MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/ParallelComm.hpp"
#include "MBParallelConventions.h"
#include "MBTagConventions.hpp"
#include "moab/Core.hpp"
#include "moab/MeshTopoUtil.hpp"
#include "ReadParallel.hpp"
#include "moab/FileOptions.hpp"
#include "TestUtil.hpp"
#include <algorithm>
#include <vector>
#include <set>
#include <sstream>
Defines | |
#define | MPI_COMM_WORLD 0 |
#define | P 4 |
#define | INDEXG(i, j, k) ( (k)*NIJK[1] * NIJK[0] + (j)*NIJK[0] + ( i ) ) |
#define | INDEXL(i, j, k) ( ( (k)-ijkmin[p][2] ) * nijk[p][1] * nijk[p][0] + ( (j)-ijkmin[p][1] ) * nijk[p][0] + ( (i)-ijkmin[p][0] ) ) |
Functions | |
void | test_pack_vertices () |
void | test_pack_elements () |
void | test_pack_higher_order () |
void | test_pack_poly () |
void | test_pack_sets_simple () |
void | test_pack_set_contents () |
void | test_pack_sets_of_sets () |
void | test_pack_set_parent_child () |
void | test_pack_tag_data_sparse () |
void | test_pack_tag_data_dense () |
void | test_pack_tag_data_default_value () |
void | test_pack_bit_tag_data () |
void | test_pack_variable_length_tag () |
void | test_pack_tag_handle_data () |
void | test_pack_shared_entities_2d () |
void | test_pack_shared_entities_3d () |
void | test_filter_pstatus () |
void | test_new_pcomm_instance () |
int | main (int argc, char *argv[]) |
void | pack_unpack_noremoteh (Core &moab, Range &entities) |
void | pack_unpack_noremoteh (Core &moab) |
void | check_sizes (Interface &moab, int num_vtx, int num_edge, int num_tri, int num_quad, int num_polygon, int num_tet, int num_pyr, int num_wedge, int num_knife, int num_hex, int num_polyhedron) |
void | create_simple_grid (Interface &moab, unsigned x, unsigned y, unsigned z) |
void | create_simple_grid (Interface &moab, unsigned xyz=3) |
ErrorCode | create_patch (Interface *moab, Range &verts, Range &quads, unsigned int n, double *xyz, int *gids) |
ErrorCode | create_shared_grid_2d (ParallelComm **pc, Range *verts, Range *quads) |
ErrorCode | create_shared_grid_3d (ParallelComm **pc, Range *verts, Range *hexes) |
ErrorCode | get_entities (Interface *mb, std::vector< EntityHandle > &ent_verts, int verts_per_entity, int dim, Range &ents) |
Variables | |
int | rank = 0 |
#define INDEXG | ( | i, | |
j, | |||
k | |||
) | ( (k)*NIJK[1] * NIJK[0] + (j)*NIJK[0] + ( i ) ) |
Referenced by create_shared_grid_3d().
#define INDEXL | ( | i, | |
j, | |||
k | |||
) | ( ( (k)-ijkmin[p][2] ) * nijk[p][1] * nijk[p][0] + ( (j)-ijkmin[p][1] ) * nijk[p][0] + ( (i)-ijkmin[p][0] ) ) |
#define MPI_COMM_WORLD 0 |
Definition at line 19 of file pcomm_unit.cpp.
Referenced by main(), pack_unpack_noremoteh(), test_filter_pstatus(), test_new_pcomm_instance(), test_pack_shared_entities_2d(), and test_pack_shared_entities_3d().
#define P 4 |
void check_sizes | ( | Interface & | moab, |
int | num_vtx, | ||
int | num_edge, | ||
int | num_tri, | ||
int | num_quad, | ||
int | num_polygon, | ||
int | num_tet, | ||
int | num_pyr, | ||
int | num_wedge, | ||
int | num_knife, | ||
int | num_hex, | ||
int | num_polyhedron | ||
Definition at line 140 of file pcomm_unit.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, moab::Interface::get_number_entities_by_type(), MBEDGE, MBHEX, MBKNIFE, MBPOLYGON, MBPOLYHEDRON, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, and MBVERTEX.
Referenced by test_pack_elements(), test_pack_higher_order(), and test_pack_poly().
{ int count; ErrorCode rval; rval = moab.get_number_entities_by_type( 0, MBVERTEX, count );CHECK_ERR( rval ); CHECK_EQUAL( num_vtx, count ); rval = moab.get_number_entities_by_type( 0, MBEDGE, count );CHECK_ERR( rval ); CHECK_EQUAL( num_edge, count ); rval = moab.get_number_entities_by_type( 0, MBTRI, count );CHECK_ERR( rval ); CHECK_EQUAL( num_tri, count ); rval = moab.get_number_entities_by_type( 0, MBQUAD, count );CHECK_ERR( rval ); CHECK_EQUAL( num_quad, count ); rval = moab.get_number_entities_by_type( 0, MBPOLYGON, count );CHECK_ERR( rval ); CHECK_EQUAL( num_polygon, count ); rval = moab.get_number_entities_by_type( 0, MBTET, count );CHECK_ERR( rval ); CHECK_EQUAL( num_tet, count ); rval = moab.get_number_entities_by_type( 0, MBPYRAMID, count );CHECK_ERR( rval ); CHECK_EQUAL( num_pyr, count ); rval = moab.get_number_entities_by_type( 0, MBPRISM, count );CHECK_ERR( rval ); CHECK_EQUAL( num_wedge, count ); rval = moab.get_number_entities_by_type( 0, MBKNIFE, count );CHECK_ERR( rval ); CHECK_EQUAL( num_knife, count ); rval = moab.get_number_entities_by_type( 0, MBHEX, count );CHECK_ERR( rval ); CHECK_EQUAL( num_hex, count ); rval = moab.get_number_entities_by_type( 0, MBPOLYHEDRON, count );CHECK_ERR( rval ); CHECK_EQUAL( num_polyhedron, count ); }
ErrorCode create_patch | ( | Interface * | moab, |
Range & | verts, | ||
Range & | quads, | ||
unsigned int | n, | ||
double * | xyz, | ||
int * | gids | ||
Definition at line 224 of file pcomm_unit.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertices(), ErrorCode, moab::Interface::globalId_tag(), moab::Range::insert(), MB_SUCCESS, MBQUAD, and moab::Interface::tag_set_data().
Referenced by create_shared_grid_2d().
{ // create vertices/quads in square array ErrorCode result = moab->create_vertices( xyz, n * n, verts ); if( MB_SUCCESS != result ) return result; std::vector< EntityHandle > connect; for( unsigned int j = 0; j < n - 1; j++ ) { for( unsigned int i = 0; i < n - 1; i++ ) { connect.push_back( verts[n * j + i] ); connect.push_back( verts[n * j + i + 1] ); connect.push_back( verts[n * ( j + 1 ) + i + 1] ); connect.push_back( verts[n * ( j + 1 ) + i] ); } } unsigned int nquads = ( n - 1 ) * ( n - 1 ); for( unsigned int i = 0; i < nquads; i++ ) { EntityHandle dum_quad; result = moab->create_element( MBQUAD, &connect[4 * i], 4, dum_quad ); if( MB_SUCCESS != result ) return result; quads.insert( dum_quad ); } // global ids Tag gid_tag = moab->globalId_tag(); result = moab->tag_set_data( gid_tag, verts, gids ); if( MB_SUCCESS != result ) return result; return result; }
ErrorCode create_shared_grid_2d | ( | ParallelComm ** | pc, |
Range * | verts, | ||
Range * | quads | ||
Definition at line 258 of file pcomm_unit.cpp.
References CHECK_ERR, create_patch(), ErrorCode, and moab::ParallelComm::resolve_shared_ents().
Referenced by test_pack_shared_entities_2d().
{ // // P2______ // /__/__/ /|P1 // y: /__/__/ /|| // 1 _____ ||/ _____ 1 // | | | |/|-1 | | | // .5 |__|__| ||/ |__|__| .5 // |P0| | |/-.5 |P3| | // 0 |__|__| z:0 |__|__| 0 // x:-1 -.5 0 0 .5 1 // // nodes: P2 // 18 16 14 P1 // 17 15 13 14 // 6 7 8 13 12 // 8 11 10 // 6 7 8 5 9 8 23 24 P3 // 3 4 5 2 5 21 22 // P0 0 1 2 2 19 20 int gids[] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, // P0 2, 9, 10, 5, 11, 12, 8, 13, 14, // P1 6, 7, 8, 17, 15, 13, 18, 16, 14, // P2 2, 19, 20, 5, 21, 22, 8, 23, 24 // P3 }; double xyz[] = { -1.0, 0.0, 0.0, -0.5, 0.0, 0.0, 0.0, 0.0, 0.0, -1.0, 0.5, 0.0, -0.5, 0.5, 0.0, 0.0, 0.5, 0.0, -1.0, 1.0, 0.0, -0.5, 1.0, 0.0, 0.0, 1.0, 0.0, // n0-8 0.0, 0.0, -0.5, 0.0, 0.0, -1.0, 0.0, 0.5, -0.5, 0.0, 0.5, -1.0, 0.0, 1.0, -0.5, 0.0, 1.0, -1.0, // n9-14 -0.5, 1.0, -0.5, -0.5, 1.0, -1.0, -1.0, 1.0, -0.5, -1.0, 1.0, -1.0, // n15-18 0.5, 0.0, 0.0, 1.0, 0.0, 0.0, 0.5, 0.5, 0.0, 1.0, 0.5, 0.0, 0.5, 1.0, 0.0, 1.0, 1.0, 0.0, // n19-24 }; double xyztmp[27]; // create the test mesh above for( unsigned int i = 0; i < 4; i++ ) { for( unsigned int j = 0; j < 9; j++ ) { xyztmp[3 * j] = xyz[3 * gids[9 * i + j]]; xyztmp[3 * j + 1] = xyz[3 * gids[9 * i + j] + 1]; xyztmp[3 * j + 2] = xyz[3 * gids[9 * i + j] + 2]; } create_patch( pc[i]->get_moab(), verts[i], quads[i], 3, xyztmp, &gids[9 * i] ); } ErrorCode rval = ParallelComm::resolve_shared_ents( pc, 4, 0, 2 );CHECK_ERR( rval ); return rval; }
ErrorCode create_shared_grid_3d | ( | ParallelComm ** | pc, |
Range * | hexes | ||
Definition at line 313 of file pcomm_unit.cpp.
References CHECK_ERR, moab::Interface::create_element(), moab::Interface::create_vertices(), ErrorCode, fname, moab::ParallelComm::get_moab(), moab::Interface::globalId_tag(), INDEXG, INDEXL, moab::Range::insert(), MB_SUCCESS, MBHEX, P, rank, moab::ParallelComm::resolve_shared_ents(), moab::Interface::tag_set_data(), and moab::Interface::write_file().
