perftool.cpp File Reference
#include <cmath>
#include <iostream>
#include <iomanip>
#include <ctime>
#include <cassert>
#include <list>
#include "moab/Core.hpp"
#include "moab/Skinner.hpp"
#include "moab/ReadUtilIface.hpp"
+ Include dependency graph for perftool.cpp:
Typedefs
typedef void(* test_func_t )(int, int, int)
Functions
void create_regular_mesh (int interval, int dimension)
void skin_common (int interval, int dim, int blocks, bool use_adj)
void skin (int intervals, int dim, int num)
void skin_adj (int intervals, int dim, int num)
void tag_time (TagType storage, bool direct, int intervals, int dim, int blocks)
void dense_tag (int intervals, int dim, int blocks)
void sparse_tag (int intervals, int dim, int blocks)
void direct_tag (int intervals, int dim, int blocks)
void usage (const char *argv0, bool error=true)
void list_tests ()
int main (int argc, char *argv[])
void create_regular_mesh (Interface *gMB, int interval, int dim)
Variables
double LENGTH = 1.0
const int DEFAULT_INTERVALS = 50
struct {
   std::string   testName
   test_func_t   testFunc
   std::string   testDesc
TestList []
const int TestListSize = sizeof( TestList ) / sizeof( TestList[0] )
Typedef Documentation
typedef void( * test_func_t)(int, int, int)
Definition at line 65 of file perftool.cpp.
Function Documentation
void create_regular_mesh ( int  interval,
int  dimension
Referenced by skin_common(), and tag_time().
void create_regular_mesh ( Interface gMB,
int  interval,
int  dim
Definition at line 220 of file perftool.cpp.
References conn, corners, dim, ErrorCode, moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), MB_SUCCESS, MBEDGE, MBHEX, MBQUAD, moab::Interface::query_interface(), moab::ReadUtilIface::update_adjacencies(), and z.
    if( dim < 1 || dim > 3 || interval < 1 )
        std::cerr << "Invalid arguments" << std::endl;
        exit( 1 );
    const int nvi     = interval + 1;
    const int dims[3] = { nvi, dim > 1 ? nvi : 1, dim > 2 ? nvi : 1 };
    int num_vert      = dims[0] * dims[1] * dims[2];
    ReadUtilIface* readMeshIface;
    gMB->query_interface( readMeshIface );
    EntityHandle vstart;
    std::vector< double* > arrays;
    ErrorCode rval = readMeshIface->get_node_coords( 3, num_vert, 1, vstart, arrays );
    if( MB_SUCCESS != rval || arrays.size() < 3 )
        std::cerr << "Vertex creation failed" << std::endl;
        exit( 2 );
    double *x = arrays[0], *y = arrays[1], *z = arrays[2];
    // Calculate vertex coordinates
    for( int k = 0; k < dims[2]; ++k )
        for( int j = 0; j < dims[1]; ++j )
            for( int i = 0; i < dims[0]; ++i )
                *x = i;
                ++x;
                *y = j;
                ++y;
                *z = k;
                ++z;
    const long vert_per_elem = 1 << dim;  // 2^dim
    const long intervals[3]  = { interval, dim > 1 ? interval : 1, dim > 2 ? interval : 1 };
    const long num_elem      = intervals[0] * intervals[1] * intervals[2];
    const EntityType type    = ( dim == 1 ) ? MBEDGE : ( dim == 2 ) ? MBQUAD : MBHEX;
    EntityHandle estart, *conn = 0;
    rval = readMeshIface->get_element_connect( num_elem, vert_per_elem, type, 0, estart, conn );
    if( MB_SUCCESS != rval || !conn )
        std::cerr << "Element creation failed" << std::endl;
        exit( 2 );
    // Offsets of element vertices in grid relative to corner closest to origin
    long c                = dims[0] * dims[1];
    const long corners[8] = { 0, 1, 1 + dims[0], dims[0], c, c + 1, c + 1 + dims[0], c + dims[0] };
    // Populate element list
    EntityHandle* iter = conn;
    for( long z1 = 0; z1 < intervals[2]; ++z1 )
        for( long y1 = 0; y1 < intervals[1]; ++y1 )
            for( long x1 = 0; x1 < intervals[0]; ++x1 )
                const long index = x1 + y1 * dims[0] + z1 * ( dims[0] * dims[1] );
                for( long j = 0; j < vert_per_elem; ++j, ++iter )
                    *iter = index + corners[j] + vstart;
    // notify MOAB of the new elements
    rval = readMeshIface->update_adjacencies( estart, num_elem, vert_per_elem, conn );
    if( MB_SUCCESS != rval )
        std::cerr << "Element update failed" << std::endl;
        exit( 2 );
void dense_tag ( int  intervals,
int  dim,
int  blocks
Definition at line 49 of file perftool.cpp.
