quality.cpp
00001 #include <iostream>
00002 #include <cstdlib>
00003 #include <vector>
00004 #include <map>
00005 #include <string>
00006 #include <cstdio>
00007 #include <iomanip>
00008 #include <fstream>
00009 #include "moab/MOABConfig.h"
00010 #ifdef MOAB_HAVE_MPI
00011 #include "moab_mpi.h"
00012 #include "moab/ParallelComm.hpp"
00013 #endif
00014 #if !defined( _MSC_VER ) && !defined( __MINGW32__ )
00015 #include <termios.h>
00016 #include <sys/ioctl.h>
00017 #endif
00018 #include <cmath>
00019 #include <cassert>
00020 #include <cfloat>
00021
00022 #include "moab/Core.hpp"
00023 #include "moab/Range.hpp"
00024 #include "MBTagConventions.hpp"
00025 #include "moab/Interface.hpp"
00026
00027 #include "moab/verdict/VerdictWrapper.hpp"
00028
00029 using namespace moab;
00030
00031 static void print_usage( const char* name, std::ostream& stream )
00032 {
00033     stream << "Usage: " << name << " <input_file> [<output_file>]" << std::endl;
00034 }
00035
00036 int main( int argc, char* argv[] )
00037 {
00038     int proc_id = 0, size = 1;
00039 #ifdef MOAB_HAVE_MPI
00040     MPI_Init( &argc, &argv );
00041     MPI_Comm_rank( MPI_COMM_WORLD, &proc_id );
00042     MPI_Comm_size( MPI_COMM_WORLD, &size );
00043 #endif
00044     if( argc < 2 && 0 == proc_id )
00045     {
00046         print_usage( argv[0], std::cerr );
00047 #ifdef MOAB_HAVE_MPI
00048         MPI_Finalize();
00049 #endif
00050         return 1;
00051     }
00052     Core mb;
00053     std::string read_options;
00054     if( size > 1 ) read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS";
00055
00056     if( size > 1 && argc > 2 )
00057     {
00058         std::cerr << " cannot use verbose option in parallel \n";
00059 #ifdef MOAB_HAVE_MPI
00060         MPI_Finalize();
00061 #endif
00062         return 1;
00063     }
00064
00065     char* out_file = NULL;
00066     std::ofstream ofile;
00067
00068     if( argc == 3 )
00069     {
00070         std::cout << " write verbose output to a CSV file " << argv[2] << "\n";
00071         out_file = argv[2];
00072         ofile.open( out_file );
00073     }
00074     if( MB_SUCCESS != mb.load_file( argv[1], 0, read_options.c_str() ) )
00075     {
00076         fprintf( stderr, "Error reading file: %s\n", argv[1] );
00077 #ifdef MOAB_HAVE_MPI
00078         MPI_Finalize();
00079 #endif
00080         return 1;
00081     }
00082
00083     VerdictWrapper vw( &mb );
00084     vw.set_size( 1. );  // for relative size measures; maybe it should be user input
00085     Range entities;
00086     ErrorCode rval = mb.get_entities_by_handle( 0, entities );
00087     if( MB_SUCCESS != rval )
00088     {
00089         fprintf( stderr, "Error getting entities from file %s\n", argv[1] );
00090 #ifdef MOAB_HAVE_MPI
00091         MPI_Finalize();
00092 #endif
00093         return 1;
00094     }
00095     // get all edges and faces, force them to be created
00096     Range allfaces, alledges;
00097     Range cells = entities.subset_by_dimension( 3 );
00098     rval        = mb.get_adjacencies( cells, 2, true, allfaces, Interface::UNION );
00099     if( MB_SUCCESS != rval )
00100     {
00101         fprintf( stderr, "Error getting all faces" );
00102 #ifdef MOAB_HAVE_MPI
00103         MPI_Finalize();
00104 #endif
00105         return 1;
00106     }
00107
00108     rval = mb.get_adjacencies( allfaces, 1, true, alledges, Interface::UNION );
00109     if( MB_SUCCESS != rval )
00110     {
00111         fprintf( stderr, "Error getting all edges" );
00112 #ifdef MOAB_HAVE_MPI
00113         MPI_Finalize();
00114 #endif
00115         return 1;
00116     }
00117     entities.merge( allfaces );
00118     entities.merge( alledges );
00119     for( EntityType et = MBENTITYSET; et >= MBEDGE; et-- )
00120     {
00121         int num_qualities = vw.num_qualities( et );
00122         if( !num_qualities ) continue;
00123         Range owned = entities.subset_by_type( et );
00124         std::map< QualityType, double > qualities, minq, maxq;
00125         int ne_local  = (int)owned.size();
00126         int ne_global = ne_local;
00127
00128 #ifdef MOAB_HAVE_MPI
00129         int mpi_err;
00130         if( size > 1 )
00131         {
00132             // filter the entities not owned, so we do not process them more than once
00133             ParallelComm* pcomm = ParallelComm::get_pcomm( &mb, 0 );
00134             Range current       = owned;
00135             owned.clear();
00136             rval = pcomm->filter_pstatus( current, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned );
00137             if( rval != MB_SUCCESS )
00138             {
00139                 MPI_Finalize();
00140                 return 1;
00141             }
00142             ne_local = (int)owned.size();
00143             mpi_err  = MPI_Reduce( &ne_local, &ne_global, 1, MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD );
00144             if( mpi_err )
00145             {
00146                 MPI_Finalize();
00147                 return 1;
00148             }
00149         }
00150 #endif
00151         if( ne_global > 0 )
00152         {
00153             if( ne_local > 0 )
00154             {
00155                 Range::iterator it = owned.begin();
00156                 rval               = vw.all_quality_measures( *it, qualities );
00157                 if( MB_SUCCESS != rval )
00158                 {
00159                     fprintf( stderr, "Error getting quality for entity type %d with id %ld \n", et,
00160                              (long)mb.id_from_handle( *it ) );
00161 #ifdef MOAB_HAVE_MPI
00162                     MPI_Finalize();
00163 #endif
00164                     return 1;
00165                 }
