range_test.cpp File Reference
#include "moab/Range.hpp"
#include "TestUtil.hpp"
+ Include dependency graph for range_test.cpp:
Functions
void insert_hint_test ()
void intersect_test ()
void merge_test ()
void const_pair_iterator_test ()
void swap_test ()
void subtract_test ()
void subset_by_dimension_test ()
void erase_test ()
void contains_test ()
int main ()
Variables
const EntityHandle h1 = CREATE_HANDLE( MBVERTEX, 1 )
const EntityHandle h4 = CREATE_HANDLE( MBVERTEX, 4 )
const EntityHandle h5 = CREATE_HANDLE( MBVERTEX, 5 )
const EntityHandle h9 = CREATE_HANDLE( MBVERTEX, 9 )
const EntityHandle h10 = CREATE_HANDLE( MBVERTEX, 10 )
const EntityHandle h15 = CREATE_HANDLE( MBVERTEX, 15 )
const EntityHandle h16 = CREATE_HANDLE( MBVERTEX, 16 )
const EntityHandle h20 = CREATE_HANDLE( MBVERTEX, 20 )
const EntityHandle hh1 = CREATE_HANDLE( MBHEX, 1 )
const EntityHandle hh3 = CREATE_HANDLE( MBHEX, 3 )
Function Documentation
Definition at line 157 of file range_test.cpp.
References CHECK_EQUAL, moab::Range::const_pair_begin(), h1, h4, h5, and moab::Range::insert().
Referenced by main().
    // const_pair_iterator test
    Range r1;
    r1.insert( h1 );
    r1.insert( h4 );
    r1.insert( h5 );
    Range::const_pair_iterator pair_iter = r1.const_pair_begin();
    EntityHandle cpi_h1                  = ( *pair_iter ).first;
    EntityHandle cpi_h2                  = ( *pair_iter ).second;
    ++pair_iter;
    EntityHandle cpi_h3 = ( *pair_iter ).first;
    EntityHandle cpi_h4 = ( *pair_iter ).second;
    ++pair_iter;
    CHECK_EQUAL( cpi_h1, h1 );
    CHECK_EQUAL( cpi_h2, h1 );
    CHECK_EQUAL( cpi_h3, h4 );
    CHECK_EQUAL( cpi_h4, h5 );
void contains_test ( )
Definition at line 438 of file range_test.cpp.
References CHECK, moab::Range::clear(), moab::Range::contains(), moab::Range::erase(), and moab::Range::insert().
    Range r1, r2;
    // simple test cases: one range each
    r1.clear();
    r2.clear();
    r1.insert( 1, 20 );
    r2.insert( 1, 21 );
    CHECK( !r1.contains( r2 ) );
    CHECK( r2.contains( r1 ) );
    r1.clear();
    r2.clear();
    r1.insert( 2, 20 );
    r2.insert( 1, 20 );
    r1.clear();
    r2.clear();
    r1.insert( 5 );
    r2.insert( 1, 6 );
    r1.clear();
    r2.clear();
    r1.insert( 5 );
    r2.insert( 6 );
    CHECK( !r2.contains( r1 ) );
    r1.clear();
    r2.clear();
    r1.insert( 18 );
    r2.insert( 18 );
    CHECK( r1.contains( r2 ) );
    // empty range test cases
    r1.clear();
    r2.clear();
    r1.clear();
    r2.clear();
    r1.insert( 18 );
    // slightly more complex tests: one range in one container
    // and multiple in the other
    r1.clear();
    r1.insert( 10, 100 );
    r2.clear();
    r2.insert( 20, 30 );
    r2.insert( 40, 50 );
    r2.insert( 10, 12 );
    r2.insert( 90, 100 );
    r2.insert( 9 );
    r2.erase( 9 );
    r2.insert( 101 );
    r2.erase( 101 );
    r2.insert( 103, 110 );
    r2.insert( 1, 5 );
    // most complex case: both containers have several ranges
    r1.clear();
    r1.insert( 10, 30 );
    r1.insert( 40, 50 );
    r1.insert( 90, 100 );
    r2.clear();
    r2.insert( 9 );
    r2.erase( 9 );
    r2.insert( 101 );
    r2.erase( 101 );
    r2.insert( 1, 5 );
void erase_test ( )
Definition at line 275 of file range_test.cpp.