References MB_TAG_DENSE, and tag_time().
    std::cout << "Dense Tag Time:";
    tag_time( MB_TAG_DENSE, false, intervals, dim, blocks );
void direct_tag ( int  intervals,
int  dim,
int  blocks
Definition at line 59 of file perftool.cpp.
    std::cout << "Direct Tag Time:";
    tag_time( MB_TAG_DENSE, true, intervals, dim, blocks );
void list_tests ( )
Definition at line 96 of file perftool.cpp.
References testDesc, TestList, TestListSize, and testName.
Referenced by main(), and runner_run_tests().
    unsigned max_test_name = 0, max_test_desc = 0;
    for( int i = 0; i < TestListSize; ++i )
        if( TestList[i].testName.size() > max_test_name ) max_test_name = TestList[i].testName.size();
        if( TestList[i].testDesc.size() > max_test_desc ) max_test_desc = TestList[i].testDesc.size();
    std::cout << std::setw( max_test_name ) << "NAME"
              << "   " << std::setw( max_test_desc ) << std::left << "DESCRIPTION" << std::endl
              << std::setfill( '-' ) << std::setw( max_test_name ) << ""
              << "   " << std::setfill( '-' ) << std::setw( max_test_desc ) << "" << std::setfill( ' ' ) << std::endl;
        std::cout << std::setw( max_test_name ) << TestList[i].testName << " : " << std::setw( max_test_desc )
                  << std::left << TestList[i].testDesc << std::endl;
int main ( int  argc,
char *  argv[]
Definition at line 113 of file perftool.cpp.
References DEFAULT_INTERVALS, list_tests(), testFunc, TestList, TestListSize, testName, and usage.
    int intervals = DEFAULT_INTERVALS;
    int dimension = 3;
    int number    = 0;
    std::vector< test_func_t > test_list;
    std::list< int* > expected_list;
    bool did_help = false;
    for( int i = 1; i < argc; ++i )
        if( !expected_list.empty() )
            int* ptr = expected_list.front();
            expected_list.pop_front();
            char* endptr;
            *ptr = strtol( argv[i], &endptr, 0 );
            if( !endptr )
                usage( argv[0] );
                std::cerr << "Expected integer value, got \"" << argv[i] << '"' << std::endl;
                return 1;
        else if( *argv[i] == '-' )
        {  // flag
            for( int j = 1; argv[i][j]; ++j )
                switch( argv[i][j] )
                    case 'i':
                        expected_list.push_back( &intervals );
                        break;
                    case 'd':
                        expected_list.push_back( &dimension );
                        break;
                    case 'n':
                        expected_list.push_back( &number );
                        break;
                    case 'h':
                        did_help = true;
                        usage( argv[0], false );
                        break;
                    case 'l':
                        did_help = true;
                        list_tests();
                        break;
                    default:
                        usage( argv[0] );
                        std::cerr << "Invalid option: -" << argv[i][j] << std::endl;
                        return 1;
        else
            int j = -1;
            do
                ++j;
                if( j >= TestListSize )
                    usage( argv[0] );
                    std::cerr << "Invalid test name: " << argv[i] << std::endl;
                    return 1;
            } while( TestList[j].testName != argv[i] );
            test_list.push_back( TestList[j].testFunc );
        usage( argv[0] );
        std::cerr << "Missing final argument" << std::endl;
        return 1;
    // error if no input
    if( test_list.empty() && !did_help )
        usage( argv[0] );
        std::cerr << "No tests specified" << std::endl;
        return 1;
    if( intervals < 1 )
        std::cerr << "Invalid interval count: " << intervals << std::endl;
        return 1;
    if( dimension < 1 || dimension > 3 )
        std::cerr << "Invalid dimension: " << dimension << std::endl;
        return 1;
    // now run the tests
    for( std::vector< test_func_t >::iterator i = test_list.begin(); i != test_list.end(); ++i )
        test_func_t fptr = *i;
        fptr( intervals, dimension, number );
    return 0;
void skin_adj ( int  intervals,
int  dim,
int  num
Definition at line 41 of file perftool.cpp.
