MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/ParallelMergeMesh.hpp"
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab_mpi.h"
#include <iostream>
#include <string>
#include <cstdlib>
#include "moab/ParallelComm.hpp"
#include "MBParallelConventions.h"
#include <fstream>
#include <sstream>
#include "moab/Skinner.hpp"
Defines | |
#define | PrintInfo false |
Functions | |
void | print_output (moab::ParallelComm *pc, moab::Core *mb, int numprocs, int myID, bool perform) |
int | main (int argc, char *argv[]) |
#define PrintInfo false |
Definition at line 21 of file parmerge.cpp.
Referenced by main().
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 48 of file parmerge.cpp.
References epsilon, ErrorCode, moab::Core::get_error_string(), moab::Core::get_last_error(), moab::Core::load_mesh(), mb, MB_SUCCESS, moab::ParallelMergeMesh::merge(), MPI_COMM_WORLD, outfile, print_output(), PrintInfo, and moab::Core::write_file().
{ // Check argument count if( argc != 4 ) { std::cerr << "Usage: " << argv[0] << " <inputfile> <outputfile> <tolerance>" << std::endl; return 1; } // Check the output file extension std::string outfile( argv[2] ); if( outfile.compare( outfile.size() - 4, 4, ".h5m" ) != 0 ) { std::cerr << "Invalid Parallel Output File" << std::endl; return 1; } // Read in tolerance double epsilon; if( !( std::istringstream( argv[3] ) >> epsilon ) ) { std::cerr << "Unable to parse tolerance" << std::endl; return 1; } // Initialize MPI int numprocs, myID; MPI_Init( &argc, &argv ); MPI_Comm_size( MPI_COMM_WORLD, &numprocs ); MPI_Comm_rank( MPI_COMM_WORLD, &myID ); // Read in files from input files // Round robin distribution of reading meshes moab::Core* mb = new moab::Core(); moab::ErrorCode rval; std::ifstream file( argv[1] ); if( file.is_open() ) { std::string line; int count = 0; // Read each line while( file.good() ) { getline( file, line ); if( myID == count && line != "" ) { // Read in the file rval = mb->load_mesh( line.c_str() ); if( rval != moab::MB_SUCCESS ) { std::cerr << "Error Opening Mesh File " << line << std::endl; MPI_Abort( MPI_COMM_WORLD, 1 ); file.close(); return 1; } } count = ( count + 1 ) % numprocs; } file.close(); } else { std::cerr << "Error Opening Input File " << argv[1] << std::endl; MPI_Abort( MPI_COMM_WORLD, 1 ); return 1; } // Get a pcomm object moab::ParallelComm* pc = new moab::ParallelComm( mb, MPI_COMM_WORLD ); // Call the resolve parallel function moab::ParallelMergeMesh pm( pc, epsilon ); rval = pm.merge(); if( rval != moab::MB_SUCCESS ) { std::cerr << "Merge Failed" << std::endl; MPI_Abort( MPI_COMM_WORLD, 1 ); return 1; } print_output( pc, mb, myID, numprocs, PrintInfo ); // Write out the file rval = mb->write_file( outfile.c_str(), 0, "PARALLEL=WRITE_PART" ); if( rval != moab::MB_SUCCESS ) { std::cerr << "Writing output file failed. Code:"; // Temporary File error info. std::cerr << mb->get_error_string( rval ) << std::endl; std::string foo = ""; mb->get_last_error( foo ); std::cerr << "File Error: " << foo << std::endl; return 1; } // The barrier may be necessary to stop items from being deleted when needed // But probably not necessary MPI_Barrier( MPI_COMM_WORLD ); delete pc; delete mb; MPI_Finalize(); return 0; }
void print_output | ( | moab::ParallelComm * | pc, |
moab::Core * | mb, | ||
int | numprocs, | ||
int | myID, | ||
bool | perform | ||
Definition at line 155 of file parmerge.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), moab::Skinner::find_skin(), moab::Core::get_entities_by_dimension(), moab::ParallelComm::get_owner(), MPI_COMM_WORLD, and skin().
{ moab::Range ents, skin; int o_ct = 0, no_ct = 0, tmp = 0, o_tot = 0, no_tot = 0; if( perform ) { if( myID == 0 ) std::cout << "------------------------------------------" << std::endl; // Check the count of total vertices mb->get_entities_by_dimension( 0, 0, ents ); for( moab::Range::iterator rit = ents.begin(); rit != ents.end(); ++rit ) { pc->get_owner( *rit, tmp ); if( tmp == myID ) { o_ct++; } } MPI_Reduce( &o_ct, &o_tot, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD ); if( myID == 0 ) { std::cout << "There are " << o_tot << " vertices." << std::endl; std::cout << "------------------------------------------" << std::endl; } // Check the count of owned and not owned skin faces. // owned-not owned == total skin faces moab::Skinner skinner( mb ); o_ct = 0; no_ct = 0; o_tot = 0; no_tot = 0; skin.clear(); ents.clear(); mb->get_entities_by_dimension( 0, 3, ents ); skinner.find_skin( 0, ents, 2, skin ); for( moab::Range::iterator s_rit = skin.begin(); s_rit != skin.end(); ++s_rit ) { pc->get_owner( *s_rit, tmp ); if( tmp == myID ) { o_ct++; } else { no_ct++; } } MPI_Reduce( &o_ct, &o_tot, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD ); MPI_Reduce( &no_ct, &no_tot, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD ); if( myID == 0 ) { std::cout << "There are " << o_tot << " owned skin faces." << std::endl; std::cout << "There are " << no_tot << " not owned skin faces." << std::endl; std::cout << "The difference (Global Skin Faces) is " << ( o_tot - no_tot ) << "." << std::endl; std::cout << "------------------------------------------" << std::endl; } } }
