point_location.cpp File Reference
#include "moab/Core.hpp"
#include "moab/AdaptiveKDTree.hpp"
#include "moab/Range.hpp"
#include "moab/CartVect.hpp"
#include "moab/GeomUtil.hpp"
#include <iostream>
#include <ctime>
#include <cstdlib>
#include <cassert>
#include <sstream>
+ Include dependency graph for point_location.cpp:
Defines
#define CHK(ErrorCode)
Enumerations
enum  TreeType { UseKDTree, UseNoTree, UseDefaultTree = UseKDTree }
Functions
static void fail (ErrorCode error_code, const char *file_name, int line_number)
const char * is_default_tree (TreeType type)
static void usage (char *argv0, bool help=false)
static void generate_random_points (Interface &mesh, size_t num_points, std::vector< CartVect > &points, std::vector< EntityHandle > &point_elems)
static void do_kdtree_test (Interface &mesh, int tree_depth, int elem_per_leaf, long num_test, const std::vector< CartVect > &points, std::vector< EntityHandle > &point_elems, clock_t &build_time, clock_t &test_time, size_t &depth)
static void do_linear_test (Interface &mesh, int tree_depth, int elem_per_leaf, long num_test, const std::vector< CartVect > &points, std::vector< EntityHandle > &point_elems, clock_t &build_time, clock_t &test_time, size_t &depth)
int main (int argc, char *argv[])
static CartVect random_point_in_hex (Interface &mb, EntityHandle hex)
Variables
const char * default_str = "(default)"
const char * empty_str = ""
const long DEFAULT_NUM_TEST = 100000
const long HARD_MAX_UNIQUE_POINTS = 100000
const long HARD_MIN_UNIQUE_POINTS = 1000
const long FRACTION_UNIQUE_POINTS = 100
const int HexSign [8][3]
Define Documentation
#define CHK (   ErrorCode)
Value:
do        \
        if( MB_SUCCESS != ( ErrorCode ) ) fail( ( ErrorCode ), __FILE__, __LINE__ ); \
    } while( false )
Definition at line 12 of file point_location.cpp.
Referenced by do_kdtree_test(), do_linear_test(), generate_random_points(), and random_point_in_hex().
Enumeration Type Documentation
enum TreeType
Enumerator:
UseKDTree
UseNoTree
UseDefaultTree
Definition at line 22 of file point_location.cpp.
Function Documentation
void do_kdtree_test ( Interface mesh,
int  tree_depth,
int  elem_per_leaf,
long  num_test,
const std::vector< CartVect > &  points,
std::vector< EntityHandle > &  point_elems,
clock_t &  build_time,
clock_t &  test_time,
size_t &  depth
) [static]
Definition at line 310 of file point_location.cpp.
References build_time, moab::AdaptiveKDTree::build_tree(), CHK, moab::Range::clear(), conn, ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::AdaptiveKDTree::get_info(), init(), leaf, MBHEX, moab::GeomUtil::point_in_trilinear_hex(), and moab::AdaptiveKDTree::point_search().
Referenced by main().
