <sstream>
#include <algorithm>
#include "moab_mpi.h"
#include <unistd.h>
#include <cfloat>
#include <cstdio>
#include <ctime>
Enumerations | |
enum | Mode { READ_PART, READ_DELETE, BCAST_DELETE } |
Functions | |
void | load_and_partition (Interface &moab, const char *filename, bool print_debug=false) |
void | save_and_load_on_root (Interface &moab, const char *tmp_filename) |
void | check_identical_mesh (Interface &moab1, Interface &moab2) |
void | test_write_elements () |
void | test_write_shared_sets () |
void | test_var_length_parallel () |
void | test_read_elements_common (bool by_rank, int intervals, bool print_time, const char *extra_opts=0) |
void | test_read_elements () |
void | test_read_elements_by_rank () |
void | test_bcast_summary () |
void | test_read_summary () |
void | test_read_time () |
void | test_read_tags () |
void | test_read_global_tags () |
void | test_read_sets_common (const char *extra_opts=0) |
void | test_read_sets () |
void | test_read_sets_bcast_dups () |
void | test_read_sets_read_dups () |
void | test_read_bc_sets () |
void | test_write_different_element_types () |
void | test_write_different_tags () |
void | test_write_polygons () |
void | test_write_unbalanced () |
void | test_write_dense_tags () |
void | test_read_non_adjs_side () |
std::string | get_read_options (bool by_rank=DEFAULT_BY_RANK, Mode mode=DEFAULT_MODE, const char *extra_opts=0) |
std::string | get_read_options (const char *extra_opts) |
std::string | get_read_options (bool by_rank, const char *extra_opts) |
int | main (int argc, char *argv[]) |
void | print_partitioned_entities (Interface &moab, bool list_non_shared=false) |
void | count_owned_entities (Interface &moab, int counts[MBENTITYSET]) |
bool | check_sets_sizes (Interface &mb1, EntityHandle set1, Interface &mb2, EntityHandle set2) |
void | create_input_file (const char *file_name, int intervals, int num_cpu, int blocks_per_cpu=1, const char *ijk_vert_tag_name=0, const char *ij_set_tag_name=0, const char *global_tag_name=0, const int *global_mesh_value=0, const int *global_default_value=0, bool create_bcsets=false) |
Tag | get_tag (Interface &mb, int rank, bool create) |
Variables | |
int | ReadIntervals = 0 |
const char | PARTITION_TAG [] = "PARTITION" |
bool | KeepTmpFiles = false |
bool | PauseOnStart = false |
bool | HyperslabAppend = false |
const int | DefaultReadIntervals = 2 |
int | ReadDebugLevel = 0 |
int | WriteDebugLevel = 0 |
int | ReadBlocks = 1 |
const Mode | DEFAULT_MODE = READ_PART |
const bool | DEFAULT_BY_RANK = false |
enum Mode |
Definition at line 95 of file parallel_hdf5_test.cpp.
{ READ_PART, READ_DELETE, BCAST_DELETE };
void check_identical_mesh | ( | Interface & | moab1, |
Interface & | moab2 | ||
Definition at line 490 of file parallel_hdf5_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), MBEDGE, MBENTITYSET, MBVERTEX, moab::Range::size(), and t.
Referenced by test_write_elements().
{ ErrorCode rval; std::map< EntityHandle, EntityHandle > entmap; // match vertices by coordinate Range r1, r2; Range::iterator i1, i2; rval = mb1.get_entities_by_type( 0, MBVERTEX, r1 );CHECK_ERR( rval ); rval = mb2.get_entities_by_type( 0, MBVERTEX, r2 );CHECK_ERR( rval ); CHECK_EQUAL( r1.size(), r2.size() ); for( i1 = r1.begin(); i1 != r1.end(); ++i1 ) { double coords1[3]; rval = mb1.get_coords( &*i1, 1, coords1 );CHECK_ERR( rval ); for( i2 = r2.begin(); i2 != r2.end(); ++i2 ) { double coords2[3]; rval = mb2.get_coords( &*i2, 1, coords2 );CHECK_ERR( rval ); coords2[0] -= coords1[0]; coords2[1] -= coords1[1]; coords2[2] -= coords1[2]; double lensqr = coords2[0] * coords2[0] + coords2[1] * coords2[1] + coords2[2] * coords2[2]; if( lensqr < 1e-12 ) break; } CHECK( i2 != r2.end() ); entmap[*i2] = *i1; r2.erase( i2 ); } // match element connectivity std::vector< EntityHandle > conn1, conn2; for( EntityType t = MBEDGE; t < MBENTITYSET; ++t ) { r1.clear(); rval = mb1.get_entities_by_type( 0, t, r1 );CHECK_ERR( rval ); r2.clear(); rval = mb2.get_entities_by_type( 0, t, r2 );CHECK_ERR( rval ); CHECK_EQUAL( r1.size(), r2.size() ); for( i1 = r1.begin(); i1 != r1.end(); ++i1 ) { conn1.clear(); rval = mb1.get_connectivity( &*i1, 1, conn1 );CHECK_ERR( rval ); for( i2 = r2.begin(); i2 != r2.end(); ++i2 ) { conn2.clear(); rval = mb2.get_connectivity( &*i2, 1, conn2 );CHECK_ERR( rval ); if( conn1.size() != conn2.size() ) continue; for( std::vector< EntityHandle >::iterator j = conn2.begin(); j != conn2.end(); ++j ) *j = entmap[*j]; if( conn1 == conn2 ) break; } CHECK( i2 != r2.end() ); entmap[*i2] = *i1; r2.erase( i2 ); } } }
bool check_sets_sizes | ( | Interface & | mb1, |
EntityHandle | set1, | ||
Interface & | mb2, | ||
EntityHandle | set2 | ||
Definition at line 608 of file parallel_hdf5_test.cpp.
References CHECK_ERR, moab::CN::EntityTypeName(), ErrorCode, moab::Interface::get_number_entities_by_type(), MBMAXTYPE, MBVERTEX, and t.
Referenced by test_write_shared_sets().
{ ErrorCode rval; bool result = true; for( EntityType t = MBVERTEX; t < MBMAXTYPE; ++t ) { int count1, count2; rval = mb1.get_number_entities_by_type( set1, t, count1 );CHECK_ERR( rval ); rval = mb2.get_number_entities_by_type( set2, t, count2 );CHECK_ERR( rval ); if( count1 != count2 ) { std::cerr << "Sets differ in number of " << CN::EntityTypeName( t ) << " : " << count1 << " vs. " << count2 << std::endl; result = false; } } return result; }
void count_owned_entities | ( | Interface & | moab, |
int | counts[MBENTITYSET] | ||
Definition at line 474 of file parallel_hdf5_test.cpp.
References CHECK, CHECK_ERR, moab::Range::empty(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Interface::get_entities_by_type(), moab::ParallelComm::get_pcomm(), MBENTITYSET, MBVERTEX, PSTATUS_NOT, PSTATUS_NOT_OWNED, moab::Range::size(), t, and u.
{ ErrorCode rval; ParallelComm* pcomm = ParallelComm::get_pcomm( &moab, 0 ); CHECK( 0 != pcomm ); std::fill( counts, counts + MBENTITYSET, 0u ); for( EntityType t = MBVERTEX; t < MBENTITYSET; ++t ) { Range range; rval = moab.get_entities_by_type( 0, t, range );CHECK_ERR( rval ); if( !range.empty() ) rval = pcomm->filter_pstatus( range, PSTATUS_NOT_OWNED, PSTATUS_NOT );CHECK_ERR( rval ); counts[t] = range.size(); } }
void create_input_file | ( | const char * | file_name, |
int | intervals, | ||
int | num_cpu, | ||
int | blocks_per_cpu = 1 , |
const char * | ijk_vert_tag_name = 0 , |
const char * | ij_set_tag_name = 0 , |
const char * | global_tag_name = 0 , |
const int * | global_mesh_value = 0 , |
const int * | global_default_value = 0 , |
bool | create_bcsets = false |
Definition at line 788 of file parallel_hdf5_test.cpp.
References moab::Interface::add_entities(), CHECK_ERR, conn, moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), DIRICHLET_SET_TAG_NAME, moab::dum, ErrorCode, moab::Skinner::find_skin(), moab::Interface::get_adjacencies(), MATERIAL_SET_TAG_NAME, mb, MB_TAG_CREAT, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBHEX, MESHSET_SET, NEUMANN_SET_TAG_NAME, PARTITION_TAG, moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), moab::Interface::UNION, and moab::Interface::write_file().
Referenced by test_read_bc_sets(), test_read_elements_common(), test_read_global_tags(), test_read_sets_common(), test_read_tags(), and test_read_time().