References b, moab::Range::back(), moab::Range::begin(), CHECK, CHECK_EQUAL, moab::Range::clear(), moab::Range::end(), moab::Range::erase(), moab::Range::front(), moab::Range::insert(), and moab::Range::size().
    Range range;
    Range::iterator result;
    // test erase from first node
    range.clear();
    range.insert( 5, 10 );
    range.insert( 12, 20 );
    result = range.erase( range.begin(), range.begin() + 2 );
    CHECK_EQUAL( (EntityHandle)7, range.front() );
    CHECK_EQUAL( (EntityHandle)20, range.back() );
    CHECK_EQUAL( (size_t)13, range.size() );
    CHECK_EQUAL( (EntityHandle)7, *result );
    // test erase first node
    range.clear();
    result = range.erase( range.begin(), range.begin() + 6 );
    CHECK_EQUAL( (EntityHandle)12, range.front() );
    CHECK_EQUAL( (size_t)9, range.size() );
    CHECK_EQUAL( (EntityHandle)12, *result );
    // test erase from back of first node
    range.clear();
    result = range.erase( range.begin() + 2, range.begin() + 6 );
    CHECK_EQUAL( (EntityHandle)5, range.front() );
    CHECK_EQUAL( (size_t)11, range.size() );
    // test erase from middle of first node
    range.clear();
    result = range.erase( range.begin() + 2, range.begin() + 5 );
    CHECK_EQUAL( (size_t)12, range.size() );
    CHECK_EQUAL( (EntityHandle)10, *result );
    // test erase spanning two nodes
    range.clear();
    result = range.erase( range.begin() + 3, range.begin() + 7 );
    CHECK_EQUAL( (EntityHandle)13, *result );
    // test erase of first node and part of second
    range.clear();
    result = range.erase( range.begin(), range.begin() + 7 );
    CHECK_EQUAL( (EntityHandle)13, range.front() );
    CHECK_EQUAL( (size_t)8, range.size() );
    // test erase spanning three nodes
    range.clear();
    range.insert( 100, 101 );
    result = range.erase( range.begin() + 3, range.begin() + 16 );
    CHECK_EQUAL( (EntityHandle)101, range.back() );
    CHECK_EQUAL( (size_t)4, range.size() );
    CHECK_EQUAL( (EntityHandle)101, *result );
    // test erase from start of second node
    range.clear();
    result = range.erase( range.begin() + 6, range.begin() + 8 );
    CHECK_EQUAL( (EntityHandle)14, *result );
    // test erase from back of last node
    range.clear();
    result = range.erase( range.begin() + 13, range.end() );
    CHECK_EQUAL( (EntityHandle)18, range.back() );
    CHECK( result == range.end() );
    // test erase part of first node through end
    range.clear();
    result = range.erase( range.begin() + 4, range.end() );
    CHECK_EQUAL( (EntityHandle)8, range.back() );
    // test erase of single node
    range.clear();
    result = range.erase( range.begin(), range.end() );
    CHECK_EQUAL( (size_t)0, range.size() );
    // test erase of multi-node range
    range.clear();
    // test erase nothing
    range.clear();
    result = range.erase( range.begin() + 3, range.begin() + 3 );
    CHECK_EQUAL( (size_t)15, range.size() );
    CHECK_EQUAL( (EntityHandle)8, *result );
    // test iterators before erase remain valid
    Range::iterator a, b, c;
    range.clear();
    a      = range.begin();
    b      = range.begin() + 6;
    c      = range.begin() + 8;
    result = range.erase( range.begin() + 9, range.end() );
    CHECK( a == range.begin() );
    CHECK( b == range.begin() + 6 );
    CHECK( c == range.begin() + 8 );
    // test iterators before erase remain valid, single value case
    range.clear();
    a      = range.begin();
    result = range.erase( range.begin() + 9 );
    CHECK_EQUAL( (size_t)14, range.size() );
    CHECK_EQUAL( (EntityHandle)16, *result );
void insert_hint_test ( )
Definition at line 31 of file range_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, moab::Range::const_pair_begin(), moab::Range::const_pair_end(), and moab::Range::insert().