Referenced by test_pack_shared_entities_3d().
{ // // 4 _____ _____ // | | | | | | // 3|__|__| |__|__| GIDS HANDLES // |P1| | |P2| | // |__|__| |__|__| 20 21 22 22 23 24 7 8 9 7 8 9 // 2 ___________ 15 16 17 17 18 19 4 5 6 4 5 6 // | | | | | 10 11 12 12 13 14 1 2 3 1 2 3 // / 1|__|__|__|__| // | | |P0| | | 10 11 12 13 14 10 11 12 13 14 // J 0|__|__|__|__| 5 6 7 8 9 5 6 7 8 9 // I-> 0 1 2 3 4 0 1 2 3 4 0 1 2 3 4 // // P3 - k = 2..4 // create structured meshes // ijkmin[p][ijk], ijkmax[p][ijk] #define P 4 int ijkmin[P][3] = { { 0, 0, 0 }, { 0, 2, 0 }, { 2, 2, 0 }, { 0, 0, 2 } }; int ijkmax[P][3] = { { 4, 2, 2 }, { 2, 4, 2 }, { 4, 4, 2 }, { 4, 4, 4 } }; int nijk[P][3]; int NIJK[3] = { 0, 0, 0 }; #define INDEXG( i, j, k ) ( (k)*NIJK[1] * NIJK[0] + (j)*NIJK[0] + ( i ) ) #define INDEXL( i, j, k ) \ ( ( (k)-ijkmin[p][2] ) * nijk[p][1] * nijk[p][0] + ( (j)-ijkmin[p][1] ) * nijk[p][0] + ( (i)-ijkmin[p][0] ) ) int p, i, j, k; for( p = 0; p < P; p++ ) { for( i = 0; i < 3; i++ ) { nijk[p][i] = ijkmax[p][i] - ijkmin[p][i] + 1; NIJK[i] = std::max( NIJK[i], nijk[p][i] ); } } std::vector< int > gids; std::vector< double > xyz; ErrorCode rval; Tag gid_tag; for( p = 0; p < P; p++ ) { gid_tag = pc[p]->get_moab()->globalId_tag(); // make vertices int nverts = nijk[p][0] * nijk[p][1] * nijk[p][2]; xyz.resize( 3 * nverts ); gids.resize( nverts ); // set vertex gids int nv = 0; for( k = ijkmin[p][2]; k <= ijkmax[p][2]; k++ ) for( j = ijkmin[p][1]; j <= ijkmax[p][1]; j++ ) for( i = ijkmin[p][0]; i <= ijkmax[p][0]; i++ ) { // xyz xyz[3 * nv] = i; xyz[3 * nv + 1] = j; xyz[3 * nv + 2] = k; // gid gids[nv++] = INDEXG( i, j, k ); } rval = pc[p]->get_moab()->create_vertices( &xyz[0], nverts, verts[p] );CHECK_ERR( rval ); rval = pc[p]->get_moab()->tag_set_data( gid_tag, verts[p], &gids[0] ); if( MB_SUCCESS != rval ) return rval; // make elements nv = 0; EntityHandle connect[8], dum_hex; for( k = ijkmin[p][2]; k < ijkmax[p][2]; k++ ) for( j = ijkmin[p][1]; j < ijkmax[p][1]; j++ ) for( i = ijkmin[p][0]; i < ijkmax[p][0]; i++ ) { // gid connect[0] = verts[p][INDEXL( i, j, k )]; connect[1] = verts[p][INDEXL( i + 1, j, k )]; connect[2] = verts[p][INDEXL( i + 1, j + 1, k )]; connect[3] = verts[p][INDEXL( i, j + 1, k )]; connect[4] = verts[p][INDEXL( i, j, k + 1 )]; connect[5] = verts[p][INDEXL( i + 1, j, k + 1 )]; connect[6] = verts[p][INDEXL( i + 1, j + 1, k + 1 )]; connect[7] = verts[p][INDEXL( i, j + 1, k + 1 )]; rval = pc[p]->get_moab()->create_element( MBHEX, connect, 8, dum_hex ); hexes[p].insert( dum_hex ); gids[nv++] = INDEXG( i, j, k ); } rval = pc[p]->get_moab()->tag_set_data( gid_tag, hexes[p], &gids[0] ); if( MB_SUCCESS != rval ) return rval; std::ostringstream fname; fname << "tmp" << p << "." << rank << ".h5m"; rval = pc[p]->get_moab()->write_file( fname.str().c_str() ); if( MB_SUCCESS != rval ) return rval; } rval = ParallelComm::resolve_shared_ents( pc, 4, 0, 3 );CHECK_ERR( rval ); return rval; }
void create_simple_grid | ( | Interface & | moab, |
unsigned | x, | ||
unsigned | y, | ||
unsigned | z | ||
Definition at line 196 of file pcomm_unit.cpp.
References CHECK_ERR, conn, moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, MBHEX, and z.
Referenced by create_simple_grid(), test_filter_pstatus(), test_pack_bit_tag_data(), test_pack_set_contents(), test_pack_sets_simple(), test_pack_tag_data_default_value(), test_pack_tag_data_dense(), test_pack_tag_data_sparse(), test_pack_tag_handle_data(), and test_pack_variable_length_tag().
{ ErrorCode rval; EntityHandle* verts = new EntityHandle[x * y * z]; for( unsigned k = 0; k < z; ++k ) for( unsigned j = 0; j < y; ++j ) for( unsigned i = 0; i < x; ++i ) { const double coords[3] = { static_cast< double >( i ), static_cast< double >( j ), static_cast< double >( k ) }; rval = moab.create_vertex( coords, verts[x * y * k + x * j + i] );CHECK_ERR( rval ); } EntityHandle* elems = new EntityHandle[( x - 1 ) * ( y - 1 ) * ( z - 1 )]; for( unsigned k = 0; k < ( z - 1 ); ++k ) for( unsigned j = 0; j < ( y - 1 ); ++j ) for( unsigned i = 0; i < ( x - 1 ); ++i ) { const size_t idx = (size_t)i + (size_t)j * x + (size_t)k * x * y; const EntityHandle conn[8] = { verts[idx], verts[idx + 1], verts[idx + x + 1], verts[idx + x], verts[idx + x * y], verts[idx + x * y + 1], verts[idx + x * y + x + 1], verts[idx + x * y + x] }; rval = moab.create_element( MBHEX, conn, 8, elems[( x - 1 ) * ( y - 1 ) * k + ( x - 1 ) * j + i] );CHECK_ERR( rval ); } delete[] verts; delete[] elems; }
unsigned | xyz = 3 |
Definition at line 192 of file pcomm_unit.cpp.
References create_simple_grid().
{ create_simple_grid( moab, xyz, xyz, xyz ); }
ErrorCode get_entities | ( | Interface * | mb, |
std::vector< EntityHandle > & | ent_verts, | ||
int | verts_per_entity, | ||
int | dim, | ||
Range & | ents | ||
Definition at line 1575 of file pcomm_unit.cpp.
References CHECK_ERR, moab::Range::clear(), ErrorCode, moab::Interface::get_adjacencies(), MB_SUCCESS, moab::Range::merge(), and moab::Range::size().
{ assert( !( ent_verts.size() % verts_per_entity ) ); unsigned int num_ents = ent_verts.size() / verts_per_entity; Range dum_ents; ErrorCode result; for( unsigned int i = 0; i < num_ents; i++ ) { result = mb->get_adjacencies( &ent_verts[verts_per_entity * i], verts_per_entity, dim, true, dum_ents );CHECK_ERR( result ); assert( dum_ents.size() == 1 ); ents.merge( dum_ents ); dum_ents.clear(); } return MB_SUCCESS; }
int main | ( | int | argc, |
char * | argv[] | ||
Definition at line 59 of file pcomm_unit.cpp.
References MPI_COMM_WORLD, rank, RUN_TEST, test_filter_pstatus(), test_new_pcomm_instance(), test_pack_elements(), test_pack_higher_order(), test_pack_poly(), test_pack_set_contents(), test_pack_set_parent_child(), test_pack_sets_of_sets(), test_pack_sets_simple(), test_pack_shared_entities_2d(), test_pack_shared_entities_3d(), test_pack_tag_data_default_value(), test_pack_tag_data_dense(), test_pack_tag_data_sparse(), test_pack_tag_handle_data(), test_pack_variable_length_tag(), and test_pack_vertices().
{ #ifdef MOAB_HAVE_MPI MPI_Init( &argc, &argv ); MPI_Comm_rank( MPI_COMM_WORLD, &rank ); #endif int num_err = 0; num_err += RUN_TEST( test_pack_vertices ); num_err += RUN_TEST( test_pack_elements ); num_err += RUN_TEST( test_pack_higher_order ); num_err += RUN_TEST( test_pack_poly ); num_err += RUN_TEST( test_pack_sets_simple ); num_err += RUN_TEST( test_pack_set_contents ); num_err += RUN_TEST( test_pack_sets_of_sets ); num_err += RUN_TEST( test_pack_set_parent_child ); num_err += RUN_TEST( test_pack_tag_data_sparse ); num_err += RUN_TEST( test_pack_tag_data_dense ); num_err += RUN_TEST( test_pack_tag_data_default_value ); // num_err += RUN_TEST( test_pack_bit_tag_data ); num_err += RUN_TEST( test_pack_variable_length_tag ); num_err += RUN_TEST( test_pack_tag_handle_data ); num_err += RUN_TEST( test_pack_shared_entities_2d ); num_err += RUN_TEST( test_pack_shared_entities_3d ); num_err += RUN_TEST( test_filter_pstatus ); num_err += RUN_TEST( test_new_pcomm_instance ); #ifdef MOAB_HAVE_MPI MPI_Finalize(); #endif return num_err; }
void pack_unpack_noremoteh | ( | Core & | moab, |
Range & | entities | ||
Definition at line 93 of file pcomm_unit.cpp.
References moab::Range::begin(), moab::ParallelComm::Buffer::buff_ptr, CHECK_ERR, moab::Range::clear(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Core::get_adjacencies(), moab::Core::get_entities_by_handle(), moab::ParallelComm::INITIAL_BUFF_SIZE, MBENTITYSET, moab::Range::merge(), MPI_COMM_WORLD, moab::ParallelComm::pack_buffer(), moab::ParallelComm::Buffer::reset_ptr(), moab::ParallelComm::Buffer::set_stored_size(), moab::Range::size(), moab::Range::subset_by_type(), moab::subtract(), moab::Interface::UNION, moab::ParallelComm::unpack_buffer(), and moab::Core::~Core().