00166                 if( ofile.is_open() )
00167                 {
00168                     // write first header or this entity type, then the first values, separated by
00169                     // commas
00170                     ofile << " There are " << ne_local << " entities of type " << vw.entity_type_name( et ) << " with "
00171                           << qualities.size() << " qualities:\n"
00172                           << " Entity id ";
00173                     for( std::map< QualityType, double >::iterator qit = qualities.begin(); qit != qualities.end();
00174                          ++qit )
00175                     {
00176                         ofile << ", " << vw.quality_name( qit->first );
00177                     }
00178                     ofile << "\n";
00179                     ofile << mb.id_from_handle( *it );
00180                     for( std::map< QualityType, double >::iterator qit = qualities.begin(); qit != qualities.end();
00181                          ++qit )
00182                     {
00183                         ofile << ", " << qit->second;
00184                     }
00185                     ofile << "\n";
00186                 }
00187                 minq = qualities;
00188                 maxq = qualities;
00189                 ++it;
00190                 for( ; it != owned.end(); ++it )
00191                 {
00192                     rval = vw.all_quality_measures( *it, qualities );
00193                     if( MB_SUCCESS != rval )
00194                     {
00195                         fprintf( stderr, "Error getting quality for entity type %d with id %ld \n", et,
00196                                  (long)mb.id_from_handle( *it ) );
00197 #ifdef MOAB_HAVE_MPI
00198                         MPI_Finalize();
00199 #endif
00200                         return 1;
00201                     }
00202                     if( ofile.is_open() )
00203                     {
00204                         ofile << mb.id_from_handle( *it );
00205                         for( std::map< QualityType, double >::iterator qit = qualities.begin(); qit != qualities.end();
00206                              ++qit )
00207                         {
00208                             ofile << ", " << qit->second;
00209                         }
00210                         ofile << "\n";
00211                     }
00212                     std::map< QualityType, double >::iterator minit = minq.begin();
00213                     std::map< QualityType, double >::iterator maxit = maxq.begin();
00214                     for( std::map< QualityType, double >::iterator mit = qualities.begin(); mit != qualities.end();
00215                          ++mit, ++minit, ++maxit )
00216                     {
00217                         if( mit->second > maxit->second ) maxit->second = mit->second;
00218                         if( mit->second < minit->second ) minit->second = mit->second;
00219                     }
00220                 }
00221             }
00222             if( 0 == proc_id )
00223             {
00224                 std::cout << " \n\n   " << ne_global << " entities of type " << vw.entity_type_name( et ) << "\n";
00225                 std::cout << std::setw( 30 ) << "Quality Name" << std::setw( 15 ) << "    MIN" << std::setw( 15 )
00226                           << "  MAX"
00227                           << "\n";
00228             }
00229
00230             QualityType quality_type = MB_EDGE_RATIO;
00231             for( int i = 0; i < num_qualities; i++, quality_type = (QualityType)( quality_type + 1 ) )
00232             {
00233                 while( !( vw.possible_quality( et, quality_type ) ) && quality_type < MB_QUALITY_COUNT )
00234                     quality_type = (QualityType)( quality_type + 1 );  // will get them in order
00235                 const char* name_q = vw.quality_name( quality_type );
00236                 double local_min, global_min;
00237                 double local_max, global_max;
00238                 if( ne_local > 0 )
00239                 {
00240                     local_min = minq[quality_type];
00241                     local_max = maxq[quality_type];
00242                 }
00243                 else
00244                 {
00245                     local_min = 1.e38;   // so this task has no entities of this type
00246                     local_max = -1.e38;  // it can get here only in parallel
00247                 }
00248 #ifdef MOAB_HAVE_MPI
00249                 mpi_err = MPI_Reduce( &local_min, &global_min, 1, MPI_DOUBLE, MPI_MIN, 0, MPI_COMM_WORLD );
00250                 if( mpi_err )
00251                 {
00252                     MPI_Finalize();
00253                     return 1;
00254                 }
00255                 mpi_err = MPI_Reduce( &local_max, &global_max, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD );
00256                 if( mpi_err )
00257                 {
00258                     MPI_Finalize();
00259                     return 1;
00260                 }
00261 #else
00262                 global_min = local_min;
00263                 global_max = local_max;
00264 #endif
00265                 if( 0 == proc_id )
00266                 {
00267                     std::cout << std::setw( 30 ) << name_q << std::setw( 15 ) << global_min << std::setw( 15 )
00268                               << global_max << "\n";
00269                 }
00270             }
00271         }
00272     }  // etype
00273     if( ofile.is_open() )
00274     {
00275         ofile.close();
00276     }
00277 #ifdef MOAB_HAVE_MPI
00278     MPI_Finalize();
00279 #endif
00280     return 0;
00281 }