    const EntityHandle pairs[][2] = { { 4980, 4981 }, { 4985, 4986 }, { 4990, 4990 }, { 5886, 5886 }, { 5888, 5890 },
                                      { 5890, 5890 }, { 5886, 5888 }, { 5890, 5890 }, { 5894, 5894 }, { 5899, 5899 } };
    const int num_pairs           = sizeof( pairs ) / sizeof( pairs[0] );
    const EntityHandle exp_pairs[][2] = { { 4980, 4981 }, { 4985, 4986 }, { 4990, 4990 },
                                          { 5886, 5890 }, { 5894, 5894 }, { 5899, 5899 } };
    const int num_exp                 = sizeof( exp_pairs ) / sizeof( exp_pairs[0] );
    Range range;
    Range::iterator it = range.begin();
    for( int i = 0; i < num_pairs; ++i )
        it = range.insert( it, pairs[i][0], pairs[i][1] );
    Range::const_pair_iterator pit = range.const_pair_begin();
    for( int i = 0; i < num_exp; ++i )
        CHECK( pit != range.const_pair_end() );
        CHECK_EQUAL( exp_pairs[i][0], pit->first );
        CHECK_EQUAL( exp_pairs[i][1], pit->second );
        ++pit;
    CHECK( pit == range.const_pair_end() );
void intersect_test ( )
Definition at line 68 of file range_test.cpp.
References CHECK, CHECK_EQUAL, moab::Range::clear(), moab::Range::empty(), h1, h10, h15, h16, h20, h4, h5, h9, moab::Range::insert(), moab::intersect(), and moab::Range::size().
    Range r1, r2, rhs;
    // equal start/end
    r1.insert( h1, h5 );
    r1.insert( h10, h15 );
    r2.insert( h5, h10 );
    r2.insert( h15, h20 );
    rhs = intersect( r1, r2 );
    CHECK_EQUAL( (size_t)3, rhs.size() );
    // identical ranges test
    r1.clear();
    r2.clear();
    rhs.clear();
    r1.insert( h10, h20 );
    r2.insert( h1, h5 );
    r2.insert( h10, h20 );
    CHECK_EQUAL( r1.size(), rhs.size() );
    CHECK_EQUAL( r2.size(), rhs.size() );
    // off by one test
    r1.clear();
    r2.clear();
    rhs.clear();
    r1.insert( h1, h4 );
    r2.insert( h5, h9 );
    r2.insert( h16, h20 );
    CHECK( rhs.empty() );
    // interior test
    r1.clear();
    r2.clear();
    rhs.clear();
    r1.insert( h1, h20 );
    // half-above test
    r1.clear();
    r2.clear();
    rhs.clear();
    r1.insert( h1, h10 );
    r2.insert( h5, h20 );
    CHECK_EQUAL( (size_t)( h10 - h5 + 1 ), rhs.size() );
    // half-below test
    r1.clear();
    r2.clear();
    rhs.clear();
    r1.insert( h5, h20 );
    r2.insert( h1, h10 );
void merge_test ( )
Definition at line 131 of file range_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, moab::Range::clear(), moab::Range::end(), h1, h10, h15, h5, moab::Range::insert(), moab::Range::merge(), and moab::Range::size().
    Range r1, r2;
    // merge all test
    r1.clear();
    r2.clear();
    r2 = r1;
    r1.merge( r2 );
    CHECK_EQUAL( r2.size(), r1.size() );
    // merge subset test
    r1.clear();
    r2.clear();
    Range::const_iterator i1 = r1.begin();
    Range::const_iterator i2 = r1.end();
    i1 += 2;
    i2 -= 2;
    r2.merge( i1, i2 );
    CHECK_EQUAL( r1.size() - 4, r2.size() );
Definition at line 260 of file range_test.cpp.