{ Core moab; Interface& mb = moab; ErrorCode rval; Tag ijk_vert_tag = 0, ij_set_tag = 0, global_tag = 0; if( ijk_vert_tag_name ) { rval = mb.tag_get_handle( ijk_vert_tag_name, 3, MB_TYPE_INTEGER, ijk_vert_tag, MB_TAG_EXCL | MB_TAG_DENSE );CHECK_ERR( rval ); } if( ij_set_tag_name ) { rval = mb.tag_get_handle( ij_set_tag_name, 2, MB_TYPE_INTEGER, ij_set_tag, MB_TAG_SPARSE | MB_TAG_EXCL );CHECK_ERR( rval ); } if( global_tag_name ) { rval = mb.tag_get_handle( global_tag_name, 1, MB_TYPE_INTEGER, global_tag, MB_TAG_DENSE | MB_TAG_EXCL, global_default_value );CHECK_ERR( rval ); if( global_mesh_value ) { EntityHandle root = 0; rval = mb.tag_set_data( global_tag, &root, 1, global_mesh_value );CHECK_ERR( rval ); } } const int num_blk = num_cpu * blocks_per_cpu; int iv = intervals + 1, ii = num_blk * intervals + 1; std::vector< EntityHandle > verts( iv * iv * ii ); int idx = 0; for( int i = 0; i < ii; ++i ) { for( int j = 0; j < iv; ++j ) { int start = idx; for( int k = 0; k < iv; ++k ) { const double coords[3] = { static_cast< double >( i ), static_cast< double >( j ), static_cast< double >( k ) }; rval = mb.create_vertex( coords, verts[idx] );CHECK_ERR( rval ); if( ijk_vert_tag ) { int vals[] = { i, j, k }; rval = mb.tag_set_data( ijk_vert_tag, &verts[idx], 1, vals );CHECK_ERR( rval ); } ++idx; } if( ij_set_tag ) { EntityHandle set; rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); rval = mb.add_entities( set, &verts[start], idx - start );CHECK_ERR( rval ); int vals[] = { i, j }; rval = mb.tag_set_data( ij_set_tag, &set, 1, vals );CHECK_ERR( rval ); } } } const int eb = intervals * intervals * intervals; std::vector< EntityHandle > elems( num_blk * eb ); idx = 0; for( int c = 0; c < num_blk; ++c ) { for( int i = c * intervals; i < ( c + 1 ) * intervals; ++i ) { for( int j = 0; j < intervals; ++j ) { for( int k = 0; k < intervals; ++k ) { EntityHandle conn[8] = { verts[iv * ( iv * i + j ) + k], verts[iv * ( iv * ( i + 1 ) + j ) + k], verts[iv * ( iv * ( i + 1 ) + j + 1 ) + k], verts[iv * ( iv * i + j + 1 ) + k], verts[iv * ( iv * i + j ) + k + 1], verts[iv * ( iv * ( i + 1 ) + j ) + k + 1], verts[iv * ( iv * ( i + 1 ) + j + 1 ) + k + 1], verts[iv * ( iv * i + j + 1 ) + k + 1] }; rval = mb.create_element( MBHEX, conn, 8, elems[idx++] );CHECK_ERR( rval ); } } } } Tag part_tag; rval = mb.tag_get_handle( PARTITION_TAG, 1, MB_TYPE_INTEGER, part_tag, MB_TAG_SPARSE | MB_TAG_EXCL );CHECK_ERR( rval ); std::vector< EntityHandle > parts( num_cpu ); for( int i = 0; i < num_cpu; ++i ) { rval = mb.create_meshset( MESHSET_SET, parts[i] );CHECK_ERR( rval ); for( int j = 0; j < blocks_per_cpu; ++j ) { rval = mb.add_entities( parts[i], &elems[( num_cpu * j + i ) * eb], eb );CHECK_ERR( rval ); } rval = mb.tag_set_data( part_tag, &parts[i], 1, &i );CHECK_ERR( rval ); } if( create_bcsets ) { // neumann set Range skin_ents; rval = Skinner( &mb ).find_skin( 0, &elems[0], elems.size(), false, skin_ents );CHECK_ERR( rval ); EntityHandle bcset; rval = mb.create_meshset( MESHSET_SET, bcset );CHECK_ERR( rval ); Tag bcset_tag; rval = mb.tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, bcset_tag, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( rval ); int dum = 100; rval = mb.tag_set_data( bcset_tag, &bcset, 1, &dum );CHECK_ERR( rval ); rval = mb.add_entities( bcset, skin_ents );CHECK_ERR( rval ); // dirichlet set rval = mb.create_meshset( MESHSET_SET, bcset );CHECK_ERR( rval ); rval = mb.tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, bcset_tag, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( rval ); dum = 200; rval = mb.tag_set_data( bcset_tag, &bcset, 1, &dum );CHECK_ERR( rval ); Range nodes; rval = mb.get_adjacencies( skin_ents, 0, false, nodes, Interface::UNION );CHECK_ERR( rval ); rval = mb.add_entities( bcset, nodes );CHECK_ERR( rval ); // material set rval = mb.create_meshset( MESHSET_SET, bcset );CHECK_ERR( rval ); rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, bcset_tag, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( rval ); dum = 300; rval = mb.tag_set_data( bcset_tag, &bcset, 1, &dum );CHECK_ERR( rval ); rval = mb.add_entities( bcset, &elems[0], elems.size() );CHECK_ERR( rval ); } rval = mb.write_file( file_name, "MOAB" );CHECK_ERR( rval ); }
std::string get_read_options | ( | bool | by_rank = DEFAULT_BY_RANK , |
Mode | mode = DEFAULT_MODE , |
const char * | extra_opts = 0 |
Definition at line 114 of file parallel_hdf5_test.cpp.
References BCAST_DELETE, HyperslabAppend, MPI_COMM_WORLD, PARTITION_TAG, READ_DELETE, READ_PART, and ReadDebugLevel.
Referenced by get_read_options(), test_read_bc_sets(), test_read_elements_common(), test_read_global_tags(), test_read_sets_common(), test_read_tags(), and test_read_time().
{ int numproc; MPI_Comm_size( MPI_COMM_WORLD, &numproc ); // do parallel read unless only one processor std::ostringstream str; if( numproc > 1 ) { str << "PARALLEL="; switch( mode ) { case READ_PART: str << "READ_PART"; break; case READ_DELETE: str << "READ_DELETE"; break; case BCAST_DELETE: str << "BCAST_DELETE"; break; } str << ";PARTITION=" << PARTITION_TAG << ";"; if( by_rank ) str << "PARTITION_BY_RANK;"; } if( extra_opts ) str << extra_opts << ";"; if( ReadDebugLevel ) str << "DEBUG_IO=" << ReadDebugLevel << ";"; if( HyperslabAppend ) str << "HYPERSLAB_APPEND;HYPERSLAB_SELECT_LIMIT=2147483647"; return str.str(); }
std::string get_read_options | ( | const char * | extra_opts | ) |
Definition at line 105 of file parallel_hdf5_test.cpp.
References DEFAULT_BY_RANK, DEFAULT_MODE, and get_read_options().
{ return get_read_options( DEFAULT_BY_RANK, DEFAULT_MODE, extra_opts ); }
std::string get_read_options | ( | bool | by_rank, |
const char * | extra_opts | ||
Definition at line 109 of file parallel_hdf5_test.cpp.
References DEFAULT_MODE, and get_read_options().
{ return get_read_options( by_rank, DEFAULT_MODE, extra_opts ); }
Definition at line 1305 of file parallel_hdf5_test.cpp.
References CHECK_ERR, ErrorCode, MB_TAG_BIT, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_SPARSE, MB_TAG_VARLEN, MB_TYPE_BIT, MB_TYPE_DOUBLE, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, rank, moab::Interface::tag_get_handle(), and TagType.
Referenced by test_write_different_tags().