Referenced by pack_unpack_noremoteh(), test_pack_bit_tag_data(), test_pack_elements(), test_pack_higher_order(), test_pack_poly(), test_pack_set_contents(), test_pack_set_parent_child(), test_pack_sets_of_sets(), test_pack_sets_simple(), test_pack_tag_data_default_value(), test_pack_tag_data_dense(), test_pack_tag_data_sparse(), test_pack_tag_handle_data(), test_pack_variable_length_tag(), and test_pack_vertices().
{ ErrorCode rval; if( entities.empty() ) { rval = moab.get_entities_by_handle( 0, entities );CHECK_ERR( rval ); } ParallelComm* pcomm = new ParallelComm( &moab, MPI_COMM_WORLD ); // get the necessary vertices too Range tmp_range = entities.subset_by_type( MBENTITYSET ); entities = subtract( entities, tmp_range ); rval = moab.get_adjacencies( entities, 0, false, entities, Interface::UNION );CHECK_ERR( rval ); entities.merge( tmp_range ); ParallelComm::Buffer buff( ParallelComm::INITIAL_BUFF_SIZE ); buff.reset_ptr( sizeof( int ) ); rval = pcomm->pack_buffer( entities, false, true, false, -1, &buff );CHECK_ERR( rval ); buff.set_stored_size(); delete pcomm; moab.~Core(); new( &moab ) Core(); pcomm = new ParallelComm( &moab, MPI_COMM_WORLD ); entities.clear(); std::vector< std::vector< EntityHandle > > L1hloc, L1hrem; std::vector< std::vector< int > > L1p; std::vector< EntityHandle > L2hloc, L2hrem; std::vector< unsigned int > L2p; buff.reset_ptr( sizeof( int ) ); std::vector< EntityHandle > entities_vec( entities.size() ); std::copy( entities.begin(), entities.end(), entities_vec.begin() ); rval = pcomm->unpack_buffer( buff.buff_ptr, false, -1, -1, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, entities_vec );CHECK_ERR( rval ); std::copy( entities_vec.begin(), entities_vec.end(), range_inserter( entities ) ); delete pcomm; }
void pack_unpack_noremoteh | ( | Core & | moab | ) |
Definition at line 133 of file pcomm_unit.cpp.
References pack_unpack_noremoteh().
{ Range empty; pack_unpack_noremoteh( moab, empty ); }
void test_filter_pstatus | ( | ) |
Test filter_pstatus function
Definition at line 1656 of file pcomm_unit.cpp.
References moab::Range::begin(), CHECK, CHECK_ERR, create_simple_grid(), ErrorCode, moab::Interface::get_entities_by_type(), moab::Range::insert(), MBVERTEX, MPI_COMM_WORLD, PSTATUS_AND, PSTATUS_GHOST, PSTATUS_INTERFACE, PSTATUS_MULTISHARED, PSTATUS_NOT, PSTATUS_NOT_OWNED, PSTATUS_SHARED, moab::Range::rbegin(), moab::Range::size(), and moab::Core::tag_set_data().
Referenced by main().
{ Range::iterator i; Core moab; Interface& mb = moab; ErrorCode rval; // create some mesh create_simple_grid( mb, 3 ); std::vector< EntityHandle > verts; Range dum_vertsr, vertsr; rval = mb.get_entities_by_type( 0, MBVERTEX, dum_vertsr );CHECK_ERR( rval ); vertsr.insert( dum_vertsr[0], dum_vertsr[8] ); for( int k = 0; k < 9; k++ ) verts.push_back( vertsr[k] ); CHECK( !verts.empty() ); ParallelComm* pcomm = new ParallelComm( &moab, MPI_COMM_WORLD ); std::vector< int > procs( 70, -1 ); for( int k = 0; k < 6; k++ ) procs[k] = k; std::vector< unsigned char > pvals( verts.size(), 0 ); // interface, owned pvals[0] = ( PSTATUS_INTERFACE | PSTATUS_SHARED ); // p0 rval = moab.tag_set_data( pcomm->sharedp_tag(), &verts[0], 1, &procs[0] );CHECK_ERR( rval ); // interface, not owned pvals[1] = ( PSTATUS_NOT_OWNED | PSTATUS_INTERFACE | PSTATUS_SHARED ); // p1 rval = moab.tag_set_data( pcomm->sharedp_tag(), &verts[1], 1, &procs[1] );CHECK_ERR( rval ); // interface, multi-shared, owned pvals[2] = ( PSTATUS_INTERFACE | PSTATUS_SHARED | PSTATUS_MULTISHARED ); // p0, p1 rval = moab.tag_set_data( pcomm->sharedps_tag(), &verts[2], 1, &procs[0] );CHECK_ERR( rval ); // interface, multi-shared, not owned pvals[3] = ( PSTATUS_INTERFACE | PSTATUS_MULTISHARED | PSTATUS_NOT_OWNED | PSTATUS_SHARED ); // p1, p2 rval = moab.tag_set_data( pcomm->sharedps_tag(), &verts[3], 1, &procs[1] );CHECK_ERR( rval ); // ghost, shared pvals[4] = ( PSTATUS_GHOST | PSTATUS_SHARED | PSTATUS_NOT_OWNED ); // p2 rval = moab.tag_set_data( pcomm->sharedp_tag(), &verts[4], 1, &procs[2] );CHECK_ERR( rval ); // ghost, multi-shared pvals[5] = ( PSTATUS_GHOST | PSTATUS_MULTISHARED | PSTATUS_NOT_OWNED | PSTATUS_SHARED ); // p2, p3 rval = moab.tag_set_data( pcomm->sharedps_tag(), &verts[5], 1, &procs[2] );CHECK_ERR( rval ); // owned, shared pvals[6] = ( PSTATUS_SHARED ); // p4 rval = moab.tag_set_data( pcomm->sharedp_tag(), &verts[6], 1, &procs[4] );CHECK_ERR( rval ); // owned, multi-shared pvals[7] = ( PSTATUS_MULTISHARED | PSTATUS_SHARED ); // p4, p5 rval = moab.tag_set_data( pcomm->sharedps_tag(), &verts[7], 1, &procs[4] );CHECK_ERR( rval ); // not shared, owned pvals[8] = 0x0; rval = moab.tag_set_data( pcomm->pstatus_tag(), &verts[0], 9, &pvals[0] );CHECK_ERR( rval ); Range tmp_range = vertsr; // interface ents rval = pcomm->filter_pstatus( tmp_range, PSTATUS_INTERFACE, PSTATUS_AND );CHECK_ERR( rval ); CHECK( tmp_range.size() == 4 && *tmp_range.begin() == verts[0] && *tmp_range.rbegin() == verts[3] ); // not interface tmp_range = vertsr; rval = pcomm->filter_pstatus( tmp_range, PSTATUS_INTERFACE, PSTATUS_NOT );CHECK_ERR( rval ); CHECK( tmp_range.size() == 5 && *tmp_range.begin() == verts[4] && *tmp_range.rbegin() == verts[8] ); // interface not owned tmp_range = vertsr; rval = pcomm->filter_pstatus( tmp_range, PSTATUS_INTERFACE | PSTATUS_NOT_OWNED, PSTATUS_AND );CHECK_ERR( rval ); CHECK( tmp_range.size() == 2 && *tmp_range.begin() == verts[1] && *tmp_range.rbegin() == verts[3] ); // ghost tmp_range = vertsr; rval = pcomm->filter_pstatus( tmp_range, PSTATUS_GHOST, PSTATUS_AND );CHECK_ERR( rval ); CHECK( tmp_range.size() == 2 && *tmp_range.begin() == verts[4] && *tmp_range.rbegin() == verts[5] ); // shared not multi-shared tmp_range = vertsr; rval = pcomm->filter_pstatus( tmp_range, PSTATUS_SHARED, PSTATUS_AND );CHECK_ERR( rval ); rval = pcomm->filter_pstatus( tmp_range, PSTATUS_MULTISHARED, PSTATUS_NOT );CHECK_ERR( rval ); CHECK( tmp_range.size() == 4 && tmp_range[0] == verts[0] && tmp_range[1] == verts[1] && tmp_range[2] == verts[4] && tmp_range[3] == verts[6] ); // shared w/ p0 tmp_range = vertsr; rval = pcomm->filter_pstatus( tmp_range, PSTATUS_SHARED, PSTATUS_AND, 0 );CHECK_ERR( rval ); CHECK( tmp_range.size() == 2 && tmp_range[1] == verts[2] ); // shared w/ p2 && not owned tmp_range = vertsr; rval = pcomm->filter_pstatus( tmp_range, PSTATUS_SHARED | PSTATUS_NOT_OWNED, PSTATUS_AND, 2 );CHECK_ERR( rval ); CHECK( tmp_range.size() == 3 && tmp_range[0] == verts[3] && tmp_range[1] == verts[4] && tmp_range[2] == verts[5] ); delete pcomm; }
void test_new_pcomm_instance | ( | ) |
Test creating a new ParallelComm instance in addition to an existing one
Definition at line 1745 of file pcomm_unit.cpp.
References CHECK_ERR, ErrorCode, example, moab::Interface::load_file(), MPI_COMM_WORLD, and read_options.
{ #if defined( MOAB_HAVE_MPI ) && defined( MOAB_HAVE_HDF5 ) Core moab; Interface& mb = moab; // This parallel read will create a ParallelComm instance implicitly std::string example = TestDir + "unittest/64bricks_1khex.h5m"; std::string read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS"; ErrorCode rval = mb.load_file( example.c_str(), 0, read_options.c_str() );CHECK_ERR( rval ); // It is highly recommended to reuse existing ParallelComm instance with // ParallelComm::get_pcomm() Creating a new ParallelComm instance should still be allowed, // anyway ParallelComm* pcomm = new moab::ParallelComm( &moab, MPI_COMM_WORLD ); // Do something with pcomm // ... delete pcomm; #endif }
void test_pack_bit_tag_data | ( | ) |
Test pack/unpack tag values
Definition at line 1312 of file pcomm_unit.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), create_simple_grid(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), mb, MB_TAG_BIT, MB_TAG_EXCL, MB_TYPE_BIT, MBVERTEX, pack_unpack_noremoteh(), size, moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), moab::Interface::tag_set_data(), and TagType.