    ErrorCode rval;
    clock_t init = clock();
    AdaptiveKDTree tool( &mb );
    EntityHandle root;
    std::ostringstream options;
    if( tree_depth > 0 ) options << "MAX_DEPTH=" << tree_depth << ";";
    if( elem_per_leaf > 0 ) options << "MAX_PER_LEAF=" << elem_per_leaf << ";";
    Range all_hexes;
    rval = mb.get_entities_by_type( 0, MBHEX, all_hexes );
    CHK( rval );
    FileOptions opt( options.str().c_str() );
    rval = tool.build_tree( all_hexes, &root, &opt );
    CHK( rval );
    all_hexes.clear();
    build_time = clock() - init;
    EntityHandle leaf;
    std::vector< EntityHandle > hexes;
    std::vector< EntityHandle >::iterator j;
    CartVect coords[8];
    const EntityHandle* conn;
    int len;
    for( long i = 0; i < num_test; ++i )
        const size_t idx = (size_t)i % points.size();
        rval             = tool.point_search( points[idx].array(), leaf, 1.0e-10, 1.0e-6, NULL, &root );
        CHK( rval );
        hexes.clear();
        rval = mb.get_entities_by_handle( leaf, hexes );
        CHK( rval );
        for( j = hexes.begin(); j != hexes.end(); ++j )
            rval = mb.get_connectivity( *j, conn, len, true );
            CHK( rval );
            rval = mb.get_coords( conn, 8, reinterpret_cast< double* >( coords ) );
            CHK( rval );
            if( GeomUtil::point_in_trilinear_hex( coords, points[idx], 1e-12 ) )
                point_elems[idx] = *j;
                break;
        if( j == hexes.end() ) point_elems[idx] = 0;
    test_time = clock() - build_time;
    double tmp_box[3];
    unsigned max_d;
    tool.get_info( root, tmp_box, tmp_box, max_d );
    depth = max_d;
void do_linear_test ( Interface mesh,
int  tree_depth,
int  elem_per_leaf,
long  num_test,
size_t &  depth
) [static]
Definition at line 372 of file point_location.cpp.
References moab::Range::begin(), build_time, CHK, conn, moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), init(), MBHEX, and moab::GeomUtil::point_in_trilinear_hex().
    Range hexes;
    ErrorCode rval = mb.get_entities_by_type( 0, MBHEX, hexes );
    CHK( rval );
    depth = 0;
    point_elems.resize( points.size() );
    CartVect coords[8];
    int len;
        for( Range::iterator h = hexes.begin(); h != hexes.end(); ++h )
            rval = mb.get_connectivity( *h, conn, len, true );
            CHK( rval );
            CHK( rval );
                point_elems[idx] = *h;
                break;
void fail ( ErrorCode  error_code,
const char *  file_name,
int  line_number
) [static]
Definition at line 236 of file point_location.cpp.
    std::cerr << "Internal error (error code " << error_code << ") at " << file << ":" << line << std::endl;
    abort();
void generate_random_points ( Interface mesh,
size_t  num_points,
) [static]
Definition at line 274 of file point_location.cpp.
References moab::Range::all_of_type(), moab::Range::begin(), CHK, moab::Range::empty(), moab::Range::end(), moab::Range::equal_range(), moab::Range::erase(), ErrorCode, moab::Interface::get_entities_by_dimension(), MBHEX, random_point_in_hex(), and moab::Range::size().
    Range elems;
    ErrorCode rval;
    rval = mb.get_entities_by_dimension( 0, 3, elems );
    CHK( rval );
    if( !elems.all_of_type( MBHEX ) )
        std::cerr << "Warning: ignoring non-hexahedral elements." << std::endl;
        std::pair< Range::iterator, Range::iterator > p = elems.equal_range( MBHEX );
        elems.erase( p.second, elems.end() );
        elems.erase( elems.begin(), p.first );
    if( elems.empty() )
        std::cerr << "Input file contains no hexahedral elements." << std::endl;
        exit( 1 );
    points.resize( num_points );
    point_elems.resize( num_points );
    const size_t num_elem = elems.size();
    for( size_t i = 0; i < num_points; ++i )
        size_t offset = 0;
        for( size_t x = num_elem; x > 0; x /= RAND_MAX )
            offset += rand();
        offset %= num_elem;
        point_elems[i] = elems[offset];
        points[i]      = random_point_in_hex( mb, point_elems[i] );
const char* is_default_tree ( TreeType  type) [inline]
Definition at line 31 of file point_location.cpp.
References default_str, empty_str, and UseDefaultTree.
Referenced by usage().
    return type == UseDefaultTree ? default_str : empty_str;
int main ( int  argc,
char *  argv[]
Definition at line 87 of file point_location.cpp.