References moab::Range::back(), CHECK_EQUAL, moab::Range::front(), h1, h4, hh1, hh3, moab::Range::insert(), moab::Range::size(), and moab::Range::subset_by_dimension().
    Range r1, r2;
    // subset_by_dimension test
    r1.insert( h1 );
    r1.insert( h4 );
    r1.insert( hh1 );
    r1.insert( hh3 );
    r2 = r1.subset_by_dimension( 3 );
    CHECK_EQUAL( (size_t)2, r2.size() );
    CHECK_EQUAL( hh1, r2.front() );
    CHECK_EQUAL( hh3, r2.back() );
void subtract_test ( )
Definition at line 231 of file range_test.cpp.
References CHECK, CHECK_EQUAL, moab::Range::clear(), moab::Range::end(), moab::Range::find(), h1, h4, h5, moab::Range::insert(), moab::Range::size(), and moab::subtract().
    Range r1, r2, r3;
    r1.clear();
    r2.clear();
    r1.insert( h1 );
    r1.insert( h4 );
    r1.insert( h5 );
    r2.insert( h4 );
    r3 = subtract( r1, r2 );
    CHECK_EQUAL( (size_t)2, r3.size() );
    CHECK( r3.find( h1 ) != r3.end() );
    CHECK( r3.find( h5 ) != r3.end() );
    CHECK( r3.find( h4 ) == r3.end() );
    // destination empty
    r1.clear();
    r2.clear();
    r1.insert( h1 );
    r1.insert( h4 );
    r1.insert( h5 );
    CHECK_EQUAL( (size_t)3, r3.size() );
    CHECK( r3.find( h4 ) != r3.end() );
void swap_test ( )
Definition at line 178 of file range_test.cpp.
References CHECK, CHECK_EQUAL, moab::Range::clear(), moab::Range::empty(), moab::Range::end(), moab::Range::find(), h1, h4, h5, h9, moab::Range::insert(), moab::Range::size(), and moab::Range::swap().
    Range r1, r2;
    // both non-empty
    r1.clear();
    r2.clear();
    r1.insert( h1 );
    r1.insert( h4 );
    r1.insert( h5 );
    r2.insert( h9 );
    r1.swap( r2 );
    CHECK_EQUAL( (size_t)1, r1.size() );
    CHECK_EQUAL( (size_t)3, r2.size() );
    CHECK( r1.find( h9 ) != r1.end() );
    CHECK( r2.find( h1 ) != r2.end() );
    CHECK( r2.find( h4 ) != r2.end() );
    CHECK( r2.find( h5 ) != r2.end() );
    r1.clear();
    r2.clear();
    r2.insert( h1 );
    r2.insert( h4 );
    r2.insert( h5 );
    r1.swap( r2 );
    CHECK_EQUAL( (size_t)3, r1.size() );
    CHECK_EQUAL( (size_t)0, r2.size() );
    CHECK( r1.find( h1 ) != r1.end() );
    CHECK( r1.find( h4 ) != r1.end() );
    CHECK( r1.find( h5 ) != r1.end() );
    // source empty
    r1.clear();
    r2.clear();
    r1.insert( h1 );
    r1.insert( h4 );
    r1.insert( h5 );
    r1.swap( r2 );
    CHECK_EQUAL( (size_t)0, r1.size() );
    // both empty
    r1.clear();
    r2.clear();
    r1.swap( r2 );
    CHECK( r1.empty() );
    CHECK( r2.empty() );
Variable Documentation
Definition at line 61 of file range_test.cpp.
Referenced by intersect_test(), and merge_test().
Definition at line 62 of file range_test.cpp.
Definition at line 63 of file range_test.cpp.
Referenced by intersect_test().
Definition at line 64 of file range_test.cpp.
Definition at line 60 of file range_test.cpp.
Referenced by intersect_test(), and swap_test().
Definition at line 65 of file range_test.cpp.
Referenced by subset_by_dimension_test().
Definition at line 66 of file range_test.cpp.