{ Range::iterator i; Core moab; Interface& mb = moab; ErrorCode rval; // create some mesh create_simple_grid( mb, 3 ); Range verts; rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); CHECK( !verts.empty() ); // Create a bit tag const char tag_name[] = "test bit"; Tag tag; rval = mb.tag_get_handle( tag_name, 3, MB_TYPE_BIT, tag, MB_TAG_EXCL );CHECK_ERR( rval ); // Set bits to 1 unless cooresponding coordinate of // vertex is zero. for( i = verts.begin(); i != verts.end(); ++i ) { double coords[3]; rval = mb.get_coords( &*i, 1, coords );CHECK_ERR( rval ); unsigned char data = 0; for( int j = 0; j < 3; ++j ) if( fabs( coords[j] ) > 1e-6 ) data |= ( 1 << j ); rval = mb.tag_set_data( tag, &*i, 1, &data );CHECK_ERR( rval ); } // pack and unpack Range ents; pack_unpack_noremoteh( moab, ents ); verts.clear(); rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); // check tag meta rval = mb.tag_get_handle( tag_name, 3, MB_TYPE_BIT, tag );CHECK_ERR( rval ); int size; rval = mb.tag_get_length( tag, size );CHECK_ERR( rval ); CHECK_EQUAL( 3, size ); TagType storage; rval = mb.tag_get_type( tag, storage );CHECK_ERR( rval ); CHECK_EQUAL( MB_TAG_BIT, storage ); DataType type; rval = mb.tag_get_data_type( tag, type ); CHECK_EQUAL( MB_TYPE_BIT, type ); // check tag values for( i = verts.begin(); i != verts.end(); ++i ) { double coords[3]; rval = mb.get_coords( &*i, 1, coords );CHECK_ERR( rval ); unsigned char expected = 0; for( int j = 0; j < 3; ++j ) if( fabs( coords[j] ) > 1e-6 ) expected |= ( 1 << j ); unsigned char data = (unsigned char)0xFF; rval = mb.tag_get_data( tag, &*i, 1, &data );CHECK_ERR( rval ); CHECK_EQUAL( (int)expected, (int)data ); } }
void test_pack_elements | ( | ) |
Test pack/unpack of elements
Definition at line 450 of file pcomm_unit.cpp.
References moab::Range::back(), CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, check_sizes(), moab::Range::clear(), moab::Core::create_element(), moab::Core::create_vertex(), ErrorCode, moab::Range::front(), moab::Core::get_connectivity(), moab::Core::get_coords(), moab::Core::get_entities_by_type(), hex_corners, moab::Range::insert(), MBHEX, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, pack_unpack_noremoteh(), moab::Range::size(), and swap().
{ Core moab; ErrorCode rval; Range elems; // define some vertices const size_t num_verts = 12; EntityHandle verts[num_verts]; const double hex_corners[3 * num_verts] = { -1, -1, -1, 1, -1, -1, 1, 1, -1, -1, 1, -1, -1, -1, 0, 1, -1, 0, 1, 1, 0, -1, 1, 0, -1, -1, 1, 1, -1, 1, 1, 1, 1, -1, 1, 1 }; for( size_t i = 0; i < num_verts; ++i ) { rval = moab.create_vertex( hex_corners + 3 * i, verts[i] );CHECK_ERR( rval ); } // define two adjacent hexes const size_t num_hex = 2; EntityHandle hexes[num_hex]; rval = moab.create_element( MBHEX, verts, 8, hexes[0] );CHECK_ERR( rval ); elems.insert( hexes[0] ); rval = moab.create_element( MBHEX, verts + 4, 8, hexes[1] );CHECK_ERR( rval ); elems.insert( hexes[1] ); // define a single quad on the adjacent sides of the hexes const size_t num_quad = 1; EntityHandle quad; rval = moab.create_element( MBQUAD, verts + 4, 4, quad );CHECK_ERR( rval ); elems.insert( quad ); // define a decomposition of the first hex into 5 tets const size_t num_tet = 5; EntityHandle tets[num_tet]; EntityHandle tet_conn[num_tet][4] = { { verts[0], verts[1], verts[3], verts[4] }, { verts[1], verts[2], verts[3], verts[6] }, { verts[1], verts[3], verts[4], verts[6] }, { verts[4], verts[6], verts[5], verts[1] }, { verts[7], verts[6], verts[4], verts[3] } }; rval = moab.create_element( MBTET, tet_conn[0], 4, tets[0] );CHECK_ERR( rval ); elems.insert( tets[0] ); rval = moab.create_element( MBTET, tet_conn[1], 4, tets[1] );CHECK_ERR( rval ); elems.insert( tets[1] ); rval = moab.create_element( MBTET, tet_conn[2], 4, tets[2] );CHECK_ERR( rval ); elems.insert( tets[2] ); rval = moab.create_element( MBTET, tet_conn[3], 4, tets[3] );CHECK_ERR( rval ); elems.insert( tets[3] ); rval = moab.create_element( MBTET, tet_conn[4], 4, tets[4] );CHECK_ERR( rval ); elems.insert( tets[4] ); // define the 4 shared faces of the above tets as tris // (the faces of the 3rd tet) const size_t num_tri = 4; EntityHandle tris[num_tri]; EntityHandle tri_conn[num_tri][3] = { { verts[3], verts[1], verts[4] }, { verts[1], verts[6], verts[4] }, { verts[1], verts[3], verts[6] }, { verts[3], verts[4], verts[6] } }; rval = moab.create_element( MBTRI, tri_conn[0], 3, tris[0] );CHECK_ERR( rval ); elems.insert( tris[0] ); rval = moab.create_element( MBTRI, tri_conn[1], 3, tris[1] );CHECK_ERR( rval ); elems.insert( tris[1] ); rval = moab.create_element( MBTRI, tri_conn[2], 3, tris[2] );CHECK_ERR( rval ); elems.insert( tris[2] ); rval = moab.create_element( MBTRI, tri_conn[3], 3, tris[3] );CHECK_ERR( rval ); elems.insert( tris[3] ); // define a decomposition of the second hex into two wedges const size_t num_wedge = 2; EntityHandle wedges[num_wedge]; EntityHandle wedge_conn[num_wedge][6] = { { verts[4], verts[5], verts[7], verts[8], verts[9], verts[11] }, { verts[5], verts[6], verts[7], verts[9], verts[10], verts[11] } }; rval = moab.create_element( MBPRISM, wedge_conn[0], 6, wedges[0] );CHECK_ERR( rval ); elems.insert( wedges[0] ); rval = moab.create_element( MBPRISM, wedge_conn[1], 6, wedges[1] );CHECK_ERR( rval ); elems.insert( wedges[1] ); // define a pyramid EntityHandle pyr; rval = moab.create_element( MBPYRAMID, verts, 5, pyr );CHECK_ERR( rval ); elems.insert( pyr ); // pack and unpack mesh pack_unpack_noremoteh( moab, elems ); // check_counts check_sizes( moab, num_verts, 0, num_tri, num_quad, 0, num_tet, 1, num_wedge, 0, num_hex, 0 ); // get connectivity for two hexes and a quad Range range; const EntityHandle *conn1, *conn2, *conn3; int len1, len2, len3; rval = moab.get_entities_by_type( 0, MBHEX, range );CHECK_ERR( rval ); CHECK_EQUAL( num_hex, range.size() ); rval = moab.get_connectivity( range.front(), conn1, len1, true );CHECK_ERR( rval ); CHECK_EQUAL( 8, len1 ); rval = moab.get_connectivity( range.back(), conn2, len2, true );CHECK_ERR( rval ); CHECK_EQUAL( 8, len2 ); range.clear(); rval = moab.get_entities_by_type( 0, MBQUAD, range );CHECK_ERR( rval ); CHECK_EQUAL( num_quad, range.size() ); rval = moab.get_connectivity( range.front(), conn3, len3, true );CHECK_ERR( rval ); CHECK_EQUAL( 4, len3 ); // Check if hexes are reversed if( conn1[0] == conn2[4] ) { std::swap( conn1, conn2 ); } // Check consistant connectivity between hexes CHECK_EQUAL( conn1[4], conn2[0] ); CHECK_EQUAL( conn1[5], conn2[1] ); CHECK_EQUAL( conn1[6], conn2[2] ); CHECK_EQUAL( conn1[7], conn2[3] ); // Check connectivity of quad on shared face CHECK_EQUAL( conn1[4], conn3[0] ); CHECK_EQUAL( conn1[5], conn3[1] ); CHECK_EQUAL( conn1[6], conn3[2] ); CHECK_EQUAL( conn1[7], conn3[3] ); // Check coordinates const EntityHandle combined[12] = { conn1[0], conn1[1], conn1[2], conn1[3], conn3[0], conn3[1], conn3[2], conn3[3], conn2[4], conn2[5], conn2[6], conn2[7] }; double coords[36]; rval = moab.get_coords( combined, 12, coords );CHECK_ERR( rval ); for( int i = 0; i < 36; ++i ) { CHECK_REAL_EQUAL( hex_corners[i], coords[i], 1e-12 ); } }
void test_pack_higher_order | ( | ) |
Test pack/unpack of higher-order elements
Definition at line 580 of file pcomm_unit.cpp.
References moab::Range::back(), CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, check_sizes(), moab::Range::clear(), moab::Core::create_element(), moab::Core::create_vertex(), ErrorCode, moab::Range::front(), moab::Core::get_connectivity(), moab::Core::get_coords(), moab::Core::get_entities_by_type(), moab::Range::insert(), MBTET, MBTRI, pack_unpack_noremoteh(), moab::Range::size(), and swap().