{ DataType type = (DataType)( rank % ( MB_MAX_DATA_TYPE + 1 ) ); TagType storage = ( type == MB_TYPE_BIT ) ? MB_TAG_BIT : ( rank % 2 ) ? MB_TAG_DENSE : MB_TAG_SPARSE; int len = rank % 3 + 1; TagType cbit = create ? MB_TAG_EXCL : (TagType)0; TagType vbit = rank % 4 == 1 && storage != MB_TAG_BIT ? MB_TAG_VARLEN : (TagType)0; std::ostringstream name; name << "TestTag" << rank; const void* defval = 0; const int defint[] = { static_cast< int >( rank ), static_cast< int >( rank / 2 ), static_cast< int >( rank + 1 ), static_cast< int >( rank - 1 ) }; const double defreal[] = { 0.1 * rank, 1.0 / rank, static_cast< double >( -rank ), static_cast< double >( rank ) }; const int defhandle[] = { 0, 0, 0, 0 }; const unsigned char defbit = 0x1; const char defopq[] = "Jason"; if( rank % 4 < 2 ) { switch( type ) { case MB_TYPE_BIT: defval = &defbit; break; case MB_TYPE_INTEGER: defval = defint; break; case MB_TYPE_DOUBLE: defval = defreal; break; case MB_TYPE_HANDLE: defval = defhandle; break; case MB_TYPE_OPAQUE: defval = defopq; break; } } Tag result; ErrorCode rval = mb.tag_get_handle( name.str().c_str(), len, type, result, storage | cbit | vbit, defval );CHECK_ERR( rval ); return result; }
void load_and_partition | ( | Interface & | moab, |
const char * | filename, | ||
bool | print_debug = false |
Definition at line 412 of file parallel_hdf5_test.cpp.
References CHECK_ERR, ErrorCode, moab::Interface::load_file(), and print_partitioned_entities().
Referenced by test_write_elements(), and test_write_shared_sets().
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 149 of file parallel_hdf5_test.cpp.
References CHECK, DefaultReadIntervals, HyperslabAppend, KeepTmpFiles, MPI_COMM_WORLD, PauseOnStart, rank, ReadBlocks, ReadDebugLevel, ReadIntervals, RUN_TEST, test_read_bc_sets(), test_read_elements(), test_read_elements_by_rank(), test_read_global_tags(), test_read_non_adjs_side(), test_read_sets(), test_read_sets_bcast_dups(), test_read_sets_read_dups(), test_read_tags(), test_read_time(), test_var_length_parallel(), test_write_dense_tags(), test_write_different_element_types(), test_write_different_tags(), test_write_elements(), test_write_polygons(), test_write_shared_sets(), test_write_unbalanced(), and WriteDebugLevel.
{ int err = MPI_Init( &argc, &argv ); CHECK( !err ); for( int i = 1; i < argc; ++i ) { if( !strcmp( argv[i], "-k" ) ) KeepTmpFiles = true; else if( !strcmp( argv[i], "-p" ) ) PauseOnStart = true; else if( !strcmp( argv[i], "-R" ) ) { ++i; CHECK( i < argc ); ReadIntervals = atoi( argv[i] ); CHECK( ReadIntervals > 0 ); } else if( !strcmp( argv[i], "-b" ) ) { ++i; CHECK( i < argc ); ReadBlocks = atoi( argv[i] ); CHECK( ReadBlocks > 0 ); } else if( !strcmp( argv[i], "-r" ) ) { ++i; CHECK( i < argc ); ReadDebugLevel = atoi( argv[i] ); CHECK( ReadDebugLevel > 0 ); } else if( !strcmp( argv[i], "-w" ) ) { ++i; CHECK( i < argc ); WriteDebugLevel = atoi( argv[i] ); CHECK( WriteDebugLevel > 0 ); } else if( !strcmp( argv[i], "-A" ) ) HyperslabAppend = true; else { std::cerr << "Usage: " << argv[0] << " [-k] [-p] [-R <intervals>] [-r <level>] [-w <level>] [-b <blocks>] [-A]" << std::endl; return 1; } } if( PauseOnStart ) { int rank; MPI_Comm_rank( MPI_COMM_WORLD, &rank ); printf( "Rank %2d PID %lu\n", rank, (unsigned long)getpid() ); sleep( 30 ); } int result = 0; if( ReadIntervals ) { result = RUN_TEST( test_read_time ); } else { ReadIntervals = DefaultReadIntervals; result += RUN_TEST( test_write_elements ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_write_shared_sets ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_var_length_parallel ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_read_elements ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_read_elements_by_rank ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_read_tags ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_read_global_tags ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_read_sets ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_read_sets_bcast_dups ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_read_sets_read_dups ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_read_bc_sets ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_write_different_element_types ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_write_different_tags ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_write_polygons ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_write_unbalanced ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_write_dense_tags ); MPI_Barrier( MPI_COMM_WORLD ); result += RUN_TEST( test_read_non_adjs_side ); MPI_Barrier( MPI_COMM_WORLD ); } MPI_Finalize(); return result; }
void print_partitioned_entities | ( | Interface & | moab, |
bool | list_non_shared = false |
Definition at line 261 of file parallel_hdf5_test.cpp.
References moab::Range::begin(), buffer, CHECK_ERR, children, moab::Range::clear(), dim, moab::Range::empty(), moab::Range::end(), entities, ErrorCode, geom, GEOM_DIMENSION_TAG_NAME, geom_tag, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::globalId_tag(), id_tag, MAX_SHARING_PROCS, MB_TAG_NOT_FOUND, MB_TYPE_HANDLE, MB_TYPE_INTEGER, MB_TYPE_OPAQUE, MBENTITYSET, MPI_COMM_WORLD, PARALLEL_SHARED_HANDLE_TAG_NAME, PARALLEL_SHARED_HANDLES_TAG_NAME, PARALLEL_SHARED_PROC_TAG_NAME, PARALLEL_SHARED_PROCS_TAG_NAME, PARALLEL_STATUS_TAG_NAME, PSTATUS_NOT_OWNED, PSTATUS_SHARED, rank, size, moab::Range::size(), moab::subtract(), moab::Range::swap(), t, moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by load_and_partition().
{ ErrorCode rval; int size, rank; std::vector< int > ent_procs( MAX_SHARING_PROCS ), tmp_ent_procs( MAX_SHARING_PROCS ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); MPI_Comm_size( MPI_COMM_WORLD, &size ); // expect shared entities to correspond to geometric sets // get tags for parallel data Tag sharedp_tag, sharedps_tag, sharedh_tag, sharedhs_tag, pstatus_tag; rval = moab.tag_get_handle( PARALLEL_SHARED_PROC_TAG_NAME, 1, MB_TYPE_INTEGER, sharedp_tag );CHECK_ERR( rval ); rval = moab.tag_get_handle( PARALLEL_SHARED_PROCS_TAG_NAME, MAX_SHARING_PROCS, MB_TYPE_INTEGER, sharedps_tag );CHECK_ERR( rval ); rval = moab.tag_get_handle( PARALLEL_SHARED_HANDLE_TAG_NAME, 1, MB_TYPE_HANDLE, sharedh_tag );CHECK_ERR( rval ); rval = moab.tag_get_handle( PARALLEL_SHARED_HANDLES_TAG_NAME, MAX_SHARING_PROCS, MB_TYPE_HANDLE, sharedhs_tag );CHECK_ERR( rval ); rval = moab.tag_get_handle( PARALLEL_STATUS_TAG_NAME, 1, MB_TYPE_OPAQUE, pstatus_tag );CHECK_ERR( rval ); // for each geometric entity, check which processor we are sharing // entities with Tag geom_tag, id_tag; rval = moab.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag );CHECK_ERR( rval ); id_tag = moab.globalId_tag(); const char* topo_names_s[] = { "Vertex", "Curve", "Surface", "Volume" }; // const char* topo_names_p[] = { "Vertices", "Curves", "Surfaces", "Volumes" }; std::ostringstream buffer; // buffer output in an attempt to prevent lines from different // processsors being mixed up. for( int t = 0; t < 4; ++t ) { Range geom; int dim = t; const void* ptr = &dim; rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, &ptr, 1, geom );CHECK_ERR( rval ); // for each geometric entity of dimension 't' for( Range::const_iterator i = geom.begin(); i != geom.end(); ++i ) { EntityHandle set = *i; int id; rval = moab.tag_get_data( id_tag, &set, 1, &id );CHECK_ERR( rval ); buffer.clear(); // get entities contained in this set but not its children Range entities, tmp_entities, children, diff; rval = moab.get_entities_by_handle( set, entities );CHECK_ERR( rval ); rval = moab.get_child_meshsets( set, children );CHECK_ERR( rval ); for( Range::const_iterator j = children.begin(); j != children.end(); ++j ) { tmp_entities.clear(); rval = moab.get_entities_by_handle( *j, tmp_entities );CHECK_ERR( rval ); diff = subtract( entities, tmp_entities ); entities.swap( diff ); } // for each entity, check owning processors std::vector< char > status_flags( entities.size(), 0 ); std::vector< int > shared_procs( entities.size(), 0 ); rval = moab.tag_get_data( pstatus_tag, entities, &status_flags[0] ); if( MB_TAG_NOT_FOUND == rval ) { // keep default values of zero (not shared) } CHECK_ERR( rval ); unsigned num_shared = 0, num_owned = 0; for( size_t j = 0; j < status_flags.size(); ++j ) { num_shared += !!( status_flags[j] & PSTATUS_SHARED ); num_owned += !( status_flags[j] & PSTATUS_NOT_OWNED ); } if( !num_shared ) { if( list_non_shared ) buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" << "not shared" << std::endl; } else if( num_shared != entities.size() ) { buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" << "ERROR: " << num_shared << " of " << entities.size() << " entities marked as 'shared'" << std::endl; } else if( num_owned && num_owned != entities.size() ) { buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" << "ERROR: " << num_owned << " of " << entities.size() << " entities owned by this processor" << std::endl; } else { rval = moab.tag_get_data( sharedp_tag, entities, &shared_procs[0] );CHECK_ERR( rval ); int proc = shared_procs[0]; bool all_match = true; for( size_t j = 1; j < shared_procs.size(); ++j ) if( shared_procs[j] != proc ) all_match = false; if( !all_match ) { buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" << "ERROR: processsor IDs do not match!" << std::endl; } else if( proc != -1 ) { buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" << "shared with processor " << proc; if( num_owned ) buffer << " (owned by this processor)"; buffer << std::endl; } else if( entities.empty() ) { buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" << "ERROR: no entities!" << std::endl; } else { Range::const_iterator j = entities.begin(); rval = moab.tag_get_data( sharedps_tag, &*j, 1, &ent_procs[0] );CHECK_ERR( rval ); for( ++j; j != entities.end(); ++j ) { rval = moab.tag_get_data( sharedps_tag, &*j, 1, &tmp_ent_procs[0] );CHECK_ERR( rval ); if( ent_procs != tmp_ent_procs ) all_match = false; } if( !all_match ) { buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" << "ERROR: processsor IDs do not match!" << std::endl; } else { buffer << rank << ":\t" << topo_names_s[t] << " " << id << ":\t" << "processors "; for( int k = 0; k < MAX_SHARING_PROCS; ++k ) if( ent_procs[k] != -1 ) buffer << ent_procs[k] << ", "; if( num_owned ) buffer << " (owned by this processor)"; buffer << std::endl; } } } } } for( int i = 0; i < size; ++i ) { MPI_Barrier( MPI_COMM_WORLD ); if( i == rank ) { std::cout << buffer.str(); std::cout.flush(); } } }
void save_and_load_on_root | ( | Interface & | moab, |
const char * | tmp_filename | ||
Definition at line 427 of file parallel_hdf5_test.cpp.
