MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
#include "MBTagConventions.hpp"
#include "InitCGMA.hpp"
#include "GeometryQueryTool.hpp"
#include "ReadCGM.hpp"
#include "moab/FileOptions.hpp"
Defines | |
#define | IS_BUILDING_MB |
#define | OPTION_APPEND(X) |
Functions | |
void | read_file (Interface *moab, const char *input_file) |
void | test_cube_curve_facet () |
void | test_cone_curve_facet () |
void | read_file (Interface *moab, bool curve_fatal, const char *input_file, ErrorCode check_val, int &curve_fail, int &surface_fail) |
int | main (int, char **) |
Variables | |
std::string | input_cube = "unittest/io/cube.sat" |
std::string | input_cone = "unittest/io/cone.sat" |
#define IS_BUILDING_MB |
Definition at line 4 of file read_cgm_facet_test.cpp.
#define OPTION_APPEND | ( | X | ) |
{ \ if( options.length() ) options += ";"; \ options += ( X ); \ }
int main | ( | int | , |
char ** | |||
Definition at line 101 of file read_cgm_facet_test.cpp.
References RUN_TEST, test_cone_curve_facet(), and test_cube_curve_facet().
{ int result = 0; result += RUN_TEST( test_cube_curve_facet ); #ifndef HAVE_OCC_STEP result += RUN_TEST( test_cone_curve_facet ); #endif return result; }
Definition at line 57 of file read_cgm_basic_test.cpp.
References CHECK_ERR, ErrorCode, and moab::Interface::load_file().
{ InitCGMA::initialize_cgma(); GeometryQueryTool::instance()->delete_geometry(); ErrorCode rval = moab->load_file( input_file );CHECK_ERR( rval ); }
void read_file | ( | Interface * | moab, |
bool | curve_fatal, | ||
const char * | input_file, | ||
ErrorCode | check_val, | ||
int & | curve_fail, | ||
int & | surface_fail | ||
Definition at line 35 of file read_cgm_facet_test.cpp.
References CHECK_EQUAL, ErrorCode, and OPTION_APPEND.
{ InitCGMA::initialize_cgma(); GeometryQueryTool::instance()->delete_geometry(); EntityHandle fs = 0; // set the options std::string options; #define OPTION_APPEND( X ) \ { \ if( options.length() ) options += ";"; \ options += ( X ); \ } OPTION_APPEND( "CGM_ATTRIBS=no" ); if( curve_fatal ) OPTION_APPEND( "FATAL_ON_CURVES" ); OPTION_APPEND( "VERBOSE_CGM_WARNINGS" ); // set the file options FileOptions opts( options.c_str() ); // new ReadCGM instance ReadCGM* RCGM = new ReadCGM( moab ); ErrorCode rval = RCGM->load_file( input_file, &fs, opts ); // CHKERR(rval); curve_fail = RCGM->get_failed_curve_count(); surface_fail = RCGM->get_failed_surface_count(); // std::cout << curve_fail << " " << surface_fail << std::endl; CHECK_EQUAL( rval, check_val ); CHECK_EQUAL( curve_fail, 0 ); CHECK_EQUAL( surface_fail, 0 ); }
void test_cone_curve_facet | ( | ) |
Definition at line 89 of file read_cgm_facet_test.cpp.
References input_cone, mb, and read_file().
Referenced by main().
{ // Open the test file Core moab; Interface* mb = &moab; int curve_fail = 0; int surface_fail = 0; // should expect MB_FAILURE since we fail on curves read_file( mb, true, input_cone.c_str(), MB_FAILURE, curve_fail, surface_fail ); }
void test_cube_curve_facet | ( | ) |
Definition at line 76 of file read_cgm_facet_test.cpp.
References input_cube, mb, MB_SUCCESS, and read_file().
{ // Open the test file Core moab; Interface* mb = &moab; int curve_fail = 0; int surface_fail = 0; // should succeed since we are not fatal error on curves read_file( mb, false, input_cube.c_str(), MB_SUCCESS, curve_fail, surface_fail ); }
std::string input_cone = "unittest/io/cone.sat" |
Definition at line 25 of file read_cgm_facet_test.cpp.
Referenced by test_cone_curve_facet().
std::string input_cube = "unittest/io/cube.sat" |
Definition at line 19 of file read_cgm_facet_test.cpp.
