parametrizer.hpp
00001 #ifndef MOAB_PARAMETRIZER_HPP
00002 #define MOAB_PARAMETRIZER_HPP
00003 #include "moab/Matrix3.hpp"
00004 #include "moab/CartVect.hpp"
00005 #include "moab/ElemUtil.hpp"
00006 namespace moab
00007 {
00008
00009 namespace element_utility
00010 {
00011     // non-exported functionality
00012     namespace
00013     {
00014
00015         template < typename Moab, typename Entity_handle, typename Points >
00016         void get_moab_points( Moab& moab, Entity_handle eh, Points& points )
00017         {
00018             const Entity_handle* connectivity_begin;
00019             int num_vertices;
00020             moab.get_connectivity( eh, connectivity_begin, num_vertices );
00021             // TODO: This is hacky, it works correctly since
00022             // CartVect is only double d[ 3], with a default
00023             // constructor.. get_coords() should be
00024             // flexible enough to allow other types..
00025             points.resize( num_vertices );
00026             moab.get_coords( connectivity_begin, num_vertices, &( points[0][0] ) );
00027         }
00028
00029     }  // namespace
00030
00031     template < typename Element_map >
00032     class Element_parametrizer
00033     {
00034       public:
00035         // public types
00036         typedef Element_map Map;
00037
00038       private:
00039         typedef Element_parametrizer< Map > Self;
00040
00041       public:  // public functionality
00042         Element_parametrizer() : map() {}
00043         Element_parametrizer( const Self& f ) : map( f.map ) {}
00044
00045       public:
00046         template < typename Moab, typename Entity_handle, typename Point >
00047         std::pair< bool, Point > operator()( Moab& moab, const Entity_handle& eh, const Point& point, const double tol )
00048         {
00049             typedef std::vector< moab::CartVect > Points;
00050             Points points;
00051             get_moab_points( moab, eh, points );
00052             return map( moab, eh, points, point, tol );
00053         }
00054
00055       private:
00056         Element_map map;
00057     };  // class Element_parametrizer
00058
00059     class Parametrizer
00060     {
00061       private:
00062         typedef Parametrizer Self;
00063         typedef moab::EntityHandle Entity_handle;
00064
00065       public:  // public functionality
00066         Parametrizer() : hex_map(), tet_map() {}
00067         Parametrizer( const Self& f ) : hex_map( f.hex_map ), tet_map( f.tet_map ) {}
00068
00069       public:
00070         template < typename Moab, typename Entity_handle, typename Point >
00071         std::pair< bool, Point > operator()( Moab& moab, const Entity_handle& eh, const Point& point )
00072         {
00073             // get entity
00074             typedef std::vector< moab::CartVect > Points;
00075             Points points;
00076             get_moab_points( moab, eh, points );
00077             // get type
00078             switch( moab.type_from_handle( eh ) )
00079             {
00080                 case moab::MBHEX:
00081                     return hex_map( moab, eh, points, point );
00082                 case moab::MBTET:
00083                     return tet_map( moab, eh, points, point );
00084                 // TODO: not correct..
00085                 // TODO: add quadratic hex, and a proper case for
00086                 // spectral hex
00087                 default:
00088                     quadratic_hex_map( moab, eh, points, point );
00089                     return spectral_hex_map( moab, eh, points, point );
00090                     std::cerr << "Element type not supported" << std::endl;
00091                     return make_pair( false, Point( 3, 0.0 ) );
00092             }
00093         }
00094         template < typename Moab, typename Entity_handle, typename Point >
00095         void interpolate( Moab& moab, const Entity_handle& eh, const Point& natural_coords )
00096         {
00097             // get field values from moab tag,
00098             // then
00099             // evaluate_scalar_field();
00100         }
00101
00102       private:
00103         Linear_hex_map< moab::Matrix3 > hex_map;
00104         Linear_tet_map< Entity_handle, moab::Matrix3 > tet_map;
00105         Spectral_hex_map< moab::Matrix3 > spectral_hex_map;
00106         Quadratic_hex_map< moab::Matrix3 > quadratic_hex_map;
00107     };  // class Parametrizer
00108
00109 }  // namespace element_utility
00110 }  // namespace moab
00111 #endif  // MOAB_PARAMETRIZER_HPP