References CHECK_ERR, moab::Interface::delete_mesh(), ErrorCode, moab::ParallelComm::get_all_pcomm(), KeepTmpFiles, moab::Interface::load_file(), MB_SUCCESS, MPI_COMM_WORLD, moab::Interface::tag_delete(), moab::Interface::tag_get_tags(), moab::Interface::write_file(), and WriteDebugLevel.
Referenced by test_write_different_element_types(), test_write_different_tags(), test_write_elements(), test_write_shared_sets(), and test_write_unbalanced().
{ ErrorCode rval; int procnum; MPI_Comm_rank( MPI_COMM_WORLD, &procnum ); const char* opt = "PARALLEL=WRITE_PART"; std::string str; if( WriteDebugLevel ) { std::ostringstream s; s << opt << ";DEBUG_IO=" << WriteDebugLevel; str = s.str(); opt = str.c_str(); } rval = moab.write_file( tmp_filename, 0, opt ); if( MB_SUCCESS != rval ) { std::cerr << "Parallel write failed on processor " << procnum << std::endl; if( procnum == 0 && !KeepTmpFiles ) remove( tmp_filename );CHECK_ERR( rval ); } if( procnum == 0 && KeepTmpFiles ) std::cout << "Wrote file: \"" << tmp_filename << "\"\n"; // All created pcomm objects should be retrieved (with the pcomm tag) and // deleted at this time. Otherwise, the memory used by them will be leaked // as the pcomm tag will be deleted by moab.delete_mesh() below. std::vector< ParallelComm* > pc_list; ParallelComm::get_all_pcomm( &moab, pc_list ); for( std::vector< ParallelComm* >::iterator vit = pc_list.begin(); vit != pc_list.end(); ++vit ) delete *vit; moab.delete_mesh(); std::vector< Tag > tags; rval = moab.tag_get_tags( tags );CHECK_ERR( rval ); for( size_t i = 0; i < tags.size(); ++i ) { rval = moab.tag_delete( tags[i] );CHECK_ERR( rval ); } if( procnum == 0 ) { rval = moab.load_file( tmp_filename ); if( !KeepTmpFiles ) remove( tmp_filename );CHECK_ERR( rval ); } }
void test_bcast_summary | ( | ) |
Definition at line 51 of file parallel_hdf5_test.cpp.
References ReadIntervals, and test_read_elements_common().
{ test_read_elements_common( false, ReadIntervals, false, "BCAST_SUMMARY=yes" ); }
void test_read_bc_sets | ( | ) |
Definition at line 1199 of file parallel_hdf5_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), create_input_file(), DefaultReadIntervals, DIRICHLET_SET_TAG_NAME, ErrorCode, moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type_and_tag(), get_read_options(), KeepTmpFiles, moab::Interface::load_file(), MATERIAL_SET_TAG_NAME, MB_TYPE_INTEGER, MBENTITYSET, MPI_COMM_WORLD, NEUMANN_SET_TAG_NAME, rank, moab::Range::size(), and moab::Interface::tag_get_handle().
Referenced by main().
{ // const char tag_name[] = "test_tag_s"; const char file_name[] = "test_read_sets.h5m"; int numproc, rank; MPI_Comm_size( MPI_COMM_WORLD, &numproc ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); Core moab; Interface& mb = moab; ErrorCode rval; // if root processor, create hdf5 file for use in testing if( 0 == rank ) create_input_file( file_name, DefaultReadIntervals, numproc, 1, NULL, NULL, NULL, NULL, NULL, true ); MPI_Barrier( MPI_COMM_WORLD ); // make sure root has completed writing the file // do parallel read unless only one processor std::string opt = get_read_options(); rval = mb.load_file( file_name, 0, opt.c_str() ); MPI_Barrier( MPI_COMM_WORLD ); // make sure all procs complete before removing file if( 0 == rank && !KeepTmpFiles ) remove( file_name );CHECK_ERR( rval ); Tag tag; int num_ents[3], global_num_ents[3] = { 0, 0, 0 }; Range sets, contents; const char* names[] = { NEUMANN_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME, MATERIAL_SET_TAG_NAME }; int vints = DefaultReadIntervals + 1; int expected_num_ents[] = { ( numproc * 4 + 2 ) * DefaultReadIntervals * DefaultReadIntervals, ( ( numproc * 4 + 2 ) * ( vints - 2 ) * ( vints - 2 ) + 12 * numproc * ( vints - 2 ) + 8 * numproc ), numproc * DefaultReadIntervals * DefaultReadIntervals * DefaultReadIntervals }; for( int i = 0; i < 3; i++ ) { rval = mb.tag_get_handle( names[i], 1, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, sets );CHECK_ERR( rval ); CHECK_EQUAL( 1, (int)sets.size() ); rval = mb.get_entities_by_handle( *sets.begin(), contents, true );CHECK_ERR( rval ); num_ents[i] = contents.size(); sets.clear(); contents.clear(); } MPI_Reduce( num_ents, global_num_ents, 3, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD ); if( 0 == rank ) { // std::cout << "Global:" << global_num_ents[0] << " " << global_num_ents[1] << " " << // global_num_ents[2] << " " << std::endl; std::cout << "Expected:" << // expected_num_ents[0] << " " << expected_num_ents[1] << " " << expected_num_ents[2] << // " " << std::endl; for( int i = 0; i < 3; i++ ) { CHECK_EQUAL( global_num_ents[i], expected_num_ents[i] ); } } }
void test_read_elements | ( | ) |
Definition at line 43 of file parallel_hdf5_test.cpp.
{ test_read_elements_common( false, ReadIntervals, false ); }
void test_read_elements_by_rank | ( | ) |
Definition at line 47 of file parallel_hdf5_test.cpp.
{ test_read_elements_common( true, ReadIntervals, false ); }
void test_read_elements_common | ( | bool | by_rank, |
bool | print_time, | ||
Definition at line 929 of file parallel_hdf5_test.cpp.
References CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, create_input_file(), ErrorCode, moab::Range::front(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_dimension(), get_read_options(), KeepTmpFiles, moab::Interface::load_file(), MB_TYPE_INTEGER, MBENTITYSET, MBVERTEX, MPI_COMM_WORLD, PARTITION_TAG, rank, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
Referenced by test_bcast_summary(), test_read_elements(), test_read_elements_by_rank(), and test_read_summary().