{ Core moab; ErrorCode rval; Range elems; // define coordinates for a pyramid decomposed // into two 10-node tets const size_t num_vert = 14; const double coords[3 * num_vert] = { -1, -1, 0, 0, -1, 0, 1, -1, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0, -1, 1, 0, -1, 0, 0, 0, 0, 0, 0, 0, 1, -.5, -.5, .5, .5, -.5, .5, .5, .5, .5, -.5, .5, .5 }; EntityHandle verts[num_vert]; for( size_t i = 0; i < num_vert; ++i ) { rval = moab.create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( rval ); } // define two tets const size_t num_tet = 2; EntityHandle tet_conn[2][10] = { { verts[0], verts[4], verts[9], verts[2], verts[8], verts[12], verts[10], verts[1], verts[3], verts[11] }, { verts[0], verts[9], verts[4], verts[6], verts[10], verts[12], verts[8], verts[7], verts[13], verts[5] } }; EntityHandle tets[num_tet]; rval = moab.create_element( MBTET, tet_conn[0], 10, tets[0] );CHECK_ERR( rval ); elems.insert( tets[0] ); rval = moab.create_element( MBTET, tet_conn[1], 10, tets[1] );CHECK_ERR( rval ); elems.insert( tets[1] ); // define interior tri face const size_t num_tri = 1; EntityHandle tri_conn[6] = { verts[0], verts[4], verts[9], verts[8], verts[12], verts[10] }; EntityHandle tri; rval = moab.create_element( MBTRI, tri_conn, 6, tri );CHECK_ERR( rval ); elems.insert( tri ); // pack and unpack mesh pack_unpack_noremoteh( moab, elems ); // check_counts check_sizes( moab, num_vert, 0, num_tri, 0, 0, num_tet, 0, 0, 0, 0, 0 ); // get connectivity for two tets and a tri Range range; const EntityHandle *conn1, *conn2, *conn3; int len1, len2, len3; rval = moab.get_entities_by_type( 0, MBTET, range );CHECK_ERR( rval ); CHECK_EQUAL( num_tet, range.size() ); rval = moab.get_connectivity( range.front(), conn1, len1, false );CHECK_ERR( rval ); CHECK_EQUAL( 10, len1 ); rval = moab.get_connectivity( range.back(), conn2, len2, false );CHECK_ERR( rval ); CHECK_EQUAL( 10, len2 ); range.clear(); rval = moab.get_entities_by_type( 0, MBTRI, range );CHECK_ERR( rval ); CHECK_EQUAL( num_tri, range.size() ); rval = moab.get_connectivity( range.front(), conn3, len3, false );CHECK_ERR( rval ); CHECK_EQUAL( 6, len3 ); // The first face of one of the tets is in the // same order as the tri. if( conn3[1] != conn1[1] ) std::swap( conn1, conn2 ); // check consistant connectivity for face shared by tets CHECK_EQUAL( conn1[0], conn2[0] ); CHECK_EQUAL( conn1[1], conn2[2] ); CHECK_EQUAL( conn1[2], conn2[1] ); CHECK_EQUAL( conn1[4], conn2[6] ); CHECK_EQUAL( conn1[5], conn2[5] ); CHECK_EQUAL( conn1[6], conn2[4] ); // check connsistant connectivity between tet face and tri CHECK_EQUAL( conn1[0], conn3[0] ); CHECK_EQUAL( conn1[1], conn3[1] ); CHECK_EQUAL( conn1[2], conn3[2] ); CHECK_EQUAL( conn1[4], conn3[3] ); CHECK_EQUAL( conn1[5], conn3[4] ); CHECK_EQUAL( conn1[6], conn3[5] ); // order vertex handles corresponding to original coordinate list const EntityHandle combined[num_vert] = { conn1[0], conn1[7], conn1[3], conn1[8], conn1[1], conn2[9], conn2[3], conn2[7], conn1[4], conn1[2], conn1[6], conn1[9], conn1[5], conn2[8] }; double coords2[3 * num_vert]; rval = moab.get_coords( combined, num_vert, coords2 );CHECK_ERR( rval ); // check vertex coordinates for( int i = 0; i < 36; ++i ) { CHECK_REAL_EQUAL( coords[i], coords2[i], 1e-12 ); } }
void test_pack_poly | ( | ) |
Test pack/unpack of polygons & polyhedra
Definition at line 671 of file pcomm_unit.cpp.
References b, moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, check_sizes(), moab::Range::clear(), conn, moab::Core::create_element(), moab::Core::create_vertex(), moab::Range::end(), ErrorCode, moab::Range::front(), moab::Core::get_connectivity(), moab::Core::get_coords(), moab::Core::get_entities_by_type(), moab::Range::insert(), MBPOLYGON, MBPOLYHEDRON, MBTRI, pack_unpack_noremoteh(), and moab::Range::size().
{ Core moab; ErrorCode rval; Range elems; // define a pyramid w/ a octagonal base const double a = 0.5; const double b = 1 + sqrt( 2.0 ) / 2.0; const size_t num_vert = 9; const double coords[3 * num_vert] = { -a, -b, 0, a, -b, 0, b, -a, 0, b, a, 0, a, b, 0, -a, b, 0, -b, a, 0, -b, -a, 0, 0, 0, 1 }; EntityHandle verts[num_vert]; for( size_t i = 0; i < num_vert; ++i ) { rval = moab.create_vertex( coords + 3 * i, verts[i] );CHECK_ERR( rval ); } // define octagonal base const size_t num_polygon = 1; EntityHandle octagon; rval = moab.create_element( MBPOLYGON, verts, 8, octagon );CHECK_ERR( rval ); // define triangular sides const size_t num_tri = num_vert - 1; EntityHandle tri[num_tri]; for( size_t i = 0; i < num_tri; ++i ) { const EntityHandle conn[3] = { verts[i], verts[( i + 1 ) % num_tri], verts[num_tri] }; rval = moab.create_element( MBTRI, conn, 3, tri[i] );CHECK_ERR( rval ); } // define the octagon-based pyramid const size_t num_polyhedron = 1; EntityHandle polyhedron; EntityHandle all_faces[num_vert]; all_faces[0] = octagon; std::copy( tri, tri + num_tri, all_faces + 1 ); rval = moab.create_element( MBPOLYHEDRON, all_faces, num_vert, polyhedron );CHECK_ERR( rval ); // pack and unpack the mesh elems.clear(); elems.insert( polyhedron ); elems.insert( octagon ); std::copy( tri, tri + num_tri, range_inserter( elems ) ); pack_unpack_noremoteh( moab, elems ); // check counts check_sizes( moab, num_vert, 0, num_tri, 0, num_polygon, 0, 0, 0, 0, 0, num_polyhedron ); // get entities Range range; rval = moab.get_entities_by_type( 0, MBPOLYHEDRON, range );CHECK_ERR( rval ); CHECK_EQUAL( num_polyhedron, range.size() ); polyhedron = range.front(); range.clear(); rval = moab.get_entities_by_type( 0, MBPOLYGON, range );CHECK_ERR( rval ); CHECK_EQUAL( num_polygon, range.size() ); octagon = range.front(); range.clear(); rval = moab.get_entities_by_type( 0, MBTRI, range );CHECK_ERR( rval ); CHECK_EQUAL( num_tri, range.size() ); // check coords of octagon vertices const EntityHandle* oct_conn; int eight = 0; rval = moab.get_connectivity( octagon, oct_conn, eight );CHECK_ERR( rval ); CHECK_EQUAL( 8, eight ); double oct_coords[3 * 8]; rval = moab.get_coords( oct_conn, 8, oct_coords );CHECK_ERR( rval ); for( int i = 0; i < 3 * 8; ++i ) { CHECK_REAL_EQUAL( coords[i], oct_coords[i], 1e-12 ); } // check faces of polyhedron std::vector< EntityHandle > volconn; rval = moab.get_connectivity( &polyhedron, 1, volconn );CHECK_ERR( rval ); CHECK_EQUAL( num_tri + 1, volconn.size() ); CHECK_EQUAL( volconn[0], octagon ); for( Range::iterator i = range.begin(); i != range.end(); ++i ) { CHECK( std::find( volconn.begin(), volconn.end(), *i ) != volconn.end() ); } }
void test_pack_set_contents | ( | ) |
Test pack/unpack of entity sets including implicit packing of set contents
Definition at line 883 of file pcomm_unit.cpp.
References moab::Core::add_entities(), CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Core::create_meshset(), create_simple_grid(), moab::Core::delete_entities(), moab::Range::empty(), entities, ErrorCode, moab::Range::front(), moab::Core::get_entities_by_type(), moab::Range::insert(), MBENTITYSET, MBVERTEX, MESHSET_SET, pack_unpack_noremoteh(), and moab::Range::size().
{ Core moab; ErrorCode rval; create_simple_grid( moab, 3 ); // delete any existing sets Range sets; rval = moab.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval ); if( !sets.empty() ) { rval = moab.delete_entities( sets );CHECK_ERR( rval ); } // get all vertices Range vertices; rval = moab.get_entities_by_type( 0, MBVERTEX, vertices );CHECK_ERR( rval ); CHECK_EQUAL( 27, (int)vertices.size() ); // create meshset containing vertices EntityHandle set; rval = moab.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); rval = moab.add_entities( set, vertices );CHECK_ERR( rval ); // pack and unpack range containing only set handle. // Will fail unless we also pass in set contents explicitly Range entities( vertices ); entities.insert( set ); pack_unpack_noremoteh( moab, entities ); // expect single set in mesh entities.clear(); rval = moab.get_entities_by_type( 0, MBENTITYSET, entities );CHECK_ERR( rval ); CHECK_EQUAL( 1, (int)entities.size() ); set = entities.front(); // expect 27 vertices in mesh vertices.clear(); rval = moab.get_entities_by_type( 0, MBVERTEX, vertices );CHECK_ERR( rval ); CHECK_EQUAL( 27, (int)vertices.size() ); // expect set to contain all 27 vertices vertices.clear(); rval = moab.get_entities_by_type( set, MBVERTEX, vertices );CHECK_ERR( rval ); CHECK_EQUAL( 27, (int)vertices.size() ); }
void test_pack_set_parent_child | ( | ) |
Test pack/unpack of set parent/child relations
Definition at line 1008 of file pcomm_unit.cpp.
References moab::Core::add_child_meshset(), moab::Core::add_parent_child(), moab::Core::add_parent_meshset(), moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, children, moab::Range::clear(), moab::Core::create_meshset(), moab::Core::delete_entities(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Core::get_child_meshsets(), moab::Core::get_entities_by_type(), moab::Core::get_parent_meshsets(), moab::Range::insert(), MB_SUCCESS, MBENTITYSET, MESHSET_SET, moab::Core::num_child_meshsets(), moab::Core::num_parent_meshsets(), pack_unpack_noremoteh(), and moab::Range::size().