References build_time, DEFAULT_NUM_TEST, do_kdtree_test(), do_linear_test(), ErrorCode, moab::Interface::estimated_memory_use(), moab::fail(), FRACTION_UNIQUE_POINTS, generate_random_points(), moab::Interface::get_last_error(), HARD_MAX_UNIQUE_POINTS, HARD_MIN_UNIQUE_POINTS, input_file, moab::Interface::load_file(), mb, MB_SUCCESS, usage, UseDefaultTree, UseKDTree, and UseNoTree.
    const char* input_file = 0;
    long tree_depth        = -1;
    long elem_per_leaf     = -1;
    long num_points        = DEFAULT_NUM_TEST;
    TreeType type          = UseDefaultTree;
    char* endptr;
    // PARSE ARGUMENTS
    long* valptr = 0;
    for( int i = 1; i < argc; ++i )
        if( valptr )
            *valptr = strtol( argv[i], &endptr, 0 );
            if( *valptr < 1 || *endptr )
                std::cerr << "Invalid value for '" << argv[i - 1] << "' flag: " << argv[i] << std::endl;
                exit( 1 );
            valptr = 0;
        else if( argv[i][0] == '-' && argv[i][1] && !argv[i][2] )
            switch( argv[i][1] )
                case 'h':
                    usage( argv[0], true );
                    break;
                case 'k':
                    type = UseKDTree;
                    break;
                case 'v':
                    type = UseNoTree;
                    break;
                case 'd':
                    valptr = &tree_depth;
                    break;
                case 'e':
                    valptr = &elem_per_leaf;
                    break;
                case 'n':
                    valptr = &num_points;
                    break;
                default:
                    std::cerr << "Invalid flag: " << argv[i] << std::endl;
                    usage( argv[0] );
                    break;
        else if( !input_file )
            input_file = argv[i];
        else
            std::cerr << "Unexpected argument: " << argv[i] << std::endl;
            usage( argv[0] );
    if( valptr )
        std::cerr << "Expected value following '" << argv[argc - 1] << "' flag" << std::endl;
        usage( argv[0] );
    if( !input_file )
        std::cerr << "No input file specified." << std::endl;
        usage( argv[0] );
    // LOAD MESH
    Core moab;
    Interface& mb = moab;
    ErrorCode rval;
    std::string init_msg, msg;
    mb.get_last_error( init_msg );
    rval = mb.load_file( input_file );
    if( MB_SUCCESS != rval )
        std::cerr << input_file << " : failed to read file." << std::endl;
        mb.get_last_error( msg );
        if( msg != init_msg ) std::cerr << "message : " << msg << std::endl;
    // GENERATE TEST POINTS
    int num_unique = num_points / FRACTION_UNIQUE_POINTS;
    if( num_unique > HARD_MAX_UNIQUE_POINTS )
        num_unique = HARD_MAX_UNIQUE_POINTS;
    else if( num_unique < HARD_MIN_UNIQUE_POINTS )
        num_unique = num_points;
    std::vector< CartVect > points;
    std::vector< EntityHandle > elems;
    generate_random_points( mb, num_unique, points, elems );
    // GET MEMORY USE BEFORE BUILDING TREE
    unsigned long long init_total_storage;
    mb.estimated_memory_use( 0, 0, &init_total_storage );
    // RUN TIMING TEST
    clock_t build_time, test_time;
    size_t actual_depth = 0;
    std::vector< EntityHandle > results( points.size() );
    switch( type )
        default:
        case UseKDTree:
            do_kdtree_test( mb, tree_depth, elem_per_leaf, num_points, points, results, build_time, test_time,
                            actual_depth );
            break;
        case UseNoTree:
            do_linear_test( mb, tree_depth, elem_per_leaf, num_points, points, results, build_time, test_time,
                            actual_depth );
            break;
    unsigned long long fini_total_storage;
    mb.estimated_memory_use( 0, 0, &fini_total_storage );
    // VALIDATE RESULTS
    int fail = 0;
    if( results != elems )
        std::cout << "WARNING:  Test produced invalid results" << std::endl;
        fail = 1;
    // SUMMARIZE RESULTS
    std::cout << "Number of test queries: " << num_points << std::endl;
    std::cout << "Tree build time: " << ( (double)build_time ) / CLOCKS_PER_SEC << " seconds" << std::endl;
    std::cout << "Total query time: " << ( (double)test_time ) / CLOCKS_PER_SEC << " seconds" << std::endl;
    std::cout << "Time per query: " << ( (double)test_time ) / CLOCKS_PER_SEC / num_points << " seconds" << std::endl;
    std::cout << "Tree depth: " << actual_depth << std::endl;
    if( actual_depth )
        std::cout << "Total query time/depth: " << ( (double)test_time ) / CLOCKS_PER_SEC / actual_depth << " seconds"
                  << std::endl;
    std::cout << std::endl;
    std::cout << "Bytes before tree construction: " << init_total_storage << std::endl;
    std::cout << "Bytes after tree construction: " << fini_total_storage << std::endl;
    std::cout << "Difference: " << fini_total_storage - init_total_storage << " bytes" << std::endl;
    return fail;
static CartVect random_point_in_hex ( Interface mb,
EntityHandle  hex
) [static]
Definition at line 245 of file point_location.cpp.