{ const char* file_name = by_rank ? "test_read_rank.h5m" : "test_read.h5m"; int numproc, rank; MPI_Comm_size( MPI_COMM_WORLD, &numproc ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); Core moab; Interface& mb = moab; ErrorCode rval; // if root processor, create hdf5 file for use in testing if( 0 == rank ) create_input_file( file_name, intervals, numproc ); MPI_Barrier( MPI_COMM_WORLD ); // make sure root has completed writing the file // do parallel read unless only one processor std::string opt = get_read_options( by_rank, extra_opts ); rval = mb.load_file( file_name, 0, opt.c_str() ); MPI_Barrier( MPI_COMM_WORLD ); // make sure all procs complete before removing file if( 0 == rank && !KeepTmpFiles ) remove( file_name );CHECK_ERR( rval ); Tag part_tag; rval = mb.tag_get_handle( PARTITION_TAG, 1, MB_TYPE_INTEGER, part_tag );CHECK_ERR( rval ); Range parts; rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &part_tag, 0, 1, parts );CHECK_ERR( rval ); CHECK_EQUAL( 1, (int)parts.size() ); EntityHandle part = parts.front(); int id; rval = mb.tag_get_data( part_tag, &part, 1, &id );CHECK_ERR( rval ); if( by_rank ) { CHECK_EQUAL( rank, id ); } // check that all of the elements in the mesh are in the part int npart, nall; rval = mb.get_number_entities_by_dimension( part, 3, npart );CHECK_ERR( rval ); rval = mb.get_number_entities_by_dimension( 0, 3, nall );CHECK_ERR( rval ); CHECK_EQUAL( npart, nall ); // check that we have the correct vertices const double x_min = intervals * rank; const double x_max = intervals * ( rank + 1 ); Range verts; rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); std::vector< double > coords( verts.size() ); rval = mb.get_coords( verts, &coords[0], 0, 0 );CHECK_ERR( rval ); const double act_x_min = *std::min_element( coords.begin(), coords.end() ); const double act_x_max = *std::max_element( coords.begin(), coords.end() ); CHECK_REAL_EQUAL( x_min, act_x_min, DBL_EPSILON ); CHECK_REAL_EQUAL( x_max, act_x_max, DBL_EPSILON ); }
void test_read_global_tags | ( | ) |
Definition at line 1103 of file parallel_hdf5_test.cpp.
References CHECK_EQUAL, CHECK_ERR, create_input_file(), ErrorCode, get_read_options(), KeepTmpFiles, moab::Interface::load_file(), MB_TAG_DENSE, MB_TYPE_INTEGER, MPI_COMM_WORLD, rank, moab::Interface::tag_get_data(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_type(), and TagType.
{ const char tag_name[] = "test_tag_g"; const char file_name[] = "test_read_global_tags.h5m"; int numproc, rank; MPI_Comm_size( MPI_COMM_WORLD, &numproc ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); Core moab; Interface& mb = moab; ErrorCode rval; const int def_val = 0xdeadcad; const int global_val = -11; // if root processor, create hdf5 file for use in testing if( 0 == rank ) create_input_file( file_name, 1, numproc, 1, 0, 0, tag_name, &global_val, &def_val ); MPI_Barrier( MPI_COMM_WORLD ); // make sure root has completed writing the file // do parallel read unless only one processor std::string opt = get_read_options(); rval = mb.load_file( file_name, 0, opt.c_str() ); MPI_Barrier( MPI_COMM_WORLD ); // make sure all procs complete before removing file if( 0 == rank && !KeepTmpFiles ) remove( file_name );CHECK_ERR( rval ); Tag tag; rval = mb.tag_get_handle( tag_name, 1, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); TagType storage; rval = mb.tag_get_type( tag, storage );CHECK_ERR( rval ); CHECK_EQUAL( MB_TAG_DENSE, storage ); int mesh_def_val, mesh_gbl_val; rval = mb.tag_get_default_value( tag, &mesh_def_val );CHECK_ERR( rval ); CHECK_EQUAL( def_val, mesh_def_val ); EntityHandle root = 0; rval = mb.tag_get_data( tag, &root, 1, &mesh_gbl_val );CHECK_ERR( rval ); CHECK_EQUAL( global_val, mesh_gbl_val ); }
void test_read_non_adjs_side | ( | ) |
Definition at line 1572 of file parallel_hdf5_test.cpp.
References CHECK, CHECK_ERR, ErrorCode, moab::Core::load_file(), MPI_COMM_WORLD, rank, and size.
{ int err, rank, size; ErrorCode rval; err = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); CHECK( !err ); err = MPI_Comm_size( MPI_COMM_WORLD, &size ); CHECK( !err ); Core moab; rval = moab.load_file( InputOneSide, 0, "PARALLEL=READ_PART;" "PARTITION=PARALLEL_PARTITION;" "PARALLEL_RESOLVE_SHARED_ENTS" );CHECK_ERR( rval ); return; }
void test_read_sets | ( | ) |
Definition at line 64 of file parallel_hdf5_test.cpp.
References test_read_sets_common().
{ test_read_sets_common(); }
void test_read_sets_bcast_dups | ( | ) |
Definition at line 68 of file parallel_hdf5_test.cpp.
{ test_read_sets_common( "BCAST_DUPLICATE_READS=yes" ); }
void test_read_sets_common | ( | const char * | extra_opts = 0 | ) |
Definition at line 1141 of file parallel_hdf5_test.cpp.
References moab::Range::all_of_type(), moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, create_input_file(), DefaultReadIntervals, moab::Range::end(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type_and_tag(), get_read_options(), KeepTmpFiles, moab::Interface::load_file(), MB_TAG_SPARSE, MB_TYPE_INTEGER, MBENTITYSET, MBVERTEX, MPI_COMM_WORLD, rank, moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_type(), and TagType.
Referenced by test_read_sets(), test_read_sets_bcast_dups(), and test_read_sets_read_dups().
{ const char tag_name[] = "test_tag_s"; const char file_name[] = "test_read_sets.h5m"; int numproc, rank; MPI_Comm_size( MPI_COMM_WORLD, &numproc ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); Core moab; Interface& mb = moab; ErrorCode rval; // if root processor, create hdf5 file for use in testing if( 0 == rank ) create_input_file( file_name, DefaultReadIntervals, numproc, 1, 0, tag_name ); MPI_Barrier( MPI_COMM_WORLD ); // make sure root has completed writing the file // do parallel read unless only one processor std::string opt = get_read_options( extra_opts ); rval = mb.load_file( file_name, 0, opt.c_str() ); MPI_Barrier( MPI_COMM_WORLD ); // make sure all procs complete before removing file if( 0 == rank && !KeepTmpFiles ) remove( file_name );CHECK_ERR( rval ); Tag tag; rval = mb.tag_get_handle( tag_name, 2, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); TagType storage; rval = mb.tag_get_type( tag, storage );CHECK_ERR( rval ); CHECK_EQUAL( MB_TAG_SPARSE, storage ); const int iv = DefaultReadIntervals + 1; Range sets; rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, 0, 1, sets );CHECK_ERR( rval ); CHECK_EQUAL( ( iv * iv ), (int)sets.size() ); for( Range::iterator i = sets.begin(); i != sets.end(); ++i ) { int ij[2]; rval = mb.tag_get_data( tag, &*i, 1, &ij );CHECK_ERR( rval ); CHECK( ij[0] >= DefaultReadIntervals * rank ); CHECK( ij[0] <= DefaultReadIntervals * ( rank + 1 ) ); CHECK( ij[1] >= 0 ); CHECK( ij[1] <= DefaultReadIntervals ); Range contents; rval = mb.get_entities_by_handle( *i, contents );CHECK_ERR( rval ); CHECK( contents.all_of_type( MBVERTEX ) ); CHECK_EQUAL( iv, (int)contents.size() ); for( Range::iterator v = contents.begin(); v != contents.end(); ++v ) { double coords[3]; rval = mb.get_coords( &*v, 1, coords );CHECK_ERR( rval ); CHECK_REAL_EQUAL( coords[0], (double)ij[0], 1e-100 ); CHECK_REAL_EQUAL( coords[1], (double)ij[1], 1e-100 ); } } }
void test_read_sets_read_dups | ( | ) |
Definition at line 72 of file parallel_hdf5_test.cpp.
{ test_read_sets_common( "BCAST_DUPLICATE_READS=no" ); }
void test_read_summary | ( | ) |
Definition at line 55 of file parallel_hdf5_test.cpp.