{ Core moab; ErrorCode rval; // delete any existing sets Range sets; rval = moab.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval ); if( !sets.empty() ) { rval = moab.delete_entities( sets );CHECK_ERR( rval ); } // create three sets such that set3 has a child link to // set1, set2 has a parent link to set1, and such that set3 and // set2 are parent and child, respectively. EntityHandle set1, set2, set3; sets.clear(); rval = moab.create_meshset( MESHSET_ORDERED, set1 );CHECK_ERR( rval ); sets.insert( set1 ); rval = moab.create_meshset( MESHSET_SET, set2 );CHECK_ERR( rval ); sets.insert( set2 ); rval = moab.create_meshset( MESHSET_SET, set3 );CHECK_ERR( rval ); sets.insert( set3 ); rval = moab.add_child_meshset( set3, set1 );CHECK_ERR( rval ); rval = moab.add_parent_meshset( set2, set1 );CHECK_ERR( rval ); rval = moab.add_parent_child( set3, set2 );CHECK_ERR( rval ); // make sure everything is valid before doing the pack/unpack int count; rval = moab.num_child_meshsets( set1, &count ); CHECK( MB_SUCCESS == rval && 0 == count ); rval = moab.num_child_meshsets( set2, &count ); CHECK( MB_SUCCESS == rval && 0 == count ); rval = moab.num_child_meshsets( set3, &count ); CHECK( MB_SUCCESS == rval && 2 == count ); rval = moab.num_parent_meshsets( set1, &count ); CHECK( MB_SUCCESS == rval && 0 == count ); rval = moab.num_parent_meshsets( set2, &count ); CHECK( MB_SUCCESS == rval && 2 == count ); rval = moab.num_parent_meshsets( set3, &count ); CHECK( MB_SUCCESS == rval && 0 == count ); // pack and unpack pack_unpack_noremoteh( moab, sets ); // get sets sets.clear(); rval = moab.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval ); CHECK_EQUAL( 3, (int)sets.size() ); // look for a set with two child links (set3) set1 = set2 = set3 = 0; for( Range::iterator i = sets.begin(); i != sets.end(); ++i ) { int mcount; rval = moab.num_child_meshsets( *i, &mcount );CHECK_ERR( rval ); if( mcount == 2 ) { set3 = *i; break; } } CHECK( 0 != set3 ); // check set relations std::vector< EntityHandle > parents, children; rval = moab.get_child_meshsets( set3, children );CHECK_ERR( rval ); CHECK_EQUAL( (std::vector< EntityHandle >::size_type)2, children.size() ); set1 = children[0]; set2 = children[1]; rval = moab.get_parent_meshsets( set1, parents );CHECK_ERR( rval ); CHECK( parents.empty() ); children.clear(); rval = moab.get_parent_meshsets( set1, children );CHECK_ERR( rval ); CHECK( children.empty() ); rval = moab.get_parent_meshsets( set2, parents );CHECK_ERR( rval ); CHECK_EQUAL( (std::vector< EntityHandle >::size_type)2, parents.size() ); CHECK_EQUAL( set1, parents[0] ); CHECK_EQUAL( set3, parents[1] ); }
void test_pack_sets_of_sets | ( | ) |
Test pack/unpack of entity sets containing entity sets
Definition at line 929 of file pcomm_unit.cpp.
References moab::Core::add_entities(), moab::Range::back(), moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Core::create_meshset(), moab::Core::delete_entities(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Range::front(), moab::Core::get_entities_by_type(), moab::Core::get_number_entities_by_type(), moab::Range::insert(), MBENTITYSET, MESHSET_SET, pack_unpack_noremoteh(), and moab::Range::size().
{ Core moab; ErrorCode rval; // delete any existing sets Range sets; rval = moab.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval ); if( !sets.empty() ) { rval = moab.delete_entities( sets );CHECK_ERR( rval ); } // create three sets such that set2 contains set1, and set3 contains // both set1 and set2 EntityHandle set1, set2, set3; sets.clear(); rval = moab.create_meshset( MESHSET_ORDERED, set1 );CHECK_ERR( rval ); sets.insert( set1 ); rval = moab.create_meshset( MESHSET_SET, set2 );CHECK_ERR( rval ); rval = moab.add_entities( set2, sets );CHECK_ERR( rval ); sets.insert( set2 ); rval = moab.create_meshset( MESHSET_SET, set3 );CHECK_ERR( rval ); rval = moab.add_entities( set3, sets );CHECK_ERR( rval ); sets.insert( set3 ); // pack and unpack pack_unpack_noremoteh( moab, sets ); // get sets sets.clear(); rval = moab.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval ); CHECK_EQUAL( 3, (int)sets.size() ); // figure out which is which set1 = set2 = set3 = 0; for( Range::iterator i = sets.begin(); i != sets.end(); ++i ) { int count; rval = moab.get_number_entities_by_type( *i, MBENTITYSET, count );CHECK_ERR( rval ); CHECK( count >= 0 && count <= 2 ); switch( count ) { case 0: CHECK_EQUAL( (EntityHandle)0, set1 ); set1 = *i; break; case 1: CHECK_EQUAL( (EntityHandle)0, set2 ); set2 = *i; break; case 2: CHECK_EQUAL( (EntityHandle)0, set3 ); set3 = *i; break; } } // check that set2 contains set1 sets.clear(); rval = moab.get_entities_by_type( set2, MBENTITYSET, sets );CHECK_ERR( rval ); CHECK_EQUAL( 1, (int)sets.size() ); CHECK_EQUAL( set1, sets.front() ); // check that set3 contains set1 and set2 sets.clear(); rval = moab.get_entities_by_type( set3, MBENTITYSET, sets );CHECK_ERR( rval ); CHECK_EQUAL( 2, (int)sets.size() ); if( sets.front() == set1 ) { CHECK_EQUAL( set2, sets.back() ); } else { CHECK_EQUAL( set2, sets.front() ); CHECK_EQUAL( set1, sets.back() ); } }
void test_pack_sets_simple | ( | ) |
Definition at line 759 of file pcomm_unit.cpp.
References moab::Core::add_entities(), moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Core::create_meshset(), create_simple_grid(), moab::Core::delete_entities(), moab::Range::empty(), moab::Range::end(), entities, ErrorCode, moab::Range::front(), moab::Core::get_entities_by_handle(), moab::Core::get_entities_by_type(), moab::Core::get_meshset_options(), moab::Core::get_number_entities_by_type(), moab::Range::insert(), MBENTITYSET, MBHEX, MBVERTEX, moab::Range::merge(), MESHSET_SET, MESHSET_TRACK_OWNER, moab::Range::num_of_type(), pack_unpack_noremoteh(), moab::Range::size(), and u.
{ Core moab; ErrorCode rval; create_simple_grid( moab, 3 ); // delete any existing sets Range sets; rval = moab.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval ); if( !sets.empty() ) { rval = moab.delete_entities( sets );CHECK_ERR( rval ); } // get all entities Range entities; rval = moab.get_entities_by_handle( 0, entities );CHECK_ERR( rval ); // expect 8 elements and 27 vertices CHECK_EQUAL( 35, (int)entities.size() ); CHECK_EQUAL( 27u, entities.num_of_type( MBVERTEX ) ); CHECK_EQUAL( 8u, entities.num_of_type( MBHEX ) ); // create five sets: // 1) one with all the elements and vertices, // 2) one with half of the elements, // 3) one with the other half of the elements, // 4) one with a single vertex, // 5) an empty set, EntityHandle all_set, half1_set, half2_set, vertex_set, empty_set; const unsigned int all_opt = MESHSET_SET | MESHSET_TRACK_OWNER, half1_opt = MESHSET_SET, half2_opt = MESHSET_SET, vertex_opt = MESHSET_ORDERED, empty_opt = MESHSET_ORDERED | MESHSET_TRACK_OWNER; rval = moab.create_meshset( all_opt, all_set );CHECK_ERR( rval ); entities.insert( all_set ); rval = moab.create_meshset( half1_opt, half1_set );CHECK_ERR( rval ); entities.insert( half1_set ); rval = moab.create_meshset( half2_opt, half2_set );CHECK_ERR( rval ); entities.insert( half2_set ); rval = moab.create_meshset( vertex_opt, vertex_set );CHECK_ERR( rval ); entities.insert( vertex_set ); rval = moab.create_meshset( empty_opt, empty_set );CHECK_ERR( rval ); entities.insert( empty_set ); Range elems, verts, half; rval = moab.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); rval = moab.get_entities_by_type( 0, MBHEX, elems );CHECK_ERR( rval ); rval = moab.add_entities( all_set, verts );CHECK_ERR( rval ); rval = moab.add_entities( all_set, elems );CHECK_ERR( rval ); half.merge( elems.begin(), elems.begin() += elems.size() / 2 ); rval = moab.add_entities( half1_set, half );CHECK_ERR( rval ); half.clear(); half.merge( elems.begin() += elems.size() / 2, elems.end() ); rval = moab.add_entities( half2_set, half );CHECK_ERR( rval ); EntityHandle vert = verts.front(); rval = moab.add_entities( vertex_set, &vert, 1 );CHECK_ERR( rval ); // do pack and unpack pack_unpack_noremoteh( moab, entities ); // get entities by type verts.clear(); rval = moab.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); elems.clear(); rval = moab.get_entities_by_type( 0, MBHEX, elems );CHECK_ERR( rval ); sets.clear(); rval = moab.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval ); CHECK_EQUAL( 27, (int)verts.size() ); CHECK_EQUAL( 8, (int)elems.size() ); CHECK_EQUAL( 5, (int)sets.size() ); // guess which is which empty_set = all_set = vertex_set = half1_set = half2_set = 0; for( Range::iterator i = sets.begin(); i != sets.end(); ++i ) { int num_vtx, num_elem; rval = moab.get_number_entities_by_type( *i, MBVERTEX, num_vtx );CHECK_ERR( rval ); rval = moab.get_number_entities_by_type( *i, MBHEX, num_elem );CHECK_ERR( rval ); if( num_vtx == 0 ) { if( num_elem == 0 ) { CHECK_EQUAL( (EntityHandle)0, empty_set ); empty_set = *i; } else if( !half1_set ) { half1_set = *i; } else { CHECK_EQUAL( (EntityHandle)0, half2_set ); half2_set = *i; } } else if( num_vtx == 1 ) { CHECK_EQUAL( 0, num_elem ); CHECK_EQUAL( (EntityHandle)0, vertex_set ); vertex_set = *i; } else { CHECK_EQUAL( 8, num_elem ); CHECK_EQUAL( 27, num_vtx ); CHECK_EQUAL( (EntityHandle)0, all_set ); all_set = *i; } } // check set options unsigned opt; rval = moab.get_meshset_options( all_set, opt );CHECK_ERR( rval ); CHECK_EQUAL( all_opt, opt ); rval = moab.get_meshset_options( half1_set, opt );CHECK_ERR( rval ); CHECK_EQUAL( half1_opt, opt ); rval = moab.get_meshset_options( half2_set, opt );CHECK_ERR( rval ); CHECK_EQUAL( half2_opt, opt ); rval = moab.get_meshset_options( vertex_set, opt );CHECK_ERR( rval ); CHECK_EQUAL( vertex_opt, opt ); rval = moab.get_meshset_options( empty_set, opt );CHECK_ERR( rval ); CHECK_EQUAL( empty_opt, opt ); }
void test_pack_shared_entities_2d | ( | ) |
Test pack/unpack of shared entities in 2d
Definition at line 1595 of file pcomm_unit.cpp.
References CHECK_ERR, create_shared_grid_2d(), ErrorCode, moab::ParallelComm::exchange_ghost_cells(), MPI_COMM_WORLD, and moab::ParallelComm::set_rank().