References skin_common().
    std::cout << "Skinning with adjacencies:" << std::endl;
    skin_common( intervals, dim, num, true );
void skin_common ( int  interval,
int  dim,
int  blocks,
bool  use_adj
Definition at line 295 of file perftool.cpp.
References moab::Range::begin(), moab::Range::clear(), create_regular_mesh(), moab::Range::empty(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), gMB, MB_SUCCESS, moab::Range::merge(), moab::Range::size(), skin(), t, and moab::Interface::UNION.
Referenced by skin(), and skin_adj().
    Core moab;
    Interface* gMB = &moab;
    ErrorCode rval;
    double d;
    clock_t t, tt;
    create_regular_mesh( gMB, interval, dim );
    Range skin, verts, elems;
    rval = gMB->get_entities_by_dimension( 0, dim, elems );
    assert( MB_SUCCESS == rval );
    assert( !elems.empty() );
    Skinner tool( gMB );
    t    = clock();
    rval = tool.find_skin( 0, elems, true, verts, 0, use_adj, false );
    t    = clock() - t;
        std::cerr << "Search for skin vertices failed" << std::endl;
        exit( 2 );
    d = ( (double)t ) / CLOCKS_PER_SEC;
    std::cout << "Got " << verts.size() << " skin vertices in " << d << " seconds." << std::endl;
    t = 0;
    if( num < 1 ) num = 1000;
    long blocksize = elems.size() / num;
    if( !blocksize ) blocksize = 1;
    long numblocks     = elems.size() / blocksize;
    Range::iterator it = elems.begin();
    for( long i = 0; i < numblocks; ++i )
        verts.clear();
        Range::iterator end = it + blocksize;
        Range blockelems;
        blockelems.merge( it, end );
        it   = end;
        tt   = clock();
        rval = tool.find_skin( 0, blockelems, true, verts, 0, use_adj, false );
        t += clock() - tt;
            exit( 2 );
    std::cout << "Got skin vertices for " << numblocks << " blocks of " << blocksize << " elements in " << d
    for( int e = 0; e < 2; ++e )
    {  // do this twice
        if( e == 1 )
            // create all interior faces
            skin.clear();
            t = clock();
            gMB->get_adjacencies( elems, dim - 1, true, skin, Interface::UNION );
            t = clock() - t;
            std::cout << "Created " << skin.size() << " entities of dimension-1 in " << d << " seconds" << std::endl;
        skin.clear();
        t    = clock();
        rval = tool.find_skin( 0, elems, false, skin, 0, use_adj, true );
        t    = clock() - t;
            exit( 2 );
        std::cout << "Got " << skin.size() << " skin elements in " << d << " seconds." << std::endl;
        t  = 0;
        it = elems.begin();
            skin.clear();
            Range blockelems;
            it   = end;
            tt   = clock();
            rval = tool.find_skin( 0, blockelems, false, skin, 0, use_adj, true );
            t += clock() - tt;
                std::cerr << "Search for skin elements failed" << std::endl;
                exit( 2 );
        std::cout << "Got skin elements for " << numblocks << " blocks of " << blocksize << " elements in " << d
void sparse_tag ( int  intervals,
int  dim,
int  blocks
Definition at line 54 of file perftool.cpp.
References MB_TAG_SPARSE, and tag_time().
    std::cout << "Sparse Tag Time:";
    tag_time( MB_TAG_SPARSE, false, intervals, dim, blocks );
void tag_time ( TagType  storage,
bool  direct,
int  intervals,
int  dim,
int  blocks
Definition at line 398 of file perftool.cpp.
References moab::Range::begin(), moab::Range::clear(), create_regular_mesh(), moab::Range::end(), moab::Interface::get_entities_by_type(), mb, MB_TAG_CREAT, MB_TYPE_DOUBLE, MBVERTEX, moab::Range::merge(), moab::Range::size(), t, moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_iterate(), and moab::Interface::tag_set_data().