{ test_read_elements_common( false, ReadIntervals, false, "BCAST_SUMMARY=no" ); }
void test_read_tags | ( | ) |
Definition at line 1050 of file parallel_hdf5_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, create_input_file(), DefaultReadIntervals, moab::Range::end(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), get_read_options(), KeepTmpFiles, moab::Interface::load_file(), MB_TAG_DENSE, MB_TYPE_INTEGER, MBVERTEX, MPI_COMM_WORLD, rank, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_type(), and TagType.
{ const char tag_name[] = "test_tag_xx"; const char file_name[] = "test_read_tags.h5m"; int numproc, rank; MPI_Comm_size( MPI_COMM_WORLD, &numproc ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); Core moab; Interface& mb = moab; ErrorCode rval; // if root processor, create hdf5 file for use in testing if( 0 == rank ) create_input_file( file_name, DefaultReadIntervals, numproc, 1, tag_name ); MPI_Barrier( MPI_COMM_WORLD ); // make sure root has completed writing the file // do parallel read unless only one processor std::string opt = get_read_options(); rval = mb.load_file( file_name, 0, opt.c_str() ); MPI_Barrier( MPI_COMM_WORLD ); // make sure all procs complete before removing file if( 0 == rank && !KeepTmpFiles ) remove( file_name );CHECK_ERR( rval ); Tag tag; rval = mb.tag_get_handle( tag_name, 3, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); TagType storage; rval = mb.tag_get_type( tag, storage );CHECK_ERR( rval ); CHECK_EQUAL( MB_TAG_DENSE, storage ); Range verts, tagged; rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); rval = mb.get_entities_by_type_and_tag( 0, MBVERTEX, &tag, 0, 1, tagged );CHECK_ERR( rval ); CHECK_EQUAL( verts, tagged ); for( Range::iterator i = verts.begin(); i != verts.end(); ++i ) { double coords[3]; rval = mb.get_coords( &*i, 1, coords );CHECK_ERR( rval ); int ijk[3]; rval = mb.tag_get_data( tag, &*i, 1, ijk );CHECK_ERR( rval ); CHECK( ijk[0] >= DefaultReadIntervals * rank ); CHECK( ijk[0] <= DefaultReadIntervals * ( rank + 1 ) ); CHECK( ijk[1] >= 0 ); CHECK( ijk[1] <= DefaultReadIntervals ); CHECK( ijk[2] >= 0 ); CHECK( ijk[2] <= DefaultReadIntervals ); CHECK_REAL_EQUAL( coords[0], (double)ijk[0], 1e-100 ); CHECK_REAL_EQUAL( coords[1], (double)ijk[1], 1e-100 ); CHECK_REAL_EQUAL( coords[2], (double)ijk[2], 1e-100 ); } }
void test_read_time | ( | ) |
Definition at line 983 of file parallel_hdf5_test.cpp.
References BCAST_DELETE, CHECK_ERR, create_input_file(), moab::Interface::delete_mesh(), ErrorCode, get_read_options(), KeepTmpFiles, moab::Interface::load_file(), MPI_COMM_WORLD, rank, READ_DELETE, READ_PART, ReadBlocks, and ReadIntervals.
{ const char file_name[] = "read_time.h5m"; int numproc, rank; MPI_Comm_size( MPI_COMM_WORLD, &numproc ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); ErrorCode rval; // if root processor, create hdf5 file for use in testing if( 0 == rank ) create_input_file( file_name, ReadIntervals, numproc, ReadBlocks ); MPI_Barrier( MPI_COMM_WORLD ); // CPU Time for true paralle, wall time for true paralle, // CPU time for read and delete, wall time for read and delete double times[6]; clock_t tmp_t; // Time true parallel read Core moab; Interface& mb = moab; times[0] = MPI_Wtime(); tmp_t = clock(); std::string opt = get_read_options( true, READ_PART ); rval = mb.load_file( file_name, 0, opt.c_str() );CHECK_ERR( rval ); times[0] = MPI_Wtime() - times[0]; times[1] = double( clock() - tmp_t ) / CLOCKS_PER_SEC; mb.delete_mesh(); // Time read and delete Core moab2; Interface& mb2 = moab2; std::string opt2 = get_read_options( true, READ_DELETE ); times[2] = MPI_Wtime(); tmp_t = clock(); rval = mb2.load_file( file_name, 0, opt2.c_str() );CHECK_ERR( rval ); times[2] = MPI_Wtime() - times[2]; times[3] = double( clock() - tmp_t ) / CLOCKS_PER_SEC; mb2.delete_mesh(); // Time broadcast and delete Core moab3; Interface& mb3 = moab3; std::string opt3 = get_read_options( true, BCAST_DELETE ); times[4] = MPI_Wtime(); tmp_t = clock(); rval = mb3.load_file( file_name, 0, opt3.c_str() );CHECK_ERR( rval ); times[4] = MPI_Wtime() - times[4]; times[5] = double( clock() - tmp_t ) / CLOCKS_PER_SEC; mb3.delete_mesh(); double max_times[6] = { 0, 0, 0, 0, 0, 0 }, sum_times[6] = { 0, 0, 0, 0, 0, 0 }; MPI_Reduce( times, max_times, 6, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD ); MPI_Reduce( times, sum_times, 6, MPI_DOUBLE, MPI_SUM, 0, MPI_COMM_WORLD ); MPI_Barrier( MPI_COMM_WORLD ); if( 0 == rank ) { printf( "%12s %12s %12s %12s\n", "", "READ_PART", "READ_DELETE", "BCAST_DELETE" ); printf( "%12s %12g %12g %12g\n", "Max Wall", max_times[0], max_times[2], max_times[4] ); printf( "%12s %12g %12g %12g\n", "Total Wall", sum_times[0], sum_times[2], sum_times[4] ); printf( "%12s %12g %12g %12g\n", "Max CPU", max_times[1], max_times[3], max_times[5] ); printf( "%12s %12g %12g %12g\n", "Total CPU", sum_times[1], sum_times[3], sum_times[5] ); } MPI_Barrier( MPI_COMM_WORLD ); if( 0 == rank && !KeepTmpFiles ) remove( file_name ); }
void test_var_length_parallel | ( | ) |
Definition at line 668 of file parallel_hdf5_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Interface::create_vertices(), moab::Range::end(), ErrorCode, filename, moab::Interface::get_entities_by_type(), KeepTmpFiles, moab::Interface::load_mesh(), mb, MB_SUCCESS, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_VARLEN, MB_TYPE_INTEGER, MB_VARIABLE_DATA_LENGTH, MBVERTEX, MPI_COMM_WORLD, n, PARALLEL_GID_TAG_NAME, rank, size, moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), moab::Interface::tag_set_by_ptr(), tagname, TagType, moab::Interface::write_file(), WriteDebugLevel, and moab::Core::~Core().