{ Core moab[4]; ParallelComm* pc[4]; for( unsigned int i = 0; i < 4; i++ ) { pc[i] = new ParallelComm( &moab[i], MPI_COMM_WORLD ); pc[i]->set_rank( i ); } Range verts[4], quads[4]; ErrorCode rval = create_shared_grid_2d( pc, verts, quads );CHECK_ERR( rval ); // moab[0].list_entities(0,1); // exchange interface cells rval = ParallelComm::exchange_ghost_cells( pc, 4, -1, -1, 0, 0, true );CHECK_ERR( rval ); // now 1 layer of hex ghosts rval = ParallelComm::exchange_ghost_cells( pc, 4, 2, 0, 1, 0, true );CHECK_ERR( rval ); // now 1 layer of hex ghosts w/ edges rval = ParallelComm::exchange_ghost_cells( pc, 4, 2, 0, 1, 1, true );CHECK_ERR( rval ); for( unsigned int i = 0; i < 4; i++ ) delete pc[i]; }
void test_pack_shared_entities_3d | ( | ) |
Test pack/unpack of shared entities in 3d
Definition at line 1623 of file pcomm_unit.cpp.
References CHECK_ERR, create_shared_grid_3d(), ErrorCode, moab::ParallelComm::exchange_ghost_cells(), moab::ParallelComm::get_buffers(), MPI_COMM_WORLD, and moab::ParallelComm::set_rank().
{ Core moab[4]; ParallelComm* pc[4]; for( unsigned int i = 0; i < 4; i++ ) { pc[i] = new ParallelComm( &moab[i], MPI_COMM_WORLD ); pc[i]->set_rank( i ); for( unsigned int j = 0; j < 4; j++ ) { if( j == i ) continue; else pc[i]->get_buffers( j ); } } Range verts[4], hexes[4]; ErrorCode rval = create_shared_grid_3d( pc, verts, hexes );CHECK_ERR( rval ); // exchange interface cells rval = ParallelComm::exchange_ghost_cells( pc, 4, -1, -1, 0, 0, true );CHECK_ERR( rval ); // now 1 layer of hex ghosts rval = ParallelComm::exchange_ghost_cells( pc, 4, 3, 0, 1, 0, true );CHECK_ERR( rval ); // now 1 layer of hex ghosts w/ faces, edges rval = ParallelComm::exchange_ghost_cells( pc, 4, 3, 0, 1, 3, true );CHECK_ERR( rval ); for( unsigned int i = 0; i < 4; i++ ) delete pc[i]; }
void test_pack_tag_data_default_value | ( | ) |
Definition at line 1224 of file pcomm_unit.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Interface::create_meshset(), create_simple_grid(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type(), mb, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_OPAQUE, MBENTITYSET, MBHEX, MBVERTEX, MESHSET_SET, pack_unpack_noremoteh(), size, moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), moab::Interface::tag_set_data(), and TagType.
{ Range::iterator i; int size; DataType type; TagType storage; Core moab; Interface& mb = moab; ErrorCode rval; create_simple_grid( mb, 3 ); Range verts, elems, sets; rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); CHECK( !verts.empty() ); rval = mb.get_entities_by_type( 0, MBHEX, elems );CHECK_ERR( rval ); CHECK( !elems.empty() ); // Define a dense, opaque tag with a default value of "DEFLT". // Set the tag on one element, one vertex,and one set to "TAGGD". const char dense_5_opaque_tag_name[] = "This is intentionally a very long tag name in an attempt to test for an arbitrary " "limitations on tag name length."; Tag dense_5_opaque_tag; rval = mb.tag_get_handle( dense_5_opaque_tag_name, 5, MB_TYPE_OPAQUE, dense_5_opaque_tag, MB_TAG_DENSE | MB_TAG_EXCL, "DEFLT" );CHECK_ERR( rval ); EntityHandle set; rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); const EntityHandle handles[3] = { verts.front(), elems.front(), set }; const char data[] = "TAGGDTAGGDTAGGD"; rval = mb.tag_set_data( dense_5_opaque_tag, handles, 3, data );CHECK_ERR( rval ); // pack and unpack Range ents; pack_unpack_noremoteh( moab, ents ); elems.clear(); verts.clear(); sets.clear(); rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); rval = mb.get_entities_by_type( 0, MBHEX, elems );CHECK_ERR( rval ); rval = mb.get_entities_by_type( 0, MBENTITYSET, sets );CHECK_ERR( rval ); // check tag meta for dense_5_opaque_tag rval = mb.tag_get_handle( dense_5_opaque_tag_name, 5, MB_TYPE_OPAQUE, dense_5_opaque_tag );CHECK_ERR( rval ); rval = mb.tag_get_length( dense_5_opaque_tag, size );CHECK_ERR( rval ); CHECK_EQUAL( 5, size ); rval = mb.tag_get_type( dense_5_opaque_tag, storage );CHECK_ERR( rval ); CHECK_EQUAL( MB_TAG_DENSE, storage ); rval = mb.tag_get_data_type( dense_5_opaque_tag, type );CHECK_ERR( rval ); CHECK_EQUAL( MB_TYPE_OPAQUE, type ); char odata[6]; odata[5] = '\0'; rval = mb.tag_get_default_value( dense_5_opaque_tag, odata );CHECK_ERR( rval ); CHECK_EQUAL( std::string( "DEFLT" ), std::string( odata ) ); // count number of each type with tag set to non-default int vcount = 0, ecount = 0, scount = 0; for( i = verts.begin(); i != verts.end(); ++i ) { rval = mb.tag_get_data( dense_5_opaque_tag, &*i, 1, odata );CHECK_ERR( rval ); if( strcmp( odata, "DEFLT" ) != 0 ) { CHECK_EQUAL( std::string( "TAGGD" ), std::string( odata ) ); ++vcount; } } CHECK_EQUAL( 1, vcount ); for( i = elems.begin(); i != elems.end(); ++i ) { rval = mb.tag_get_data( dense_5_opaque_tag, &*i, 1, odata );CHECK_ERR( rval ); if( strcmp( odata, "DEFLT" ) != 0 ) { CHECK_EQUAL( "TAGGD", odata ); ++ecount; } } CHECK_EQUAL( 1, ecount ); for( i = sets.begin(); i != sets.end(); ++i ) { rval = mb.tag_get_data( dense_5_opaque_tag, &*i, 1, odata );CHECK_ERR( rval ); if( strcmp( odata, "DEFLT" ) != 0 ) { CHECK_EQUAL( "TAGGD", odata ); ++scount; } } CHECK_EQUAL( 1, scount ); }
void test_pack_tag_data_dense | ( | ) |
Definition at line 1164 of file pcomm_unit.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, CHECK_REAL_EQUAL, moab::Range::clear(), create_simple_grid(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), mb, MB_ENTITY_NOT_FOUND, MB_TAG_DENSE, MB_TAG_EXCL, MB_TYPE_DOUBLE, MBVERTEX, pack_unpack_noremoteh(), size, moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), moab::Interface::tag_set_data(), and TagType.
{ Range::iterator i; int size; DataType type; TagType storage; Core moab; Interface& mb = moab; ErrorCode rval; create_simple_grid( mb, 3 ); Range verts; rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); CHECK( !verts.empty() ); // Define a dense tag containing a single double-precision floating // point value. For each vertex, store the distance from the origin // in this tag. const char dense_1_double_tag_name[] = "test tag 2"; Tag dense_1_double_tag; rval = mb.tag_get_handle( dense_1_double_tag_name, 1, MB_TYPE_DOUBLE, dense_1_double_tag, MB_TAG_DENSE | MB_TAG_EXCL );CHECK_ERR( rval ); for( i = verts.begin(); i != verts.end(); ++i ) { double coords[3]; rval = mb.get_coords( &*i, 1, coords );CHECK_ERR( rval ); double val = sqrt( coords[0] * coords[0] + coords[1] * coords[1] + coords[2] * coords[2] ); rval = mb.tag_set_data( dense_1_double_tag, &*i, 1, &val );CHECK_ERR( rval ); } // pack and unpack Range ents; pack_unpack_noremoteh( moab, ents ); verts.clear(); rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); // check tag meta for dense_1_double_tag rval = mb.tag_get_handle( dense_1_double_tag_name, 1, MB_TYPE_DOUBLE, dense_1_double_tag );CHECK_ERR( rval ); rval = mb.tag_get_length( dense_1_double_tag, size );CHECK_ERR( rval ); CHECK_EQUAL( 1, size ); rval = mb.tag_get_type( dense_1_double_tag, storage );CHECK_ERR( rval ); CHECK_EQUAL( MB_TAG_DENSE, storage ); rval = mb.tag_get_data_type( dense_1_double_tag, type );CHECK_ERR( rval ); CHECK_EQUAL( MB_TYPE_DOUBLE, type ); double dval; rval = mb.tag_get_default_value( dense_1_double_tag, &dval ); CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); // check tag data for dense_1_double_tag for( i = verts.begin(); i != verts.end(); ++i ) { double coords[3]; rval = mb.get_coords( &*i, 1, coords );CHECK_ERR( rval ); const double expected = sqrt( coords[0] * coords[0] + coords[1] * coords[1] + coords[2] * coords[2] ); rval = mb.tag_get_data( dense_1_double_tag, &*i, 1, &dval );CHECK_ERR( rval ); CHECK_REAL_EQUAL( expected, dval, 1e-6 ); } }
void test_pack_tag_data_sparse | ( | ) |
Definition at line 1091 of file pcomm_unit.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), conn, create_simple_grid(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), mb, MB_ENTITY_NOT_FOUND, MB_TAG_CREAT, MB_TAG_SPARSE, MB_TYPE_INTEGER, MBHEX, pack_unpack_noremoteh(), size, moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), moab::Interface::tag_set_data(), and TagType.