Referenced by dense_tag(), direct_tag(), main(), and sparse_tag().
    Core moab;
    Interface& mb = moab;
    create_regular_mesh( &mb, intervals, dim );
    // Create tag in which to store data
    Tag tag;
    mb.tag_get_handle( "data", 1, MB_TYPE_DOUBLE, tag, storage | MB_TAG_CREAT );
    // Make up some arbitrary iterative calculation for timing purposes:
    // set each value v_n = (V + v_n)/2 until all values are within
    // epsilon of V.
    std::vector< double > data;
    Range verts;
    mb.get_entities_by_type( 0, MBVERTEX, verts );
    clock_t t = clock();
    // initialize
    if( direct )
        Range::iterator i, j = verts.begin();
        void* ptr;
        int count;
        while( j != verts.end() )
            mb.tag_iterate( tag, i, verts.end(), count, ptr );
            double* arr = reinterpret_cast< double* >( ptr );
            for( j = i + count; i != j; ++i, ++arr )
                *arr = ( 11.0 * *i + 7.0 ) / ( *i );
    else
        data.resize( verts.size() );
        double* arr = &data[0];
        for( Range::iterator i = verts.begin(); i != verts.end(); ++i, ++arr )
        mb.tag_set_data( tag, verts, &data[0] );
    // iterate
    const double v0   = acos( -1.0 );  // pi
    size_t iter_count = 0;
    double max_diff;
    const size_t num_verts = verts.size();
    do
        if( direct )
            max_diff = 0.0;
            void* ptr;
                int count;
                    *arr        = 0.5 * ( *arr + v0 );
                    double diff = fabs( *arr - v0 );
                    if( diff > max_diff ) max_diff = diff;
        else if( blocks < 1 )
            max_diff = 0.0;
            mb.tag_get_data( tag, verts, &data[0] );
            for( size_t i = 0; i < data.size(); ++i )
                data[i]     = 0.5 * ( v0 + data[i] );
                double diff = fabs( data[i] - v0 );
        else
            max_diff = 0.0;
            Range r;
            Range::iterator it = verts.begin();
            size_t step        = num_verts / blocks;
            for( int j = 0; j < blocks - 1; ++j )
                Range::iterator nx = it;
                nx += step;
                r.clear();
                r.merge( it, nx );
                mb.tag_get_data( tag, r, &data[0] );
                it = nx;
                for( size_t i = 0; i < step; ++i )
                mb.tag_set_data( tag, r, &data[0] );
            r.clear();
            r.merge( it, verts.end() );
            for( size_t i = 0; i < ( num_verts - ( blocks - 1 ) * step ); ++i )
        ++iter_count;
        //    std::cout << iter_count << " " << max_diff << std::endl;
    } while( max_diff > 1e-6 );
    double secs = ( clock() - t ) / (double)CLOCKS_PER_SEC;
    std::cout << " " << iter_count << " iterations in " << secs << " seconds" << std::endl;
void usage ( const char *  argv0,
bool  error = true
Definition at line 80 of file perftool.cpp.
References DEFAULT_INTERVALS, and moab::error().
    std::ostream& str = error ? std::cerr : std::cout;
    str << "Usage: " << argv0
        << " [-i <ints_per_side>] [-d <dimension>] [-n <test_specifc_int>] <test_name> "
           "[<test_name2> ...]"
        << std::endl;
    str << "       " << argv0 << " [-h|-l]" << std::endl;
    if( error ) return;
    str << "  -i  : specify interverals per side (num hex = ints^3, default: " << DEFAULT_INTERVALS << std::endl;
    str << "  -d  : specify element dimension, default: 3" << std::endl;
    str << "  -n  : specify an integer value that for which the meaning is test-specific" << std::endl;
    str << "  -h  : print this help text." << std::endl;
    str << "  -l  : list available tests" << std::endl;
Variable Documentation
Definition at line 32 of file perftool.cpp.
double LENGTH = 1.0
Definition at line 31 of file perftool.cpp.
Definition at line 70 of file perftool.cpp.
Referenced by list_tests().
Definition at line 69 of file perftool.cpp.
Referenced by main(), runner_find_test_func(), and runner_run_tests().
struct { ... } TestList[]
Referenced by list_tests(), and main().
Definition at line 78 of file perftool.cpp.