{ Range::const_iterator i; ErrorCode rval; Core moab; Interface& mb = moab; Range verts; Tag vartag; const char* filename = "var-len-para.h5m"; const char* tagname = "ParVar"; // If this tag doesn't exist, writer will fail Tag junk_tag; mb.tag_get_handle( PARALLEL_GID_TAG_NAME, 1, MB_TYPE_INTEGER, junk_tag, MB_TAG_DENSE | MB_TAG_EXCL ); int numproc, rank; MPI_Comm_size( MPI_COMM_WORLD, &numproc ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); // Create N+1 vertices on each processor, where N is the rank std::vector< double > coords( 3 * rank + 3, (double)rank ); rval = mb.create_vertices( &coords[0], rank + 1, verts );CHECK_ERR( rval ); // Create a var-len tag rval = mb.tag_get_handle( tagname, 0, MB_TYPE_INTEGER, vartag, MB_TAG_DENSE | MB_TAG_VARLEN | MB_TAG_EXCL );CHECK_ERR( rval ); // Write data on each vertex: // { n, rank, rank+1, ..., rank+n-1 } where n >= 1 std::vector< int > data; rval = MB_SUCCESS; for( i = verts.begin(); i != verts.end(); ++i ) { EntityHandle h = *i; const int n = h % 7 + 1; data.resize( n + 1 ); data[0] = n; for( int j = 0; j < n; ++j ) data[j + 1] = rank + j; const int s = ( n + 1 ); const void* ptrarr[] = { &data[0] }; ErrorCode tmperr = mb.tag_set_by_ptr( vartag, &h, 1, ptrarr, &s ); if( MB_SUCCESS != tmperr ) rval = tmperr; } CHECK_ERR( rval ); // Write file const char* opt = "PARALLEL=WRITE_PART"; std::string str; if( WriteDebugLevel ) { std::ostringstream s; s << opt << ";DEBUG_IO=" << WriteDebugLevel; str = s.str(); opt = str.c_str(); } rval = mb.write_file( filename, "MOAB", opt );CHECK_ERR( rval ); // Read file. We only reset and re-read the file on the // root processor. All other processors keep the pre-write // mesh. This allows many of the tests to be run on all // processors. Running the tests on the pre-write mesh on // non-root processors allows us to verify that any problems // are due to the file API rather than some other bug. ErrorCode rval2 = rval = MB_SUCCESS; if( !rank ) { moab.~Core(); new( &moab ) Core; rval = mb.load_mesh( filename ); if( !KeepTmpFiles ) remove( filename ); rval2 = mb.tag_get_handle( tagname, 0, MB_TYPE_INTEGER, vartag ); } CHECK_ERR( rval );CHECK_ERR( rval2 ); // Check that tag is correct int tag_size; rval = mb.tag_get_length( vartag, tag_size ); CHECK_EQUAL( MB_VARIABLE_DATA_LENGTH, rval ); TagType storage; rval = mb.tag_get_type( vartag, storage );CHECK_ERR( rval ); CHECK_EQUAL( MB_TAG_DENSE, storage ); DataType type; rval = mb.tag_get_data_type( vartag, type );CHECK_ERR( rval ); CHECK_EQUAL( MB_TYPE_INTEGER, type ); // get vertices verts.clear(); rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); // Check consistency of tag data on each vertex // and count the number of vertices for each rank. std::vector< int > vtx_counts( numproc, 0 ); for( i = verts.begin(); i != verts.end(); ++i ) { EntityHandle h = *i; int size = -1; const void* ptrarr[1] = { 0 }; rval = mb.tag_get_by_ptr( vartag, &h, 1, ptrarr, &size );CHECK_ERR( rval ); const int* tag_data = reinterpret_cast< const int* >( ptrarr[0] ); CHECK( size >= 2 ); CHECK( NULL != tag_data ); CHECK_EQUAL( size - 1, tag_data[0] ); CHECK( tag_data[1] >= 0 && tag_data[1] < numproc ); ++vtx_counts[tag_data[1]]; for( int j = 1; j < size - 1; ++j ) CHECK_EQUAL( tag_data[1] + j, tag_data[1 + j] ); } // Check number of vertices for each rank for( int j = 0; j < numproc; ++j ) { // Only root should have data for other processors. if( rank == 0 || rank == j ) CHECK_EQUAL( j + 1, vtx_counts[j] ); else CHECK_EQUAL( 0, vtx_counts[j] ); } }
void test_write_dense_tags | ( | ) |
Definition at line 1514 of file parallel_hdf5_test.cpp.
References CHECK, CHECK_ERR, ErrorCode, moab::Core::get_coords(), moab::Core::get_entities_by_dimension(), moab::Core::load_file(), MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MPI_COMM_WORLD, rank, size, moab::Range::size(), moab::Core::tag_get_handle(), moab::Core::tag_get_type(), moab::Core::tag_set_data(), tagname, TagType, and moab::Core::write_file().
{ int err, rank, size; ErrorCode rval; err = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); CHECK( !err ); err = MPI_Comm_size( MPI_COMM_WORLD, &size ); CHECK( !err ); Core moab; rval = moab.load_file( InputMix, 0, "PARALLEL=READ_PART;" "PARTITION=PARALLEL_PARTITION;" "PARALLEL_RESOLVE_SHARED_ENTS" );CHECK_ERR( rval ); // create an dense tag, on all elements, then write the output in parallel // load the file again, and test the type of the tag Range elems; moab.get_entities_by_dimension( 0, 2, elems ); const char* tagname = "element_tag"; const double defVal = 0.; Tag fieldTag; rval = moab.tag_get_handle( tagname, 1, MB_TYPE_DOUBLE, fieldTag, MB_TAG_DENSE | MB_TAG_CREAT, &defVal );CHECK_ERR( rval ); int numElems = (int)elems.size(); for( int i = 0; i < numElems; i++ ) { EntityHandle elem = elems[i]; double xyz[3]; moab.get_coords( &elem, 1, xyz ); // some value double fieldValue = sqrt( xyz[0] * xyz[0] + xyz[1] * xyz[1] + xyz[2] * xyz[2] ); moab.tag_set_data( fieldTag, &elem, 1, &fieldValue ); } // write the file in parallel rval = moab.write_file( "newfile.h5m", 0, "PARALLEL=WRITE_PART" );CHECK_ERR( rval ); // now read the new file, in a new instance, and test the tag type Core moab2; rval = moab2.load_file( "newfile.h5m", 0, "PARALLEL=READ_PART;" "PARTITION=PARALLEL_PARTITION;" "PARALLEL_RESOLVE_SHARED_ENTS" );CHECK_ERR( rval ); // find the element tag Tag found_tag; rval = moab2.tag_get_handle( tagname, 1, MB_TYPE_DOUBLE, found_tag );CHECK_ERR( rval ); TagType tagt; rval = moab2.tag_get_type( found_tag, tagt );CHECK_ERR( rval ); CHECK( tagt == MB_TAG_DENSE ); }
void test_write_different_element_types | ( | ) |
Definition at line 1257 of file parallel_hdf5_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, conn, moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), MBEDGE, MBHEX, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, MPI_COMM_WORLD, rank, and save_and_load_on_root().
{ const char file_name[] = "test_write_different_element_types.h5m"; int numproc, rank; MPI_Comm_size( MPI_COMM_WORLD, &numproc ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); Core moab; Interface& mb = moab; ErrorCode rval; const EntityType topos[] = { MBEDGE, MBEDGE, MBQUAD, MBTRI, MBQUAD, MBTRI, MBTET, MBHEX, MBPRISM, MBPYRAMID, MBHEX, MBHEX }; const int verts[] = { 2, 3, 4, 3, 9, 6, 4, 8, 6, 5, 20, 27 }; const int ntypes = sizeof( topos ) / sizeof( topos[0] ); const EntityType mtype = topos[rank % ntypes]; const int nvert = verts[rank % ntypes]; std::vector< EntityHandle > conn( nvert ); for( int i = 0; i < nvert; ++i ) { const double coords[] = { static_cast< double >( rank ), static_cast< double >( i ), 0 }; rval = mb.create_vertex( coords, conn[i] );CHECK_ERR( rval ); } EntityHandle handle; rval = mb.create_element( mtype, &conn[0], nvert, handle );CHECK_ERR( rval ); save_and_load_on_root( mb, file_name ); if( rank ) return; for( int i = 0; i < ntypes; ++i ) { const int num_exp = numproc / ntypes + ( i < ( numproc % ntypes ) ? 1 : 0 ); Range ents; rval = mb.get_entities_by_type( 0, topos[i], ents );CHECK_ERR( rval ); int num = 0; for( Range::iterator e = ents.begin(); e != ents.end(); ++e ) { const EntityHandle* junk; int len; rval = mb.get_connectivity( *e, junk, len, false ); if( len == verts[i] ) ++num; } CHECK_EQUAL( num_exp, num ); } }
void test_write_different_tags | ( | ) |
Definition at line 1348 of file parallel_hdf5_test.cpp.
References get_tag(), MPI_COMM_WORLD, rank, and save_and_load_on_root().
{ const char file_name[] = "test_write_different_tags.h5m"; int numproc, rank; MPI_Comm_size( MPI_COMM_WORLD, &numproc ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); Core moab; Interface& mb = moab; const int min_tags = 8; get_tag( mb, rank, true ); for( int idx = rank + numproc; idx < min_tags; idx += numproc ) get_tag( mb, idx, true ); save_and_load_on_root( mb, file_name ); if( 0 == rank ) { for( int i = 0; i < std::max( min_tags, numproc ); ++i ) get_tag( mb, i, false ); } }
void test_write_elements | ( | ) |
Definition at line 551 of file parallel_hdf5_test.cpp.
References CHECK, CHECK_ERR, check_identical_mesh(), count_owned_entities(), moab::CN::EntityTypeName(), ErrorCode, moab::Interface::get_number_entities_by_type(), load_and_partition(), moab::Core::load_file(), MBENTITYSET, MBVERTEX, MPI_COMM_WORLD, rank, save_and_load_on_root(), t, and u.