References CHK, conn, ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), HexSign, MB_SUCCESS, and MBMesquite::xi.
Referenced by generate_random_points().
    const double f = RAND_MAX / 2;
    CartVect xi( ( (double)rand() - f ) / f, ( (double)rand() - f ) / f, ( (double)rand() - f ) / f );
    CartVect coords[8];
    int len;
    ErrorCode rval = mb.get_connectivity( hex, conn, len, true );
    if( len != 8 && MB_SUCCESS != rval )
        std::cerr << "Invalid element" << std::endl;
        assert( false );
        abort();
    CHK( rval );
    CartVect point( 0, 0, 0 );
    for( unsigned i = 0; i < 8; ++i )
        double coeff = 0.125;
        for( unsigned j = 0; j < 3; ++j )
            coeff *= 1 + HexSign[i][j] * xi[j];
        point += coeff * coords[i];
    return point;
static void usage ( char *  argv0,
bool  help = false
) [static]
Definition at line 41 of file point_location.cpp.
References DEFAULT_NUM_TEST, help(), is_default_tree(), UseKDTree, and UseNoTree.
    const char* usage_str = "[-k|-v] [-n <N>] [-d <N>] [-e <N>] <input_mesh>";
    if( !help )
        std::cerr << "Usage: " << argv0 << " " << usage_str << std::endl;
        std::cerr << "     : " << argv0 << " -h" << std::endl;
        exit( 1 );
    std::cout << "Usage: " << argv0 << " " << usage_str << std::endl
              << "  -k : Use kD Tree " << is_default_tree( UseKDTree ) << std::endl
              << "  -v : Use no tree" << is_default_tree( UseNoTree ) << std::endl
              << "  -n : Specify number of test points (default = " << DEFAULT_NUM_TEST << ")" << std::endl
              << "  -d : Specify maximum tree depth" << std::endl
              << "  -e : Specify maximum elements per leaf" << std::endl
              << " <input_mesh> : Mesh to build and query." << std::endl
              << std::endl;
    exit( 0 );
Variable Documentation
Definition at line 36 of file point_location.cpp.
Referenced by main(), and usage().
const char* default_str = "(default)"
Definition at line 29 of file point_location.cpp.
Referenced by is_default_tree().
const char* empty_str = ""
Definition at line 30 of file point_location.cpp.
Definition at line 39 of file point_location.cpp.
Definition at line 37 of file point_location.cpp.
Definition at line 38 of file point_location.cpp.
const int HexSign[8][3]
Initial value:
 { { -1, -1, -1 }, { 1, -1, -1 }, { 1, 1, -1 }, { -1, 1, -1 },
                            { -1, -1, 1 },  { 1, -1, 1 },  { 1, 1, 1 },  { -1, 1, 1 } }
Definition at line 242 of file point_location.cpp.
Referenced by random_point_in_hex().