{ Range::iterator i; int size; DataType type; TagType storage; Core moab; Interface& mb = moab; ErrorCode rval; create_simple_grid( mb, 3 ); Range elems; rval = mb.get_entities_by_type( 0, MBHEX, elems );CHECK_ERR( rval ); CHECK( !elems.empty() ); // Define a sparse tag containing two integers. For every other element // in the mesh, set the tag value to the floor of the x and y // coordinates of the first vertex in the elements connectivity list. const char sparse_2_int_tag_name[] = "test tag 1"; Tag sparse_2_int_tag; rval = mb.tag_get_handle( sparse_2_int_tag_name, 2, MB_TYPE_INTEGER, sparse_2_int_tag, MB_TAG_SPARSE | MB_TAG_CREAT );CHECK_ERR( rval ); bool skip = false; for( i = elems.begin(); i != elems.end(); ++i, skip = !skip ) { if( skip ) continue; const EntityHandle* conn = 0; int len; rval = mb.get_connectivity( *i, conn, len );CHECK_ERR( rval ); double coords[3]; rval = mb.get_coords( conn, 1, coords );CHECK_ERR( rval ); const int data[2] = { (int)coords[0], (int)coords[1] }; rval = mb.tag_set_data( sparse_2_int_tag, &*i, 1, data );CHECK_ERR( rval ); } // pack and unpack Range ents; pack_unpack_noremoteh( moab, ents ); elems.clear(); rval = mb.get_entities_by_type( 0, MBHEX, elems );CHECK_ERR( rval ); // check tag meta for sparse_2_int_tag rval = mb.tag_get_handle( sparse_2_int_tag_name, 2, MB_TYPE_INTEGER, sparse_2_int_tag );CHECK_ERR( rval ); rval = mb.tag_get_length( sparse_2_int_tag, size );CHECK_ERR( rval ); CHECK_EQUAL( 2, size ); rval = mb.tag_get_type( sparse_2_int_tag, storage );CHECK_ERR( rval ); CHECK_EQUAL( MB_TAG_SPARSE, storage ); rval = mb.tag_get_data_type( sparse_2_int_tag, type );CHECK_ERR( rval ); CHECK_EQUAL( MB_TYPE_INTEGER, type ); int intdata[2]; rval = mb.tag_get_default_value( sparse_2_int_tag, intdata ); CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval ); // check tag data for sparse_2_int_tag Range tagged; rval = mb.get_entities_by_type_and_tag( 0, MBHEX, &sparse_2_int_tag, 0, 1, tagged );CHECK_ERR( rval ); CHECK_EQUAL( ( elems.size() + 1 ) / 2, tagged.size() ); for( i = tagged.begin(); i != tagged.end(); ++i ) { rval = mb.tag_get_data( sparse_2_int_tag, &*i, 1, intdata );CHECK_ERR( rval ); const EntityHandle* conn = 0; int len; rval = mb.get_connectivity( *i, conn, len );CHECK_ERR( rval ); double coords[3]; rval = mb.get_coords( conn, 1, coords );CHECK_ERR( rval ); CHECK_EQUAL( (int)( coords[0] ), intdata[0] ); CHECK_EQUAL( (int)( coords[1] ), intdata[1] ); } }
void test_pack_tag_handle_data | ( | ) |
Definition at line 1466 of file pcomm_unit.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), conn, create_simple_grid(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), MB_TAG_EXCL, MB_TAG_SPARSE, MB_TYPE_HANDLE, MBHEX, MBVERTEX, pack_unpack_noremoteh(), size, moab::Interface::tag_get_data(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), moab::Interface::tag_set_data(), and TagType.
{ Range::iterator i; Core moab; Interface& mb = moab; ErrorCode rval; // create some mesh create_simple_grid( mb, 3 ); Range verts, elems; rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); CHECK( !verts.empty() ); rval = mb.get_entities_by_type( 0, MBHEX, elems );CHECK_ERR( rval ); CHECK( !elems.empty() ); // create a tag const char* tag_name = "entity tag"; EntityHandle default_val[8] = { 0, 0, 0, 0, 0, 0, 0, 0 }; Tag tag; rval = mb.tag_get_handle( tag_name, 8, MB_TYPE_HANDLE, tag, MB_TAG_SPARSE | MB_TAG_EXCL, &default_val );CHECK_ERR( rval ); // Store on each vertex the handles of the adjacent hexes, padded // with NULL handles. EntityHandle tagdata[8 * 8]; for( i = elems.begin(); i != elems.end(); ++i ) { const EntityHandle* conn; int len; rval = mb.get_connectivity( *i, conn, len );CHECK_ERR( rval ); CHECK_EQUAL( 8, len ); rval = mb.tag_get_data( tag, conn, len, tagdata );CHECK_ERR( rval ); for( int j = 0; j < 8; ++j ) { EntityHandle* vdata = tagdata + 8 * j; int idx = 0; while( vdata[idx] ) { ++idx; CHECK( idx < 8 ); } vdata[idx] = *i; } rval = mb.tag_set_data( tag, conn, len, tagdata );CHECK_ERR( rval ); } // pack and unpack pack_unpack_noremoteh( moab ); verts.clear(); rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); // check tag meta rval = mb.tag_get_handle( tag_name, 8, MB_TYPE_HANDLE, tag );CHECK_ERR( rval ); int size; rval = mb.tag_get_length( tag, size );CHECK_ERR( rval ); CHECK_EQUAL( 8, size ); TagType storage; rval = mb.tag_get_type( tag, storage );CHECK_ERR( rval ); CHECK_EQUAL( MB_TAG_SPARSE, storage ); DataType type; rval = mb.tag_get_data_type( tag, type );CHECK_ERR( rval ); CHECK_EQUAL( MB_TYPE_HANDLE, type ); rval = mb.tag_get_default_value( tag, tagdata );CHECK_ERR( rval ); for( int j = 0; j < 8; ++j ) { CHECK_EQUAL( (EntityHandle)0, tagdata[j] ); } // check tag values for( i = elems.begin(); i != elems.end(); ++i ) { const EntityHandle* conn; int len; rval = mb.get_connectivity( *i, conn, len );CHECK_ERR( rval ); CHECK_EQUAL( 8, len ); rval = mb.tag_get_data( tag, conn, len, tagdata );CHECK_ERR( rval ); for( int j = 0; j < 8; ++j ) { EntityHandle* vdata = tagdata + 8 * j; int idx = 0; while( vdata[idx] != *i ) { ++idx; CHECK( idx < 8 ); } vdata[idx] = 0; } rval = mb.tag_set_data( tag, conn, len, tagdata );CHECK_ERR( rval ); } for( i = verts.begin(); i != verts.end(); ++i ) { rval = mb.tag_get_data( tag, &*i, 1, tagdata );CHECK_ERR( rval ); for( int j = 0; j < 8; ++j ) { CHECK_EQUAL( (EntityHandle)0, tagdata[j] ); } } }
void test_pack_variable_length_tag | ( | ) |
Test pack/unpack of variable length tag values
Definition at line 1381 of file pcomm_unit.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), create_simple_grid(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), mb, MB_TAG_DENSE, MB_TAG_EXCL, MB_TAG_VARLEN, MB_TYPE_INTEGER, MB_VARIABLE_DATA_LENGTH, MBVERTEX, pack_unpack_noremoteh(), size, moab::Interface::tag_get_by_ptr(), moab::Interface::tag_get_data_type(), moab::Interface::tag_get_default_value(), moab::Interface::tag_get_handle(), moab::Interface::tag_get_length(), moab::Interface::tag_get_type(), moab::Interface::tag_set_by_ptr(), and TagType.
{ Range::iterator i; Core moab; Interface& mb = moab; ErrorCode rval; // create some mesh create_simple_grid( mb, 3 ); Range verts; rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); CHECK( !verts.empty() ); // create a variable-length tag const char* tag_name = "var_int_tag"; const int defval_size = 5; const int default_val[defval_size] = { 0xBEEF, 0xFEED, 0xDEAD, 0xBAD, 0xBEAD }; Tag tag; rval = mb.tag_get_handle( tag_name, defval_size, MB_TYPE_INTEGER, tag, MB_TAG_DENSE | MB_TAG_VARLEN | MB_TAG_EXCL, default_val );CHECK_ERR( rval ); // for each vertex, store in the tag an integer between 1 and 3, // followed by the floor of the cooresponding number of vertex // coordinates, beginning with x. for( i = verts.begin(); i != verts.end(); ++i ) { double coords[3]; rval = mb.get_coords( &*i, 1, coords );CHECK_ERR( rval ); const int num_coord = 1 + *i % 3; const int data_size = num_coord + 1; const int data[4] = { num_coord, (int)coords[0], (int)coords[1], (int)coords[2] }; const void* data_ptrs[1] = { data }; rval = mb.tag_set_by_ptr( tag, &*i, 1, data_ptrs, &data_size );CHECK_ERR( rval ); } // pack and unpack pack_unpack_noremoteh( moab ); verts.clear(); rval = mb.get_entities_by_type( 0, MBVERTEX, verts );CHECK_ERR( rval ); // check tag meta rval = mb.tag_get_handle( tag_name, 0, MB_TYPE_INTEGER, tag );CHECK_ERR( rval ); int size; rval = mb.tag_get_length( tag, size ); CHECK_EQUAL( MB_VARIABLE_DATA_LENGTH, rval ); TagType storage; rval = mb.tag_get_type( tag, storage );CHECK_ERR( rval ); CHECK_EQUAL( MB_TAG_DENSE, storage ); DataType type; rval = mb.tag_get_data_type( tag, type );CHECK_ERR( rval ); CHECK_EQUAL( MB_TYPE_INTEGER, type ); const void* defval_ptr; rval = mb.tag_get_default_value( tag, defval_ptr, size );CHECK_ERR( rval ); CHECK_EQUAL( defval_size, size ); const int* defval_arr = reinterpret_cast< const int* >( defval_ptr ); for( int j = 0; j < size; ++j ) CHECK_EQUAL( default_val[j], defval_arr[j] ); // check tag values for( i = verts.begin(); i != verts.end(); ++i ) { double coords[3]; rval = mb.get_coords( &*i, 1, coords );CHECK_ERR( rval ); int tsize; const void* valptr; rval = mb.tag_get_by_ptr( tag, &*i, 1, &valptr, &tsize );CHECK_ERR( rval ); CHECK( tsize > 1 ); CHECK( tsize <= 4 ); const int* valarr = reinterpret_cast< const int* >( valptr ); CHECK( valarr[0] >= 1 ); CHECK( valarr[0] <= 3 ); for( int j = 0; j < valarr[0]; ++j ) { CHECK_EQUAL( (int)( coords[j] ), valarr[j + 1] ); } } }
void test_pack_vertices | ( | ) |
Test pack/unpack of vertices
Definition at line 418 of file pcomm_unit.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::Core::create_vertices(), ErrorCode, moab::Core::get_coords(), pack_unpack_noremoteh(), and moab::Range::size().
{ Core moab; ErrorCode rval; Range verts; const size_t num_verts = 4; const double coords[3 * num_verts] = { -0.5, -1. / 3, 0.0, 0.5, -1. / 3, 0.0, 0.0, 2. / 3, 0.0, 0.0, 0.0, 0.745356 }; rval = moab.create_vertices( coords, num_verts, verts );CHECK_ERR( rval ); pack_unpack_noremoteh( moab, verts ); CHECK_EQUAL( num_verts, verts.size() ); double coords2[3 * num_verts]; rval = moab.get_coords( verts, coords2 );CHECK_ERR( rval ); std::vector< bool > seen( num_verts, false ); for( unsigned i = 0; i < num_verts; ++i ) { unsigned j; for( j = 0; j < num_verts; ++j ) if( coords[3 * j] == coords2[3 * i] && coords[3 * j + 1] == coords2[3 * i + 1] && coords[3 * j + 2] == coords2[3 * i + 2] ) break; CHECK( j < num_verts ); CHECK( !seen[j] ); seen[j] = true; } }
int rank = 0 |
Definition at line 57 of file pcomm_unit.cpp.