{ int proc_counts[MBENTITYSET], all_counts[MBENTITYSET], file_counts[MBENTITYSET]; int err, rank; ErrorCode rval; err = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); CHECK( !err ); // load and partition a .cub file Core moab_instance; Interface& moab = moab_instance; load_and_partition( moab, InputFile, false ); // count number of owned entities of each type and sum over all procs count_owned_entities( moab, proc_counts ); std::fill( all_counts, all_counts + MBENTITYSET, 0u ); err = MPI_Allreduce( proc_counts, all_counts, MBENTITYSET, MPI_INT, MPI_SUM, MPI_COMM_WORLD ); CHECK( !err ); // do parallel write and on root proc do serial read of written file save_and_load_on_root( moab, "test_write_elements.h5m" ); if( rank == 0 ) { for( EntityType t = MBVERTEX; t < MBENTITYSET; ++t ) { rval = moab.get_number_entities_by_type( 0, t, file_counts[t] );CHECK_ERR( rval ); } } // check that sum of owned entities equals number of entities from serial read err = MPI_Bcast( file_counts, MBENTITYSET, MPI_INT, 0, MPI_COMM_WORLD ); CHECK( !err ); bool all_equal = true; for( EntityType t = MBVERTEX; t < MBENTITYSET; ++t ) if( file_counts[t] != all_counts[t] ) all_equal = false; if( rank == 0 && !all_equal ) { std::cerr << "Type\tPartnd\tWritten" << std::endl; for( EntityType t = MBVERTEX; t < MBENTITYSET; ++t ) std::cerr << CN::EntityTypeName( t ) << '\t' << all_counts[t] << '\t' << file_counts[t] << std::endl; } CHECK( all_equal ); // on root processor, do serial read of original .cub file and compare if( rank == 0 ) { Core moab2; rval = moab2.load_file( InputFile );CHECK_ERR( rval ); check_identical_mesh( moab, moab2 ); } }
void test_write_polygons | ( | ) |
void test_write_shared_sets | ( | ) |
Definition at line 627 of file parallel_hdf5_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, check_sets_sizes(), moab::Range::end(), ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type_and_tag(), load_and_partition(), moab::Interface::load_file(), MATERIAL_SET_TAG_NAME, MB_TYPE_INTEGER, MBENTITYSET, MPI_COMM_WORLD, rank, save_and_load_on_root(), size, moab::Range::size(), moab::Interface::tag_get_data(), and moab::Interface::tag_get_handle().
{ int err, rank, size; ErrorCode rval; err = MPI_Comm_rank( MPI_COMM_WORLD, &rank ); CHECK( !err ); err = MPI_Comm_size( MPI_COMM_WORLD, &size ); CHECK( !err ); Core moab_instance; Interface& moab = moab_instance; load_and_partition( moab, InputFile ); save_and_load_on_root( moab, "test_write_shared_sets.h5m" ); if( rank != 0 ) return; Core moab2_instance; Interface& moab2 = moab2_instance; rval = moab2.load_file( InputFile );CHECK_ERR( rval ); Tag mattag1, mattag2; rval = moab.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mattag1 );CHECK_ERR( rval ); rval = moab2.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mattag2 );CHECK_ERR( rval ); Range matsets; rval = moab2.get_entities_by_type_and_tag( 0, MBENTITYSET, &mattag2, 0, 1, matsets );CHECK_ERR( rval ); for( Range::iterator i = matsets.begin(); i != matsets.end(); ++i ) { int block_id; rval = moab2.tag_get_data( mattag2, &*i, 1, &block_id );CHECK_ERR( rval ); Range tmpents; void* tagdata[] = { &block_id }; rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &mattag1, tagdata, 1, tmpents ); if( tmpents.size() != 1 ) std::cerr << tmpents.size() << " sets with material set id " << block_id << std::endl; CHECK_EQUAL( (int)tmpents.size(), 1 ); CHECK( check_sets_sizes( moab2, *i, moab, tmpents.front() ) ); } }
void test_write_unbalanced | ( | ) |
Definition at line 1437 of file parallel_hdf5_test.cpp.
References moab::Interface::add_entities(), CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), conn, moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), entities, ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), moab::ParallelComm::get_pcomm(), GLOBAL_ID_TAG_NAME, moab::Interface::globalId_tag(), moab::Range::insert(), MB_TYPE_INTEGER, MBENTITYSET, MBQUAD, MBVERTEX, MESHSET_SET, MPI_COMM_WORLD, rank, moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), save_and_load_on_root(), moab::Range::size(), moab::Interface::tag_get_handle(), and moab::Interface::tag_set_data().
{ const char file_name[] = "test_write_unbalanced.h5m"; int numproc, rank; MPI_Comm_size( MPI_COMM_WORLD, &numproc ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); Core moab; Interface& mb = moab; ErrorCode rval; Tag idtag = mb.globalId_tag(); // create a shared set const int two = 2; Range entities, sets; EntityHandle set; rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); rval = mb.tag_set_data( idtag, &set, 1, &two );CHECK_ERR( rval ); sets.insert( set ); // create a quad on every odd processor if( rank % 2 ) { const double coords[4][3] = { { static_cast< double >( rank ), 0, 0 }, { static_cast< double >( rank + 2 ), 0, 0 }, { static_cast< double >( rank + 2 ), 2, 0 }, { static_cast< double >( rank ), 2, 0 } }; EntityHandle conn[4], quad; for( int i = 0; i < 4; ++i ) mb.create_vertex( coords[i], conn[i] ); mb.create_element( MBQUAD, conn, 4, quad ); const int ids[4] = { rank, rank + 2, rank + 3, rank + 1 }; rval = mb.tag_set_data( idtag, conn, 4, ids );CHECK_ERR( rval ); rval = mb.add_entities( set, &quad, 1 );CHECK_ERR( rval ); entities.insert( quad ); } // set up sharing data ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 ); if( 0 == pcomm ) pcomm = new ParallelComm( &mb, MPI_COMM_WORLD ); rval = pcomm->resolve_shared_ents( 0, entities, 2, 0, NULL, &idtag );CHECK_ERR( rval ); rval = pcomm->resolve_shared_sets( sets, idtag );CHECK_ERR( rval ); // do parallel write and serial load save_and_load_on_root( mb, file_name ); if( rank != 0 ) return; // check that we got what we expected Range quads, verts; rval = mb.get_entities_by_type( 0, MBQUAD, quads );CHECK_ERR( rval ); rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); const size_t nquads = numproc / 2; const size_t nverts = nquads ? 2 + 2 * nquads : 0; CHECK_EQUAL( nquads, quads.size() ); CHECK_EQUAL( nverts, verts.size() ); rval = mb.tag_get_handle( GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, idtag );CHECK_ERR( rval ); sets.clear(); const void* vals[] = { &two }; rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &idtag, vals, 1, sets );CHECK_ERR( rval ); CHECK_EQUAL( (size_t)1, sets.size() ); entities.clear(); rval = mb.get_entities_by_handle( sets.front(), entities );CHECK_ERR( rval ); CHECK_EQUAL( nquads, entities.size() ); CHECK_EQUAL( quads, entities ); }
const bool DEFAULT_BY_RANK = false |
Definition at line 102 of file parallel_hdf5_test.cpp.
Referenced by get_read_options().
const Mode DEFAULT_MODE = READ_PART |
Definition at line 101 of file parallel_hdf5_test.cpp.
Referenced by defstr(), get_read_options(), and main().
const int DefaultReadIntervals = 2 |
Definition at line 90 of file parallel_hdf5_test.cpp.
Referenced by main(), test_read_bc_sets(), test_read_sets_common(), and test_read_tags().
bool HyperslabAppend = false |
Definition at line 89 of file parallel_hdf5_test.cpp.
Referenced by get_read_options(), and main().
bool KeepTmpFiles = false |
Definition at line 87 of file parallel_hdf5_test.cpp.
Referenced by main(), save_and_load_on_root(), test_read_bc_sets(), test_read_elements_common(), test_read_global_tags(), test_read_sets_common(), test_read_tags(), test_read_time(), and test_var_length_parallel().
const char PARTITION_TAG[] = "PARTITION" |
Definition at line 85 of file parallel_hdf5_test.cpp.
Referenced by create_input_file(), get_read_options(), and test_read_elements_common().
bool PauseOnStart = false |
Definition at line 88 of file parallel_hdf5_test.cpp.
int ReadBlocks = 1 |
Definition at line 93 of file parallel_hdf5_test.cpp.
Referenced by main(), and test_read_time().
int ReadDebugLevel = 0 |
Definition at line 91 of file parallel_hdf5_test.cpp.
int ReadIntervals = 0 |
Definition at line 42 of file parallel_hdf5_test.cpp.
Referenced by main(), test_bcast_summary(), test_read_elements(), test_read_elements_by_rank(), test_read_summary(), and test_read_time().
int WriteDebugLevel = 0 |
Definition at line 92 of file parallel_hdf5_test.cpp.
Referenced by main(), save_and_load_on_root(), and test_var_length_parallel().
